Reading: What is Auto Reclosing?
Inst Tools > Blog > Electrical Machines > What is Auto Reclosing?
Last updated: July 10, 2020 7:59 pm
Electrical Machines
Auto Reclosing
Auto reclosing is a phenomenon in which the breaker tries to reconnect the line between two points with the delay or without delay at the time of the fault.
Auto ReclosingWhy we employ Auto reclosers on lines?Is autorecloser applicable with respect to fault nature?What is the blocking feature?What happened during this reclosers operations?Could we employ a single-phase auto recloser at the three-phase line?What are the types of auto-recloser?Why is High-speed reclosing type recommended for the Generator-Transmission line?What are the settings criteria of auto recloser?What is Dead Time and Reclaim Time?What is Fault clearance time?What is Sequence of Operations?
As per one estimate, only 5% fault in power system is permanent, others are semi transient or transient in nature, one more estimate stated that about 80% fault (Schneider claims transient fault up to 60 to 70%) at the line is transient in nature. I want to share one feeder tripping of my previous employer company here
Feeder XYZ- Trip-9 times from 5th Feb 2011 to 5th March 2011, Fault traced 1 time and 8 times no fault. We do not have auto reclosers, so due to these transient faults, our loss is due to
  • Man-hour engaged to the normalized feeder after long petrol of inspection
  • Fuel cost
  • Potential revenue lost during an undesired power outage
No, we cannot apply auto recloser with respect to fault nature, because it is not definable, but we can use blocking feature for the semi-transient or permanent faults.
Auto recloser is a device which can open at the time of fault and reclose after a delay or without delay, but engineer needs to define that how many reclosing options are allowed, let suppose 3 reclosers are allowed, then after 3 O-C (open and close) operations, auto reclosers programmed (manually or remotely) blocked further operation and remain in the open position.
During the opening phase of the recloser’s operation, the arc is opted to deionized. Let suppose our auto recloser is programmed for 2 successful reclosers, and after 2 reclosers fault persists in a system, then the fault will be characterized as semi transient or permanent, and auto recloser performed blocking of line.
Yes, as per CBIP Publication # 74, in India single phase auto recloser is employed at 220KV and 400KV Generation-Transmission lines with a high recommendation. But the type of Auto recloser employee here is High-speed single-pole reclosing type.
1.  High-speed single-pole reclosing
2.  High speed three poles reclosing (HTAR)
3.  Delayed three-phase reclosing (DAR)
4.  DAR with a deadline(DL) and synchronism check(SC)
5.  HTAR with DL and SC
6.  HTAR with Parallel line check (PC)
As per Generation engineer point of view “Main advantages are the stability of machine (in this case generator) and minimum outage”
  1. Deadtime
  2. Reclaim time
  3. Breaker Operating cycle or Sequence of Operation
The period between Arc Extinguished point to Contacts Make a point.
Dead time = t2 + t3 + t4
Reclaim time is the time between Coil’s closed energized point to Breaker’s fully closed point.
Referring to figure mention
The fault clearance time is the interval between the operation of the relay (trip initiation) and the time it takes to open the breaker contacts (Contacts Separate).
O + 0.3s + CO + 3 min + CO…….. (1)
O stands for Open
CO stands for Close-Open
We can read equation (1) as,
The rated operating cycle of the circuit breaker consisting of an opening, a holding time of 0.3 seconds, a CO cycle, a 3-minute wait, and another CO cycle.
Author: Qazi Arsalan Hamid
  • Power System Protection
  • Circuit Breaker Animation
  • Synchronous Generators
Types of AC Motors and DC Motors
Synchronous Generator Salient Pole vs Non Salient Pole
Advantages & Disadvantages Induction Motor
Transformer Energy Losses & Efficiency
AC Motor Speed Control
Losses in a DC Generator
  • Hussnain SArwaR says:
    March 2, 2023 at 10:47 am
    I need Hardware Circuit Diagram of Auto reclose Circuit breaker.
Star to Delta and Delta to Star Conversion Formula
Advantages and Disadvantages of Squirrel Cage Induction motor
Types of Transformers
What happen When Synchronous Generator loss Excitation
Differences Between AC and DC Motors
Why Armature is placed on Stator for Synchronous machines
Types of Transfomer Cooling Methods
Difference Between Squirrel Cage and Slip Ring Motors
BLDC Motor Vs AC Induction Motor
Difference between Permanent Magnet BLDC and DC Motor
Losses of Transformer
Types of Generators
Motor Star Delta Connections
Squirrel Cage Induction Motor vs Slip Ring Induction Motor
Applications of Synchronous Motors
Questions and Answers on Motors and Generators
100+ Questions and Answers on Motors and Generators
Level Gauges
Level Gauge Design
3-Wire, Three-Phase Delta Wiring System
Stepper Motor Working Principle Animation
Studio 5000 Programming Three Motors with Fixed Priorities
Studio 5000: Programming Three Motors with Fixed Priorities
Difference between ON-OFF Controller and PID Controller
Induction Motors Flux & MMF Phasors and Waves Questions
Latest Control Valves Interview Questions
Control Valve Interview Questions and Answers
Paddle switch Working Principle
Paddle Switch Working Principle
