Reading: Ferroresonance in Power Transformers
Inst Tools > Blog > Power Systems > Ferroresonance in Power Transformers
Last updated: September 21, 2016 10:37 am
Power Systems
1 Min Read
Ferroresonance:
Ferroresonance phenomenon can be triggered off through interaction of the system capacitance with a non-linear inductance, when transformer is at no-load. This oscillatory phenomenon or resonance phenomenon result in over-voltages which can damage the cable and the power transformer. Series ferroresonance is dangerous to power transformer
Ferroresonance can occur when:
  • The power transformer is on no-load (even an active load which can be less than one tenth of the rated power can be sufficient to prevent the phenomenon of ferroresonance to occur by absorbing the energy).
  • A large capacitance exists in line or the cable connected to at least one terminal of the transformer while the other terminals remain at normal potential
  • An unbalanced situation is created by a single phase trip out, a break in the conductor or blowing of one or two fuses
Methods to Prevent Ferroresoance:
  • Ferroresonance can be reduced by reducing the length between the transformer terminals and the section circuit-breaker or fuses
  • Avoid non simultaneous switching of power transformer
  • Earth the neutral point directly or through a resistor limiting the single phase fault current
Electrical Power System Protection Quiz
Silicon Carbide Lightning Arresters Working Principle
Advantages & Disadvantages of AC power and DC power
Voltage Variations Effects on Power Plant Equipment
Harmonics effect on Induction Motor
Advantages and Disadvantages of Per Unit System
Ungrounded or Isolated Neutral System Disadvantages
Harmonics Disadvantages in Power System
Rotor Angle Stability of Synchronous Generators in Power System
Shunt Capacitor Advantages in Power System
Harmonics effect on Transformer
Underground Cable Fault Identification Methods
why-symmetrical-components-used
Why Symmetrical Components Used for Unbalanced faults in Power System
Why Grounding
Generating Station Grounding Principles
current-limiting-reactors-and-short-circuit-currents
Current Limiting Reactors and Short Circuit Currents
Auto Recloser Circuit Breaker in Power System
Shunt Vs Series Capacitors Advantages
why-reactive-power-is-generated-at-load
Why Reactive Power is Generated at Load
neutral-grounding-practice-in-power-system
Neutral Grounding Practice in Power System
Electrification in Mining Industry
Wedge Flow Meter
Wedge Flow Meter Principle
Converter Instruction in Siemens PLC Programming
Power Supply Sizing for Industrial Automation Systems
Hardware Description Language Objective Questions
Absorption chiller
Capacity Control of Absorption Chillers
PLC Instruction List Code
Shutdown Maintenance
The 5 Phases of Conducting Shutdown Maintenance
