| 1 | The number of starts for an electric motor in a given period of time should be limited because overheating of the ___ can occur due to the ___ counter electromotive force produced at low rotor speeds |
| 2 | What is the primary reason for limiting the number of starts for an electric motor in a given period of time ___ |
| 3 | The frequency of start/stop cycles for an electrical motor is limited to prevent ___ |
| 4 | Motor winding temperature will be reduced by ___ |
| 5 | The frequency of starts for large AC motors should be limited to prevent excessive ___ |
| 6 | Which one of the following is the primary reason for limiting the number of motor starts in a given time period ___ |
| 7 | The discharge valve for pump A is fully open and the discharge valve for pump B is fully closed ___ |
| 8 | To minimize the duration of high starting current, an AC induction motor should be started ___ to ___ the stator counter electromotive force |
| 9 | The discharge valve for pump A is fully shut and the discharge valve for pump B is fully open ___ |
| 10 | Which one of the following is a characteristic of a typical AC induction motor that causes starting current to be greater than running current ___ |
| 11 | Two identical AC induction motors are connected to identical radial-flow centrifugal pumps in identical but separate cooling water systems ___ |
| 12 | Frequent starts of large motors will result in overheating of the motor windings due to high current flow caused by ___ |
| 13 | Which one of the following describes when the highest stator current will be experienced by an AC induction motor ___ |
| 14 | Two identical AC induction motors are connected to identical radial-flow centrifugal pumps being used to provide cooling water flow in separate systems in a nuclear power plant ___ |
| 15 | The starting current in a typical AC induction motor is usually much higher than the full-load running current because ___ |
| 16 | Which one of the following AC induction motor events is characterized by maximum rotor slip and a motor current five to six times full-load current ___ |
| 17 | The average starting current for a typical AC induction motor is approximately ___ |
| 18 | Which one of the following describes the motor current indications that would be observed during the start of a large motor-driven radial-flow centrifugal pump with a closed discharge valve ___ |
| 19 | Refer to the partial drawing of two identical centrifugal pumps in a cooling water system ___ |
| 20 | Initially, an AC induction motor is operating with the following steady-state conditions ___ |
| 21 | The fan is operating at 90 percent of rated flow rate with its discharge damper partially closed ___ |
| 22 | The rate of heat production in the stator windings of an AC induction motor is ___ proportional to the ___ of the stator current |
| 23 | An air-cooled AC induction motor is initially operating at steady-state conditions, producing a work output of 50 hp ___ |
| 24 | The pump is being driven by a single-speed AC induction motor. Pump flow rate is being controlled by a throttled discharge flow control valve ___ |
| 25 | Consider two identical single-speed AC induction motors, one of which is connected to a radial-flow centrifugal pump and the other to a rotary-type positive displacement pump (PDP) ___ |
| 26 | An axial flow ventilation fan is being driven by an AC motor ___ |
| 27 | An AC induction motor is connected to a radial-flow centrifugal pump in a cooling water system ___ |
| 28 | The pump is being driven by a single-speed AC induction motor ___ |
| 29 | Consider two identical single-speed AC induction motors, one of which is connected to a radial-flow centrifugal pump and the other to a reciprocating-type positive displacement pump (PDP) ___ |
| 30 | Refer to the pump performance curves for a centrifugal cooling water pump ___ |
| 31 | Which one of the following describes the relationship between the current drawn by an AC induction motor and the amount of heat generated in the motor windings ___ |
| 32 | A motor-driven centrifugal pump is operating with a flow rate of 3,000 gpm and a motor current of 150 amps ___ |
| 33 | A multi-speed centrifugal pump is operating with a flow rate of 1,800 gpm at a speed of 3,600 rpm ___ |
| 34 | What will be the approximate value of pump head if pump speed is increased to 1,200 rpm ___ |
| 35 | What will be the approximate values of pump head and motor current if pump speed is increased to 1,600 rpm ___ |
| 36 | What will be the new value of pump head if the pump speed is increased such that the current requirements are now 640 amps ___ |
| 37 | A multi-speed motor-driven centrifugal pump is operating with the following parameters ___ |
| 38 | A motor-driven centrifugal pump is operating at 600 rpm with the following parameters ___ |
| 39 | A motor-driven centrifugal pump is operating with the following parameters ___ |
| 40 | A motor-driven centrifugal pump is operating with a flow rate of 3,000 gpm and a current requirement of 200 amps ___ |
| 41 | Given the following conditions for a variable-speed motor-driven centrifugal pump ___ |
| 42 | A shutdown nuclear power plant is operating normally when an electrical fault causes a sustained 20 percent voltage reduction on all phases of the onsite three-phase AC electrical distribution system ___ |
| 43 | A 4,000 KW rated diesel generator (DG) is supplying 2,000 KW to a 4.16 KV emergency bus ___ |
| 44 | A main generator is connected to an infinite power grid with the following generator output parameters ___ |
| 45 | A 4,000 KW diesel generator (DG) is supplying 2,000 KW to a 4.16 KV emergency bus ___ |
| 46 | A nuclear power plant startup is in progress ___ |
| 47 | Refer to the partial drawing of two identical radial-flow centrifugal pumps in a cooling water system ___ |
| 48 | A main generator that is connected to an infinite power grid has the following generator indications ___ |
| 49 | An AC generator is supplying an isolated electrical system with a power factor of 1.0 ___ |
| 50 | A large AC motor has a maximum ambient temperature rating of 40°C ___ |
| 51 | Which one of the following will provide the initial motor protection against electrical damage caused by gradual bearing failure ___ |
| 52 | Which one of the following will result from prolonged operation of an AC induction motor with excessively high stator temperatures ___ |
| 53 | Continuous operation of a motor at rated load with a loss of required cooling to the motor windings will eventually result in ___ |
| 54 | When a motor-driven centrifugal pump was started, the motor ammeter reading immediately increased to, and stabilized at, many times the normal operating value ___ |
| 55 | A motor-driven centrifugal pump exhibits indications of pump failure while being started in an idle cooling water system ___ |
| 56 | A motor-driven cooling water pump is operating normally ___ |
| 57 | A cooling water pump is being driven by an AC induction motor ___ |
| 58 | If a locked rotor occurs on an operating motor-driven pump, motor amps will ___ |
| 59 | Refer to the drawing of a water storage tank with a differential pressure (D/P) level detection system. Assume that the initial temperature of the reference leg and the water in the tank ___ |
| 60 | Which one of the following is a characteristic of a venturi flow device ___ |
| 61 | The direction of rotation of a ___ AC induction motor cannot be changed with the motor running in either direction (referred to as “reverse on the flyâ€) ___ |
| 62 | Due to the difference in strength of the two electromagnetic fields (the ___ magnetic path for the power contactor that is energized has a much stronger field); |
| 63 | Interlock in a control circuit, which can be performed by either control contacts (___ interlock), or mechanical linkage (___ interlock) can also be used to ensure that one or more operations occur simultaneously |
| 64 | When the control circuit for a single motor is modified to include electrical reversing, a(n) ___ circuit (gate) must be created with the addition of the reversing control circuit |
| 65 | In a single-phase AC induction motor, the phase connections or polarities of the ___ or ___ windings must be interchanged in reference to supply lines 1 and 2 to command the change in direction of rotation |
| 66 | The direction of rotation of a single-phase AC induction motor cannot be changed with the motor running in either direction (referred to as “reverse on the ___â€) |
| 67 | If the motor must be allowed to coast to a stop before the direction of rotation is electrically reversed; the circuit must be modified with an ___ switch (___ switch) |
| 68 | At rest, one set of control contacts on a single-direction plugging switch is NO; the other set is NC ___ |
| 69 | Anti-plugging switches are normally used in conjunction with either 2-wire, selector-switch reverse, or 3-wire, reverse-through-stop circuits ___ |
| 70 | A single-direction motor-starter consists of a 3-pole ___ and a 3-pole thermal ___ |
| 71 | Because the opposing electromagnetic fields in the rotor circuit are ___ by the rotation of the stator fields in a 3-phase AC induction motor, the rotor surface will be caused to follow |
| 72 | Plugging of the motor can be limited to just ___ the motor (when the rotor stops, the reverse-circuit ___ ), or plugging can be used as a means of ___ of the motor’s direction of rotation |
| 73 | Cross -connection is required for reversing, and it creates a possible short-circuit condition between line 1 and line 3 of the 3-phase AC supply power ___ |
| 74 | Due to the difference in strength of the two electromagnetic fields (the complete magnetic path for the power contactor that is energized has a much stronger field); the ___ |
| 75 | Interchanging the connection of the motor-circuit conductors with any two of the three winding configurations in a 3-phase AC induction motor causes the ___ rotation |
| 76 | The direction of rotation of a ___ AC induction motor cannot be changed with the motor running in either direction (referred to as “reverse on the flyâ€) |
| 77 | The reversing electromagnetic motor -starter consists of two 3-pole power contactors, ___ and ___, with a single overload protection device (usually a thermal ___) for the electric motor |
| 78 | ___ protection (as it is normally referred to) will not prevent the direction of rotation of a motor rotor from being reversed; |
| 79 | A single-direction motor-starter consists of a 3-pole power contactor and a 3-pole thermal overload relay ___ |
| 80 | The electrical displacement of the three single-phase AC supplies within a 3-phase AC induction motor creates a ___ electromagnetic field that can be electrically reversed while running in either direction |
| 81 | As a rule, connecting the motor-circuit conductors (line supply) to the motor-terminal leads in a configuration of (line) L1 to (terminal) L1 to T3, L2 to T2, and L3 to T1 will result in ___ |
| 82 | Reversing the direction of rotation of an AC induction motor requires a change in the ___ relationship of the phase windings in the motor stator assembly |
| 83 | The single-direction plugging switch contains a set of NO switch contacts and a set of NC switch contacts ___ |
| 84 | On a bi-directional ___ switch, both sets of contacts are NC when the plug switch is at-rest |
| 85 | The long straight line drawn between the two power-contactor solenoids on a reversing motor-starter, with two dashed lines connecting the solenoid symbols at a diagonal to ___ |
| 86 | A plugging switch is mounted on the non-power end of the motor to monitor the ___ of the rotor shaft |
| 87 | The two forms of electrical interlock are ___ interlock and ___ interlock: |
| 88 | As a rule, connecting the motor-circuit conductors (line supply) to the motor-terminal leads in a configuration of (line) ___ to (terminal) |
| 89 | The reversing electromagnetic motor-starter consists of two 3-pole power contactors, forward and reverse, with a single overload protection device (usually a thermal overload relay) for the electric motor ___ |
| 90 | The single-direction plugging switch contains a set of ___ switch contacts and a set of ___ switch contacts |
| 91 | ___ interlock normally requires two or more stacked or combination NO and NC PB switches |
| 92 | Anti-plugging ___ (as it is normally referred to) will not prevent the direction of rotation of a motor rotor from being reversed; instead, anti-plugging circuits are used to reduce the ___ placed on bearings |
| 93 | As with any type of pilot device, the plugging switch has a ___ (different value of ___) between the opening and closing of the contacts |
| 94 | A ___ AC induction motor is technically a split-phase motor: the second phase is generated within the motor from a single-phase supply |
| 95 | On a bi-directional plugging switch, both sets of contacts are NO when the plug switch is at-rest ___ |
| 96 | As with any type of pilot device, both the anti-plugging and the plugging switch have a ___ (different value of rpm) between the opening and closing of the contacts |
| 97 | ___ is a control-circuit method of applying power to a reversing electromagnetic motor -starter that will generate a retarding force (counter-torque) within the electric motor for quick stopping or instant reversing; |
| 98 | Interlock with stack switches or multiple auxiliary contacts on a motor -starter is used for the ___ of two operations |
| 99 | The heat will build up rapidly in the motor windings and housing (enclosure) during plugging, which will have an effect on the lifetime of the winding ___, the ___ in the bearings, as well as, metal ___ |
| 100 | On a bi-directional anti-plugging switch, both sets of contacts are NC when the plug switch is at-rest ___ |
| 101 | Plugging the electric motor in the opposite direction of rotation while it is running in either direction also places electrical stress on the supply and winding conductors ___ |
| 102 | A 3-phase AC induction motor can be reversed by interchanging the lead connections (between line and terminal) of any ___ of the ___ motor-supply conductors |
| 103 | Connecting the motor-circuit conductors to the motor-terminal conductors in a configuration of (line) ___ to (terminal) |
| 104 | ___ interlock is used to assure priority: one function or operation has to precede a second function or operation (sequence control) |
| 105 | The wiring and drawing of the 3-position selector switch in a 2-wire reversing control circuit is similar to a(n) ___ control circuit |
| 106 | One of the simplest 3-wire reversing circuits parallels the forward and reverse control circuits through a common Stop PB switch ___ |
| 107 | Interlock in a control circuit, which can be performed by either control contacts (___ interlock) or mechanical linkage |
| 108 | ___ interlock is used to assure priority: one function or operation has to precede a second function or operation |
| 109 | Reverse-torque applied to an electric motor commands the rotor to stop as the reverse-direction electromagnetic field attempts to force it to run in the reverse direction ___ |
| 110 | In a ___ AC induction motor, the phase connections or polarities of the start or run windings must be interchanged in reference to supply lines 1 and 2 to command the change in direction of rotation |
| 111 | The wiring and drawing of the 3-position selector switch in a 2-wire reversing control circuit is similar to an H-O-A control circuit ___ |
| 112 | The two common failures of motor control and motor load circuits are opens and shorts, and of the two: the ___ are the more common |
| 113 | When the switch controlling overhead lighting, the solenoid of a relay, contactor, or motor starter, or the power supplied to an electric motor is closed, then ___ should be measured across the switch |
| 114 | In combination circuits, voltage, resistance, and current rules are obeyed according to the type of circuit seen ___ |
| 115 | As with the line-to-line voltage test, if zero volts are measured on both the line and load sides of the fuse, the fuse is not necessarily open ___ |
| 116 | All loads supplied by individual or multioutlet branch circuits, and all the load centers, either supplied by the service or by feeder circuits, operate in ___, and at the same ___ as established for the building |
| 117 | Because the measured value is displayed as a numerical (digital) value on digital multimeters, errors can occur when reading a digital display if the displayed ___ are not properly applied |
| 118 | As used with electrical test instruments: The term ___ refers to a continuous, non-interrupted, smooth change in an electrical or electronic process |
| 119 | In most cases, a loss of voltage due to a ___ connection makes the load inoperative |
| 120 | Electrical-power distribution and process control circuits are normally referenced to earth ground ___ |
| 121 | For any parallel circuit: The ___ of the individual-branch load-resistance wattages must equal the total circuit wattage |
| 122 | When the fuse, circuit breaker, or control switch is ___, the circuit or power-supply voltage appears as voltage drop across the is ___ device (assuming the load is still connected and provides circuit continuity) |
| 123 | For any parallel circuit: The total circuit resistance will be less than the least value of resistance found in any one parallel branch ___ |
| 124 | For line-to-line voltage measurements (readings); with the disconnecting means closed and the motor-starter at rest ___ |
| 125 | Testing for the proper supply ___ is usually the first step when troubleshooting a circuit |
| 126 | Without load current flowing in a rung of a ladder diagram / control process, the ___ through the light filament, through the coil of the solenoid, or through the windings of the motor |
| 127 | All the loads supplied by individual or multioutlet branch circuits, and all the load centers, either supplied by the service or by feeder circuits operate in ___, and at the same ___ is ___ as established for the building |
| 128 | The acronym DMM stands ___ |
| 129 | If the letters OL appear on the digital display when a measure is being attempted, these letters indicate the measure is of higher value than the digital multimeter can read the meter is ___ |
| 130 | Ideally no ___ will occur across a switch or an overcurrent protection device when wired in series with a connected load |
| 131 | In series-parallel circuits, fuses, circuit breakers or other types of overcurrent protection devices are wired in ___ with the circuits they protect at the point where the circuit receives its supply |
| 132 | As each individual parallel load is added, the circuit current will increase according to the full-load ___ rating of the individual loads added |
| 133 | A(n) ___ multimeter can be destroyed and in some cases cause bodily injury by exploding, if an attempt is made to measure voltage on an ohmic scale |
| 134 | The principal types of electrical circuits include ___ |
| 135 | The same value of circuit ___ is applied to all the utilization-equipment loads connected in parallel |
| 136 | An ___ multimeter is a meter that can measure two or more electrical properties and display the measured properties along calibrated scales using a pointer |
| 137 | A voltmeter offers high resistance to the flow of current; however, a minute amount of current ― enough to drive the meter, but not enough to energize the connected load does flow |
| 138 | For any parallel circuit: The circuit (applied) voltage will be ___ or the ___ for each branch according to the value of the supply voltage |
| 139 | Two ways are available to check for an open fuse ___ |
| 140 | The basic electrical circuit is described as a series-parallel ___ circuit when a second load is added |
| 141 | The electrical-power distribution system within a building or other structure has three major circuit classifications ___ |
| 142 | If a blown or open fuse is detected, it is not enough to just replace the fuse ___ |
| 143 | Never attempt to replace a fuse or CB with the power ___ and the load ___ |
| 144 | There are three principle types of electrical circuits: ___; ___; and ___ series/parallel or parallel/series |
| 145 | To check the continuity of a fuse with the power on, two methods are available for taking voltage readings ___ |
| 146 | Any electrical utilization equipment supplied by the two ungrounded busses in the service equipment will operate at the higher phase-to-phase, or “line voltage†of ___ volts |
| 147 | If ___ volts is measured from the line side of the fuse in reference to the metal enclosure and ___ volts is measured from the load side, the fuse is open |
| 148 | The principal quantities of measure in an electrical circuit are ___ |
| 149 | Basic digital meters can measure values of ___, ___, and ___ as the analog meters they were developed to replace |
| 150 | The total circuit current depends on the resistance of both loads. In parallel ___ |
| 151 | ___ switches are pilot devices that are often used to sense a change of position, motion, or relocation |
| 152 | A digital multimeter, which is set to measure voltage, may display a voltage reading before it is connected to a powered electrical circuit ___ |
| 153 | A ___ is a meter that is capable of measuring two or more electrical quantities, such as voltage, current, continuity, resistance, capacitance, frequency, or duty cycle |
| 154 | A phenomenon referred to as “___ error†occurs when reading the pointer against the selected scale on an analog meter: |
| 155 | The ___ lead of the transformer is normally fused and extended in the ladder diagram of the control circuit as the left-side vertical bus |
| 156 | A ___ circuit does not supply a connected load directly |
| 157 | In the ladder diagram of a control process ___ |
| 158 | In manufacturing or other types of process control, the supply to one or more motors is normally broken down into the ___ or ___ circuit and the ___ or ___ circuit within a motor control center |
| 159 | If any terminal reading from a CB does not give the rated voltage measurement, the CB should be ___ |
| 160 | As the name implies, in a series-parallel or ___ circuit, part of the circuit components are wired in a series configuration, and other parts of the circuit are wired in a parallel configuration |
| 161 | Most analog multimeters have several ___ for the single meter movement |
| 162 | In the control of overhead lighting, all the luminaires on a single branch circuit must be wired in ___ |
| 163 | In troubleshooting a circuit, the location of the ___ normally has to be located by dismantling the affected circuit in parts and taking resistance checks of different parts of the circuit |
| 164 | The standard single-phase AC service is normally rated 120/240-volt, 3-wire ___ |
| 165 | ___ switches normally offer only ON/OFF control of a fan, the flow of water or steam, or the electrical power being applied to different types of heating elements |
| 166 | In Principle to the ___ of individual-load voltage drops in a series circuit and to the ___ of individual branch-circuit currents in a parallel circuit |
| 167 | To provide a fast and easy understanding of the connections and use of the components, ___ or ___ diagrams show the logic of an electrical circuit or system using standard symbols |
| 168 | Indicating lights, which indicate either an alarm or the run status of process pumps or blowers, are normally of the ___ type, which is mounted with NO and NC contacts |
| 169 | Indicating lights in a ladder diagram or other drawing are symbolized with a ___ |
| 170 | An electric motor draws locked-rotor current on starting, which can be ___ to ___ times higher than its full-load current rating |
| 171 | The forms of electrical interlock include ___ |
| 172 | Limited to a single set of NC control-relay contacts: running overload protection poses a problem with a reversing motor-starter simply because the reversing circuit consists of only one other 3-pole contactor ___ |
| 173 | Plugging a 3-phase AC induction motor in the opposite direction of rotation while it is running in either direction places electrical stress on the supply and winding conductors ___ |
| 174 | A reversing motor-starter consists of two 3-pole ___ and a single 3-pole thermal ___ |
| 175 | Because some building or other-structure 3-phase AC electrical-power distribution systems operate with the center leg (Line ___ or Phase ___) referenced or connected directly to earth ground |
| 176 | Reversing the direction of rotation of an AC induction motor requires a change in the magnetic relationship of the phase windings in the motor stator assembly ___ |
