Reading: Difference between Water Cooled Chiller and Air Cooled Chiller
Inst Tools > Blog > Common > Difference between Water Cooled Chiller and Air Cooled Chiller
In this post, we will learn the difference between water cooled and air cooled chillers in an HVAC system.
Last updated: September 28, 2022 4:16 pm
Common
In this post, we will learn the difference between water cooled and air cooled chillers.
What is Water Cooled Chiller?What is an Air Cooled Chiller?Difference between Water Cooled and Air Cooled Chillers
HVAC is a very vast field and it comprises of many devices. One of the main components in HVAC is a chiller. Chiller is a refrigerant component which is used to cool the temperature of water, air or evaporation. They are used in many commercial and industrial applications.
Chillers are classified into various categories. One of them is based on cooling medium used in condensers. There are two types of that – water cooled and air cooled. In this post, we will see the difference between water cooled and air cooled chillers.
To understand first of all how a refrigeration cycle works, refer to the below article. It will help to then understand the chillers more easily.
HVAC Refrigeration Cycle
As the name implies, Water Cooled chiller uses water as a condensing medium. In condensers, water from the cooling tower is used to condense the hot gas coming from the compressor. The remaining refrigerant cycle remains the same. When the final gas reaches evaporator coils, it does heat exchange with a warm medium (water or air) and cools its temperature.
Cooling Tower is a big building that circulates water with chiller condensers. So, you can say it is a facility where unwanted heat dissipates. There is a large fan that feeds the unit with air, which meets the incoming warm water from the condenser. Heat exchange happens between air and water, and the water becomes cooler.
As the name implies, an Air-cooled chiller uses the air as a condensing medium. Condensing fans are used to condense the hot gas coming from the compressor. The remaining refrigerant cycle remains the same. When the final gas reaches evaporator coils, it does heat exchange with a warm medium (water or air) and cools its temperature.
Outside ambient air is used to reduce the temperature of refrigerant gas coming from the compressor. The incoming fans suck air from outside and allow heat exchange. The resultant warm air is also eliminated outside by the outgoing fans.
Compare Water Cooled Chiller and Air Cooled Chiller
The following are the key points that discuss the differences between air-cooled chillers and water-cooled chillers.
  • The main difference is that water cooled ones use humid air (ambient air with water stream), while the air cooled ones use pure ambient air.
  • Air cooled ones are cheaper to set as they require no expensive cooling towers. Water cooled chillers are thus comparatively costlier ones.
  • Air cooled chillers are easier to operate and maintain as compared to water cooled chillers, where you will also need to attend cooling towers apart from your chiller.
  • As water is the main working point in water cooled ones, if there is any issue in water supply or the water is contaminated, then the condensing will be affected. There is no such issue in air cooled chillers.
  • The main advantage of water cooled chillers is their size. The cooling capacity is 10-4000 tons, as compared to air cooled chillers which have a capacity of maximum 500 tons. So, if you have a large industrial setup comprising of many chillers, then water cooled is the most preferred option instead of multiple air cooled condensers.
  • The lifespan of water cooled chillers is longer than air cooled chillers.
  • The efficiency of water cooled ones is higher than air cooled chillers.
  • If you see space consumption, then air cooled chillers consume more space as compared to water cooled chillers due to area occupied by condenser fans and the distance it requires to properly come in contact with ambient air temperature.
  • Water chillers are less noisy as compared to air chillers which make a large amount of noise; due to presence of compressor and fans in the same area.
In this way, we understand the difference between an HVAC air-cooled chiller and water cooled chiller.
Wireless Electric Vehicle Charging
How ANSI Class Relates to PSI ?
Basics of Two, Three & Four Wire Transmitters
How Many Types of Cable Glands Are There?
What is a Voltage Reference? – Electronic Components
Strain Gauge Load Cell
How to Begin Learning Programming and Succeed?
Batch Type Centrifugal Automation in Sugar Industries
Look Listen Feel of Instruments – Instrumentation Engineer Maintenance
What is C Programming Language? Fundamentals, Pros & Cons
Use of Isolator in Microwaves
Dew Point in Instrument Air
List of Tools used by Instrument Technician or Engineer
Data Preparation for AI
Data Preparation for AI: For Successful Machine Learning
HVAC Questions & Answers
Pipeline Pig Detector
What are Non-Intrusive Pig Signallers or Pig Detectors?
The Best HVAC System for Home
Which HVAC System is Best for Home?
Difference Between Microcontroller and Microprocessor
Circuit diagram of Liquid level measurment using Adruino C
Level Measurement and Control using Arduino C
Machine Learning
Difference Between Machine Learning and Artificial Intelligence?
List of Cybersecurity Labs
Difference between Motion Controller and PLC
Difference Between Emergency STOP and Emergency Power OFF
Radio Telemetry Objective Questions
Electrical Drives Animation
PLC Ladder Logic for Lube Oil Pump Motor
Electric Open Circuit
Series Open Circuit Faults
Industrial Automation and Control
100+ Questions and Answers on Industrial Automation and Control
device-specific-diagnostics-to-ne107-status-signals
NAMUR NE107 Standard
