| 1 | A gyroscope works on which of the following principles? |
| 2 | The input to a stepper motor is in the ___ |
| 3 | For a two-phase servomotor which of the following statements is incorrect? |
| 4 | In root locus plot different roots have the ___ |
| 5 | In pneumatic systems the medium used is ___ |
| 6 | Which of the following is the non-linear system? |
| 7 | Which of the following is the output of a synchor error detector? |
| 8 | Gain margin is the factor by which the gain of the system is ___ |
| 9 | Which of the following happens as the type of a system increases? |
| 10 | In amplidyne the compensating winding is ___ |
| 11 | The damping ratio of the system having only two poles, each having a ___ |
| 12 | The proportional error device has output as function of ___ |
| 13 | The value of the resonant peak, in second order control system, will ‘be unity when ___ |
| 14 | The servomechanisms with step displacement input is ___ |
| 15 | By which of the following is the order of the system determined? |
| 16 | The operational amplifier used in servo amplification should have ___ |
| 17 | If a step function is applied to the input of a system and ___ |
| 18 | Which of the following is an advantage of Laplace transform method? |
| 19 | ___ is not a form of non-linearity for a control system ___ |
| 20 | A transfer function may be best defined as ___ |
| 21 | ___ is the reference input minus the primary feedback |
| 22 | ___ is not a form of non-linearity for a control system |
| 23 | The viscous friction co-efficient, in force-voltage analogy, is ___ |
| 24 | In an automatic control system which of the following elements is not used? |
| 25 | A phase lag lead network introduces in the ___ |
| 26 | Which of the following should be done to make an unstable system stable? |
| 27 | The initial response when tne output is not equal to input is called ___ |
| 28 | Velocity error constant of a system is measured when the input to ___ |
| 29 | Spring constant in force-voltage analogy is ___ |
| 30 | In electrical-pneumatic system analogy the current is considered analogous to ___ |
| 31 | A control system with excessive noise, is likely to ___ |
| 32 | ___ is a closed loop system |
| 33 | A good control system has all the following features except ___ |
| 34 | Which of the one is incorrect? |
| 35 | In a system the friction co-efficient is decreased to ___ |
| 36 | Phase lag network does which of the following? |
| 37 | The overshoot (an indication of the largest error between the actual and desired output) is the ratio of ___ |
| 38 | ___ system provides excellent transient as well as steady-state response |
| 39 | On which of the following factors does the resolution of a potentiometer depend? |
| 40 | ___ has infinite resolution |
| 41 | In type-1 system a constant output velocity at steady state will be ___ |
| 42 | In a control system, noise can be reduced by ___ |
| 43 | By the use of which of the following the power amplification of a magnetic amplifier is increased? |
| 44 | The eigen values of a linear system are the locations of ___ |
| 45 | In pneumatic control system the output of ___ |
| 46 | In a system of controlling oil flow to burner which of the following elements is not required? |
| 47 | For servomechanisms which of the following statements is incorrect? |
| 48 | The type 2 system has which of the following? |
| 49 | The system response can be tested better with ___ |
| 50 | In a control application the choice of error detector depends on ___ |
| 51 | A unit step function on integration results in a ___ |
| 52 | The break away points of the root locus occur at ___ |
| 53 | Through which of the following the frequency domain analysis can be related to time doniain analysis? |
| 54 | In hydraulic system power is transmitted by ___ |
| 55 | The operational amplifier is used for which of the following? |
| 56 | Which of the following is an essential feature of servomechanism? |
| 57 | A servomechanism with unit step input can be ___ |
| 58 | Bandwidth is used as a means of specifying performance of ___ |
| 59 | With feed back ___ |
| 60 | The phase lag produced by transportation relays ___ |
| 61 | Hydraulic torque transmission system is analog of ___ |
| 62 | The temperature, under thermal and electrical system analogy, is ___ |
| 63 | Which of the following statements is correct for a system with ___ |