| 177 | The normal forward direction of rotation for an AC induction motor is ___ when looking at the non-drive end of the motor. The normal reverse direction is ___ |
| 178 | The normal forward direction of rotation for an AC induction motor is ___ when looking at the non-drive end of the motor |
| 179 | Most power contactors have openings or protruding pins or parts that will allow the contact block to be closed manually ___ |
| 180 | For all practical purposes, the term ___ refers to a system of quick braking of the motor’s rotation |
| 181 | Because some building or other-structure 3-phase AC electrical-power distribution systems operate with the center leg (Line 2 or Phase B) referenced or connected directly to earth ground ___ |
| 182 | The single-direction, 3-wire control circuit for a 3-phase AC induction motor can be modified with a reversing electromagnetic motor -starter for plug braking of the electric motor ___ |
| 183 | The combined effect of the electrical displacement of the three single-phase AC sources in the 3-phase power supply and the mechanical displacement of the generated electromagnetic fields in the ___ |
| 184 | A single-phase AC induction motor is technically a ___ motor: the second phase is generated within the motor from a single-phase supply |
| 185 | How to calculate the consumption of electrical in a camp under construction?! |
| 186 | The relation between the breakdown voltage V and the thickness t of the dielectric – |
| 187 | The ratio of charge stored by two metallic spheres raised to the same potential is 6. The ratio of the surface areas of the sphere is |
| 188 | For a group of cells when internal resistance of the group is ___ |
| 189 | The energy capacity of a storage battery is ___ |
| 190 | What happens during the charging of acid cell? |
| 191 | What causes lower efficiency of alkali cell as compared to the acid cell? |
| 192 | The relative density of the electrolyte of acid accumulator should not be ___ |
| 193 | Which of the following acts as depolariser in Lechlanche cell? |
| 194 | The amount of ions liberated by 96500 C of charge passed through the electrolyte is called? |
| 195 | The current capacity of the charged secondary cell does not ___ |
| 196 | What happens during the discharging of Edison cell? |
| 197 | What carries current in ___ |
| 198 | The current capacity of a cell is measured in ___ |
| 199 | Which of the following cells is more likely to be damaged due to short circuiting? |
| 200 | Through an electrolyte an electric current is due to ___ |
| 201 | During charging and discharging of an Edison cell ___ |
| 202 | The arrangement of 12 cells, each of internal resistance 1.5 ω, to ___ |
| 203 | For keeping the lead acid battery terminals free from corrosion it is ___ |
| 204 | Rust, scales and oxides can be removed from a surface with ___ |
| 205 | A battery is connected to a resistance causing a current of ___ |
| 206 | The capacity of a lead acid battery does not depend upon ___ |
| 207 | Short circuiting of a cell may be caused by ___ |
| 208 | In a lead acid battery, separators are provided to ___ |
| 209 | For achieving uniform thickness of deposit on ___ |
| 210 | Cells are connected in parallel in order to ___ |
| 211 | If the specific gravity of the electrolyte in a lead acid cell increases beyond ___ |
| 212 | Sulphated cells are indicated by ___ |
| 213 | In a battery, cover is placed over the elements and sealed at ___ |
| 214 | Oil and grease can be removed from a surface with the help of ___ |
| 215 | A 24 V battery of internal resistance r = 4 ω connected to ___ |
| 216 | Five cells are connected in series in a row and then four such rows are ___ |
| 217 | The condition of a fully charged lead acid battery cannot be ascertained by ___ |
| 218 | During electrodeposition the amounts of different substances liberated by ___ |
| 219 | A floating battery is ___ |
| 220 | Battery charging equipment should be ___ |
| 221 | During electroplating the weight of a substance deposited depends upon ___ |
| 222 | In comparison to constant current charging method, the constant ___ |
| 223 | In which of the following cells polarisation is the major defect? |
| 224 | First electrochemical cell was designed by ___ |
| 225 | Within the electric cell, the charge is ___ |
| 226 | Who was the first to design storage cell? |
| 227 | Which of the following is not the name of a secondary cell? |
| 228 | Overhead lines generally use ___ |
| 229 | Most of the high voltage transmission lines in ___ |
| 230 | Which of the following methods is used for laying of underground cables? |
| 231 | Which of the following are the constants of the transmission lines? |
| 232 | In the cables sheaths are used to ___ |
| 233 | Which of the following is a static exciter? |
| 234 | Which of the following equipment should be installed by the consumers having low power factor? |
| 235 | If the height of transmission tower is ___ |
| 236 | By which of the following methods the protection against ___ |
| 237 | When a conductor carries more current on the surface as compared to ___ |
| 238 | For transmission of power over a distance of 500 km, the transmission voltage should ___ |
| 239 | Pin type insulators are generally not used for ___ |
| 240 | In aluminium conductors, steel core is ___ |
| 241 | Which of the following characteristics should the line supports for transmission lines possess? |
| 242 | A feeder, in a transmission system, feeds power to ___ |
| 243 | Large industrial consumers are supplied electrical energy at ___ |
| 244 | The loads on distributors systems are ___ |
| 245 | The cause of damage to the lead sheath of a ___ |
| 246 | The operating voltage of supertension cables is ___ |
| 247 | The usual spans with R.C.C. poles are ___ |
| 248 | ___ are the conductors, which connect the consumer’s terminals to the distribution |
| 249 | Transmission lines link ___ |
| 250 | If the voltage is increased x times, the size of the conductor would be ___ |
| 251 | Skin effect exists only in ___ |
| 252 | As compared to cables, the disadvantage of transmission lines is ___ |
| 253 | When the load at the receiving end of a long transmission line is ___ |
| 254 | Basically the boosters are ___ |
| 255 | With which of the following are step-up substations associated? |
| 256 | The effect of ice on transmission line conductors is to ___ |
| 257 | Which of the following bar schemes is the most expensive? |
| 258 | The conductors are bundled primarily to ___ |
| 259 | The voltage regulation in magnetic amplifier type ___ |
| 260 | The current drawn by the line due to corona losses is ___ |
| 261 | By which of the following methods string efficiency can be improved? |
| 262 | Which of the following distribution systems is more reliable? |
| 263 | The presence of ozone due to corona is ___ |
| 264 | The spacing between phase conductors of a 220 kV line is ___ |
| 265 | The material commonly used for insulation in ___ |
| 266 | Which of the following faults is most likely to occur in cables? |
| 267 | The operating voltage of high voltage cable’s is ___ |
| 268 | Galvanised steel wire is generally used as ___ |
| 269 | The size of the earth wire is ___ |
| 270 | By using bundle conductors, the critical voltage for the formation of ___ |
| 271 | In case of transmission line conductors with the increase in ___ |
| 272 | The effect of wind pressure is more predominant on ___ |
| 273 | Power system stability is least affected by ___ |
| 274 | In which of the following cases shunt capacitance is negligible? |
| 275 | Which of the following is neglected in the analysis of short transmission lines? |
| 276 | A booster is connected in |
| 277 | Out of the following which type of poles are bulky? |
| 278 | A tap changing transformer is ___ |
| 279 | 310 km line is considered as ___ |
| 280 | Series capacitors on transmission lines are of little use ___ |
| 281 | On which of the following factors skin effect depends? |
| 282 | The use of strain type insulators is made where the ___ |
| 283 | Owing to skin effect ___ |
| 284 | The steel used in steel cored conductors is ___ |
| 285 | For an overhead line, the surge impedance is ___ |
| 286 | The minimum clearance between the ground and a 220 kV line is ___ |
| 287 | Distribution lines in India generally use ___ |
| 288 | Besides a method of trial and error, which of the following methods is ___ |
| 289 | Low voltage cables are meant for use up to ___ |
| 290 | Which of the following materials is not used for transmission and distribution of electrical power? |
| 291 | Solid grounding is adopted for ___ |
| 292 | High voltage is primarily used, for long distance power transmission, to ___ |
| 293 | Due to which of the following reasons aluminium is being favoured as busbar material? |
| 294 | Corona is likely to occur maximum in ___ |
| 295 | Skin effect is noticeable only at ___ |
| 296 | For which of the following, the excitation control method is satisfactory? |
| 297 | A gay wire ___ |
| 298 | In a distribution system major cost is that of ___ |
| 299 | Poles which carry transformers are ___ |
| 300 | Which of the following is the main advantage of A.C. transmission ___ |
| 301 | When a live conductor of public electric supply breaks down and touches the earth which of ___ |
| 302 | Electro-mechanical voltage regulators are ___ |
| 303 | Constant voltage transmission entails the ___ |
| 304 | The voltage drop, for constant voltage transmission is ___ |
| 305 | Which of the following bus-bar schemes has the lowest cost? |
| 306 | Which of the following relays is used on long transmission lines? |
| 307 | Which of the following is usually not the generating voltage? |
| 308 | The material commonly used for sheaths of underground cables is ___ |
| 309 | Multicore cables generally use ___ |
| 310 | Which of the following is the demerit of a ‘constant voltage transmission system? |
| 311 | The wooden poles well impregnated with creosote oil or ___ |
| 312 | Resistance grounding is used for voltage between ___ |
| 313 | High voltages for transmitting power is ___ |
| 314 | Which of the following short-circuits is most dangerous? |
| 315 | Impedance relay is used on ___ |
| 316 | Surge absorbers protect against ___ |
| 317 | The area of cross-section of the neutral in a 3-wire D.C. system is ___ |
| 318 | Which of the following cause transient disturbances? |
| 319 | Power loss due to corona is not directly proportional to ___ |
| 320 | Which of the following distribution systems is the most economical? |
| 321 | The skin effect of a conductor will reduce as ___ |
| 322 | The angular displacement between two interconnected stations is ___ |
| 323 | In a tap changing transformer, the tappings are ___ |
| 324 | Corona usually occurs when the electrostatic stress in ___ |
| 325 | In A.C.S.R. conductors, the insulation between aluminium and ___ |
| 326 | There is a greater possibility of occurence of ___ |
| 327 | As compared to a 2-wire D.C. distributor, a 3-wire distributor with same ___ |
| 328 | Transmission line insulators are made of ___ |
| 329 | High voltage transmission lines use ___ |
| 330 | Which of the following D.C. distribution system is the simplest and lowest in first cost? |
| 331 | The square root of the ratio of line impedance and shunt admittance is ___ |
| 332 | If variable part of annual cost on account of interest and depreciation on the ___ |
| 333 | Earthing is necessary to give protection against ___ |
| 334 | The string efficiency of an insulator can be ___ |
| 335 | By using bundled conductors which of the following is reduced? |
| 336 | A.C.S.R. conductor having 7 steel stands surrounded by ___ |
| 337 | A synchronous condenser is generally installed at the of ___ |
| 338 | By which of the following factors is the sag of a transmission line least affected? |
| 339 | Which of the following are connected by the service mains? |
| 340 | In context of corona, if the conductors are polished and smooth, which of ___ |
| 341 | By which of the following methods voltage of transmission can be regulated? |
| 342 | When an alternator connected to the bus-bar is shut, down the ___ |
| 343 | Which of the following equipment, for regulating the voltage in distribution feeder, will be most economical? |
| 344 | A conductor due to sag between two supports, takes the ___ |
| 345 | Which of the following is not a constituent for making porcelain insulators? |
| 346 | A uniformly-loaded D.C. distributor is fed at both ends with ___ |
| 347 | The material generally used for armour of high voltage cables is ___ |
| 348 | The conductors of the overhead lines are ___ |
| 349 | Due to which of the following reasons the cables should not, be operated too hot? |
| 350 | The phenomenon of rise in voltage at the receiving end of ___ |
| 351 | Ground wire is used to ___ |
| 352 | The ground ring transmission lines are ___ |
| 353 | To increase the capacity of a transmission line for transmitting power which of ___ |
| 354 | If the height of transmission tower is increased, which of the following; parameters is likely to change? |
| 355 | Induction regulators are used for ___ |
| 356 | The limit of distance of transmission line may be ___ |
| 357 | On which of the following does the size of a feeder depend? |
| 358 | Which of the following has least effect on corona? |
| 359 | In transmission and distribution system the ___ |
| 360 | The frequency of voltage generated, in case of generators, can be ___ |
| 361 | For aluminium, as compared to copper, all the following ___ |
| 362 | For which of the following equipment current rating is not necessary? |
| 363 | Skin effect is proportional to ___ |
| 364 | Which of the following materials is used for overhead transmission lines? |
| 365 | Transmitted power remaining the same, if supply voltage of ___ |
| 366 | In transmission lines the cross-arms are made of ___ |
| 367 | Which of the following is the source of heat generation in the cables? |
| 368 | The underground system cannot be ___ |
| 369 | The charging current in the cables ___ |
| 370 | The electrostatic stress in underground cables is ___ |
| 371 | Conductors for high voltage transmission lines are suspended from ___ |
| 372 | Which of the following can be used for bus-bars? |
| 373 | The purpose of using a booster is ___ |
| 374 | Corona results in ___ |
| 375 | In A.C.S.R. conductor the function of steel is ___ |
| 376 | When the interconnector between two stations has ___ |
| 377 | For transmission of power over a distance of 200 km, the ___ |
| 378 | A circuit is disconnected by isolators when ___ |
| 379 | Which of the following regulations is considered best? |
| 380 | A 3-phase 4 wire system is commonly used on ___ |
| 381 | In a D.C. 3-wire distributor using balancers and having ___ |
| 382 | The surge resistance of cables is ___ |
| 383 | The effective resistance of a conductor will be the same as ___ |
| 384 | System grounding is done so ___ |
| 385 | For exact compensation of voltage drop in the feeder the ___ |
| 386 | Which of the following equipment is used to limit short-circuit current level in a substation? |
| 387 | If string efficiency is 100 percent it ___ |
| 388 | In which of the following voltage regulators the effect of dead zero is found? |
| 389 | The top most conductor in a high transmission line is ___ |
| 390 | The following system is not generally ___ |
| 391 | In the analysis of which of the following lines shunt capacitance is neglected? |
| 392 | Aluminium has a specific gravity of ___ |
| 393 | By which of the following a bus-bar is rated? |
| 394 | Transmission voltage of 11 kV is normally used for ___ |
| 395 | The power transmitted will be maximum when ___ |
| 396 | In a D.C. 3-wire distribution system, balancer fields are ___ |
| 397 | The power factor of industrial loads is ___ |
| 398 | The voltage of the single phase supply to residential consumers is ___ |
| 399 | The operating voltage of extra high tension cables is ___ |
| 400 | The corona is considerably affected by which of the following? |
| 401 | By which of the following systems electric power may be transmitted? |
| 402 | The colour of the neutral of three-core flexible cable is ___ |
| 403 | Floating neutral, in 3-phase supply, is undesirable because it ___ |
| 404 | In overhead transmission lines the effect of capacitance can be ___ |
| 405 | In medium transmission lines the shunt capacitance is ___ |
| 406 | The material used for the manufacture of ___ |
| 407 | The angle between the rotor poles and stator poles, in ___ |
| 408 | The speed of the synchronous motor ___ |
| 409 | In a circuit breaker ionisation is not facilitated by ___ |
| 410 | The over-voltage surges in power systems may be caused by ___ |
| 411 | The use of oil immersed reactors is generally restricted upto ___ |
| 412 | Which fuse material is more susceptible to oxidation as compared to the remaining? |
| 413 | Least number of faults are generally reported for ___ |
| 414 | A circuit breaker will normally operate ___ |
| 415 | Air used in air blast circuit breaker ___ |
| 416 | A fuse wire possesses |
| 417 | The information to the circuit breaker under fault conditions is ___ |
| 418 | A fuse is never inserted in ___ |
| 419 | The power loss is an important factor for the ___ |
| 420 | Air blast circuit breakers for 400 kV power system are ___ |
| 421 | Which of the following devices will receive voltage surge first travelling on the transmission line? |
| 422 | ___ relays are used for phase faults on long line |
| 423 | Discrimination between in a in and back up protection is provided by ___ |
| 424 | To protect most of the electrical equipment handling low ___ |
| 425 | The time of closing the cycle, in modern circuit breakers is ___ |
| 426 | When a transmission line is energized, the wave that propagates on ___ |
| 427 | Circuit breakers are essentially ___ |
| 428 | Thermal circuit breaker has ___ |
| 429 | The main function of a fuse is ___ |
| 430 | The most serious result of a major uncleared short-circuit fault could be ___ |
| 431 | Which of the following protective devices can be used against lightning surges? |
| 432 | Basically a lightning arrester is ___ |
| 433 | The pilot relay is provided to ___ |
| 434 | In a circuit breaker the time duration from the instant of the fault to ___ |
| 435 | The transient voltage that appears across the contacts at ___ |
| 436 | A short-circuit is identified by ___ |
| 437 | Protection by fuses is generally not ___ |
| 438 | The inductive interference between power and communication line can be ___ |
| 439 | The single phasing relays are used for ___ |
| 440 | The short circuit in any winding of the transformer is ___ |
| 441 | With which of the following a circuit breaker must be equipped for remote operation? |
| 442 | In a circuit breaker ionisation is not ___ |
| 443 | The over-voltage surges in power systems may be ___ |
| 444 | Current limiting reactors may be ___ |
| 445 | The use of oil immersed reactors is ___ |
| 446 | The under voltage relay can be ___ |
| 447 | Bus coupler is very essential in ___ |
| 448 | The interaction between a transmission line and communication line is minimized |
| 449 | Resistance grounding is used for ___ |
| 450 | Interruption of large currents by ___ |
| 451 | A differential relay measures the ___ |
| 452 | The relay operating speed depends ___ |
| 453 | Fault diverters are ___ |
| 454 | The contact space in circuit breakers is ___ |
| 455 | Which portion of transmission system is least prone to faults? |
| 456 | A lightning arrester provides ___ |
| 457 | An arc in a circuit behaves like ___ |
| 458 | The total time for high speed breakers in ___ |
| 459 | In a contactor, interrupting medium may be ___ |
| 460 | A switchgear is device used for ___ |
| 461 | On which of the following effects of electric current a fuse operates? |
| 462 | If the fault occurs near the impedance relay, the V/I ratio will be ___ |
| 463 | ___ transmission line has reflection coefficient as one |
| 464 | A ___ is used to measure the stator winding temperature of the generator |
| 465 | To reduce short circuit fault currents ___ |
| 466 | Which of the following is the least expensive protection for overcurrent is low voltage system? |
| 467 | Overheating of relay contacts or contact born out is ___ |
| 468 | Directional relays are based on ___ |
| 469 | D.C. shunt relays are made of ___ |
| 470 | In the event, of a fault on connected circuit, a circuit breaker will ___ |
| 471 | Breaking capacity of a circuit breaker is usually expressed in ___ |
| 472 | Which of the following is used in liquid fuses? |
| 473 | Oil switches are employed for ___ |
| 474 | The material used for fuse must have ___ |
| 475 | Arc in a circuit breaker is ___ |
| 476 | For which of the following ratings of the transformer differential protection is recommended? |
| 477 | Short-circuit currents are due to ___ |
| 478 | For the protection of power station buildings against ___ |
| 479 | The delay fuses are used for ___ |
| 480 | In a circuit breaker the basic problem is ___ |
| 481 | Burden of a protective relay is ___ |
| 482 | Magnetic circuit breaker has ___ |
| 483 | Which of the following medium is employed for extinction of arc in air circuit breaker? |
| 484 | The advantage of neutral earthing is ___ |
| 485 | Surge modifiers are used to ___ |
| 486 | An earth conductor provided on the top of the transmission line ___ |
| 487 | In circuit breakers, the advantage of using oil as ___ |
| 488 | Minimum arcing voltage will be least in ___ |
| 489 | In a single bus-bar system there will be ___ |
| 490 | The fuse rating is expressed in terms of ___ |
| 491 | Which of the following circuit breakers has high reliability and minimum maintenance? |
| 492 | Distance relays are generally ___ |
| 493 | Pick the right statement from the following? |
| 494 | The reflection co-efficient at the open circuited end of ___ |
| 495 | The ground wire should not be smaller than ___ |
| 496 | Ionization in circuit breaker is ___ |
| 497 | An efficient and a well designed protective relaying should ___ |
| 498 | Thermal overload relays are used to protect the motor against over ___ |
| 499 | The arcing contacts in a circuit breaker are ___ |
| 500 | SF6 gas is transported in ___ |
| 501 | The main factor in favour of the use of aluminium as ___ |
| 502 | Reactance relays are used for phase fault in ___ |
| 503 | ____ gives rise to symmetrical fault? |
| 504 | H.R.C. fuses provide best protection in ___ |
| 505 | A balanced 3-phase system consists of ___ |
| 506 | H.R.C. fuse, as compared to a rewirable fuse, has ___ |
| 507 | Series capacitors are used ___ |
| 508 | Series reactors should have ___ |
| 509 | ____ relay is preferred for phase fault on ___ |
| 510 | A.C. network analyser is used to ___ |
| 511 | Ungrounded neutral transmission system is not recommended because of ___ |
| 512 | H.R.C. fuses provide best protection against ___ |
| 513 | The voltage appearing across the contacts after opening of ___ |
| 514 | Air blast circuit breaker is ___ |
| 515 | Overload relays are of ___ |
| 516 | SF6 gas ___ |
| 517 | Outdoor switchgear is generally used for ___ |
| 518 | The material used for bus-bars should ___ |
| 519 | Merz-Price protection is used for ___ |
| 520 | The rating of a circuit breaker is generally determined on ___ |
| 521 | Which of the following relays is used for protection of motors against overload? |
| 522 | To limit short-circuit current in a power system ___ |
| 523 | A fuse is ___ |
| 524 | Overfluxing protection is recommended for ___ |
| 525 | Which of the following parameter can be neglected for a short line? |
| 526 | For which of the following protection from negative sequence currents is provided? |
| 527 | Induction cup relay is operated due to ___ |
| 528 | Wave trap is used to ___ |
| 529 | Insulation resistance of high voltage circuit breakers is ___ |
| 530 | Protective relays are devices that detect abnormal conditions in ___ |
| 531 | The current zero interruption, in oil and air blast circuit breakers, is ___ |
| 532 | Relays can be designed to respond to ___ |
| 533 | Capillary tube is generally made up of ___ |
| 534 | Which system is not used in ___ |
| 535 | Freezing point of water is ___ |
| 536 | WhÃch is not a part of electrical system in ___ |
| 537 | Hot water of condenser is ___ |
| 538 | Belt driven unit is ___ |
| 539 | The purpose of a dehydrator is ___ |
| 540 | What is the cause of a pump runs ___ |
| 541 | Which is the type of liquid circulating pump out of ___ |
| 542 | Out of which is not a part of ___ |
| 543 | Freon gas is a ___ |
| 544 | Out of following which is ___ |
| 545 | Generally which gas is used in ___ |
| 546 | How much temperature is maintained in freezer of ___ |
| 547 | For voltage regulation for domestic refrigerator which is ___ |
