Reading: Logic Gates and Truth tables
Inst Tools > Blog > Common > Logic Gates and Truth tables
Last updated: November 1, 2018 8:40 pm
Common
2 Min Read
Truth tables offer a simple and easy to understand tool that can be used to determine the output of any logic gate or circuit for all input combinations.
Truth Tables
When a logic gate has only two inputs, or the logic circuit to be analyzed has only one or two gates, it is fairly easy to remember how a specific gate responds and determine the output of the gate or circuit. But as the number of inputs and/or the complexity of the circuit grows, it becomes more difficult to determine the output of the gate or circuit.
Truth tables, as illustrated in Figure 11, are tools designed to help solve this problem.
A truth table has a column for the input of each gate and column for the output of each gate. The number of rows needed is based on the number of inputs, so that every combination of input signal is listed (mathematically the number of rows is 2 , where n = number of inputs).
In truth tables, the on and off status of the n inputs and outputs is represented using 0s and 1s. As previously stated 0 = off and 1 = on. Figure 11 lists truth tables for the seven basic logic gates. Compare each gate’s truth table with its definition given earlier in this module, and verify for yourself that they are stating the same thing.
Universal Logic Gates and Truth tables
Figure 11 Truth Tables
How Technology is Shaping the Future of Education?
Why Industrial Safety Automation Matters Today?
CNC Programming – Definition, Types, and Tips
What is C Programming Language? Fundamentals, Pros & Cons
Best Online Courses to Learn Electrical Engineering
  • nelly says:
    November 4, 2023 at 6:56 pm
    very good
Test Automation in Production Environment – Everything You Should Know
Difference Between Adhesion and Cohesion
What is PPE? – Types – Personal Protection Equipment
Difference between Standards, Codes, Specifications, Regulations
What is an IP address? How to Set IP Address of the Computer?
Engineering Logic Diagrams
What is a Tactile Sensor? Principle, Advantages, and Applications
Essential Safety Tips for Glass Workers
Types of Sensors Used in Automobiles
Sample of a production Downtime
How to Use Production Line Failures for Your Gains?
CNC Machining Deep Hole Drilling
Deep Hole Drilling Ideal Methods For CNC Machining
Comparison of Absorption Chillers and Electric (Compression) Chillers
Difference between HVAC Absorption Chillers and Electric Chillers
Laser Cutting Precision and Accuracy
Benefits of Steel Laser Cutting
Jet Pump
What is a Jet Pump? – Principle, Types, Comparison
What is a Laser Sensor
What is a Laser Sensor? Principle
Robot Anatomy
Robot – Anatomy, Configuration, Reference Frame, Characteristics
Industrial Automation Mobile Apps
IoT Interview Questions and Answers
Introduction to GOC controllers
Mitsubishi Electric GOC Controllers
Diagram of Oscillator Circuit
Barkhausen Criterion
Exclusive Valve Sequencing
Exclusive Control Valve Sequence
GSD File installation in Simatic Manager
How to Install GSD File in Step 7 PLC using Simatic Manager?
Commissioning Differential Pressure Transmitter in Boiler Steam Drum
Categories of Unshielded Twisted Pair
Network Cabling
