Reading: Advantages & Disadvantages of Synchronous Motors
Inst Tools > Blog > Electrical Machines > Advantages & Disadvantages of Synchronous Motors
Last updated: December 22, 2018 1:16 am
Electrical Machines
3 Min Read
In industries induction motors are employed mostly because of less cost, rugged construction, good starting torques and very less maintenance. Synchronous motors are rarely used in industries for drive applications. They are generally used as power factor correction device. In industries they are employed to improve the power factor of the system. Some of the advantages and disadvantages related to synchronous motors are explained below:
Advantage or Merits:
  • One of the major advantage of using synchronous motor is the ability to control the power factor. An over excited synchronous motor can have leading power factor and can be operated in parallel to induction motors and other lagging power factor loads thereby improving the system power factor.
  • In synchronous motor the speed remains constant irrespective of the loads. This characteristics helps in industrial drives where constant speed is required irrespective of the load it is driving. It also useful when the motor is required to drive another alternator to supply at a different frequency as in frequency changes
  • Synchronous motors can be constructed with wider air gaps than induction motors which makes these motors mechanically more stable
  • In synchronous motors electro-magnetic power varies linearly with the voltage
  • Synchronous motors usually operate with higher efficiencies ( more than 90%) especially in low speed and unity power factor applications compared to induction motors
  Disadvantages or Demerits:
  • Synchronous motors requires dc excitation which must be supplied from external sources
  • Synchronous motors are inherently not self starting motors and needs some arrangement for its starting and synchronizing
  • The cost per kW output is generally higher than that of induction motors
  • These motors cannot be used for variable speed applications as there is no possibility of speed adjustment unless the incoming supply frequency is adjusted (Variable Frequency Drives)
  • Synchronous motors cannot be started on load. Its starting torque is zero
  • These motors have tendency to hunt
  • When loading on the synchronous motor increases beyond its capability, the synchronism between rotor and stator rotating magnetic field is lost and motor comes to halt
  • Collector rings and brushes are required resulting in increase in maintenance
  • Synchronous motors cannot be useful for applications requiring frequent starting or high starting torques required
Advantages of Hydrogen cooling in Synchronous Generators
Types of Generators
Difference between Permanent Magnet BLDC and DC Motor
Difference between Star and Delta Connections
Types of Transformers
Synchronous Generator Salient Pole vs Non Salient Pole
Difference Between Squirrel Cage and Slip Ring Motors
Why rating of Synchronous Generators and Alternators in MVA or KVA
Losses of Transformer
Synchronous Motor Starting Methods
Losses in a DC Generator
DC Motor Speed Control
Advantages & Disadvantages of Variable Speed Drives
Dead Time and Reclaim Time
What is Auto Reclosing?
Why Armature is placed on Stator for Synchronous machines
What is a transformer tap changer?
Why Starting Current of Induction Motor is High
VFD circuit
AC Motor Braking
Use of line reactors
Allen-Bradley VFD
AC Motor Speed Control
Quiz on Sensor Transducer
Pressure Measurement using Manometer
Override Control Functions
Plant Shutdown Analysis: Valve Closed and SOV Coil Failure
PID Simulator
PID Simulator Download
HIPPS Operating Philosophy
Understanding High Integrity Pressure Protection Systems (HIPPS)
Statement List (STL) to Find Highest Value in the Data Block
ControlLogix 5580 Controllers
Rockwell PLCs for Large Scale Applications
