Reading: Pressure Transmitter Troubleshooting Tips
Inst Tools > Blog > Pressure Measurement > Pressure Transmitter Troubleshooting Tips
Last updated: December 7, 2018 9:13 am
2 Min Read
The below list provides the list of general pressure transmitter problems and their possible corrective actions.
Transmitter milliamp reading is zero
  • Verify power is applied to signal terminals
  • Check power wires for reversed polarity
  • Verify terminal voltage is 10.5 to 42.4 Vdc
  • Check for open diode across test terminal
Transmitter Not Communicating with Field Communicator
  • Verify the output is between 4 and 20 mA or saturation levels
  • Verify clean DC Power to transmitter (Max AC noise 0.2 volts peak to peak)
  • Check loop resistance, 250 ohms minimum (Power supply voltage -transmitter voltage/loop current)
  • Have Field Communicator poll for all addresses
Transmitter milliamp reading is low or high
  • Verify applied pressure
  • Verify 4 and 20 mA range points
  • Verify output is not in alarm condition (Alarm option available in some transmitters)
  • Verify if 4 – 20 mA output trim is required
Transmitter will not respond to changes in applied pressure
  • Check test equipment
  • Check impulse piping or manifold for blockage
  • Verify the transmitter is not in multidrop mode
  • Verify applied pressure is between the 4 and 20 mA set points
  • Verify transmitter is not in Loop Test mode
Digital Pressure Variable reading is low or high
  • Check test equipment (verify accuracy)
  • Check impulse piping for blockage or low fill in wet leg
  • Verify transmitter is calibrated properly
  • Verify pressure calculations for application
Digital Pressure Variable reading is erratic
  • Check application for faulty equipment in pressure line
  • Verify transmitter is not reacting directly to equipment turning on/off
  • Verify damping is set properly for application
Milliamp reading is erratic
  • Verify power source to transmitter has adequate voltage and current
  • Check for external electrical interference
  • Verify transmitter is properly grounded
  • Verify shield for twisted pair is only grounded at one end
Reference : Rosemount
Impulse Piping standards for Field instruments
Differential Pressure Transmitter with 5 Way Manifold Valve
Pressure Gauge Cocks
Effects of Symmetric and Asymmetric Capillary Tube Pressure Measurement
PLC Raw Count Calculation for Pressure Transmitter
Resistance Type Pressure Transducers Principle
  • Abdel-rahman says:
    March 20, 2017 at 3:22 pm
    very good tips.
How Capacitive Pressure Sensor Works ?
Problem on Water Filter Discharge Pressure Transmitter and Gauge
Inductance Type Pressure Transducers Principle
Pressure Gauges with Capsule Sensor Principle
Bellows
Diaphragm Pressure Sensors
Piston Type Differential Pressure Gauge Principle
Sealed Bellows Temperature Sensors
Bellows Pressure Sensors Working Principle Animation
differential-pressure-transmitter-calibration-procedure
Differential Pressure Transmitter Calibration Procedure
gauge’s bourdon tube
Pressure Gauges : Remote and Chemical Seals
What are Pressure Sensing Lines
What are Pressure Sensing Lines? – Causes of Errors in Measurement
Direct Mounting of Diaphragm Seals Level Transmitter
What are the Mounting Techniques of Diaphragm Seals?
Advantages of Pneumatic Systems in the Automotive Industry
Fine wire strain gauge
Fine Wire Strain Gauge Principle
Load Cell Design
Load Cell Design
catalytic-gas-detectors-principle
Catalytic Gas Detectors Principle
What is a Non-Linear Device
What is a Non-Linear Device? Example – Advantages
Omron PLC Instructions - Move, Move Bit, Move Digit
Move, Move Bit, Move Digit – Examples of Omron PLC Programs
Stability in Frequency Domain
Preliminary Considerations of Classical Design
types of maintenance programs
Snubber Circuits
Thyristor Protection Circuits (SCR) – Types, Principle, Explanation
How to Get a PLC Programming Job With No Experience
