Reading: Motor STAR – DELTA Starter Working Principle
Inst Tools > Blog > Electrical Basics > Motor STAR – DELTA Starter Working Principle
Motor STAR – DELTA Starter Working principle. A Dual starter connects the motor terminals directly to the power supply. Hence, the motor is subjected to the full voltage of the power supply. Consequently, high starting current flows through the motor.
Last updated: November 1, 2023 3:39 pm
Electrical Basics
5 Comments
Reduced Voltage StartersStar / Delta StartersHow does Motor Star-Delta Starter work?
Consequently, a high starting current flows through the motor. This type of starting is suitable for small motors below 5 hp (3.75 kW).
Reduced-voltage starters are employed with motors above 5 hp. Dual motor starters are available for motors less than 150 KW on 400 V and for motors less than 1 MW on 6.6 kV.
Supply reliability and reserve power generation dictate the use of reduced voltage or not to reduce the starting current of an induction motor, the voltage across the motor needs to be reduced.
This can be done by
  1. Autotransformer starter,
  2. Star-delta starter or
  3. Resistor starter.
Nowadays VVVF drive (VFD) used extensively for speed control serves this purpose also.
In a dual starter, the motor is directly fed from the line and in a star-delta starter then motor is started initially from the star and later during running from the delta. This is a starting method that reduces the starting current and starting torque.
The Motor must be delta-connected during a normal run, in order to be able to use this starting method.
The received starting current is about 30 % of the starting current during direct online start and the starting torque is reduced to about 25 % of the torque available at a D.O.L start.
Star/Delta starters are probably the most common reduced voltage starters in the 50Hz world. (Known as Wye/Delta starters in the 60Hz world). They are used in an attempt to reduce the start current applied to the motor during start as a means of reducing the disturbances and interference on the electrical supply.
Component: The Star/Delta starter is manufactured from three contactors, a timer, and a thermal overload. The contactors are smaller than the single contactor used in a Direct on Line starter as they control winding currents only.
The currents through the winding are 1√3 = 0.58 (58%) of the current in the line. this connection amounts to approximately 30% of the delta values. The starting current is reduced to one-third of the direct starting current.
There are two contactors that are close during the run, often referred to as the main contactor and the delta contactor. These are AC3 rated at 58% of the current rating of the motor.
The third contactor is the star contactor only carries star current while the motor is connected in star. The current in star is one-third of the current in delta, so this contactor can be AC3 rated at one-third of the motor rating.
In operation, the Main Contactor (KM3) and the Star Contactor (KM1) are closed initially, and then after a period of time, the star contactor is opened, and then the delta contactor (KM2) is closed.
The control of the contactors is by the timer (K1T) built into the starter. The Star and Delta are electrically interlocked and preferably mechanically interlocked as well.
In effect, there are four states:
  1. OFF State: All Contactors are open
  2. Star State: The Main and the Star contactors are closed and the delta contactor is open. The motor is connected in star and will produce one-third of DOL torque at one-third of DOL current.
  3. Open State: The Main contactor is closed and the Delta and Star contactors are open. There is voltage on one end of the motor windings, but the other end is open so no current can flow. The motor has a spinning rotor and behaves like a generator.
  4. Delta State: The Main and the Delta contactors are closed. The Star contactor is open. The motor is connected to full line voltage and full power and torque are available.
This type of operation is called open transition switching because there is an open state between the star state and the delta state.
Motor STAR - DELTA Working principle
Also Read: Variable Frequency Drive Working Principle
Electrical Power Grid Automation
One Nation One Grid One Frequency – Electrical Engineering
Difference Between Permittivity and Permeability
What is a Buchholz Relay? Working Principle
Motor VFD Drive features
Electrical Cabinet Air Conditioner – Enclosure Cooling, Maintenance
5 Comments
  • XYZ says:
    November 10, 2017 at 10:39 am
    Thanks for your wonderful site sir.It will be very useful.But,please provide the working principle of all the Equipments like Instruments,Electrical,Electronics,etc in automation.It will be more easy to understand practically.Expecting your work asap.
  • sam says:
    March 4, 2021 at 2:47 pm
    good diagram but no explanatin on how the circuit is controllled
  • Mohammed saeed dowelbite says:
    March 12, 2022 at 10:51 pm
    thank u for info & good explain circuits power and control
  • Ammar says:
    March 13, 2022 at 6:44 pm
    Great article and good website.
    Kindly we need article explains control panel building and design and wiring
    Regards
  • maseresha kumela says:
    December 8, 2023 at 8:48 pm
    IT is explanation of controlling cercute bast for all
What is an ELV System? – Extra Low Voltage
Electrical Motor Terms and Concepts
How does a Lead Acid Battery Work?
Difference Between AA and AAA Batteries
Dahlander Motors – Principle, Advantages, Disadvantages
Why Three-phase Voltage is 440 Volts?
Ground Fault Versus Short Circuit
Difference Between Short Circuit and Ground Fault
Floating Neutral - Electrical Engineering Basics
What is Floating Neutral? – Electrical Engineering Basics
Motor Disconnector Switch
What is a Motor Disconnector Switch? – Purpose, Principle, Factors
Why Circuit Breakers Don't Protect People?
Why Circuit Breakers Don’t Protect People?
Motor Maintenance
Motor Maintenance, Troubles, Regular Checks, Performance
LBB protection relay
What is the LBB Protection Relay? (Local Breaker Backup)
Inverse Time Circuit Breaker
What are Inverse Time and Instantaneous Trip Circuit Breakers?
Why Are Neutral and Earth Separated
Why Are Neutral and Earth Separated?
PID parameters
PID in Siemens TIA Portal
PLC Program using Bitwise Instructions
Allen Bradley Bitwise Logical Operations
User Defined Data Types - UDT
User Defined Data Types (UDT) – Purpose, Need, Tutorial
Microprocessors Objective Questions – Set 4
Reactor Top lid lapped
Urea Reactor Top Bolted Plug developed Leaks
Eddy Current
Eddy Current Working Principle Animation
Magnetically coupled float indicates liquid level
What are Mechanical Level Indicators? – Classification & Principle
