NFPA standards from National Fire Protection Association provide guidelines for incorporating fire protection safety measures in industrial systems.
Classification of Fire and Hazard as per NFPA –
The National Fire Protection Association (NFPA) categorizes fires by class.
A fire can be classified among these classes – Class A, Class B, Class C, Class D and Class K.
In accordance with NFPA, areas are typically classified as being light (low) hazard, ordinary (moderate) hazard, or extra (high) hazard.
Fire Extinguishers – color codes and symbolic representation –
In accordance with NFPA 10 (2007 edition), the selection of fire extinguishers depends mainly on the following parameters:
- type and size of fire most likely to occur,
- present hazards in the area where the fire is most likely to occur,
- existence of electrical equipment in close proximity to the area where the fire will most probably occur,
- ambient temperature conditions,
- other conditions, such as human presence in the area where the fire is most likely to occur, whether the suspect area is ventilated or not etc.
Fire Hydrants –
In accordance with NFPA 25, a fire hydrant is a valved connection on a water main having as a purpose to supply water to various fire protection apparatus, fire hose or other.
There are four (4) major types of hydrants mainly in use nowadays:
- Dry Barrel type fire hydrant
- Monitor Nozzle fire hydrant
- Wall fire hydrant
- Wet barrel fire hydrant
Fire Fighting Pumps (centrifugal type) – In accordance with NFPA 20 (2007 edition), fire fighting pumps –
shall be specifically dedicated and listed for fire protection service. Electric motors, diesel engines or even steam turbines (for big pumps) are the acceptable drivers for fire fighting pumps.
A fire fighting pump set is selected typically from the following types of pumps:
– One (1) 100% motor-driven pump
– One (1) 100% diesel-driven pump for redundancy reasons
– One (1) jockey or make up pump, usually of vertical type. Jockey pumps are pressure maintenance pumps and their basic role is to cover the various pressure losses of fire fighting network.
Fire protection for power generation plants –
NFPA 850 provides recommendations (not requirements) for fire protection for fossil fueled (i.e. coal, gas or oil) or alternative fueled (i.e. biomass, solid waste etc) power generation plants.
Nuclear power plants or hydroelectric power plants are not covered by NFPA 850:
Nuclear power plants standards are addressed by NFPA 805, whereas recommendations for hydroelectric power plants are presented at NFPA 851.
List of Standards
| Standard | Name |
| NFPA 1 | Fire Code |
| NFPA 2 | Hydrogen Technologies Code |
| NFPA 3 | Recommended Practice for Commissioning of Fire Protection and Life Safety Systems |
| NFPA 4 | Standard for Integrated Fire Protection and Life Safety System Testing |
| NFPA 10 | Standard for Portable Fire Extinguishers |
| NFPA 11 | Standard for Low-, Medium-, and High-Expansion Foam |
| NFPA 11A | Standard for Medium- and High-Expansion Foam Systems |
| NFPA 11C | Standard for Mobile Foam Apparatus |
| NFPA 12 | Standard on Carbon Dioxide Extinguishing Systems |
| NFPA 12A | Standard on Halon 1301 Fire Extinguishing Systems |
| NFPA 13 | Standard for the Installation of Sprinkler Systems |
| NFPA 13D | Standard for the Installation of Sprinkler Systems in One- and Two-Family Dwellings and Manufactured Homes |
| NFPA 13E | Recommended Practice for Fire Department Operations in Properties Protected by Sprinkler and Standpipe Systems |
| NFPA 13R | Standard for the Installation of Sprinkler Systems in Low-Rise Residential Occupancies |
| NFPA 14 | Standard for the Installation of Standpipe and Hose Systems |
| NFPA 15 | Standard for Water Spray Fixed Systems for Fire Protection |
| NFPA 16 | Standard for the Installation of Foam-Water Sprinkler and Foam-Water Spray Systems |
| NFPA 17 | Standard for Dry Chemical Extinguishing Systems |
| NFPA 17A | Standard for Wet Chemical Extinguishing Systems |
| NFPA 18 | Standard on Wetting Agents |
| NFPA 18A | Standard on Water Additives for Fire Control and Vapor Mitigation |
| NFPA 20 | Standard for the Installation of Stationary Pumps for Fire Protection |
| NFPA 22 | Standard for Water Tanks for Private Fire Protection |
| NFPA 24 | Standard for the Installation of Private Fire Service Mains and Their Appurtenances |
