Reading: Logic Families Questions and Answers
Inst Tools > Blog > Multiple Choice Questions > Logic Families Questions and Answers
Last updated: November 27, 2021 5:36 pm
1. Which of the following is the most widely employed logic family?
a) Emitter-coupled logic
b) Transistor-transistor logic
c) CMOS logic family
d) NMOS logic
Answer: b
Explanation: Transistor-transistor logic is the most widely employed logic family. It is the most popular logic family.
2. The basic function of TTL gate is which of the following functions?
a) AND
b) OR
c) NOR
d) NAND
Answer: d
Explanation: The basic function of TTL gate is NAND function. It is the most popular logic family.
3. In TTL logic, the input transistor has a number of ________ equal to the desired fan-in of the circuit.
a) Base
b) Collect
c) Emitter
d) Gate
Answer: c
Explanation: In TTL logic, the input transistor has a number of emitter equal to the desired fan-in of the circuit. This is a major advantage.
4. Which of the following is the propagation delay of TTL circuits?
a) 1 s
b) 1 ms
c) 1 ns
d) 1 ps
Answer: c
Explanation: The propagation delay of TTL circuit is 1 ns. It is a main characteristic of TTL circuit.
5. The standard TTL gates are marketed as _______ series.
a) 80
b) 82
c) 74
d) 08
Answer: c
Explanation: The standard TTL gates are marketed as 74 series. They can operate up to 700C.
6. Schottky TTL logic family does not have which of the following features?
a) Good fan-in
b) Good fan-out
c) High speed capability
d) High propagation delay
Answer: d
Explanation: Schottky TTL circuits have reduced propagation delay than normal TTL circuits. The propagation delay of 10ns is very high for some applications.
7. The logic ‘0’ of ECL is represented as ______V and logic ‘1’ is represented as ______V.
a) 1, 1.65
b) 0.9, 1.75
c) 1.2, 2.35
d) 1.9, 4.3
Answer: b
Explanation: The logic ‘0’ of ECL is represented as 0.9 V and logic ‘1’ is represented as 1.75 V. ECL stands for emitter-coupled logic.
8. ECL is a way of achieving higher speed of gate.
a) True
b) False
Answer: a
Explanation: We can achieve high speed of gate by sing ECL. ECL stands for emitter-coupled logic.
9. Which of the following is not the advantage of MOS gates?
a) Low power dissipation
b) Small size
c) Good immunity to noise
d) High switching speeds
Answer: d
Explanation: MOS gates do not have high switching speed. They have limited switching capability.
10. CMOS gates are commercially available as which of the following series?
a) 1000
b) 2000
c) 3000
d) 4000
Answer: d
Explanation: CMOS gates are commercially available as 4000 series. This technique is most suitable for commercial circuits.
11. The switching of MOS gates can be improved by using CMOS.
a) True
b) False
View Answer
Answer: a
Explanation: The switching of MOS gates can be improved by using CMOS. CMOS stands for complementary MOS. It is an inverter.
Electrical Measurements and Instrumentation Objective Questions & Answers
Instrumentation of ESR Spectrometer
Control Loop Multiple Choice Questions
Time of Flight Mass Spectrometer
Flame Emission Photometers Questions & Answers
Radiation Detectors Questions & Answers
Total Reflection Spectrometer Questions & Answers
Liapunov’s Stability Criterion – Part II
Paramagnetic Oxygen Analyzers Questions & Answers
Direct Method & Constructing of Liapunov for the Linear & Non-Linear System
The inverse z-transform & Response of Linear Discrete Systems
Gamma Camera Questions & Answers
Frequency Response MCQ
Experimentation of Transfer Function
IR Instrumentation Questions & Answers
Solution of State Equations
Bipolar Junction Transistors Questions & Answers
Measurement and Instrumentation Objective Questions – Part 1
Instrumentation Diagrams Multiple Choice Questions
Objective Questions of Building Fire and Gas Detectors
Top 1000 Analytical Instrumentation Questions & Answers
Linear Programming in Excel
How to Do Linear Programming in Excel?
Dall Tube Flow Meter Working Principle
Dall Tube Flow Meter – Principle, Advantages, Disadvantages
Magnetic Flow Meter Liner Damaged
Magnetic Flow Meter Liner Damaged and Winding Burnt
Compressor Coolers
Calculate the 0%, 50%, and 100% Calibration Points
Metal Foil Strain Gauge Principle
Function Module in Siemens PLC
What is Function Module in Siemens PLC?
Erratic Stroking Control Valves
Erratic Stroking Control Valves Delaying the Shutdown Plant Restart
