Reading: Difference between Induction motor and Synchronous motor
Inst Tools > Blog > Electrical Machines > Difference between Induction motor and Synchronous motor
Last updated: April 26, 2016 5:47 pm
Electrical Machines
2 Min Read
Induction Motor:
  • 3 phase induction motor is self starting. Self starting torque is generated hence no special means is required for starting of Induction motor. It is to be remembered that Auto transformer starter, Star-Delta starting and other type of starters are employed to reduce the inrush starting current.
  • Speed of the induction motor falls with the increase in the load. Induction motor always runs below synchronous speed
  • Induction motor always operates on lagging power factor and during light loads power factor of  induction motor will be very poor
  • Induction motor requires no dc excitation to the field and hence it is singly excited machine
  • Speed of the induction motor can be controlled however it is limited
  • It is used to supply mechanical load to drive the load
  • Its torque is more sensitive to change in the input volatge
  • It is simple, rugged in construction and is comparatively lower cost
Synchronous Motor:
  • Synchronous Motor is not self starting (it don’t have self starting torque), therefore some external means is required for its starting
  • Speed of the Synchronous machine is constant and is independent of the load
  • It can be operated under a wide range of power factor, both leading and lagging
  • It requires dc supply for field, so synchronous motors are doubly excited
  • Speed control is not possible
  • Synchronous motor is used for supplying mechanical load to drive and also used for power factor improvement (when synchronous motor operates under over excited condition it delivers reactive power to the system)
  • Torque of synchronous motor is less sensitive to the supply voltage
  • Construction wise it is complicated compared to induction motor, maintenance is required and also initial cost is also high compared to induction motor.
Importance of Hysteresis Loop
Synchronous Motor Starting Methods
BLDC Motor Vs AC Induction Motor
Losses of Transformer
Stepper Motor Basics, Types, Modes, Wiring, Questions
Types of AC Motors and DC Motors
  • Tayo Arogundade says:
    March 30, 2017 at 11:03 am
    Very serious learning avenue..
Advantages and Applications of zigzag transformer
Star to Delta and Delta to Star Conversion Formula
Differences Between AC and DC Motors
Advantages & Disadvantages of Synchronous Motors
Difference Between Squirrel Cage and Slip Ring Motors
AC Motor Speed Control
Induction Motors Faults and Protection
What is a Transformer Tap Changer
Difference between Permanent Magnet BLDC and DC Motor
Types of Transfomer Cooling Methods
Squirrel Cage Induction Motor vs Slip Ring Induction Motor
Dead Time and Reclaim Time
What is Auto Reclosing?
Synchronous Motor Is Not Self Starting?
What is a transformer tap changer?
DC motor speed control
DC Motor Speed Control
Transformer Open and Short Circuit Tests
K-Map Simplification Objective Questions
toroidal conductivity probe principle
Electrodeless Conductivity Probes Principle
Level Gauges Questions and Answers
Level Gauges Objective Questions and Answers – Instrumentation
What is Gear Box Backlash
What is Gear Box Backlash ?
Using Kirchhoff’s Voltage Law to find Current with Multiple Battery Sources
Kirchhoff’s Laws
Pressure transmitter Calibration Setup
Instruments Calibration Procedures
Turbine Meter in Gas Metering System
Read Gas Composition from Gas Metering System using RS485 Protocol
How to Use Analog Input in Mitsubishi FX3U LOLLETTE PLC
How to Use Analog Input in Mitsubishi FX3U LOLLETTE PLC?
