Reading: Z-transform Analysis of Sampled-Data Control Systems
Inst Tools > Blog > Multiple Choice Questions > Z-transform Analysis of Sampled-Data Control Systems
1. The DFT of a signal x(n) of length N is X(k). When X(k) is given and x(n) is computed from it, the length of x(n)
a) Is increased to infinity
b) Remains N
c) Becomes 2N – 1
d) Becomes N2
Answer: a
Explanation: When X (k) is given and x (n) is computed from it, the length of x (n) is increased to infinity.
2. The system having input x (n) related to output y(n) as y (n) = log |x (n)| is:
a) Nonlinear, causal, stable
b) Linear, noncausal, stable
c) Nonlinear, causal, not stable
d) Linear, noncausal, not stable
Answer: a
Explanation: As y (n) is the function of x (n) hence it is nonlinear but it is bounded and also depends upon past and present values therefore it is stable and causal respectively.
3. Zero-order hold used in practical reconstruction of continuous-time signals is mathematically represented as a weighted-sum of rectangular pulses shifted by:
a) Any multiples of the sampling interval
b) Integer multiples of the sampling interval
c) One sampling interval
d) 1 second intervals
Answer: b
Explanation: Zero-order hold is used to reconstruct the continuous-time signal which is represented as a weighted sum of rectangular pulses shifted by integer multiples of the sampling interval.
4. When two honest coins are simultaneously tossed, the probability of two heads on any given trial is:
a) 1
b) 3/4
c) 1/2
d) ¼
Answer: d
Explanation: Total outcomes =4
Favorable outcomes =1
Hence probability =1/4.
5. A continuous-time periodic signal x(t), having a period T, is convolved with itself. The resulting signal is
a) Not periodic
b) Periodic having a period T
c) Periodic having a period 2T
d) Periodic having a period T/2
Answer: b
Explanation: Periodic having a period T Convolution of a periodic signal (period T) with itself will give the same period T.
6. If the Fourier series coefficients of a signal are periodic then the signal must be
a) Continuous-time, periodic
b) Discrete-time, periodic
c) Continuous-time, non-periodic
d) Discrete-time, non-periodic
Answer: b
Explanation: Discrete-time, periodic these are the properties of the discrete-time periodic signal.
7. The region of convergence of a causal finite duration discrete-time signal is
a) The entire z-plane except z = 0
b) The entire z-plane except z = ∞
c) The entire z-plane
d) A strip in z-plane enclosing jω–axis
Answer: a
Explanation: For discrete time signal for any causal system the region of convergence is always entire z-plane but except z =0.
8. The probability cumulative distribution function must be monotone and
a) Increasing
b) Decreasing
c) Non-increasing
d) Non-decreasing
Answer: d
Explanation: The cumulative distribution function that is monotone and non-decreasing or can be increasing.
9. Convolution is used to find:
a) The impulse response of an LTI System
b) Frequency response of a System
c) The time response of a LTI system
d) The phase response of a LTI system
Answer: c
Explanation: Convolution is the combination of addition and multiplication of the signals and used to find the impulse response of the LTI system.
10. The Fourier Transform of a rectangular pulse is
a) Another rectangular pulse
b) Triangular pulse
c) Sinc function
d) Impulse
Answer: c
Explanation: The Fourier Transform of a rectangular pulse that is the sinc function.
Fuzzy Logic Control
Carbon Monoxide Questions & Answers
DC Circuits Multiple Choice Questions
Cascade Compensation in Frequency Domain
Frequency Response MCQ
Assessment of Relative Stability Using Nyquist Criterion
Chromatographic Behaviour of Solutes Questions & Answers
Mathematical Preliminaries
Control Loop Multiple Choice Questions
Instrumentation of Ion Spectroscopy
Feedback Control Loop Questions & Answers
Diagonalization
Time Response Analysis
State Variable Analysis – Part I
Digital Control Systems
Signal Reconstruction
Stepper Motor Parts
Stepper Motor MCQ
State Variable Analysis – Part II
Control Valves Multiple Choice Questions
Split-Range, Auto-Selector Ratio, And Cascade Systems
Split-Range, Auto-Selector, Ratio & Cascade Systems
Electric Motor Actuator Parts
Lime Slaker
Advancements in Lime Slaking Technology: What’s New And What’s Next
Troubleshooting Magnetic Flow Meters Common Problems
What is calibration?
How to do Force in GE PLC Proficy Machine Edition?
PID Controllers Multiple Choice Questions
PID Controller Multiple Choice Questions
flow-meter-accuracy-calculation
Impact of Flow Meter Accuracy
Circular Chart Recorder
How to Read Circular Chart Recorder for Flow Measurement?