| NFPA 25 | Standard for the Inspection, Testing, and Maintenance of Water-Based Fire Protection Systems |
| NFPA 30 | Flammable and Combustible Liquids Code |
| NFPA 30A | Code for Motor Fuel Dispensing Facilities and Repair Garages |
| NFPA 30B | Code for the Manufacture and Storage of Aerosol Products |
| NFPA 31 | Standard for the Installation of Oil-Burning Equipment |
| NFPA 32 | Standard for Drycleaning Facilities |
| NFPA 33 | Standard for Spray Application Using Flammable or Combustible Materials |
| NFPA 34 | Standard for Dipping, Coating, and Printing Processes Using Flammable or Combustible Liquids |
| NFPA 35 | Standard for the Manufacture of Organic Coatings |
| NFPA 36 | Standard for Solvent Extraction Plants |
| NFPA 37 | Standard for the Installation and Use of Stationary Combustion Engines and Gas Turbines |
| NFPA 40 | Standard for the Storage and Handling of Cellulose Nitrate Film |
| NFPA 42 | Code for the Storage of Pyroxylin Plastic |
| NFPA 45 | Standard on Fire Protection for Laboratories Using Chemicals |
| NFPA 46 | Recommended Safe Practice for Storage of Forest Products |
| NFPA 50 | Standard for Bulk Oxygen Systems at Consumer Sites |
| NFPA 50A | Standard for Gaseous Hydrogen Systems at Consumer Sites |
| NFPA 50B | Standard for Liquefied Hydrogen Systems at Consumer Sites |
| NFPA 51 | Standard for the Design and Installation of Oxygen-Fuel Gas Systems for Welding, Cutting, and Allied Processes |
| NFPA 51A | Standard for Acetylene Cylinder Charging Plants |
| NFPA 51B | Standard for Fire Prevention During Welding, Cutting, and Other Hot Work |
| NFPA 52 | Vehicular Natural Gas Fuel Systems Code |
| NFPA 53 | Recommended Practice on Materials, Equipment, and Systems Used in Oxygen-Enriched Atmospheres |
| NFPA 54 | National Fuel Gas Code |
| NFPA 55 | Compressed Gases and Cryogenic Fluids Code |
| NFPA 56 | Standard for Fire and Explosion Prevention During Cleaning and Purging of Flammable Gas Piping Systems |
| NFPA 57 | Liquefied Natural Gas (LNG) Vehicular Fuel Systems Code |
| NFPA 58 | Liquefied Petroleum Gas Code |
| NFPA 59 | Utility LP-Gas Plant Code |
| NFPA 59A | Standard for the Production, Storage, and Handling of Liquefied Natural Gas (LNG) |
| NFPA 61 | Standard for the Prevention of Fires and Dust Explosions in Agricultural and Food Processing Facilities |
| NFPA 67 | Guide on Explosion Protection for Gaseous Mixtures in Pipe Systems |
| NFPA 68 | Standard on Explosion Protection by Deflagration Venting |
| NFPA 69 | Standard on Explosion Prevention Systems |
| NFPA 70 | National Electrical Code® |
| NFPA 70A | National Electrical Code® Requirements for One- and Two-Family Dwellings |
| NFPA 70B | Recommended Practice for Electrical Equipment Maintenance |
| NFPA 70E | Standard for Electrical Safety in the Workplace® |
| NFPA 72 | National Fire Alarm and Signaling Code |
| NFPA 73 | Standard for Electrical Inspections for Existing Dwellings |
| NFPA 75 | Standard for the Fire Protection of Information Technology Equipment |
| NFPA 76 | Standard for the Fire Protection of Telecommunications Facilities |
| NFPA 77 | Recommended Practice on Static Electricity |
| NFPA 79 | Electrical Standard for Industrial Machinery |
| NFPA 80 | Standard for Fire Doors and Other Opening Protectives |
| NFPA 80A | Recommended Practice for Protection of Buildings from Exterior Fire Exposures |
| NFPA 82 | Standard on Incinerators and Waste and Linen Handling Systems and Equipment |
| NFPA 85 | Boiler and Combustion Systems Hazards Code |
| NFPA 86 | Standard for Ovens and Furnaces |
| NFPA 86C | Standard for Industrial Furnaces Using a Special Processing Atmosphere |
| NFPA 86D | Standard for Industrial Furnaces Using Vacuum as an Atmosphere |
| NFPA 87 | Recommended Practice for Fluid Heaters |
| NFPA 88A | Standard for Parking Structures |
| NFPA 88B | Standard for Repair Garages |
| NFPA 90A | Standard for the Installation of Air-Conditioning and Ventilating Systems |
| NFPA 90B | Standard for the Installation of Warm Air Heating and Air-Conditioning Systems |
| NFPA 91 | Standard for Exhaust Systems for Air Conveying of Vapors, Gases, Mists, and Particulate Solids |
| NFPA 92 | Standard for Smoke Control Systems |
| NFPA 92A | Standard for Smoke-Control Systems Utilizing Barriers and Pressure Differences |
