Explore the top 300 Digital Signal Processing projects. DSP project with innovative ideas and technologies for students and professionals.
Digital Signal Processing Projects
| S.No. | DSP Projects |
| 1 | Frequency-Domain Equalization for Optical Communication Systems |
| 2 | Medical Image Retrieval Using Pattern Similarity Scheme |
| 3 | Adaptive Directional Wavelet Transform via Pre-filtering |
| 4 | Accelerated Consensus via Optimal Filter Design in Signal Processing on Random Graphs |
| 5 | Image Segmentation with Information Bottleneck Method |
| 6 | Multi-Resolution Analysis for Efficient Image and Video Compression |
| 7 | Delay-Less Sub-Band Adaptive Filtering Algorithm for Active Noise Cancellation |
| 8 | Extended Kalman Filtering for MIMO-OFDM Channel Estimation |
| 9 | Active Constellation Extension Algorithm in OFDM Peak-to-Average Ratio Reduction |
| 10 | Dominant Objective Contextual Multi-Armed Bandit in Multi-Objective Scenarios |
| 11 | Signal Detection and Separation via Windowed State-Space Filters |
| 12 | 3D Sound Localization Using Sparse Array Processing |
| 13 | Sliced Ridgelet Transform for Enhanced Image De-noising |
| 14 | Budget-Constrained Low-Rank Subspace Tracking for Large-Scale Kernel-Based Feature Extraction |
| 15 | Reversible Watermarking Expansion Embedding Techniques |
| 16 | Uplink Scheduling Fractional Programming in Communication Systems |
| 17 | Confidence Interval Based Hierarchical Clustering for Metric Distances |
| 18 | Filter Banks for Graph Signal Subgraph Structuring |
| 19 | Convex Variational Inference for Associating Multiple Scan Data |
| 20 | DWT Modeling for Human Vision Interpolation Phenomenon via Piecewise Lifting Scheme |
| 21 | MISO Wireless Network Beamforming for Physical Layer Security Optimization |
| 22 | Enhanced Visual Cryptography for Secured Secret Hiding |
| 23 | Downlink BER Simulation in IEEE 802.16e OFDM Physical Layer |
| 24 | Variable Step-Size Affine Projection for Acoustic Echo Cancellation |
| 25 | Robust Watermarking with Blind Self-Authentication via Integer Wavelet Transform |
| 26 | Empirical Mode Decomposition for ECG Signal De-noising and Baseline Wander Correction |
| 27 | Morphological Processing Techniques for Color Images |
| 28 | Decentralized Joint Precoding with Pilot-Aided Techniques |
| 29 | Manifold Separation Application in Parametric Localization of Distributed Sources |
| 30 | Multi-Sensor Medical Image Fusion at Pixel Level Analysis |
| 31 | Robust Speech Recognition via Deep Learning in Noisy Environments |
| 32 | Enhanced Quantizer Design for Uniform Planar Array FD-MIMO Systems |
| 33 | Massive MIMO Channel Non-Reciprocity Estimation and Mitigation |
| 34 | Training Amount Optimization in Correlated Massive MIMO Channels |
| 35 | Energy-Efficient DSP Techniques for Prolonged Battery Life in Mobile Devices |
| 36 | Natural Image Blind and Semi-Blind De-blurring |
| 37 | ADMM in Big Data Processing Based on Multileader Multifollower Game Theory |
| 38 | Post-Processing of Low Bit Rate Block DCT Coded Images with Fields of Experts Prior |
| 39 | Non-Linear Predictive Coding for High-Quality Music Streaming |
| 40 | Power-Efficient Coexistence Approach for MIMO Radar and Cellular Systems |
| 41 | Sensor Network Localization System’s Attack Detection with Quantized Data |
| 42 | Multi-layer Sparse Approximations in Flexible Matrix Structures |
| 43 | Secrecy Constraints Oriented Optimal Parameter Encoding with ECRB |
| 44 | Stochastic Amplitude Flow for Random Quadratic Equation Solvers |
| 45 | K-Means Clustering for Image Classification |
| 46 | System Tracking with Graph-Structured Inputs for Efficient Adaptive Equalization |
| 47 | Stochastic Sensor Selection and Field Reconstruction in Heterogeneous Sensor Networks |
| 48 | Adaptive Filter Design for Echo Cancellation in VoIP |
| 49 | Distributed Linear Estimation Amidst Observation Model Uncertainties |