| 548 | Motor used for a domestic refrigerators is ___ |
| 549 | The refrigeration process is ___ |
| 550 | Refrigeration capacity is measured in ___ |
| 551 | Mercury, in arc rectifiers, is chosen for ___ |
| 552 | Normally, which of the following is used, when ___ |
| 553 | Which of the following are the applications of D.C. system? |
| 554 | A commutating rectifier consists of ___ |
| 555 | The metal rectifiers are preferred to valve rectifiers due to which of the following advantages? |
| 556 | Which of the following rectifiers are primarily used for charging of ___ |
| 557 | Choose incorrect statement from the following? |
| 558 | On which of the following factors the number of phases for ___ |
| 559 | To produce cathode spot in a ___ |
| 560 | Which of the following rectifiers have been used extensively in ___ |
| 561 | In a phase-shift control method, the phase shift, between anode and ___ |
| 562 | In a mercury arc rectifier ___ |
| 563 | If cathode and anode connections in a mercury arc rectifier are ___ |
| 564 | In a rotary converter I2R losses as compared to a D.C. generator of ___ |
| 565 | Which of the following metals is generally manufactured by electrolysis process? |
| 566 | The applications of selenium rectifiers are usually limited to ___ |
| 567 | In phase-shift control method the control is carried out by ___ |
| 568 | In a glass bulb mercury arc rectifier the maximum current rating is ___ |
| 569 | The internal efficiency of a mercury arc rectifier depends on ___ |
| 570 | In which of the following equipment direct current is needed? |
| 571 | Which of the following is reversible in action? |
| 572 | The ignited or auxiliary anode in mercury arc rectifier is ___ |
| 573 | Ageing of a selenium rectifier may change the ___ |
| 574 | In mercury arc rectifiers having grid, the arc can be ___ |
| 575 | Which of the following mercury arc rectifier will deliver least undulating current? |
| 576 | The voltage drop at anode, in a mercury arc rectifier is ___ |
| 577 | In a rotary converter armature currents are ___ |
| 578 | A rotary converter combines the ___ |
| 579 | In a mercury arc rectifier, the anode is ___ |
| 580 | In selenium rectifiers efficiencies ranging from ___ |
| 581 | In a mercury arc rectifier characteristic blue luminosity is ___ |
| 582 | Glass rectifiers are usually made into units capable of ___ |
| 583 | Which of the following A.C. motors is usually used in large motor-generator sets? |
| 584 | A rotary converter is a single machine with ___ |
| 585 | The metal rectifiers, as compared to mercury arc ___ |
| 586 | Selenium rectifier can be operated at temperatures as ___ |
| 587 | In a three-phase mercury arc rectifiers each ___ |
| 588 | The voltage drop between the anode and cathode, of ___ |
| 589 | In which of the following applications, direct current is absolutely essential? |
| 590 | A synchronous converter can be ___ |
| 591 | Which of the following is the loss within the mercury arc rectifier chamber? |
| 592 | Copper oxide rectifier is usually designed not to ___ |
| 593 | It is the ___ of the transformer on which the magnitude of angle of overlap |
| 594 | In a mercury pool rectifier the voltage drop across its ___ |
| 595 | The potential drop in the arc, in ___ |
| 596 | A rotary converter operates at ___ |
| 597 | The efficiency of an electrolytic rectifier is ___ |
| 598 | The efficiency of the copper oxide rectifier seldom ___ |
| 599 | A mercury arc rectifier possesses ___ |
| 600 | The advantage of mercury arc rectifier is ___ |
| 601 | The ionization potential of mercury is ___ |
| 602 | A rotary converter in general construction and design, is ___ |
| 603 | A network consists of linear resistors and ___ |
| 604 | Two resistors R1 and R2 give combined resistance of 4.5 ω when in ___ |
| 605 | If the length of a wire of resistance R is uniformly stretched to ___ |
| 606 | Three parallel resistive branches are connected across ___ |
| 607 | Temperature co-efficient of resistance is ___ |
| 608 | The resistance of a few metres of wire conductor in ___ |
| 609 | The resistance of a parallel circuit consisting of ___ |
| 610 | Conductance is reciprocal of ___ |
| 611 | Two copper conductors have ___ |
| 612 | A 3 ω resistor having 2 A current will dissipate the ___ |
| 613 | A light bulb draws 300 mA when the voltage across it is ___ |
| 614 | The resistance of a conductor varies inversely as ___ |
| 615 | With three resistances connected in parallel, if ___ |
| 616 | Specific resistance of a substance is ___ |
| 617 | In a series circuit with unequal ___ |
| 618 | In a circuit a 33 ω resistor carries a current of ___ |
| 619 | Voltage dependent resistors are used |
| 620 | The temperature coefficient of resistance of ___ |
| 621 | Resistance of a material always decreases if ___ |
| 622 | Varistors are ___ |
| 623 | The resistance of two wires is 25 ω when connected in ___ |
| 624 | Voltage dependent resistors are usually made from ___ |
| 625 | Which of the following quantities remain the same in all parts of a series circuit? |
| 626 | A resistance having rating 10 ohms, 10 W is ___ |
| 627 | Three resistances of 10 ohms, 15 ohms and 30 ohms are ___ |
| 628 | An open resistor, when checked with an ___ |
| 629 | Heat in a conductor is produced on the passage of ___ |
| 630 | Two resistors are said to be connected in ___ |
| 631 | The resistance of a copper wire 200 m long is ___ |
| 632 | A rheostat differs from potentiometer in ___ |
| 633 | A closed switch has a resistance of ___ |
| 634 | You have to replace 1500 ω resistor in ___ |
| 635 | Which resistor will be physically larger in size? |
| 636 | Two resistances R1 and R2 are connected in series across the ___ |
| 637 | A current of 16 amperes divides between two branches in parallel of ___ |
| 638 | With rise in temperature the resistance of ___ |
| 639 | Which of tite following materials has the least resistivity? |
| 640 | If a wire conductor of 0.2 ohm resistance is doubled in ___ |
| 641 | Four wires of same material, the same cross-sectional area and the ___ |
| 642 | For which of the following substances the temperature co-efficient of resistivity is positive? |
| 643 | The temperature coefficient of resistance of some material is ___ |
| 644 | The specific resistance of ___ |
| 645 | The example of non-ohmic resistance is ___ |
| 646 | The specific resistance of all metals is ___ |
| 647 | The resistance of a straight conductor does not ___ |
| 648 | Which of the following is an ohmic conductor? |
| 649 | In a circuit containing two unequal resistors connected in ___ |
| 650 | Three resistances each of R Ω are corrected to ___ |
| 651 | The temperature-coefficient of resistance of ___ |
| 652 | In an ordinary heater if the length of the coil is halved, then ___ |
| 653 | The insulation resistance of a cable of length 10 km is ___ |
| 654 | In the case of diamagnetic materials, the magnetic susceptibly is ___ |
| 655 | Which of the following is the unit of magnetic flux density? |
| 656 | Substances winch have permeability less than the permeability of ___ |
| 657 | The unit of relative permeability is ___ |
| 658 | The direction of magnetic lines of force is ___ |
| 659 | In order tominimise loss due to hysteresis the ___ |
| 660 | In case all the flux from the current in coil 1 links with ___ |
| 661 | There is a constant homogeneous magnetic field pointing in ___ |
| 662 | Linkage flux per unit current is ___ |
| 663 | Reluctance offered by the magnetic circuit ___ |
| 664 | When a plane wave propagates in ___ |
| 665 | The magnetic field strength of an air-cored coil can be ___ |
| 666 | The hysteresis loss is ___ |
| 667 | The shape of B-H curve for air gap is___ |
| 668 | The coupling between two magnetically coupled coils is ___ |
| 669 | Lower the self inductance of ___ |
| 670 | A ferromagnetic core subjected to cycles of magetisation will ___ |
| 671 | Two parallel wires separated by a distance dare carrying ___ |
| 672 | Hard steel is suitable for making permanent magnets because ___ |
| 673 | The conductance of electrical circuit is ___ |
| 674 | Those magnetic materials are best suited for making armature and ___ |
| 675 | If a current carrying conductor is placed in ___ |
| 676 | An air gap is usually inserted in magnetic circuits to ___ |
| 677 | A ferrite core has less eddy current loss than ___ |
| 678 | If the area of hysteresis loop of a material is large, the ___ |
| 679 | The relative permeability of a ferromagnetic material is ___ |
| 680 | The transformer cores operating at microwave frequency range, are ___ |
| 681 | The unit of reluctance is ___ |
| 682 | Those materials are well suited for making permanent magnets which have ___ |
| 683 | Permanent magnets are normally made of ___ |
| 684 | According to steinmetz hysteresis law, hysteresis loss in a material is ___ |
| 685 | When a piece of iron is placed in ___ |
| 686 | While comparing magnetic and electric circuits, the flux of ___ |
| 687 | Choose the correct statement(s) from the following? |
| 688 | In a magnetic material hysteresis loss takes place primarily due to ___ |
| 689 | The magnetising force (H) and magnetic flux density (B) are connected by ___ |
| 690 | Permeance is to reluctance as ___ |
| 691 | Reciprocal of reluctance is ___ |
| 692 | Conductivity is analogous to ___ |
| 693 | Relative permeability of vacuum is ___ |
| 694 | The area of hysteresis loss is a measure of ___ |
| 695 | The unit of retentivity is ___ |
| 696 | A material for good magnetic memory should have ___ |
| 697 | Point out the wrong statement ___ |
| 698 | Laminated cores, in electrical machines, are used to ___ |
| 699 | The property of a material which opposes the creation of ___ |
| 700 | The initial rate of rise of current through a coil of ___ |
| 701 | Permeability in a magnetic circuit corresponds to ___ |
| 702 | Conductance is analogous to ___ |
| 703 | When both the inductance and resistance of ___ |
| 704 | The unit of magnetic flux is ___ |
| 705 | For a perfect conductor, the field strength at a distance equal to ___ |
| 706 | In order to minimise loss due to hysteresis, the magnetic material should have ___ |
| 707 | Silicon steel is used in electrical machines because ___ |
| 708 | The rate of rise of current through an inductive coil is ___ |
| 709 | Which of the following statements should be true if one compares the ___ |
| 710 | The coils having self-inductance of 10 mH and 15 mH and ___ |
| 711 | For which of the following materials the net magnetic moment should be zero? |
| 712 | If in an iron cored coil the iron core is removed so ___ |
| 713 | How does the magnetic compass needle behave in a magnetic field? |
| 714 | In all cases of electromagnetic induction, an induced voltage will ___ |
| 715 | The uniform magnetic field is ___ |
| 716 | The force per unit length between two stationary parallel ___ |
| 717 | A permanent magnet ___ |
| 718 | A coil wound over an iron ring carries certain ___ |
| 719 | The tubes of force within the magnetic material are ___ |
| 720 | Two coils having equal resistances but different inductances are ___ |
| 721 | The magnitude of force acting on a current carrying conductor placed in ___ |
| 722 | When two ends of a circular uniform wire are joined to the terminals of ___ |
| 723 | Which of the following associated with magnetic field is correct? |
| 724 | The magnetism left in the iron after exciting field has been removed is known as |
| 725 | In a magnetic material, hysteresis loss takes ___ |
| 726 | The magnetic susceptibility of ___ |
| 727 | A conductor of length L has current I passing through ___ |
| 728 | The magnetic field required to reduce the residual magnetisation to ___ |
| 729 | The overall inductance of two coils connected in series, with ___ |
| 730 | Tesla is a unit of ___ |
| 731 | Strength of an electromagnet can be ___ |
| 732 | The magnitude of induced emf in a conductor depends upon ___ |
| 733 | If the two conductors carry current in opposite directions there will ___ |
| 734 | Which part of the magnetic path requires largest m.m.f? |
| 735 | An electric field is parallel but opposite to ___ |
| 736 | If a copper disc is rotated rapidly below a freely suspended ___ |
| 737 | Supermagnetic materials are composed of ___ |
| 738 | The change of cross-sectional area of conductor in ___ |
| 739 | What is the value of the magnetic vector potential due to ___ |
| 740 | If a copper disc is rotated rapidly below a ___ |
| 741 | A keeper is used for ___ |
| 742 | Supermagnetic materials are ___ |
| 743 | The commonly used material for shielding or ___ |
| 744 | One maxwell is equal to ___ |
| 745 | The relative permeability is less than unity is ___ |
| 746 | Degaussing is the process of ___ |
| 747 | The left hand rule correlates to ___ |
| 748 | Air gap has ___ reluctance as compared to iron or steel path |
| 749 | Main causes of noisy solenoid are ___ |
| 750 | The susceptibility of paramagnetic materials generally lies between ___ |
| 751 | The magnetic reluctance of ___ |
| 752 | An electromagnetic field is ___ |
| 753 | A keeper is used to ___ |
| 754 | The energy stored in the magnetic field of ___ |
| 755 | The most effective and quickest may of ___ |
| 756 | The area of hysteresis loop is ___ |
| 757 | When a magnet is in motion relative to ___ |
| 758 | The coercive force in a ferromagnetic material is ___ |
| 759 | Reciprocal of permeability is ___ |
| 760 | Paramagnetic materials have relative permeability ___ |
| 761 | Magnetising steel is normals difficult because ___ |
| 762 | The laws of electromagnetic induction ___ |
| 763 | Ferrites are ___ |
| 764 | Temporary magnets are used in ___ |
| 765 | Which of the following type of materials are not very important for engineering applications? |
| 766 | At a certain current, the energy stored in an iron-cored coil is ___ |
| 767 | An infinitely long straight conductor located along Z-axis carries a ___ |
| 768 | A certain amount of current flows through a ringshaped coil with ___ |
| 769 | A rectangular magnet of magnetic moment M is ___ |
| 770 | The electromagnet has 50 turns and a current of ___ |
| 771 | Materials subjected to rapid reversals of ___ |
| 772 | Out of the following statements, concerning an electric field, which statement is not true? |
| 773 | The working of a meter is based on the use of ___ |
| 774 | The principle of dynamically induced emf is ___ |
| 775 | The use of permanent magnets is ___ |
| 776 | According to Faraday’s law of electromagnetic induction an ___ |
| 777 | The ratio of intensity of magnetisation to the magnetisation force is known as ___ |
| 778 | Choose which the following statements is a correct statement? |
| 779 | Aluminium and platinum are ___ |
| 780 | The force experienced by a current carrying conductor lying parallel to ___ |
| 781 | Magnetism of a magnet can be destroyed by ___ |
| 782 | In which of the materials the spin moments associated with ___ |
| 783 | Which of the following materials are diamagnetic? |
| 784 | Choose correct statements from the below? |
| 785 | Hysteresis loop in case of magnetically hard materials is ___ |
| 786 | A 200 turn coil having an axial length of 30 mm and a radius of ___ |
| 787 | Gilbert is a unit of ___ |
| 788 | The main constituent of permalloy is ___ |
| 789 | Fleming’s left hand rule is ___ |
| 790 | A magnet does not ___ |
| 791 | The magnetisation and applied field in ferromagnetic materials are ___ |
| 792 | What will be the magnetic potential difference across the ___ |
| 793 | The ____ materials are a bit inferior conductors of magnetic flux than air |
| 794 | The Biot-savart’s law is ___ |
| 795 | A 300 mm long conductor is carrying a current of 10 A and is ___ |
| 796 | One tesla is equal to ___ |
| 797 | Ferrites are a sub-group of ___ |
| 798 | Indicate which of the following material does not ___ |
| 799 | When an iron piece is placed in ___ |
| 800 | A magnetic field exists ___ |
| 801 | Pick the correct from the following statements? |
| 802 | The stray line of magnetic flux is defined as ___ |
| 803 | What will be the current passing through the ___ |
| 804 | The relative permeability of ___ |
| 805 | Unit for quantity of electricity is ___ |
| 806 | Two long parallel conductors carry ___ |
| 807 | Which of the following is expected to have the maximum permeability? |
| 808 | Which of the following is a ferromagnetic material? |
| 809 | A coil with a certain number of turns has a ___ |
| 810 | Materials subjected to rapid reversal of magnetism should have ___ |
| 811 | A material which is slightly repelled by ___ |
| 812 | Two conducting thin coils X and ___ |
| 813 | The materials having low retentivity are ___ |
| 814 | Mutual inductance between two magnetically coupled coils depends on ___ |
| 815 | The attraction capacity of electromagnet will increase if ___ |
| 816 | When a single turn coil rotates in a uniform magnetic field, at ___ |
| 817 | In a simple magnetic field the strength of ___ |
| 818 | The magneto-motive force is ___ |
| 819 | An air gap is usually inserted in ___ |
| 820 | The retentivity (a property) of material is useful for ___ |
| 821 | Which of the following statements holds of the divergence of ___ |
| 822 | The unit of flux is the same as ___ |
| 823 | Remanent magnetism is ___ |
| 824 | Susceptibility is positive for ___ |
| 825 | Which of the following is not a unit of flux? |
| 826 | In the left hand rule, forefinger always ___ |
| 827 | The force between two long parallel conductors is ___ |
| 828 | The two conductors of a transmission line carry equal current ___ |
| 829 | When a battery of E volts is suddenly applied across an ___ |
| 830 | Magnetostriction is a phenomenon whereby the magnetisation of ___ |
| 831 | Two identical coils of negligible resistance, when connected in series across a ___ |
| 832 | The field at any point on the axis of a current carrying coil will be ___ |
| 833 | Two coils are coupled in such a way that the mutual inductance between ___ |
| 834 | The inductance of a long solenoid of length 1,000 mm wound ___ |
| 835 | A magnetic circuit requires 800 AT to produce a certain quantity of ___ |
| 836 | The magnetic field intensity (in A/m) at the centre of ___ |
| 837 | For which of the following applications motor has to start with high acceleration? |
| 838 | Which of the following motors is preferred when smooth and ___ |
| 839 | In case of ___ speed control by injecting e.m.f. in the rotor circuit is possible |
| 840 | ___ has relatively wider range of speed control |
| 841 | Belted slip ring induction motor is almost invariably used for ___ |
| 842 | Which of the following motors are best for the rolling mills? |
| 843 | Which of the following motors are preferred for overhead travelling cranes? |
| 844 | The selection of an electric motor for any application depends on which of the following factors? |
| 845 | For a D.C. shunt motor which of the following is incorrect? |
| 846 | Which of the following motors is preferred when quick speed reversal is the main consideration? |
| 847 | ___ has the least value of starting torque to full load torque ratio |
| 848 | Heat control switches are used in ___ |
| 849 | For blowers which of the following motors is preferred? |
| 850 | The starting torque in case of centrifugal pumps is ___ |
| 851 | While selecting an electric motor for a floor mill, which ___ |
| 852 | For a particular application the type of electric and ___ |
| 853 | Which of the following happens when star-delta starter is used? |
| 854 | By the use of which of the following D.C. can be obtained from A.C.? |
| 855 | ___ has least range of speed control |
| 856 | Which of the following motors is usually preferred for kiln drives? |
| 857 | The size of an excavator is usually expressed in ___ |
| 858 | ___ motor is a constant speed motor |
| 859 | Light duty cranes are used in which of the following? |
| 860 | In series motor which of the following methods can ___ |
| 861 | Which of the following motors has series characteristics? |
| 862 | Besides a constant speed a synchronous rotor possesses which of the following advantages? |
| 863 | Battery operated scooter for ___ |
| 864 | For a motor-generator set which of the following motors will be preferred? |
| 865 | A reluctance motor ___ |
| 866 | Which feature, while selecting a motor for centrifugal pump, will be of least significance? |
| 867 | The load cycle for a motor driving a power press will be ___ |
| 868 | The cost of an induction motor will ___ |
| 869 | A wound rotor induction motor is preferred, as compared to ___ |
| 870 | The travelling speed of cranes varies from ___ |
| 871 | For derries and winches which of the following drives can be used? |
| 872 | In jaw crushers a motor has to often start against ___ |
| 873 | In a paper mill where constant speed is ___ |
| 874 | ___ need frequent starting and stopping of electric motors |
| 875 | When the load is above ___ |
| 876 | Which of the following alternatives will be cheaper? |
| 877 | Which of the following motors is preferred for boom hoist of a travelling crane? |
| 878 | Heavy duty cranes are used in ___ |
| 879 | Which of the following machines has heavy fluctuation of load? |
| 880 | In ___ method of starting three phase induction motors the starting voltage |
| 881 | For which of the following applications ‘D.C. motors are still preferred? |
| 882 | Which part of a motor needs maximum attention for maintenance? |
| 883 | ___ is preferred for automatic drives |
| 884 | The diameter of the rotor shaft for an electric motor depends on ___ |
| 885 | The characteristics of drive for crane hoisting and lowering are which of the following? |
| 886 | In which of the following applications variable speed operation is preferred? |
| 887 | Flame proof motors are ___ |
| 888 | ___ method of starting a three phase induction motor needs six terminals |
| 889 | Rotor of a motor is usually supported on ___ |
| 890 | Which of the following motors is used for elevators? |
| 891 | Which of the following motors always starts on load? |
| 892 | While selecting motor for an air conditioner which of ___ |
| 893 | The capacity of a crane is expressed in ___ |
| 894 | In ___ the speed can be varied by changing the position of brushes |
| 895 | In which of the following application the load on motor changes in cyclic order? |
| 896 | Reluctance motor is ___ |
| 897 | The starting torque of a D.C. motor is independent of which of the following? |
| 898 | Ward-Leonard controlled D.C. drives are generally used ___ |
| 899 | Which of the following motors is preferred for traction work? |
| 900 | Which of the following types of motor enclosure is safest? |
| 901 | For crane travel which of the following motors is normally used? |
| 902 | A pony motor is used for the starting which of the following motors? |
| 903 | In squirrel cage induction motors which of the following methods of starting cannot be used? |
| 904 | Which of the following is essentially needed while selecting a motor? |
| 905 | ___ is not a part of ball bearing? |
| 906 | ___ is preferred for synthetic fibre mills |
| 907 | Reflectors are provided with slits at ___ |
| 908 | Stroboscopic effect due to use of discharge lamps in ___ |
| 909 | Sometimes the wheels of rotating machinery, under the influence of ___ |
| 910 | In electric discharge lamps for ___ |
| 911 | Due to moonlight, illumination is ___ |
| 912 | On which of the following factors does the depreciation or maintenance factor depend? |
| 913 | Fine diameter tungsten wires are ___ |
| 914 | Soft shadows are produced by ___ |
| 915 | In an incandescent lamp bird cage filament is usually used in ___ |
| 916 | A mercury vapour lamp gives ___ |
| 917 | Most affected parameter of a filament lamp due to ___ |
| 918 | ___ will need lowest level of illumination |
| 919 | Desired illumination level on the working plane ___ |
| 920 | The filament of a GLS lamp is ___ |
| 921 | Luminous efficiency of a fluorescent tube is ___ |
| 922 | A poor man for his kitchen will make use of ___ |
| 923 | The vapour discharge tube used for domestic lighting has ___ |
| 924 | In case of ___ power factor is the power factor |
| 925 | In sodium vapour lamp the function of the leak transformer is ___ |
| 926 | The purpose of coating the fluorescent tube from inside with ___ |
| 927 | Carbon arc lamps are commonly used in ___ |
| 928 | Filament lamps operate normally at a power factor of ___ |
| 929 | The level of illumination on a ___ |
| 930 | Sky appears blue because of ___ |
| 931 | A substance which change its electrical resistance when ___ |
| 932 | ___ does not have separate choke |
| 933 | A reflector is provided to ___ |
| 934 | The colour of sodium vapour discharge lamp is ___ |
| 935 | The unit of luminous flux is ___ |
