Reading: U-tube Manometer with equal & unequal limb types
Inst Tools > Blog > Pressure Measurement > U-tube Manometer with equal & unequal limb types
Last updated: June 4, 2019 10:31 am
3 Min Read
This is the most simple and precise device used for the measurement of pressure.
It consists of a transparent tube constructed in the form of an elongated ‘U’, and partially filled with the manometeric fluid such as mercury. The purpose of using mercury as the manometeric fluid is that their specific gravity at various temperatures are known exactly and they dont stick to the tube. The two common types of manometers are the equal limb type and unequal limb type.
Operation of Manometer :
To measure the pressure of a fluid which is less dense and immersible with the manometeric fluid, it is applied to the top of one of the limbs of the manometer while a reference fluid pressure (generally atmospheric ) is applied to the other limb.
Let : P1 = unknown pressure with specific weight w1.
And : P2 = reference pressure with specific weight w2.
And : wm = specfic weight of the manometeric fluid.
The difference between the pressure on the two limbs of the manometer is a function of ‘h’, the difference between the levels of the manometeric fluid in the two limbs. ‘h’, can be read directly by placing a scale near the manometer.
For Equal Limb type:
U-tube Manometer Equal Limb Type
 The pressure balance equation is
P1 + gh * w1 = P2 + gh * wm
therefore, differential pressure
P = P1 – p2 = gh(wm – w1)
For unequal Limb type
U-tube Manometer unEqual Limb Type
The pressure balance equation is : (section-XX)
P1+w1(h1+h2+h) = P2 + w2h2 + wmh
Therefore, differential pressure:
P = P1 – P2 = w2h2 + wm * h – w1(h1 + h2 + h)
= wm*h [ 1 + (w2/wm * h2/h) – w1/wm ( h1+h2/h + 1) ]
= wmh * Cn
where; Cn = [ 1 + ( w2/wm – h2/h) – w1/wm ( h1+h2/h + 1)]
Cn is known as hydraulic correction factor.
Applications of Manometer
  • they are used to sense differential pressure in venturi meter and other flow meters.
  • They are used as level devices to sense liquid heads.
  • There are used as primary standard for pressure measurements.
Advantages of Manometer
  • They are simple is construction.
  • They give accurate results.
  • Wide range of manometeric fluids ar available such as mercury, water, aniline, tetrabromethane, bromoform and carbon tetrachloride.
Disadvantages of Manometer
  • They might break during transport.
  • Certain manometeric fluids cause hazards when exposed to atmosphere.
  • Error is introduced if the diameter of the tube is less.
  • Leveling is required.
All About Instrumentation Impulse Lines
Effects of Symmetric and Asymmetric Capillary Tube Pressure Measurement
Pressure Transmitters Purged impulse lines
Pressure Gauge Pulsation Damping
Strain Gauge Working Principle
Pressure Gauges : Common Causes for Failures and Their Effective Solutions
What is LVDT ?
Impulse Piping standards for Field instruments
Bellows, Diaphragms and Bourdon Tubes
Pressure Gauge Selection
Diaphragms
Foundation Fieldbus Pressure Transmitter Configuration
Difference between Axial and Radial Diaphragm Seal Connection?
Pressure Gauge Datasheet Preparation
How to Prepare Pressure Gauge Datasheet ?
Gauge Display Scale
How to Read Gauge Analog Scales
Pressure Gauge Accessories
Bellow Principle
Bellows
Absolute and Gauge Pressure
Difference Between Absolute and Gauge Pressure
Diaphragm Seal Transmitters Errors
Pressure Transmitters Filled impulse lines
DP Transmitter Block and Bleed Valve
DP Transmitter Block and Bleed Valves
Measurements & Instrumentation Quiz – Set 10
caliper metrology tool
An Overview of Metrology Tools for CNC Machining
Semiconductor Fuse
What is a Semiconductor Fuse?
Start the Counting from a Preset Value in PLC
magnetic-level-gauge-principle
Magnetic Level Gauge Working Principle Animation
Best Practices of PLC Wiring
Best Practices of PLC Wiring – Programmable Logic Controller
Multiple Position Calibration of Temperature Chamber (Mapping)
What is FAT and SAT?
