| 1 | How many master devices can exist in one HART communication loop? |
| 2 | Which type of flow meter uses the principle of Bernoulli’s equation? |
| 3 | What does the letter “A” represent in the “HART” protocol? |
| 4 | What type of control action anticipates disturbance before it affects? |
| 5 | In cascade control, secondary loop primarily improves which performance aspect of the main control loop? |
| 6 | In a feedback loop, what is the primary purpose of comparing PV with SP? |
| 7 | If transmitter fails but controller is active, what happens to loop? |
| 8 | In a control loop, error is defined as the difference between which two parameters? |
| 9 | The force applied to a strain gauge causes it to bend and ___ |
| 10 | Alphatron measures pressure ___ microns |
| 11 | Refer to the simplified drawing of a control rod position detector circuit ___ |
| 12 | Reed switches are being used in an electrical measuring circuit to monitor the position of a control rod in a reactor ___ |
| 13 | Which one of the following devices is commonly used to provide remote indication of valve position on an analog meter in units of “percent of full open” ___ |
| 14 | What type of sensor is most commonly used to provide remote position indication of a valve that is normally either fully open or fully closed ___ |
| 15 | Refer to the drawing of a simple chromel-alumel thermocouple circuit. Initially, the temperature instrument indicates 350°F ___ |
| 16 | Refer to the drawing of a simple chromel-alumel thermocouple circuit. The thermocouple, thermocouple connection head, and reference junction panel are located inside a reactor building (RB), while the temperature instrument is located outside the RB ___ |
| 17 | Because of a thermocouple temperature display failure, the millivolt output of a thermocouple circuit is being converted to a temperature value using conversion tables. The tables are based on a thermocouple reference ___ |
| 18 | Because of a thermocouple temperature display failure, the millivolt output of a thermocouple circuit is being converted to a temperature value using conversion tables ___ |
| 19 | Refer to the drawing of a simple chromel-alumel thermocouple circuit. The thermocouple, thermocouple connection head, and reference junction panel are located inside a reactor building (RB) while the temperature instrument is located outside the RB ___ |
| 20 | Refer to the drawing of a simple thermocouple circuit. Given that the temperatures at the measuring and reference junctions remain constant ___ |
| 21 | Refer to the drawing of a simple thermocouple circuit. A thermocouple temperature indication is initially 390°F ___ |
| 22 | Refer to the drawing of a simple thermocouple circuit that is calibrated for a reference junction temperature of 90°F ___ |
| 23 | Refer to the drawing of a simple thermocouple circuit. A thermocouple temperature indication is initially 150°F ___ |
| 24 | Refer to the drawing of a simple thermocouple circuit. A thermocouple temperature indication is initially 350°F ___ |
| 25 | An operator suspects that a steam temperature instrument reading is not correct ___ |
| 26 | If shorting occurs within a resistance temperature detector, the associated indication will fail ___ |
| 27 | A resistance temperature detector (RTD) is used in a balanced bridge circuit to indicate temperature ___ |
| 28 | A simple two-wire resistance temperature detector (RTD) is being used to measure the temperature in a water system ___ |
| 29 | For proper operation of a thermocouple circuit, the reference junction temperatue ___ |
| 30 | Refer to the drawing of a simple thermocouple circuit. The measuring junction temperature is currently 300°F while the reference junction temperature is being held constant at 120°F ___ |
| 31 | A resistance temperature detector (RTD) and a thermocouple (TC) are commonly used sensors for temperature measurement ___ |
| 32 | A simple two-wire resistance temperature detector (RTD) is being used to measure the temperature of a water system ___ |
| 33 | Refer to the drawing of a simple chromel-alumel thermocouple circuit. What is the effect on the thermocouple reference junctions if the copper extension wires from the ___ |
| 34 | Which one of the following is a characteristic of a resistance temperature detector but not a thermocouple ___ |
| 35 | Refer to the drawing of a simple chromel-alumel thermocouple circuit. What is the effect on the thermocouple reference junctions if the chromel and alumel extension wires from the thermocouple connection head to the ___ |
| 36 | Refer to the drawing of a simple thermocouple circuit. The measuring and reference junctions are located inside the reactor containment building while the instrument is located in a remote location outside the containment building ___ |
| 37 | Refer to the drawing of a simple thermocouple circuit. A thermocouple temperature indication is initially 410°F with the reference (cold) junction at 125°F ___ |
| 38 | Unlike a resistance temperature detector, a typical thermocouple ___ |
| 39 | Refer to the drawing of a simple thermocouple circuit ___ |
| 40 | In contrast to a thermocouple, a resistance temperature detector ___ |
| 41 | Which one of the following describes a characteristic of a thermocouple ___ |
| 42 | A bourdon-tube pressure detector was indicating 50 percent of scale when it was suddenly exposed to a high pressure transient that caused permanent strain to the bourdon tube ___ |
| 43 | Which one of the following parameters requires square root compensation when measured by a differential pressure detector ___ |
| 44 | A cooling water system pressure detector uses a bourdon tube as the sensing element. Which one of the following explains how the indicated system pressure will be affected if ___ |
| 45 | A cooling water system pressure detector uses a bourdon tube as the sensing element ___ |
| 46 | The pressure within a cooling water system is 100 psig, as indicated by a bourdon tube pressure detector ___ |
| 47 | A properly calibrated 0 to 100 psia diaphragm pressure detector is connected to a pressurized system; the low pressure side of the detector is vented to the atmosphere ___ |
| 48 | Refer to the drawing of a bellows-type pressure detector ___ |
| 49 | A cooling water system bourdon tube pressure detector is located inside a sealed building and system pressure currently indicates 50 psig ___ |
| 50 | Cooling water system pressure is being monitored by a simple diaphragm pressure detector with its low pressure side vented to the containment ___ |
| 51 | A simple bellows pressure detector is connected to a cooling water system ___ |
| 52 | A centrifugal pump is taking suction from the bottom of a vented cylindrical storage tank that contains 100,000 gallons of water at 60°F ___ |
| 53 | A bourdon tube works on the principle that when the pressure inside the tube decreases, the tube tends to ___ |
| 54 | Refer to the drawing of a bellows-type differential pressure (D/P) detector. The spring in this detector (shown in a compressed state) has weakened from long-term use ___ |
| 55 | If the pressure sensed by a bourdon tube increases, the curvature of the detector will ___ because the greater force is being applied to the ___ curve of the detector |
| 56 | Refer to the drawing of a reactor vessel (RV) differential pressure (D/P) level detection system (see figure below). A reactor is shutdown with the reactor coolant system being maintained at 100 psia ___ |
| 57 | Refer to the drawing of a reactor vessel (RV) differential pressure (D/P) level detection system. The reactor vessel is supplying steam at normal operating ___ |
| 58 | Refer to the drawing of a reactor vessel differential pressure (D/P) level detection system that was calibrated at normal operating conditions. A reactor vessel cooldown has resulted in a decrease in reactor vessel pressure ___ |
| 59 | Refer to the drawing of a reactor vessel differential pressure (D/P) level detection system. Which one of the following events will result in a reactor vessel level indication that is greater than actual level ___ |
| 60 | Refer to the drawing of a reactor vessel differential pressure (D/P) level detection system. Which one of the following will result in the lowest reactor vessel level indication ___ |
| 61 | Refer to the drawing of a reactor vessel (RV) differential pressure (D/P) level detection system. Which one of the following events will result in a reactor vessel level indication that is greater than actual level ___ |
| 62 | Refer to the drawing of a reactor vessel differential pressure (D/P) level detection system. The D/P detector was calibrated at the current conditions ___ |
| 63 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detection system. Which one of the following failures will cause the lowest stable water level indication? |
| 64 | Reactor feedwater flow and vessel level detectors use differential pressure (D/P) cells to measure flow and level. If a level D/P cell diaphragm fails, the level indication ___ |
| 65 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detection system. The level instrument has just been calibrated to ___ |
| 66 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detection system. Assume that the initial temperature of the reference leg and the water in the tank are the ___ |
| 67 | Refer to the drawing of a reactor vessel level detection system ___ |
| 68 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detector. The level detector is being used in a level control system that is calibrated to maintain tank level at ___ |
| 69 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detector. The level detector is being used in a level control system that is ___ |
| 70 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detection system. A calibrated D/P level detector is being used to ___ |
| 71 | Refer to the drawing of two water storage tanks with four differential pressure (D/P) level detectors |
| 72 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detection system. Tank water level indication will be lower than actual level when reference leg temperature is ___ |
| 73 | Refer to the drawing of two water storage tanks with four differential pressure (D/P) level detectors ___ |
| 74 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detection system. The level detector has just been calibrated ___ |
| 75 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detection system. The water storage tank is 40 feet tall ___ |
| 76 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detection system. The D/P level detector was just calibrated and returned to operation with the following conditions ___ |
| 77 | Refer to the drawing of a differential pressure (D/P) level detection system for a reactor vessel at normal operating temperature and pressure. The level detector has just been calibrated ___ |
| 78 | The downcomer region of a reactor vessel contains 40 feet of saturated water at 536°F ___ |
| 79 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detection system ___ |
| 80 | Refer to the drawing of a water storage tank with two tank differential pressure (D/P) level indicators ___ |
| 81 | A cooling water system is cooling a lube oil heat exchanger ___ |
| 82 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detection system. The D/P sensed by the detector varies in the ___ direction as the temperature of the water in the tank if the ___ |
| 83 | Many reactor vessel water level instruments are designed with a condensing chamber in the reference leg ___ |
| 84 | Refer to the drawing of a reactor vessel differential pressure (D/P) level detection system ___ |
| 85 | Refer to the drawing of a differential pressure (D/P) level detection system for a reactor vessel at normal operating temperature and pressure ___ |
| 86 | Refer to the drawing of a water storage tank with two differential pressure (D/P) level indicators. Indicator 1 was calibrated at 120°F and indicator 2 was calibrated at 180°F. If tank water temperature is ___ |
| 87 | Refer to the drawing of a reactor vessel differential pressure (D/P) level detection system that was recently calibrated at normal operating conditions ___ |
| 88 | Refer to the drawing of a reactor vessel (RV) differential pressure (D/P) level detection system that was recently calibrated at normal operating conditions ___ |
| 89 | A reactor is currently shut down at 180°F. Reactor vessel (RV) level is being monitored using a differential pressure detector with a wet reference leg ___ |
| 90 | Refer to the drawing of a reactor vessel differential pressure (D/P) level detection system that was calibrated at 500 psia ___ |
| 91 | Refer to the drawing of a reactor vessel differential pressure (D/P) level detection system that was calibrated at 1,000 psia ___ |
| 92 | Refer to the drawing of a water storage tank with two differential pressure (D/P) level indicators (see figure below). Indicator 1 was calibrated at 180°F and indicator 2 was calibrated at 120°F ___ |
| 93 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detector. The level detector is being used in a level control system that was calibrated to maintain tank level at 80 percent at the ___ |
| 94 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detector that was recently calibrated at a tank water temperature of 80°F. If the mass of the water in the tank remains the same while the tank water temperature is ___ |
| 95 | Refer to the drawing of a water storage tank with two differential pressure (D/P) level indicators. Two D/P level indicators are installed on a large water storage tank ___ |
| 96 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detector. The associated level instrument was calibrated with the water ___ |
| 97 | Two differential pressure level transmitters are installed on a large water storage tank ___ |
| 98 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detector. The associated level instrument was calibrated with the ___ |
| 99 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detection system (see figure below). The level detector is being used in a level control system that was calibrated to maintain tank level at 80 percent when the ___ |
| 100 | Refer to the drawing of a water storage tank with two differential pressure (D/P) level indicators. Indicator 1 was calibrated at 120°F and indicator 2 was calibrated at 180°F ___ |
| 101 | Refer to the drawing of a water storage tank with two differential pressure (D/P) level indicators ___ |
| 102 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detector ___ |
| 103 | Refer to the drawing of a reactor vessel (RV) differential pressure (D/P) level detection system ___ |
| 104 | A differential pressure detector is being used with an orifice plate to measure water flow rate through a pipe. When the flow instrument was last calibrated, the ___ |
| 105 | A steam flow measuring instrument uses density compensation and square root extraction to convert the differential pressure across the flow element to flow rate in lbm/hr ___ |
| 106 | Refer to the drawing of a horizontal pipe elbow (top view) in an operating water system. Three separate bellows-type differential pressure flow detectors are connected to taps A, B, C, and D as follows ___ |
| 107 | Refer to the drawing of a pipe elbow used for flow measurement in a cooling water system. A differential pressure (D/P) flow detector is properly connected to instrument lines A and C ___ |
| 108 | A cooling water system is operating at a steady-state flow rate of 400 gpm with 60 psid across the flow transmitter venturi. If cooling water flow rate is increased to 600 gpm, differential pressure across the ___ |
| 109 | A cooling water system is operating at a steady-state flow rate of 400 gpm with 60 psid across the flow transmitter venturi ___ |
| 110 | A differential pressure detector is being used with an orifice plate to measure water flow rate through a pipe ___ |
| 111 | Refer to the drawing of a horizontal pipe elbow (top view) in an operating water system. Three separate bellows differential pressure flow detectors are connected to taps A, B, C, and D as follows ___ |
| 112 | Refer to the drawing of a pipe elbow used for flow measurement in a cooling water system. A differential pressure (D/P) flow detector is connected to instrument lines A and B ___ |
| 113 | A cooling water system is operating at a steady-state flow rate of 500 gpm with 60 psid across the flow transmitter venturi ___ |
| 114 | Refer to the drawing of a pipe elbow used for flow measurement in a cooling water system ___ |
| 115 | Water is flowing through each of the following devices ___ |
| 116 | Refer to the drawing of a horizontal pipe elbow (top view) in an operating water system ___ |
| 117 | Refer to the drawing of a pipe elbow (top view) in an operating water system. At which one of the following pairs of connection points will the greatest differential pressure be sensed ___ |
| 118 | Flow rate in a cooling water system, measured using a differential pressure (D/P) detector, indicates 100 gpm at a D/P of 30 psid. If indicated flow rate increases to 150 gpm, what D/P is being sensed by the detector ___ |
| 119 | If the flow rate through a differential pressure (D/P) detector flow nozzle doubles, by what factor would the D/P increase ___ |
| 120 | Refer to the drawing of a pipe elbow (top view) in an operating water system. At which one of the following locations is the highest pressure sensed ___ |
| 121 | Refer to the drawing of a pipe elbow (top view) in an operating water system ___ |
| 122 | A steam flow measuring instrument uses density compensation and square root compensation to convert the differential pressure across a flow element to flow rate in lbm/hr ___ |
| 123 | The flow rate of water passing through a venturi can be determined by measuring the ___ |
| 124 | How will flow rate indication be affected if the equalizing valve for the associated differential pressure detector is fully opened ___ |
| 125 | An orifice is being used in an operating cooling water system to measure flow rate ___ |
| 126 | A flow instrument for an operating cooling water system was calibrated with the differential pressure flow detector equalizing valve slightly open ___ |
| 127 | If the orifice in a differential pressure (D/P) flow sensor erodes such that the orifice opening becomes larger, indicated flow rate will ___ due to a ___ D/P across the orifice |
| 128 | Which one of the following will cause indicated liquid flow rate to be higher than actual flow rate when using a differential pressure (D/P) flow detector with a calibrated orifice ___ |
| 129 | Flow rate is being measured using a differential pressure flow detector and a calibrated orifice ___ |
| 130 | A differential pressure flow detector is connected to a calibrated orifice in a cooling water system ___ |
| 131 | A differential pressure (D/P) cell is being used to measure flow rate in a cooling water system ___ |
| 132 | A leak develops in the high-pressure side of a flow detector. What effect does the leak have on the affected flow indication ___ |
| 133 | A nuclear power plant is initially operating with the following main steam parameter values ___ |
| 134 | A main steam flow rate differential pressure detector was properly calibrated to produce a main steam flow rate indication of 500,000 lbm/hr with the following initial input conditions ___ |
| 135 | If the steam pressure input to a density-compensated steam flow instrument fails high, the associated flow rate indication will ___ |
| 136 | Density input is normally used in steam flow instruments to convert ___ into ___ |
| 137 | The density compensating input to a steam flow instrument is used to convert volumetric flow rate into ___ |
| 138 | If the density input to a density-compensated steam flow instrument rapidly fails high, the indicated flow will ___ |
| 139 | The change in pressure across a main steam line flow element is ___ |
| 140 | Refer to the drawing of a frictionless venturi flow element. Subcooled water is flowing through the venturi with the ___ |
| 141 | Refer to the drawing of a frictionless venturi flow element. Subcooled water is flowing through the venturi with the following initial conditions ___ |
| 142 | Refer to the drawing of a frictionless venturi flow element ___ |
| 143 | For water flowing through a venturi, there is a proportional relationship between flow rate and differential pressure ___ |
| 144 | A cooling water system uses a horizontal venturi with a differential pressure flow detector to provide flow rate indication. Water enters and leaves the venturi at ___ |
| 145 | The following is the current calibration data for an orifice plate that is being used for water flow rate measurement ___ |
| 146 | Refer to the drawing of a venturi flow element in an operating cooling water system. At what point does the lowest pressure exist ___ |
| 147 | A cooling water system uses a horizontal venturi with a differential pressure flow detector to provide flow rate indication ___ |
| 148 | A differential pressure detector is being used with an orifice plate to measure water flow rate through a pipe. When the flow detector was last calibrated, the following parameters were observed ___ |
