Reading: Unbonded Strain Gauge Principle
Inst Tools > Blog > Pressure Measurement > Unbonded Strain Gauge Principle
Last updated: April 1, 2018 4:31 pm
2 Min Read
These strain gauges are not directly bonded onto the surface of the structure under study. Hence they are termed as unbounded strain gauges.
Description of the Unbonded Strain gauges:
The arrangement of an unbonded strain gauges consists of the following. Two frames P and Q carrying rigidly fixed insulated pins as shown in diagram. these two frames can move relative with respect to each other and they are held together by a spring loaded mechanism. A fine wire resistance strain gauge is stretched around the insulated pins. The strain gauge is connected to a wheat stone bridge.
Operation of Unbonded strain gauges:
When a force is applied on the structure under study (frames P & Q), frames P moves relative to frame Q, and due to this strain gauge will change in length and cross section. That is, the strain gauge is strained.
This strain changes the resistance of the strain gauge and this change in resistance of the strain gauge is measured using a wheat stone bridge. This change in resistance when calibrated becomes a measure of the applied force and change in dimensions of the structure under study.
Application of Unbonded strain gauge:
Unbonded strain gauge is usedin places where the gauge is to be detached and used again and again.
unbonded strain gauges are used in force, pressure and acceleration measurement.
Advantages of Unbonded strain gauge:
  • The range of this gauge is +/- 0.15% strain.
  • This gauge has a very high accuracy.
Limitation of unbonded strain gauges
It occupies more space.
Pressure and Temperature Gauges
Pressure Detection Circuit
Pressure Gauge Problems
Bellows Pressure Sensors Working Principle Animation
DeadWeight Tester Questions
Inclined-limb Manometer Principle
Double Block and Bleed Valves Opening or Closing Sequence
Pressure Transmitter Circuit
Metal Foil Strain Gauge Principle
Pressure Gauges with Bourdon Tube Principle
How to Prepare Pressure Gauge Datasheet ?
What is Hammer Effect in Gauges ?
Differential Pressure Gauge Principle
Piston Type Differential Pressure Gauge Principle
Differential Pressure Flow Transmitter Interview Questions
Functions of Pressure Detectors
Pressure Sensor Specifications
Pressure Sensor Temperature Effects
Temperature Compensation for Pressure Measurement
Three Valve Manifold
3 Valve Manifold Operation
How to Connect HART Communicator with DP Transmitter
15 HART Communicator Questions
Carbon Monoxide Questions & Answers
Meters used in Troubleshooting Electrical Equipment
Allen-Bradley MicroLogix 1000 PLC
Questions on Allen-Bradley MicroLogix 1000 PLC
hipps
What is High Integrity Pressure Protection System?
Marking Polarity
What is an RTU - Remote Terminal Unit
What is an RTU? – Remote Terminal Unit
Stability in Frequency Domain
Mathematical Preliminaries
Self Actuated Pressure Control Valve Functional Testing