| NFPA 92B | Standard for Smoke Management Systems in Malls, Atria, and Large Spaces |
| NFPA 96 | Standard for Ventilation Control and Fire Protection of Commercial Cooking Operations |
| NFPA 97 | Standard Glossary of Terms Relating to Chimneys, Vents, and Heat-Producing Appliances |
| NFPA 99 | Health Care Facilities Code |
| NFPA 99B | Standard for Hypobaric Facilities |
| NFPA 101 | Life Safety Code® |
| NFPA 101A | Guide on Alternative Approaches to Life Safety |
| NFPA 101B | Code for Means of Egress for Buildings and Structures |
| NFPA 102 | Standard for Grandstands, Folding and Telescopic Seating, Tents, and Membrane Structures |
| NFPA 105 | Standard for Smoke Door Assemblies and Other Opening Protectives |
| NFPA 110 | Standard for Emergency and Standby Power Systems |
| NFPA 111 | Standard on Stored Electrical Energy Emergency and Standby Power Systems |
| NFPA 115 | Standard for Laser Fire Protection |
| NFPA 120 | Standard for Fire Prevention and Control in Coal Mines |
| NFPA 121 | Standard on Fire Protection for Self-Propelled and Mobile Surface Mining Equipment |
| NFPA 122 | Standard for Fire Prevention and Control in Metal/Nonmetal Mining and Metal Mineral Processing Facilities |
| NFPA 123 | Standard for Fire Prevention and Control in Underground Bituminous Coal Mines |
| NFPA 130 | Standard for Fixed Guideway Transit and Passenger Rail Systems |
| NFPA 140 | Standard on Motion Picture and Television Production Studio Soundstages, Approved Production Facilities, and Production Locations |
| NFPA 150 | Standard on Fire and Life Safety in Animal Housing Facilities |
| NFPA 160 | Standard for the Use of Flame Effects Before an Audience |
| NFPA 170 | Standard for Fire Safety and Emergency Symbols |
| NFPA 203 | Guide on Roof Coverings and Roof Deck Constructions |
| NFPA 204 | Standard for Smoke and Heat Venting |
| NFPA 211 | Standard for Chimneys, Fireplaces, Vents, and Solid Fuel-Burning Appliances |
| NFPA 214 | Standard on Water-Cooling Towers |
| NFPA 220 | Standard on Types of Building Construction |
| NFPA 221 | Standard for High Challenge Fire Walls, Fire Walls, and Fire Barrier Walls |
| NFPA 225 | Model Manufactured Home Installation Standard |
| NFPA 230 | Standard for the Fire Protection of Storage |
| NFPA 231 | Standard for General Storage |
| NFPA 231C | Standard for Rack Storage of Materials |
| NFPA 231D | Standard for Storage of Rubber Tires |
| NFPA 231E | Recommended Practice for the Storage of Baled Cotton |
| NFPA 231F | Standard for the Storage of Roll Paper |
| NFPA 232 | Standard for the Protection of Records |
| NFPA 232A | Guide for Fire Protection for Archives and Records Centers |
| NFPA 241 | Standard for Safeguarding Construction, Alteration, and Demolition Operations |
| NFPA 251 | Standard Methods of Tests of Fire Resistance of Building Construction and Materials |
| NFPA 252 | Standard Methods of Fire Tests of Door Assemblies |
| NFPA 253 | Standard Method of Test for Critical Radiant Flux of Floor Covering Systems Using a Radiant Heat Energy Source |
| NFPA 255 | Standard Method of Test of Surface Burning Characteristics of Building Materials |
| NFPA 256 | Standard Methods of Fire Tests of Roof Coverings |
| NFPA 257 | Standard on Fire Test for Window and Glass Block Assemblies |
| NFPA 258 | Recommended Practice for Determining Smoke Generation of Solid Materials |
| NFPA 259 | Standard Test Method for Potential Heat of Building Materials |
| NFPA 260 | Standard Methods of Tests and Classification System for Cigarette Ignition Resistance of Components of Upholstered Furniture |
| NFPA 261 | Standard Method of Test for Determining Resistance of Mock-Up Upholstered Furniture Material Assemblies to Ignition by Smoldering Cigarettes |
| NFPA 262 | Standard Method of Test for Flame Travel and Smoke of Wires and Cables for Use in Air-Handling Spaces |
| NFPA 265 | Standard Methods of Fire Tests for Evaluating Room Fire Growth Contribution of Textile or Expanded Vinyl Wall Coverings on Full Height Panels and Walls |
| NFPA 266 | Standard Method of Test for Fire Characteristics of Upholstered Furniture Exposed to Flaming Ignition Source |
| NFPA 267 | Standard Method of Test for Fire Characteristics of Mattresses and Bedding Assemblies Exposed to Flaming Ignition Source |
| NFPA 268 | Standard Test Method for Determining Ignitability of Exterior Wall Assemblies Using a Radiant Heat Energy Source |
