Reading: Optimal Control Problems – Part 1
Inst Tools > Blog > Multiple Choice Questions > Optimal Control Problems – Part 1
1. The output of the system is considered near :
a) 1
b) 2
c) 3
d) 0
Answer: d
Explanation: Our main objective in the optimal control problem is to reduce the performance index of the system as minimize the output and make it near equal to zero.
2. A performance index written in terms of :
a) 1 variable
b) 2 variable
c) 3 variable
d) 5 variable
Answer: b
Explanation: Generally the performance index be of any variables but in standard form we consider the performance index to be in 2 variable only.
3. Matrix Q is :
a) Positive semi definite symmetric matrix
b) Positive definite non-symmetric matrix
c) Negative definite symmetric matrix
d) Negative definite non-symmetric matrix
Answer: a
Explanation: Matrix Q defines positive definite or non-definite symmetric matrix which is used in the performance index so as to give equal weightage to each element.
4. Matrix R is :
Answer: a
Explanation: Matrix R defines positive definite or non-definite symmetric matrix which is used in the performance index so as to give equal weightage to each element.
5. The major requirement of making the output of the system small in output regulator problem is :
a) The system must be controllable
b) The system must be stable
c) The system must be observable
d) The system must be LTI
Answer: c
Explanation: We are concerned with making the output of the output regulator problem small this is achieved when the system is observable.
6. Minimum principle was given by:
a) Pontryagin
b) Hamiltonian
c) Bellman
d) Jacobi
Answer: a
Explanation: The minimum principle to minimize the performance index is given by Pontryagin.
7. Dynamic programming is developed by:
a) Pontryagin
b) Hamiltonian
c) Bellman
d) Jacobi
Answer: c
Explanation: Dynamic programming for minimizing the performance index is given by Bellman.
8. The performance index is reduced by:
a) State variable constraint
b) Input constraint
c) Control function minimization
d) Control function constraint
Answer: c
Explanation: Once the performance index is calculated the next task is to find the control function which is used to minimize the performance index.
9. Minimum principle is based on :
a) Concepts of calculus of variations
b) Principle of calculus
c) Principle of invariant imbedding
d) Principle of optimality
Answer: a
Explanation: Minimum principle of Pontryagin is based on the concept of calculus of variations.
10. Dynamic programming is based on :
a) Principle of calculus
b) Principle of invariant imbedding
c) Principle of optimality
d) All of the mentioned
Answer: d
Explanation: Dynamic programming is based on principle of calculus, invariant imbedding and optimality and these are the basic laws of the nature and does not need complex mathematical development to explain its validity.
Signal Flow Graphs Objective Questions
Construction of Root Loci
Pressure Measurement Multiple Choice Questions
Parameter Optimization
Differential Equations of Physical Systems & Dynamics of Robotic Mechanisms
Paramagnetic Oxygen Analyzers Questions & Answers
Solution of State Equations
Frequency Response MCQ
Assessment of Relative Stability Using Nyquist Criterion
State Variables & Linear Discrete Time Systems
Advances in Control System
Adaptive Control
pH Meters Questions & Answers
Pneumatic Systems Objective Questions
Temperature Measurement Multiple Choice Questions
Encoder Questions
Encoder Multiple Choice Questions
Time Response Analysis
Standard Test Signals Objective Questions
X-Ray Spectroscopy Questions & Answers
Secondary Reference Electrodes Questions & Answers
Electronic Devices & Circuits Quiz – Set 16
High Voltage and Power System Stability Interview Questions
Electrical Wire Mesh
What is an Electrical Wire Mesh?
Top 1000 Analytical Instrumentation Questions & Answers
PID Controller Tuning
How to tune a PID Controller ?
Center Tapped Full Wave Rectifier Operation
Measurements & Instrumentation Quiz – Set 4
Questions on Single Loop Controller
Single Loop Controller Questions
