Reading: Electrical Voltage and current Signals
Inst Tools > Blog > Electrical Basics > Electrical Voltage and current Signals
Last updated: September 18, 2016 2:27 am
Electrical Basics
Voltage and current levels in electrical engineering is very important. As any electrical system, equipment, devices all are characterized by their different voltage and current levels.
Voltage levels in Electrical system
Two types of voltage levels-
1. Nominal Voltage levels
  • Rated voltage designated for a system or equipment.
  • Rated voltage referring to some operating characteristics.
Say for a single phase motor the designated voltage is 220 volt as it is connected to a phase and a neutral; for a three phase motor which is
connected to three phases the designated voltage is 400V.
Now say for a protection system to be active, the energizing voltage has to be maintained within 10V to 20V DC- this is an operating characteristics. So 10V, 20V is also a nominal voltage levels.
2. Highest voltage level
  • Voltage by consideration of the insulation.
  • Highest voltage defined by the manufacturer or recommended by the manufacturer.
Electrical system insulation designed as per the voltage. So the highest voltage level will be the voltage which the system insulation can sustain.
Also the manufacturer defines some voltage restrictions for a certain electrical system or equipment. These all are highest voltage levels. Say an electrical system insulation highest voltage level is 11KV, but the connected electrical equipment highest voltage level is 5KV, as recommended by the manufacturer.
Some important concept to understand current levelsmcb
The definition of Circuit Breaker: A circuit breaker is an electrical device that is capable of break or make current in both the normal or abnormal (faulty) condition.
Make current: is closing the circuit breaker or establishing a connection. While closing the breaker there is high instantaneous non-linear current appears for short duration and the electrical system or equipment has to sustain this.
Break current is opening the circuit breaker or dis-engaging an electrical connection. This breaking current might be for normal operation or might be for abnormal/ faulty condition. While breaking current there is some time delay and the electrical system or equipment have to withstand high value of fault current during this short time.
If there is delay in breaking a connection while a fault occurred, the circuit breaker contacts might become welded by arc and large amount of heat.
Current levels in Electrical system
1. Rated current levels
– R.M.S value of a current that the electrical system or equipment can carry continuously. This is a normal operating current.
2. Rated short time withstand current
RMS value of a current that an electrical system or equipment can carry in closed position for a specified short duration such as 1s or 3s.
3. Rated peak withstand current
First major loop of the rated short time withstand current which an electrical system or equipment can carry in closed position.
For high voltage system rated peak withstand current is 2.5 times of rated short time withstand current.
For low voltage system rated peak with stand current is 1.5 to 2 times of rated short time withstand current.
4. Rated short circuit breaking current
rms value of maximum symmetrical short-circuit current in KA, which a circuit breaker shall be capable of breaking.
There are two values included in the rated short circuit breaking current-
  • RMS value of the ac component.
  • The percentage of DC component.
5.Rated short circuit making current
The maximum peak current the circuit breaker shall be able to close and latch again. This peak value is related to the RMS value of the rated short circuit breaking current, frequency and time constant.
As per ANSI/IEEE rated short circuit making current is also referred to as closing and latching capability.
Some specified value of rated short circuit breaking current are
If Rated short circuit making current=Ism and rated short circuit breaking current=Isb
  • Ism=2.5*Isb, At 50Hz and t=45 ms,
  • Ism=-2.6*Isb, at 60Hz, t=45ms.
  • Ism=-2.7*Isb, at both 50Hz and 60Hz, t=45ms.
Difference Between MCB and MCCB
Difference between Power Cables and Signal Cables
How to Locate Faults in Cables? – Fault Analysis & Location
Totally Enclosed Fan Cooled (TEFC) Motors Rampant Winding Burnouts
Corona Discharge in Power Transmission Lines
Motor Control Timer Circuit – Automatic Motor START and STOP
Pros and Cons of Soft Starter
Motor Protection Circuits
Difference Between Single Core and Multi-Core Cables
How Do Air Compressor Filters Clean and Protect the System?
What is an Intelligent Motor Control Center? – IMCC
Testing of Thermal Protection Relay for Motors
Single Phase versus Three Phase Power
Phase Failure Relay
Why is Phase Failure Relay Required in LV Panels?
Difference Between Circuit Breaker and Disconnector
Induction Motor Operation
Induction Motor Over and Under Voltage Problems
Difference between Single-phase and three-phase power supply
Difference between Single-phase and Three-phase Power
Working of Stepper Motor
Types of Stepper Motors
Semiconductor Fuse
What is a Semiconductor Fuse?
Preventive Maintenance of Variable Frequency Drive
Types of Industrial Storage Batteries
Applications of CNC Machining
Important Applications of Rapid Prototype CNC Machining Services
Use Cryptographic checks for PLC
#5 PLC Best Practices – Cryptographic and Checksum Integrity Checks
Pressure Transmitters Filled impulse lines
Simatic Prosave HMI
How to Backup and Restore from Simatic Prosave HMI?
Node-RED in PLC Automation
Control System Basic Wiring Practice Animation
PLC Connection between Instrument, Junction Box, Marshalling & System Cabinet
Swirl Flowmeters Principle
Swirl Flow Meters Working Principle
Ammonia Gas Detector Calibration
Ammonia Gas Detector Working Principle and Calibration