| NFPA 269 | Standard Test Method for Developing Toxic Potency Data for Use in Fire Hazard Modeling |
| NFPA 270 | Standard Test Method for Measurement of Smoke Obscuration Using a Conical Radiant Source in a Single Closed Chamber |
| NFPA 271 | Standard Method of Test for Heat and Visible Smoke Release Rates for Materials and Products Using an Oxygen Consumption Calorimeter |
| NFPA 272 | Standard Method of Test for Heat and Visible Smoke Release Rates for Upholstered Furniture Components or Composites and Mattresses Using an Oxygen Consumption Calorimeter |
| NFPA 274 | Standard Test Method to Evaluate Fire Performance Characteristics of Pipe Insulation |
| NFPA 275 | Standard Method of Fire Tests for the Evaluation of Thermal Barriers |
| NFPA 276 | Standard Method of Fire Test for Determining the Heat Release Rate of Roofing Assemblies with Combustible Above-Deck Roofing Components |
| NFPA 277 | Standard Methods of Tests for Evaluating Fire and Ignition Resistance of Upholstered Furniture Using a Flaming Ignition Source |
| NFPA 284 | Standard Test Method for Mattresses for Correctional Occupancies |
| NFPA 285 | Standard Fire Test Method for Evaluation of Fire Propagation Characteristics of Exterior Non-Load-Bearing Wall Assemblies Containing Combustible Components |
| NFPA 286 | Standard Methods of Fire Tests for Evaluating Contribution of Wall and Ceiling Interior Finish to Room Fire Growth |
| NFPA 287 | Standard Test Methods for Measurement of Flammability of Materials in Cleanrooms Using a Fire Propagation Apparatus (FPA) |
| NFPA 288 | Standard Methods of Fire Tests of Horizontal Fire Door Assemblies Installed in Horizontal Fire Resistance-Rated Assemblies |
| NFPA 289 | Standard Method of Fire Test for Individual Fuel Packages |
| NFPA 290 | Standard for Fire Testing of Passive Protection Materials for Use on LP-Gas Containers |
| NFPA 291 | Recommended Practice for Fire Flow Testing and Marking of Hydrants |
| NFPA 295 | Standard for Wildfire Control |
| NFPA 297 | Guide on Principles and Practices for Communications Systems |
| NFPA 298 | Standard on Foam Chemicals for Wildland Fire Control |
| NFPA 299 | Standard for Protection of Life and Property from Wildfire |
| NFPA 301 | Code for Safety to Life from Fire on Merchant Vessels |
| NFPA 302 | Fire Protection Standard for Pleasure and Commercial Motor Craft |
| NFPA 303 | Fire Protection Standard for Marinas and Boatyards |
| NFPA 306 | Standard for the Control of Gas Hazards on Vessels |
| NFPA 307 | Standard for the Construction and Fire Protection of Marine Terminals, Piers, and Wharves |
| NFPA 312 | Standard for Fire Protection of Vessels During Construction, Conversion, Repair, and Lay-Up |
| NFPA 318 | Standard for the Protection of Semiconductor Fabrication Facilities |
| NFPA 326 | Standard for the Safeguarding of Tanks and Containers for Entry, Cleaning, or Repair |
| NFPA 328 | Recommended Practice for the Control of Flammable and Combustible Liquids and Gases in Manholes, Sewers, and Similar Underground Structures |
| NFPA 329 | Recommended Practice for Handling Releases of Flammable and Combustible Liquids and Gases |
| NFPA 350 | Guide for Safe Confined Space Entry and Work |
| NFPA 385 | Standard for Tank Vehicles for Flammable and Combustible Liquids |
| NFPA 386 | Standard for Portable Shipping Tanks for Flammable and Combustible Liquids |
| NFPA 395 | Standard for the Storage of Flammable and Combustible Liquids at Farms and Isolated Sites |
| NFPA 400 | Hazardous Materials Code |
| NFPA 402 | Guide for Aircraft Rescue and Fire-Fighting Operations |
| NFPA 403 | Standard for Aircraft Rescue and Fire-Fighting Services at Airports |
| NFPA 405 | Standard for the Recurring Proficiency of Airport Fire Fighters |
| NFPA 407 | Standard for Aircraft Fuel Servicing |
| NFPA 408 | Standard for Aircraft Hand Portable Fire Extinguishers |
| NFPA 409 | Standard on Aircraft Hangars |
| NFPA 410 | Standard on Aircraft Maintenance |
| NFPA 412 | Standard for Evaluating Aircraft Rescue and Fire-Fighting Foam Equipment |
| NFPA 414 | Standard for Aircraft Rescue and Fire-Fighting Vehicles |
| NFPA 415 | Standard on Airport Terminal Buildings, Fueling Ramp Drainage, and Loading Walkways |
| NFPA 418 | Standard for Heliports |
| NFPA 422 | Guide for Aircraft Accident/Incident Response Assessment |