| 50 | Compressed Sensing for Efficient Wireless Sensor Networks |
| 51 | Fuzzy Clustering Algorithm for Abnormal MR Image Segmentation |
| 52 | Coarray-Based MUSIC Performance in Sensor Location Error Scenarios |
| 53 | Realistic Color Image Retrieval in Content-Based Systems |
| 54 | Nonlinear Image Enhancement for Aerial Imagery via Automatic Wavelet Techniques |
| 55 | Optimal Resource Allocation for Multicarrier Communication Systems |
| 56 | Sparse Representation and Dictionary Learning for Image Super-Resolution |
| 57 | Hybrid Analog-Digital Beamforming for Spectrum Sharing Networks |
| 58 | Coexistence Strategy Design for Joint MIMO Radar and Communication Systems |
| 59 | Dual Trace Discrete Wavelet Packet Image and Video De-noising |
| 60 | MRI Brain Tumor Detection via Effective Fuzzy C-Means Clustering |
| 61 | Electromyogram Based Japanese Janken Recognition using Support Vector Machine |
| 62 | Robust Adaptive Filtering with Generalized Correntropy |
| 63 | ROF Method Implementation for Image De-noising |
| 64 | Multi-Band Signal Reconstruction from Sub-Nyquist Samples |
| 65 | High-Parallelism, Low-Complexity Preprocessing Algorithm for K-Best MIMO System Detection |
| 66 | Dynamic Texture Analysis in Video Using Higher Order SVD |
| 67 | Cell Camera Image Blur Reduction via Adaptive Tonal Correction |
| 68 | Multisubject Complex Valued FMRI Data Analysis with Adaptive Fixed-point IVA Algorithm |
| 69 | Pareto Optimality Based Beam Design and User Scheduling in Nonorthogonal Multiple Access |
| 70 | Optimized Solutions for High-Dimensional MVDR Beamforming Based on Spiked Models |
| 71 | Discrimination of Speech/Music for Radio Station Analysis |
| 72 | Tree-Based Parity Check in Optimal Data Hiding Schemes |
| 73 | Scalable Video Coding for Multi-Platform Distribution |
| 74 | Dual-Linear Equalizer for Enhanced MIMO Systems |
| 75 | Low-Latency Video Streaming Optimization Over Wireless Networks |
| 76 | Multimodal Sentiment Analysis from Audio-Visual Data |
| 77 | Perceptual Audio Coding with Integer Modified Discrete Cosine Transform |
| 78 | Biometric Identification Using Gait Analysis and Deep Learning |
| 79 | Matching Pursuit Subspace Rejection in Unresolved Target Environments |
| 80 | Iterative Multi-User Detection in CDMA System Channel Estimation Performance Analysis |
| 81 | Lattice Basis Reduction Design for Finite Wordlength FIR Filters |
| 82 | Retrieving Images through Both Color and Texture Features |
| 83 | Optimizing Joint Transmit and Receive Filters for Sub-Nyquist Estimation |
| 84 | Techniques for Asymptotic Confidence in Structured High-Dimensional Sparsity |
| 85 | MIMO Radar Waveform Design in Multiple Target Scenarios |
| 86 | Dynamic, Decidable Dataflow for Signal Processing on Diverse Platforms |
| 87 | Spectral Efficiency Enhancement with Wavelets in Digital Communication Systems |
| 88 | Exploring the Null Space of Nonsparse and Canonical-Sparse Blind Deconvolution |
| 89 | Angular Estimation for Incoherently Distributed Sources via Generalized Shift Invariance |
| 90 | Image Watermarking with Robust Scaling and Maximum-Likelihood Decoding |
| 91 | Phase-Aware Speech Enhancement in Time-Frequency Domain |
| 92 | Fingerprint Detail Enhancement Using Short-Time Fourier Transform Analysis |
| 93 | Efficient Robust RFI Extraction with Sparse Recovery Techniques |
| 94 | High-Capacity Architecture for List Successive Cancellation Polar Code Decoders |
| 95 | Time-Frequency Analysis for Detecting Microsleep Events |
| 96 | Sub-Nyquist Sampling Enhancement with Intentional Aliasing Method |
| 97 | Low Power Motion Estimation via Variable Block Size Pixel Truncation |
| 98 | Robust Kalman Filtering for GPS Signal Tracking |
| 99 | Massive Connectivity in Sparse Activity Detection |
| 100 | Active Learning Influence on Acoustic Model Changes in Speech Recognition |
