  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Experimentation of Transfer Function
  • PLC Tutorials
  • Control Systems
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Multiple Choice Questions > Experimentation of Transfer Function
Experimentation of Transfer Function MCQ
1. The impulse response of a LTI system is a unit step function, then the corresponding transfer function is
a) 1/s
b) 1/s2
c) 1
d) s
Answer: a
Explanation: The impulse response of a LTI system is the transfer function itself and hence for the unit step function . As input then the transfer function will be 1/s.
2. For a type one system, the steady – state error due to step input is equal to
a) Infinite
b) Zero
c) 0.25
d) 0.5
Answer: b
Explanation: The steady state error is defined as the error between the final value and the desired response and the difference in the value of both will be the steady state error due to step input for type one system is zero.
3. The equation 2s4+s3+3s2+5s+10=0 has roots in the left half of s–plane:
a) One
b) Two
c) Three
d) Four
Answer: b
Explanation: The roots of the equation can be calculated using Routh-Hurwitz criterion and hence there are 2 sign changes in the first column of the row and therefore the two roots lie on the right half of s-plane.
4. If the Nyquist plot of the loop transfer function G (s)H (s) of a closed-loop system encloses the (1, j0) point in the G (s)H (s) plane, the gain margin of the system is
a) Zero
b) Greater than zero
c) Less than zero
d) Infinity
Answer: c
Explanation: Nyquist plot deals with the open loop poles and zero and equals the encirclements to the open loop poles of the system.
5. Consider the function F (s) =5/s (s2+s+2) , where F (s) is the Laplace transform f (t). Then the final value theorem is equal to
a) 5
b) 5/2
c) Zero
d) Infinity
Answer: b
Explanation: Final value theorem is given for the stable system only and this is a type 1 system and for step input the final value can be calculated as 5/2.
6. The transfer function of a phase-lead controller is given by
a) (1+aTs)/(1+Ts) , a>1 T>0
b) (1+aTs)/(1+Ts) , a<1 T>0
c) (1-aTs)/(1+Ts) , a>1 T>0
d) (1±Ts)/(1+Ts) , a<1 T>0
Answer: a
Explanation: For the phase lead controller in which the stability and speed of response is more for the system, the magnitude of the pole must be greater than the magnitude of the zero.
7. If the system matrix of a linear time invariant continuous system is given by Its characteristic equation is given by:
a) s2+5s+3=0
b) s2-3s-5=0
c) s2+3s+5=0
d) s2+s+2=0
Answer: a
Explanation: The transfer function is calculated by the state variable analysis and hence the transfer function is calculated by state transition matrix and taking the inverse Laplace transform.
8. Given a unity feedback control system with G (s) = K/s(s+4), the value of K for which the damping ratio is 0.5.
a) 1
b) 16
c) 64
d) 32
Answer: b
Explanation: The value is found by using the Routh- Hurwitz criteria and equating one of the row of the Routh-Hurwitz criteria equal to zero and hence finding the value of K.
9. The LVDT is used in the measurement of:
a) Displacement
b) Acceleration
c) Velocity
d) Humidity
Answer: a
Explanation: The LVDT is the linear variable differential transformer and it is used to calculate the displacement with the inductor process.
10. A system with gain margin close to unity and phase margin close to zero is :
a) Highly stable
b) Oscillatory
c) Relatively stable
d) Unstable
Answer: c
Explanation: A system is relative stable not stable if the phase margin is close to zero then the stability is checked by gain margin.
Assessment of Relative Stability Using Nyquist Criterion
Control Loop Multiple Choice Questions
Mathematical Preliminaries
Effect of Adding a Zero to a System
Cascade Compensation in Frequency Domain
Block diagram Algebra Objective Questions
208kSubscribersSubscribe
Temperature Measurement Multiple Choice Questions
Ion Analyzer Questions & Answers
Split-Range, Auto-Selector, Ratio & Cascade Systems
DC Circuits Multiple Choice Questions
Diagonalization
State Variable Analysis – Part II
Transfer Functions Objective Questions
Ion Selective Electrodes Questions and Answers
Gamma Camera Questions & Answers
Digital Control Systems
Z-transform Analysis of Sampled-Data Control Systems
Optimal Control Systems
Optimal Control Problems – Part 1
Parameter Optimization
Advances in Control System
Fuzzy Logic Control
Signal Flow Graphs Objective Questions
Mass Spectrometer Questions & Answers
Construction of Root Loci
Time Response Analysis
Time Response of Second Order Systems – I
Discover More
Stilling wells
Stilling Wells for Level Measurement
How to Select a pH and ORP Meter
How to Select a pH or ORP Meter
Electrical Machines MCQ Series 23
RC Triggering
SCR Triggering Methods
Programmable Logic Controller (PLC) Questions and Answers – 7
Ball Valve root cause
Ammonia Feed Ball Valve to Ship Tank Closed
single-acting-vs-double-acting-control-valve-actuators
Single Acting Vs Double Acting Actuators
Top PLC Manufacturers