| NFPA 423 | Standard for Construction and Protection of Aircraft Engine Test Facilities |
| NFPA 424 | Guide for Airport/Community Emergency Planning |
| NFPA 430 | Code for the Storage of Liquid and Solid Oxidizers |
| NFPA 432 | Code for the Storage of Organic Peroxide Formulations |
| NFPA 434 | Code for the Storage of Pesticides |
| NFPA 450 | Guide for Emergency Medical Services and Systems |
| NFPA 451 | Guide for Fire Based Community Healthcare Providers |
| NFPA 471 | Recommended Practice for Responding to Hazardous Materials Incidents |
| NFPA 472 | Standard for Competence of Responders to Hazardous Materials/Weapons of Mass Destruction Incidents |
| NFPA 473 | Standard for Competencies for EMS Personnel Responding to Hazardous Materials/Weapons of Mass Destruction Incidents |
| NFPA 475 | Recommended Practice for Organizing, Managing, and Sustaining a Hazardous Materials/Weapons of Mass Destruction Response Program |
| NFPA 480 | Standard for the Storage, Handling, and Processing of Magnesium Solids and Powders |
| NFPA 481 | Standard for the Production, Processing, Handling, and Storage of Titanium |
| NFPA 482 | Standard for the Production, Processing, Handling, and Storage of Zirconium |
| NFPA 484 | Standard for Combustible Metals |
| NFPA 485 | Standard for the Storage, Handling, Processing, and Use of Lithium Metal |
| NFPA 490 | Code for the Storage of Ammonium Nitrate |
| NFPA 495 | Explosive Materials Code |
| NFPA 496 | Standard for Purged and Pressurized Enclosures for Electrical Equipment |
| NFPA 497 | Recommended Practice for the Classification of Flammable Liquids, Gases, or Vapors and of Hazardous (Classified) Locations for Electrical Installations in Chemical Process Areas |
| NFPA 498 | Standard for Safe Havens and Interchange Lots for Vehicles Transporting Explosives |
| NFPA 499 | Recommended Practice for the Classification of Combustible Dusts and of Hazardous (Classified) Locations for Electrical Installations in Chemical Process Areas |
| NFPA 501 | Standard on Manufactured Housing |
| NFPA 501A | Standard for Fire Safety Criteria for Manufactured Home Installations, Sites, and Communities |
| NFPA 502 | Standard for Road Tunnels, Bridges, and Other Limited Access Highways |
| NFPA 505 | Fire Safety Standard for Powered Industrial Trucks Including Type Designations, Areas of Use, Conversions, Maintenance, and Operations |
| NFPA 513 | Standard for Motor Freight Terminals |
| NFPA 520 | Standard on Subterranean Spaces |
| NFPA 550 | Guide to the Fire Safety Concepts Tree |
| NFPA 551 | Guide for the Evaluation of Fire Risk Assessments |
| NFPA 555 | Guide on Methods for Evaluating Potential for Room Flashover |
| NFPA 556 | Guide on Methods for Evaluating Fire Hazard to Occupants of Passenger Road Vehicles |
| NFPA 557 | Standard for Determination of Fire Loads for Use in Structural Fire Protection Design |
| NFPA 560 | Standard for the Storage, Handling, and Use of Ethylene Oxide for Sterilization and Fumigation |
| NFPA 600 | Standard on Facility Fire Brigades |
| NFPA 601 | Standard for Security Services in Fire Loss Prevention |
| NFPA 610 | Guide for Emergency and Safety Operations at Motorsports Venues |
| NFPA 650 | Standard for Pneumatic Conveying Systems for Handling Combustible Particulate Solids |
| NFPA 651 | Standard for the Machining and Finishing of Aluminum and the Production and Handling of Aluminum Powders |
| NFPA 652 | Standard on the Fundamentals of Combustible Dust |
| NFPA 654 | Standard for the Prevention of Fire and Dust Explosions from the Manufacturing, Processing, and Handling of Combustible Particulate Solids |
| NFPA 655 | Standard for Prevention of Sulfur Fires and Explosions |
| NFPA 664 | Standard for the Prevention of Fires and Explosions in Wood Processing and Woodworking Facilities |
| NFPA 701 | Standard Methods of Fire Tests for Flame Propagation of Textiles and Films |
| NFPA 703 | Standard for Fire Retardant—Treated Wood and Fire–Retardant Coatings for Building Materials |
| NFPA 704 | Standard System for the Identification of the Hazards of Materials for Emergency Response |
| NFPA 705 | Recommended Practice for a Field Flame Test for Textiles and Films |
| NFPA 720 | Standard for the Installation of Carbon Monoxide(CO) Detection and Warning Equipment |
| NFPA 730 | Guide for Premises Security |
