Reading: Power Electronics Interview Questions Part-1
Inst Tools > Blog > Electrical Q & A > Power Electronics Interview Questions Part-1
Last updated: September 11, 2016 6:49 am
Electrical Q & A
6 Min Read
Why thyristors are not preferred now a days for chopper fed DC drives?
Since it requires commutation circuit, thyristors are not preferred now a days for chopper fed DC drives. The commutation circuit is complex for chopper circuits.
What is function of a free wheeling diode in a phase controlled rectifier?
  1. Input power factor is improved
  2. Make the load current continuous
What causes poor input power factor in phase controlled DC drives?
The input power factor in the phase controlled rectifier is low when the output voltage is less than the maximum, that is when the firing angle is large. When the firing angle increases, the converter draws more lagging reactive power. So the input power is low.
What are the advantages of three-phase drives over single phase drives?
  1. Reducing the armature ripple current
  2. The filtering requirement is less
  3. Armature current is mostly continuous
  4. Motor performance is better
What are the various control strategies for varying duty cycle of the chopper
  1. Time Ratio Control (TRC)
  2. Current Limit Control (CLC)
What are the different methods of speed control of induction motors?
  1. Stator voltage control
  2. Supply frequency control
  3. Rotor resistance control
  4. Slip power recovery control
What are the advantages in operation of choppers at high frequency?
The operation at a high frequency improves motor performance by reducing current ripple and eliminating discontinuous conduction.
What is step angle in stepper motor?
Step angle is defined as the angle through which the stepper motor shaft rotates for each command pulse. It is denoted beta.
What is stepper motor?
A stepper motor is a digital actuator whose input is in the form of programmed energization of the stator windings and whose output is in the form of discrete angular rotation.
What is slewing in stepper motor?
A stepper motor operates at high speeds is called as slewing.
Define resolution in stepper motor?
It is defined as the number of steps needed to complete one revolution of the rotor shaft.
Resolution = No of steps/ Revolution
State some applications of stepper motor?
  • Floppy disk drives
  • Camera shutter operation
  • Machine tool application
  • Robotics
  • Dot matrix and line printers
  • Quartz watches
What are the advantages and disadvantages of the stepper motor?
Advantages
  1. It is mechanically simple.
  2. It requires less maintenance.
  3. It can be driven in open loop without feedback
  4. As it responds directly to digital control signals, stepper motors are natural choice for digital computer controls.
Disadvantages:
  1. Low efficiency with ordinary controller.
  2. Limited power output and sizes available
  3. Low efficiency with ordinary controller.
  4. Fixed step angle
What are the different types of stepping motors?
  • Variable reluctance stepper motor
  • Permanent magnet stepper motor
  • Hybrid stepper motor
What are the different modes of excitation in a stepper motor?
  • 1-Phase on or full-step operation
  • 2-phase on mode
  • Half step operation ( alternate 1-phase on and 2-phase on mode)
  • Micro stepping operation
What is meant by half-step operation?
It is the alternate one-phase on and 2-phase on mode operation.
Here, the rotor rotate an each angle is half of the full step angle.
What is meant by full-step operation?
  • It is one-phase on mode operation.
  • It means, at that time only one winding is energized.
  • By energizing one stator winding, the rotor rotates some angle.
  • It is the full-step operation.
What is meant by micro stepping in stepper motor?
  • Micro stepping means, the step angle of the VR stepper motor is very small.
  • It is also called mini-stepping.
  • It can be achieved by two phases simultaneously as in 2-phase on mode but with the two currents deliberately made unequal.
What is the main application of the micro stepping VR stepper motor?
  • The micro stepping is mainly used where very fine resolution is required.
  • The applications are printing and photo type setting.
  • A VR stepper motor with micro stepping provides very smooth low-speed operation and high-resolution.
What are the advantages and disadvantages of VR stepper motor?
Advantages:
  1. Low rotor inertia
  2. Less weight
  3. Freewheeling capability
  4. High stepping rate capability
  5. High torque to inertia ratio
Disadvantages
  1. Normally available in 3.6deg to 30 step angles
  2. No detente torque available with windings de-energized.
What is a multi-stack VR stepper motor?
Micro stepping of VR stepper motor can be achieved by using multistack VR stepper motor.
It has 3 separate magnetically isolated sections or stacks. Here the stator and rotor teeths are equal.
What are the advantages and disadvantages of permanent magnet stepper motor?
Advantages
  1. Requires low power
  2. High detente torque as compared to VR motor.
  3. Rotor do not require external exciting current.
  4. It produces more torque per ampere stator current.
Single Phase Induction Motors Questions and Answers
Induction Motor Interview Questions Answers
Industrial Automation and Control Interview Questions
High Voltage and Power System Stability Interview Questions
Protection Relays Interview Questions & Answers
Advantages & Disadvantages of Air Insulated Substation
Latest Transformers Questions and Answers
Basic Electrical Engineering Interview Questions Answers
Transformers Questions & Answers Part-4
Top Electrical Engineering Interview Questions for Freshers
Top 100 Switchgear and Protection Interview Questions
Electrical Motors Interview Question And Answers
Transformers Questions & Answers Part-2
Electrical Cables Interview Questions & Answers
transformers-questions-answers-part-1
Transformers Questions & Answers Part-1
Instrumentation Engineering Standards Interview Questions & Answers
Electrical Machines Objective Questions & Answers
Substation Interview Questions Answers
electrical-drives-questions-answers
Electrical Drives Questions & Answers
Basic Power Electronics Interview Questions
Problem on PLC, HMI, VFD, and Motor Circuit
Motor Star Delta Connections
displacer level transmitter cylindrical weighs
Displacer Level Transmitter 5-point Calibration
Y Strainer
What is a Y Strainer ?
BUS TIE REACTORS
Current Limiting Reactors in Power System
DP transmitter installation
Water and Steam Circuits in Power Plants
Choked Flow of Control Valve
Choked Flow of Control Valves
Failsafe interlock Design
Failsafe Wiring Practices
