Reading: Stepper Motors Objective Questions & Answers
Inst Tools > Blog > Electrical Q & A > Stepper Motors Objective Questions & Answers
Last updated: June 21, 2025 10:05 am
Electrical Q & A Instrumentation MCQ Multiple Choice Questions
1. A variable reluctance stepper motor is constructed of ______________ material with salient poles.
a) Paramagnetic
b) Ferromagnetic
c) Diamagnetic
d) Non-magnetic
Answer: b
Explanation: A variable reluctance stepper motor is the motor that has motion in steps with respect to increase in time and constructed of ferromagnetic material with salient poles.
2. In a three-stack 12/8-pole VR motor, the rotor pole pitch is
a) 15º
b) 30º
c) 45º
d) 60º
Answer: c
Explanation: Pole pitch is defined as the number of armature slots to the pole pitch and here this has been converted into degrees.
3. A stepper motor having a resolution of 300 steps/rev and running at 2400 rpm has a pulse rate of- pps.
a) 4000
b) 8000
c) 6000
d) 10,000
Answer: c
Explanation: Pulse per second is mathematically given as PPS = (Rpm/60)*(number of steps per minute).
4. If a hybrid stepper motor has a rotor pitch of 36º and a step angle of 9º, the number of its phases must be
a) 4
b) 2
c) 3
d) 6
Answer: a
Explanation: Step angle is defined as =(Ns-Nr)/(Ns+Nr)*360.
5. The rotor of a stepper motor has no
a) Windings
b) Commutator
c) Brushes
d) All of the mentioned
Answer: d
Explanation: The rotor is the rotatory part of the motor of a stepper motor and has no windings, commutator and brushes.
6. A stepping motor is a ____________ device.
a) Mechanical
b) Electrical
c) Analogue
d) Incremental
Answer: d
Explanation: A stepping motor is a motor in which the motion in the form of steps and is a incremental device i which as the time increases the steps are increased.
7. The rotational speed of a given stepper motor is determined solely by the
a) Shaft load
b) Step pulse frequency
c) Polarity of stator current
d) Magnitude of stator current.
Answer: b
Explanation: The stator part of a motor is the stationary part of the motor and rotational speed of a given stepper motor is given by the step pulse frequency.
8. Which of the following phase switching sequence represents half-step operation of a VR stepper motor ?
a) A, B, C,A……..
b) A, C, B,A…….
c) AB, BC, CA, AB……..
d) A, AB, B, BC……..
Answer: d
Explanation: In the half step operation of a Variable reluctance motor physical step resolution is multiplied by 2 and control signals appear to be digital rather than analog.
9. A stepper motor may be considered as a ____________ converter.
a) Dc to dc
b) Ac to ac
c) Dc to ac
d) Digital-to-analogue
Answer: d
Explanation: A stepper motor is a motor in which the motion is in steps and it is an increemental device and may be considered as a digital to analog converter.
10. What is the step angle of a permanent-magnet stepper motor having 8 stator poles and 4 rotor poles?
a) 60º
b) 45º
c) 30º
d) 15º
Answer: b
Explanation: Step angle is defined as =(Ns-Nr)/(Ns+Nr)*360 where Ns is the number of stator poles and Nr is the number of rotor poles.
Measurement of Impedance Objective Questions
Nano Instrumentation Objective Questions
Stability Analysis
Objective Questions of Building Fire and Gas Detectors
Signal Flow Graphs Objective Questions
Paramagnetic Oxygen Analyzers Questions & Answers
Effect of Adding a Zero to a System – II
X-Ray Spectroscopy Questions & Answers
Ion Transducers Questions & Answers
Micro Sensors Objective Questions
Capacitive Transducers Objective Questions
Filtering and Dynamic Compensation Objective Questions
Digital Readout Systems Objective Questions
Transfer Functions Objective Questions
Stability in Frequency Domain
Preliminary Considerations of Classical Design
Inductive Transducers Objective Questions
Linearizing Effect & Regenerative Feedback MCQ
Digital Control Systems
Compensation Techniques : Control Systems
Photo Electric Transducers Objective Questions
Measurements & Instrumentation Quiz – Set 8
Top 100 Power Electronics Questions & Answers
four-way-solenoid-valve-diagram
Four Way Solenoid Valve Working Principle
Asynchronous Motor Animation
Process Control Instrumentation Terms Glossary
Components of a Water Treatment Plant
Components of Water Treatment Plant
Solenoid Valve
Solenoid Valve Troubleshooting Practices
how-to-avoid-bad-grounds
How to Avoid Bad Grounds ?
different PLC brands of Distributed IO
What is Distributed IO? – Decentralized Peripherals in PLC
Electricity Magnetism