| 101 | Modified SPIHT-Based Natural Image Compression |
| 102 | Conditionally Linear Gaussian Model Particle Smoothing via Message Passing |
| 103 | Extrinsic Probabilities Utilization in Non-Bayesian Cramér–Rao Bounds Computation for Signal Processing |
| 104 | Graph-Based Semi-Supervised Learning for Image Segmentation |
| 105 | Spatio-Temporal Function Inference over Graphs with Multikernel Kalman Filtering |
| 106 | Adaptive Bilateral Filter for Image Sharpness Enhancement and Noise Reduction |
| 107 | Full Rank Regularization in MMSE Detection for Multi-User CDMA Systems |
| 108 | Eigenvalue Decomposition in Parahermitian Matrices: Existence and Uniqueness Insights |
| 109 | Quality of Service-Oriented Linear Transceiver Design for Full-Duplex Communications |
| 110 | Audio Scene Classification Using Machine Learning Techniques |
| 111 | Stochastic Models for Adaptive Noise Cancellation in Hearing Aids |
| 112 | Cramer–Rao Bounds and Algorithms for Quantized Spectral Compressed Sensing |
| 113 | Kernel Induced Distance Measure for Robust Image Segmentation using Fuzzy Clustering |
| 114 | Double Talk Tolerant Acoustic Echo Cancellation Algorithm |
| 115 | Voice Activity Detection via Spectrum Energy Analysis |
| 116 | Noisy Speech Enhancement Based on Warped DCT |
| 117 | Wavelet Transform Techniques for Texture Analysis and Recognition |
| 118 | Asynchronous Stochastic Dual Descent for Network Resource Allocation |
| 119 | Multi-Layer Perceptron for RF Fingerprinting in Cognitive Radio Networks |
| 120 | Potential of Data Transmission with Advanced Large Intelligent Surfaces |
| 121 | Rapid Channel Estimation Algorithm for Sensor Networks |
| 122 | Noisy, Quantized and Erroneous Measurement Recovery in Low-Rank Matrix |
| 123 | Accelerated LMS/Newton Methods for Stereophonic Acoustic Echo Cancellation |
| 124 | Graph-Based Lifting Transform Optimization for Enhanced Update/Prediction |
| 125 | Fingerprint Recognition Using Ridge Thinning Method |
| 126 | Image Enhancement through Quadratic Programming |
| 127 | Optimized Algorithms for Max and Min Filters in Random Input Analysis |
| 128 | Pattern Recognition in Non-Invasive Brain Signals for Neuroprosthetics |
| 129 | Hierarchical Clustering for Image Retrieval in Large Databases |
| 130 | Linear Pre-coding Technique in Cellular Relay Network Multiuser Environment |
| 131 | Distributed Beamforming for Enhanced Wireless Network Performance |
| 132 | Palm Print Authentication System Employing Wavelets |
| 133 | Non-Overlapping Pilot Signals Based Adaptive OFDMA/TDMA Uplink Channel Estimation and Prediction |
| 134 | Image Coding with Curved Wavelet Transform |
| 135 | Function Evaluation Techniques for Efficient Wideband DOA Estimation |
| 136 | Weighted Adaptive Wavelet Transform for Enhanced Image Coding |
| 137 | Dual-Polarized Antenna Array Signal Processing for 5G Communications |
| 138 | Adaptive DS-CDMA Receiver Code Tracking in Phase Unknown Environments |
| 139 | SISO Volterra Filter in Ultraharmonic Ultrasound Echo Signal Modeling |
| 140 | Adaptive Fuzzy Filtering for Composed Image and Video Artifact Reduction |
| 141 | Signal Processing Architecture for FMCW Radar with Active Backscatter Tags |
| 142 | Optimal Sequential Fusion Estimation in Energy Harvesting Sensors |
| 143 | Linear Time Invariant System Identification via Nonparametric DWT |
| 144 | Pre-DFT Processing in MIMO OFDM Systems with Space-Time-Frequency Coding |
| 145 | Vibration Analysis for Structural Health Monitoring using DSP |
| 146 | Advanced Algorithms for Satellite Image Denoising and Sharpening |
| 147 | Lifting Wavelet Transform for Low Complexity Image Codec |
| 148 | Content-Based Speech Watermarking Using Discrete Wavelet Transform |
| 149 | Explicit Calculations of State-Estimation Errors in Flag Hidden Markov Models |
| 150 | Digital Forensics: Image and Video Tampering Detection |
