Siemens S7-200 PLC Questions and Answers
Suppose we have a Siemens S7-200 PLC connected to a pair of process switches and light bulbs as shown in this illustration:
Examine the following relay ladder logic (RLL) program for this Siemens PLC, determining the statuses of the two lamps provided the pressure switch sees a fluid pressure of 30 PSI and the level switch sees a liquid level of 4 feet:
Answer :
Green lamp is on, red lamp is off.
Share Your Answer / Comments
Credits : Tony R. Kuphaldt – under CC BY 1.0
For More PLC Questions : CLICK HERE
In the Relay Ladder Logic program, you have to show the second line L2 of the power supply, or else both lamps will be off whatever the status of the inputs.