| 149 | A main steam flow rate measuring instrument uses a steam pressure input to produce main steam mass flow rate indication. Assuming steam volumetric flow rate does not change, a steam pressure decrease will cause indicated steam mass flow rate to ___ |
| 150 | A venturi is being used to measure the flow rate in a cooling water system. As the water flows from the throat to the discharge of the venturi, water pressure will ___; and volumetric flow rate will ___ |
| 151 | A cooling water system is operating at a steady-state flow rate of 700 gpm with 60 psid across the associated venturi flow element ___ |
| 152 | Which one of the following flow measuring elements produces the largest unrecoverable head loss when used in an operating fluid system ___ |
| 153 | A cooling water system is operating at steady-state conditions. A calibrated system flow meter indicates 600 gpm with 50 psid across the flow element ___ |
| 154 | Refer to the drawing of a venturi flow element in an operating cooling water system ___ |
| 155 | Refer to the drawing of a venturi flow element (see figure below) with direction of water flow indicated by the arrow ___ |
| 156 | A cooling water system is operating at a steady-state flow rate of 700 gpm with 60 psid across the flow transmitter venturi. If cooling water flow rate is increased to 1,000 gpm, differential pressure across the flow transmitter venturi will be ___ |
| 157 | As water flows through a venturi flow element, the ___ pressure and the ___ velocity of the fluid occurs at the throat of the venturi |
| 158 | Refer to the drawing of a convergent-divergent venturi (see figure below). Subcooled water is flowing through the venturi, and the pipe diameters at P1 and P2 are equal ___ |
| 159 | A cooling water system is operating at steady-state conditions indicating 900 gpm with 60 psid across the flow transmitter venturi. If cooling water flow rate is increased to 1,800 gpm, differential pressure ___ |
| 160 | What happens to the pressure and velocity of water as it passes through a venturi ___ |
| 161 | If the pressure in a closed vessel is greater than the atmospheric pressure (the outside air), then a ___ switch is used to monitor the exact pressure inside the vessel |
| 162 | If the pressure inside a closed vessel is less than the atmospheric pressure, then a ___ switch is used to monitor the lack of pressure inside the vessel |
| 163 | Solid-state devices, which are used to sense pressure, include pressure transducers and load cells ___ |
| 164 | The ___ switch has the advantage over the mechanical limit or liquid-level switch, in that physical contact of the medium being sensed is not required |
| 165 | The typical mechanical limit switch has an operator head that will accept several different types of ___ |
| 166 | The capillary-type temperature switch is actually a pressure switch ___ |
| 167 | A ___ switch is employed to monitor the position of a liquid according to the depth of the containing vessel, whereas a ___ switch is employed to sense the flow of a fluid in a pipe or conduit or an open channel |
| 168 | Proximity switches are solid-state devices that can use ___ or ___ to sense the presence of a material, either its position or fluid level |
| 169 | Temperature switches normally use the expansion of heated metals or fluids to sense a change in temperature ___ |
| 170 | Float or liquid-level switches, like most pilot devices, normally contain both a set of NO and a set of NC contacts ___ |
| 171 | A ___ switch is employed to monitor the position of a liquid according to the depth of the containing vessel |
| 172 | In addition to On/Off control, temperature controllers offer other refinements or regulation that will monitor the rate at which the temperature of the air or material is heating (or cooling) to prevent overheating (or overcooling) ___ |
| 173 | ___ switches sense the flow of a fluid in a pipe or conduit or an open channel. These sensing devices are often referred to as ___ switches because the operator appears to be a sail as used on a boat |
| 174 | A difference of pressure is normally sensed by the deflection of metal. In low-pressure applications, a ___ is used to monitor the change in pressure |
| 175 | A ___ consists of two dissimilar metals that have been fused to each other along their length |
| 176 | In low-pressure applications, a ___ tube is used to monitor the change in pressure |
| 177 | ___ switches monitor liquid levels in many manufacturing processes |
| 178 | A long strip of bimetallic material can be wound into a sort of loose clock-spring appearance, such that a(n) ___ in temperature will tend to unwind the spring (___ -tube principle with pressure), whereas a(n) ___ |
| 179 | A transducer is a device that is used to ____ |
| 180 | The deflection of the free end of the bimetallic strips in a bimetallic thermometer with temperature is nearly ___ |
| 181 | An ideal PID controller has the transfer function ___ |
| 182 | The transfer function for a first order process with time delay is ___ |
| 183 | What is the dynamic error in a critically damped second order instrument for a ramp input (At) ___ |
| 184 | Which of the systems having following transfer functions is stable ___ |
| 185 | Liquid argon level in a pressurised storage tank is measured by a/an ___ |
| 186 | Starting temperature of optical radiation pyrometer is ___ °C |
| 187 | ___ thermometer can not measure sub-zero (< 0° C) temperature, |
| 188 | The characteristic equation for the control system with a closed loop ___ |
| 189 | Transfer functions X/Y for which of the following block diagrams is ___ |
| 190 | The ___ of the fluid contained in the temperature sensing element (i.e., bulb) of filled system thermometers changes with change in temperature |
| 191 | Pirani gauge is used for the measurement of ___ |
| 192 | Pressure of 0.0001 absolute psi can be measured by ___ gauge |
| 193 | For increased speed of response of an expansion pressure spring thermometer, the thermometer bulb should have a ___ |
| 194 | An amplitude ratio of 0.1 corresponds to ___ decibels |
| 195 | Paramagnetism method is not used for the composition determination of ___ in gases |
| 196 | The temperature range for which copper resistance thermometer can be used is ___ °C |
| 197 | Which of the following can not measure a temperature of 1600°C ___ |
| 198 | In a single tank system, the transfer function of ___ to inlet flow rate is 1/TS+1 |
| 199 | Concentration of sugar solution can be determined by the ___ |
| 200 | Which of the following filled system expansion thermometer has the capability to measure the lowest temperature ___ |
| 201 | Which thermocouple can be used to measure a temperature of around 1400°C ___ |
| 202 | Feed forward controller accounts for the ___ changes |
| 203 | “A control system is unstable, if the open loop frequency response exhibits an amplitude ratio exceeding unity at the crossover frequency ___ |
| 204 | Identify an unbounded input from inputs whose transfer functions are given below ___ |
| 205 | Flow rate of those fluids which are insensitive to changes in their density, viscosity or flow velocity profile can be best measured by a ___ |
| 206 | Which of the following thermocouple materials does not contain nickel ___ |
| 207 | Flow rate of a river is measured by a/an ___ |
| 208 | The fluid used in hydraulic controller is ___ |
| 209 | Measurement of pressure in ammonia reactor is done by ___ |
| 210 | Resistance of a gas in a vessel is given by ___ |
| 211 | In a closed loop system, the process to be controlled is an integrating process with transfer function l/2s ___ |
| 212 | According to Bode stability criterian, a system is unstable, if the open loop frequency response exhibits an amplitude ratio exceeding unity at frequency for which phase lag is ___ |
| 213 | Thermodynamic celcius scale of temperature measurement is ___ |
| 214 | Configuration of Bourdon spring tube is never made of ___ shape |
| 215 | Relationship between absorption/evolution of heat at the thermocouple junctions and the current flow in the circuit is given by ___ effect |
| 216 | Accurate temperature measurement performance of a radiation pyrometer can not be affected, if the ___ |
| 217 | Pick out the most suitable instrument for measuring temperature in the range of-40 to 425°C ___ |
| 218 | What is the overall transfer function (C/R) of the following block diagram if ___ |
| 219 | Nitrogen gas constant volume thermometer is suitable for measuring a temperature of ___ °C |
| 220 | A sinusoidal variation in the input passing through a linear first order system |
| 221 | The time constant of a first order process with resistance R and capacitance C is ___ |
| 222 | The ___ of a vapor pressure thermometer is a primary element |
| 223 | The initial value (t=0) of the unit step response of the transfer function [(s + 1)/(2s + 1)] is ___ |
| 224 | Range of hydrogen gas constant volume themometer is ___ °C |
| 225 | Choose out the wrong statement ___ |
| 226 | Strain gage uses an electrical conductor wire, which when elastically stretched increases in length and reduces in diameter ___ |
| 227 | Working principle of disappearing filament type optical pyrometer is based on the ___ |
| 228 | Bode diagram is a plot of ___ |
| 229 | The transfer function for a P-D controller is ___ |
| 230 | Thermocouple in a thermal well behaves as a true ___ |
| 231 | Humidity of air can be determined by a ___ |
| 232 | A barometer measures the ___ pressure |
| 233 | Thermistors are made of ___ |
| 234 | Degree to which an instrument indicates the changes in measured variable without dynamic error is called its ___ |
| 235 | Which of the following thermometers is not suitable for distant reading upto 60 metres ___ |
| 236 | Dead zone is the ___ |
| 237 | ___ temperature scale assigns 0° to the ‘ice point’ and 80° to the ‘steam point’ |
| 238 | Specific gravity of a liquid can not be measured by a/an ___ |
| 239 | Liquid flow rate in a small channel is best measured by a/an ___ |
| 240 | Radiation pyrometers as compared to thermocouples ___ |
| 241 | Which of the following thermocouples can measure the maximum temperature ___ |
| 242 | Gas chromatography is used for the measurement of ___ |
| 243 | The frequency response of a first order system, has a phase shift with lower and upper bounds given by ___ |
| 244 | The transfer function for an ideal proportional plus reset controller (reset time T) is ___ |
| 245 | A non-linear chemical system is exemplified by a/an ___ |
| 246 | In a shell and tube heat exchanger, the flow rate of heating/cooling fluid is the ___ variable |
| 247 | The second order system with the transfer function ___ |
| 248 | Which of the following relates the absorption & evolution of heat at the junctions of a thermocouple to the current flow in the circuit ___ |
| 249 | Emf developed by a thermocouple, while measuring a temperature of 600°C is about 5.5 mV ___ |
| 250 | The ___ of a vapor pressure thermometer is a secondary element |
| 251 | Continuous shell temperature measurement in a liquid-liquid heat exchanger is done by a ___ |
| 252 | For an input forcing function ___ |
| 253 | Select the correct statement from the following ___ |
| 254 | ___ is undesirable in thermocouples used in industries, |
| 255 | The symbol for “capillary line” in instrumentation diagram is ___ |
| 256 | A proportional controller with a gain of ___ |
| 257 | Which of the following thermocouples will give the highest output for the same value of hot and cold junction temperature ___ |
| 258 | Nichol’s chart deals with ___ |
| 259 | The function of a transducer is to ___ |
| 260 | The transfer function for a PID controller is ___ |
| 261 | Strain gage pressure transducers are used to measure ___ pressures |
| 262 | Zirconia probe is used for the continuous measurment of ___ flue gases going out of the furnace |
| 263 | A magnetic flowmeter is ___ |
| 264 | Which of the following measurements can be made by the measurement of emf ___ |
| 265 | Volumetric expansion is the working principle of the ___ thermometers |
| 266 | Which of the following controllers has the least maximum deviation ___ |
| 267 | The maximum service temperature for fibre glass used as thermocouple wire insulation material is ___ °C |
| 268 | Pick out the first order system from among the following ___ |
| 269 | Temperature measuring instruments are standardised mostly with ___ points of pure substances |
| 270 | Transfer function of transportation lag is ___ |
| 271 | Smoke density of the flue gas going out of the chimney is measured by a ___ |
| 272 | The closed loop pole of a stable second order system could be ___ |
| 273 | Response of a system to a sinusoidal input is called ___ response |
| 274 | Thermal conductivity measurement com-prises the working principle of a ___ |
| 275 | Which of the following temperature measuring instruments need not touch the object whose temperature is being measured ___ |
| 276 | Instrumentation in a plant offers the advantage of ___ |
| 277 | The temperature of tempering oil baths maintained at 400°C during heat treatment of steel is measured by a/an ___ thermocouple |
| 278 | The operation of a rotameter is based on ___ |
| 279 | Which of the following is a desirable characteristic of an instrument ___ |
| 280 | In a single tank system, the transfer function of level to inlet flow rate is ___ |
| 281 | Dilute wine was used as a thermometric liquid initially to develop temperature scale ___ |
| 282 | Which of the following relates the emf. generated in a single homogeneous wire to the temperature difference ___ |
| 283 | Working principle of radiation pyrometer is based on the ___ |
| 284 | Typical specifications for design stipulates the gain margin and phase margin to be respectively ___ |
| 285 | Flapper nozzle is used in a/an ___ controller |
| 286 | Thermistor, which has high temperature co-efficient of resistivity, is used as the sensing element in resistance thermometer ___ |
| 287 | A negative gain margin expressed in decibels means a/an ___ system |
| 288 | The ___ of a vapor pressure thermometer is a functioning element |
| 289 | Pick out the wrong statement ___ |
| 290 | Which of the following is the dynamic characteristics of an instrument ___ |
| 291 | Load cells are used for the measurement of ___ |
| 292 | A device used to position dampers and control valves is termed ___ |
| 293 | Thermostats may be classified according to their ___ |
| 294 | On-off thermostats are equipped with ___ |
| 295 | A bimetal thermostat’s operating range is between ___ |
| 296 | A room thermostat should be mounted on an inside wall about ___ |
| 297 | Pressure controllers can be divided into two classes ___ |
| 298 | An example of a controlled device would be ____ |
| 299 | Control motors are divided into two classifications ___ |
| 300 | In a basic electrical control system the device that senses a drop in air temperature is called the ___ |
| 301 | An example of a final control element is a ___ |
| 302 | Electronic controllers can be divided into two types ___ |
| 303 | Transmitters or transducers can measure ___ |
| 304 | Bimetal thermometers consist of two thin metal strips bonded together. The metal strips must have |
| 305 | Iron and constantan can be used in a thermocouple to measure a temperature range of ___ |
| 306 | The optical pyrometer operates on the principle that the color of a hot object is a measure of its ___ |
| 307 | Bimetal thermometers are sometimes wound in the form of a helix to ___ |
| 308 | Thermowells are ____ |
| 309 | Double Bourdon tube gauge can be used to measure _____ |
| 310 | Filled thermal elements ___ |
| 311 | Bellows type elements are generally used to measure pressures below _____ kPa |
| 312 | Increasing the number of corrugations in a bellows type element ___ |
| 313 | The vena contracta is the point where the ___ |
| 314 | An absolute pressure gauge uses a/an _____ to sense the pressure |
| 315 | Optical pyrometers are used ___ |
| 316 | On the Bellows type of indicating mechanism used in conjunction with orifice plate, the bellows are filled with ___ |
| 317 | The orifice plate has the advantage over other types of metering restrictions because it ___ |
| 318 | The most undesirable feature of the orifice plate is the _____ |
| 319 | Venturi tubes will handle about _____ more flow than an orifice plate with the same pipe size and the same differential pressure |
| 320 | When using a venturi tube for flow measurement the high-pressure connection is placed at the _____ of the venturi tube |
| 321 | One Pascal is equal to |
| 322 | Oil or mercury are sometimes used in thermowells to |
| 323 | Rotary type positive displacement meters are independent of temperature, pressure and _____ |
| 324 | When using the float-type manometer, the differential pressure across the U-tube is greatest when the level in the steam drum is: |
| 325 | The pressure differential across an orifice plate is measured by a _____ connection before the plate and a _____ connection after the plate |
| 326 | What pressure would be exerted on the base of the container whose area is 1 m2? |
| 327 | _____ of liquid in the tank can be converted into a constant proportional air signal |
| 328 | A Bourdon tube has an oval cross section, which is often shaped in the form of a “C”, having an arc span of about: |
| 329 | Glass thermometers with a mercury fill are sometimes pressurized with nitrogen so it |
| 330 | Float cage units are used ___ |
| 331 | When diaphragms are used as sensing devices to measure level the low-pressure side is filled with __ |
| 332 | What is the flow when the differential pressure is 81% of designed maximum? |
| 333 | Float-type manometers ___ |
| 334 | Bimetal thermometers consist of two thin metal strips bonded together |
| 335 | The coefficient of expansion of aluminum is higher than copper |
| 336 | Iron and constantan can be used in a thermocouple to measure any temperature range |
| 337 | The optical pyrometer operates on the principle that the color of a hot object is a measure of its temperature |
| 338 | Double Bourdon tube gauge is used to measure vacuum only |
| 339 | Bellows type elements are generally used to measure pressures below 350 kPa |
| 340 | The pressure differential across an orifice plate is measured by a low-pressure connection before ___ |
| 341 | An orifice plate is the most common form of restriction that is used in flow measurement |
| 342 | Venturi tubes will handle about 20% more flow than an orifice plate with ___ |
| 343 | The most undesirable feature of the orifice plate is the ___ |
| 344 | Rotary type positive displacement meters are independent of temperature, pressure and specific gravity |
| 345 | When diaphragms are used as sensing devices to measure level the low-pressure side is filled with a sealing fluid |
| 346 | A continuous air supply is provided to the differential pressure transmitter ___ |
| 347 | Siphon installed between the boiler and the pressure gauge is to prevent ___ |
| 348 | Which of the following units would the pressure gauge on a steam boiler likely use? |
| 349 | An essential fitting between the boiler and the steam pressure gauge is a ___ |
| 350 | According to code, the scale of a pressure gauge for a steam heating boiler shall be graduated between ___ |
| 351 | An indication of a pressure gauge not performing properly is ___ |
| 352 | When using a dead weight tester, the effect of friction ___ |
| 353 | An inspector’s test connection for a boiler pressure gauge ___ |
| 354 | A function of a Bourdon tube gage hairspring is ___ |
| 355 | When installing a siphon it ___ |
| 356 | The working medium in the dead weight tester is ___ |
| 357 | As the boiler pressure increases, the bourdon tube of the pressure gauge will ___ |
| 358 | The cross-section of a Bourdon tube is generally ___ |
| 359 | A compound gauge shows both ___ |
| 360 | Match the following Signals in an P&ID? |
| 361 | What does the TIC symbol indicate? |
| 362 | Piping and instrumentation diagram indicates ___ |
| 363 | Match the instrument’s location |
| 364 | About the Instrumentation MCQ category |
| 365 | Pick out the one which is a first order instrument ___ |
| 366 | Which of the following is not the triple point of water ___ |
| 367 | Which of the following is an undesirable dynamic characteristic of an instrument ___ |
| 368 | What should be used to adjust contact clearances on a relay? |
| 369 | What should be used to clean the contacts of a relay? |
| 370 | If a relay is NOT operating properly, which of the following items need NOT be checked? |
| 371 | If a relay is hermetically sealed with an opaque cover, which of ___ |
| 372 | If a solenoid is not operating properly, which of ___ |
| 373 | A solenoid is commonly used in which of the following devices? |
| 374 | A solenoid is based upon which of the following principles? |
| 375 | Checking a switch with the power applied is accomplished by using which of the following meters? |
| 376 | Checking a switch with the circuit power NOT applied is accomplished by ___ |
| 377 | Designation of switch voltage rating is based on which of the following voltage values? |
| 378 | Designation of switch current rating is based on which of the following current values? |
| 379 | What is the common name for a accurate snap-acting switch? |