| 151 | Online Censoring for Regression in Large-Scale Data Streams |
| 152 | GHM, CAL, SAS Multi-Wavelets Based Image Codec |
| 153 | Dynamic Programming Approach to Data Hiding in Grayscale Images Based on Human Vision |
| 154 | High-Fidelity Audio Reconstruction with Advanced DSP Techniques |
| 155 | Multi-Wavelet Transform Steganography using BPCS |
| 156 | Time of Arrival-Based Matrix Rank Characterization |
| 157 | Ocular Artifact Correction of EEG Signal Using a Wavelet-Based De-noising Technique |
| 158 | Analog Flat-Fading Bandpass Channels Speech Watermarking |
| 159 | Speaker Recognition with MFCC and Feature Mapping via GMM |
| 160 | Tone Reservation Peak-to-Average Power Ratio Control in Orthonormal Transmission Systems |
| 161 | Probability Hypothesis Density and Cardinalized Filtering with Uncertain Detection Rates |
| 162 | Wideband Effects in Millimeter-Wave Massive MIMO Systems |
| 163 | Sturdy Parallel Algorithm for Compressed Sensing in Combinatorial Domains |
| 164 | Semi-definite Programming in Computable Bounds for Block-Sparsity Recovery |
| 165 | SNR Estimation in Frequency Selective Channels for OFDM Systems with Preamble |
| 166 | Distributed Signal Processing for Networked Unmanned Aerial Vehicles |
| 167 | Carrier Frequency Offset Estimation for OFDM in Fading Channels via Maximum Likelihood |
| 168 | Lossless Compression for Bayer Color Filter Array Images |
| 169 | Large-Scale Network Regression via Data-Adaptive Censoring |
| 170 | Pre-DFT Combining Optimization in Coded SIMO-OFDM Systems through Multi-Objective Approaches |
| 171 | Adaptive Beamforming for Underwater Acoustic Communications |
| 172 | Fundamentals of Super Nested Arrays in Sparse Linear Arrays with Reduced Coupling |
| 173 | Mixed-Norm Array Processing for Enhanced Radar Imaging |
| 174 | Texture Extraction Using Gabor Filters for Adaptive Wavelet Packets |
| 175 | Region-Based Segmentation with Variational Multiple Texture Statistics |
| 176 | Sparse-Promoting Prior in Weak and Strong Target Radar Scene Estimation |
| 177 | Blind Identification of Error Correcting Codes Using Euclidean Distance Classification |
| 178 | Cross-Frequency Coupling Measurement in Epilepsy using Mutual Information Techniques |
| 179 | BER Analysis in Nonlinear Distortion Effects on DS-CDMA Downlink Signals |
| 180 | Distributed Sensor Fusion Mitigation via Least Squares in Quantization-Affected Environments |
| 181 | Time-Frequency Block Thresholding Approach for Audio De-noising |
| 182 | Ensemble Face Recognition Methods with Bit Plane Decomposition |
| 183 | FPGA Implementation of Real-Time Video Stabilization |
| 184 | Hybrid Sensing Optimization under Spectrum Sensing Constraints |
| 185 | Speech Enhancement Using Adaptive KLT Approach |
| 186 | Adaptive Directional Partitioning in Contourlet Transform |
| 187 | Deep Learning for Automated Optical Inspection in Manufacturing |
| 188 | Adaptive Thresholding in Morphological Component Analysis |
| 189 | SVD Transform in Video Watermarking Algorithms |
| 190 | Bayesian Compressive Sensing in Frequency-Hopping Spectrum Estimation with Missing Observations |
| 191 | Extended Sparse Bayesian Learning Alternatives and Pattern-Coupled Relations |
| 192 | Robust Adaptive Kalman Filtering for Speech Enhancement |
| 193 | Wavelet-Based Statistical Method for De-Noising EEG Signals with Ocular Artifacts |
| 194 | Unified Framework for Web Image Retrieval with Relevance Feedback |
| 195 | Parameter Tracking and Fusion Estimation with Stochastic Perturbations and Correlated Noises |
| 196 | HOUGH Transform Implementation in IRIS Recognition System |
| 197 | Regularized Least Squares BER Analysis in BPSK Recovery |
| 198 | Speech Compression via Adaptive Cosine Packet Transform Algorithm |
| 199 | High-Speed OFDM Systems Timing Jitter Impact Reduction via Oversampling |
| 200 | Histogram Modification Based Reverse Data Hiding |