| 64 | ___ has tendency to oscillate |
| 65 | For transistor amplifier circuits the common emitter configuration is ___ |
| 66 | A minor loop feedback compensation increases the steady state error by ___ |
| 67 | The term confirmity is associated with which of the following? |
| 68 | With the knowledge of state space representation the transfer function of ___ |
| 69 | Which of the following methods may be used to minimize the loading in potentiometers? |
| 70 | An ideal transformer should have ___ |
| 71 | A synchro is employed ___ |
| 72 | A ‘drag cup’ type motor has which of the following? |
| 73 | In a system nonlinearity may be introduced by which of the following? |
| 74 | ___ can measure pressure error |
| 75 | In pneumatic instrumentation systems the pressure of ___ |
| 76 | The root loci of a system has three asymptotes the system can ___ |
| 77 | The frequency range is specified by which of the following? |
| 78 | If the bandwidth of a system is increased the response will ___ |
| 79 | Which of the following forces resists motion? |
| 80 | The root locus plot is symmetrical about the ___ |
| 81 | The maximum overshoot of a second order system can be increased by |
| 82 | Regenerative feedback means the output is ___ |
| 83 | Which of the following devices is used to indicate angular position of an aircraft? |
| 84 | A servomechanism is a feedback control system required to ___ |
| 85 | Type 1 system under parabolic input will have which of the following? |
| 86 | The lead compensator in a ___ |
| 87 | Which of the following is the output of a thermocouple? |
| 88 | In a control system integral error compensation ___ |
| 89 | The effect of error damping is to ___ |
| 90 | In order to increase the clamping of a badly underdampecl system which of ___ |
| 91 | The type 2 system has ___ |
| 92 | The capacitance, in force-current analogy, is analogous to ___ |
| 93 | The output of a feedback control system must be a function of ___ |
| 94 | There is a ____ between the two nodes of signal flow graph |
| 95 | Which of the following statements is incorrect in respect of closed loop control system? |
| 96 | For which of the following reasons nonlinearities are introduced? |
| 97 | High power amplification is achieved by the use of ___ |
| 98 | Which of the following types of motor has printed windings? |
| 99 | For a linear transfer function of the variable the transfer function of ___ |
| 100 | The resolution of potentiometer should be ___ |
| 101 | Which of the following materials is used for making a stator of a synchro? |
| 102 | The velocity lag error in the type-1 system is ___ |
| 103 | By use of which of the following the system damping factor can be reduced? |
| 104 | Zero percent porportional band means ___ |
| 105 | A pneumatic amplifier ___ |
| 106 | Which of the following statements is incorrect for root locus technique? |
| 107 | By which of the following the order of the system can be determined? |
| 108 | In radars the control systein used is ___ |
| 109 | Nyquist criterion is used to find which of the following? |
| 110 | A servomechanism usually consist of ___ |
| 111 | The Bode plot is used to analyse which of the following? |
| 112 | In order to decrease the time constant of the control system its ___ |
| 113 | The value of a node in the signal flow graph is ___ |
| 114 | LVDT is an ___ |
| 115 | ___ is preferred when a control signal is required |
| 116 | The steady state acceleration error for a ___ |
| 117 | A limit switch is used to ___ |
| 118 | The transfer function technique is considered as inadequate under which of ___ |
| 119 | If the gain of the critical damped system is increased it will ___ |
| 120 | The type 1 system has ___ |
| 121 | The on-off controller is a ___ |
| 122 | Regenerative feedback implies feedback with ___ |
| 123 | A closed loop system is distinguished from open loop system by which of the following? |
| 124 | Which of the following statements is not nedessarily correct for open control system? |
| 125 | The feedback of the tachometer reduces the ___ |
| 126 | For frequency domain analysis sinusoidal signals considered have ___ |
| 127 | The magnetic properties of silicon steel crystal are ___ |
| 128 | The characteristic equation of the second order of the system is ___ |
| 129 | In a feedback amplifier, the ___ |
