  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: D’Arsonval Movement
  • PLC Tutorials
  • Control Systems
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Common > D’Arsonval Movement
D’Arsonval Movement
Last updated: March 31, 2018 5:42 am
Common
2 Min Read
The main aim of a measuring system is to presnt the data in an understandable manner to the user / observer. The data presentation device is called as an output device or terminating device.
Priniciple of D’Arsonval MovementDescription of D’Arsonval MovementOperation of D’Arsonval Movement
The D’Arsonval movement is a current sensing mechanism which is used in DC Ammeter, ohm meter and Voltmeter.
D’Arsonval Movement
When an electric current is passed through a coil placed in a magnetic field, it experiences a force. This force causes a torque in the coil that is fixed to a spindle. The spindle can rotate in fixed bearings.
The rotation of the spindle is proportional to the electric current passed through the coil. This torque that is produced is balanced after a movement against the restoring torques of springs. The torque that is produced that tends to rotate the spindle is termed as D’Arsonval Movement.
D’Arsonval Movement Principle
  1. The arrangement consists of a coil which is wound over an iron core (spindle).
  2. This spindle is place between the two poles of a horse shoe magnet.
  3. The spindle is attached at its end to bearings. Sprial and torsional springs are provided for restrotation of the system when the extraction is removed.
  4. A pointer is attached to the spindle that can sweep over the calibrated scale.
  1. When a current is passed through the coil, it produces a force. Due to this force, a torque is produced in the spindle which rotates it.
  2. When the spindle rotates, it moves a pointer making it sweep over the calibrated scale.
  3. The spring produce a restoring torque. When this restoring torque becomes equal to the excitation torque, the pointer comes to rest.
  4. The rotational movement of the spindle is proportional to the supply (D.C) Current.
Recommended Articles
Recommendations to HVAC Engineers
Piping and Instrumentation Drawing (P&ID) Tutorials – Part 4
What is Optical Modulation? – Methods of Optical Modulation
Software Testing Projects – How to Approach the Process Effectively?
Electrical Switches Principle & Types
FPGA vs. CPLD – What are the differences between them
208kSubscribersSubscribe
Recent Comments
Related Articles
Sheet Metal Fabrication Manufacturing and Design
Ideal Guide To Sheet Metal Fabrication Manufacturing and Design
Centrifugal Machine Field
Batch Type Centrifugal Automation in Sugar Industries
Difference Between Resistive Touch and Capacitive Touch
Food Safety Equipment And Tools
Food Safety Equipment, Tools, and Tips: A Guide For Businesses
Production Planning Software
Strip-Chart-Recorder-Working-Principle
Strip Chart Recorder Working Principle
Difference between Standards and Codes
Difference between Standards, Codes, Specifications, Regulations
The Best HVAC System for Home
Which HVAC System is Best for Home?
More Articles
Control System Basic Wiring Practice Animation
PLC Connection between Instrument, Junction Box, Marshalling & System Cabinet
History of 3-15 psi, 10-50 mA, and 4-20 mA signals
Best Practices of PLC Wiring
Best Practices of PLC Wiring – Programmable Logic Controller
Determine Resistance value of Resistors
Types of Industrial Storage Batteries
fire alarm system operation
What is Fire Alarm System?
Start the Counting from a Preset Value in PLC
Motor Stop Interlock for Changing the Direction PLC Program
