Reading: 6.6kV HV Induction motor Protection
Inst Tools > Blog > Electrical Machines > 6.6kV HV Induction motor Protection
Last updated: April 24, 2016 6:25 pm
Electrical Machines
2 Min Read
HV 6.6kV Induction motor Protection
For HV motors rated 6.6kV and above motor over current, stalled rotor, and short circuit protections shall be provided by three 3-element relays mounted on the medium voltage switchgear
Over-current protection:
The inverse time over-current element shall be set to operate at 110 to 115% of the rated full load current, to initiate a common motor overload alarm and individual display light in the control system
Stalled rotor protection:
The low set instantaneous over-current element shall be set to trip the motor at 170 to 180% of the full load current and is wired in series with a contact on the inverse time element. The time setting of the inverse time over-current element shall be below the safe operating time at rated locked rotor current for a particular motor, but shall allow a minimum two-second margin over calculated starting time under minimum voltage condition
Short Circuit Protection:
The high set instantaneous element shall be set up to trip motor at slightly above the asymmetrical value of the motor inrush current. This can be usually be achieved by setting of 160% to 175% of the locked rotor current
Ground fault protection:
Automatic tripping on detection of ground fault current shall be provided by a sensitive instantaneous over-current relay.
Differential protection:
Motors rated 2500hp and above sensitive protection against internal phase and ground faults shall be provided by three phase, self balancing differential relay. This relay shall be mounted on the switchgear and connected to three CT’s mounted in the motor terminal box
Bearing protection:
HV motors shall be provided with dual element, standard accuracy bearing thermocouples, continuously monitored to alert the operators of high bearing temperature
Advantages & Disadvantages of Variable Speed Drives
What happen When Synchronous Generator loss Excitation
Star to Delta and Delta to Star Conversion Formula
Electrical Motor Starter Circuits
Basics of AC Induction Motors
Types of Transformers
Squirrel Cage Induction Motor vs Slip Ring Induction Motor
Induction Motor Operating Characteristics
What is Auto Reclosing?
Synchronous Motor Starting Methods
DC Motor Applications in Industries
Advantages of Hydrogen cooling in Synchronous Generators
Applications of Synchronous Motors
Advantages & Disadvantages of Synchronous Motors
Distribution transformer
Different Types of Transformers
Losses of Transformer
Metering pumps
Metering Pumps
Stepper Motor Construction
Stepper Motor Basics, Types, Modes, Wiring, Questions
Zigzag Transformers Theory
Off load Tap Changer Principle
Transformer Tap Changing Working Principle
Why rating of Synchronous Generators and Alternators in MVA or KVA
Studio 5000 Logix Emulate
Simulation of Studio 5000 and FactoryTalk View Studio
Current-to-Pressure Transducer Calibration Table
Digital Image Processing Projects - DIP Project Ideas
600+ Digital Image Processing Projects – DIP Project Ideas
PLC Program for Automatic Heating and Mixing of Products
Heating and Mixing of Products using PLC Example Tutorial
Chemical Reactor Vessel P and ID
Questions on Chemical Reactor Vessel P & ID
Basic Instrumentation Test
PID Controllers Multiple Choice Questions
PID Controller Multiple Choice Questions
Interview Questions on Electronics and Instrumentation