| 130 | Error Constants of a system are ___ |
| 131 | Control Systems are normally designed with ___ |
| 132 | The impulse function is a derivative of ___ |
| 133 | The ON-OFF controller is ___ |
| 134 | Transfer function of the control system ___ |
| 135 | The transfer function has the main application in the study of ___ |
| 136 | The transfer function of a system is ___ |
| 137 | The Transfer function of the system is used to ___ |
| 138 | In a hybrid feedback control systems carrier signals ___ |
| 139 | Regenerative feedback ___ |
| 140 | The transient response of a system is ___ |
| 141 | The deviation of the primary feedback signal from the ___ |
| 142 | In a control system, the controller output is ___ |
| 143 | A controller essentially is ___ |
| 144 | In a control system the use of ___ |
| 145 | A control system in which control action depends on the output is ___ |
| 146 | Introduction of the feedback reduces the ___ |
| 147 | A Closed loop system is basically different from ___ |
| 148 | In a control system the comparator compares the output response and ___ |
| 149 | The weighting function of the control system is ___ |
| 150 | A signal other than the reference input that tends to affect the value of controlled variable is ___ |
| 151 | In a control system the comparator measures the ___ |
| 152 | Tachometer is employed to ___ |
| 153 | Potentiometers are used in ___ |
| 154 | The thermocouple directly converts temperature ___ |
| 155 | The input to a controller is always a/an ___ |
| 156 | Synchros are widely used for transmission of ___ |
| 157 | ___ can be used for converting the angular the angular position of a shaft |
| 158 | The output of synchro error detector is ___ |
| 159 | AC Servo motor is basically a ___ |
| 160 | A gyroscope operates on the ___ |
| 161 | Which of the following is not true for ___ |
| 162 | Two stator windings of the ac servo motors are oriented ___ |
| 163 | Bimetallic thermostat is ___ |
| 164 | Transfer function of a control system ___ |
| 165 | The transfer function of a system is used to ___ |
| 166 | Laplace transform method has the ___ |
| 167 | A transfer function of a system is a Laplace transform of ___ |
| 168 | The basic property of the signal flow graph is ___ |
| 169 | A signal flow graph is ___ |
| 170 | ___ gives indication how fast the system tends to attain the final value |
| 171 | Error constants of the system are measure of ___ |
| 172 | The overshoot (an indication of the largest error between the actual and desired output) is ___ |
| 173 | A signal whose value changes from one level to ___ |
| 174 | Control systems are normally designed with a ___ |
| 175 | The time required for the response to rise from 10% to 90% of the ___ |
| 176 | The required for the response to rise and stay within the ___ |
| 177 | An impulse function is a derivative of ___ |
| 178 | A unit step function on integration results ___ |
| 179 | In a control system noise can be ___ |
| 180 | Transient function of the system and the response in terms of ___ |
| 181 | Differentiators are avoided in the system design as ___ |
| 182 | The second derivative input signal ___ |
| 183 | Transfer function can be obtained from ___ |
| 184 | Velocity error constant of the system is a measured when the input of the ___ |
| 185 | The steady state error of a control system can be ___ |
| 186 | In a PID controller, the overshoots has ___ |
| 187 | In a PID controller, the offset has increased ___ |
| 188 | Which of the following system provides excellent transient and ___ |
| 189 | The number of operational amplifiers require for designing of ___ |
| 190 | When derivative action is included in a proportional controller, the ___ |
| 191 | In a proportional temperature controller, if the quantity under the ___ |
| 192 | The integral control ___ |
| 193 | The term reset control refers to ___ |
| 194 | Proportional band of the controller is ___ |
| 195 | Proportional band of a controller is defined as the ___ |
| 196 | Which of the following is exhibited by Root locus diagrams? |
| 197 | The first order control system, which is well designed, has a ___ |
| 198 | A.C. servomotor is basically a ___ |
| 199 | The transfer function technique is considered as inadequate under which of the following conditions? |
| 200 | ___ directly converts temperature into voltage |