| 936 | Choose the correct statements from the following? |
| 937 | The tungsten filament lamps when compared with fluorescent tubes have ___ |
| 938 | Due to which of the following reasons the light of a tube appears cooler than that of a bulb? |
| 939 | The gas filled in vacuum filament lamps is ___ |
| 940 | In electric discharge lamps light is ___ |
| 941 | The function of capacitor across the supply to ___ |
| 942 | Filament lamp at starting will take ____ |
| 943 | The illumination is directly proportional to the cosine of ___ |
| 944 | A solid angle is expressed in terms of ___ |
| 945 | When a fluorescent lamp is to be operated on ___ |
| 946 | When an electric bulb is broken it produces bang, this is ___ |
| 947 | Which gas can be filled in GLS lamps? |
| 948 | For normal reading the illumination level required is ___ |
| 949 | ___ cannot sustain much voltage fluctuations |
| 950 | In houses the illumination is in ___ |
| 951 | Illumination of one lumen per square metre is ___ |
| 952 | In incandescent lamps, coiled coil filaments are ___ |
| 953 | Which of the following is present inside the fluorescent tube? |
| 954 | Which of the following applications does not need ultraviolet lamps? |
| 955 | In case of ___ |
| 956 | In the fluorescent tube circuit the function of choke is ___ |
| 957 | For the same power output ___ |
| 958 | Which of the following is not the standard rating of GLS lamps? |
| 959 | Colour of light depends upon ___ |
| 960 | In fluorescent tubes ballast resistance is connected in ___ |
| 961 | Glare is reduced by ___ |
| 962 | The flicker effect of fluorescent lamps is ___ |
| 963 | ___ is a cold cathode lamp |
| 964 | For the same lumen output, the running cost of ___ |
| 965 | Which of the following lamps is the cheapest for the same wattage? |
| 966 | Candela is the unit of which of the following? |
| 967 | In sodium vapour lamp neon gas ___ |
| 968 | Co-efficient of utilisation depends upon ___ |
| 969 | Which of the following bulbs operates on least power? |
| 970 | For precision work the illumination ‘level required is of ___ |
| 971 | Which of the following instruments is used for the comparison of candle powers of different sources? |
| 972 | In lighting circuit using filament lamps 1% voltage drop results ___ |
| 973 | What percentage of the input energy is radiated by filament lamps? |
| 974 | Two 300 μH coils in series without mutual coupling have a ___ |
| 975 | A conductor carries 125 amperes of current under ___ |
| 976 | In case all the flux from the current in ___ |
| 977 | Which of the following circuit elements will oppose the change in circuit current? |
| 978 | The direction of induced e.m.f. can be found by ___ |
| 979 | The property of coil by which a counter e.m.f. is induced in it ___ |
| 980 | Lenz’s law is a consecluence of the law of ___ |
| 981 | Two coils have self-inductances of 10 H and 2 H, the ___ |
| 982 | In case of an inductance, current is ___ |
| 983 | If current in a conductor increases then according to ___ |
| 984 | As per Faraday’s laws of electromagnetic induction, an e.m.f. is ___ |
| 985 | A coil induces 350 mV when the current changes at ___ |
| 986 | A conductor 2 metres long moves at right angles to ___ |
| 987 | A 200 turn coil has an inductance of ___ |
| 988 | Which of the following is not a unit of inductance? |
| 989 | Both the number of turns and the core length of an inductive coil are ___ |
| 990 | Which of the following inductor will have the least eddy current losses? |
| 991 | Two coils have inductances of 8 mH and 18 mH and a co-efficient of ___ |
| 992 | The law that the induced e.m.f. and current always oppose the ___ |
| 993 | A coil is wound on iron core which carries ___ |
| 994 | A 500 turns solenoid develops an average induced voltage of ___ |
| 995 | The self inductances of two coils are ___ |
| 996 | The co-efficient of self-inductance for a coil is ___ |
| 997 | In an iron cored coil the iron core is removed so that the coil becomes an ___ |
| 998 | An average voltage of 10 V is induced in a 250 turns solenoid as ___ |
| 999 | The core of a coil has a length of ___ |
| 1000 | A laminated iron core has reduced eddy-current losses because ___ |
| 1001 | A crack in the magnetic path of an inductor will result in ___ |
| 1002 | The co-efficient of coupling between two ___ |
| 1003 | An e.m.f. of 16 volts is induced in a coil of ___ |
| 1004 | Mutually inductance between two magnetically coupled coils depends on ___ |
| 1005 | The inductance of a coil will increase under all ___ |
| 1006 | Which circuit element(s) will oppose the change in circuit current? |
| 1007 | A coil with negligible resistance has 50 V across it ___ |
| 1008 | Which of the following is unit of inductance? |
| 1009 | The magnitude of the induced e.m.f. in a conductor depends on ___ |
| 1010 | Which of the following circuit element stores energy in the electromagnetic field? |
| 1011 | Current changing from 8 A to 12 A in one second induced 20 volts in ___ |
| 1012 | Find the force acting on a conductor 3m long carrying a current of 50 amperes at ___ |
| 1013 | For a purely inductive circuit which of the following is true? |
| 1014 | Air-core coils are practically free from ___ |
| 1015 | Potential difference across a capacitor of ___ |
| 1016 | When the plate area of a parallel plate capacitor is increased keeping the ___ |
| 1017 | Two electrons moving parallel to each other at the same velocity will ___ |
| 1018 | The relation between the breakdown voltage V and the thickness ___ |
| 1019 | The capacitor charged up to 5 ms, as per the current profile given in the figure, is ___ |
| 1020 | The relation between electric polarization and susceptibility indicates ___ |
| 1021 | The electric field intensity at a point situated at a distanced from ___ |
| 1022 | A condenser suitable for D.C. only is ___ |
| 1023 | To prevent the generation of static charges on rubber or ___ |
| 1024 | The minimum value of potential gradient in a cable occurs in |
| 1025 | The condensers of 20 μF and 40 μF capacitance are connected in ___ |
| 1026 | For a good 0.05 μF capacitor ohmmeter reading should ___ |
| 1027 | The capacitance between two plates increases with ___ |
| 1028 | The time constant and R-C circuit may also be defined as ___ |
| 1029 | ___ is that property of a capacitor which delays any change of voltage across it |
| 1030 | The direction of the lines of force at any point is the direction along which a ___ |
| 1031 | An equipotential surface is one which has all points at ___ |
| 1032 | The area of plates of the parallel plate capacitor, to obtain capacity of ___ |
| 1033 | The units of volume charge density are ___ |
| 1034 | The breakdown voltage for paper capacitors is ___ |
| 1035 | The capacitor preferred for high frequency circuits is ___ |
| 1036 | A capacitor in a circuit became hot and ultimately exploded due to ___ |
| 1037 | When a dielectric slab is introduced in a parallel plate capacitor, the ___ |
| 1038 | Which of the following materials has the highest value of dielectric constant? |
| 1039 | Voltage applied across a ceramic dielectric produces an ___ |
| 1040 | The ability of charged bodies to exert force on one another is ___ |
| 1041 | The force between two charges is ___ |
| 1042 | When a dielectric is placed in an ___ |
| 1043 | A region around a stationary electric charge ___ |
| 1044 | A potential of 400 V is applied to a capacitor, the plates of ___ |
| 1045 | An uncharged conductor is placed near a ___ |
| 1046 | One volt is the same as ___ |
| 1047 | The time constant of an R-C circuit is defined as the ___ |
| 1048 | The property of a capacitor to store electricity is ___ |
| 1049 | Electric intensity at any point in an electric field is equal to ___ |
| 1050 | ___ capacitors are used for audio frequency and radio frequency coupling |
| 1051 | The electrostatic force between two charges of ___ |
| 1052 | Which of the following capacitors will have the least value of breakdown voltage? |
| 1053 | While checking a good 0.05 μF capacitor by ohmmeter, its ___ |
| 1054 | With steady D.C. voltage from a battery applied to a ___ |
| 1055 | Which of the following statements with capacitors is wrong? |
| 1056 | A capacitor charged to 200 V has ___ |
| 1057 | In a capacitive circuit ___ |
| 1058 | The unit of polarization is the same as ___ |
| 1059 | In a capacitor the electric charge is stored in ___ |
| 1060 | Which of the following statement(s) is/are valid in case of conductors in ___ |
| 1061 | If AC. voltage is applied to capacitive circuit, the alternating current can ___ |
| 1062 | The electric field inside a perfectly conducting media is ___ |
| 1063 | An electrolytic capacitor can be ___ |
| 1064 | A field line and an equipotential surface are ___ |
| 1065 | The mass of an electron is ___ |
| 1066 | Which is the most superior dielectric out of the following? |
| 1067 | While testing a capacitor with ohmmeter, if the capacitor shows ___ |
| 1068 | If a third equal and similar charge is placed between two ___ |
| 1069 | Three capacitors each of breakdown voltage 500 V are ___ |
| 1070 | A variable capacitor of 100 μF carries a charge of ___ |
| 1071 | On a conducting surface boundary, electric field lines are ___ |
| 1072 | Out of the following capacitors of identical rating which one will have the smallest dimensions? |
| 1073 | Fields are said to be circularly polarized if ___ |
| 1074 | 1 volt/metre is same as ___ |
| 1075 | Two copper spheres A (hollow) and B (solid) are of ___ |
| 1076 | In a cable capacitor, voltage gradient is maximum at ___ |
| 1077 | Across the surface of ___ |
| 1078 | The relation between the breakdown voltage V and the thickness (t) of ___ |
| 1079 | ___ at a point may be defined as equal to the lines of force passing normally |
| 1080 | The relative permittivity has the ___ |
| 1081 | A single core cable used of 33000 V has ___ |
| 1082 | ___ capacitors are used in transistor circuits |
| 1083 | For closer tolerances which of the following capacitors is usually preferred? |
| 1084 | Which of the following material has least value of dielectric constant? |
| 1085 | When 4 volts e.m.f is applied across ___ |
| 1086 | The unit of capacitance is ___ |
| 1087 | Which of the following expression is correct for electric field strength? |
| 1088 | Two plates of a parallel plate capacitor after being charged from ___ |
| 1089 | A dielectric material must be ___ |
| 1090 | The direction of electric field due to ___ |
| 1091 | A ceramic and a mica capacitor have the ___ |
| 1092 | When a capacitor undergoes a ___ |
| 1093 | The force of attraction or repulsion between ___ |
| 1094 | In order to remove static electricity from ___ |
| 1095 | Voltage applied across a dielectric produces an ___ |
| 1096 | Which medium has the least dielectric strength? |
| 1097 | Dielectric strength ___ |
| 1098 | The value of E within the field due to a point charge can be ___ |
| 1099 | The total deficiency or excess of electrons in ___ |
| 1100 | A capacitor having capacitance of 5 μF is charged to ___ |
| 1101 | ___ capacitors can be used only for D.C |
| 1102 | Paper capacitors usually have a tolerance of ___ |
| 1103 | A mica capacitor and a ceramic capacitor both have the ___ |
| 1104 | Air capacitors are generally available in ___ |
| 1105 | The power dissipated in a pure capacitor is ___ |
| 1106 | A conducting body has surface charge density of ___ |
| 1107 | If three 10 μF capacitors are connected in parallel, the ___ |
| 1108 | The electric field at a point situated at ___ |
| 1109 | If a current of 2 A passes through a lamp for 200 seconds, the number of ___ |
| 1110 | In a multilayer dielectric material on either side of ___ |
| 1111 | A capacitance is a circuit component that opposes the ___ |
| 1112 | A positive and a negative charge are ___ |
| 1113 | An, electrolytic capacitor is generally made to ___ |
| 1114 | Paper condenser is ___ |
| 1115 | A capacitance of ___ |
| 1116 | What will happen to an insulating medium if ___ |
| 1117 | The unit of dielectric strength is ___ |
| 1118 | The unit of electric instensity is ___ |
| 1119 | ___ field is associated with the capacitor |
| 1120 | ___ capacitors are mainly used for radio frequency tuning |
| 1121 | What is the value of capacitance that must be connected in ___ |
| 1122 | The relative permittivity of free space is ___ |
| 1123 | A paper capacitor is usually available in the form of ___ |
| 1124 | In the case of a lossy capacitor, its series equivalent resistance value will be ___ |
| 1125 | For which of the following parameter variation, the capacitance of ___ |
| 1126 | Electric field inside a hollow metallic charged sphere is ___ |
| 1127 | If three 15 μF capacitors are connected in ___ |
| 1128 | The line of force due to charged particles are ___ |
| 1129 | If C be the capacitance, V be the potential difference and ___ |
| 1130 | If the dielectric of a capacitor is replaced by ___ |
| 1131 | Which of the following capacitor is preferred in case of single phase motor? |
| 1132 | Which of the following medium will have highest value of relative permittivity? |
| 1133 | Which of the following capacitors preferred for high frequency circuits? |
| 1134 | The presence of an uncharged conductor near ___ |
| 1135 | If an ohmmeter reading immediately goes practically to ___ |
| 1136 | ___ at a point is equal to the negative potential gradient at that point |
| 1137 | The number of Faraday tubes of flux passing through a ___ |
| 1138 | The potential gradient across the material of ___ |
| 1139 | The dielectric constant (relative permittivity) of ___ |
| 1140 | Which of the following capacitors can be used for temperature compensation? |
| 1141 | For removing static charge from ___ |
| 1142 | Which capacitor will be physically smaller for the same ratings? |
| 1143 | In a cable capacitor, voltage gradient is ___ |
| 1144 | The absolute permittivity of free, space is ___ |
| 1145 | A gang condenser is a ___ |
| 1146 | Two spheres of ___ |
| 1147 | The sparking between two electrical contacts can be ___ |
| 1148 | Coulomb’ s law for the force between electric charges most ___ |
| 1149 | Three capacitors each of ___ |
| 1150 | Two metal plates distance ‘d’ apart form ___ |
| 1151 | The units of capacitance are ___ |
| 1152 | Electric intensity (E) at any point in an electric field is ___ |
| 1153 | In case of lossy capacitor, its series equivalent resistance value will be ___ |
| 1154 | Dielectric strength of a medium is ___ |
| 1155 | Pick the correct statements? |
| 1156 | Which of the following capacitors is marked for polarity? |
| 1157 | If a 6 iF capacitor is charged to 200 V, the charge in ___ |
| 1158 | Which of the following capacitors has relatively shorter shelf life? |
| 1159 | The total electric flux through any closed surface surrounding charges is ___ |
| 1160 | Electric flux in coulombs emanating from any surface of ___ |
| 1161 | For making a capacitor, it is better to ___ |
| 1162 | The electric field intensity at a point situated 4 metres from ___ |
| 1163 | Internal heating of a capacitor is ___ |
| 1164 | A variable capacitance is ___ |
| 1165 | A charge which when placed in vacuum from ___ |
| 1166 | Which of the following capacitors will have least energy stored in it? |
| 1167 | The bridge used for the measurement of the value of ___ |
| 1168 | A capacitor consists of ___ |
| 1169 | The surface integral of normal component of ___ |
| 1170 | The phenomenon of an uncharged body getting charged merely by ___ |
| 1171 | The inverse of capacitance is ___ |
| 1172 | The value of dielectric constant for vacuum is ___ |
| 1173 | Energy density in a static electric field is ___ |
| 1174 | While testing a capacitor with ohm. metre, if ___ |
| 1175 | The ratio of electric flux density to electric field intensity is ___ |
| 1176 | Capacitance increases with ___ |
| 1177 | The dissipation factor of a good dielectric is ___ |
| 1178 | Which of the following is not a vector? |
| 1179 | A capacitor stores 0.24 coulombs at ___ |
| 1180 | As per Coulomb’s law ___ |
| 1181 | In a capacitor, the electric charge is ___ |
| 1182 | A capacitor having a capacitance of 40 μF is ___ |
| 1183 | Dielectric strength of ___ |
| 1184 | The ohmmeter reading for a short circuited capacitor is ___ |
| 1185 | The capacitance G is charged through a ___ |
| 1186 | The capacitance of a capacitor is ___ |
| 1187 | In a concentric cable capacitor the diameters of ___ |
| 1188 | Electric displacement is a ___ |
| 1189 | It was suggested by ___ that the electric field should be imagined |
| 1190 | If three capacitors C1, C2 and C3 of values of ___ |
| 1191 | The surface integral of the normal component of ___ |
| 1192 | Dielectric constant for mica is ___ |
| 1193 | The capacity of capacitor bank used in power factor correction is ___ |
| 1194 | Which of the following capacitors will have the least variation? |
| 1195 | If the sheet of a bakelite is inserted between the plates of ___ |
| 1196 | Two capacitors each having capacitance C and ___ |
| 1197 | The value of one Farad in ___ |
| 1198 | Capacity of a parallel plate condensor can be ___ |
| 1199 | The potential gradient at which the dielectric of ___ |
| 1200 | Check the correct relation ___ |
| 1201 | The capacity of a spherical conductor is ___ |
| 1202 | The energy of a charged capacitor resides in ___ |
| 1203 | Putting the plates of a charged capacitor apart ___ |
| 1204 | A glass slab is put within the plates of ___ |
| 1205 | The dissipation factor of good dielectric is of ___ |
| 1206 | The electric field between the two spheres of ___ |
| 1207 | An electric dipole is placed in an electric field generated by a ___ |
| 1208 | The electric potential due to an electric dipole of ___ |
| 1209 | Two conductors having the same type of charges are connected by ___ |
| 1210 | Electric potential at the centre of a charged conductor is ___ |
| 1211 | Inside a charge hollow conducting sphere, potential will be ___ |
| 1212 | The point charges Q and 2Q are placed at a ___ |
| 1213 | A large sphere P of radius R is ___ |
| 1214 | A hollow sphere of charge does not produce an ___ |
| 1215 | Equal charges are given to two spheres of ___ |
| 1216 | The equipotential line due to ___ |
| 1217 | A positively charged glass rod attracts an ___ |
| 1218 | A soap bubble is given a negative charge then its ___ |
| 1219 | The electric potential at the surface of ___ |
| 1220 | A charge q is divided into two ___ |
| 1221 | The electric potential due to an electric dipole at ___ |
| 1222 | For induction motors requiring speed control or ___ |
| 1223 | The diameter of commutator generally lies ___ |
| 1224 | Which of the following methods may be adopted to reduce the effects of armature reaction? |
| 1225 | The weight of copper of both armature and ___ |
| 1226 | Which of the following in an application of D.C. motors? |
| 1227 | The space factor depends on all of ___ |
| 1228 | The yoke of a D.C. motor is generally made of ___ |
| 1229 | The ratio of magnetising current to ideal short circuit current is ___ |
| 1230 | The harmonic fields are produced due to which of the following? |
| 1231 | For 275 kV transformers, using cold rolled grain ___ |
| 1232 | Multi-layer helical windings are commonly used in ___ |
| 1233 | The winding where dummy coils are used is ___ |
| 1234 | The value of exciting or magnetizing current depends upon which of the following factors? |
| 1235 | The resistivity of water should not be ___ |
| 1236 | The density of hydrogen is ___ |
| 1237 | Electrical machines having power outputs ranging from ___ |
| 1238 | Which of the following is the major consideration to evolve a good design? |
| 1239 | The number of poles in D.C. machines is ___ |
| 1240 | Large values of air gap flux density can be ___ |
| 1241 | The cost of an induction motor as compared to that of ___ |
| 1242 | In case of phase wound induction motors the ___ |
| 1243 | Which of the following, primarily, determines the magnetizing current drawn by three phase induction motor? |
| 1244 | It is a common practice to use deep bar rotors when ___ |
| 1245 | In a D.C. generator the number of commutator segments is ___ |
| 1246 | The operation of a D.C. machine with large air gap lengths is ___ |
| 1247 | Which of the following problem arises in D.C. motors which are fed from thyristor bridge circuits? |
| 1248 | The surge phenomenon is particularly important in case of ___ |
| 1249 | The usual values of maximum flux densities for ___ |
| 1250 | Helical windings are used in ___ |
| 1251 | The distance between the starts of two consecutive coils measured in ___ |
| 1252 | The slot leakage can be calculated by making which of the following assumptions? |
| 1253 | With direct water cooling it is possible to have ratings of ___ |
| 1254 | Which of the following is an advantage of hydrogen cooling? |
| 1255 | ___ has a low relative permeability and is used principally in field frames when cost |
| 1256 | Electrical machines having a power output upto ___ |
| 1257 | ___ impose limitation on design |
| 1258 | Tap changing facility is generally provided on ___ |
| 1259 | ____ of lots are generally used in induction motors |
| 1260 | In case of electrical machines, the intermittent rating as ___ |
| 1261 | A semi-enclosed slot gives ___ |
| 1262 | Which of the following factors should be considered when estimating the length of air gap? |
| 1263 | The great majority of present day induction motors are ___ |
| 1264 | The conductors for large sizes of D.C. machines are ___ |
| 1265 | In D.C. machines, the ___ |
| 1266 | ___ is the common method of applying brushes to the commentator |
| 1267 | The cylindrical windings using circular conductors are ___ |
| 1268 | Cylindrical windings using circular conductors, employed in ___ |
| 1269 | ___ are always double layer type |
| 1270 | By which of the following methods the temperature rise of windings and other parts may be determines? |
| 1271 | In direct cooled system using hydrogen both stator and ___ |
| 1272 | Multiple inlet system of air cooling of turbo-alternators can be used for ___ |
| 1273 | Materials exhibiting zero value of resistivity are known as ___ |
| 1274 | The length of air gap to be provided in ____ is primarily determined by power factor |
| 1275 | Transformer oil should have ___ |
| 1276 | The slip rings of wound rotor machines are made of ___ |
| 1277 | A wire of ___ |
| 1278 | In an induction motor, closed slots are ___ |
| 1279 | Due to which of the following, harmonic fields are produced? |
| 1280 | Frames of electrical machines are used to serve which of the following purposes? |
| 1281 | D.C. windings are ___ |
| 1282 | In D.C. machines, in order to prevent excessive distortion of ___ |
| 1283 | Which of the following brushes can be used for high values of current density? |
| 1284 | The insulation between windings and grounded core and ___ |
| 1285 | The voltage control in electric supply networks in required on account of which of the following reasons? |
| 1286 | The cold rolled grain oriented steel has ___ |
| 1287 | When the two coil sides forming a coil are ___ |
| 1288 | Which of the following methods is most accurate? |
| 1289 | Machines cooled by direct cooling method may be ___ |
| 1290 | Which of the following methods is used for air cooling of turbo-alternators? |
| 1291 | Which of the following materials is used in the manufacture of resistance grids to ___ |
| 1292 | In ___ machines, the size of the shaft is decided by the critical speed |
| 1293 | Short time rating machines have ___ |
| 1294 | Which of the following limits the output of a rotating electrical machine? |
| 1295 | The transformer ID nise is mainly due to ___ |
| 1296 | Current density in the rotor bars of an induction motor may be ___ |
| 1297 | The flux density in the stator core of an induction motor should not ___ |
| 1298 | On which of the following factors, does the brush friction loss depend? |
| 1299 | In D.C. machines the number of ___ |
| 1300 | D.C. machines designed with a large value of ___ |
| 1301 | ___ brushes are fragile and cause excessive wear of commutator |
| 1302 | A practical formula for determining the thickness of ___ |
| 1303 | The flash point of transformer oil should be ___ |
| 1304 | Yokes with rectangular cross-section are ___ |
| 1305 | The design of electromagnets is based upon which of the following fundamental equations? |
| 1306 | Which of the following methods does not take into account the ___ |
| 1307 | ___ cooling is the process of dissipating the armature and field winding losses to |
| 1308 | On which of the following variables heat convected depends? |
| 1309 | Aluminium when adopted as a conductor material in ___ |
| 1310 | In induction motors, the length of air gap in kept as ___ |
