Reading: Auto Recloser Circuit Breaker in Power System
Inst Tools > Blog > Power Systems > Auto Recloser Circuit Breaker in Power System
Last updated: September 20, 2016 2:11 pm
Power Systems
2 Min Read
Most of the faults on over head lines are transient in nature. About 85% to 90% of faults are momentary and caused by tree branches, lightning, birds etc. These conditions results in arcing faults which lasts for very small duration and clears after that moment. The arc generated can be extinguished and the line can be re energized. For this momentary faults which recovers on its own normal circuit breaker operation of opening the faulty part is not advisable. Some provision should be permitted in circuit breakers to close the breaker contacts if the fault is cleared momentarily. This fact is employed as a basis for auto- reclosures.
In this scheme after the relays of both ends have picked up, the circuit breakers are tripped as for as possible at the same time and reclosed after time has be allowed for deionization. The fault disappears if it is transient and line is restored to normal service after the reclosure. If the fault is not cleared after the first reclosure a double or triple attempt of separation and reclosure is made. If the fault still persists, the breaker may permanently open till it is manually reset.
Auto reclosures may be single or three phase type. Mostly single phase auto reclosing breakers are preferred as most of the transmission faults are single phase to ground faults. Auto reclosures of single pole type improves the stability of the system as power remains transmitted through the remaining two healthy phases when fault on one phase occurs.
The breakers may be rapid auto reclosing type  (about 20 cycles or 0.4 sec) or delayed auto reclosing (5 to 30s) type. For rapid reclosing type it is not required to check synchronism while reclosing however for delay reclosing synchronism should be checked before reclosing. For this purpose synchronous relays are employed
Advantages & Disadvantages of AC power and DC power
Harmonics Disadvantages in Power System
Advantages and Disadvantages of Per Unit System
Electrical Power System Protection Quiz
Underground Cable Fault Identification Methods
Shunt Capacitor Advantages in Power System
Silicon Carbide Lightning Arresters Working Principle
Why Reactive Power is Generated at Load
Why Symmetrical Components Used for Unbalanced faults in Power System
Neutral Grounding Practice in Power System
Harmonics effect on Induction Motor
Voltage Variations Effects on Power Plant Equipment
Rotor Angle Stability of Synchronous Generators in Power System
ungrounded-or-isolated-neutral-system-disadvantages
Ungrounded or Isolated Neutral System Disadvantages
Why Grounding
Generating Station Grounding Principles
Corona-Ring-on-Surge-Arresters
harmonics-effect-on-transformer
Harmonics effect on Transformer
Reactive Power Sources and Sinks in Power System
current-limiting-reactors-and-short-circuit-currents
Current Limiting Reactors and Short Circuit Currents
Boiler Feed Water Heater Shell Flange Leaks
Radio Telemetry Objective Questions
Electron Spectroscopy for Chemical Analysis
Thermocouple Reference Junction
Thermocouple Working Principle
Difference Between Ethernet IP and EtherCAT
Displacer Level Transmitter weight calibration
Displacer Level Transmitter Dry Calibration with Weights
Control Valve Preventive Maintenance
Principle of Elastic diaphragm gauges
Elastic Diaphragm Gauge Principle