| 201 | Which of the following can be measured by LVDT? |
| 202 | An amplidyne can give which of the following characteristics? |
| 203 | With feed back _____ reduces |
| 204 | In a control system integral error compensation _______ steady state error |
| 205 | If the gain of the critical damped system is increased it will behave as ___ |
| 206 | Which of the following is an electromechanical device? |
| 207 | When the initial conditions of a system are specified to be zero it implies ___ |
| 208 | ___ can be extended to systems which are time-varying? |
| 209 | Which of the following is the non-linearity caused by servomotor? |
| 210 | ___ technique gives quick transient and stability response |
| 211 | Which of the following devices is used for conversion of co-ordinates? |
| 212 | Pressure error can be measured by which of the following? |
| 213 | Which of the following is the definition of proportional band of a controller? |
| 214 | ___ is not a final control element |
| 215 | Which of the following can be measured by the use of a tacho-generator? |
| 216 | In a stable control system saturation can cause which of the following? |
| 217 | In order to increase the damping of a badly underdamped system which of following compensators may be used? |
| 218 | ___ technique is not applicable to nonlinear system? |
| 219 | Addition of zeros in transfer function causes which of the following? |
| 220 | Phase margin of a system is used to specify which of the following? |
| 221 | Which of the following is the best method for determining the stability and transient response? |
| 222 | If a step function is applied to the input of a system and the output remains below a certain level for ___ |
| 223 | In case of type-1 system steady state acceleration is ___ |
| 224 | Velocity error constant of a system is measured when the input to the system is unit _______ |
| 225 | The position and velocity errors of a type-2 system are ___ |
| 226 | The type 2 system has at the origin ___ |
| 227 | The type 1 system has ______ at the origin |
| 228 | The type 0 system has ______ at the origin |
| 229 | In a hybrid feedback control system carrier signals are ___ |
| 230 | Synchros’ are popularly used as ___ |
| 231 | A system which has some roots with real parts equal to ___ |
| 232 | As compared to a potentiometer which of the following is high for a LVDT? |
| 233 | The servomotor differs from other motors in the ___ |
| 234 | Which of the following is the disadcantage of hydraulic system over electrical system? |
| 235 | ___ is prefered for self-balancing instruments? |
| 236 | Magnetic amplifiers are used to amplify which of the following? |
| 237 | A controller is basically a ___ |
| 238 | The state-variable representation is ___ |
| 239 | As compared to electronic systems which of the following is ___ |
| 240 | The input to a controller is ___ |
| 241 | The effect of error rate damping is ___ |
| 242 | If the clamping factor of a control system is unity it ___ |
| 243 | ___ will increase the steady state accuracy? |
| 244 | For a D.C. generator input could be in ___ |
| 245 | The magnitude of system output, for ___ |
| 246 | When damping factor decreases the ___ |
| 247 | A signal flow graph is a ___ |
| 248 | Selsyn’ is the trade name given to ___ |
| 249 | The servosystem with step acceleration input is ___ |
| 250 | Diodes are connected in series with A.C. source of the magnetic amplifier mainly to ___ |
| 251 | In case of an on-off controller the proportional band is ___ |
| 252 | A differentiator is usually not a part of a control system because it ___ |
| 253 | The type 0 system has ___ |
| 254 | Mass, in force-voltage analogy, is ___ |
| 255 | Which of the following is the input to a controller? |
| 256 | The transient response, with feedback system ___ |
| 257 | As a result of introduction of negative feedback which of the following will not decrease? |
| 258 | Any externally introduced signal affecting the controlled output is ___ |
| 259 | In signal flow graph function points are ___ |
| 260 | Type 0 system has ___ |
| 261 | In a non-linear control system limit cycle is self sustained oscillations of ___ |
| 262 | Because of which of the following the use of deposited film type potentiometer is ___ |
| 263 | If the complex poles of a system have greater real parts, them overshoot is ___ |
