Reading: Why rating of Synchronous Generators and Alternators in MVA or KVA
Inst Tools > Blog > Electrical Machines > Why rating of Synchronous Generators and Alternators in MVA or KVA
Last updated: April 25, 2016 2:58 pm
Electrical Machines
2 Min Read
Normally the rating of synchronous generators or alternators will be in KVA or MVA instead of kW rating.
Electrical apparatus or machines are usually rated the load which it can carry without overheating and damaging to insulation. i.e, rating of the electrical machines are governed by the temperature rise caused by the internal loss of the machine. The copper loss in the armature depends on the strength of the armature current and core loss depends on voltage and these losses are independent of the power factor.
The reason for which the transformers and synchronous generators are rated in volt-amperes instead of watts is that manufacturer does not know at what power factor does these equipments are going to operate. On the other hand while manufacturing the motors manufacturer specifies the power factor at which the motor should be operate. This is the reason why the motor loads (including synchronous motors are rated in kw) are rated in wattage power.
In the case of alternator and transformers manufacturer does not know the operating power factor. Hence they are rated in KVA or MVA
Consider a generator whose output power is 1000kVA, for different power factors 0.2, 0.5 and 0.8 and unity respectively the output power in kW will be 200, 500, 800 and 1000kW.
Losses of Transformer
Difference Between Squirrel Cage and Slip Ring Motors
Advantages and Applications of zigzag transformer
Synchronous Motor Is Not Self Starting?
What happen When Synchronous Generator loss Excitation
Induction Motors Faults and Protection
Stepper Motor Basics, Types, Modes, Wiring, Questions
DC Motor Speed Control
Difference between Induction motor and Synchronous motor
100+ Questions and Answers on Motors and Generators
What is a Transformer Tap Changer
Why Starting Current of Induction Motor is High
Metering Pumps
Difference between Permanent Magnet BLDC and DC Motor
Types of Transfomer Cooling Methods
Importance of Hysteresis Loop
Applications of Synchronous Motors
Synchronous Motor Working Principle
Why Armature is placed on Stator for Synchronous machines
Transformer Open and Short Circuit Tests
What is a transformer tap changer?
6.6kV HV Induction motor Protection
Rupture Disc
Rupture Discs bursts caused too many Urea Plant Shutdowns
Digital Circuits Questions & Answers
refrigeration compressors
Why is CO2 the Most Promising Refrigerant in Cooling Industry?
Interview Questions and Answers
Circuit Protection Devices Questions
Circuit Protection Devices Objective Questions and Answers
Feedback control loop - 2
Feedback Control Principle
Derivative Controller Response
Derivative Controller Principle