| 1311 | Flame proof motors are used in ___ |
| 1312 | Turbo-alternators have ___ |
| 1313 | Which loss occurs in the yoke of a D.C. machine? |
| 1314 | Which of the following methods is used for reduction/elimination of harmonic torques? |
| 1315 | In general, the ratio of core length to pole pitch, in ___ |
| 1316 | The area of each individual brush should be ___ |
| 1317 | In D.C. machines the usual limit of ___ |
| 1318 | In D.C. machines the width of the duct is ___ |
| 1319 | ___ is usually used for brush rockers |
| 1320 | Which of the following is the basic consideration in the design of insulation? |
| 1321 | The forced oil and air circulation method is ___ |
| 1322 | In transformers using hot rolled steel, the cross-section of ___ |
| 1323 | ___ are used for construction of core of electromagnets |
| 1324 | The design of mechanical parts is particularly important in ___ |
| 1325 | By which of the following methods motor rating for variable load drives can be determined? |
| 1326 | The noise produced by a ___ |
| 1327 | The increase in heat dissipation by air blasts is ___ |
| 1328 | ___ is universally used for windings of electrical machines |
| 1329 | The design of mechanical parts is particularly important in case of ___ |
| 1330 | The electric motor provided on refrigerators is ___ |
| 1331 | A synchronous machine with large length of ___ |
| 1332 | The regulation of a transformer is least affected by ___ |
| 1333 | If the number of rotor slots is equal to the number of ___ |
| 1334 | For a normal design of an induction motor, the diameter should be ___ |
| 1335 | The thickness of brush should be so selected that it ___ |
| 1336 | In a D.C. machine, the value of ___ |
| 1337 | The laminations of the armature of a D.C. machine are ___ |
| 1338 | The high voltage winding is usually which of the following type? |
| 1339 | Transformers with a capacity of ___ |
| 1340 | The change in flux linkages can be caused in which of the following ways? |
| 1341 | If an insulating material is operated beyond the ___ |
| 1342 | A short time intermittent rating of electric motors is ___ |
| 1343 | The use of salient poles on high speed alternators will ___ |
| 1344 | If the frequency is changed without altering the number of ___ |
| 1345 | Power transformers should be designed to ___ |
| 1346 | Which of the following is the commonly used type of electroinagnets? |
| 1347 | In self cooled motors the cooling time constant is ___ |
| 1348 | With conventional hydrogen cooling it is possible to ___ |
| 1349 | The heat dissipated by from a surface depends upon its ___ |
| 1350 | The number of stator slots should ___ |
| 1351 | The air gap of an induction motor is made as ___ |
| 1352 | Pitch of commutator segment should not be ___ |
| 1353 | In a D.C. machine the current per brush arm should not be ___ |
| 1354 | The stator of a D.C. machine comprises of ___ |
| 1355 | A current density of ___ |
| 1356 | The heat dissipating capability of transformers of ratings higher than ___ |
| 1357 | Power transformers have ___ |
| 1358 | ___ electromagnets generally function as holding magnets |
| 1359 | The time taken by the machine to attain 0.632 of its ___ |
| 1360 | The thermal conductivity of hydrogen is ___ |
| 1361 | The heated parts of an electrical machine dissipate heat into their surroundings by ___ |
| 1362 | The action of electromagnetic machines can be related to which of the following basic principles? |
| 1363 | The efficiency of a machine should be as ___ |
| 1364 | The shafts of electric motors is generally supported in |
| 1365 | Arc welding transformer is ___ |
| 1366 | A large value of short-circuit current indicates ___ |
| 1367 | A 3-phase winding carrying sinusoidal currents produces harmonics of ___ |
| 1368 | The slip rings for wound rotor machines are made of ___ |
| 1369 | The higher commutator peripheral speeds ___ |
| 1370 | In a D.C. machine the number of brush arms ___ |
| 1371 | D.C. servomotors are used in ___ |
| 1372 | For large power transformers, self oil cooled type or air blast type which of the following values af current density may be used? |
| 1373 | Disc windings are primarily used in ___ |
| 1374 | Dummy coil should not be ___ |
| 1375 | Tractive magnets are operated from ___ |
| 1376 | Direct water cooling of rotor winding presents ___ |
| 1377 | Hydrogen has a heat transfer co-efficient ___ |
| 1378 | Hot rolled sheets have ___ |
| 1379 | Commercial available medium size machines have a speed range of ___ |
| 1380 | Electric arc welding process produces temperature upto ___ |
| 1381 | The ideal core material for small reactors and transformers employed in ___ |
| 1382 | For ferro-magnetic materials the ___ |
| 1383 | Ferro-electric materials are the dielectrics analogous to ___ |
| 1384 | When the temperature exceeds a certain value called the ___ |
| 1385 | Which of the following kind of breakdown is possible in solid dielectrics? |
| 1386 | Dielectrics have ___ |
| 1387 | Electronegative gases are ___ |
| 1388 | The insulating materials to be used for most of electronic equipment should ___ |
| 1389 | Insulators have which of the following? |
| 1390 | Emitter arrow, in a transistor, shows the direction of ___ |
| 1391 | In a semiconductor, the hole formed is ___ |
| 1392 | ___ is an element used in semiconductors whose atoms have three valence |
| 1393 | Effect of moisture on the insulating materials is ___ |
| 1394 | The conduction of electricity, in semiconductors, takes place due to ___ |
| 1395 | Which of the following is an advantage of stranded conductor over equivalent single conductor? |
| 1396 | Carbon resistors are used extensively because they are ___ |
| 1397 | In graphite, bonding is ___ |
| 1398 | Most of the common metals have ___ |
| 1399 | In thermocouples which of the following pairs is commonly used? |
| 1400 | If the domain walls in a magnetic material can be easily moved the ___ |
| 1401 | The transition temperature of mercury is ___ |
| 1402 | The value of critical field below the transition temperature will ___ |
| 1403 | A perfect conductor has ___ |
| 1404 | If the domain walls in a magnetic material can be ___ |
| 1405 | Magnetically hard materials possess which of the following characteristics? |
| 1406 | Curie temperature is the temperature above which a ___ |
| 1407 | The ___ polarisation vanishes at Curie temperature of the material |
| 1408 | A ferro-electric material contains small regions which are polarised in ___ |
| 1409 | Dielectric strength is expressed in ___ |
| 1410 | By which of the following methods the insulation can be protected against moisture? |
| 1411 | Which of the following gases is classified as electronegative? |
| 1412 | Insulators are the materials in which valence electrons are ___ |
| 1413 | In a P.N.P. transistor the collector current is ___ |
| 1414 | Germanium possesses ___ |
| 1415 | For a hole which of the following statements is incorrect? |
| 1416 | Which of the following factors affect resistivity of metals? |
| 1417 | Due to which of the following fact, in India, aluminium is replacing copper? |
| 1418 | Platinum is used in ___ |
| 1419 | Which of the following material is not a semiconductor? |
| 1420 | Which of the following materials does not have covalent bonds? |
| 1421 | A good electric contact material should have all of ___ |
| 1422 | Piezoelectric materials serve as a source of ____ |
| 1423 | The conductors have transport phenomena of ___ |
| 1424 | The superconductivity is due to ___ |
| 1425 | The covalent bond is ___ |
| 1426 | Fahy permeameter entails which of the following advantages? |
| 1427 | In carbon steels if the percentage of carbon is increased it has which of the following effects? |
| 1428 | ___ is that property of material which opposes the production of magnetic flux in it |
| 1429 | Above the Curie temperature the materials have no ___ |
| 1430 | If the centre of gravity of the positive and negative charges in ___ |
| 1431 | The moisture absorbed by an insulating material causes which of the following? |
| 1432 | Insulating gases entail which of the following major problems? |
| 1433 | Porcelain insulators are employed for insulating terminals of ___ |
| 1434 | The change of resistance in a magnetic field is ___ |
| 1435 | In a P.N.P. transistor majority charge carriers are ___ |
| 1436 | A pure semiconductor, under ordinary conditions, behaves like ___ |
| 1437 | The current due to electron flow in conduction band is ___ |
| 1438 | The forbidden gap in an insulator is ___ |
| 1439 | Thermocouples are mainly used for ___ |
| 1440 | Low resistivity materials are used in ___ |
| 1441 | The impurity atoms is ___ |
| 1442 | A carbon resistor contains ___ |
| 1443 | ___ is the main constituent of glass |
| 1444 | ___ has zero temperature co-efficient of resistance |
| 1445 | The coils of D.C. motor starter are wound with wire of ___ |
| 1446 | Superconductivity is observed for ___ |
| 1447 | The co-ordination number of a simple cubic structure is ___ |
| 1448 | ___ is the most detrimental impurity in the magnetic materials |
| 1449 | Practically all organic substances are ___ |
| 1450 | The ratio of intensity of magnetisation to magnetising force is ___ |
| 1451 | The ferro-electric materials ___ |
| 1452 | The dielectric susceptibility determines the value of ___ |
| 1453 | The behaviour of real dielectrics is ___ |
| 1454 | Which of the following is a consequence of ionisation? |
| 1455 | Which of the following effects is produced by ‘sludge’ formation? |
| 1456 | Which of the following processes is used to produce porcelain? |
| 1457 | Hall effect may be used for which of the following? |
| 1458 | When radiation is incident on a semiconductor, its ___ |
| 1459 | The conductivity of an extrinsic semiconductor ___ |
| 1460 | Spark plug makes use of which of the following materials for insulation? |
| 1461 | ___ is the property of absorbing moisture from atmosphere |
| 1462 | Steel wire is used as ___ |
| 1463 | Due to which of the following reasons aluminium does not corrode in atmosephere? |
| 1464 | Non-linear resistors ___ |
| 1465 | ___ is an example of piezoelectric material |
| 1466 | Which of the following is the poorest conductor of electricity? |
| 1467 | Which of the following resistive materials has the lowest temperature co-efficient of resistance? |
| 1468 | The conductivity of a conductor can be increased by ___ |
| 1469 | The tiny block formed by the arrangement of a small group of ___ |
| 1470 | The eddy currents produce a magnetic field of their own which ___ |
| 1471 | Uniaxial anisotropy can be induced in bulk materials by which of the following methods? |
| 1472 | High-frequency transformers cores are generally made from ___ |
| 1473 | In potassium Dihydrogen Phosphate the Curie points are ___ |
| 1474 | Polarisation is ___ |
| 1475 | The dielectric loss is affected by which of the following factors? |
| 1476 | Flash point temperature of fresh dry oil is ___ |
| 1477 | The dielectric strength of asbestos is ___ |
| 1478 | Photo-voltaic cells find applications in which of the following? |
| 1479 | A thermistor has ___ |
| 1480 | For a particular material the Hall coefficient was ___ |
| 1481 | If the resistance of a conductor does not vary in accordance with ___ |
| 1482 | Which of the following materials is the best conductor of electricity? |
| 1483 | Which of the following high resistance materials has the highest operating temperature? |
| 1484 | In a crystal, an atom vibrates at a frequency determined by ___ |
| 1485 | Super conductivity can be destroyed by ___ |
| 1486 | Overhead telephone wires are made of ___ |
| 1487 | Constantan contains ___ |
| 1488 | An H.R.C. fuse is ___ |
| 1489 | A highly conductive material must have ___ |
| 1490 | The formula ___ determines the number of electrons that can be accommodated |
| 1491 | The value of steinmetz co-efficient k is approximately ___ |
| 1492 | The spontaneous magnetisation is the most important characteristic of ___ |
| 1493 | The readiness of a material to accept magnetism is ___ |
| 1494 | Rochelle salt has ___ |
| 1495 | The dielectric strength of gaseous dielectrics depends on which of the following factors? |
| 1496 | The dielectric losses occur in all solid and liquid dielectrics due to which of the following? |
| 1497 | Presence of even a trace of water in transformer oil ___ |
| 1498 | Mica is usually avoided for slot linings of high voltage machines because its ___ |
| 1499 | Thermistors possess ___ |
| 1500 | In a semiconductor the resistivity decreases ___ |
| 1501 | The carbon percentage is least in ___ |
| 1502 | The photo-electric effect occurs only when the incident light has ___ |
| 1503 | Substances whose specific resistance abruptly decreases at ___ |
| 1504 | Carbon bearings are used under which of the following conditions? |
| 1505 | The resistivity of a metal is a function of ___ |
| 1506 | ___ is most commonly used for making magnetic recording tape |
| 1507 | Which of the following variety of copper has the best conductivity? |
| 1508 | Mercury as an electric contact material is ___ |
| 1509 | The kinetic energy of a bounded electron is ___ |
| 1510 | ___ is a negatively charged particle present in an atom |
| 1511 | The relative magnetisation under a given field ___ |
| 1512 | The permeability of iron is ___ |
| 1513 | Capacitors with very high dielectric constants have been developed by ___ |
| 1514 | Which of the following is a ferro-electric material? |
| 1515 | The power arc following a flashover or the breaking of contacts over the ___ |
| 1516 | The value of dielectric strength is useful in which of the following? |
| 1517 | Which of the following tests is carried out on transformer oil? |
| 1518 | The dielectric strength of ___ |
| 1519 | Non-linear resistors are also called ___ |
| 1520 | Thermistors find use in which of the following? |
| 1521 | In conductors conduction of electricity takes place due to ___ |
| 1522 | ___ has the best damping properties |
| 1523 | Which of the following materials is used for making coils of standard resistances? |
| 1524 | Which of the following are non-conductors of electricity? |
| 1525 | The conductivity of a metal is ___ |
| 1526 | ___ is a hard solder |
| 1527 | At transition temperature the value of ___ |
| 1528 | High resistivity materials are used in ___ |
| 1529 | Which of the following materials is preferred for transmitting electrical energy over long distance? |
| 1530 | Which of the following factors cause magnetic ageing? |
| 1531 | ___ materials have relative permeability slightly less than unity |
| 1532 | The materials having permanent electric moment are ___ |
| 1533 | Which of the following is not a ferroelectric material? |
| 1534 | ___ breakdown normally occurs when the temperature is very high and surrounding air has high humidity |
| 1535 | The resistivity of the insulator ___ |
| 1536 | The function of insulating liquids is ___ |
| 1537 | A good insulating material should possess which of the following characteristics? |
| 1538 | Conduction of heat in a semiconductor takes place in which of the following ways? |
| 1539 | The conductivity of semiconductors depends on which of the following factors? |
| 1540 | For germanium the forbidden energy gap is ___ |
| 1541 | Superconducting metal in super conducting state has ___ |
| 1542 | Selenium is ___ |
| 1543 | Copper, even though costly, finds use in the windings of ___ |
| 1544 | Due to which of the following factors the brush wear rate is altered? |
| 1545 | The number of atoms per unit cell in B.C.C. structure is ___ |
| 1546 | Thermonic emission occurs in ___ |
| 1547 | Carbon electrodes are not used in ___ |
| 1548 | The structure sensitive property of ___ |
| 1549 | Superconductors are becoming popular for ___ |
| 1550 | Commonly used conducting materials are ___ |
| 1551 | The converse of hardness is known as ___ |
| 1552 | The magnetic domains, during the process of magnetisation of ___ |
| 1553 | Alnico magnet alloys have the ___ |
| 1554 | For which of the following materials the relative permeability is much greater than unity? |
| 1555 | The major use of ferro-electrics is ___ |
| 1556 | Ferro-electric materials have which of the following characteristics? |
| 1557 | Which of the following conditions go a long way in causing the electrothermal breakdown of the dielectric? |
| 1558 | Dielectric materials are ___ |
| 1559 | Insulation resistance ___ |
| 1560 | The ionically and covalently bonded materials are ___ |
| 1561 | As compared to thermionic tubes, transistors claim which of the following advantages? |
| 1562 | In ___ semiconductor, the Fermi level lies midway between the conduction |
| 1563 | The minority carrier concentration is largely a function of |
| 1564 | Surface resistance of an insulating material is reduced due to the ___ |
| 1565 | Which of the following is a semiconductor material? |
| 1566 | Due to which of the following reasons copper and aluminium are not used for heating elements? |
| 1567 | Carbon rods are used in wet and ___ |
| 1568 | Total number of crystal systems is ___ |
| 1569 | Which of the following affect greatly the resistivity of electrical conductors? |
| 1570 | ___ is viscoelastic |
| 1571 | By increasing impurity content in the ___ |
| 1572 | In a superconductor the value of critical density depends upon ___ |
| 1573 | The metal having the lowest temperature co-efficient of ___ |
| 1574 | On which of the following factors does the resistivity of a material depend? |
| 1575 | The change in dimensions during the process of ___ |
| 1576 | A SWG electrode usually operates in ___ |
| 1577 | Steel pipes are manufactured by ___ |
| 1578 | The tips of the electrodes, for spot welding, are ___ |
| 1579 | During arc welding as the thickness of the metal to be ___ |
| 1580 | Welding leads have ___ |
| 1581 | Resistance welding cannot be ___ |
| 1582 | During resistance welding heat produced at the joint is ___ |
| 1583 | Which of the following automatic welding processes is likely to give maximum rate of metal deposition? |
| 1584 | Arc blow (a welding defect) is generally encountered in ___ |
| 1585 | In electrical resistance welding the greatest resistance is offered by which of the following? |
| 1586 | In argon arc welding argon is ___ |
| 1587 | Due to which of the following reasons aluminium is difficult to weld? |
| 1588 | Electronic components are joined by which of the following methods? |
| 1589 | For the welding of aluminium alloys which of the following methods would you recommend? |
| 1590 | In welding weld spatter defect is generally the result of ___ |
| 1591 | The porosity of welded joint may be ___ |
| 1592 | Plain and butt welds may be used on materials upto thickness of ___ |
| 1593 | Helium produces which of the following? |
| 1594 | Which of the following is not an inert gas? |
| 1595 | Flux used in TIG welding is ___ |
| 1596 | During carbon arc welding ___ |
| 1597 | In atomic hydrogen welding the electrode is ___ |
| 1598 | Motor-generator set for D.C. arc welding has ___ |
| 1599 | In spot welding composition and thickness of ___ |
| 1600 | Which of the following equipment is used for arc welding generally used for arc welding? |
| 1601 | In ultrasonic welding the frequency range is ___ |
| 1602 | TIG welding is ___ |
| 1603 | The welding of aluminium alloy entails which of the following problems? |
| 1604 | In which of the following methods of welding the molten metal is poured for joining the metals? |
| 1605 | A seamless pipe has ___ |
| 1606 | In arc welding major personal hazards are ___ |
| 1607 | ___ welding process uses consumable electrodes |
| 1608 | Steel rails are welded by ___ |
| 1609 | The welding load is ___ |
| 1610 | Which of the following methods is normally not preferred for welding of chromium-molybdenum steels? |
| 1611 | During carbon arc welding if electrode is connected to ___ |
| 1612 | Galvanising is a process of applying a layer of ___ |
| 1613 | In seam welding ___ |
| 1614 | For arc welding, D.C. is produced by which of the following? |
| 1615 | The welding electric circuit is ___ |
| 1616 | Grey iron is usually welded by ___ |
| 1617 | The power factor of a spot welding machine is expected to ___ |
| 1618 | A percent duty cycle of a welding machine means ___ |
| 1619 | Spot welding is used for ___ |
| 1620 | Arc blow results in which of the following? |
| 1621 | In a welded joint poor fusion is due to which of the following? |
| 1622 | The danger of shock is ___ |
| 1623 | Which of the following is not a welding accessory? |
| 1624 | ___ welding is not a resistance welding process |
| 1625 | The purpose of coating on arc welding electrodes is ___ |
| 1626 | For arc welding current range is ___ |
| 1627 | Increased heat due to shorter arc is harmful on ___ |
| 1628 | The metal surfaces for electrical resistance welding must be ___ |
| 1629 | Which of the following electrodes will have least diameter? |
| 1630 | A rectifier for welding has voltage/current characteristic as ___ |
| 1631 | During spot welding the current flows for ___ |
| 1632 | In D.C. arc welding ___ |
| 1633 | Air craft body is ___ |
| 1634 | Electric arc welding process produces ___ |
| 1635 | Overhead lines for power supply to tramcars are at ___ |
| 1636 | In India diesel locomotives are manufactured at ___ |
| 1637 | Suri transmission is ___ |
| 1638 | In main line service as compared to ___ |
| 1639 | Which of the following braking systems is used on steam locomotives? |
| 1640 | Which of the following is the disadvantage of electric traction over other systems of traction? |
| 1641 | The number of passanger coaches that can be attached to a ___ |
| 1642 | In case of locomotives the tractive power is ___ |
| 1643 | Main traction systems used in India are ___ |
| 1644 | The rate of acceleration on suburban or urban service is ___ |
| 1645 | In India electrification of railway track was done for the first time in ___ |
| 1646 | In case of ___ free running and coasting periods are generally long |
| 1647 | Specific energy consumption becomes ___ |
| 1648 | The pulsating torque exerted by steam locomotives causes which of the following? |
| 1649 | Quadrilateral speed-time curve pertains to which of the following services? |
| 1650 | The speed of a superfast train is ___ |
| 1651 | Which of the following drives is suitable for mines where explosive gas exists? |
| 1652 | The speed of a locomotive is controlled by ___ |
| 1653 | The braking retardation is usually in ___ |
| 1654 | Power for lighting in passenger coach in ___ |
| 1655 | Specific energy consumption is affected by which of the following factors? |
| 1656 | For three-phase induction motors which of the following is the least efficient method of speed control? |
| 1657 | The normal value of adhesion friction is ___ |
| 1658 | Due to which of the following co-efficient of adhesion improves? |
| 1659 | The efficiency of diesel locomotives is ___ |
| 1660 | In a steam locomotive electric power is ___ |
| 1661 | Long distance railways use which of the following? |
| 1662 | ___ watt-hours per tonne km is usually the specific energy consumption |
| 1663 | For 25 kV single phase system power supply frequency is ___ |
| 1664 | ___ have maximum unbalanced forces |
| 1665 | The voltage used for suburban trains in D.C. system is ___ |
| 1666 | The air resistance to the movement of the train is ___ |
| 1667 | Co-efficient of adhesion reduces due to the presence of which of the following? |
| 1668 | Automatic signaling is used for which of the following trains? |
| 1669 | In tramways which of the following motors is used? |
| 1670 | If the co-efficient of adhesion on dry rails is 0.26, which of the following could be the value for wet rails? |
| 1671 | ___ frequency is not common in low frequency traction system |
| 1672 | An ideal traction system should have ___ |
| 1673 | The value of co-efficient of adhesion will be ___ |
| 1674 | The friction at the track is proportional to ___ |
| 1675 | For given maximum axle load tractive efforts of A.C. locomotive will ___ |
| 1676 | The wheels of a train, engine as well as bogies, are ___ |
| 1677 | The overall efficiency of steam locomotive is ___ |
| 1678 | Which of the following is an advantage of electric traction over other methods of traction? |
| 1679 | Which of the following methods is used to control speed of 25 kV, 50 Hz single phase traction? |
| 1680 | Energy consumption in propelling the train is required for which of the following? |
| 1681 | ___ method can bring the locomotive to dead stop |
| 1682 | The specific energy consumption of a train depends on which of the following? |
| 1683 | Tractive effort is required to ___ |
| 1684 | Electric locomotives in India are manufactured at ___ |