| 264 | Steep out off characteristics will have ___ |
| 265 | The effect of adding potes and zeros can be determined quickly by which of the following? |
| 266 | A reduction gear is used to increase the ___ |
| 267 | By which of the following methods steady state error can be minimized? |
| 268 | A servo system will become absolutely unstable if ___ |
| 269 | ___ cannot be the final control element |
| 270 | The compressed air in pneumatic control systems is ___ |
| 271 | The transfer function of a system can be used to ___ |
| 272 | Synchros’ are commonly used as transmitters of ___ |
| 273 | At which of the following root loci will end? |
| 274 | ___ is the non-linearity caused by servomotor |
| 275 | Which of the following is an advantage of Bode plot? |
| 276 | Transfer function technique is inadequate when the ___ |
| 277 | In a control system an ___ |
| 278 | In several applications hydraulic motors are preferred to ___ |
| 279 | For root locus technique which of the following statements is incorrect? |
| 280 | In pneumatic control systems the control valve used as___ |
| 281 | A conditionally stable system exhibits poor stability at ___ |
| 282 | With feedback ___ |
| 283 | On which of the following factors does the sensitivity of a closed loop system to ___ |
| 284 | A.C. servo Motor resembles ___ |
| 285 | An automatic toaster is ___ |
| 286 | In closed loop control system, with positive value of feedback gain the ___ |
| 287 | The gain of the amplidyne is related to the gain of D.C. generator of ___ |
| 288 | LVDT is preferred over the potentiometer as an error detector because ___ |
| 289 | Slope of asymptote in Bode plot for a second order system is ___ |
| 290 | The Root locus are the plots of the variations of the poles of ___ |
| 291 | Sampled data systems final application in which of the following? |
| 292 | Which of the following is an assumption made in Laplace technique in sampled data control? |
| 293 | The loading effect-on the potentiometer can be avoided by the use of ___ |
| 294 | In aircrafts the use of hydraulic motor is preferred over the ___ |
| 295 | Regulator can be categorized as ___ |
| 296 | Frequency domain analysis is preferred when dealing with ___ |
| 297 | In system design which of the following is the disadvantage of differentiators? |
| 298 | Which of the following is incorrect? |
| 299 | ___ is used for Nyquist plot |
| 300 | The phase difference between the two windings of A.C. servomotor is ___ |
| 301 | ___ use hydraulic control devices? |
| 302 | In the case of a second order differential equation when ___ |
| 303 | A.C. servomotor, as compared to a standard induction motor has ___ |
| 304 | Which of the followin.g is a disadvantage of a series D.C. motor? |
| 305 | In a control system noise can be avoided by which of the following methods? |
| 306 | In pneumatic-electrical analogy, the electrical resistance is ___ |
| 307 | In pneumetic systems a restrictionvolume combination is equivalent to ___ |
| 308 | In pneumatic control systems compensation is provided by which of the following? |
| 309 | ___ is the serious disadvantage of electronic control systems |
| 310 | Backlash, in a stable control system, can cause which of the following? |
| 311 | The gain margin is the factor by which the gain of the system can be ___ |
| 312 | The output of a stepper motor is in the form of ___ |
| 313 | For root loci which of the following are the starting points? |
| 314 | For system gain to be zero, the roots will move towards ___ |
| 315 | Non-linearities can be ___ |
| 316 | System damping can be increased by using compensator having pair of ___ |
| 317 | When the gain margin is positive and the phase margin is negative, the system is ___ |
| 318 | Phase margin is the amount of angle to make the ___ |
| 319 | When synchro transmitter shaft is disconnected from the driving shaft it will ___ |
| 320 | By the used of which of the following high power amplification is achieved? |
| 321 | Which of the following is the basic property of signal flaw graph? |
| 322 | The transfer function of a system is used calculate which of the following? |
| 323 | A zero order hold is used with sampled data system to ___ |
| 324 | ___ is the input which is established or varied by some means external to and independent of ___ |
| 325 | In distributed systems the transportation delays are detrimental to stability due to which of the following reasons? |
