Reading: Gas Detectors Practical Problems and Troubleshooting
Inst Tools > Blog > Fire & Gas System > Gas Detectors Practical Problems and Troubleshooting
Many times, we encounter problems with these gas detectors and face issues in troubleshooting and practical solutions for them.
Last updated: July 9, 2024 10:20 am
Fire & Gas System
Gas detectors are one of the most important safety devices used in plants. Gas detectors are of various types and available for detection of various gases like Chlorine gas, hydrogen sulphide gas, carbon monoxide gas and many other gases.
Many times, we encounter problems with these gas detectors and face issues in troubleshooting of these gas detectors.
Below mentioned steps can be followed for troubleshooting the problems in any gas detector.
  1. For gas detector not responding, check the display of the gas detector. If the display is in power off condition, then check the voltage to the gas detector. If no voltage is present, then check the fuse in marshalling cabinet. If fuse is ok, then check the barrier or the isolator’s healthiness in the marshalling cabinet. If found ok, then check the cable connections in field, junction box and in marshalling cabinet. If connections are ok, then check the healthiness of the cable. Check the resistance of the cable to know the healthiness of the cable. If the cable is found faulty, then reply the pair with a spare pair.
  2. Still if gas detector is not getting on, then check the connection in the terminal block of the gas detector. The connections in the gas detector’s terminal block can be incorrect. Use the vendor manual for confirming the connections. Most of the gas detectors are 3 wire. Hence checking connections is necessary.
  3. Check the sensor’s sintered filter. The filter might be blocked by external dust or dirt. Clean the filter with a proper tool like a brush or moisture free air. Also check the condition of the sensor. If dust or dirt is present on sensor, then clean the sensor also. Reinstall the sensor and sintered filter. Check the response with the calibration gas.
  4. If gas detector is not responding then check the connections of the sensor to the terminal block. Loose connection or incorrect connection can create such problem.
  5. If the gas detector is showing non zero reading when there is no leakage or gas present, then power reboot the gas detector.
  6. If still the gas detector is showing values, then calibration of gas detector is needed. Use appropriate gas for calibration of the gas detector.
  7. If above mentioned steps do not solve the issue, then replace the sensor. Check the removed sensor’s response with another transmitter.
  8. If replacing sensor doesn’t work then replace the transmitter. Use old sensor if the response of the sensor is ok with another transmitter.
  • Instrumentation and Control Quiz
  • Pneumatic Systems Objective Questions
  • Electrical Systems vs. Pneumatic Systems
  • Troubleshooting PLC Automation Systems
  • Troubleshooting Flow Meter Common Problems
Lower Explosive Limit (LEL)
Hydrogen Sulfide Gas (H2S)
Oxygen Safety Analyzer
Carbon Monoxide Gas Hazards
What is Bump Testing ?
Chlorine Gas Hazards
Infrared Open Path Gas Detectors Working Principle
Why LEL important in Gas Detection?
Portable Gas Detectors Calibration Procedure
What is an Explosive Limit? – Lower Explosive Limit (LEL)
Objective Questions of Building Fire and Gas Detectors
Overview of Fire/Smoke/Flame/Heat/Gas Detectors
Basics of Fire Detection and Alarm System
How to identify location of Fire Detectors
Fire-Triangle-in-Gas-Detection-System
Basics of Fire Detection System
Infrared Gas Detectors Principle
Infrared Gas Detectors Working Principle
Gases LEL and UEL
What is Lower Explosive Limit & Upper Explosive Limit ?
Gas Detection System Abbreviations
Difference Between Passive and Active Fire Protection
Active and Passive Fire Protection
Fire Extinguishers Mock Test
Smoke Detection System Questions
Interview Questions on Smoke Detection System
Static and Temp Variables in PLC
PC-Based Motion Controller
Various Types of Delta PLC used in Industrial Automation
Core-Type Transformer
Transformer Turns Ratio
Linear Variable Displacement Transducer (LVDT)
What is LVDT ?
Voting Logic in Safety Instrumented System (SIS)
Dual-beam non-dispersive analyzer
Dual-beam Non-dispersive Analyzer
Gyroscope Objective Questions
PLC Motor Control Circuit
Motor Trip Logic using PLC Programming