| NFPA 731 | Standard for the Installation of Electronic Premises Security Systems |
| NFPA 750 | Standard on Water Mist Fire Protection Systems |
| NFPA 770 | Standard on Hybrid (Water and Inert Gas) Fire Extinguishing Systems |
| NFPA 780 | Standard for the Installation of Lightning Protection Systems |
| NFPA 790 | Standard for Competency of Third-Party Field Evaluation Bodies |
| NFPA 791 | Recommended Practice and Procedures for Unlabeled Electrical Equipment Evaluation |
| NFPA 801 | Standard for Fire Protection for Facilities Handling Radioactive Materials |
| NFPA 803 | Standard for Fire Protection for Light Water Nuclear Power Plants |
| NFPA 804 | Standard for Fire Protection for Advanced Light Water Reactor Electric Generating Plants |
| NFPA 805 | Performance-Based Standard for Fire Protection for Light Water Reactor Electric Generating Plants |
| NFPA 806 | Performance-Based Standard for Fire Protection for Advanced Nuclear Reactor Electric Generating Plants Change Process |
| NFPA 820 | Standard for Fire Protection in Wastewater Treatment and Collection Facilities |
| NFPA 850 | Recommended Practice for Fire Protection for Electric Generating Plants and High Voltage Direct Current Converter Stations |
| NFPA 851 | Recommended Practice for Fire Protection for Hydroelectric Generating Plants |
| NFPA 853 | Standard for the Installation of Stationary Fuel Cell Power Systems |
| NFPA 855 | Standard for the Installation of Stationary Energy Storage Systems |
| NFPA 900 | Building Energy Code |
| NFPA 901 | Standard Classifications for Incident Reporting and Fire Protection Data |
| NFPA 902 | Fire Reporting Field Incident Guide |
| NFPA 903 | Fire Reporting Property Survey Guide |
| NFPA 904 | Incident Follow-up Report Guide |
| NFPA 906 | Guide for Fire Incident Field Notes |
| NFPA 909 | Code for the Protection of Cultural Resource Properties – Museums, Libraries, and Places of Worship |
| NFPA 914 | Code for Fire Protection of Historic Structures |
| NFPA 921 | Guide for Fire and Explosion Investigations |
| NFPA 950 | Standard for Data Development and Exchange for the Fire Service |
| NFPA 951 | Guide to Building and Utilizing Digital Information |
| NFPA 1000 | Standard for Fire Service Professional Qualifications Accreditation and Certification Systems |
| NFPA 1001 | Standard for Fire Fighter Professional Qualifications |
| NFPA 1002 | Standard for Fire Apparatus Driver/Operator Professional Qualifications |
| NFPA 1003 | Standard for Airport Fire Fighter Professional Qualifications |
| NFPA 1005 | Standard for Professional Qualifications for Marine Fire Fighting for Land-Based Fire Fighters |
| NFPA 1006 | Standard for Technical Rescue Personnel Professional Qualifications |
| NFPA 1021 | Standard for Fire Officer Professional Qualifications |
| NFPA 1026 | Standard for Incident Management Personnel Professional Qualifications |
| NFPA 1031 | Standard for Professional Qualifications for Fire Inspector and Plan Examiner |
| NFPA 1033 | Standard for Professional Qualifications for Fire Investigator |
| NFPA 1035 | Standard on Fire and Life Safety Educator, Public Information Officer, Youth Firesetter Intervention Specialist and Youth Firesetter Program Manager Professional Qualifications |
| NFPA 1037 | Standard on Fire Marshal Professional Qualifications |
| NFPA 1041 | Standard for Fire Service Instructor Professional Qualifications |
| NFPA 1051 | Standard for Wildland Firefighting Personnel Professional Qualifications |
| NFPA 1061 | Professional Qualifications for Public Safety Telecommunications Personnel |
| NFPA 1071 | Standard for Emergency Vehicle Technician Professional Qualifications |
| NFPA 1072 | Standard for Hazardous Materials/Weapons of Mass Destruction Emergency Response Personnel Professional Qualifications |
| NFPA 1081 | Standard for Industrial Fire Brigade Member Professional Qualifications |
| NFPA 1082 | Standard for Facilities Safety Director Professional Qualifications |
| NFPA 1091 | Standard for Traffic Control Incident Management Professional Qualifications |
| NFPA 1122 | Code for Model Rocketry |
| NFPA 1123 | Code for Fireworks Display |
| NFPA 1124 | Code for the Manufacture, Transportation, and Storage of Fireworks and Pyrotechnic Articles |
| NFPA 1125 | Code for the Manufacture of Model Rocket and High-Power Rocket Motors |