| 380 | To guard against the accidental turning off of a circuit, which of ___ |
| 381 | To guard against the accidental actuation of a circuit, which of the following types of switches are used? |
| 382 | Control of a circuit requiring a temporary actuation signal is provided by which of the following switches? |
| 383 | What is the maximum number of different single-pole, double throw switch positions possible? |
| 384 | What is the maximum number of different single-pole, single throw switch positions possible? |
| 385 | A switch actuator is described by which of the following terms? |
| 386 | Control or selection of one or more circuits is a function of which of the following switches? |
| 387 | Which of the following is an automatic switch? |
| 388 | Which of the following is a manual switch? |
| 389 | Which of the following are types of circuit control devices? |
| 390 | Circuit control devices should NOT be used for which of the following reasons? |
| 391 | Which of the following items is NOT checked during maintenance on a circuit breaker? |
| 392 | The following actions must be taken prior to working on ___ |
| 393 | Selective tripping is used to accomplish which of the following purposes? |
| 394 | Selective tripping is used to cause which of the following circuit breakers to ___ |
| 395 | Which of the following is NOT a timedelay rating for a circuit breaker? |
| 396 | What type of circuit breaker can be overridden if the operating mechanism is held ON? |
| 397 | A circuit breaker that will trip even if the operating mechanism is ___ |
| 398 | Which of the following is NOT a type of trip element for a circuit breaker? |
| 399 | What is the total number of main components in a circuit breaker? |
| 400 | When you perform preventive maintenance on ___ |
| 401 | Which of the following is NOT a safety precaution to be observed when a fuse is changed? |
| 402 | Before replacing a fuse, you should check for which of the following conditions? |
| 403 | Which of the following is a safety precaution to be observed when a fuse is checked? |
| 404 | What should you use to remove a fuse from a clip-type fuseholder? |
| 405 | Which of the following methods should be used to check a .002 ampere fuse? |
| 406 | A fuse is removed from a circuit, checked with ___ |
| 407 | Which of the following methods will provide an ABSOLUTE determination as ___ |
| 408 | What is the new military designation for a fuse with the old, military designation F03D1R50B? |
| 409 | What is the current rating for a fuse with the designation AGC2125V? |
| 410 | What is the voltage rating for a fuse with the designation AGC5125V? |
| 411 | What is the current rating for a fuse with the designation 3AG1032V? |
| 412 | What is the voltage rating for a fuse with the designation 3AG20125V? |
| 413 | What is the time-delay rating for a fuse with the designation F04C125V2AS? |
| 414 | What is the current rating for a fuse with the designation F03A125V5A? |
| 415 | What is the voltage rating for a fuse with the designation F02B250V10AS? |
| 416 | What is the time-delay rating for a fuse with the designation F03A20R0C? |
| 417 | What is the current rating for a fuse with the designation F03B0R50B? |
| 418 | What is the voltage rating for a fuse with the designation F03D1R00B? |
| 419 | A fuse voltage rating has which of the following definitions? |
| 420 | A fuse current rating has which of the following definitions? |
| 421 | Which of the following factors is NOT used to rate fuses? |
| 422 | Which of the following two are circuit protection devices? |
| 423 | How are circuit protection devices connected to the circuit they are protecting? |
| 424 | If the bearings of a generator were to fail, which of the following ___ |
| 425 | When circuit current increases beyond the designed current carrying capability of ___ |
| 426 | When a point in a circuit, where full system voltage is present, comes in ___ |
| 427 | Which of the following conditions does NOT require the use of a circuit protection device? |
| 428 | Circuit protection devices are used for which of the following purposes? |
| 429 | If a multimeter has no OFF position, and it is returned to storage, on ___ |
| 430 | Which of the following safety precautions does NOT apply to a multimeter? |
| 431 | If the mirror on the face of a multimeter is used properly, where will ___ |
| 432 | Why is there a mirror on the face of a multimeter? |
| 433 | One of the problems encountered in building a multimeter is ___ |
| 434 | The function switch on a multimeter does NOT perform which of the following functions? |
| 435 | A multimeter can be used to measure which of the following electrical properties? |
| 436 | Which of the following safety precautions should be observed when a megger is used? |
| 437 | When a megger is used to check the insulation of ___ |
| 438 | Meggers (megohmmeters) are used to measure which of the following quantities? |
| 439 | Which of the following safety precautions should be observed when an ohmmeter is used? |
| 440 | What is the most obvious differences in the two types of ohmmeters? |
| 441 | Ohmmeter are classified by type ___ |
| 442 | What area of an ohmmeter scale should be used when a measurement is taken? |
| 443 | An ohmmeter can measure different ranges because of ___ |
| 444 | How should an ohmmeter be connected in an electrical circuit? |
| 445 | An ohmmeter is used to check for which of the following conditions? |
| 446 | What electrical property is measured with an ohmmeter? |
| 447 | Which of the following safety precautions should be observed when a voltmeter is used? |
| 448 | Electrostatic meter movements are used to measure which of the following current/voltage values? |
| 449 | The electrostatic meter movement reacts to which of the following electrical properties? |
| 450 | What voltmeter range should be used for initial measurements? |
| 451 | Which of the following configurations extends the range of a voltmeter? |
| 452 | A voltmeter has a high sensitivity when it has which of the following characteristics? |
| 453 | Which of the following types of meters can be made from a current sensitive meter movement? |
| 454 | To keep the effect of a voltmeter on a circuit to a minimum, the ___ |
| 455 | A voltmeter has an effect on the circuit being measured; what is this effect called? |
| 456 | A voltmeter should be connected in an electrical circuit in what manner? |
| 457 | What electrical property is measured by a voltmeter? |
| 458 | Which of the following safety precautions should be observed prior to ___ |
| 459 | When, if ever, can you use a dc ammeter to measure ac values? |
| 460 | What portion of the ammeter scale should be used to take a final reading? |
| 461 | What range of an ammeter should you use for an initial measurement? |
| 462 | Ammeters measure various ranges through the addition of which of the following components? |
| 463 | The ammeter with the greatest sensitivity has which of the following characteristics? |
| 464 | How is the effect that an ammeter produces in a circuit kept to a minimum? |
| 465 | How does an ammeter affect the circuit being measured? |
| 466 | How are ammeters connected in an electrical circuit? |
| 467 | What electrical property is measured by an ammeter? |
| 468 | What electrical property is reacted to by the electrodynamic, d’Arsonval, moving ___ |
| 469 | Which of the following meter movements will measure either ___ |
| 470 | What value of ac is indicated by a meter scale? |
| 471 | A d’Arsonval meter movement reacts to which of the following values of voltage? |
| 472 | Which of the following methods is used to dampen a meter? |
| 473 | What is meant by the term “meter damping”? |
| 474 | What device allows a d’Arsonval meter movement to ___ |
| 475 | The hairsprings in a d’Arsonval meter movement perform which of the following functions? |
| 476 | Current through a meter results in the ___ |
| 477 | The d’Arsonval meter movement is based on which of the following principles? |
| 478 | Out-of-circuit meters have which of the following advantages over in circuit meters? |
| 479 | An in-circuit meter is used for which of the following purposes? |
| 480 | Circuit measurement is used for which of the following purposes? |
| 481 | Ratio of net amount of heat received and stored in the body for certain time interval is ___ |
| 482 | Heat transfer coefficient of a material with length l is ___ |
| 483 | Ratio of net amount of heat received and stored in the body for ___ |
| 484 | Analogous quantities of heat flow and temperature in electrical are ___ |
| 485 | When bimetallic thermometer heated, curling occurs to the side of ___ |
| 486 | Which of the following is true for bimetallic type thermometer? |
| 487 | Which of the following is used as indication instrument in a liquid expansion system? |
| 488 | In liquid in steel bulb thermometer, which liquid can be used for measuring temperature up to 6000°C? |
| 489 | IPTS stands for ___ |
| 490 | Which of the following can be used for measuring temperature? |
| 491 | Output of a bimetallic element will be ___ |
| 492 | In closed container type level measuring system, pressure at ___ |
| 493 | Which of the following is correct for a level to force conversions? |
| 494 | What will happen if the float becomes lighter? |
| 495 | In closed container type level measuring system, pressure at top of container is ___ |
| 496 | Diaphragm element is used for a level to ___ |
| 497 | Which of the following devices are used for a level to force conversion? |
| 498 | Which of the following represents pressure of a liquid column with constant density? |
| 499 | For float element, uniformity of density is ___ |
| 500 | Which of the following conversions take place in float element? |
| 501 | In ___ system, float whose weight greater than liquid to be displaced is used |
| 502 | Instrument which is capable of discriminating temperature differences of ___ |
| 503 | In fibre-optic level sensors, the amount of ___ |
| 504 | The following liquid level switch will only function with liquids that are ___ |
| 505 | A guided-wave radar transmitter is able to measure liquid interface ___ |
| 506 | Which of the following level-measurement technologies cannot be ___ |
| 507 | A d/p cell used to measure liquid level has a ___ |
| 508 | Calculate the LRV and URV for this ΔP-based liquid ___ |
| 509 | If the specific gravity of the liquid inside the vessel increases, what aspects of ___ |
| 510 | A displacer-type level transmitter has a ___ |
| 511 | The main advantage of a “dip tube†or “bubbler†system for ___ |
| 512 | Suppose a storage vessel holds a liquid of ___ |
| 513 | In function generator, the output waveform of integrator is ___ |
| 514 | The full range of audibility in audio frequency oscillator is ___ |
| 515 | In liquid crystal displays, the liquid crystal exhibits properties of ___ |
| 516 | Depending on whether the display is a numeric or ___ |
| 517 | The measurements which can be simplifies by ___ |
| 518 | X-Y recorders is the type of ___ |
| 519 | In the beginning, all the outputs of the ___ |
| 520 | In potentiometric type DVM, the adjustment of ___ |
| 521 | In a ramp type DVM, the multivibrator determines the ___ |
| 522 | An rms reading voltmeter can accurately measure voltages of ___ |
| 523 | To increase the current sensitivity below ___ |
| 524 | In fibre-optic level sensors, the amount of ___ |
| 525 | An Instrument which is capable of discriminating temperature differences of ___ |
| 526 | Contact devices used for the measurement of ___ |
| 527 | A vibrating level sensors consists of ___ |
| 528 | In radiation methods, the detector system is ___ |
| 529 | If the ambient temperature is doubled and ___ |
| 530 | In ultrasonic level gauge, the ultrasonic source is ___ |
| 531 | Capacitive devices are used for the ___ |
| 532 | The most common application of ___ |
| 533 | Dipsticks are used for the ___ |
| 534 | The flow meter which is replacing the differential pressure meters in ___ |
| 535 | Turbine meters are generally preferred for ___ |
| 536 | Example for positive displacement meter is ___ |
| 537 | The instrument which is not suitable for the application in ___ |
| 538 | The device which is used for making temporary measurements of ___ |
| 539 | The devices used for flow obstruction is/are ___ |
| 540 | For the measurement of flow rate of liquid, the method ___ |
| 541 | Conveyor-based methods is used for the measurement of ___ |
| 542 | The rate at which fluid flows through a closed pipe can be ___ |
| 543 | If a pressure gauge of range 0-10 bar has a quoted inaccuracy of ___ |
| 544 | Accuracy of an measuring instrument indicates the ___ |
| 545 | To read and record a measurement, the indicating ___ |
| 546 | The microcomputer performs its computations in ___ |
| 547 | The output of an analogue instrument varies ___ |
| 548 | In terms of usage, deflection type instruments are ___ |
| 549 | The accuracy of the deflection type instruments and of the ___ |
| 550 | In deadweight gauge, weights are added on the top of piston until ___ |
| 551 | Instruments are subdivided into active and passive based on ___ |
| 552 | In function generator, the output waveform of ___ |
| 553 | The basic difference between square wave and pulse generator is ___ |
| 554 | The full range of audibility in audio frequency ___ |
| 555 | A liquid crystal display requires ___ |
| 556 | In liquid crystal displays, the liquid crystal exhibits ___ |
| 557 | In light emitting diode, the available light emitting ___ |
| 558 | Depending on whether the display is a ___ |
| 559 | The measurements which can be simplifies by using ___ |
| 560 | Q meter is used to measure the properties of ___ |
| 561 | In the beginning, all the outputs of the successive ___ |
| 562 | In potentiometric type DVM, the adjustment of sliding contact is ___ |
| 563 | In a ramp type DVM, the multivibrator determines the rate at ___ |
| 564 | Which among the following is not the type of digital voltmeters? |
| 565 | The measurement range of digital voltmeter is ___ |
| 566 | In electronic voltmeter, the range of input voltages can be ___ |
| 567 | An rms reading voltmeter can accurately measure ___ |
| 568 | Electronic voltmeters can be designed to ___ |
| 569 | To increase the current sensitivity below 10 mV, electronic instrument uses ___ |
| 570 | In McLeod gauge ___ |
| 571 | Advantage of passive instrument is ___ |
| 572 | For the measurement of high pressure with high ___ |
| 573 | When visual indication of pressure level is ___ |
| 574 | The ionization gauge an instrument used for the ___ |
| 575 | Dead weight gauge is used for the measurement of ___ |
| 576 | Bourdon tube is used for the measurement of ___ |
| 577 | The instrument used for the measurement of ___ |
| 578 | A capacitive pressure sensor has a typical measurement uncertainty ___ |
| 579 | If the displacement is measured with strain gauge then the ___ |
| 580 | Photo multiplier consists of ___ |
| 581 | Fiber optic sensor can be used to sense ___ |
| 582 | ___ fiber is used in interferometric instruments |
| 583 | In a graded index fiber, the total reflected ___ |
| 584 | The capacitance microphone is used for ___ |
| 585 | Silver chloride electrode is used as a reference electrode due to ___ |
| 586 | pH value of venous blood is ___ |
| 587 | ___ is the example of photo emissive cell |
| 588 | Most commonly used indicator electrode is ___ |
| 589 | Test electrode is also known as ___ |
| 590 | Which one of the following is the correct ___ |
| 591 | Photo conductive cell consists of ___ |
| 592 | In foil strain gauge the thickness of ___ |
| 593 | The change in resistance of a metal wire owing to ___ |
| 594 | Pressure transducer for measuring blood pressure is ___ |
| 595 | Venturi is associated with ___ |
| 596 | The application of LVDT is ___ |
| 597 | The principle of operation of variable resistance ___ |
| 598 | The transducers which requires an external power and their output is ___ |
| 599 | Pick the correct statement regarding functions of a transducer |
| 600 | Capacitive transducers are normally employed for ___ |
| 601 | In a LVDT, the two secondary voltage ___ |
| 602 | Which of the following are correct statements : |
| 603 | Which of the following can be measured with the help of piezo electric crystal? |
| 604 | LVDT is an/a ___ |
| 605 | The principle of operation of LVDT is based on ___ |
| 606 | The size of air cored transducers in comparison to ___ |
| 607 | LVDT windings are wound on ___ |
| 608 | The draw backs of strain gauges are ___ |
| 609 | Piezo electric crystal can produce ___ |
| 610 | Piezo – electric transducers work when we apply ___ |
| 611 | Piezo-electric transducers are ___ |
| 612 | Which of the following are piezo electric substances? |
| 613 | Quartz and Rochelle salt belongs to ___ |
| 614 | Certain type of materials generates an electrostatic charge ___ |
| 615 | Bonded wire strain gauges are ___ |
| 616 | In wire wound strain gauges, the change in resistance is ___ |
| 617 | Which of the following is not an integrating instrument? |
| 618 | What should be the size of the slide wire of the potentiometer to make it to achieve high accuracy? |
| 619 | Which of the following material will be preferred as a shunt for ___ |
| 620 | An ammeter is convertible to a voltmeter by ___ |
| 621 | An ammeter is inserted in ___ |
| 622 | In hot wire instrument, the sensing wire is made of ___ |
| 623 | A pointer of an instrument once deflected returns to zero position, when the current is ___ |
| 624 | An instrument in which the value of ethnical quantity to be measured can be ___ |
| 625 | A measuring system consists of ___ |
| 626 | Meggar is operated by ___ |
| 627 | In resistance thermometers platinum is ___ |
| 628 | ___ voltmeter has the least power consumption |
| 629 | When the damping of an instrument is adjusted to enable the pointer to ___ |
| 630 | Moving coil and moving iron type instruments can be ___ |
| 631 | A potentiometer works on ___ |
| 632 | The readings of a dynamometer type wattmeter can be ___ |
| 633 | The ratio of maximum displacement deviation to ___ |
| 634 | In a dynamometer 3-phase power factor meter the planes of ___ |
| 635 | Basically a potentiometer is ___ |
| 636 | In a low power factor wattmeter the pressure coil is ___ |
| 637 | The shunt in an ammeter is ___ |
| 638 | ___ is an instrument which measures the insulation resistance of an electric circuit |
| 639 | A moving-coil permanent-magnet instrument can be used as ___ |
| 640 | ___ instruments are those which measure the total quantity of electricity delivered |
| 641 | A Hall’s effect pick up can be used for the ___ |
| 642 | A dummy strain gauge is ___ |
| 643 | Which of the following gets varied by the focus adjustment of an oscillograph? |
| 644 | Which of the following cannot be measured by Ring-balance meter? |
| 645 | The advantage of digital tape recording is ___ |
| 646 | The instrument used for the measurement of power at ___ |
| 647 | The static error band of ___ |
| 648 | Deflection of a hot wire instrument is ___ |
| 649 | Relative permitlivity can be measured by ___ |
| 650 | Rosette gauges are used to ___ |
| 651 | Air friction clamping is achieved by the movement of ___ |
| 652 | Dead time of the instrument is ___ |
| 653 | Radio frequency can be measured by which of the following frequency meters? |
| 654 | Which of the following resistances is shown by a needle in a meggar not in operation? |
| 655 | By a ‘Rotameter’ we can ___ |
| 656 | Null type recorders are ___ |
| 657 | The meter constant of single phase energy meter is expressed in ___ |
| 658 | An induction wattmeter measures ___ |
| 659 | ___ type instrument can have full scale deflection of 300 degrees |
| 660 | A very accurate voltmeter, when used to measure voltage across a ___ |
| 661 | ___ instrument is free from hysteresis and eddy current errors |
| 662 | Weston cell is a ___ |
| 663 | Which of the following is measured by using a vector voltmeter? |
| 664 | Meter ranges are so selected that the indications are ___ |
| 665 | Torque weight ratio will be least in ___ |
| 666 | In a single phase power factor meter the phase difference between ___ |
| 667 | Permanent magnets used in instruments are ___ |
| 668 | Wagner earthing device is used to ___ |
| 669 | A portable instrument is likely to ___ |
| 670 | A phase shifting transformer is used in ___ |
| 671 | In the measurement of power by two wattmeter method, when the ___ |
| 672 | The electrical power to a meggar is ___ |
| 673 | ___ type instrument has identical calibration for A.C. as well as D.C. values? |
| 674 | The pressure coil of a wattmeter should be connected on the ___ |
| 675 | Which of the following instruments cannot be used for the measurement of ___ |
| 676 | Two holes in the disc of energy meter are drilled at ___ |
| 677 | A potentiometer may be ___ |
| 678 | Instrumerat transformers are ___ |
| 679 | A moving-coil permanent-magnet instrument can be ___ |
| 680 | If an instrument has cramped scale for larger values, then it ___ |
| 681 | The power factor of a single phase load can be ___ |
| 682 | The two pressure coils of a single phase power ___ |
| 683 | In an Anderson bridge, the unknown inductance is ___ |
