Reading: Harmonics effect on Induction Motor
Inst Tools > Blog > Power Systems > Harmonics effect on Induction Motor
Last updated: September 20, 2016 2:10 pm
Power Systems
2 Min Read
Harmonics in the power system are generated due to the usage of non linear load. Some of the effects  of harmonics on the performance of  induction machine are:
  • Core losses in the Induction machine increases
  • Torque of the Induction motor reduces
  • Increase in the Skin effect
  • Damage of the induction motor insulation
  • Electromagnetic Interference
  • Deviation in the induction motor Torque-Speed curves
Increase in Core Loss:
Core loss in any machine machine constitutes both hysteresis loss and eddy current loss. Hysteresis loss of the induction machine is proportional to the applied frequency and eddy current loss is proportional to the frequency squared. Frequency of the harmonics will be in the  order of the multiples of the fundamental frequency. Therefore core loss is major concern at higher frequencies due to harmonics. Also harmonic currents and voltages reduces the overall efficiency of the machine
Increase in Skin effect:
Increase in the harmonics frequency results in increase in skin effect tending the current to flow on the surface of the conductor. Skin effect contributes the loss in the form of resistance to the flow of current
Electromagnetic Interference:
Harmonics increase the Electromagnetic Interference(EMI). This EMI does not affect the motor, however it affects the operation of nearby electronics, control and communication circuits
Reduced Motor Torque:
Fundamental frequency of the induction motor produces forward operating torque. However it is observed that harmonics frequency will generate torque in both forward and in reverse direction. For example 5th 7th and 11th harmonics produce torques in reverse direction and on the other hand 7th, 13th and 19th harmonics components produces torque in forward direction.5th harmonic components will have higher magnitude compared to 7th harmonics. Hence harmonics torque will reduce the operating torque of the machine
Deviation from Torque-Speed Characteristics:
Losses which occur due to Harmonics will cause the deviation in the torque speed characteristics of the motor from original and affects the performance of the motor
Harmonics Disadvantages in Power System
Underground Cable Fault Identification Methods
Why Reactive Power is Generated at Load
Silicon Carbide Lightning Arresters Working Principle
Why Symmetrical Components Used for Unbalanced faults in Power System
Neutral Grounding Practice in Power System
Electrical Power System Protection Quiz
Rotor Angle Stability of Synchronous Generators in Power System
Voltage Variations Effects on Power Plant Equipment
Auto Recloser Circuit Breaker in Power System
Ungrounded or Isolated Neutral System Disadvantages
Shunt Capacitor Advantages in Power System
Advantages & Disadvantages of AC power and DC power
Advantages and Disadvantages of Per Unit System
Transformer Tap changer
Reactive Power Sources and Sinks in Power System
current-limiting-reactors-and-short-circuit-currents
Current Limiting Reactors and Short Circuit Currents
Shunt Vs Series Capacitors Advantages
Corona-Ring-on-Surge-Arresters
harmonics-effect-on-transformer
Harmonics effect on Transformer
Lithium-ion Battery Charging System
Lithium-ion Battery Charging Systems
Programmable Read Only Memory Objective Questions – Part 1
Recurring Short Circuit Flash Overs Safety Hazards
Recurring Short Circuit Flash Overs Safety Hazards & Damages
how-to-select-a-fuse
How to Select a Fuse ?
PLC Conveyor Forward and Reverse Logic
Advanced PLC Conveyor Control: Forward and Reverse Rotation
PLC Program to Drain Same Products from Two Tanks
Programming with Schneider PLC
Mail Box Automation: Programming with Schneider PLC
Differential Pressure Transmitters Static Pressure
What is Static Pressure Limit in DP Transmitter ?
