Reading: Feedforward Control Questions and Answers
Inst Tools > Blog > Instrumentation MCQ > Feedforward Control Questions and Answers
Last updated: June 21, 2025 10:09 am
Instrumentation MCQ Multiple Choice Questions
2 Min Read
Feedforward Control Questions & Answers
1. The feedback control system:
a. Cannot make corrections until a measurable error exists
b. Makes a change in output which is the differentiated error
c. Is always superior to a feedforward system in operation
d. Is theoretically capable of perfect control
Answer: a
2. The feedforward control system:
b. Makes a change in output that is the integrated error
c. Requires little knowledge of the process before installation
Answer: d
3. The original boiler drum level application of feedforward control, developed in 1925:
a. Is still being applied everyday
b. Was abandoned because of poor measuring techniques
c. Worked well only with the particular boiler for which it was originally designed
d. Was immediately recognized as the ultimate control system
Answer: a
4. A properly designed feedforward control system:
a. Should be applied to every process
b. Should be employed when its use can be justified economically and technologically
c. Is always easier to adjust than a feedback system
d. Will always result in more economical process operation
Answer: b
5. The most dramatic application of feedforward techniques has occurred in their application to:
a. Heat exchangers
b. Level processes
c. Flow processes
d. Distillation columns
Answer: d
Feedback Compensation
Servo Operated Manometer Objective Questions
Mass Spectrometer Questions & Answers
Total Reflection Spectrometer Questions & Answers
Construction of Phase -Trajectories
Ion Spectroscopy Questions & Answers
Approximation of Higher-Order Systems by Lower Order
Digital Circuits Questions & Answers
250+ Electronic Measurements and Instrumentation MCQ Questions
Recording Systems Objective Questions
Fluidic Systems Objective Questions
Solenoid Valve Terminology Questions and Answers
Measurements & Instrumentation Quiz – Set 6
Controllability & Observability
Instrumentation Documents
Instrument Document Quiz
DC Circuits Multiple Choice Questions
Liquid Scintillation Counters Questions & Answers
Open Loop and Closed Loop System Questions
DC Power Supplies Objective Questions
X-Ray Fluorescence Spectrometry Questions and Answers
Dissolved Oxygen Analyzer Questions and Answers
Fiber Optic Measurement Techniques
Fiber Optic Measurement Multiple Choice Questions (MCQ)
reverse-biased varactor diode
Varactor Diode Operation
Silicon Controlled Rectifier Commutation Quiz
Rotor Angle Stability of Synchronous Generators in Power System
What is Gear Run Out
What is Gear Run Out ?
Diagram of Oscillator Circuit
Barkhausen Criterion
Inter Discipline Check (IDC)
What is Inter Discipline Check (IDC)?
Codesys function block example
Create a User-Defined Function Block in Codesys
Calculate Amount of Weight Indicated by the Scale