| 684 | To measure a resistance with the help of a potentiometer it ___ |
| 685 | An induction wattmeter can be ___ |
| 686 | The disc of an instrument using eddy current damping should be ___ |
| 687 | Which of the following is an essential part of a motor meter? |
| 688 | A Weston synchronoscope is ___ |
| 689 | To avoid the effect of stray magnetic field in A.C. bridges we can ___ |
| 690 | In an A.C. co-ordinate potentiometer, the currents in ___ |
| 691 | It is required to measure the true open circuit e.m.f. of ___ |
| 692 | The adjustment of position of shading bands, in an energy meter is ___ |
| 693 | In hot wire instruments the sensing wire is ___ |
| 694 | ___ will always indicate true r.m.s. value in respective of the wave form? |
| 695 | Which of the following cannot be measured by multimeters? |
| 696 | High voltage tests are ___ |
| 697 | Wattmeter cannot be designed on ___ |
| 698 | Which of the following properties a damping oil must possess? |
| 699 | The use of ___ instruments is merely confined within laboratories |
| 700 | ___ is a low cost thermocouple |
| 701 | A dummy bridge employing strain gauge provides ___ |
| 702 | Which of the following can be measured with the help of piezo-electric crystal? |
| 703 | The principle of Pirani gauge is based on ___ |
| 704 | ___ can measure only level |
| 705 | A digital voltmeter claims Which of the following advantage? |
| 706 | Electrodynamic types of instruments are used commonly for ___ |
| 707 | In an ammeter the shunt resistance is usually ___ |
| 708 | An instrument’s reliability means ___ |
| 709 | A milli-ammeter can be ___ |
| 710 | For malting shunts the material suitable is ___ |
| 711 | In the case of indicating instruments the function of ___ |
| 712 | Moving parts of instruments are supported in ___ |
| 713 | The temperature of a furnace can be measured by ___ |
| 714 | ___ frequency meter can be used for the measurement of radio frequency |
| 715 | The advantage of moving coil permanent magnet type ___ |
| 716 | A Q-meter measures ___ |
| 717 | Which of the following methods is used to shield a dynamometer type wattmeter against stray fields? |
| 718 | In instruments the term ‘artificial aging’ is ___ |
| 719 | The power of a n-phase circuit can be measured by using ___ |
| 720 | Damping of the Ballistic galvanometer is ___ |
| 721 | In Weston synchronoscope the moving coil is ___ |
| 722 | When a capacitor was connected to the terminal of ___ |
| 723 | A dynamometer wattmeter can be ___ |
| 724 | In a portable instrument, the controlling torque is ___ |
| 725 | Which of the following meters are not used on D.C. circuits? |
| 726 | The spring material used in a spring control device should have ___ |
| 727 | In optical pyrometer temperature is ___ |
| 728 | The brightest spot, on a cathode ray screen, occurs at ___ |
| 729 | Thermistors have ___ temperature coefficient |
| 730 | Which of the following is the pH value of pure water? |
| 731 | ___ can measure only pressure |
| 732 | Transmission channels for ___ |
| 733 | The total power delivered to ___ |
| 734 | ___ damping method is common in moving coil instruments |
| 735 | The error, when reading at half-scale in ___ |
| 736 | A high resistance is usually connected in series with an ___ |
| 737 | Aluminium is selected as the material for rotating disc of ___ |
| 738 | Control springs are made up of ___ |
| 739 | Which of the following bridges is used to measure power factor? |
| 740 | The e.m.f. of a Weston standard cell can be ___ |
| 741 | Which of the following can be measured by Solometers? |
| 742 | ___ give the value of the quantity to be measured in terms of the constants |
| 743 | Which of the following instruments can be made using magnetic effect? |
| 744 | In a Weston synchronoscope, the fixed coils are ___ |
| 745 | If an inductance is connected in one arm of bridge and resistances in ___ |
| 746 | A voltage of about 200 V can be ___ |
| 747 | The resistance in the circuit of the moving coil of ___ |
| 748 | Most common form of A.C. meters met with in ___ |
| 749 | A ___ device prevents the oscillation of the moving system and enables the latter |
| 750 | Which of the following is an analogue transducer? |
| 751 | Phosphor coating for cathode ray tubes is ___ |
| 752 | ___ is not an element of electropneumatic pressure transmitter |
| 753 | For measuring the resistance of the elements of ___ |
| 754 | Which of the following is determined by a hydrometer? |
| 755 | ___ cannot be used to measure pressure |
| 756 | Synchro is a ___ |
| 757 | The minimum number of wattmeters required to measure power in ___ |
| 758 | ___ meter has the best accuracy |
| 759 | The sensitivity inaccuracy of an instrument does not ___ |
| 760 | Which of the following instruments may be used to measure D.C. voltage accurately? |
| 761 | If voltage supply to the energy meter is more than ___ |
| 762 | Sensitivity of a voltmeter is ___ |
| 763 | ___ bridge is used for the precise measurement of inductances over a wide range |
| 764 | The ratio error of a current transformer is ___ |
| 765 | ___ is the commonly used material for thermocouples |
| 766 | By which of the following methods an ammeter can be converted to a voltmeter? |
| 767 | ___ method is suitable for the measurement of a resistance |
| 768 | ___ instrument will draw least current from the circuit in which it is incorporated |
| 769 | Ring specimens can be tested for its magnetic properties by ___ |
| 770 | In an energy rater braking torque is produced to ___ |
| 771 | For measuring current at high frequency we should ___ |
| 772 | In majority of instruments damping is ___ |
| 773 | Induction type single phase energy meters measure electric energy in ___ |
| 774 | Which of the following essential features is possessed by an indicating instrument? |
| 775 | LVDT possesses the following advantage ___ |
| 776 | A double beam oscilloscope has ___ |
| 777 | Which of the following can be measured by a hot wire anemometer? |
| 778 | Which of the following devices may be used to measure accurately the interelectrode capacitances? |
| 779 | ___ is used to measure flow of air around an aeroplane |
| 780 | The Lissajous pattern of eight, on an oscilloscope, keeps on ___ |
| 781 | Unit of deflection sensitivity of CRO is ___ |
| 782 | A multimeter consists of ___ |
| 783 | In an instrument hysteresis means ___ |
| 784 | The accuracy of a meter is determined by ___ |
| 785 | Swamping resistance is used to ___ |
| 786 | The stator of phase shifting transformer for use in conjunction with ___ |
| 787 | The chemical effect of current is ___ |
| 788 | For handling greater currents induction wattmeters are used in ___ |
| 789 | ___ can measure pressure directly? |
| 790 | In an oscilloscope a moving wave form can be made stationary by adjusting which of the following? |
| 791 | Which of the following properties are measured by a Q-meter? |
| 792 | Which of the following will happen if a voltmeter is connected like an ammeter in series to the load? |
| 793 | Damping in an instrument provides ___ |
| 794 | According to application, instruments are ___ |
| 795 | A C.R.O. can be used to ___ |
| 796 | Which of the following is the most suitable transducer for ___ |
| 797 | A ___ is used to measure frequency in wave guides |
| 798 | In measuring instruments a mirror is provided behind the ___ |
| 799 | Scale of an instrument will be ___ |
| 800 | Primary of an instrument transformer (C.T.) is ___ |
| 801 | In electrical measuring instruments, electrical energy is ___ |
| 802 | The internal resistance of a voltmeter must be ___ |
| 803 | The phenomenon of ‘creeping’ occurs in ___ |
| 804 | Which of the following instruments can be used for measuring 132 kV A.C. voltage? |
| 805 | The dissipation factor of a capacitor can be ___ |
| 806 | A wattmeter will be free from the effects of power factor and ___ |
| 807 | A dynamometer type wattmeter has ___ |
| 808 | Potentiometer is a ___ |
| 809 | In a Weston frequency meter, the magnetic axes of ___ |
| 810 | If the current in a capacitor leads the voltage by 80°, the loss angle of ___ |
| 811 | To measure an A.C. voltage by using an A.C. potentiometer, it is ___ |
| 812 | Murray loop test can be used for ___ |
| 813 | In a 3-phase power measurement by ___ |
| 814 | A wave guide acts as ___ |
| 815 | Load cell is essentially a ___ |
| 816 | In brewing process the degree of fermentation is ___ |
| 817 | The Q-meter Works on the principle of ___ |
| 818 | Which of the following is the merit of a moving iron instrument? |
| 819 | In which part of the scale does the pointer indicate most accurately? |
| 820 | Moving iron instruments are rarely used in ___ |
| 821 | Meggar will give resistance values which ___ |
| 822 | Changes in atmospheric temperature, humidity ___ |
| 823 | For protecting a galvanometer during transport ___ |
| 824 | Hot wire instruments read ___ |
| 825 | In order to get best results, indicating instruments are ___ |
| 826 | Which of the following can be measured by the use of a Schering bridge? |
| 827 | A multimeter can be used for measuring ___ |
| 828 | The gravity controlled instrument has crowded scale because ___ |
| 829 | In a vibrating reed frequency meter the natural frequencies of ___ |
| 830 | For measurement of inductance having high ___ |
| 831 | In order to achieve high accuracy, the slide wire of ___ |
| 832 | The operating voltage of a meggar is ___ |
| 833 | Which of the following devices may be used for extending the range of instruments? |
| 834 | Which of the following are integrating instruments? |
| 835 | ___ is a digital transducer |
| 836 | The cathode of a C.R.O. is usually coated with ___ |
| 837 | ___ is not a signal conditioner |
| 838 | Which of the following is the best method for the measurement of ___ |
| 839 | Harmonic distortion is due to which of the following? |
| 840 | The reed frequency is ___ |
| 841 | An electrodynamic meter can be used to ___ |
| 842 | Following type of instrument is used to measure very ___ |
| 843 | Moving iron meters are extensively used for the ___ |
| 844 | A control system with excessive noise is likely to ___ |
| 845 | The frequency and time domain are ___ |
| 846 | The energy consumption of MI instrument as compared to ___ |
| 847 | The energy meter used for measuring energy of ___ |
| 848 | Most commonly used watt meter is ___ |
| 849 | A galvanometer can be used for measuring current and voltage of ___ |
| 850 | For increasing the range of an ___ |
| 851 | Moving coil instruments are ___ |
| 852 | The deflection torque can be ___ |
| 853 | Chemical effect is used for the ___ |
| 854 | In spring control instruments, controlling torque ___ |
| 855 | Moving Iron instruments can be ___ |
| 856 | Ballastic tests are used in magnetic measurements for the ___ |
| 857 | Anderson’s bridge is a modification of ___ |
| 858 | The power measurement in a balanced 3-phase circuit can be ___ |
| 859 | The moving iron voltmeters are ___ |
| 860 | The relative error is ___ |
| 861 | A 150 V moving iron voltmeter of accuracy class 1.0 reads 75 V when used in ___ |
| 862 | The ratio of maximum displacement deviation to the full scale deviation of ___ |
| 863 | For measuring an unknown electrical quantity, select the ___ |
| 864 | In which part of the scale does the pointer indicate ___ |
| 865 | Hysteresis of an instrument ___ |
| 866 | Campbell’s bridge method is used to ___ |
| 867 | Anderson bridge is used to measure of ___ |
| 868 | A Dynamometer type wattmeter responds to ___ |
| 869 | Uniformity in the scale of an ammeter indicates that it ___ |
| 870 | Electrostatic instruments are mainly employed to ___ |
| 871 | Which of the following instrument can be used for ___ |
| 872 | Swamping of resistance is used to compensate error due to ___ |
| 873 | The internal resistance for milli ammeter must be ___ |
| 874 | Voltmeter should be of very high resistance so ___ |
| 875 | Which of the following is not an ___ |
| 876 | Which of the set of torques is provided in deflection ___ |
| 877 | A moving iron ammeter coil has few turns of thick wire in order to ___ |
| 878 | The material used to make standard resistance is ___ |
| 879 | Introduction of dielectric ___ |
| 880 | Kelvin double bridge is best suited for the ___ |
| 881 | Vibration reeds are employed in ___ |
| 882 | Megger is an instrument used for the ___ |
| 883 | Loss of charge method is used to ___ |
| 884 | For measuring emf of a ___ |
| 885 | The most commonly used null deflector in a ___ |
| 886 | For eliminating the effect of earth capacitance from the ___ |
| 887 | ____ factor is the ratio of total flux to the useful flux in a magnetic circuit |
| 888 | A ballistic galvanometer is used to ___ |
| 889 | Maxwell-Wien bridge is used to ___ |
| 890 | An instrument that is capable of measuring only ___ |
| 891 | PMMC instrument gives uniform scale because ___ |
| 892 | Air friction damping is used in the instruments which is ___ |
| 893 | Preferred material for permanent magnet is ___ |
| 894 | If a voltmeter is connected, like an ammeter in ___ |
| 895 | The damping torque must operate only when the moving system of ___ |
| 896 | The reliability of the instrument refer to ___ |
| 897 | If two meters X and Y requires 40mA and 50mA respectively, to ___ |
| 898 | The deflection of hot-wire instrument depends on ___ |
| 899 | In a dynamo-meter type of moving coil instrument a swamping resistance is ___ |
| 900 | Moving iron and PMMC instruments can be ___ |
| 901 | Which of the following statement is true of phase-shift type and ___ |
| 902 | The main advantage of crystal oscillator is ___ |
| 903 | In CRO astigmatism is ___ |
| 904 | In CRO the time base signal is ___ |
| 905 | Open circuit fault in a cable can be ___ |
| 906 | A PMMC instrument can be used as a ___ |
| 907 | Magnetic materials can be tested by ___ |
| 908 | B-H Curve is used to determination of ___ |
| 909 | The ballistic galvanometer is usually lightly damped so ___ |
| 910 | The frequency can be measured by ___ |
| 911 | Hay’s Bridge is suitable for the ___ |
| 912 | Anderson Bridge is used to ___ |
| 913 | Direct current is preferred over alternating current for testing of ___ |
| 914 | Tesla coil is a ___ |
| 915 | Which of the following bridge is ___ |
| 916 | Potentiometer is an ___ |
| 917 | A megger indicates infinity when test terminals are ___ |
| 918 | A Ohmmeter is ___ |
| 919 | While testing cables the galvanometer used should be initially short-circuited in order to protect it from sudden initial inrush currents as ___ |
| 920 | Which of the following instruments can be used for full scale deflection of ___ |
| 921 | The instrument having its deflection depends upon ___ |
| 922 | Which of the following instruments have least ___ |
| 923 | Which of the following voltmeter have least ___ |
| 924 | Measurement range of a voltmeter can be extended by ___ |
| 925 | The instrument which is cheapest for ___ |
| 926 | Electrostatic type instruments are mainly used for ___ |
| 927 | A thermo-couple instrument can be used for the ___ |
| 928 | Potentiometer is basically a ___ |
| 929 | Which of the following is used to measure the resistance of ___ |
| 930 | The shunt type ohm meter is not suitable for ___ |
| 931 | The sensitivity of the Wheatstone bridge depends on ___ |
| 932 | If an induction type energy meter runs faster, it can be ___ |
| 933 | The synchroscope is an instrument ___ |
| 934 | The power delivered to a 3-phase load can be measured by the use of 2-wattmeter only ___ |
| 935 | The difference between the measured value and the true value is ___ |
| 936 | Dead zone of an instrument is ___ |
| 937 | Wien bridge is useful for measuring ___ |
| 938 | The thermocouple instruments do not have ___ |
| 939 | The thermocouple instrument will measure ___ |
| 940 | With a sweep time 10ms across the screen the approx. horizontal sawtooth frequency will be ___ |
| 941 | It can be stated that ___ |
| 942 | The full-scale deflection current of an ammeter is 1 mA and its internal resistance is 100°hm ___ |
| 943 | Which instrument has identical calibration for ac as well as dc values? |
| 944 | Jewels are used in instruments for the purpose of ___ |
| 945 | PMMC type instruments normally use ___ |
| 946 | A spring controlled indicating instrument has a deflection of 90 deg for ___ |
| 947 | The full-scale deflection current of an ammeter is 1 mA and its ___ |
| 948 | Electrostatic instruments are normally used for ___ |
| 949 | An instrument to be used for measurement and control should preferably have ___ |
| 950 | Which of the following devices should be used for accurate measurement of low D.C. voltage? |
| 951 | Which meter is suitable for the measurement of 10mV at 50MHz? |
| 952 | The problem of Electrostatic coupling in a transformer is acute at ___ |
| 953 | In a gravity controlled instrument, the deflection angle is proportional ___ |
| 954 | The resistance offered to the passage of an in-varying current by a column of mercury at the ___ |
| 955 | The form factor in AC is the ratio of ___ |
| 956 | A milli-ammeter can be used as ___ |
| 957 | It is found that 10A current passes through a resistor of 10°hms ___ |
| 958 | A resistor of 10kΩhms with 5% tolerance is connected in parallel with a 5kΩhms resistor of 10% tolerance ___ |
| 959 | Some wire- wound resistors have bifilar winding ___ |
| 960 | A permanent magnet moving coil ammeter has a coil resistance of ___ |
| 961 | For power measurement of three phase circuit by two wattmeter method, when the value of power factor is ___ |
| 962 | The absolute measurement of resistance is done by ___ |
| 963 | To measure the flux, devices used are based on ___ |
| 964 | The current coil of a wattmeter is connected to the CT of R-phase ___ |
| 965 | Which wave has the least form factor? |
| 966 | In a moving iron meter, the deflecting torque is proportional to ___ |
| 967 | In a moving coil instrument, the deflecting torque is proportional to ___ |
| 968 | The resistance can be measured most accurately by ___ |
| 969 | Direct method is used to measure ___ |
| 970 | Ryall crest voltmeter is used for measurement of ___ |
| 971 | An oscilloscope indicates ___ |
| 972 | A rectifier type instrument is connected to 100VDC and is operated in the ___ |
| 973 | The internal resistance of an ammeter should be ___ |
| 974 | Ampere is one of the ___ |
| 975 | A megger is usually ___ |
| 976 | A galvanometer has ___ |
| 977 | A CRO can display ___ |
| 978 | When using ohmmeter, applied voltage is to be disconnected from the circuit because ___ |
| 979 | For handling greater currents induction watt-meters are used in conjunction with ___ |
| 980 | A moving iron ammeter may be compensated for frequency errors by ___ |
| 981 | One single phase wattmeter operating on 230V and 5A for ___ |
| 982 | Radio waves that curve earthward in the lower atmosphere are being affected by ___ |
| 983 | Which of the following is the probable output if all inputs of a TTL gate are binary 1? |
| 984 | The voltage across an SCR when it is turned on is about ___ |
| 985 | What sensing element is typically made from a thin-walled tube formed into deep convolutions and sealed at one end, whose displacement can then be made to act on a transduction element? |
| 986 | What is the most widely used altitude and altitude-rate transducers? |
| 987 | The SCR can exercise control over ___ of ac supply |
| 988 | When the SCR is OFF, the current in the circuit is ___ |
| 989 | When the firing angle of SCR is increased, its output ___ |
| 990 | When an SCR is combined to a switch, it is considered as a ___ switch |
| 991 | Acceleration transducers are also called ____ |
| 992 | ECG stands for electrocardiography while EEG stands for? |
| 993 | An SCR is made of what material? |
| 994 | The typical turn-off time of an SCR is about ___ |
| 995 | An SCR when turned on has a typical voltage across of ___ |
| 996 | When SCR starts conducting, then ___ losses all control |
| 997 | How many pn junction does SCRs have? |
| 998 | An SCR is a member of what family? |
| 999 | Which of the following can change the angle of conduction in SCR? |
| 1000 | What is one of the most widely used sensing elements particularly for pressure ranges higher than 2 MPa? |
| 1001 | What device measures humidity directly with a single sensing element? |
| 1002 | A normally operated SCR has an anode which is ___ with respect to cathode |
| 1003 | The gate of an SCR is with respect to its cathode ___ |
| 1004 | An SCR is a solid state equivalent of which tube? |
| 1005 | What is the typical turn-on time of an SCR? |
| 1006 | What Greek word which means “switch� |
| 1007 | What are some areas where GTO is applicable? |
| 1008 | What is the sensing element of acceleration transducer? |
| 1009 | What is an automatic speed control device using the centrifugal force on rotating flyweights as the feedback element? |
| 1010 | What is the required gate triggering current of GTO? |
| 1011 | Which is equivalent to a zener or avalanche region of the fundamental two-layer semiconductor diode? |
| 1012 | What is that value of current below which the SCR switches from the conduction state to the forward blocking region under stated conditions? |
| 1013 | A control system in which the output is related to the input by device parameters only ___ |
