Reading: Parallel Operation of Alternators
Inst Tools > Blog > Electrical Machines > Parallel Operation of Alternators
Last updated: April 25, 2016 3:58 pm
Electrical Machines
1 Min Read
Requirements of parallel operation of alternators:
The alternators which are to be operated in parallel should meet the following requirements so as to make the operation successful. Requirements are:
  • Two alternators or synchronous generators which are to be operated in parallel should have same output voltage rating
  • The rated speed of the machines which are operating in parallel should be such as to give the same frequency (f is equal to (PxN)/120)
  • The alternators should be of the same type so as to generate voltages of the same waveform. Generators operating can have different power rating (KVA rating)
  • The prime movers of the alternators should have same speed load characteristics, the nature of characteristics should be drooping so that load on the generator is proportional to output rating of the alternators
  • Without reactancce the alternators will not develop generating power and parallel operation would not be possible. Hence the alternators should have reactances in armature circuits, otherwise they will not operate in parallel
Faults in a Transformer
DC Motor Applications in Industries
What is a transformer tap changer?
Synchronous Generator Salient Pole vs Non Salient Pole
Types of Generators
Why rating of Synchronous Generators and Alternators in MVA or KVA
Metering Pumps
Difference between Star and Delta Connections
Induction Motor Operating Characteristics
BLDC Motor Vs AC Induction Motor
Advantages & Disadvantages Induction Motor
AC Motor Braking
Advantages & Disadvantages of Synchronous Motors
DC Motor Speed Control
Synchronous Motor Working Principle
Advantages of Hydrogen cooling in Synchronous Generators
Advantages and Disadvantages of Slip Ring Induction Motor
Squirrel Cage Induction Motor vs Slip Ring Induction Motor
Dead Time and Reclaim Time
What is Auto Reclosing?
Use of line reactors
Advantages & Disadvantages of Variable Speed Drives
Synchronous Motor Is Not Self Starting?
Single Phase Half-controlled Rectifier RL Load With FD
Phase-Controlled Half-Wave Rectifier With Freewheeling Diode
Schneider PLC Programming Example
Schneider PLC Programming Example for Beginners
Control Valves Leakage Classifications
PLC Instructions
Program Flow Control Instructions in PLC Programming
Strainer Principle
Backwashing
Analog Demodulators Objective Questions
Landline Telemetry Objective Questions
Gamp 5 Compliance in Pharmaceutical Industry
