Reading: pH Measurement Questions & Answers
Inst Tools > Blog > Multiple Choice Questions > pH Measurement Questions & Answers
Last updated: November 27, 2021 5:37 pm
1. Which of the following is the formula for pH calculation?
a) log10[H+].
b) -log10[H+].
c) log2[H+].
d) -log2[H+].
Answer: b
Explanation: pH is defined as the negative logarithm of hydrogen ion concentration. Hence, its formula is -log10[H+].
2. Pure water is known to be which of the following?
a) Weak electrolyte
b) Strong electrolyte
c) Neither weak nor strong
d) Not an electrolyte
Answer: a
Explanation: Pure water is a weak electrolyte. It dissociates to form hydrogen ions and hydroxyl ions.
3. Which of the following is the value of hydrogen ion concentration of pure water?
a) 1×107 moles/litre
b) 1×105 moles/litre
c) 1×106 moles/litre
d) 1×108 moles/litre
Answer: a
Explanation: The hydrogen ion concentration of pure water is 1×107 moles/litre. It can be represented as [H+]=1×107 moles/litre.
4. Which of the following is the value of hydroxyl ion concentration of pure water?
Answer: a
Explanation: The hydroxyl ion concentration of pure water is 1×107 moles/litre. It can be represented as [OH-]=1×107 moles/litre.
5. Which of the following is the relation between hydrogen and hydroxyl ion concentration of pure water?
a) Value of hydrogen ion concentration is greater
b) Value of hydroxyl ion concentration is greater
c) They are both always the same
d) The concentrations keep changing
Answer: c
Explanation: In water, the value of hydrogen and hydroxyl ion concentrations are the same. It can be represented as [H+]=[OH-].
6. The Nernst equation is given by which of the following statements?
a) E=Eo + 2.303 RT/F log CH
b) E=Eo – 2.303 RT/F log CH
c) E=Eo + 2.303 RT×F log CH
d) E=Eo – 2.303 RT×F log CH
Answer: a
Explanation: The Nernst equation is represented as, E=Eo + 2.303 RT/F log CH. it is used for measuring the potential of electrodes.
7. Which of the following is the relation between concentration of hydrogen and hydroxyl ions in an acidic solution?
Answer: a
Explanation: In acidic solution, the value of hydrogen ion concentration is greater than that of hydroxyl ion concentration. It can be represented as [H+]>[OH-].
8. Which of the following is the relation between concentration of hydrogen and hydroxyl ions in a basic solution?
Answer: b
Explanation: In basic solution, the value of hydroxyl ion concentration is greater than that of hydrogen ion concentration. It can be represented as [H+]<[OH-].
9. The measurement of hydrogen ion concentration can be made by measuring the potential developed in an electrochemical cell.
a) True
b) False
Answer: a
Explanation: The measurement of hydrogen ion concentration can be made by measuring the potential developed in an electrochemical cell.
10. Slope factor is independent of temperature.
a) True
b) False
Answer: b
Explanation: Slope factor is dependent on temperature. Slope factor is given by – 2.303 RT/F.
Digital Circuits Questions & Answers
Continuous Wave NMR Spectroscopy Questions & Answers
Programmable Logic Controllers Multiple Choice Questions
Measurement and Instrumentation Objective Questions – Part 2
Process Pressure Measurement Objective Questions
Quadrupole Mass Spectrometer
Nyquist Stability Criterion
Liapunov’s Stability Criterion – Part I
PID Controller Multiple Choice Questions
Design Considerations for Higher Order Systems
Ion Spectroscopy Questions & Answers
Flame Emission Photometers Questions & Answers
Parameter Optimization : Servomechanims
Root Locus in Control Systems
Signal Flow Graphs Objective Questions
Single Beam and Double Beam Instruments
Liapunov’s Stability Analysis
Liapunov’s Stability Criterion – Part II
Time Response Analysis
Time Response of Second Order Systems – IV
Induction Motor Interview Questions Answers
Electrical Measurements and Instrumentation Objective Questions & Answers
Nonlinear Control Systems
Liquid Chromatography Questions & Answers
Inductively Coupled Plasma Mass Spectrometer
X-Ray Fluorescence Spectrometry Questions and Answers
Omron CX programmer shift register
The Concept of Shift Register in Omron PLC with Example
Basics of Actuators
Basics of Actuators
Advanced Ladder Logic PLC Example
Automatic Sanitizer – Complex Ladder Logic PLC Examples
Difference Between Sensor and Transducer
What is the Difference Between Sensor and Transducer?
harmonics-disadvantages-in-power-system
Harmonics Disadvantages in Power System
Emergency Stop Push button
Thyristor Family Objective Questions and Answers