| 1014 | A locus or path of the roots traced out on the s-plane as a parameter is changed ___ |
| 1015 | What is that voltage above when the SCR enters the conduction region? |
| 1016 | A feedback control system in which the controlled variable is mechanical position ___ |
| 1017 | The step response of a first order systems is given by ___ |
| 1018 | When the supply voltage exceeds the breakover voltage of an SCR, it ___ |
| 1019 | The triac is fundamentally a/an ___ with a gate terminal for controlling the turn-on conditions of the bilateral device in either direction |
| 1020 | The supply voltage is generally ___ that of breakover voltage in an SCR |
| 1021 | What is a solid state equivalent of a gas filled triode? |
| 1022 | A transduction principle used primarily in optical sensors ___ |
| 1023 | SCR is a rectifier constructed of silicon material. Silicon is chosen because ___ |
| 1024 | The UJT operates in what region after peak point? |
| 1025 | Which device exhibits negative resistance region? |
| 1026 | What refers to the application of electronic theory, technology, instrumentation, and computing system to biological research and medical problems? |
| 1027 | What region lies between the peak point and valley point of UJT emitter characteristic? |
| 1028 | A diac is simply ___ |
| 1029 | An SCR whose state is controlled by the light falling upon a silicon semiconductor layer of the device ___ |
| 1030 | A diac is turned on by ___ |
| 1031 | What is the ratio of two exponential functions of time called? |
| 1032 | What is dimensionless parameter of the second-order characteristic equation? |
| 1033 | When the temperature increases, the intrinsic stand off ratio ___ |
| 1034 | To turn on the UJT, the forward bias on emitter diode should be ___ the peak point voltage |
| 1035 | Control system that maintains a speed voltage, or other variable within specified limits of a preset level ___ |
| 1036 | To turn off the SCR, which of the following is done? |
| 1037 | Which equation defines the intrinsic stand off ratio (y) of UJTs? |
| 1038 | AC power in a load can be controlled by connecting ___ |
| 1039 | When the emitter terminal of a UJT is open, the resistance between the base-terminals is generally ___ |
| 1040 | Power electronics deals with the control of ac power at what frequencies essentially? |
| 1041 | Which of the following is the normal way to turn on a diac? |
| 1042 | The UJT may be used as ___ |
| 1043 | The UJT has ___ |
| 1044 | When UJTs is turned on, the resistance between emitter terminal and lower base terminal ___ |
| 1045 | An SCR is a ___ triggered device |
| 1046 | Which device does not have a gate terminal? |
| 1047 | Which of the following is a common application of UJT? |
| 1048 | An effect that reduces the possibility of accidental triggering of the SCS ___ |
| 1049 | What is the control element in an SCR? |
| 1050 | An SCR is made of silicon and not germanium because silicon ___ |
| 1051 | A diac is ___ switch |
| 1052 | A UJT is sometimes called a ___ diode |
| 1053 | A diac has ___ |
| 1054 | The p-type emitter of a UJT is ___ doped |
| 1055 | A diac has how many semiconductor layers? |
| 1056 | How many semiconductor layers does a triac have? |
| 1057 | Which is the control element in an SCR? |
| 1058 | An SCR combines the feature of ___ |
| 1059 | A diac has how many terminals? |
| 1060 | A triac can pass a portion of ___ half cycle through the load |
| 1061 | Which of the following is the normal way to turn on an SCR? |
| 1062 | A triac is a ___ switch |
| 1063 | How many semiconductor layers does an SCR have? |
| 1064 | If a body is considered as a conducting sphere of 0.5m radius its capacitance to infinity is ___ |
| 1065 | The three terminals of an SCR are the ___ |
| 1066 | The x-ray region of the electromagnetic spectrum has a corresponding range of wavelengths from ___ |
| 1067 | In diagnostic radiology and for superficial therapy purposes, the energy spectrum of radiation varies from about ___ |
| 1068 | A triac is equivalent to two SCRs ___ |
| 1069 | The three terminals of a triac are ___ |
| 1070 | When the temperature increases, the inter-base resistance of a UJT ___ |
| 1071 | The V-I characteristics for a triac in the first and third quadrants are essentially identical to those of ___ in the quotation |
| 1072 | What are the regions corresponding to open-circuit condition for the controlled rectifier which block the flow of charge from anode to cathode? |
| 1073 | What is the other term for thermoelectric effect? |
| 1074 | What is a three terminal device used to control large current to a load? |
| 1075 | Which transistor conducts current in both directions when turned on? |
| 1076 | PUT stands for ___ |
| 1077 | What is the typical value of the interbase resistance of UJTs? |
| 1078 | What is basically a two-terminal parallel-inverse combination of semiconductor layers that permits triggering in either direction? |
| 1079 | Which of the following is a four-layer diode with an anode gate and a cathode gate? |
| 1080 | In therapeutic radiology and in nuclear medicine, the energies of interest range from about ___ |
| 1081 | What is concerned with the measurement of electric signals on the scalp with arise from the underlying neural activity in the brain (including synaptic sources)? |
| 1082 | What is a nucleonic sensing method employing usually one or more radioisotope sources and radiation detectors? |
| 1083 | Insulation resistance is measured by which meter? |
| 1084 | What is the smallest change in applied stimulus that will indicate a detectable change in deflection in a indicating instrument called? |
| 1085 | Sensitivity of a voltmeter is expressed in ___ |
| 1086 | What has a series RC combination in one arm and a parallel RC combination in the adjoining arm and used as a notch filter in harmonic distortion analyzer? |
| 1087 | What is used for measuring medium Q coils (1<Q<10)? |
| 1088 | Maxwell bridge measures an unknown inductance in terms of known ___ |
| 1089 | What bridge is used to measure high-Q inductors (Q>10)? |
| 1090 | Most AC voltmeters have an rms scale which is valid only if the input signal being measured is a ___ signal |
| 1091 | An ammeter with an internal resistance of 50 Ω is used to measure a current through a load resistance RL= 1 k Ω ___ |
| 1092 | What sensor provides a change of resistance with typical power range of 1µW to 10mW and with maximum frequency greater than 100GHz? |
| 1093 | A material that glows when struck by the energetic electrons in a CRT ___ |
| 1094 | Considered as the “heart†of the cathode ray oscilloscope ___ |
| 1095 | The interval of a pulse from start to end is the ___ of the pulse |
| 1096 | What provides a visual presentation of ant waveform applied to the input terminals? |
| 1097 | One of the basic functions of electronic circuit is ___ |
| 1098 | Indicating instrument is assumed to be most accurate at what part of the scale? |
| 1099 | A certain pulse measures 10ms and has a period of 50ms ___ |
| 1100 | What type of instrument is the watt-hour meter? |
| 1101 | Which is the most commonly used induction type instrument? |
| 1102 | Which instrument is the most sensitive? |
| 1103 | An electric pyrometer is an instrument used to measure ___ |
| 1104 | What is the typical power range of thermocouple sensors ___ |
| 1105 | Electrostatic instruments are exclusively used as ___ |
| 1106 | What provides visual display showing the form of the signal applied as a waveform on the front screen of a cathode ray oscilloscope? |
| 1107 | A common technique for measuring power at high frequency is to ___ |
| 1108 | Which of the voltmeter is used for measuring high direct voltage (say 10kV)? |
| 1109 | What ammeter is used to measure high-frequency currents? |
| 1110 | For amplitude measurements, what scale is calibrated in either volts per centimeter (V/cm), or milivolts per centimeter (mV/cm) ___ |
| 1111 | Which part of the following is not a basic part of a CRT? |
| 1112 | Which of the following extends the range of a moving-iron ac ammeter? |
| 1113 | A galvanometer with a 20 Ω coil resistance has a full-scale deflection of 10mA ___ |
| 1114 | A pattern displayed by oscilloscopes which has a steady characteristic is called ___ |
| 1115 | Moving-iron instrument has what scale? |
| 1116 | What element of a CRT releases electrons when heated indirectly by a filament? |
| 1117 | What is the period of a repetitive signal? |
| 1118 | What is the typical full-scale voltage across a moving coil voltmeter? |
| 1119 | What type of meter gives a precise reading on voltage, current or resistance where there is the generation of samples at the input and then feeds it to a digital read-out? |
| 1120 | What instrument is used for measuring the amount of current flowing in a circuit? |
| 1121 | What is the typical full-scale deflection current of a moving coil instrument? |
| 1122 | When current through the operating coil of a moving-iron instrument is tripled the operating force becomes ___ |
| 1123 | Which of the following forces does not act on the moving systems of analog instruments? |
| 1124 | Which of the items below describes an absorption meter’s usage? |
| 1125 | The frequency of rotation in some rotating machinery can be measured by a ___ |
| 1126 | In VTVMs, ___ refers to the smallest signal that can be reliably measured |
| 1127 | What instrument which springs provide the controlling torque as well as serve to lead current into and out of the operating coil? |
| 1128 | Multimeter typically provides measurements of values (for a sinusoidal waveform) ___ |
| 1129 | Majority of analog measuring instrument utilizes one of the following effects ___ |
| 1130 | Which of the following is a dc bridge that is very useful for making extremely accurate voltage measurements? |
| 1131 | What dc bridge is widely used for the accurate measurements of resistance? |
| 1132 | A ___ operates on the magnetic attraction-repulsion principles |
| 1133 | The typical power range of diode sensor is ___ |
| 1134 | A small swamping resistance is connected in series with operating coil of a moving coil ammeter in order to compensate for the effects of ___ |
| 1135 | The resistance of a moving-coil instrument is 10 fi and gives full-scale deflection at 10 mA ___ |
| 1136 | In Wheatstone bridge, bridge balance is considered where ___ |
| 1137 | Attraction and repulsion instruments are considered as ___ |
| 1138 | Which movement is the most expensive? |
| 1139 | A dynamometer instrument is mainly used as a /an ___ |
| 1140 | What meter is the most sensitive? |
| 1141 | Shunts are generally made of what material? |
| 1142 | Tank circuit frequency can be measured by ___ |
| 1143 | A sensing element that provides a dc voltage less than 10 mV with typical power range of 0.1 to 100 mW ___ |
| 1144 | When the vertical input is 0V, the electron beam may be positioned at the ___ of the screen |
| 1145 | What refers to garaging two adjustments of an AC bridge together in such a way that changing one adjustment changes the other in a special way, but changing the second adjustment does not change the first? |
| 1146 | What CRT element provides for control of the number of electrons passing farther into the tube? |
| 1147 | Permanent- magnet moving coil instrument can be used in ___ |
| 1148 | Current range extension in moving coil instruments can be achieved by placing a ___ in shunt with the instrument |
| 1149 | Fluid friction damping is employed in one of the following ___ |
| 1150 | For time measurements, ___ scale of the scope is used |
| 1151 | Hot-wire instrument has a/an ___ scale |
| 1152 | What sensor provides a dc voltage approximately 1 V at 10 mW? |
| 1153 | An element in electrons which serves as a protection against overload? |
| 1154 | An oscilloscope provides easy measurement of ___ values |
| 1155 | The time interval between pulses is called ___ |
| 1156 | Disc is made of what material in eddy current damping? |
| 1157 | All voltmeters except one of the following are operated by the passage of current ___ |
| 1158 | A moving force in analog instruments which ensures that the deflection of the pointer for a given value of measured quantity always has the same value ___ |
| 1159 | A moving system force in analog instruments which causes the moving system to deflect from its zero position ___ |
| 1160 | The pointer of an indicating instrument is the final deflected position, the ___ is zero |
| 1161 | A Wheatstone bridge is balanced if ___ |
| 1162 | The time interval that a waveform is high (or low) is the ___ of the signal |
| 1163 | The pointer of an indicating instrument is generally made of ___ |
| 1164 | When should a fuse be replaced with a higher rated unit? |
| 1165 | How can electrical currents be inducted with a coil and a magnet? |
| 1166 | If the pointer of an indicating instrument is in motion, then what opposes deflecting torque? |
| 1167 | An instrument in which the magnitude of the measured quantity is indicated by means of a pointer ___ |
| 1168 | The output voltage of a thermocouple ___ |
| 1169 | When both deflecting and controlling torque act, the pointer of an indicating instrument comes to ___ |
| 1170 | Which is the best type of meter movement? |
| 1171 | As the deflection of the moving system increases, the controlling torque in an indicating instrument ___ |
| 1172 | What kind of instrument an ammeter is? |
| 1173 | RC coupling is used for ___ amplification |
| 1174 | One electron volt (1 eV) is equivalent to joules ___ |
| 1175 | To measure radio frequency, the suitable frequency meter is ___ |
| 1176 | The principle on which vector voltmeter is based is ___ |
| 1177 | Which of the following is measured by using a vector voltmeter ___ |
| 1178 | Two holes in the disc of energymeter are drilled at the opposite sides of the spindle to ___ |
| 1179 | The power of a n-phase circuit can be measured by using a minimum of ___ |
| 1180 | Various adjustments in an energy meter include ___ |
| 1181 | In an energymeter braking torque is produced to ___ |
| 1182 | Wattmeter cannot be designed on the principle of ___ |
| 1183 | An instrument transformer is used to extend the range of ___ |
| 1184 | Instrument transformers are ___ |
| 1185 | Most sensitive galvanometer is ___ |
| 1186 | Alternating current is measured by ___ |
| 1187 | The rectifier instrument is not free from ___ |
| 1188 | A multirange instrument has ___ |
| 1189 | A sensitive galvanometer produces large deflection for a ___ |
| 1190 | The gravity controlled instrument has crowded scale because current is proportional to ___ |
| 1191 | E.m.f. of a Weston cell is accurately measured by ___ |
| 1192 | Volt box is a component to ___ |
| 1193 | If an instrument has cramped scale for larger values, then it follows ___ |
| 1194 | Damping of the Ballistic galvanometer is made small to ___ |
| 1195 | Commonly used instruments in power system measurement are ___ |
| 1196 | Operating torques in analogue instruments are ___ |
| 1197 | Commonly used standard capacitor is ___ |
| 1198 | Standard resistor is made from ___ |
| 1199 | Systematic errors are ___ |
| 1200 | The ratio of maximum displacement deviation to full scale deviation of the instrument is called ___ |
| 1201 | The desirable static characteristics of a measuring system are ___ |
| 1202 | The power factor of a single phase load can be calculated if the instruments available are ___ |
| 1203 | In Weston synchronoscope the moving coil is connected across ___ |
| 1204 | In a Weston synchronoscope, the fixed coils are connected across ___ |
| 1205 | In a Weston frequency meter, the magnetic axes of the two fixed coils are ___ |
| 1206 | In a dynamometer 3-phase power factor meter, the planes of the two moving coils are at ___ |
| 1207 | In a single phase power factor meter the phase difference between the currents in the two pressure coils is ___ |
| 1208 | The two pressure coils of a single phase power factor meter have ___ |
| 1209 | If an inductance is connected in one arm of bridge and resistances in the remaining three arms ___ |
| 1210 | To avoid the effect of stray magnetic field in A.C. bridges we can use ___ |
| 1211 | In a Schering bridge the potential of the detector above earth potential is ___ |
| 1212 | If the current in a capacitor leads the voltage by 80°, the loss angle of the capacitor is ___ |
| 1213 | For measurement of inductance having high value, we should use ___ |
| 1214 | For measurement of mutual inductance we can use ___ |
| 1215 | Wagner earthing device is used to eliminate errors due to ___ |
| 1216 | In an Anderson bridge, the unknown inductance is measured in terms of ___ |
| 1217 | For measurements on high voltage capacitors, the suitable bridge is ___ |
| 1218 | A universal RLC bridge uses ___ |
| 1219 | In an AC. co-ordinate potentiometer, the currents in the phase and quadrature potentiometer are adjusted to be ___ |
| 1220 | The stator of phase shifting transformer for use in conjunction with an A.C. potentiometer usually has a ___ |
| 1221 | To measure an A. C. voltage by using an A.C. potentiometer, it is desirable that the supply for the potentiometer in taken ___ |
| 1222 | In order to achieve high accuracy, the slide wire of a potentiometer should be ___ |
| 1223 | To measure a resistance with the help of a potentiometer it is ___ |
| 1224 | A direct current can be measured by ___ |
| 1225 | A voltage of about 200 V can be measured ___ |
| 1226 | Which of the following devices should be used for accurate measurement of low D.C. voltage ___ |
| 1227 | Murray loop test can be used for location of ___ |
| 1228 | The operating voltage of a meggar is about ___ |
| 1229 | In a meggar controlling torque is provided by ___ |
| 1230 | The electrical power to a meggar is provided by ___ |
| 1231 | When a capacitor was connected to the terminal of ohmmeter, the pointer indicated a low resistance initially and then slowly came to infinity position ___ |
| 1232 | The adjustment of position of shading bands, in an energy meter is done to provide ___ |
| 1233 | In a 3-phase power measurement by two wattmeter method the reading of one of the wattmeter was zero ___ |
| 1234 | In a 3-phase power measurement by two wattmeter method, both the watt meters had identical readings ___ |
| 1235 | In a low power factor wattmeter the compensating coil is connected ___ |
| 1236 | In a low power factor wattmeter the pressure coil is connected ___ |
| 1237 | The pressure coil of a wattmeter should be connected on the supply side of the current coil when ___ |
| 1238 | For measuring current at high frequency we should use ___ |
| 1239 | The scale of a rectifier instrument is ___ |
| 1240 | The multiplier and the meter coil in a voltmeter are in ___ |
| 1241 | The function of shunt in an ammeter is ___ |
| 1242 | The switch board instruments ___ |
| 1243 | The disc of an instrument using eddy current damping should be of ___ |
| 1244 | In a portable instrument, the controlling torque is provided by ___ |
| 1245 | An ammeter is a ___ |
| 1246 | In majority of instruments damping is provided by ___ |
| 1247 | The pointer of an indicating instrument should ___ |
| 1248 | ___ is an instrument which measures the insulation resistance of an electric circuit relative to earth and one another, |
| 1249 | A potentiometer may be used for ___ |
| 1250 | Which of the following is an essential part of a motor meter ___ |
| 1251 | Which of the following meters are not used on D.C. circuits ___ |
| 1252 | Most common form of A.C. meters met with in every day domestic and industrial installations are ___ |
| 1253 | For handling greater currents induction wattmeters are used in conjunction with ___ |
| 1254 | An induction meter can handle current upto ___ |
| 1255 | Which of the following devices may be used for extending the range of instruments ___ |
| 1256 | A moving-coil permanent-magnet instrument can be used as flux-meter ___ |
| 1257 | A moving-coil permanent-magnet instrument can be used as ___ by using a low resistance shunt |
| 1258 | Which of the following properties a damping oil must possess ___ |
| 1259 | The spring material used in a spring control device should have the following property ___ |
| 1260 | A ___ device prevents the oscillation of the moving system and enables the latter to reach its final position quickly |
| 1261 | Which of the following essential features is possessed by an indicating instrument ___ |
| 1262 | According to application, instruments are classified as ___ |
| 1263 | Resistances can be measured with the help of ___ |
| 1264 | Which of the following are integrating instruments ___ |
| 1265 | ___ instruments are those which measure the total quantity of electricity delivered in a particular time |
| 1266 | Which of the following instruments indicate the instantaneous value of the electrical quantity being measured at the time at which it is being measured ___ |
| 1267 | The use of ___ instruments is merely confined within laboratories as standardizing instruments |
| 1268 | If J is moment of Inertia, D is damping constant, C is spring constant, G is displacement constant and I is current throught the coil of DArsonval galvanometer, the equation of motion is ___ |
| 1269 | The term ‘Poisson’s ratio’ is connected with ___ |