| 326 | A servomotor entails which of the following disadvantages? |
| 327 | Proportional band of a controller is expressed as ___ |
| 328 | When the initial conditions of a system are specified to be ___ |
| 329 | Which of the followit’ig can be measured by LVDT? |
| 330 | Which of the following is the nonlinearity caused by servomotor? |
| 331 | Static error co-efficients are used as a measure of the effectiveness of ___ |
| 332 | The term backlash is associated with ___ |
| 333 | In a control system the output of the controller is ___ |
| 334 | In liquid level and electrical system analogy, voltage is considered analogous to ___ |
| 335 | ___ increases the steady state accuracy |
| 336 | Zero initial condition for a system means ___ |
| 337 | A control system working under unknown random actions is ___ |
| 338 | A control system in which the control action is somehow dependent on the ___ |
| 339 | A car is running at a constant speed of 50 km/h, which of the following is ___ |
| 340 | Micros is a component based on the principle of ___ |
| 341 | The frequency range specification required to satisfactorily describe the ___ |
| 342 | Which of the following is the specification of optimal control problems? |
| 343 | To maximize or minimize a set of criteria is ___ |
| 344 | Differential used in synchro differential unit indicates which of the following? |
| 345 | The steady state output of a unity feedback control system is ___ |
| 346 | The effect of second derivative input control is ___ |
| 347 | The Bode plot is applicable to ___ |
| 348 | Which of the following is an example of intentional non-linear systems? |
| 349 | In a magnetic amplifier the purpose of bias winding is ___ |
| 350 | Which of the following is an advantage of on line identification? |
| 351 | By which of the following methods viscous friction can be added to a servomechanism? |
| 352 | In a pneumatic control valve the function of valve positioner is ___ |
| 353 | Which of the foaming is the main advantage of hydraulic system over electrical system? |
| 354 | In order to convert the angular position of a shaft into an ___ |
| 355 | By which of the following methods the steady state error of a control system can be reduced? |
| 356 | Which of the following terms is not connected with potentiometer? |
| 357 | Electrical capacitance in pneumatic systems is ___ |
| 358 | A servomechanism with step displacement input will ___ |
| 359 | In a compressed air plant which of the following is not a function of the reservior? |
| 360 | Which of the following is the setting time in the second order linear system? |
| 361 | In pneumatic systems time lags are obtained by ___ |
| 362 | The time required for the response to reach half the final value for ___ |
| 363 | The overshoot is an indication of ___ |
| 364 | Static error co-efficients are used as a measure of the effectiveness of closed loop systems ___ |
| 365 | An increase in gain, in most systems, leads to ___ |
| 366 | The frequency and time domain are related through which of the following? |
| 367 | Spring constant in force-voltage analogy is analogous to ___ |
| 368 | In a system low friction co-efficient facilitates ___ |
| 369 | In a system zero initial condition means that ___ |
| 370 | By which of the following the system response can be tested better? |
| 371 | With feedback _____ increases |
| 372 | From which of the following transfer function can be obtained? |
| 373 | The transfer function is applicable to which of the following? |
| 374 | A signal other than the reference input that tends to affect the value of ___ |
| 375 | ___ signal will become zero when the feedback signal and reference signs are equal |
| 376 | The transient response of a system is mainly due to ___ |
| 377 | Mass, in force-voltage analogy, is analogous to ___ |
| 378 | In thermal-electrical analogy charge is considered analogous to ___ |
| 379 | In force-voltage analogy, velocity is analogous to ___ |
| 380 | The viscous friction co-efficient, in force-voltage analogy, is analogous to ___ |
| 381 | In a stable control system backlash can cause which of the following? |
| 382 | Due to which of the following reasons excessive bond width in control systems should be avoided? |