| 1685 | The horsepower of steam locomotives is ___ |
| 1686 | Which of the following is the voltage for single phase A.C. system? |
| 1687 | For 600 V D.C. line for tramcars track is ___ |
| 1688 | For which of the following locomotives the maintenance requirements are the least? |
| 1689 | Locomotives with monometer bogies have ___ |
| 1690 | When a bogie negotiates a curve, reduction in ___ |
| 1691 | Battery operated trucks are used in ___ |
| 1692 | The rate of acceleration on suburban or urban services is ___ |
| 1693 | Which of the following braking systems on the locomotives is costly? |
| 1694 | The steam engine provided on steam locomotives is ___ |
| 1695 | ___ locomotive has the highest operational availability |
| 1696 | ___ is the method of braking in which motor armature remains connected |
| 1697 | Which of the following happens in Kando system? |
| 1698 | Specific energy consumption is ___ |
| 1699 | Series motor is not suitable for traction duty due to which of the following account? |
| 1700 | The resistance encountered by a train in motion is ___ |
| 1701 | Speed-time curve of main line service differs from those of ___ |
| 1702 | Which of the following is the advantage of electric braking? |
| 1703 | In case of steam engines the ___ |
| 1704 | For diesel locomotives the range of horsepower is ___ |
| 1705 | Which of the following track is ___ |
| 1706 | In case of a steam engine an average coal consumption per km is ___ |
| 1707 | The return circuit for tramcars is ___ |
| 1708 | Locomotive having monomotor bogies ___ |
| 1709 | Vacuum created by which of the following? |
| 1710 | Co-efficient of adhesion is ___ |
| 1711 | Which of the following state capitals is not on broad gauge track? |
| 1712 | Overload capacity of diesel engines is ___ |
| 1713 | For radiant heating around 2250°C, the heating elements are made of ___ |
| 1714 | Radiations from proportional to ___ |
| 1715 | Induction heating takes place in which of the following? |
| 1716 | The material of the heating element for a ___ |
| 1717 | A perfect black body is ___ |
| 1718 | Which of the following is an advantage of heating by electricity? |
| 1719 | Which of the following devices is necessarily required for automatic temperature control in a furnace? |
| 1720 | It is desirable to operate the arc furnaces at power factor of ___ |
| 1721 | In an electric press mica is ___ |
| 1722 | Which of the following will happen if the thickness of refractory wall of furnace is increased? |
| 1723 | Heat transfer by condition will ___ |
| 1724 | ___ has the highest value of thermal conductivity |
| 1725 | Radiant heating is used for which of the following? |
| 1726 | Which of the following methods is used to control temperature in resistance furnaces? |
| 1727 | In a domestic cake baking oven the temperature is ___ |
| 1728 | The temperature inside a furnace is usually measured by which of the following? |
| 1729 | For the transmission of heat from one body to ___ |
| 1730 | In heating the ferromagnetic material by induction heating, heat is ___ |
| 1731 | Property of low temperature co-efficient of heating element is desired due to which of the following reasons? |
| 1732 | In an electric room heat convector the method of ___ |
| 1733 | A non-dimensional number generally associated with ___ |
| 1734 | When a body reflects entire radiation incident on it ___ |
| 1735 | Hysteresis loss and eddy current loss are ___ |
| 1736 | In the indirect resistance heating method, maximum heat-transfer takes place by ___ |
| 1737 | Which of the following insulating materials is suitable for low temperature applications? |
| 1738 | Which of the following methods of heating is not dependent on the frequency of supply? |
| 1739 | In direct arc furnace which of the following has high value? |
| 1740 | Resistance variation method of temperature control is ___ |
| 1741 | Due to which of the following reasons it is desirable to have short arc length? |
| 1742 | By the use of which of the following, high frequency power supply for induction furnaces can be obtained? |
| 1743 | Induction heating process is based on which of the following principles? |
| 1744 | ___ is used for heating non-conducting materials |
| 1745 | Direct arc furnaces have which of the following power factors? |
| 1746 | In electric press, mica is used because it is ___ |
| 1747 | For intermittent work which of the following furnaces is suitable? |
| 1748 | In induction heating ___ |
| 1749 | Which of the following has the highest value of thermal conductivity? |
| 1750 | ___ method has leading power factor |
| 1751 | The electrode of a direct arc furnace is ___ |
| 1752 | Ajax Wyatt furnace is started when ___ |
| 1753 | In resistance heating highest working temperature is ___ |
| 1754 | By which of the following methods the temperature inside a resistance furnace can be varied? |
| 1755 | The process of heat transfer during the re-entry of satellites and missiles, at ___ |
| 1756 | Which of the following heating methods has maximum power factor? |
| 1757 | Which of the following is an advantage of eddy current heating? |
| 1758 | In arc furnace the function of ___ |
| 1759 | For heating element high resistivity material is ___ |
| 1760 | In a resistance furnace the atmosphere is ___ |
| 1761 | Heat is transferred simultaneously by ___ |
| 1762 | If the tariff for electrical energy charges provides incentive by way of ___ |
| 1763 | When the demand of consumers is not met by a power plant, it will resort to which of the following? |
| 1764 | Which of the following plants is almost inevitably used as base load plant? |
| 1765 | The area under daily load curve divided by ___ |
| 1766 | In India production and distribution of electrical energy is ___ |
| 1767 | Which of the following is not necessarily an advantage of interconnecting various power stations? |
| 1768 | Which of the following is the disadvantage of a synchronous condenser? |
| 1769 | Which of the following is not an operating cost? |
| 1770 | ___ industry has the least power consumption per tonne of product |
| 1771 | ___ power plant cannot have single unit of 100 MW |
| 1772 | Low power factor is usually not ___ |
| 1773 | Annual depreciation of the plant is proportional to ___ |
| 1774 | Diversity factor has direct effect on ___ |
| 1775 | A load curve indicates ___ |
| 1776 | Which of the following is the disadvantage of static capacitor for power factor improvement? |
| 1777 | Which of the following devices may be used to provide protection against lightning overvoltages? |
| 1778 | The depreciation charges in diminishing value method are ___ |
| 1779 | Which of the following source of power is least reliable? |
| 1780 | The connected load of a domestic consumer is ___ |
| 1781 | Base load plants usually have ___ |
| 1782 | ___ is invariably used for peak load |
| 1783 | ___ offers the highest electric load |
| 1784 | ___ power plant is expected to have the longest life |
| 1785 | Which of the following should be used for extinguishing electrical fires? |
| 1786 | Annual instalment towards depreciation reduces as rate of ___ |
| 1787 | High load factor indicates ___ |
| 1788 | Load factor of a power station is ___ |
| 1789 | When a plant resorts to load shedding it can be ___ |
| 1790 | Which lightning stroke is most dangerous? |
| 1791 | Major share of power produced in India is ___ |
| 1792 | Power generation cost reduces as ___ |
| 1793 | In a load curve the highest point ___ |
| 1794 | For the same maximum demand, if load factor is decreased, the cost of ___ |
| 1795 | Static capacitors are rated in ___ |
| 1796 | In which of the following power plants the maintenance cost is usually high? |
| 1797 | Generating capacity connected to the bus bars and ready to ___ |
| 1798 | A nuclear power plant is invariably used as a ___ |
| 1799 | Which of the following is not a source of power? |
| 1800 | Maximum demand on a power plant is ___ |
| 1801 | The area under a load curve gives ___ |
| 1802 | Demand factor is defined as ___ |
| 1803 | Load shedding is done to ___ |
| 1804 | The effect of electric shock on human body depends on ___ |
| 1805 | For cooling of large size generators hydrogen is ___ |
| 1806 | The efficiency of a plant is of least concern when it is ___ |
| 1807 | The expected useful life of an hydroelectric power station is ___ |
| 1808 | ___ will be least affected due to charge in supply voltage frequency |
| 1809 | In a distribution system, in order to improve power factor, the ___ |
| 1810 | For which of the following power plants highly skilled engineers are required for running the plants? |
| 1811 | ___ is the reserved generating capacity available for service under emergency |
| 1812 | Air will not be the working substance in which of the following? |
| 1813 | A low utilization factor for a plant indicates that ___ |
| 1814 | Annual operating expenditure of a power plant consists of ___ |
| 1815 | Which plant can never have 100 percent load factor? |
| 1816 | Depreciation charges are high in ___ |
| 1817 | The knowledge of diversity factor helps in ___ |
| 1818 | An alternator coupled to a ___ |
| 1819 | A 130 MW generator is usually ___ |
| 1820 | For any type of consumer the ideal tariff is ___ |
| 1821 | Generators for peak load plants are usually designed for ___ |
| 1822 | Which of the following is the disadvantage due to low power factor? |
| 1823 | Which of the following power plants need the least period for installation? |
| 1824 | The increased load during summer months is ___ |
| 1825 | Efficiency is the secondary consideration in which of the following plants? |
| 1826 | Direct conversion of heat into electric power is ___ |
| 1827 | Load curve of a power plant has ___ |
| 1828 | In Hopknison demand rate or two part tariff the ___ |
| 1829 | Annual depreciation cost is calculated by ___ |
| 1830 | Which of the following are not repayable after a stipulated period? |
| 1831 | Submarines for underwater movement, are powered by which of the following? |
| 1832 | Maximum demand tariff is generally not applied to ___ |
| 1833 | Which of the following is an advantage of static capacitor for power factor improvement? |
| 1834 | For a diesel generating station the useful life is ___ |
| 1835 | In an interconnected system, the diversity factor of ___ |
| 1836 | An induction motor has relatively high power factor at ___ |
| 1837 | In case of ___ fuel transportation is the major problem |
| 1838 | Which of the following equipment provides fluctuating load? |
| 1839 | During load shedding ___ |
| 1840 | ___ can generate power at unpredictable or uncontrolled times |
| 1841 | Load curve is useful in deciding the ___ |
| 1842 | In two part tariff, variation in load factor will ___ |
| 1843 | The load factor of domestic load is ___ |
| 1844 | A company can raise funds through |
| 1845 | The least share of power is provided in India, by which of the following power plants? |
| 1846 | An over excited synchronous motor on no-load is ___ |
| 1847 | Most efficient plants are normally used as ___ |
| 1848 | For a power plant which of the following constitutes running cost? |
| 1849 | By the use of which of the following power factor can be improved? |
| 1850 | In a power plant if the maximum demand on the plant is equal to ___ |
| 1851 | In ___ fuel transportation cost is least |
| 1852 | Which of the following place is not associated with nuclear power plants in India? |
| 1853 | Load curve helps in ___ |
| 1854 | Power plant having maximum demand more than the installed rated capacity will ___ |
| 1855 | A consumer has to pay lesser fixed charges in ___ |
| 1856 | Load factor for heavy industries maybe taken as ___ |
| 1857 | In power plants insurance cover is provided for which of the following? |
| 1858 | For the same cylinder dimensions and speed, which of the following engine will produce least power? |
| 1859 | The primary reason for low power factor is supply system is due to installation of |
| 1860 | ___ public sector undertaking is associated with erection |
| 1861 | A synchronous condenser is virtually which of the following? |
| 1862 | Large capacity generators are ___ |
| 1863 | ___ is invariably used as base load plant |
| 1864 | Direct conversion of heat into electrical energy is ___ |
| 1865 | Salvage value of the plant is ___ |
| 1866 | Which of the following generating station has minimum running cost? |
| 1867 | Annual depreciation as per straight line method, is ___ |
| 1868 | Diversity factor is ___ |
| 1869 | Anything having some heat value can be used as ___ |
| 1870 | Load shedding is possible through which of the following? |
| 1871 | Which of the following component, in a steam power plant needs maximum maintenance attention? |
| 1872 | For a consumer the most economical power factor is ___ |
| 1873 | Which of the following is the essential requirement of peak load plant? |
| 1874 | With reference to a power station which of the following is not a fixed cost? |
| 1875 | Which of the following, in a thermal power plant, is not a fixed cost? |
| 1876 | Ships are generally powered by ___ |
| 1877 | For high value of diversity factor, a power station of ___ |
| 1878 | Following power plant has instant starting ___ |
| 1879 | Approximate estimation of power demand can be ___ |
| 1880 | While using electricity and paying the ___ |
| 1881 | Which of the following characteristics of electrons determines the current in a conductor? |
| 1882 | When there is an electric current through a conducting wire along its ___ |
| 1883 | Through a metallic conductor an electric current is ___ |
| 1884 | Two bulbs 100 W, 250 V and 200 W, 250 V are connected in ___ |
| 1885 | A steady current flows in a metallic conductor of ___ |
| 1886 | The equivalent resistance in series combination is ___ |
| 1887 | An electron charge (e) is revolving in a circular orbit of ___ |
| 1888 | The length of a conductor is ___ |
| 1889 | Which of the following has negative temperature coefficient of resistance? |
| 1890 | Water is an excellent solvent because its ___ |
| 1891 | The electric field at a point on equatorial line of a dipole, and the ___ |
| 1892 | Identify the set in which all the three materials are good conductors of ___ |
| 1893 | When subjected to a transverse electric field, cathode rays ___ |
| 1894 | An isolated conducting sphere is given a ___ |
| 1895 | A region surrounding a stationary electric dipole has ___ |
| 1896 | If a very flexible wire is laid out in the shape of a hair pin with its ___ |
| 1897 | Two wires A and B of the same material and ___ |
| 1898 | Two heaters, rated at 1000 W, 250 V each are connected in ___ |
| 1899 | The condition for the validity of Ohm’ s law is ___ |
| 1900 | Four 100 W bulbs are connected in parallel across ___ |
| 1901 | The flow of electric current in a conductor is due to flow of ___ |
| 1902 | For a fixed supply voltage the current flowing through a conductor will ___ |
| 1903 | Which of the following statements is incorrect? |
| 1904 | Two incandescent light bulbs of 40 W and 60 W rating are connected in ___ |
| 1905 | “The total electric flux through any ___ |
| 1906 | Correct form of ___ |
| 1907 | When an electric current flows through a conductor, its ___ |
| 1908 | A 100 watt light bulb burns on an average of 10 hours a day for ___ |
| 1909 | When a voltage of one volt is applied, a circuit allows one microampere current to ___ |
| 1910 | Which ofthe following lamps will have least resistance at room temperature? |
| 1911 | Which of the following could be th value of resistivity of copper? |
| 1912 | Bulbs in street Lighting are all connected in ___ |
| 1913 | Whether circuit may be AC. or D.C. one, following is most effective in ___ |
| 1914 | A 500 W, 220 V bulb is supplied with ___ |
| 1915 | The rating of a fuse wire is always expressed in ___ |
| 1916 | The substances which have a large number of free electrons and offer a ___ |
| 1917 | The flow of current in solids is ___ |
| 1918 | If I, R and t are the current, resistance and time respectively, then ___ |
| 1919 | According to the fuse law, the current carrying capacity varies as ___ |
| 1920 | 1 microvolt is ___ |
| 1921 | Resistance of carbon filament lamp ___ |
| 1922 | A glass rod when rubbed with silk cloth is ___ |
| 1923 | A 40 W bulb is connected in series with a ___ |
| 1924 | All of the following are equivalent to ___ |
| 1925 | Electric pressure is also ___ |
| 1926 | The resistance of human body is ___ |
| 1927 | Three conductances in parallel have the ___ |
| 1928 | A nichrome wire used as a heater coil has the resistance of ___ |
| 1929 | A substance whose molecules consist of dissimilar atoms is ___ |
| 1930 | When electric current passes through a bucket full of water, lot of bubbling is ___ |
| 1931 | If Two bulbs of 500W and 200 W rated at 250 V will have ___ |
| 1932 | The thickness of insulation provided on the conductor depends on ___ |
| 1933 | The electrical conductivity of metals is ___ |
| 1934 | Which is the best conductor of electricity? |
| 1935 | An electrical lamp consumes 100 W of ___ |
| 1936 | The number of electrons in the outermost orbit of ___ |
| 1937 | A field of force can exist only between ___ |
| 1938 | In the case of direct current ___ |
| 1939 | When electric current passes through a metallic conductor, its ___ |
| 1940 | The insulation on a current carrying conductor is ___ |
| 1941 | Ohm’s law is not applicable to ___ |
| 1942 | The maximum current rating for a 10 kω, 0.5 W resistor is ___ |
| 1943 | The ratio of mass of proton to that of electron is ___ |
| 1944 | Three 6 ohm resistors are connected to form a ___ |
| 1945 | When resistance element of a heater fuses and then we reconnect it ___ |
| 1946 | Resistance of 220 V, 100 W lamp will be ___ |
| 1947 | If the efficiency of a machine is to be high, what should be low? |
| 1948 | The hot resistance of the bulb’s filament is higher than its ___ |
| 1949 | Which of the following statement is true both for a series and a parallel D.C. circuit? |
| 1950 | One newton metre is same as ___ |
| 1951 | All good conductors have ___ |
| 1952 | Which method can be used for absolute measurement of resistances? |
| 1953 | Copper wire of certain length and resistance is drawn out to ___ |
| 1954 | Two lamps 100 W and 40 W are connected in ___ |
| 1955 | Electric current passing through the ___ |
| 1956 | The four bulbs of 40 W each are connected in series with a ___ |
| 1957 | The electrical energy required to heat a bucket of water to ___ |
| 1958 | 1 angstrom is equal to ___ |
| 1959 | Which of the following one is correct? |
| 1960 | Which of the following relation is incorrect? |
| 1961 | Sparking occurs when a load is switched off because the circuit has ___ |
| 1962 | In a lamp load when more than one lamp are ___ |
| 1963 | Resistance of a tungsten lamp ___ |
| 1964 | Three 60W bulbs are in parallel across the ___ |
| 1965 | In gases the flow of current is ___ |
| 1966 | An instrument which detects electric current is ___ |
| 1967 | One coulomb charge equals the charge on ___ |
| 1968 | Conductance : mho :: ___ |
| 1969 | The condition for the validity under Ohm’s law is ___ |
| 1970 | Three identical resistors are first connected in parallel and ___ |
| 1971 | Switching of a lamp in house produces noise in ___ |
| 1972 | When one leg of parallel circuit is opened out the ___ |
| 1973 | If a parallel circuit is opened in the main line, the ___ |
| 1974 | The property of a conductor due to which it passes current is called ___ |
| 1975 | Which of the following can have negative temperature coefficient? |
| 1976 | When current flows through heater coil it glows but ___ |
| 1977 | International ohm is defined in terms of the resistance of ___ |
| 1978 | For testing appliances, the wattage of test lamp should be ___ |
| 1979 | It becomes more difficult to ___ |
| 1980 | In an electric kettle water boils in ___ |
| 1981 | The minimum charge on an ion is ___ |
| 1982 | Out of the following which is not a poor conductor? |
| 1983 | As the temperature of hot junction increases, the ___ |
| 1984 | The thermo electric power at the neutral temperature is ___ |
| 1985 | The Thomson coefficient for lead is ___ |
| 1986 | What is thermoelectric power? |
| 1987 | The unit of Peltier coefficient is ___ |
| 1988 | What is the name of graph between temperature and thermo emf.? |
| 1989 | The dimensions of the emf of a source of ___ |
| 1990 | Which of the following is not reversible? |
| 1991 | What is the nature of graph between temperature and thermoelectric power? |
| 1992 | The thermocouple can not act as ___ |
| 1993 | Seebeck effect is inverse of ___ |
| 1994 | What is converted into heat when current is set up through a conductor? |
| 1995 | The electrons revolve around the nucleus with ___ |
| 1996 | The quantity in electricity analogous to friction in linear mechanical motion is ___ |
| 1997 | How may 200 W/220 V incandescent lamps connected in ___ |
| 1998 | Electric current is a ___ |
| 1999 | The thermal speed of electrons is of the order of ___ |
| 2000 | The electric current in a liquid is due to the flow of ___ |
| 2001 | The fuse-wire is made of ___ |
| 2002 | The conductivity of a super-conductor is ___ |
| 2003 | Poor power factor results in all of the following ___ |
| 2004 | The dual of a loop is ___ |
| 2005 | Higher the Q of a series circuit ___ |
| 2006 | When an alternating current passes through an ohmic resistance the ___ |
| 2007 | For the full wave rectified sine wave the r.m.s. value is ___ |
| 2008 | In A.C. circuit laminated iron is invariably used in ___ |
| 2009 | In a circuit containing R, L and C, power loss can ___ |
| 2010 | All the rules and laws of D.C. circuit also supply to A.C. circuit containing ___ |
| 2011 | How much r.m.s. current does a 300 W. 200V bulb take from the 200 V, 50 Hz power line? |
| 2012 | The r.m.s. value and mean value is the same in the case of ___ |
| 2013 | The capacitors for power factor correction are rated in terms of ___ |
| 2014 | Two sinusoidal quantities are said to be phase quadrature, when ___ |
| 2015 | A coil with large distributed capacitance has a ___ |
| 2016 | A resonance curve for a series circuit is a plot of ___ |
| 2017 | The unit of frequency of an A.C. signal is ___ |
| 2018 | In an A.C. circuit, a low value of kVAR compared with ___ |
| 2019 | In a pure resistive circuit ___ |
| 2020 | Inductance affects the direct current flow ___ |
| 2021 | A sine wave of voltage varies from zero to ___ |
| 2022 | The power consumed in a circuit element will be least when the phase difference between ___ |
| 2023 | The form factor is the ratio of ___ |
| 2024 | Which of the following is not a non-linear element? |
| 2025 | The product of apparent power and cosine of the phase angle between ___ |
| 2026 | The power is measured in terms of decibles in case of ___ |
| 2027 | The safest value of current the human body can carry for ___ |
| 2028 | The power factor at resonance in RLC parallel circuit is ___ |
| 2029 | For 200 V r.m.s. value triangular wave, the peak voltage will be ___ |
| 2030 | Two waves of the same frequency have opposite phase when the ___ |
| 2031 | A network is said to be non-linear if ___ |
| 2032 | The power factor of a D.C. circuit is always ___ |
| 2033 | At ___ frequencies the parallel R-L circuit behaves as purely resistive |
| 2034 | If resistance is 20 ω and inductance is 2H in a RL series circuit, then ___ |
| 2035 | The transient currents are associated with the ___ |
| 2036 | The best place to install a capacitor is ___ |
| 2037 | For a sine wave with peak value ___ |
| 2038 | The voltage of domestic supply is ___ |
| 2039 | The shunt element of prototype high pass filter is ___ |
| 2040 | Ohm is the unit of all of the following except ___ |
| 2041 | The time constant of a series R-C circuit is given by ___ |
| 2042 | The double energy transient occur in the ___ |
| 2043 | In a series resonant circuit, the impedance of ___ |
| 2044 | Form factor for a sine wave is ___ |
| 2045 | The r.m.s. value of a sine wave is ___ |
| 2046 | The power factor of incandescent bulb is ___ |
| 2047 | In A.C. circuit the power curve is ___ |
| 2048 | The r.m.s. value of pure cosine function is ___ |
| 2049 | At very low frequencies a series R-C circuit behaves as ___ |
| 2050 | In a R-L-C series circuit if voltage V across the circuit is reduced to ___ |
| 2051 | In the R-L-C containing R = 4.5ω L = 0.06 H,C = 0.6 μF the power factor will be ___ |
| 2052 | The reflection co-efficient of the simplest standing wave is ___ |
| 2053 | In an A.C. circuit I sin Φ is ___ |
| 2054 | The negative maximum of a cosine wave occurs at ___ |
| 2055 | In a parallel R-C circuit, the current always ___ |