| 1270 | While calibrating an ammeter by a dc potentiometer it is necessary to use a standard resistance ___ |
| 1271 | The flow rate of electrically conducting liquid without any suspended particle can not be measured by ___ |
| 1272 | An electrostatic voltmeter is suitable for ___ |
| 1273 | The precision of an instrument indicates its ability to reproduce a certain reading with a given ___ |
| 1274 | The electrical power to a megger is provided by ___ |
| 1275 | The dynamic characteristics of capacitive transducer are similar to those of ___ |
| 1276 | Which of the following combinations is not used in thermocouple transducer measurement of temperature ___ |
| 1277 | The scale of thermocouple instrument is linear ___ |
| 1278 | Harmonic distortion analyser ___ |
| 1279 | Which of the following, is not a piezoelectric material ___ |
| 1280 | An RTD uses platinum coil ___ |
| 1281 | For best results the system of a D’Arsonval galvanometer should be slightly under damped ___ |
| 1282 | Crompton potentiometer has ___ |
| 1283 | Measurement of non-electrical quantity involves the following subsystems ___ |
| 1284 | If two time varying signals of equal magnitudes and 90° phase displacement are applied to X and Y plates of CRO, the display will be |
| 1285 | It is required to measure the true open circuit emf of a battery ___ |
| 1286 | Basically a potentiometer is a device for ___ |
| 1287 | The material used in RTD is ___ |
| 1288 | In figure the values of ___ |
| 1289 | The response of D’Arsonval galvanometer is over damped if ___ |
| 1290 | The deflection sensitivity of a CRO is generally expressed in ___ |
| 1291 | Wagner earthing device eliminates ___ |
| 1292 | A photovoltaic cell is greatly affected by temperature ___ |
| 1293 | The method of frequency compensation in moving iron voltmeter is ___ |
| 1294 | If Ey is the voltage applied to Y plates, the vertical deflection of beam is proportional to ___ |
| 1295 | A dynamometer wattmeter is suitable for both dc and ac ___ |
| 1296 | In measurements using CRO, Lissajous patterns are used to ___ |
| 1297 | If the load current is high, the pressure coil of wattmeter should be connected directly across the load ___ |
| 1298 | DC voltage of the order of a few mV can be accurately of measured by ___ |
| 1299 | The gall tinsley potentiometer is a coordinate potentiometer and has two exactly similar potentiometers ___ |
| 1300 | Which of the following is used as detector in audio frequency ac bridges ___ |
| 1301 | An oscilloscope has an input impedance consisting of 1 MΩ and 20 pF is parallel ___ |
| 1302 | Rayleigh current balance is an absolute instrument ___ |
| 1303 | The 10 MHz in the specification of CRO means that ___ |
| 1304 | A Weston frequency meter is ___ |
| 1305 | The circuit of figure is used to measure the value ___ |
| 1306 | The speed of a shaft can be measured by using a dc tacho generator ___ |
| 1307 | A resistance strain gauge has a resistance of about ___ |
| 1308 | For measuring inductance with high Q, we should use ___ |
| 1309 | A peak responding ac voltmeter using a half wave rectifier has been calibrated to read 1 V for 1 V rms sine wave input ___ |
| 1310 | A coil resonates at 1 MHz with a resonating capacitance of 72 pF ___ |
| 1311 | Two wattmeter method for 3 phase power measurement can be used only for ___ |
| 1312 | A linear displacement digital transducer generally uses ___ |
| 1313 | To measure an unknown ac voltage by an ac potentiometer it is desirable that supply for the potentiometer is taken ___ |
| 1314 | The temperature coefficient of resistance for a thermistor is ___ |
| 1315 | A moving iron instrument has ___ |
| 1316 | If Eb is the potential of accelerating anode, the energy of electrons as they emerge from electron gun is proportional to ___ |
| 1317 | A data signal having frequency components from dc to 50 Hz is to be sent through pulse code modulation using an 8 digit code ___ |
| 1318 | The trigger circuit of a CRO is excited by the same signal as Y plates ___ |
| 1319 | Hall effect is observed in all metals but is very appreciable in semiconductors ___ |
| 1320 | Consider the following galvanometers ___ |
| 1321 | A direct current can be measured ___ |
| 1322 | In a megger the moving coil meter has a permanent magnet ___ |
| 1323 | In two wattmeter method of 3 phase power measurement, one of the wattmeters would read negative if power factor of load is less than 0.5 ___ |
| 1324 | If σ standard deviation, probable error ___ |
| 1325 | The accuracy of an instrument is determined by ___ |
| 1326 | In a CRO the Y plates are oriented ___ |
| 1327 | Schering bridge is used to measure ___ |
| 1328 | A D’ Arsonval galvanometer is a ___ |
| 1329 | The phenomenon of creep occurs in ___ |
| 1330 | Which of the following transformers has low primary current ___ |
| 1331 | To measure an emf by dc potentiometer it is necessary to standardise the potentiometer with the help of a standard cell ___ |
| 1332 | A dc potentiometer measures the true open circuit emf of a source ___ |
| 1333 | Load cell uses ___ |
| 1334 | In a dynamometer instrument, the moving coil is pressure coil ___ |
| 1335 | Which of the following quantities have same dimension in emu and esu ___ |
| 1336 | It is required to measure pressure using LVDT ___ |
| 1337 | The moving iron instruments are generally repulsion type ___ |
| 1338 | In a low power factor wattmeter, the resistance of pressure coil is more than in ordinary wattmeter ___ |
| 1339 | In which of the following instruments is the deflecting torque proportional to ___ |
| 1340 | An E transformer is a ___ |
| 1341 | To measure moisture in wood, the most suitable method is ___ |
| 1342 | RTD is generally suitable for temperature up to ___ |
| 1343 | Wagner earthing device is used to eliminate error due to ___ |
| 1344 | If two time varying signals of equal magnitude and zero phase displacement are applied to X and Y plates respectively; of CRO, the display will be ___ |
| 1345 | A transducer must have ___ |
| 1346 | A dynamometer wattmeter can be used for ___ |
| 1347 | Energy meters use induction principle ___ |
| 1348 | The total insulation resistance consists of insulation volume resistance and surface leakage resistance ___ |
| 1349 | Capacitance effect can be used to measure thickness of sheets, displacement and pressure ___ |
| 1350 | Gauge factor of a strain gauge is ___ |
| 1351 | Eddy currents are essential for the deflecting torque of an induction wattmeter ___ |
| 1352 | The time base of a high frequency CRO whose screen diameter is 10 cm is set at 10 μ sec/cm ___ |
| 1353 | In a current transformers ___ |
| 1354 | Induction wattmeter is an absolute instrument ___ |
| 1355 | The accuracy of a multimeter is about ___ |
| 1356 | Which is the displacement transducer with excellent sensitivity, linearity and resolution ___ |
| 1357 | Which of the following is active transducer ___ |
| 1358 | Magnetic deflection sensitivity is defined as ___ |
| 1359 | In Maxwell’s bridge the unknown inductance is measured by comparing it with a standard capacitor ___ |
| 1360 | The sign and magnitude of displacement can be measured by an LVDT ___ |
| 1361 | Which of the following effects is used in measurement of magnetic flux ___ |
| 1362 | Capacitive transducer is superior to inductive type for measurement of capacitance because of ___ |
| 1363 | Loading effect is primarily caused by instruments having ___ |
| 1364 | An ohmmeter is a ___ |
| 1365 | The operating voltage of a megger is about ___ |
| 1366 | If C is spring constant and θ is deflection, controlling torque is ___ |
| 1367 | The torque in an induction wattmeter is proportional to ___ |
| 1368 | The pressure coil of a wattmeter should be connected to the supply side of the current coil when ___ |
| 1369 | The output of a Piezoelectric crystal has ___ |
| 1370 | A radiation pyrometer is very suitable for high temperature measurement ___ |
| 1371 | A power factor meter operates on dynamometer principle ___ |
| 1372 | Megger is used to check insulation resistance of cables ___ |
| 1373 | In a Weston synchronoscope the deflecting torque is zero when ___ |
| 1374 | The advantage of LVDT over inductive bridge type transducer is that ___ |
| 1375 | The advantage of semiconductor strain gauge over resistance strain gauge is ___ |
| 1376 | The coding system generally used in digital telemetry is ___ |
| 1377 | In a Weston synchronoscope, the moving coil is connected across ___ |
| 1378 | Consider the following statements regarding phase sensitive detector ___ |
| 1379 | The numbers of accelerating anodes in a CRO is ___ |
| 1380 | The adjustment of position of shading bands, in an energy meter, is done to provide ___ |
| 1381 | The multiplier resistance and meter coil in a voltmeter are in ___ |
| 1382 | Two wattmeter method of 3-phase power measurement can be used to find ___ |
| 1383 | A moving iron instrument can be used for dc as well as ac ___ |
| 1384 | For measuring current at a high frequency we should use ___ |
| 1385 | In a CRT, grid is kept at negative potential with respect to cathode ___ |
| 1386 | Which of the following can be used for measuring capacitance ___ |
| 1387 | Panel type instruments are used in ___ |
| 1388 | The damping ratio, in D’Arsonval galvanometer is equal to ___ |
| 1389 | Magnetic flux can be measured by ___ |
| 1390 | Consider the following statements regarding electro-dynamometer type indicating instrument ___ |
| 1391 | Electrodynamic instrument is not used as ammeter or voltmeter ___ |
| 1392 | The signal to noise ratio in telemetry should be better than ___ |
| 1393 | In low power factor wattmeter, the pressure coil is connected ___ |
| 1394 | Consider the following statements about mutual inductances ___ |
| 1395 | An ac bridge uses galvanometer as detector ___ |
| 1396 | If they are connected in parallel, the limiting error in percent will be ___ |
| 1397 | The sensitivity of a potentiometer can be increased by ___ |
| 1398 | An average responding voltmeter using full wave rectifier has been calibrated to read 1 V for 1 V rms sinusoidal input ___ |
| 1399 | The stator of phase shifting transformer for use in conjunction with an ac potentiometer has a ___ |
| 1400 | Bridge circuits using RTD in temperature measurement usually employ 3 lead system so as to obtain ___ |
| 1401 | It is required to measure a low magnitude high frequency current ___ |
| 1402 | Which of the following is not a transducer in true sense ___ |
| 1403 | In Weston synchronoscope the fixed coils are connected across ___ |
| 1404 | Four terminal approach is used in measuring low resistance because it ___ |
| 1405 | In semiconductor strain gauge ___ |
| 1406 | A Q meter uses the principle of ___ |
| 1407 | The dimensions of permittivity are ___ |
| 1408 | An electrodynamometer instrument has the advantage of ___ |
| 1409 | If σ is standard deviation, variation is ___ |
| 1410 | Which of the following devices should be used for accurate measurement of a low dc voltage ___ |
| 1411 | Burden of an instrument transformer is expressed in ___ |
| 1412 | Absolute instruments are used in ___ |
| 1413 | Thermistors are commonly used to measure hot spot temperatures in electric machines ___ |
| 1414 | The scale of PMMC instrument is linear ___ |
| 1415 | LVDT is used to measure ___ |
| 1416 | CRO can be used to study waveshape accurately ___ |
| 1417 | The total capacitance in significant figures is ___ |
| 1418 | Four capacitors are in parallel ___ |
| 1419 | A capacitance transducer has two plates each of area ___ |
| 1420 | CRT is the most important component of a CRO ___ |
| 1421 | Pirani gauge is used to measure ___ |
| 1422 | Which one of the following is true ___ |
| 1423 | In Weston frequency meter, the magnetic axes of the two fixed coils are ___ |
| 1424 | Which of these instrument does not have a control spring ___ |
| 1425 | Schering bridge operates at a high voltage of about 10 kV ___ |
| 1426 | In a CRO, the time base signal is applied to ___ |
| 1427 | Consider the following statements regarding electromagnetic flowmeter ___ |
| 1428 | The coil of a DArsonval galvanometer has N turns ___ |
| 1429 | Which of the following instruments is used almost exclusively to measure radio frequency currents ___ |
| 1430 | The gauge factor of a semiconductor strain gauge is about ___ |
| 1431 | In a platinum RTD, the change in resistance for a temperature rise of 50° C is about ___ |
| 1432 | Damping in a vibration galvanometer is small ___ |
| 1433 | For measuring a very high resistance we should use ___ |
| 1434 | In indicating instruments the controlling torque is provided by a spring ___ |
| 1435 | In air friction damping ___ |
| 1436 | The difference between measured value and true value is called ___ |
| 1437 | In measuring resistance using voltmeter and ammeter, the resistances of voltmeter and ammeter also affect the accuracy of measurement ___ |
| 1438 | In an ac coordinate potentiometer, the currents inphase and quadrature potentiometer are adjusted to be ___ |
| 1439 | In a single phase power factor meter the phase difference between currents in the two pressure coils is ___ |
| 1440 | The chemical effect of current is used in ___ |
| 1441 | In an ac single phase energy meter, the potential coil is put on ___ |
| 1442 | In measurements using strain gauge, the dummy strain gauge is used to ___ |
| 1443 | A CT is used to feed current coils of wattmeter, energy meter, power factor meter and an ammeter ___ |
| 1444 | A permanent magnet moving coil measures ___ |
| 1445 | In low power factor wattmeter, the compensating coil is connected ___ |
| 1446 | An average responding rectifier type electronic voltmeter has its scale calibrated in terms of rms value of sine wave ___ |
| 1447 | The time base generator in a CRO gives an output which is ___ |
| 1448 | Which bridge can be used to measure frequency ___ |
| 1449 | The resistance of resistance strain gauge is about ___ |
| 1450 | The pointer of an indicating instrument should be ___ |
| 1451 | An electrostatic voltmeter is free from hysteresis and eddy current errors ___ |
| 1452 | The most serious problems in ac bridge measurement is ___ |
| 1453 | A digital voltmeter can count from 0 to 9999 ___ |
| 1454 | A 3 phase wattmeter consists of two wattmeters mounted in one case ___ |
| 1455 | Absolute instruments are used in standard laboratories ___ |
| 1456 | The channel required for FM telemetry is ___ |
| 1457 | The accuracy of measurement using CRO is about ___ |
| 1458 | A single phase energy meter operates on induction principle ___ |
| 1459 | A diode peak reading VTVM and thermocouple meter are connected across output of an amplitude modulated circuit. In the absence of modulation both meters read 10 V ___ |
| 1460 | The increase in intensity of trace in a CRO causes a change in ___ |
| 1461 | The sensitivity of electromagnetic digital flow meter can be increased by increasing ___ |
| 1462 | In portable instruments, damping is provided by ___ |
| 1463 | When frequencies of signals fed to X and Y plates of CRO are multiples of each other, Lissajous pattern is displayed on screen ___ |
| 1464 | For a current transformer, the standard secondary rating is ___ |
| 1465 | A Maxwell’s bridge has the unknown inductance in one arm and resistance in the other three arms ___ |
| 1466 | Consider the following statements as regards induction and dynamometer wattmeters ___ |
| 1467 | The range of RTD using platinum is about ___ |
| 1468 | In ac bridge measurements, ‘Wagner ground’ means ___ |
| 1469 | Secondary instruments require calibration at frequent intervals ___ |
| 1470 | If n measurements of a quantity are made, the arithmetic mean is ___ |
| 1471 | A resistance strain gauge is usually ___ |
| 1472 | To avoid the effect of stray magnetic fields in ac bridge we can use ___ |
| 1473 | For measurement of high voltage capacitors the suitable bridge is ___ |
| 1474 | A 3-digit voltmeter having a resolution of 100 mV can be used to measure a maximum of ___ |
| 1475 | In a megger the controlling torque is provided by ___ |
| 1476 | A phase shifting transformer is used in conjunction with ___ |
| 1477 | Without a spectrum analyser, it is not possible to determine ___ |
| 1478 | Acoustic strain gauges ___ |
| 1479 | A transducer needs an output measuring or display device for measuring a non electrical quantity ___ |
| 1480 | A ballistic galvanometer is used to measure charge ___ |
| 1481 | A hot wire instrument is not affected by stray magnetic fields ___ |
| 1482 | A megger has a hand driven dc generator ___ |
| 1483 | Which of the following draws minimum power from source ___ |
| 1484 | If temperature increases by about 50°, the resistance of thermistor changes to ___ |
| 1485 | A permanent magnet moving coil meter can be used as ___ |
| 1486 | In a hot wire instrument, the deflection is proportional to ___ |
| 1487 | The resistance of voltmeter affects the accuracy of measurement in loss of charge method ___ |
| 1488 | Minute cracks in metals and minute faults in welded joints can be detected using ___ |
| 1489 | To measure dielectric loss you would use ___ |
| 1490 | In a semiconductor strain gauge, the ohmic electrical contacts are generally made of ___ |
| 1491 | A power factor meter has ___ |
| 1492 | In a phase shifting transformer the currents in the two stator winding are in phase ___ |
| 1493 | A vibration galvanometer is a ___ |
| 1494 | A thermocouple instrument can be used over a very wide frequency range ___ |
| 1495 | If the reading of an instrument is low, the error is large ___ |
| 1496 | If A = 629 ± 8 and B = 131 ± 3, A-B with range of doubt is ___ |
| 1497 | Which of these instruments has highest power consumption ___ |
| 1498 | It is required to measure temperature in the range of 1300-1520°C ___ |
| 1499 | An ammeter is ___ |
| 1500 | Watthour meter is an integrating instrument ___ |
| 1501 | The instrument used to check insulation of household wiring is ___ |
| 1502 | Which of these instruments is dynamometers type ___ |
| 1503 | Magnetic effect of current is used in ___ |
| 1504 | In figure the output is ___ |
| 1505 | The coils of Drysdale polar potentiometer are wound non-inductively ___ |
| 1506 | Heating effect of current is used in ___ |
| 1507 | The Y plates of a CRO are excited by a voltage 2 sin 100 t and the X plates are not connected |
| 1508 | For measuring mutual inductance we can use ___ |
| 1509 | A dual trace CRO has ___ |
| 1510 | Two meters X and Y require 40 mA and 50 mA for full scale deflection ___ |
| 1511 | The sensitivity of a voltmeter using 0-5 mA meter movement is ___ |
| 1512 | When deflecting torque and braking torque in an energy meter are zero, ___ |
| 1513 | Which instrument needs creep compensation ___ |
| 1514 | In a Ballistic galvanometer ___ |
| 1515 | In an Anderson bridge the unknown inductance is measured in terms of ___ |
| 1516 | A thermocouple transducer is based on Seeback effect ___ |
| 1517 | If tolerance of each resistor is 0.1%, the maximum error in voltage is ___ |
| 1518 | In a dynamometer 3 phase power factor meter, the planes of the two moving coils are at ___ |
| 1519 | A Weston synchronoscope is a ___ |
| 1520 | De Sauty bridge is very widely used due to ___ |
| 1521 | In a low power factor wattmeter, compensation for pressure coil current is provided ___ |
| 1522 | A voltage of about 200 V dc can be measured ___ |
| 1523 | In dc tacho generators used for measurement of speed of shaft, frequent calibration is necessary because ___ |
| 1524 | The braking torque in single phase energy meter is proportional to speed of disc ___ |
| 1525 | A current of 3.25 A is flowing through a resistance of 34.98 Ω ___ |
| 1526 | A current of 3.18 A is flowing through resistance of 35.68 Ω ___ |
| 1527 | Piezoelectric effect can be used to measure ___ |
| 1528 | The two pressure coils in a single phase power factor meter of turns ___ |
| 1529 | Consider the following statements about a moving iron instrument ___ |
| 1530 | For use at 50 Hz the range of scale of vibrating reed frequency meter is ___ |
| 1531 | Which of the following closely represents the resistance-temperature characteristics of thermistor ___ |
| 1532 | The device having highest photo sensitivity is ___ |
| 1533 | Hay’s bridge in particularly suitable for measuring inductance having a comparatively low resistance ___ |
| 1534 | Shaft encoder is used to measure ___ |
| 1535 | Double Kelvin’s bridge is used to measure low resistances ___ |
| 1536 | The resistance of series field winding is a low resistance ___ |
| 1537 | Use of high permeability core in moving iron instrument helps in ___ |
| 1538 | A land line telemetry system is suitable for distance upto ___ |
| 1539 | Moving iron instrument can be used on ac or dc ___ |
| 1540 | The scale a PMMC ammeter is linear ___ |
| 1541 | In bridge circuit of figure, equivalent resistance between A and B is ___ |
| 1542 | An instrument of accuracy class 1 can have an error equal to ___ |
| 1543 | The sum of two resistors along with limiting error is ___ |
| 1544 | During testing of an energy meter, the energy recorded by meter was 0.05 kWh and correct energy was found to be 0.09 kWh ___ |
| 1545 | The torque in induction wattmeters due to ___ |
| 1546 | Many instruments use eddy current damping ___ |