| 201 | Optimal Spatial Compression Strategy for Beamspace MIMO Signals |
| 202 | Wavelet-Based Voice Verification System Development |
| 203 | IEEE 802.11a Physical Layer Performance Analysis |
| 204 | Spatial Audio Rendering for Virtual Reality Applications |
| 205 | Low-Light Image Enhancement Using Deep Neural Networks |
| 206 | Structured Random Matrices Recovery Bounds in Corrupted Sensing |
| 207 | Wideband Sensor Array Signal Subspace Estimation via Space-Time MUSIC |
| 208 | Authenticity and Recovery of Images through Wavelet-Based Techniques |
| 209 | Fast Global Minimization Based MRI Image Segmentation with Snake Model |
| 210 | Discrete Wavelet Transform for Video Watermarking |
| 211 | Non-Negative Least Squares Problem in Rectified Gaussian Scale Mixtures |
| 212 | Amplitude Flow Reweighting in Phase Retrieval Processes |
| 213 | Self-Adaptive Motion Characteristic Detection and Entropy Model for Video Watermarking |
| 214 | Partial-Sum Network Architectures for Efficient Polar Codes Decoding |
| 215 | Coupled Canonical Polyadic Decompositions for Array Processing Enhancement |
| 216 | Box-Relaxation Decoders in Massive MIMO Symbol Error Rate Analysis |
| 217 | Compressive Channel Estimation Efficiency for Large-Scale Antenna Systems |
| 218 | Hilbert Integral Equations and Phase Retrieval in Generalized Minimum-Phase Signals |
| 219 | Visual Cryptography and D-H Key Agreement Scheme Based Visual Information Encryption |
| 220 | Second Order Statistics Utilization in Time-Domain Signal Detection for MIMO-OFDM Systems |
| 221 | Analytical-Computational Method for Constructing Binary Sequences with Favorable Correlation Properties |
| 222 | Context Tree Modeling for Lossless Compression of Color Map Images |
| 223 | Adaptive Streaming Algorithms for Maximizing User Experience in VR/AR Applications |
| 224 | Enhanced Image Compression with Extended JPEG 2000 Systems |
| 225 | Laplacian Operators in Edge Detection for Range Data |
| 226 | Companding Transform for PAPR Reduction in OFDM Systems |
| 227 | Scrambled Digital Video Data Embedding |
| 228 | DCT Coefficients Scaling for Color Image Enhancement |
| 229 | Color K-Means Clustering for Brain Tumor Detection |
| 230 | Multirate Processing for Efficient Digital Down-Conversion |
| 231 | Observed FIM-Based Adaptive Radar Detectors |
| 232 | Learning Graphs with Monotone Topology Constraints and Multiple Connected Components |
| 233 | Scalable Framework for Time-Vertex Signal Processing |
| 234 | Machine Learning Aided Diagnosis in Medical Image Processing |
| 235 | Algorithms in Airborne SAR Data Processing Overview |
| 236 | Low-Rank Model Recovery from Signal Approximation |
| 237 | Integrated SPIHT Compression in Focal Plane CMOS Image Sensors |
| 238 | Efficient Wireless Cellular System Resource Allocation Strategy |
| 239 | Neural Network Based Predictive Control in Industrial Automation |
| 240 | Binary Key-Image Based Image Encryption Methodology |
| 241 | Device Activity Detection and Channel Estimation in Massive Connectivity MIMO Systems |
| 242 | Primary Control Perturbation Based Decentralized DC Microgrid Monitoring |
| 243 | Robust Power Allocation for MIMO Radar in Multiple Target Localization |
| 244 | Integer Wavelet Transform Based Adaptive Steganographic Technique |
| 245 | Blind Source Separation in Amplitude Based Sparsity and Low-Rank Models |
| 246 | General Power Constraints Oriented Optimal Training Design for MIMO Systems |
| 247 | Optimal Strategy for Bayesian Transfer Learning |
| 248 | Blind Video Watermarking with Singular Value Decomposition |
| 249 | Trilateral Filtering in Graph Spectral Domain for Signal Denoising |
| 250 | Wavelet Thresholding Inspired EMD-Based De-noising Development |
| 251 | Quantum Signal Processing for Enhanced Communication Security |
| 252 | PCA Analysis Based Facial Recognition System |
| 253 | Video Quality Assessment with Salient Motion Features |