| 2056 | Power factor of electric bulb is ___ |
| 2057 | The r.m.s. value of a sinusoidal A.C. current is equal to ___ |
| 2058 | For a sine wave with peak value Imax the r.m.s. value is ___ |
| 2059 | A heater is rated as ___ |
| 2060 | The form factor of D.C. supply voltage is ___ |
| 2061 | The dual of a link is ___ |
| 2062 | The power factor of a series R-L-C circuit at its half-power points is ___ |
| 2063 | The frequency of domestic power supply in India is ___ |
| 2064 | Power factor of the following circuit will be ___ |
| 2065 | The r.m.s. value of a half-wave rectified current is ___ |
| 2066 | For the same peak value, which of the following wave has the least mean value? |
| 2067 | For the same peak value of voltage which wave form will have the least r.m.s. value? |
| 2068 | The series element of a band stop filter is ___ |
| 2069 | Selectivities of different resonance circuits are compared in terms of ___ |
| 2070 | While drawing vector diagram for a series circuit the reference vector is ___ |
| 2071 | Which of the following waves has the highest value of peak factor ‘? |
| 2072 | The ratio of active power to apparent power is known as ___ |
| 2073 | Which of the following circuit component opposes the change in the ___ |
| 2074 | Power factor of an inductive circuit is usually improved by ___ |
| 2075 | For the same peak value which of the following wave will have the highest r.m.s. value? |
| 2076 | Capacitive reactance is ___ |
| 2077 | The peak value of a sine wave is ___ |
| 2078 | What inductance will give the same reactance as a capacitor of 2 μF when both are at 50 Hz? |
| 2079 | The time period of a sine wave is 1/50 seconds ___ |
| 2080 | Which of the following motors does not use a centrifugal switch? |
| 2081 | The metal rectifiers are preferred over tube rectifiers as ___ |
| 2082 | Consider the following statements regarding the speed control of ___ |
| 2083 | If the speed of a dc motor increases with load torque, then it is a ___ |
| 2084 | The emf induced in a conductor rotating in a bipolar field is ___ |
| 2085 | A 10 mH inductor carries a sinusoidal current of 1 A rms at a frequency of ___ |
| 2086 | If the step response of an initially relaxed circuit is known, then the ___ |
| 2087 | The transients produced due to sudden but energetic changes from ___ |
| 2088 | The Fourier series expansion of an even periods function contains ___ |
| 2089 | The power of a three-phase. three-wire balanced system was measured by ___ |
| 2090 | Power factor of an inductive circuit is usually improved by adding a ___ |
| 2091 | In a linear network, the ratio of voltage excitation to current response is ___ |
| 2092 | When Q-factor of a circuit is high, then ___ |
| 2093 | In a network of resonance ___ |
| 2094 | When a sinusoidal voltage is applied across R-L parallel circuit so that ___ |
| 2095 | With the increase in applied frequency, the dielectric loss in a ___ |
| 2096 | The power factor of an ac circuit is equal to ___ |
| 2097 | Unit of inductive reactance is ___ |
| 2098 | The rms value of a sine wave is ___ |
| 2099 | Which one of the following is correct? |
| 2100 | In electrical circuits, transient currents are ___ |
| 2101 | If the reading of two-wattmeters are equal and positive in two wattmeter method, the load pf in a ___ |
| 2102 | A 3-phase 3-wire supply feeds a star connected load consisting of ___ |
| 2103 | While applying reciprocity theorem ___ |
| 2104 | Higher the Q of a series circuit, narrower its ___ |
| 2105 | Q-factor of a series R-L-C circuit possessing resonant frequency of ___ |
| 2106 | Consider the following statements with respect to ___ |
| 2107 | In a parallel R-L circuit if IR is the current in resistor and IL is ___ |
| 2108 | A square wave is fed to an ___ |
| 2109 | The power factor of an ordinary electric bulb is ___ |
| 2110 | Purely inductive circuit takes power from the ac mains when ___ |
| 2111 | The form factor of sinusoidal alternating current is ___ |
| 2112 | The shunt element of a bandpass filter is ___ |
| 2113 | Transient disturbance occurs in a circuit whenever it is ___ |
| 2114 | When two-wattmeter method of measurement of power is used to ___ |
| 2115 | At a frequency more than the resonant frequency ___ |
| 2116 | Change in circuit voltage will affect ___ |
| 2117 | For a series RLC circuit, the power factor at the lower power frequency is ___ |
| 2118 | At resonant frequency an R-L-C circuit draws maximum current due to the ___ |
| 2119 | Real part of admittance is ___ |
| 2120 | A certain R-L series combination is connected across a ___ |
| 2121 | The pf of a practical inductor is ___ |
| 2122 | Pure inductive circuit ___ |
| 2123 | The most important advantage of using electrical energy in the ___ |
| 2124 | Which of the following will act as open circuit at ___ |
| 2125 | The ratio of the readings of two wattmeters connected to measure power in a ___ |
| 2126 | In series as well as parallel reasonant circuit, increase in ___ |
| 2127 | Which of the following will not be affected due to change in R? |
| 2128 | A series circuit having a resonant frequency of 60 kHz is connected in ___ |
| 2129 | When a series R-L-C circuit is under resonance ___ |
| 2130 | In an R-L-C circuit ___ |
| 2131 | An ac source of 200 V rms supplies active power of ___ |
| 2132 | A 2-terminal network consists of one of the ___ |
| 2133 | A boiler at home is switched on to the ac mains supplying power at ___ |
| 2134 | An R-C series circuit is excited by a ___ |
| 2135 | Which of the following will act as short circuit at t = 0+ with zero initial conditions? |
| 2136 | Two complex waves will have the same wave form if ___ |
| 2137 | Two-wattmeter method is employed to measure power in a 3- phase balanced system with ___ |
| 2138 | For a 3-phase load balanced condition, each phase has the same value of ___ |
| 2139 | A parallel resonant circuit can be ___ |
| 2140 | In a series resonant circuit with the increase in the value of ___ |
| 2141 | In a series R-L-C circuit, the voltage across inductance will be maximum ___ |
| 2142 | The current through a series RLC circuit under resonance condition will be ___ |
| 2143 | A small capacitance is added to a ___ |
| 2144 | Unit of reactive power is ___ |
| 2145 | A two-terminal black box contains a series combination of a ___ |
| 2146 | In a purely resistive circuit, the average power ___ |
| 2147 | A current is said to be direct current when its ___ |
| 2148 | The Fourier transform of a function is equal to its ___ |
| 2149 | In an R-L circuit connected to an alternating sinusoidal voltage, the magnitude of ___ |
| 2150 | If a capacitor is energised by a symmetrical square wave current, then ___ |
| 2151 | Any waveform can be expressed in Fourier series if ___ |
| 2152 | The power delivered to a 3-phase load can be measured by the use of ___ |
| 2153 | Total instantaneous power supplied by a 3-phase ac supply to ___ |
| 2154 | In an RLC series resonant circuit, if the maximum stored energy is increased by ___ |
| 2155 | In a series resonant circuit, with the increase in ___ |
| 2156 | In a series R-L-C circuit, the maximum voltage across the capacitor occurs at ___ |
| 2157 | At resonance power factor of a series R-L-C circuit would be ___ |
| 2158 | In an RLC circuit, supplied from an ac source, the ___ |
| 2159 | The power factor of an ac circuit lies between ___ |
| 2160 | The reactance offered by a capacitor to ac of ___ |
| 2161 | Which of the following statements pertains to resistors only? |
| 2162 | A current is said to be alternating when it changes in ___ |
| 2163 | The impulse response of an R-L circuit is a ___ |
| 2164 | Inductance affects the flow of direct current at the ___ |
| 2165 | What is the average power for periodic non-sinusoidal voltages and currents? |
| 2166 | Three unequal impedances are connected in delta to a ___ |
| 2167 | The power measurement in balanced three-phase circuit can be ___ |
| 2168 | The rated voltage of a 3-phase power system is given as ___ |
| 2169 | In order to tune a parallel resonant circuit to a lower frequency, the ___ |
| 2170 | A coil is tuned to resonance at 500 kHz with a resonating capacitor of 36 pF at ___ |
| 2171 | A series R-L-C circuit, excited by a 100 V variable frequency source, has a ___ |
| 2172 | Under the condition of resonance in R-L-C series circuit, the ___ |
| 2173 | In an ac series RLC circuit, the voltage across R and L is 20 V, voltage across ___ |
| 2174 | Skin effect occurs when a conductor carries current at ___ |
| 2175 | A circuit component that opposes the change in ___ |
| 2176 | If two sinusoids of the same frequency but of different amplitudes and ___ |
| 2177 | Nonlinear system cannot be analysed by Laplace transform because ___ |
| 2178 | For ade voltage an inductor ___ |
| 2179 | If an ac voltage wave is corrupted with an arbitrary number of harmonics, then the ___ |
| 2180 | Phase reversal in a 4-wire unbalanced load supplied from a balanced 3-phase supply causes ___ |
| 2181 | A lamp load is given a supply from ___ |
| 2182 | Under the conditions of maximum power transfer from an ___ |
| 2183 | A parallel circuit is said to be in resonance when the ___ |
| 2184 | Consider the following statementsregarding the frequency response curve of ___ |
| 2185 | A coil having a resistance of 5 ω and inductance of 0.1 H is connected in ___ |
| 2186 | A resistance of ‘R’ω and inductance ‘L’ H are connected across ___ |
| 2187 | A two terminal black box contains one of the ___ |
| 2188 | The power consumed in an inductive circuit will be ___ |
| 2189 | A pure capacitance connected across 50 Hz, 230 V supply consumes ___ |
| 2190 | The rms value of the resultant current in a wire which carries a dc current of ___ |
| 2191 | Laplace transform of the output response of a linear system is the ___ |
| 2192 | A component that opposes the change in ___ |
| 2193 | An even waveform when expressed in exponential fourier series will ___ |
| 2194 | In a 3-phase supply, floating neutral is undesirable because it may result in ___ |
| 2195 | To improve the pf in three-phase circuits, the capacitor bank is ____ |
| 2196 | According to maximum power transfer theorem, when is the maximum power absorbed by ___ |
| 2197 | An R-L-C series resonant circuit, if inductance of the circuit is made double and the ___ |
| 2198 | A high Q coil has ___ |
| 2199 | In a series RLC circuit at resonance, the magnitude of ___ |
| 2200 | Capacitive susceptance is a measure of ___ |
| 2201 | A 100 W, 100 V bulb is to be supplied from 220 V, 50Hz supply ___ |
| 2202 | Power factor of the following circuit will be zero ___ |
| 2203 | The first and the last critical frequencies (singularities) of a driving point impedance function of a ___ |
| 2204 | Which of the following theorems can be applied to any network linear or nonlinear, active or passive, time-variant or time-invariant? |
| 2205 | Nodal analysis is based on ___ |
| 2206 | A network has 10 nodes and ___ |
| 2207 | Which of the following is an active element in a circuit? |
| 2208 | The electromagnet is made of ___ |
| 2209 | In order to iriinimise loss due to hysteresis the ___ |
| 2210 | In case all the flux from the current in coil 1 links with coil 2, the ___ |
| 2211 | An open coil has ___ |
| 2212 | There is a constant homogeneous magnetic field pointing in a ___ |
| 2213 | Linkage flux per unit current is called ___ |
| 2214 | Reluctance offered by the magnetic circuit depends upon ___ |
| 2215 | Which of the following is a vcctor quantity? |
| 2216 | Air exhibits ___ |
| 2217 | When a plane wave propagates in a ___ |
| 2218 | Potential difference across a capacitor of capacitance 20 µF is increased uniformly from ___ |
| 2219 | When the plate area of a parallel plate capacitor is increased keeping the capacitor voltage constant, the ___ |
| 2220 | Two electrons moving parallel to each other at the ___ |
| 2221 | The relation between the breakdown voltage V and the thickness t of the dielectric is given as ___ |
| 2222 | Tangential component of the electric field on a perfect conductor will be ___ |
| 2223 | During charging and discharging of an ___ |
| 2224 | Overcharging of a lead acid battery would cause ___ |
| 2225 | Which of the following tests is performed for ascertaining whether the battery plates are defective or not? |
| 2226 | Which of the following substances on adding in electrolyte helps in producing bright finish? |
| 2227 | The arrangement of 12 cells, each of internal resistance 1.5 ω, to give ___ |
| 2228 | If a very flexible wire is laid out in the shape of a hair pin with its two ends secured, what shape will ___ |
| 2229 | Ohm’s law in point form in field theory can be expressed as ___ |
| 2230 | Two wires A and B of the same material and length l and 2l have ___ |
| 2231 | Poynting vector is a measure of which one of the following? |
| 2232 | Which among these following statements is correct? |
| 2233 | Which one of the following statements is correct? |
| 2234 | A network consists of linear resistors and ideal voltage source ___ |
| 2235 | Which of the following materials possesses the least specific resistance? |
| 2236 | The lowest and the highest critical frequencies of an R-L driving point impedance are ___ |
| 2237 | In a balanced Wheatstone bridge, if the positions of detector and source are interchanged, the ___ |
| 2238 | Superposition theorem is applicable for ___ |
| 2239 | Kirchhoff’s laws are not applicable to ___ |
| 2240 | Ideal voltage source have ___ |
| 2241 | An electric circuit with 10 branches and 7 nodes will ___ |
| 2242 | The terminals across the source are ____ if a current source is to be neglected |
| 2243 | The magnetic field strength of an air-cored coil can be increased by ___ |
| 2244 | The hysteresis loss is caused by ___ |
| 2245 | The shape of B-H curve for air gap is ___ |
| 2246 | The coupling between two magnetically coupled coils is said to be ideal if ___ |
| 2247 | Lower the self inductance of a ___ |
| 2248 | Which law is synonymous to the occurrence of diamagnetism? |
| 2249 | Two parallel wires separated by a distance dare carrying a ___ |
| 2250 | The conductance of electrical circuit is analogous inmagnetic circuit by ___ |
| 2251 | If a current carrying conductor is placed in a magnetic field, the mechanical force experienced on the ___ |
| 2252 | Magnetic flux density emerging out of a closed surface is ___ |
| 2253 | Iron is a ___ |
| 2254 | The normal components of electric flux density across a ___ |
| 2255 | The capacitor charged up to 5 ms, as per the current profile given in the figure, is connected across an ___ |
| 2256 | A parallel plate capacitor has capacitance of ___ |
| 2257 | The relation between electric polarization and susceptibility indicates that the ___ |
| 2258 | A medium behaves like dielectric when the ___ |
| 2259 | The capacity of a lead acid battery is adversely affected by ___ |
| 2260 | When a piece of iron is placed in a magnetic field ___ |
| 2261 | Short circuiting of a cell results in ___ |
| 2262 | Which of the following statement(s) is/are correct? |
| 2263 | In a lead acid battery, fillers are provided to ___ |
| 2264 | If an ohmmeter reading immediately goes practically to zero and stays there while checking a ___ |
| 2265 | Addition of which of the following substances in electrolyte promotes smooth deposition? |
| 2266 | The condensers of 20 µF and 40 µF capacitance are connected in series across a ___ |
| 2267 | For a group of cells when internal resistance of the group is equal to ___ |
| 2268 | In a parallel plate capacitor, a dielectric slab is ___ |
| 2269 | Two heaters, rated at 1000 W, 250 V each are connected in series across a ___ |
| 2270 | The condition for the validity of Ohm’ s law is that the ___ |
| 2271 | In a charge-free space, the Poisson’s equation results in which one of the following? |
| 2272 | Current velocity through a copper conductor is ___ |
| 2273 | Inside a hollow conducting sphere ___ |
| 2274 | Four 100 W bulbs are connected in parallel across 200 V supply line ___ |
| 2275 | The energy capacity of a storage battery is rated in ___ |
| 2276 | The unit of the Poynting vector is ___ |
| 2277 | Charging of a sulphated battery at high rate causes ___ |
| 2278 | For a uniform plane electromagnetic wave ___ |
| 2279 | For keeping the lead acid battery terminals free from corrosion it is advisable to ___ |
| 2280 | Where is the Laplace’s equation valid? |
| 2281 | Rust, scales and oxides can be removed from a surface with the help of ___ |
| 2282 | How are 500 ω resistors connected so as to give an effective resistance of 750 ω? |
| 2283 | A battery is connected to a resistance causing a current of 0.5 A in the ___ |
| 2284 | Specific resistance of a conductor depends upon ___ |
| 2285 | A pole of driving point admittance function implies ___ |
| 2286 | Which of the following is not equivalent to watts? |
| 2287 | For a linear network containing generators and impedances, the ratio of the voltage to the ___ |
| 2288 | Pure metals generally have ___ |
| 2289 | Maxwell’ s loop current method of solving electrical networks ___ |
| 2290 | ____ coefficient is numerically equal to the difference of potential per °C |
| 2291 | Kirchhoff’ s laws are valid for ___ |
| 2292 | A higher directivity is specified by ___ |
| 2293 | Constant voltage source is ___ |
| 2294 | Consider the following statements connection with electromagnetic waves ___ |
| 2295 | There are b branches and n nodes the number of equations will be ___ |
| 2296 | Equipotential surfaces about a pair of equal and opposite linear charges exist in what form? |
| 2297 | For a perfect conductor, the field strength at a distance equal to the skin depth is X% of the ___ |
| 2298 | Two resistors R1 and R2 give combined resistance of 4.5 ω when in series and 1 ω when in ___ |
| 2299 | Which of the following statements associated with inductors is wrong? |
| 2300 | The temperature coefficient of resistance of a wire is ___ |
| 2301 | Hysteresis loss least depends on ___ |
| 2302 | For a two-port symmetrical bilateral network, if A = 3 and B = 1 ω, the value of ___ |
| 2303 | Which of the following statements should be true if one compares the hysteresis loops of ___ |
| 2304 | When the power transferred to the load is maximum, the efficiency of power transfer is ___ |
| 2305 | The coils having self-inductance of 10 mH and 15 mH and effective inductance of ___ |
| 2306 | Superposition theorem is not applicable for ___ |
| 2307 | If in an iron cored coil the iron core is removed so as to make the air-cored coil, the inductance of the ___ |
| 2308 | A voltage source having an open-circuit voltage of 100 V and internal resistance of 50 ω is ___ |
| 2309 | In all cases of electromagnetic induction, an induced voltage will cause a current to flow in a ___ |
| 2310 | What is the number of chords of a connected graph G of n vertices and e edges? |
| 2311 | The force per unit length between two stationary parallel wires carrying ___ |
| 2312 | A circuit having neither any energy source nor emf source is called ___ |
| 2313 | A coil wound over an iron ring carries certaincurrent and ___ |
| 2314 | Two coils having equal resistances but different inductances are connected in ___ |
| 2315 | The magnitude of force acting on a current carrying conductor placed in a ___ |
| 2316 | A coil of 1,000 turns is wound on a ___ |
| 2317 | Which of the following statements associated with magnetic field is correct? |
| 2318 | In a magnetic material, hysteresis loss takes place primarily due to ___ |
| 2319 | The magnetic susceptibility of a paramagnetic material is ___ |
| 2320 | The magnetic field required to reduce the residual magnetisation to zero is called ___ |
| 2321 | While checking a good 0.05 µF capacitor by ohmmeter, its reading will ___ |
| 2322 | The overall inductance of two coils connected in series, with mutual inductance aiding self inductance is ___ |
| 2323 | Which of the following statements associated with capacitors is wrong? |
| 2324 | The unit(s) of inductance is/are ___ |
| 2325 | The magnitude of induced emf in a conductor depends upon the ___ |
| 2326 | The unit of polarization is the same as that of ___ |
| 2327 | If the two conductors carry current in opposite directions there will be ___ |
| 2328 | Which of the following statement(s) is/are valid in case of conductors in electrostatic fields? |
| 2329 | An electric field is parallel but opposite to a magnetic field ___ |
| 2330 | Sulphated cells are indicated by the ___ |
| 2331 | A plane wave travelling in air is incident on a conducting medium ___ |
| 2332 | In a battery, cover is placed over the elements and sealed at the top of ___ |
| 2333 | Equipotential surfaces about a point charge are in which one of the following forms? |
| 2334 | Oil and grease can be removed from a ___ |
| 2335 | Twelve 1 ω resistance are used as edges to ___ |
| 2336 | A 24 V battery of internal resistance r = 4 ω connected to a ___ |
| 2337 | If the length of a wire of resistance R is uniformly stretched to n times its ___ |
| 2338 | “The total electric flux through any closed surface surrounding charges is equal to the ___ |
| 2339 | Pole of a network is a frequency at ___ |
| 2340 | Correct form of Ohm’s law ___ |
| 2341 | A human nerve cell has an open-circuit voltage of 80 mV and it can deliver a current of 5 nA through a ___ |
| 2342 | The minimum requirements for causing flow of ___ |
| 2343 | Which of the following theorems is applicable for both linear and nonlinear circuits? |
| 2344 | Thermoelectric power at neutral temperature is ___ |
| 2345 | To neglect a voltage source, the terminals across the ___ |
| 2346 | If reflection coefficient for voltage be 0.6. the ___ |
| 2347 | For a voltage source ___ |
| 2348 | What will be the reflected wave for an elliptically polarized wave incident on the interface of a die-electric at ___ |
| 2349 | A network has 4 nodes and 3 independent loops ___ |
| 2350 | Which one of the following is the correct statement? |
| 2351 | An electromagnetic field is radiated from ___ |
| 2352 | Three parallel resistive branches are connected across a dc supply ___ |
| 2353 | The energy stored in the magnetic field of a solenoid 30 cm long and 3 cm diameter wound with ___ |
| 2354 | Resistance of a wire always increases if ___ |
| 2355 | The area of hysteresis loop is a measure of ___ |
| 2356 | A passive 2-port network is in a steady-state ___ |
| 2357 | The coercive force in a ferromagnetic material is related to ___ |
| 2358 | Which of the following statements is/are correct? |
| 2359 | Kirchhoff’s voltage law is concerned with ___ |
| 2360 | Inductance has the dimensions of ___ |
| 2361 | A constant current source supplies a current of 300 mA to a load of ___ |
| 2362 | The laws of electromagnetic induction (Faraday’s md Lenz’s laws) are summarized in the ___ |
| 2363 | The number of possible ordered trees with ___ |
| 2364 | A straight conductor of circular x-section carries a ___ |
| 2365 | A network having one or more than one source of emf is known as ____ |
| 2366 | The property of a material which opposes the production of magnetic flux in ___ |
| 2367 | At a certain current, the energy stored in an iron-cored coil is 1,000 J and its ___ |
| 2368 | An infinitely long straight conductor located along Z-axis carries a current I in the ___ |
| 2369 | Energy stored by a coil is doubled when its current is ___ |
| 2370 | Iron loss is known as ___ |
| 2371 | Materials subjected to rapid reversals of magnetism should have ___ |
| 2372 | The mutual inductance between two coupled coils is ___ |
| 2373 | The principle of dynamically induced emf is utilised in a ___ |
| 2374 | According to Faraday’s law of electromagnetic induction an emf is induced in ___ |
| 2375 | Which of these below statements is correct? |
| 2376 | The force experienced by a current canying conductor lying parallel to ___ |
| 2377 | Magnetic current is composed of which of the following? |
| 2378 | The bar magnet has ___ |
| 2379 | The magnetic materials exhibit the property of ___ |
| 2380 | If the dielectric of a capacitor is replaced by a ___ |
| 2381 | Two capacitors each having capacitance C and breakdown voltage V are ___ |
| 2382 | In a multilayer dielectric material on either side of a ___ |
| 2383 | Polarization of dielectric materials results in ___ |
| 2384 | The charge on an isolated conductor resides ___ |
| 2385 | Which one of the following statements does not state that electrostatic field is conservative? |
| 2386 | The emf of a lead battery ___ |
| 2387 | In a lead acid battery, excessive formation of lead sulphate occurs ___ |
| 2388 | During discharging of lead acid cells, the terminal voltage decreases with ___ |
| 2389 | Pickling is ___ |