| 1547 | Panel instruments are generally mounted vertically ___ |
| 1548 | For measuring temperatures below 800°C with high accuracy, the best instrument is ___ |
| 1549 | To measure a resistance of about 8 ohms we should use ___ |
| 1550 | An induction wattmeter can be used for ac only ___ |
| 1551 | Three phase four wire induction energy meter is used to measure ___ |
| 1552 | The scale of a dynamometer is linear when used as ___ |
| 1553 | Two sinusoidal signals of equal amplitude and frequency are applied to X and Y plate of CRO respectively ___ |
| 1554 | If the resistance of shunt of an ammeter is increased, the range of ammeter is reduced ___ |
| 1555 | The ac bridge in figure is balanced ___ |
| 1556 | An ammeter has a resistance of 50 ohms and a shunt of 0.01 Ω ___ |
| 1557 | In electronic voltmeters the measuring device is a ___ |
| 1558 | Moving iron instrument can be used for ac only ___ |
| 1559 | Hay’s bridge is suitable for inductances having low L/R ratio ___ |
| 1560 | The accuracy of measurement by ohmmeter is very good ___ |
| 1561 | DC ampere hour meter is an indicating instrument ___ |
| 1562 | A 0-200 V voltmeter has a sensitivity of 1 kΩ per volt ___ |
| 1563 | In most of instruments, the controlling torque is provided by ___ |
| 1564 | As per BIS, the number of accuracy classes of instrument is ___ |
| 1565 | For measurement of surface temperature of solids the elements of RTD is usually in the shape of ___ |
| 1566 | Which of the following methods can be used to measure power in a single phase circuit without using wattmeter ___ |
| 1567 | In measuring a resistance by voltmeter-ammeter method, the voltmeter can be connected either across supply or across the resistance ___ |
| 1568 | A moving coil meter has a resistance of 50 ohms and a full scale deflection current of 20 mA ___ |
| 1569 | An amplifier has to amplify pulses of 1 H-s duration ___ |
| 1570 | The dimensions of force are ___ |
| 1571 | The dead zone in a pyrometer is 0.125% of span ___ |
| 1572 | A polyphase wattmeter basically consists of two wattmeters ___ |
| 1573 | Two ammeters having resistances of 0.5 Ω and 0.25 Ω and having full scale reading of 25 A each are connected in parallel ___ |
| 1574 | The deflection of a DArsonval galvanometer is measured through a mirror and scale ___ |
| 1575 | Four voltmeters have following specifications ___ |
| 1576 | A wire strain gauge has a gauge factor of 2, resistance of 125 Ω and length 1 m ___ |
| 1577 | To avoid creep in an energy meter ___ |
| 1578 | Wheatstone bridge is suitable for low resistances ___ |
| 1579 | A sinusoidal signal is measured by CRO ___ |
| 1580 | It is necessary to measure the amplitudes of two signals and also the phase difference between them ___ |
| 1581 | Which of the following does not use the principle of change in inductance ___ |
| 1582 | The function of shunt in an ammeter is to ___ |
| 1583 | The total resistance will be ___ |
| 1584 | If A = 131 ± 4 and B = 106 ± 4, the percentage range of doubt in A-B is ___ |
| 1585 | In a CRO, the frequency of output of time base generator ___ |
| 1586 | A 0-150 voltmeter has a guaranteed accuracy of 1% of full scale reading ___ |
| 1587 | Consider the following instruments and find absolute instruments are ___ |
| 1588 | If the secondary burden of a CT 15 VA and secondary current is 5 A, the load impedance of CT is ___ |
| 1589 | The current passing through a resistance of 100 ± 0.2% Ω is 2 ± 0.5% A ___ |
| 1590 | Figure shows a Wheatstone bridge with RTD to one arm ___ |
| 1591 | A temperature sensistive transducer is subjected to sudden temperature change ___ |
| 1592 | What would be the reading of voltmeter as ___ |
| 1593 | The resistance in the circuit of the moving coil of a dynamometer wattmeter should be ___ |
| 1594 | The current through a resistance R is ___ |
| 1595 | In a thermocouple two metal junctions between metals ___ |
| 1596 | A 300 V voltmeter has an accuracy of ± 2% of full scale deflection ___ |
| 1597 | Two voltmeters are each 0-300 V range ___ |
| 1598 | A moving iron instrument can be used for ___ |
| 1599 | The most commonly used moving iron instruments are ___ |
| 1600 | Magnetic deflection is inversely proportional to ___ |
| 1601 | The scale of dynamometer wattmeter is non linear ___ |
| 1602 | A low power factor wattmeter has special constructional features to ensure accurate measurement ___ |
| 1603 | The use of thermocouple meters for ac measurement leads to a scale which is ___ |
| 1604 | A 1 mA meter is to be converted to 1 A ammeter ___ |
| 1605 | If a shunt of 200 Ω resistance is used with a galvanometer of 1000 Ω resistance, the multiplying power is ___ |
| 1606 | Strain measurement using strain gauge invariably requires a dummy strain gauge ___ |
| 1607 | Which of the following instruments can be used for dc as well ac upto a few MHz ___ |
| 1608 | A moving coil meter has 10 Ω resistance and requires 40 mA for full scale deflection ___ |
| 1609 | From the following statements, the correct statements are ___ |
| 1610 | A radiation thermometer is suitable for temperatures ___ |
| 1611 | A rectifier voltmeter using bridge rectifier and PMMC meter is calibrated to read rms value of sine wave ___ |
| 1612 | Two wattmeter method is suitable only for balanced loads ___ |
| 1613 | A meter has a resistance of 1 Ω and full scale deflection current of 1 mA ___ |
| 1614 | Thermocouple instruments can be used for ac only ___ |
| 1615 | The percentage limiting error in an instrument reading 8.3 V and having guaranteed accuracy of 1% of the full scale reading and range of 0-150 V is ___ |
| 1616 | If the secondary winding of CT is opened when primary coil is carrying current ___ |
| 1617 | In loss of charge method, it is preferable to use an electronic voltmeter ___ |
| 1618 | It is required to study transients during switching process ___ |
| 1619 | A resistance is measured by voltmeter-ammeter method ___ |
| 1620 | The response of a thermistor overs the whole of its temperatures range is ___ |
| 1621 | The wave applied to X plates, for ohtaining trace of voltage wave, is ___ |
| 1622 | Which of the following is not correct in respect of electrostatic instrument ___ |
| 1623 | The input impedance of CRO is about ___ |
| 1624 | The total resistance to the appropriate number of significant figures is ___ |
| 1625 | The current through the coil of an electromagnet is doubled ___ |
| 1626 | A variable reluctance type tachometer has 150 teeth on rotor ___ |
| 1627 | The power factor of a single phase load can be calculated if instruments available are ___ |
| 1628 | The emf of a Weston cell is 1.286 V ___ |
| 1629 | A universal RLC bridge has a battery and also a high frequency ac source ___ |
| 1630 | In household energy meters the flux of series magnet is in phase with current but the flux of shunt magnet lags the voltage by 88° ___ |
| 1631 | For balanced condition, Zd will be ___ |
| 1632 | Two ammeters A and B are connected in parallel in a circuit carrying 100 A ___ |
| 1633 | Insertion of a dielectric material between the plates of an air capacitor ___ |
| 1634 | A resistance wire strain gauge has gauge factor 2 ___ |
| 1635 | A high resistance was measured by the loss of charge method ___ |
| 1636 | The effect of lead resistance is important in measurement of ___ |
| 1637 | Which one of the following effects is used in measuring power ___ |
| 1638 | Consider the following features of an instrument ___ |
| 1639 | A moving coil meter has a shunt of 0.02 Ω resistance ___ |
| 1640 | The scale of hot wire ammeter is ___ |
| 1641 | In hot wire instrument the material of hot wire in generally platinum iridium ___ |
| 1642 | The dynamometer principle can be used for ___ |
| 1643 | A capacitance transducer can be used to measure ___ |
| 1644 | The resistance of a dc galvanometer is 20 Ω. A current of 10 mA causes full scale deflection ___ |
| 1645 | Current density has the dimensions ___ |
| 1646 | Maxwell bridge is for measuring inductance of medium magnitude ___ |
| 1647 | The loss of charge method can be used to measure ___ |
| 1648 | Which of the following is not correct ___ |
| 1649 | Two ammeters A and B both 0-10 A have internal resistance of 1 Ω and 0.5 Ω respectively ___ |
| 1650 | A Hall effect transducer has ___ |
| 1651 | A volt ratio box should have low resistance ___ |
| 1652 | The current in a circuit is measured using a 150 : 1 CT If the ammeter reads 0.6 A, the circuit current is ___ |
| 1653 | In an induction wattmeter, the shading bands are made of non conducting material ___ |
| 1654 | If the current in a capacitor leads the voltage by 80°, the loss angle of capacitor is ___ |
| 1655 | In the balanced bridge shown in figure ___ |
| 1656 | An induction wattmeter can be used for ___ |
| 1657 | A meter having 0-1000 μA range and 1000 Ω resistance is required to be changed to 0-100 mA meter ___ |
| 1658 | It is required that a strain gauge has gauge factor of 100 ___ |
| 1659 | When measuring phase angle between two waves using a CRO, the time base generator is connected to ___ |
| 1660 | With a variable reluctance tachometer having 60 rotor teeth the count reads 3600 counts per minute ___ |
| 1661 | The scale of moving iron instrument is linear ___ |
| 1662 | If eddy current damping is to be used, the disc of instrument should be ___ |
| 1663 | When a capacitor is connected to the terminals of an ohmmeter, the pointer indicated a low resistance initially and finally come to infinity position ___ |
| 1664 | A sinusoidal ac voltage of amplitude 100 V is applied to a rectifying device which offers 10 Ω resistance in forward direction and infinite resistance in reverse direction |
| 1665 | PCM employing 4 bit code is used to send data having frequency range from 0 to 2 kHz ___ |
| 1666 | Consider the following Statements regarding resistance strain gauge ___ |
| 1667 | A meter has a square law scale ___ |
| 1668 | In a digital measuring device the input electrical signal is in the frequency range of dc to ac (50) Hz ___ |
| 1669 | Measuring of unknown voltage with a dc potentiometer loses its advantage of open circuit measurement when ___ |
| 1670 | A 24 mm long conductor has a resistance of 128 Ω ___ |
| 1671 | Two voltmeters 0-250 V each having resistances of 5 kΩ and 10 kΩ respectively and are connected in series ___ |
| 1672 | Consider the following operation in respect of Wheatstone bridge ___ |
| 1673 | In the wheatstone bridge in figure, each resistance is increased by 0.05% ___ |
| 1674 | A variable reluctance tachometer has 180 teeth on rotor ___ |
| 1675 | A sinusoidal ac voltage of amplitude 100 V is applied to a rectifying device which offers 10 Ω resistance in forward direction and infinite resistance in backward direction ___ |
| 1676 | The volt ratio box is basically a ___ |
| 1677 | In figure, the position of voltmeter and ammeter are exchanged ___ |
| 1678 | Magnetic field intensity has the dimensions ___ |
| 1679 | Which instrument is based on induction principle ___ |
| 1680 | In 3 phase power measurement by two wattmeter method, both wattmeters had equal reading ___ |
| 1681 | Which of these has poor overload capacity ___ |
| 1682 | A frequency meter for 50 Hz system has a frequency range of 40 to 60 Hz ___ |
| 1683 | Wien bridge can be used for measuring frequency ___ |
| 1684 | Schering bridge is a low voltage bridge ___ |
| 1685 | Two numbers are 131 ± 5 and 629 ± 3 ___ |
| 1686 | Which of these has a magnetic brake ___ |
| 1687 | A meter coil has a resistance of 100 Ω and a full scale deflection current of 10 mA ___ |
| 1688 | The power input and output in a device are 3650 W and 3385 W with each reading in doubt by ± 10 W ___ |
| 1689 | Which of the following instruments has non-linear scale ___ |
| 1690 | The dimensions of EMF are ___ |
| 1691 | In Schering bridge, the potential of detector above earth potential is about ___ |
| 1692 | A 0-200 V voltmeter has an accuracy of 0.75% of full scale reading ___ |
| 1693 | LVDT is a ___ |
| 1694 | A single element strain gauge bridge has two fixed resistances ___ |
| 1695 | A moving iron voltmeter reads 250 V when connected to 250 V dc ___ |
| 1696 | If an inductance L is connected in one arm of bridge and resistance ___ |
| 1697 | An accelerometer has a seismic mass of 0.05 kg and spring constant of ___ |
| 1698 | Electrostatic voltmeter is suitable only for low voltages ___ |
| 1699 | The resistance of a 125 Ω strain gauge changes by 1 ohm for 4000 micro strain ___ |
| 1700 | The D’Arsonval- movement can be converted into audio frequency ac ammeter by adding a ___ |
| 1701 | The scale of hot wire instrument is linear ___ |
| 1702 | Shunt of an ammeter has a low resistance ___ |
| 1703 | Kelvin’s double bridge is used to measure low resistances because ___ |
| 1704 | In figure the bridge is balanced when ___ |
| 1705 | It is required to measure angular position ___ |
| 1706 | In two wattmeter method of 3 phase power measurement, when does one wattmeter read negative ___ |
| 1707 | Loss of charge method is suitable for medium resistances ___ |
| 1708 | A dynamometer wattmeter is connected in ac circuit. The measured power is ___ |
| 1709 | Induction wattmeter can be used in ___ |
| 1710 | A moving iron instrument gives correct reading when used at ___ |
| 1711 | In a thermocouple temperature transducer, the output voltage is usually measured by ___ |
| 1712 | Which of the following statement is correct for two wattmeters method of power measurement in 3 phase circuit ___ |
| 1713 | Which of the following measurements using a dc potentiometer do not require standardisation of potentiometer ___ |
| 1714 | A voltmeter using thermocouples measures ___ |
| 1715 | The speed transducer using a drag cup rotor has the main advantage of ___ |
| 1716 | A dynamometer wattmeter is connected in ac circuit ___ |
| 1717 | A digital frequency counter can be converted to DVM by addition of a suitable ___ |
| 1718 | Which of the following are needed both for protection and metering ___ |
| 1719 | Which of the following is true about an impulse voltage ___ |
| 1720 | A hot wire ammeter has a cramped scale ___ |
| 1721 | Potentiometer method of dc voltage measurement is more accurate than direct measurement using a voltmeter because ___ |
| 1722 | A moving coil instrument has a resistance of 0.5 Ω and a full scale deflection of 0.1 A ___ |
| 1723 | A full wave rectifier type meter is used to measure the wave shape ___ |
| 1724 | A standard cell of 1.0185 V is used with a slide wire potentiometer ___ |
| 1725 | The household energy meter is ___ |
| 1726 | In a resistance strain gauge, the value of ΔR will be ___ |
| 1727 | A meter with a resistance of 100 Ω and a full scale deflection of current of 1 mA is to be converted into voltmeter of 0-5 V range ___ |
| 1728 | Magnetic flux density has the dimensions ___ |
| 1729 | In a differential amplifier using JFET, the differential output offset is due to ___ |
| 1730 | The coil of a moving coil meter has 100 turns, is 40 mm long and 30 mm wide ___ |
| 1731 | A digital voltmeter has a read out range from 0 to 999 counts ___ |
| 1732 | The angle δ for a mica capacitor is about ___ |
| 1733 | The Lissajous pattern observed on screen of CRO is a straight line inclined at 45° to x axis ___ |
| 1734 | In a strain measuring device using a strain gauge, the output quantity is ___ |
| 1735 | Figure shows an RC potentiometer to measure ac voltage ___ |
| 1736 | The total resistance is ___ |
| 1737 | In a ballistic galvanometer, a charge of 100 μC gives a first swing of 25° ___ |
| 1738 | The Z4 for bridge to be balanced in the figure is ___ |
| 1739 | As per BIS there are 6 accuracy classes of instruments ___ |
| 1740 | When a wattmeter is used for low impedance loads, the pressure coil is connected across the load ___ |
| 1741 | An LVDT is used to measure displacement ___ |
| 1742 | A piezoelectric force transducer has a charge sensitivity of 20 pC/N ___ |
| 1743 | A moving coil instrument has a resistance of 0.6 Ω and full scale deflection at 0.1 A ___ |
| 1744 | In which of the transformer is the secondary nearly short circuited under normal operating conditions ___ |
| 1745 | De sauty’s bridge is suitable only for pure capacitor ___ |
| 1746 | A single phase energy meter has the rating 1200 resolutions/ kWh ___ |
| 1747 | Which of the following voltmeters would you use for measuring voltage across 20 kΩ resistance ___ |
| 1748 | If reference sound pressure ___ |
| 1749 | In a CRO which of the following is not a part of electron gun ___ |
| 1750 | In 3 phase power measurement by two wattmeter method, the reading of one wattmeter is zero ___ |
| 1751 | The coil of a moving iron instrument has a resistance of 500 Ω and an inductance of 1 H ___ |
| 1752 | An ammeter of 0-25 A range has a guaranteed accuracy of 1% of full scale reading ___ |
| 1753 | To increase Q factor of a coil, the wire should be ___ |
| 1754 | Composition of natural gas is determined by the ___ |
| 1755 | Which of the following thermocouples has the least temperature measurement range ___ |
| 1756 | Mercury thermometer is commonly used for low temperature measruement ___ |
| 1757 | Ordinary mercury in glass thermometer is used for measuring temperature upto 120°C ___ |
| 1758 | For two non-interacting first order systems connected in series, the overall transfer function is the ___ of the individual transfer functions |
| 1759 | Temperature of molten pig iron (1450°C) and molten slag (1500°C) flowing out of a blast furnace is measured by a/an ___ |
| 1760 | In Bode plot, Φ vs ω is plotted on a/an ___ graph paper |
| 1761 | Gain margin is equal to the ___ |
| 1762 | Temperature of ___ can not be measured by an optical or radiation pyrometer |
| 1763 | Minute depression of freezing point of a liquid solvent on addition of a solid solute can be best measured by a ___ |
| 1764 | Normal mercury thermometer can be used to measure a temperature of about 300°C ___ |
| 1765 | A manometer measures the ___ pressure |
| 1766 | Conversion formula for converting amplitude ratio (AR) into decibels is ___ |
| 1767 | If response of a control system is to be free of offset and oscillation, the most suitable controller is ___ |
| 1768 | Which of the following can measure temperatures in the range of-20 to 300°C ___ |
| 1769 | The frequency at which maximum amplitude ratio is attained is called the ___ frequency |
| 1770 | Working principle of mercury in glass thermometer is ___ |
| 1771 | Choose the wrong statement ___ |
| 1772 | Thermal well made of ___ gives the fastest speed of response, while measuring temperature by thermocouples |
| 1773 | Continuous measurement of moisture content of paper in paper industry is done by measuring the ___ |
| 1774 | Phase lag of the sinusoidal response of a first order system is ___ |
| 1775 | Dome temperature of blast furnace stove is most accurately measured by a ___ |
| 1776 | In second order underdamped system ___ |
| 1777 | The root locus plot of the roots of the characteristics equation of a closed loop system having the open loop transfer function ___ |
| 1778 | Stroboscope is used for the measurement of ___ |
| 1779 | Continuous measurement of specific gravity of a liquid is done by ___ |
| 1780 | For measuring the temperature of a red hot furnace, which is the most suitable instrument ___ |
| 1781 | A control system has the following transfer function ___ |
| 1782 | A first order system with unity gain and time constant T is subjected to a sinusoidal input of frequency w = 1/T ___ |
| 1783 | In Bode plot, A.R. vs. w is plotted on a/an ___ graph paper |
| 1784 | Which is the strongest paramagnetic gas ___ |
| 1785 | The thermal emf-temperature relationship of most thermocouples is ___ |
| 1786 | On-off control which is a special case of proportional control, has a band width of about ___ percent |
| 1787 | Platinum resistance thermometer is the international standard for temperature measurement between ___ |
| 1788 | Which of the following thermocouples is incapable of measuring sub-zero (i.e., < 0°C) temperature ___ |
| 1789 | Emf developed by a thermocouple while measuring a temperature of 800°C is about 31 mV ___ |
| 1790 | Which of the following is not a composition measuring instrument ___ |
| 1791 | Reference points i.e., ice point and steam point in Reaumer temperature scale are respectively ___ |
| 1792 | Flame photometry is used for the determination of compositional analysis of ___ |
| 1793 | Find the Laplace transform of the following input function ___ |
| 1794 | Which of the following is not suitable for measuring the temperature of a red hot object in the range of 800-1600°C ___ |
| 1795 | Which of the following instruments is not used for measuring sub-zero (<0°) temperatures ___ |
| 1796 | Change of angle of refraction with composition comprises the working principle of a ___ |
| 1797 | Platinum resistance thermometer can be used upto antimony point which is ___ °C, and is the temperature of equilibrium between solid antimony & liquid antimony at normal atmospheric pressure |
| 1798 | Which of the following thermocouples is capable of measuring a temperature of -50°C ___ |
| 1799 | Meleoid gauge measures the ___ pressure |
| 1800 | The Laplace transform of exp(at), where a > 0, is defined only for the Laplace parameter, s > a since ___ |
| 1801 | A stable system is the one ___ |
