Reading: Applications of Synchronous Motors
Inst Tools > Blog > Electrical Machines > Applications of Synchronous Motors
Last updated: December 22, 2018 1:14 am
Electrical Machines
2 Min Read
For industrial squirrel cage induction motors are used mostly for the motor and drive systems applications. Synchronous motors are very rarely used below 40kW output because of the higher cost compared to induction motors. In addition to the higher initial cost synchronous motors needs dc excitation source and starting and control devices are usually more expensive.
However for particular output range and speed high initial cost of synchronous motor varnishes are economical compared to induction motor. Where applications involve high kW output and low speed synchronous motors are economical compared to induction motors.
The various classes of service for which synchronous motors are employed may be classified as:
  • Power factor correction
  • Voltage regulation
  • Constant speed constant load drives
Applications:
  • Synchronous motors are used in generating stations and in substations connected to the busbars to improve the power factor. For this purpose they are run without mechanical load on them and in over-excited condition. These machines when over excited delivers the reactive power to grid and helps to improve the power factor of the system. The reactive power delivered by the synchronous motors can be adjusted by varying the field excitation of the motor. These motors used for power factor correction applications can also be termed as “synchronous condensers”. Advantage of synchronous condensers compared to shunt capacitors is that shunt capacitors generate constant reactive power whereas on the other hand synchronous condensers can able to deliver different reactive power levels by varying the excitation of machine.
  • Because of the higher efficiency compared to induction motors they can be employed for loads which require constant speeds. Some of the typical applications of high speed synchronous motors are such drives as fans, blowers, dc generators, line shafts, centrifugal pumps, compressors, reciprocating pumps, rubber and paper mills
  • Synchronous motors are used to regulate the voltage at the end of transmission lines
  • In textile and paper industries synchronous motors are employed to attain wide range of speeds with variable frequency drive system
Induction Motor Operating Characteristics
Squirrel Cage Induction Motor vs Slip Ring Induction Motor
AC Motor Braking
Difference between Permanent Magnet BLDC and DC Motor
Synchronous Motor Is Not Self Starting?
BLDC Motor Vs AC Induction Motor
Losses in a DC Generator
6.6kV HV Induction motor Protection
Induction Motors Faults and Protection
Metering Pumps
Stepper Motor Basics, Types, Modes, Wiring, Questions
Why Starting Current of Induction Motor is High
Advantages & Disadvantages of Synchronous Motors
Types of AC Motors and DC Motors
DC motor speed control
DC Motor Speed Control
Faults in a Transformer
Star to Delta Conversion
Star to Delta and Delta to Star Conversion Formula
Difference Between Squirrel Cage and Slip Ring Motors
Why Armature is placed on Stator for Synchronous machines
Difference between Induction motor and Synchronous motor
What is a transformer tap changer?
Advantages and Disadvantages of Squirrel Cage Induction motor
Transformer Coil Polarity
Card Failures in Automation Panels
Automation Panel Electronic Cards Failure investigation
CNC Milling Machine
CNC Milling Machines: What Are They And How Do They Work?
How to Setup a Smart Transmitter Using a HART Communicator
How to Configure a Smart Transmitter Using a HART Communicator?
Instrumentation Engineering Standards Questions & Answers
How to Blink Lights in Ladder Logic
How to Blink Lights in Ladder Logic?
psv-principle-of-operation
Instrumentation Inspection Report
Weighing Balance Calibration
Calibration Procedure of Weighing Balance and Common Mistakes