| 254 | Image Enhancement Techniques Using Quadratic Programming |
| 255 | Adaptive OFDM Downlink Channel Estimation and Prediction |
| 256 | Image Classification with Color Histogram Features in Retrieval Systems |
| 257 | Spectral Matching and Meta Similarity in Improved Shape Retrieval |
| 258 | Design and Analysis of Secure Speech Coding Techniques |
| 259 | Multi-Pose Face Recognition Using Color Images and Gabor Features |
| 260 | Dual Watermarking Scheme with DWT-SVD |
| 261 | Low-Rank Bayesian Matrix Completion with Hierarchical Gaussian Prior Models |
| 262 | Real-time Edge Detection for High-Resolution Video Processing |
| 263 | Stochastic Policies for Energy Harvesting Communication Network Routing and Scheduling |
| 264 | Pursuing Global Optimality in Low-Rank Matrix Optimization Endeavors |
| 265 | Invisible and Blind Watermarking Scheme for Digital Image Copyright Protection |
| 266 | Variable Step Size NLMS Algorithm for Acoustic Echo Cancellation in Under Modeling |
| 267 | Equalizer Effect Analysis on Speech Signals |
| 268 | Alternating Diffusion Kernel Methods in Sequential Audio-Visual Correspondence |
| 269 | Joint Blind Source Separation via Double Coupled Canonical Polyadic Decomposition |
| 270 | Content-Based Image Retrieval via Adaptive Non-separable Wavelet Transform |
| 271 | Multi-User Detection in CDMA Systems with PDA Algorithm under AWGN |
| 272 | Dynamic Range Compression for HDR Imaging in Real-time Rendering |
| 273 | Deep Reinforcement Learning for Dynamic Network Routing |
| 274 | Real-Time Gesture Recognition Using 3D Convolutional Neural Networks |
| 275 | Image Quality Assessment Using Deep Convolutional Networks |
| 276 | Global Energy Efficiency in Wireless-Powered Massive MIMO Aided Networks |
| 277 | Integer-to-Integer Wavelet Transform for Reversible Image Watermarking |
| 278 | Steganography Enhancement using BPCS in Integer Wavelet Transformed Images |
| 279 | Millimeter-Wave Massive MIMO Systems Relay Hybrid Precoding Design |
| 280 | Adaptive Mesh-Based Image Warping for Special Effects Generation |
| 281 | Two-Level DCT and Wavelet Packets De-noising for Robust Image Watermarking |
| 282 | Algorithms and Strategies for Optimal Adaptive Graph Signal Processing |
| 283 | OFDM Frequency Offset Estimation Study using EMD Algorithm |
| 284 | Fuzzy Measures in Automatic Histogram Thresholding |
| 285 | Counterlet Based Optimal Detection in Noisy Environment Image Watermarking |
| 286 | Prior Information Aided Signal Recovery via Correlation Maximization |
| 287 | Directional Audio Coding in Spatial Sound Reproduction |
| 288 | MIMO-CDMA Spreading Permutations Based on Space-Time Block Codes Design |
| 289 | New Approach in Generic Lossless Visible Watermarking |
| 290 | Real-Time Adaptive Video Encoding for Live Streaming Services |
| 291 | Audio Compression Employing Munich and Cambridge Morlet Wavelet |
| 292 | Spectral Graph Clustering: Phase Transitions and Model Order Selection Criterion |
| 293 | Graph Signal Sampling in the Spectral Domain |
| 294 | Large-Dimensional Analysis of Regularized Maronna’s M-Estimators of Covariance Matrices |
| 295 | Tracking Channel Codes in Wireless OFDM Systems |
| 296 | Correlation Method Resilient to Noise for Signal Period Detection |
| 297 | Joint Channel-Estimation and Equalization via Bilinear AMP for Single-Carrier Systems |
| 298 | Robust Localization via Convex Approximation for TDOA under NLOS Conditions |
| 299 | Multidimensional Mixed-Norm Penalty for Sparse Sound Field Decomposition |
| 300 | Distributed Target Detection in Homogeneous Environments with Signal Mismatch |
| 301 | Single-Microphone Wind Noise Reduction for Outdoor Sound Recording |
- Latest Electrical Projects Ideas
- Power Systems Project Ideas
- Top Electrical Major Project Titles
- Automobile Engineering Projects
- Renewable Energy Projects for Students