| 1802 | Which of the following shows maximum dip effect (indicating reverse direction of temperature change) ___ |
| 1803 | Which of the following is never used as an element of industrial resistance thermometer ___ |
| 1804 | Temperature measurement range of iron-constantan thermocouple is 0 to 870°C ___ |
| 1805 | Cascade control means ___ |
| 1806 | Liquid column manometers are used for measuring the pressure ___ |
| 1807 | Which of the following filled system expansion thermometers has the lowest positive temperature measurement capability ___ |
| 1808 | The unit of ‘time constant’ of a system is the same as that of ___ |
| 1809 | Liquid flow rate in an open channel can not be measured by a/an ___ |
| 1810 | The pressure sensing element of elastic type pressure gauge is never made in the form of a ___ |
| 1811 | Thermisters which have a very high temperature co-efficient of resistivity belong to the class of solid called ___ |
| 1812 | Compositional analysis of flue gas coming out of a furnace in respect of ___ |
| 1813 | Flow rate measurement of hostile acids and alkalis can be most suitably done by a/an ___ |
| 1814 | Phase margin is equal to ___ |
| 1815 | Maximum differential pressure in liquid manometer is ___ psi |
| 1816 | Which of the following is not classified as a thermo electric pyrometer ___ |
| 1817 | ___ is an example of distributed parameter system |
| 1818 | Sub-zero temperature (< 0°C) can be measured by a constant volume gas thermometer employing ___ |
| 1819 | With increase in temperature, the electrical conductivity of the platinum used in the resistance thermometer ___ |
| 1820 | Which of the following is not a variable area flow meter ___ |
| 1821 | A non-linear system will have ___ steady state values |
| 1822 | Silver point temperature is ___ °C |
| 1823 | Nickel percentage in invar which is an iron-nickel alloy, and is used as a thermocouple material is ___ |
| 1824 | When the damping co-efficient (ξ) is unity, the system is ___ |
| 1825 | Bimetal strips are not used in ___ |
| 1826 | Thermocouple is suitable for measuring ___ |
| 1827 | What is the Laplace transform of impulse input having magnitude ‘X’ ___ |
| 1828 | Which of the following statement about the above control system is wrong ___ |
| 1829 | Water is flowing through a series of four tanks and getting heated as ___ |
| 1830 | The term analogous to voltage in a single tank system is the ___ |
| 1831 | In a shell and tube heat exchanger, the outlet temperature of heating/cooling fluid is the ___ variable |
| 1832 | Mcleoid gauge is used to measure the ___ |
| 1833 | Pick out the symbol for “locally mounted instrument” in instrumentation diagram ___ |
| 1834 | “An emf of the order of mV is generated when two solutions of different hydrogen ion concentration are separated by a thin glass wall” ___ |
| 1835 | Bourdon tube is never made of ___ |
| 1836 | Temperature control of an exothermic chemical reaction taking place in a CSTR is done with the help of cooling water flowing in a jacket around the reactor ___ |
| 1837 | Which of the following thermocouples has the widest temperature measurement range ___ |
| 1838 | Response of a linear control system for a change in set point is called ___ |
| 1839 | Non-metallic diaphragm used as pressure sensor in instruments is generally made of ___ |
| 1840 | Photoelectric pyrometers are suitable in the temperature range of ___ °C |
| 1841 | Pyrometry refers to the measurement of temperature ___ |
| 1842 | Routh stability method uses ___ loop transfer function |
| 1843 | Which is the most suitable instrument for measuring pressure below 3 microns ___ |
| 1844 | Out of the following themocouple wire insulating material, the highest temperature rating is for ___ |
| 1845 | Which of the following flow-metering instru-ments is an areameter ___ |
| 1846 | Thermal wells used in temperature measurements should have ___ |
| 1847 | A bimetallic thermometer as compared to industrial mercury in glass thermometer has almost the same |
| 1848 | Polarisation of light forms the working principle of a ___ |
| 1849 | Which of following error integral is considered as the best criterion in controller settings ___ |
| 1850 | In a shell and tube heat exchanger, the inlet temperature of heating/cooling fluid is the ___ variable |
| 1851 | Flow rate of sludge is not measured by a/an ___ |
| 1852 | Which of the following fluid flow measuring devices can measure the largest flow rate ___ |
| 1853 | Polarograph is meant for the analysis of ___ |
| 1854 | Operating range of a temperature measuring instrument is 800 to 1600° C ___ |
| 1855 | Characteristic equation is the denominator of ___ loop transfer function |
| 1856 | Process degree of freedom indicates ___ number of controllers to be used |
| 1857 | Suppose that the gain, time constant and dead time of a process with the following transfer function ___ |
| 1858 | ___ type of element is normally not used in the bimetallic thermometers |
| 1859 | The root locus method, a pole of a transfer function G(s) is the value of s for which G(s) approaches ___ |
| 1860 | Zirconia probe is used for the measurement of ___ |
| 1861 | Thermal conductivity cell is the primary element of a/an ___ analyser |
| 1862 | The transfer function of a pure dead time system with dead time ___ |
| 1863 | Presence of a small amount of water in the organic systems can be determined by the ___ method |
| 1864 | Thermal conductivity measurement is used for the determination of |
| 1865 | The open loop transfer function of a control system is ___ |
| 1866 | Gas analysis is commonly done using the ___ |
| 1867 | Emission spectroscopy is used for ___ |
| 1868 | Dead zone in an instrument must be less than ___ percent of the scale |
| 1869 | Phase lag of the frequency response of a second order system to a sinusoidal forcing function ___ |
| 1870 | ___ is the static characteristics of an instrument, |
| 1871 | Thermistors are used in ___ devices |
| 1872 | Flow rate through an orifice is ___ the pressure differential |
| 1873 | A pyrheliometer is an instrument used for measuring the ___ |
| 1874 | E.m.f. generated by thermocouples is of the order of ___ |
| 1875 | Liquid levels in autocalves are measured by ___ |
| 1876 | Working principle of radiation pyrometer is based on ___ |
| 1877 | The deflection in diaphragm (which is used as pressure sensor in pneumatic and electronic instruments) is dependent on the metal thickness, its diameter (d) and shape & number of corrugations ___ |
| 1878 | Stalagmometer is used for the measurement of ___ |
| 1879 | Out of the following temperature measuring instruments, the measurement accuracy will be minimum for the ___ |
| 1880 | ___ controller has the maximum stabilising time |
| 1881 | A mercury thermometer can not be used to measure the temperature below the freezing point of mercury, which is ___ °C |
| 1882 | For a feed back control system to be stable, the ___ |
| 1883 | A simple pitot tube measures the ___ |
| 1884 | Specific conductance is defined as the reciprocal of resistance in ohms of 1c.c. of liquid at a specified temperature ___ |
| 1885 | Small furnace draught is accurately measured by an inclined tube manometer, in which the manometric liquid used most commonly is ___ |
| 1886 | Which of the following is not a second order instrument ___ |
| 1887 | Working principle of bimetallic thermometers is difference in linear co-efficient of thermal expansion of two strips of different metals welded together ___ |
| 1888 | Bode stability method uses ___ loop transfer function |
| 1889 | Emf developed by a thermocouple while measuring a temperature of 400°C is 22 mV ___ |
| 1890 | Mercury manometer (U-tube type) exemplifies a ___ order system |
| 1891 | Time constant is the ___ |
| 1892 | Stabilising time for the controllers is the time required for the response to reach ___ percent of its ultimate value |
| 1893 | Stability of a control system containing a transportation lag can be best analysed by ___ |
| 1894 | Optical activity of a solution can be determined using a ___ |
| 1895 | Composition of alloys can be determined by ___ |
| 1896 | All the thermocouples used for temperature measurement use dissimilar metal ___ |
| 1897 | A pyranometer is an instrument used for measuring the ___ |
| 1898 | ___ stability method uses open loop transfer function |
| 1899 | A first order system with a time constant of 1 min is subjected to frequency response analysis ___ |
| 1900 | Mass spectrometer is used for the composition analysis of ___ |
| 1901 | Dilatometer is used to measure ___ |
| 1902 | Continuous flue gas analyser makes use of paramagnetic properties of some of its constituents, which move towards the strongest part of the magnetic field thus displacing diamagnetic gases ___ |
| 1903 | Temperature measurement by optical pyrometer is done above ___ point, which is 1063°C |
| 1904 | Radiation thermometer can not measure the temperature ___ |
| 1905 | Working principle of mercury in glass thermometer is based on the ___ of mercury with increase in temperature |
| 1906 | Emf generated in a thermocouple depends on the temperature ___ |
| 1907 | Thermal conductivity based continuous flue gas analyser makes use of varying thermal conductivity of the constituents of flue gases ___ |
| 1908 | Very low pressure is expressed in microns(μ), which is equal to ___ mm of Hg coloumn (absolute) at 0°C |
| 1909 | In an exothermic chemical reactor, the manipulated variable is the flow rate of ___ |
| 1910 | To increase the speed of response of a pressure spring liquid or gas expansion thermometer, the clearance space between the thermometer bulb and the thermal well should not be filled with ___ |
| 1911 | A system with a double pole at the origin is unstable since the corresponding term in the time domain ___ |
| 1912 | The offset introduced by proportional controller with gain ___ |
| 1913 | A bolometer is ___ |
| 1914 | An aneroid barometer measures the ____ pressure |
| 1915 | A typical example of a physical system with under damped characteristic is a ___ |
| 1916 | A photo electric device in which the resistance of the metal is directly proportional to the light striking on it, is known as photo-conductive cell ___ |
| 1917 | Which of the following is not a differential pressure flow meter ___ |
| 1918 | Vapour actuated pressure spring thermometer does not require ambient temperature compensation ___ |
| 1919 | Mercury thermometer can be used to measure the temperature upto ___ °C |
| 1920 | Which of the following thermocouples is the most suitable for measuring a temperature of about 1600°C in an oxidizing atmosphere ___ |
| 1921 | Bode diagram are generated from output response of the system subjected to which of the following input ___ |
| 1922 | Helium gas constant volume thermometer is suitable for the measurement of a temperature of ___ °C |
| 1923 | What is the normal percentage of rhodium in platinum + rhodium element used in the thermocouple ___ |
| 1924 | When a bare thermocouple is covered by a protective sheath, the response becomes ___ |
| 1925 | The model that describes the dynamic variation of temperature of water in the tank with time is given as ___ |
| 1926 | Routh test ___ |
| 1927 | pH meter has ___ |
| 1928 | A constant volume gas thermometer employing ___ is used to measure sub-zero (i.e., < 0° C) temperature |
| 1929 | Which of the following does not figure in the list of seven substances selected for international temperature scale ___ |
| 1930 | The time constant of a unity gain, first order plus time delay process is 5 min ___ |
| 1931 | The experimental response of the controlled variable y(t) for a step change of magnitude P in the manipulated variable x(t) is shown below ___ |
| 1932 | The unit step response of the ___ |
| 1933 | High temperature of around 2000°C of incandescent gas mantles is measured by a/an ___ |
| 1934 | Pressure of 0.01 psi (absolute) can be measured by ___ gauge |
| 1935 | Which of the following controllers has maximum offset ___ |
| 1936 | Magnetic flowmeters are generally not used for the velocity/flow measurement of hydrocarbons due to their ___ |
| 1937 | On-off controllers are normally used for ___ |
| 1938 | Which of the following judges the accuracy of an instrument ___ |
| 1939 | ___ are analysed using a polarograph |
| 1940 | Which of the following is not a mechanical pressure sensing element ___ |
| 1941 | Liquid discharge from a tank or reservoir can not be measured by ___ |
| 1942 | Turbine flow meters are suitable for ___ |
| 1943 | Use of I-control along with P-control facilitates ___ |
| 1944 | For the block diagram shown below the characteristic equation is ___ |
| 1945 | Measurement of sub-zero Celcius temperature in industry is done most commonly by ___ |
| 1946 | Which of the following is not a speed measuring instrument ___ |
| 1947 | Which of the following is a ‘contact’ pyrometer ___ |
| 1948 | The amplitude ratio for the sinusoidal response of ___ is < 1 |
| 1949 | The frequency response of a dynamic element shows a constant magnitude ratio at all frequencies ___ |
| 1950 | The response of two tanks of same size and resistance in series is ___ |
| 1951 | The amplitude ratio for the sinusoidal response of a ___ is 1 |
| 1952 | Positioning controllers are used for ___ |
| 1953 | A mercury barometer measures the ___ pressure |
| 1954 | The calibration data of a thermocouple with its cold junction at 0°C are ___ |
| 1955 | Which of the systems having the following transfer function is stable ___ |
| 1956 | Psychrometer determines the ___ |
| 1957 | Continuous measurement of moisture in paper is done by ___ |
| 1958 | Reset rate is the another term used for ___ time |
| 1959 | The term analogous to the electrical current in a thermal system is the ___ |
| 1960 | A process is initially at steady state with its output y=l for an input u=l ___ |
| 1961 | The unit step response of the transfer function ___ |
| 1962 | What is the ratio of output amplitude to input amplitude for a sinusoidal forcing function in a first order system ___ |
| 1963 | A Geiger-Mueller detector with a “pancake” probe is being used to monitor workers leaving a radiologically controlled area for contamination. The probe is sensitive to alpha, beta, and ___ |
| 1964 | A Geiger-Mueller detector with a “pancake” probe is being used to monitor workers leaving a radiologically controlled area for contamination ___ |
| 1965 | A nuclear plant worker normally wears a thermoluminescent dosimeter (TLD) or similar device for measuring whole body radiation exposure ___ |
| 1966 | A Geiger-Mueller detector with a “pancake” probe (often called a frisker) is being used to monitor workers leaving a radiologically controlled area for contamination ___ |
| 1967 | A nuclear plant worker normally wears a thermoluminescent dosimeter (TLD) or similar device for measuring radiation exposure ___ |
| 1968 | Which one of the following describes a characteristic of a self-reading pocket dosimeter ___ |
| 1969 | Which one of the following describes a characteristic of a self-reading pocket dosimeter (SRPD) ___ |
| 1970 | A typical gamma ray (1 to 2 MeV) normally produces a free electron in a gas-filled radiation detector by ___ |
| 1971 | Radiation interacting with a gas-filled radiation detector produces primary ion pairs ___ |
| 1972 | A fission chamber detector is initially operating in the proportional region to measure neutron flux in the source range ___ |
| 1973 | #VALUE! |
| 1974 | A gas-filled radiation detector that operates in the Geiger-Mueller region of the gas ionization curve is being used in a constant radiation field ___ |
| 1975 | #VALUE! |
| 1976 | A Geiger-Mueller detector with a A pancake@ probe (often called a frisker) is being used to monitor personnel leaving a radiologically controlled area ___ |
| 1977 | Which one of the following personal radiation monitoring devices can be charged with DC voltage to “zero†the device prior to use ___ |
| 1978 | In which usable region(s) of the gas-filled detector ionization curve is the pulse height resulting from the detection of a 1 MeV beta particle the same as a 5 MeV alpha particle ___ |
| 1979 | Which one of the following describes the positive space charge effect associated with a gas-filled radiation detector ___ |
| 1980 | A fission chamber neutron detector is located in a constant neutron radiation field and is initially operating in the proportional region ___ |
| 1981 | Which one of the following types of radiation detectors is typically the least accurate in determining the dose rate to a human body from an unspecified source of radiation ___ |
| 1982 | #VALUE! |
| 1983 | #VALUE! |
| 1984 | A beta particle and an alpha particle with equal kinetic energies cause ionization in a gas-filled radiation detector ___ |
| 1985 | Which one of the following contains the pair of radiation detector types that are the most sensitive to low-energy beta and/or gamma radiation ___ |
| 1986 | Quench gases are added to gas-filled radiation detectors that operate in the ___ region; the quench gases prevent a single ionization event from causing ___ in the detector gas volume |
| 1987 | A nuclear power plant has been shut down for one month ___ |
| 1988 | A beta particle and an alpha particle enter and cause ionization in a gas-filled radiation detector operating in the Geiger-Mueller region ___ |
| 1989 | A beta particle and an alpha particle enter and cause ionization in a gas-filled radiation detector operating in the Geiger-Mueller region |
| 1990 | A gas-filled radiation detector operating in the ion chamber region is exposed to a constant gamma radiation field ___ |
| 1991 | Which one of the following lists the two types of gas-filled radiation detectors whose outputs will be least affected by a small variation (±10 volts) in the voltage applied to the detectors ___ |
| 1992 | Which one of the following describes the reason for the high sensitivity of a gas-filled radiation detector operating in the Geiger-Mueller region ___ |
| 1993 | Which one of the following describes a characteristic of a Geiger-Mueller radiation detector ___ |
| 1994 | Which one of the following types of radiation is the major contributor to the dose indication on a self-reading pocket dosimeter (SRPD) ___ |
| 1995 | Which one of the following statements describes the operation of a gas-filled radiation detector operating in the proportional region ___ |
| 1996 | Scintillation detectors convert radiation energy into light by a process known as ___ |
| 1997 | Two identical fission chamber neutron detectors, operating in the proportional region, are being used to monitor core neutron flux during a reactor startup ___ |
| 1998 | Two identical fission chamber neutron detectors (operating in the proportional region) are being used to monitor the neutron flux during a reactor startup ___ |
| 1999 | Which one of the following will cause an upscale failure of a fission chamber neutron detector that is operating in the ion chamber region as a local power range monitor (LPRM) ___ |
| 2000 | A fission chamber neutron monitoring instrument is operating in the proportional region ___ |
| 2001 | A proportional detector with pulse height discrimination circuitry is being used in a constant field of neutron and gamma radiation to provide source range neutron count rate indication ___ |
| 2002 | A gas-filled radiation detector operating in the proportional region is exposed to a constant gamma radiation field. If the applied voltage is decreased but maintained within the ___ |
| 2003 | What is the effect on a gas-filled neutron detector operating in the proportional region if the detector voltage is increased such that the detector operates closer to the high end of the proportional region ___ |
| 2004 | A gas-filled radiation detector operating in the proportional region is exposed to a constant gamma radiation field ___ |
| 2005 | A fission chamber neutron monitoring instrument is operating in the proportional region of the gas ionization curve ___ |
| 2006 | A fission chamber used for reactor neutron monitoring is operating in the ionization region of the gas ionization curve ___ |
| 2007 | A loss-of-coolant accident resulted in a reactor scram. The source range monitors (SRMs) were fully inserted and are currently located in a voided section of the core ___ |
| 2008 | Following a loss-of-coolant accident, a reactor scram resulted ___ |
| 2009 | Due to a loss-of-coolant accident, a reactor scram resulted ___ |
| 2010 | What is the function of the positive electrode in an ion chamber ___ |
| 2011 | Gamma radiation contributes to the output of a fission chamber mainly by interacting with the ___ |
| 2012 | Proportional band or throttling range is the ____ |
| 2013 | A pressure sensor converts pressure changes into ___ |
| 2014 | Setpoint deviation is also called ___ |
| 2015 | An electronic controller is ___ |
| 2016 | A direct acting controller ___ |
| 2017 | Resistance temperature devices can provide a relatively linear resistance variation from ___ |
| 2018 | Authority or Compensation Authority is the ___ |
| 2019 | An advantage of an electronic control system is that ___ |
| 2020 | An electronic control system is comprised of a ___ |
| 2021 | The electrical resistance of a thermistor will ___ |