| 383 | Which of the following statements is correct for a system with gain margin close to unity or a phase margin close to zero? |
| 384 | Which of the following statements is correct for any closed loop system? |
| 385 | The second derivative input signals modify which of the following? |
| 386 | On which of the following factors does the sensitivity of a closed loop system to gain changes and load disturbances depend? |
| 387 | Transfer function of a system is used to calculate which of the following? |
| 388 | ___ is an open loop control system |
| 389 | Which of the following devices are commonly used as error detectors in instruments? |
| 390 | By which of the following the control action is determined when a man walks along a path? |
| 391 | ___ is a part of the human temperature control system |
| 392 | An automatic toaster is a ______ loop control system |
| 393 | A car is running at a constant speed of 50 km/h, which of the following is the ___ |
| 394 | In open loop system ___ |
| 395 | Which of the following statements is not necessarily correct for open control system? |
| 396 | Which of the following is an open loop control system? |
| 397 | A control system in which the control action is somehow dependent on the output is ___ |
| 398 | For open control system which of the following statements is incorrect? |
| 399 | In an open loop control system ___ |
| 400 | If any term in the first column of a Routh array becomes zero, then ___ |
| 401 | Temperature is analogous to ___ |
| 402 | Which of the following is used to obtain output position in a position control system? |
| 403 | Which dc servomotor requires strongest permanent magnet? |
| 404 | A conditionally stable system is stable for the value of gain between ___ |
| 405 | DC tachogenerator can be used in ___ |
| 406 | The addition of a pole to the open loop transfer function pulls the ___ |
| 407 | For any transfer function, the constant phase angle loci are ___ |
| 408 | The permanent magnet field system of brushless dc servo- motor is ___ |
| 409 | The distance of poles from origin depends on ___ |
| 410 | Which of the following is correct? |
| 411 | Bandwidth is proportional to speed of response ___ |
| 412 | In a simple on-off controller with differential gap, the magnitude of ___ |
| 413 | If poles lie in first quadrant, damping ratio is ___ |
| 414 | If the poles lie in second quadrant, damping ratio is ___ |
| 415 | In force current analogy, displacement x is analogous to ___ |
| 416 | Nyquist stability criterion uses open loop frequency response characteristics ___ |
| 417 | Which control action can never be used alone? |
| 418 | Magnetic amplifier is used for ___ |
| 419 | Nichols chart consists of ___ |
| 420 | In force current analogue, mechanical mobility is analogous to ___ |
| 421 | The sensor generally used in incremental optical encoder is ___ |
| 422 | The poles with greater displacement from the real axis correspond to ___ |
| 423 | Which of the following is open loop system? |
| 424 | In a two phasor servomotor, the direction of rotation of the rotating field depends on ___ |
| 425 | A system is highly oscillatory if ___ |
| 426 | M circles are symmetrical with respect to ___ |
| 427 | In control systems the output of sensor usually, is ___ |
| 428 | Which of the following can be used as a rotating amplifier in a control system? |
| 429 | The effect of adding poles and zeros can be determined quickly by ___ |
| 430 | For type 1 system the velocity lag error is ___ |
| 431 | Gain margin and phase margin can be determined from ___ |
| 432 | Integral control action ___ |
| 433 | In Bode plots the frequency at which two asymptotes meet is called ___ |
| 434 | In the field controlled motor the entire damping comes from ___ |
| 435 | For a stable system having two or more gain crossover frequencies the phase margin is ___ |
| 436 | Nichol’s chart is symmetric about-180° axis ___ |
| 437 | Transport lag usually exists in ___ |
| 438 | The relative stability of a system is given by ___ |
| 439 | A lead compensator ___ |
| 440 | Which of the following features is not associated with Nichols chart? |
| 441 | The complicated shapes in the polar plots are only due to time constants in the numerator of ___ |
| 442 | Lag compensation permits a high gain at ___ |
| 443 | In root locus analysis the breakaway and break in points ___ |
| 444 | About the Control System MCQ category |
