Reading: #19 PLC Best Practices – Monitor PLC Memory Usage
Inst Tools > Blog > PLC Tutorials > #19 PLC Best Practices – Monitor PLC Memory Usage
Measure and provide a baseline for memory usage for every PLC controller deployed in the production environment and trend it on the HMI.
Last updated: September 23, 2021 11:38 am
2 Min Read
Monitor PLC Memory UsageExample
Security ObjectiveTarget Group
MonitoringIntegration / Maintenance Service Provider Asset Owner
Since the increase of lines of code in the logic can also lead to increased memory consumption at runtime, it is recommended for PLC programmers to track any deviation from the baseline and dedicate an alarm class to this event.
Example
In Rockwell Allen Bradley PLCs, a baseline can be established on a controller and memory usage can be tracked using the RSLogix 5000 Task Monitor Tool.
Not only the main memory but also the I/O memory and Ladder/Tag memory can be tracked using trends.
Why?
Beneficial for…?Why?
SecurityIncreased memory usage can be an indicator of the PLC running altered code.
ReliabilityTracking memory usage for the running programs could be useful in avoiding total memory consumption and eventual fault state for the PLC controller.
  MaintenanceTracking memory usage could be used in tuning and finding the best scan time for the monitored controller but also in troubleshooting problems and issues related to faulty states.
References
Standard/frameworkMapping
MITRE ATT&CK ICSTactic:  TA002 – Execution
Technique:  T0873 – Project File Infection
ISA 62443-3-3SR 3.4: Software and information integrity
ISA 62443-4-2EDR 3.2: Protection from malicious code
Source: PLC Security
PLC Ladder Logic Simulator Mobile Apps For Android
Safety PLC Coding Practices – Programming Recommendations
Timers in PLC Programming – Siemens Tia Portal Tutorials
Boolean Logic to PLC Programming
Web-based SCADA HMI Software
Difference between DCS, PLC, and RTU ?
PLC Counters Program
What is Fail-safe in Siemens PLC?
Water Fountain Control Logic – PLC Exercises and Solutions
#18 PLC Best Practices – Store PLC Hard Stop Events from Faults
Learn PLC in Hindi
PID with Practical Example
Omron PLC Car Parking Program
High-Speed and Fast Counters in PLC
What are High-Speed Counters and Fast Counters in PLC?
PLC Control Panel
Inside the PLC Control Panel: How Much Do You Know?
Create an Application in HMI using Tia Portal
How to Use the Shift and Rotate Instructions in PLC
How to Use the Shift and Rotate Instructions in PLC?
Siemens PLC Project Automatic Parking with Vehicle Counter
Siemens PLC Project: Automatic Parking with Vehicle Counter
Simatic 300 Station Configuration
actuated-valve-schematic
Components of Shutdown Valve
Personal Protection Equipment
What is PPE? – Types – Personal Protection Equipment
toroidal conductivity probe principle
Conductivity Analyzer Common Problems and Troubleshooting Tips
Advantages & Disadvantages of Oil Circuit Breakers
Three Phase Transformers
Laws of Boolean Algebra using Ladder Logic
Sinking and Sourcing Devices Operation
Pros and Cons of Soft Starter
