Reading: 100 PLC Quiz Questions : True or False
Inst Tools > Blog > PLC Tutorials > 100 PLC Quiz Questions : True or False
Last updated: March 4, 2021 4:04 pm
3 Comments
2 Min Read
Instrumentation Tools assists you a complete guide which mainly targets the aspirants of Electrical, Electronics and Instrumentation engineering Streams to crack the competition exams and prepare for the top MNC companies written tests.
100 PLC Quiz Questions : True or FalseClick on below button to launch the PLC Quiz.
Here’s a definitive list of 100 PLC Quiz Questions : True or False that will guarantee a sail-through to the next level as the questions been prepared in a strategic manner.
In case you have attended any competitive exams or interviews recently, or have additional questions beyond what we covered, we encourage you to post them in our Instrumentation Forum to discuss about it further.
100 PLC Quiz Questions : True or False, Programmable Logic Controller Objective Questions, Programmable Logic Controller Tests, PLC Quiz, PLC MCQ, PLC Test.
We prepared the multiple choice questions on PLC Quiz Questions : True or False. This quiz section consists of total 100 questions. Each question carries 1 point. No negative points for wrong answers. You need to score at-least 50% to pass the quiz i.e. 50 Points. You can get the Quiz Answers after submitting all quiz questions.
All the Best.
Instrumentation Quiz
Share your feedback on the PLC quiz using comments section.
PLC Math instructions
History of PLC
PLC Interview Questions
PLC Digital Input and Digital Output Modules
How Weigh Feeder Works ?
PLC Packing Machine Control System Program in XG5000
3 Comments
  • Mack Kelly says:
    September 18, 2019 at 11:09 am
    this quiz questions are so helpful.
  • yesera Getahun says:
    February 4, 2021 at 6:17 pm
    it is good for elctrcal engineering
  • Lucky Trexler says:
    February 23, 2021 at 7:14 pm
    the 2 volatile memory questions are wrong. Volatile memory WILL lose its contents if power is lost and ram is a volatile memory not non-volatile; that is rom.
How to Read an Electrical Wiring Diagram?
Factory Acceptance Test (FAT) of a PLC Panel
Job Skills Required for Industrial Electrical Maintenance
Difference between Timer and Counter – PLC Basics
PLC Question Bank
Rules for Writing SCL Language in Tia Portal
Evaluating Industrial Automation Projects Return on investment (ROI)
PLC Program Example on Multiple LEDs using Set Coil
PLC program for Sorting System by Size Example
PLC Based Product Sorting Machine System – Lift Control
Omron PLC Mixing System
Mixing Program with Timers and Counters in Omron PLC
Scan cycle of a Siemens PLC
OB1 – Main Cyclic Organization Block in TIA Portal
PLC Tag Naming Conventions
PLC FBD Programming for Burglar Alarm Security System
DCS Vs PLC
DCS versus PLC Architecture
Lightning Arrester Bursts Problem
Frequent Feeder-A Lightning Arrester (LA) Bursts – Root Cause Analysis
Vendor Selection in Procurement Service Cycle (For Industrial Projects)
Compliance Table Application (for Procurement Service Cycle)
Instrumentation Engineer’s Calibration Mistakes
FIFO and LIFO Sequences in PLC
What are FIFO and LIFO Sequences in PLC?
Gate Valve
How Gate Valves Work ?
PLC Program Example - Signal Lamp Task
PLC Program Examples
Power Systems MCQ Series 17
Applications of Power Electronics MCQ
