Reading: Humidity Sensing Absorption Hydrometer Principle
Inst Tools > Blog > Analyzers > Humidity Sensing Absorption Hydrometer Principle
Last updated: April 2, 2018 4:40 am
Analyzers
2 Min Read
A change in resistance with change in humidity is taken as a measure of humidity.
This is type of Electrical Humidity sensing Absorption Hydrometer, know more about mechanical humidity sensing methods using Hair Haydrometer.
Description:
The main Parts of this arrangements are, two metal electrodes which are coated and separated by a humidity sensing hygroscopic salt (lithium chloride). The leads of the electrodes are connected to a null – balance wheat stone bridge.
Operation:
When the humidity of the atmosphere is to be measured, the electrodes coated with lithium chloride are exposed to atmosphere. Humidity variation causes the resistance of the chemical (lithium chloride) to change. That is, the chemical absorbs moisture or loss moisture and causes a change in resistance.
Higher the humidity (RH) in the atmosphere more will be the humidity absorbed by lithium chloride and lower will be the resistance.
Lesser the humidity (RH) in the atmosphere less will be the humidity absorbed by lithium chloride and higher will be the resistance.
The change in resistance using a Wheatstone bridge and this change in resistance becomes a measure of humidity (RH) present in the atmosphere.
Applications
  • These hydrometers are used under constant temperature conditions to measure humidity of atmosphere.
  • The accuracy of this instrument is in +/- 25%.
  • The response is of the order of few seconds.
Limitations
  • These instruments should not be exposed to 100% humidity as the resulting absorption by the chemical (lithium chloride) might damage the instrument.
  • If these devices are not used under constant temperature conditions, temperature correction must be made.
Luft detector Principle
How to Calibrate pH Electrode?
Technologies for Oxygen Gas Measurement
Dissolved oxygen probe calibration procedure
Conductivity Analyzer Common Problems and Troubleshooting Tips
pH Analyzer Interview Questions and Answers
Ambient Air Quality Monitoring System Principle
Electrodeless Conductivity Probes Principle
Hair Hydrometer Principle
Free chlorine Analyzer Principle
Turbidity Sensor Calibration Procedure
Basics of Chromatograph Operation
Thermal Conductivity Detector (TCD) Principle
H2S Measurement Using Lead Acetate Principle
Gas Analyzers Interview Questions
Gas Analyzers Interview Questions and Answers
Moisture Calculator
Moisture Calculator
Turbidity Analyzer Working Principle
SWAS Analyzer Questions
SWAS Analyzers Questions and Answers
online silica analyzer
Silica Analyzer Problems and Troubleshooting Tips
Dissolved Oxygen Analyzers Interview Questions
Dissolved Oxygen Analyzer Interview Questions & Answers
Humidity sensor Working Principle
Humidity Sensor Working Principle
DO Analyzer Working Principle
Dissolved Oxygen Analyzer Working Principle
How to calculate Thermocouple Temperature by measuring the output millivoltage
Level Gauge Interface Measurement
Level Gauge Interface & Temperature Problems
Mitsubishi PLC Programming Tutorials
fundamentals of an AC motor
How does an Electric Motor Operate? – AC Motor Fundamentals
Industrial Automation Protocols
Magnetostrictive Transducers Objective Questions
Advantages & Disadvantages of Variable Speed Drives
