Reading: State Variable Analysis – Part II
Inst Tools > Blog > Multiple Choice Questions > State Variable Analysis – Part II
Last updated: November 27, 2021 5:41 pm
1. State variable analysis has several advantages overall transfer function as:
a) It is applicable for linear and non-linear and variant and time-invariant system
b) Analysis of MIMO system
c) It takes initial conditions of the system into account
d) All of the mentioned
Answer: d
Explanation: State variable analysis has several advantages overall transfer function as it is applicable for linear and non-linear and variant and time-invariant system, analysis of MIMO system, it takes initial conditions of the system into account.
2. The minimum number of states require to describe the two degree differential equation:
a) 1
b) 2
c) 3
d) 4
Answer: b
Explanation: The number of states required to describe a network is equal to the number of energy storing elements in the electrical network.
3. For a system with the transfer function H(s) = 3(s-2)/s3+4s2-2s+1 , the matrix A in the state space form is equal to:
Answer: b
Explanation: Taking the inverse Laplace of the equation and converting it into differential equation and solving the state space by considering various matrices.
4. The transfer function Y(s)/U(s) of a system described by the state equations dx/dt=-2x+2u and y(t) = 0.5x is:
a) 0.5/(s-2)
b) 1/(s-2)
c) 0.5/(s+2)
d) 1/(s+2)
Answer: d
Explanation: Taking Laplace transform of the equation X(s) = 2U(s)/(s+2)
Then Y(s)/U(s) =1/(s+2).
5. A linear time invariant single input single output system has the state space model given by dx/dt=Fx+Gu, y=Hz, where
Here, x is the state vector, u is the input, and y is the output. The damping ratio of the system is:
a) 0.25
b) 0.5
c) 1
d) 2
Answer: b
Explanation: T(s) = 1/(s2+2s+4)
G = 0.5.
6. Given the matrix
the Eigen value are___________
a) 1,2,3
b) 1
c) -1,-2,-3
d) 0
Answer: c
Explanation: Solving the characteristic equation|SI-A| =0.
7. A transfer function of control system does not have pole-zero cancellation. Which one of the following statements is true?
a) System is neither controllable nor observable
b) System is completely controllable and observable
c) System is observable but uncontrollable
d) System is controllable but unobservable
Answer: b
Explanation: If the input-output transfer function of a linear time-invariant system has pole-zero cancellation, the system will be neither controllable nor observable.
8. The analysis of multiple input multiple output is conveniently studied by;
a) State space analysis
b) Root locus approach
c) Characteristic equation approach
d) Nicholas chart
Answer: a
Explanation: State space analysis is different from the transfer function approach as this can be used for the analysis of multiple input and multiple output system.
9. The state equation in the phase canonical form can be obtained from the transfer function by:
a) Cascaded decomposition
b) Direct decomposition
c) Inverse decomposition
d) Parallel decomposition
Answer: d
Explanation: The state equation from transfer function by parallel decomposition in the phase canonical form.
10. A logarithmic spiral extending out of the singular point is__________
a) Stable
b) Unstable focus
c) Conditionally stable
d) Marginally stable
Answer: b
Explanation: Unstable focus is a logarithmic spiral extending out of the singular point.
DC Circuits Multiple Choice Questions
Silica Analyzer Questions & Answers
The Design Problem
Difference Equations
Root Locus in Control Systems
Instrumentation Diagrams Multiple Choice Questions
Control of the Effects of Disturbance Signals by Use of Feedback
Mathematical Preliminaries
The Z-Transfer Function
Stability Analysis by Describing Functions
Encoder Multiple Choice Questions
Measurement and Instrumentation Objective Questions – Part 1
The inverse z-transform & Response of Linear Discrete Systems
Infrared Gas Analyzers Questions & Answers
Top 100 Power Plant Engineering Objective Questions & Answers
Time Response Analysis
Robotic Control System – Part I
Liapunov’s Stability Analysis
Direct Method & Constructing of Liapunov for the Linear & Non-Linear System
Fundamentals of Radiochemical Methods Questions
Diagonalization
Process Control Questions & Answers
X-Ray Diffractometers Questions & Answers
Digital Control Systems
Spectrum Analysis of Sampling Process
MOS Gas Sensor Principle
MOS Type Gas Sensor Principle
CNC Machining vs 3D Printer
CNC Machining vs 3D Printer – What is the difference?
How to set password in Siemens HMI
How to Password Protect HMI in Siemens TIA Portal?
Motor Operated Valve Problems and Troubleshooting
Magnetostrictive Level Transmitter Calibration
Magnetostrictive Level Transmitter Calibration Procedure
Bus Riser in Switchgear
Differential Pressure Transmitter with 5 Way Manifold Valve