| NFPA 1126 | Standard for the Use of Pyrotechnics Before a Proximate Audience |
| NFPA 1127 | Code for High Power Rocketry |
| PYR 1128 | Standard Method of Fire Test for Flame Breaks |
| PYR 1129 | Standard Method of Fire Test for Covered Fuse on Consumer Fireworks |
| NFPA 1141 | Standard for Fire Protection Infrastructure for Land Development in Wildland, Rural, and Suburban Areas |
| NFPA 1142 | Standard on Water Supplies for Suburban and Rural Fire Fighting |
| NFPA 1143 | Standard for Wildland Fire Management |
| NFPA 1144 | Standard for Reducing Structure Ignition Hazards from Wildland Fire |
| NFPA 1145 | Guide for the Use of Class A Foams in Fire Fighting |
| NFPA 1150 | Standard on Foam Chemicals for Fires in Class A Fuels |
| NFPA 1192 | Standard on Recreational Vehicles |
| NFPA 1194 | Standard for Recreational Vehicle Parks and Campgrounds |
| NFPA 1201 | Standard for Providing Fire and Emergency Services to the Public |
| NFPA 1221 | Standard for the Installation, Maintenance, and Use of Emergency Services Communications Systems |
| NFPA 1231 | Standard on Water Supplies for Suburban and Rural Fire Fighting |
| NFPA 1250 | Recommended Practice in Fire and Emergency Service Organization Risk Management |
| NFPA 1300 | Standard on Community Risk Assessment and Community Risk Reduction Plan Development |
| NFPA 1401 | Recommended Practice for Fire Service Training Reports and Records |
| NFPA 1402 | Guide to Building Fire Service Training Centers |
| NFPA 1403 | Standard on Live Fire Training Evolutions |
| NFPA 1404 | Standard for Fire Service Respiratory Protection Training |
| NFPA 1405 | Guide for Land-Based Fire Departments that Respond to Marine Vessel Fires |
| NFPA 1407 | Standard for Training Fire Service Rapid Intervention Crews |
| NFPA 1408 | Standard for Training Fire Service Personnel in the Operation, Care, Use, and Maintenance of Thermal Imagers |
| NFPA 1410 | Standard on Training for Emergency Scene Operations |
| NFPA 1451 | Standard for a Fire and Emergency Service Vehicle Operations Training Program |
| NFPA 1452 | Guide for Training Fire Service Personnel to Conduct Community Risk Reduction |
| NFPA 1500 | Standard on Fire Department Occupational Safety and Health Program |
| NFPA 1521 | Standard for Fire Department Safety Officer Professional Qualifications |
| NFPA 1561 | Standard on Emergency Services Incident Management System and Command Safety |
| NFPA 1581 | Standard on Fire Department Infection Control Program |
| NFPA 1582 | Standard on Comprehensive Occupational Medical Program for Fire Departments |
| NFPA 1583 | Standard on Health-Related Fitness Programs for Fire Department Members |
| NFPA 1584 | Standard on the Rehabilitation Process for Members During Emergency Operations and Training Exercises |
| NFPA 1600 | Standard on Disaster/Emergency Management and Business Continuity/Continuity of Operations Programs |
| NFPA 1616 | Standard on Mass Evacuation, Sheltering, and Re-entry Programs |
| NFPA 1620 | Standard for Pre-Incident Planning |
| NFPA 1670 | Standard on Operations and Training for Technical Search and Rescue Incidents |
| NFPA 1700 | Guide for Structural Fire Fighting |
| NFPA 1710 | Standard for the Organization and Deployment of Fire Suppression Operations, Emergency Medical Operations, and Special Operations to the Public by Career Fire Departments |
| NFPA 1720 | Standard for the Organization and Deployment of Fire Suppression Operations, Emergency Medical Operations and Special Operations to the Public by Volunteer Fire Departments |
| NFPA 1730 | Standard on Organization and Deployment of Fire Prevention Inspection and Code Enforcement, Plan Review, Investigation, and Public Education Operations |
| NFPA 1800 | Standard on Electronic Safety Equipment for Emergency Services |
| NFPA 1801 | Standard on Thermal Imagers for the Fire Service |
| NFPA 1802 | Standard on Personal Portable (Hand-Held) Two-Way Radio Communications Devices for Use by Emergency Services Personnel in the Hazard Zone |
| NFPA 1851 | Standard on Selection, Care, and Maintenance of Protective Ensembles for Structural Fire Fighting and Proximity Fire Fighting |
| NFPA 1852 | Standard on Selection, Care, and Maintenance of Open-Circuit Self-Contained Breathing Apparatus (SCBA) |
| NFPA 1855 | Standard for Selection, Care, and Maintenance of Protective Ensembles for Technical Rescue Incidents |
| NFPA 1858 | Standard on Selection, Care, and Maintenance of Life Safety Rope and Equipment for Emergency Services |
| NFPA 1859 | Standard on Selection, Care and Maintenance of Tactical Operations Video Equipment |
| NFPA 1877 | Standard on Selection, Care, and Maintenance of Wildland Fire Fighting Clothing and Equipment |
| NFPA 1891 | Standard on Selection, Care, and Maintenance of Hazardous Materials Clothing and Equipment |
| NFPA 1901 | Standard for Automotive Fire Apparatus |
| NFPA 1906 | Standard for Wildland Fire Apparatus |
| NFPA 1911 | Standard for the Inspection, Maintenance, Testing, and Retirement of In-Service Emergency Vehicles |
| NFPA 1912 | Standard for Fire Apparatus Refurbishing |
| NFPA 1914 | Standard for Testing Fire Department Aerial Devices |
| NFPA 1915 | Standard for Fire Apparatus Preventive Maintenance Program |
| NFPA 1917 | Standard for Automotive Ambulances |
| NFPA 1925 | Standard on Marine Fire-Fighting Vessels |
| NFPA 1931 | Standard for Manufacturer’s Design of Fire Department Ground Ladders |
| NFPA 1932 | Standard on Use, Maintenance, and Service Testing of In-Service Fire Department Ground Ladders |
| NFPA 1936 | Standard on Powered Rescue Tools |
| NFPA 1937 | Standard for the Selection, Care, and Maintenance of Rescue Tools |
| NFPA 1951 | Standard on Protective Ensembles for Technical Rescue Incidents |
| NFPA 1952 | Standard on Surface Water Operations Protective Clothing and Equipment |
| NFPA 1953 | Standard on Protective Ensembles for Contaminated Water Diving |
| NFPA 1961 | Standard on Fire Hose |
| NFPA 1962 | Standard for the Care, Use, Inspection, Service Testing, and Replacement of Fire Hose, Couplings, Nozzles, and Fire Hose Appliances |
| NFPA 1963 | Standard for Fire Hose Connections |
| NFPA 1964 | Standard for Spray Nozzles |
| NFPA 1965 | Standard for Fire Hose Appliances |
| NFPA 1971 | Standard on Protective Ensembles for Structural Fire Fighting and Proximity Fire Fighting |
| NFPA 1975 | Standard on Emergency Services Work Clothing Elements |
| NFPA 1976 | Standard on Protective Ensemble for Proximity Fire Fighting |
| NFPA 1977 | Standard on Protective Clothing and Equipment for Wildland Fire Fighting |
| NFPA 1981 | Standard on Open-Circuit Self-Contained Breathing Apparatus (SCBA) for Emergency Services |
| NFPA 1982 | Standard on Personal Alert Safety Systems (PASS) |
| NFPA 1983 | Standard on Life Safety Rope and Equipment for Emergency Services |
| NFPA 1984 | Standard on Respirators for Wildland Fire Fighting Operations |
| NFPA 1986 | Standard on Respiratory Protection Equipment for Tactical and Technical Operations |
| NFPA 1987 | Standard on Combination Unit Respirator Systems for Tactical and Technical Operations |
| NFPA 1989 | Standard on Breathing Air Quality for Emergency Services Respiratory Protection |
| NFPA 1991 | Standard on Vapor-Protective Ensembles for Hazardous Materials Emergencies |
| NFPA 1992 | Standard on Liquid Splash-Protective Ensembles and Clothing for Hazardous Materials Emergencies |
| NFPA 1994 | Standard on Protective Ensembles for First Responders to CBRN Terrorism Incidents |
| NFPA 1999 | Standard on Protective Clothing and Ensembles for Emergency Medical Operations |
| NFPA 2001 | Standard on Clean Agent Fire Extinguishing Systems |
| NFPA 2010 | Standard for Fixed Aerosol Fire-Extinguishing Systems |
| NFPA 2112 | Standard on Flame-Resistant Garments for Protection of Industrial Personnel Against Flash Fire |
| NFPA 2113 | Standard on Selection, Care, Use, and Maintenance of Flame-Resistant Garments for Protection of Industrial Personnel Against Short-Duration Thermal Exposures |
| NFPA 2400 | Standard for Small Unmanned Aircraft Systems (sUAS) used for Public Safety Operations |
| NFPA 3000 | Standard for Preparedness and Response to Active Shooter and/or Hostile Events |
| NFPA 5000 | Building Construction and Safety Code® |
| NFPA 8501 | Standard for Single Burner Boiler Operation |
| NFPA 8502 | Standard for the Prevention of Furnace Explosions/Implosions in Multiple Burner Boilers |
| NFPA 8503 | Standard for Pulverized Fuel Systems |
| NFPA 8504 | Standard on Atmospheric Fluidized-Bed Boiler Operation |
| NFPA 8505 | Standard for Stoker Operation |
| NFPA 8506 | Standard on Heat Recovery Steam Generator Systems |