| 2390 | Five cells are connected in series in a row and then four such rows are connected in parallel to feed the current to a resistive load of ___ |
| 2391 | When an electric current flows through a conductor, its temperature rises ___ |
| 2392 | A 100 watt light bulb burns on an average of 10 hours a ___ |
| 2393 | A 200 W, 230 V lamp is connected across ___ |
| 2394 | Neutral temperature of a thermocouple ___ |
| 2395 | If the maximum and minimum voltages on a transmission line are 4 V and 2 V, respectively, for a ___ |
| 2396 | The flux density unit is ___ |
| 2397 | Unit of electric intensity is ___ |
| 2398 | Four resistances 80 ω, 50 ω, 25 ω and R are connected in ___ |
| 2399 | Which of the following statements is correct regarding resistance? |
| 2400 | A, B, C and D represent the transmission parameters of a ___ |
| 2401 | While determining RTH of a ___ |
| 2402 | A dependent source ___ |
| 2403 | The graph of an electrical network has N nodes and B branches ___ |
| 2404 | The elements which are not capable of delivering energy by its own are ___ |
| 2405 | Coil with a certain number of turns has a specified time constant ___ |
| 2406 | Magnetostriction is a phenomenon of ___ |
| 2407 | Two conducting thin coils X and Y (identical except for a thin cut in coil Y) are placed in a uniform magnetic field which is ___ |
| 2408 | Mutual inductance between two magnetically coupled coils depends on the ___ |
| 2409 | When a single turn coil rotates in a uniform magnetic field, at a uniform speed the ___ |
| 2410 | Which of the following is correct option? |
| 2411 | An air gap is usually inserted in magnetic circuits so as ___ |
| 2412 | Which of the following statements holds of the divergence of electric and magnetic flux densities? |
| 2413 | A permeable substance is ___ |
| 2414 | For removing static charge from machinery the ___ |
| 2415 | In a cable capacitor, voltage gradient is maximum at the ___ |
| 2416 | Dielectric strength of a medium ___ |
| 2417 | Two spheres of radii r1 and r2 are connected by a conducting wire ___ |
| 2418 | Coulomb’ s law for the force between electric charges most closely ___ |
| 2419 | The condition of a fully charged lead acid battery cannot be ___ |
| 2420 | In lead acid batteries, sedimentation occurs due to ___ |
| 2421 | Which of the following statements is correct about lead acid batteries? |
| 2422 | During electrodeposition. the amounts of different substances liberated by same quantity of ___ |
| 2423 | Internal resistance of primary cell varies ___ |
| 2424 | Ohm’s law is applicable to ___ |
| 2425 | Which of the following does not use heating effect of electric current? |
| 2426 | The electrical conductivity of metals is typically df the order of ___ |
| 2427 | The temperature of hot junction of a thermocouple at which the thermo-emf is ___ |
| 2428 | Which of the following is a vector quantity? |
| 2429 | Joule/coulomb is the unit of ___ |
| 2430 | The flow of electric current in a conductor is due to ___ |
| 2431 | The temperature coefficient of resistance of an insulator is ___ |
| 2432 | The poles and zeroes of an all-pass network are located in which part of the s-plane? |
| 2433 | Millman’s theorem yields equivalent ___ |
| 2434 | While Thevenizing a circuit between two terminals, VTH is ___ |
| 2435 | A practical current source is represented by ___ |
| 2436 | A connected network of N > 2 nodes has at most one branch directly connecting any ___ |
| 2437 | The circuit having same properties in either direction is known as ___ |
| 2438 | When a battery of E volts is suddenly applied across an ideal inductance of ___ |
| 2439 | Magnetostriction is a phenomenon whereby the magnetisation of a ferromagnetic material leads to ___ |
| 2440 | Two identical coils of negligible resistance, when connected in series across a 50Hz fixed voltage ___ |
| 2441 | The inductance of a single layer solenoid of 10 turns is ___ |
| 2442 | If a copper conductor is moved across a ___ |
| 2443 | Δx E = dB/dt is derived from ___ |
| 2444 | The field at any point on the axis ofa current carrying coil will be ___ |
| 2445 | Image theory is applicable to problems involving ___ |
| 2446 | Soft magnetic material is ___ |
| 2447 | What is the value of total electric flux coming out of a closed surface? |
| 2448 | For preventing the generation of static charge on rubber or ___ |
| 2449 | Energy density in a static electric field is given by ___ |
| 2450 | Dielectric strength of a material depends on ___ |
| 2451 | The potential inside a charged hollow sphere is ___ |
| 2452 | A floating battery is one ___ |
| 2453 | Battery charging equipment should be installed ___ |
| 2454 | Common impurity in a battery electrolyte is ___ |
| 2455 | Which of the following statements is incorrect about lead acid batteries? |
| 2456 | During electroplating the weight of a ___ |
| 2457 | The emf of primary cell depends upon the ___ |
| 2458 | An electric current is the ___ |
| 2459 | The draft velocity of electrons is ___ |
| 2460 | In gases the flow of current is due to ___ |
| 2461 | The absorption or evolution of heat energy, if a current is allowed to flow in a conductor having its ___ |
| 2462 | What causes electromagnetic wave polarization? |
| 2463 | For determining the polarity of the voltage drop across a resistor, it is ___ |
| 2464 | The hot resistance of the filament of a bulb is higher than the ___ |
| 2465 | The theorem that enables a number of voltage (or current) sources to be ___ |
| 2466 | In nodal analysis, if there are N nodes in the circuit, then how many equations will be ___ |
| 2467 | Ideal current source have ___ |
| 2468 | If the number of branches in a network is ‘B’, the number of nodes is ‘N’ and the number of ___ |
| 2469 | Which of the following is not bilateral element? |
| 2470 | Core of an electromagnet should have ___ |
| 2471 | Which of the following inductors will have the least eddy current losses? |
| 2472 | Two coils are coupled in such a way that the mutual inductance between them is ___ |
| 2473 | The inductance of a long solenoid of length 1,000 mm wound uniformly with 3000 turns on a ___ |
| 2474 | The emf induced in a coil due to relative motion of a magnet is ___ |
| 2475 | The magnetic field intensity (in A/m) at the centre of a circular coil of diameter 1 m and ___ |
| 2476 | Soft magnetic materials have ___ |
| 2477 | The surface integral of the electrical field intensity is ___ |
| 2478 | The dissipation factor of good dielectric is of the ___ |
| 2479 | During dielectric breakdown of a ___ |
| 2480 | The electric potential due to an electric dipole of length l at a point distance r away from it ___ |
| 2481 | Nickel-cadmium accumulators in comparison to nickel-iron accumulators have ___ |
| 2482 | In comparison to constant current charging method, the constant voltage charging method of ___ |
| 2483 | Vent plug is provided in each lead acid cell to ___ |
| 2484 | In a lead acid battery, the level of the electrolyte should be ___ |
| 2485 | Standard cell ___ |
| 2486 | Capacity of a dry cell is ___ |
| 2487 | The electrons revolve around the nucleus with high velocity ___ |
| 2488 | How may 200 W/220 V incandescent lamps connected in series would consume the same total power as a ___ |
| 2489 | EMF of a thermocouple depends upon the ___ |
| 2490 | Why is delay distortion in coaxial cables caused? |
| 2491 | Three resistances each of R Ω are corrected to form a triangle ___ |
| 2492 | The insulation resistance of a cable of length 10 km is 1 Mega Ohm’s ___ |
| 2493 | Constant power locus of transmission line at particular sending end and ___ |
| 2494 | Transmission efficiency of transmission line increases with ___ |
| 2495 | Surge Impedance loading of a transmission line can be ___ |
| 2496 | A travelling wave 400/1/50 means crest value of ___ |
| 2497 | If the traveling wave which is traveling along the loss free line which does not undergone any reflection after it ___ |
| 2498 | Bundled Conductors are used for EHV transmission lines ___ |
| 2499 | A travelling wave due to lightning with an incident voltage V travels through the ___ |
| 2500 | In a 7/30 ACSR conductor why is grease put between steel and ___ |
| 2501 | What is the surge impedance loading of a lossless 400kV, 3 phase, 50Hz overhead line of average of ___ |
| 2502 | When is the Ferranti effect on long over head lines experienced ___ |
| 2503 | The inertia of two group of machines which swing together are ___ |
| 2504 | For stability and economic reason we operate the transmission line with ___ |
| 2505 | The stability of the power system is not ___ |
| 2506 | Which one of the following is ___ |
| 2507 | Equal area criteria gives the ___ |
| 2508 | Steady state stability of the power system is improved by ___ |
| 2509 | If a generator of 250MVA rating has an inertia constant of 6MJ/MVA, its inertia constant on ___ |
| 2510 | The inertia constant of the two machines which are not ___ |
| 2511 | The use of high speed breakers can ___ |
| 2512 | The transient stability limit of the power system can be increased by ___ |
| 2513 | The steady state stability of the power system can be ___ |
| 2514 | If the torque angle of the alternator increases indefinitely the ___ |
| 2515 | The equal area criteria of stability is used for ___ |
| 2516 | The Critical Clearance time of a fault in the power system is ___ |
| 2517 | An ideal voltage source should have ___ |
| 2518 | Which of the following is ___ |
| 2519 | The superposition theorem requires as many circuits to be solved as ___ |
| 2520 | For maximum transfer of power, internal resistance of the ___ |
| 2521 | Kirchhoff’s laws are applicable to ___ |
| 2522 | If there are ‘b’ branches and ‘n’ nodes the number of ___ |
| 2523 | A terminal where more than two branches met is ___ |
| 2524 | Factors on which soil resistance depends ___ |
| 2525 | Moisture content in the soil ___ |
| 2526 | The objective of earthing or grounding is ___ |
| 2527 | When earth fault occurs ___ |
| 2528 | For an EHV equipment for maintenance first it should be isolated and connected to ___ |
| 2529 | Ground resistance should be designed such that ___ |
| 2530 | Generally grounding is provided for ___ |
| 2531 | Average resistance of human body is ___ |
| 2532 | Earth wire or ground wire is made of ___ |
| 2533 | The size of the earth or ground wire is based on ___ |
| 2534 | Which of the following material is more susceptible to ___ |
| 2535 | The relation between the fusing current (I) and diameter (d) of the ___ |
| 2536 | Heat generated in the HRC fuse is dissipated mainly through ___ |
| 2537 | A material best suited for the manufacture of the ___ |
| 2538 | The material used for the fuse wire should be of ___ |
| 2539 | The fuse blows off by ___ |
| 2540 | The delay fuses are used for the protection of ___ |
| 2541 | A fuse in a motor circuit provides protection against ___ |
| 2542 | The expected life of an incandescent lamp is ___ |
| 2543 | Which of the materials is most commonly used for the filaments in the ___ |
| 2544 | Which of the following colour has the wavelength between ___ |
| 2545 | An object which appears to be red to the ___ |
| 2546 | Candle power is ___ |
| 2547 | Sky appears to be blue because of ___ |
| 2548 | Candela is the unit of ___ |
| 2549 | Luminous flux is ___ |
| 2550 | Visible spectrum of the light has a wavelength in the ___ |
| 2551 | Light ___ |
| 2552 | Solder is an alloy of ___ |
| 2553 | Gold, Silver and Copper are good conductors because their ___ |
| 2554 | The formation of oxide film on the metal is due to ___ |
| 2555 | The property of materials by which it can be rolled into sheets is ___ |
| 2556 | Which of the following is the ___ |
| 2557 | Annealing of metals ___ |
| 2558 | Forbidden band is largest in ___ |
| 2559 | The relative permeability of the super conductor materials is ___ |
| 2560 | In metals the type of bond present is ___ |
| 2561 | The resistance of the most of the conducting materials ___ |
| 2562 | Which of the following relays has inherent directional characteristics ___ |
| 2563 | The operation speed of a relay depends on ___ |
| 2564 | The relay with inverse time characteristics will ___ |
| 2565 | Buchholz relay is a ___ |
| 2566 | The torque developed in Induction type relay is ___ |
| 2567 | Admittance relay is ___ |
| 2568 | Differential relays are used for the protection of ___ |
| 2569 | Earth fault relays are ___ |
| 2570 | Under-voltage relay is mostly used for ___ |
| 2571 | Isolators are used for disconnecting a ___ |
| 2572 | Buchholz relay is ___ |
| 2573 | Thermal relays are used for the protection of motors against over-current owing to ___ |
| 2574 | A lightning arrester connected between the line and earth in a ___ |
| 2575 | Solid earthing is provided for the voltage below ___ |
| 2576 | The short circuit current of an alternator, inc case of line to line fault depends on its: |
| 2577 | The relay best suited for phase fault relaying for medium transmission lines is ___ |
| 2578 | The relay used for the feeder protection is ___ |
| 2579 | Any winding of a power transformer develops ___ |
| 2580 | Mho relay have an R-X characteristics depicted by ___ |
| 2581 | A thermal protection switch is used to provide protection against ___ |
| 2582 | Arc chutes are used in ___ |
| 2583 | Which of the following circuit breakers produce ___ |
| 2584 | Breaking capacity of the circuit breaker is usually expressed in ___ |
| 2585 | The arc voltage produced in an ac circuit breaker is ___ |
| 2586 | The contact resistance is least affected by ___ |
| 2587 | Sparking between the contacts can be reduced by ___ |
| 2588 | The most efficient torque-producing actuating structure for ___ |
| 2589 | Relay contacts are normally made up of ___ |
| 2590 | It is the minimum clearance required between the live conductors and ___ |
| 2591 | Step potential and Touch potential is ___ |
| 2592 | In a substation current transformers are used to ___ |
| 2593 | A busbar is rated by ___ |
| 2594 | What is the maximum transmission voltage substation in ___ |
| 2595 | Which of the following bus-bars arrangement is ___ |
| 2596 | Which of the gas is used in gas insulated substation ___ |
| 2597 | A bus coupler circuit breaker is utilized in a ___ |
| 2598 | Gas Insulated Substation is employed ___ |
| 2599 | Which is the first equipment seen in the substation while coming from ___ |
| 2600 | What is Marshalling Kiosk in ___ |
| 2601 | The size of Gas Insulated Substation is significantly small compared to ___ |
| 2602 | Emulsifier protection is associated with ___ |
| 2603 | Earthing conductivity is affected by ___ |
| 2604 | Which of the following busbar arrangement is generally employed in ___ |
| 2605 | Which of the device is employed in substation to limit the short circuit current in the ___ |
| 2606 | In substation which of the device is a ___ |
| 2607 | What is the minimum phase to phase clearance required for 400kV conductors in ___ |
| 2608 | In order to improve the power factor ___ |
| 2609 | Stones are provided in the substation to ___ |
| 2610 | Internal voltage drop of a voltage source ___ |
| 2611 | Cells are connected in series in order to ___ |
| 2612 | The capacity of lead acid battery is adversely by ___ |
| 2613 | The capacity of battery is expressed in ___ |
| 2614 | Vent plug is provided in each lead acid cells to ___ |
| 2615 | During the discharge of lead acid battery, the terminal voltage decreases with ___ |
| 2616 | The law that finds application in electrolysis is ___ |
| 2617 | When two cells are connected in parallel, it should be ensured that ___ |
| 2618 | The emf of a primary cell depends upon the ___ |
| 2619 | The cell which is used as standard cell is ___ |
| 2620 | The curve representing Ohms law is ___ |
| 2621 | The ratio of voltage and electrical current in a ___ |
| 2622 | Voltage is a form of ___ |
| 2623 | The resistance of the wire varies inversely as ___ |
| 2624 | Resistance of human body is ___ |
| 2625 | Ampere-second is the unit of ___ |
| 2626 | Which of the following current is considered dangerous to ___ |
| 2627 | Current velocity through the copper conductor is ___ |
| 2628 | The minimum requirement for causing flow of current are ___ |
| 2629 | The flow of electric current in a conductor is due to the ___ |
| 2630 | The form factor for dc supply voltage is ___ |
| 2631 | An insulation is subjected to ___ |
| 2632 | Which of the statement pertained to resistance is ___ |
| 2633 | An ac generator running at 1000 rpm produces emf of ___ |
| 2634 | The ratio of the effective value to the peak value is called the ___ |
| 2635 | Which of the following statements associated with purely resistive circuit is ___ |
| 2636 | A phasor in a line which represents the ___ |
| 2637 | In a purely inductive circuit ___ |
| 2638 | In a R-L Series circuit the power factor is ___ |
| 2639 | An instantaneous change in voltage is not possible in ___ |
| 2640 | The rating of given on the name plate of a transformer indicates the ___ |
| 2641 | In a circuit low reactive power compared to ___ |
| 2642 | When the power factor in the transmission line is leading, which device is employed at substation to ___ |
| 2643 | The heat developed in an electric iron is attributed to ___ |
| 2644 | In an ac circuit i x sin (Phi) is called the ___ |
| 2645 | The power factor of an ac circuit is ___ |
| 2646 | In an induction motor when the air gap field between rotor and stator increases ___ |
| 2647 | In order to improve the power factor which device should be connected to the ___ |
| 2648 | A Circuit of zero lagging power factor behaves as ___ |
| 2649 | The power factor of ac circuit lies ___ |
| 2650 | A battery is rated according to a 20-hour rate of discharge at 300 ampere-hours ___ |
| 2651 | What determines the amount of current that a cell can deliver to the external circuit? |
| 2652 | Common method(s) of controlling electrical power with reactance ___ |
| 2653 | Which, if any, of the following types of variable resistors is used to control a large amount of current? |
| 2654 | Which of the following devices can be used as a position sensor in a servo system? |
| 2655 | In a dc position servo system, what characteristic of the error signal determines the direction in which the load is driven? |
| 2656 | What is a medium of communication with a computer where programs are written in mnemonics? |
| 2657 | Transition region refers to with regard to transistor ___ |
| 2658 | ___ refers to the term remote sensing with regard to a linear voltage regulator |
| 2659 | Find the dielectric constant of air ___ |
| 2660 | Diagram showing procedures which are followed and actions taken is called ___ |
| 2661 | What network facility is used to interconnect distinct networks physically? |
| 2662 | How do you determine if diode is defective? |
| 2663 | Which of the following is a characteristic of cascaded amplifier? |
| 2664 | What is the reason why more cells can be stored in a given area with dynamic cells? |
| 2665 | Find the value of voltage regulation having a dc voltage of 67 V without load and with full load current drawn the output voltage drops to 42 V ___ |
| 2666 | ___ is the unit of reluctance |
| 2667 | Which class of amplifier has the highest linearity and least distortion ___ |
| 2668 | ___ is the region in a transistor that is heavily doped |
| 2669 | What is the gain of a vacuum tube having the following parameter amplification factor is 80, external plate-load resistance of 30,000 ohms and the tubes internal plate resistance is 10,000 ohms? |
| 2670 | Refers to that part of computer that interprets and executes instructions ___ |
| 2671 | The energy of an oscillator can be source by ___ |
| 2672 | Find the half-power bandwidth of a resonant circuit which has a resonant frequency of 1.8 MHz and a Q of 95 |
| 2673 | What do you call an electronic component that is a non-linear resistor and its resistance is function of the voltage across it? |
| 2674 | ___ is the procedure by which an atom is given a net charge by adding or taking away of electron |
| 2675 | What do you call an electromagnet with its core in a form of magnetic ring? |
| 2676 | ___ is gaseous tube which uses a pool of liquid mercury as its cathode |
| 2677 | What type of circuit whose parameters are constant which do not change with voltage of current? |
| 2678 | Which statement is not true? |
| 2679 | Which of the following statement is incorrect? |
| 2680 | What do you call a circuit that changes pure binary code into ASCII? |
| 2681 | ___ is the progressive decay with time in the amplitude of the free oscillation in a circuit |
| 2682 | Term used for response in an electrical circuit ___ |
| 2683 | A ____ is a junction field effect transistor with a Schottky barrier instead of a normal semiconductor junction |
| 2684 | ___ is the property of magnetic materials which retain magnetism after magnetizing force is withdrawn |
| 2685 | ___ refers to a program that translates and then immediately executes statements in a high level language |
| 2686 | ___ is the term used to express the ratio of the change in the dc collector current to a change in base current in a bipolar transistor |
| 2687 | Speed of a logic circuit is normally expressed as ___ |
| 2688 | ___ is the output voltage of a carbon-zinc cell |
| 2689 | The reason for the thin layer of varnish over the copper coil pattern is to prevent ___ |
| 2690 | A digital word consisting of only four bits is called a ___ |
| 2691 | Parallel cells have the same voltage as one cell but have ___ |
| 2692 | The particles that make up the lattice in ionic crystal ___ |
| 2693 | ___ is a linear electronic voltage regulator |
| 2694 | How many lithium cells in series are needed for a 12 V battery? |
| 2695 | ___ refers to a circuit that stores pulses and produces an output pulse when specified number of pulses is stored |
| 2696 | Efficient oscillators are those that are class ___ |
| 2697 | What is the law whereby the attraction or repulsion between two magnetic poles is directly proportional to their strength? |
| 2698 | Which is the principal characteristic of a varactor diode? |
| 2699 | How many bits, binary pattern represent the decimal numbers 0 to 9 in binary coded decimal? |
| 2700 | What do you call the piece of equipment in an oscilloscope used to indicate pulse condition in a digital logic circuit? |
| 2701 | Which of the following is not a secondary type cell? |
| 2702 | Which is a common use for point-contact diode? |
| 2703 | ___ capability is analogous to permeance |
| 2704 | ___ is called an electronic transfer from one stage to the next |
| 2705 | How much voltage regulation does commercial power supply have? |
| 2706 | Determine which is not a dynamic test instrument ___ |
| 2707 | What is the logic circuit having two or more inputs but only one output with high output if any or all inputs are high, with low output only when all inputs are low? |
| 2708 | What is the equivalent of decimal 47 in binary? |
| 2709 | How many symbols do hexadecimal digital number system used? |
| 2710 | What is responsible for the phenomenon when voltages across reactances in series can often be larger than the voltage applied to them? |
| 2711 | When a logic circuit rejects an unwanted signal, this is termed as ___ |
| 2712 | An interval required to address and read out memory word ___ |
| 2713 | The current needed to operate a soldering iron which has a rating of 600 watts at 110 volts is ___ |
| 2714 | When a voltage of 100 V at 50 Hz is applied to a choking coil A, the current taken is 8A and the power is 120 W, when applied to a coil B, the current is 10 A and the power is 120 W |
| 2715 | ___ is called a memory device which holds fixed set of data in a circuit |
| 2716 | What happens in the resistance of copper wired when its temperature is raised? |
| 2717 | If a dry cell has an internal resistance of 0.50 ohm and an emf of 2 volts, find power delivered in a one ohm resistor? |
| 2718 | The science of physical phenomena at very low temperatures, approaching absolute zero is called ___ |
| 2719 | What is the law that determines polarity of an induced voltage? |
| 2720 | What is the resonant frequency of a circuit when L of 1 microhenry and C of 10 picofarads are in series? |
| 2721 | Which of the following photocell is most sensitive to? |
| 2722 | ___ currents are wasteful currents which flow in cores of transformers and produces heat |
| 2723 | Common-base (CB) amplifier has ___ compared to common-emitter and common collector amplifiers |
| 2724 | A ___ is an instruction in a source language that is to be replaced by a defined sequence of instructions in the same source language |
| 2725 | ___ for a transistor to be cut-off |
| 2726 | Semiconductors which are considered to be “low power†or “small signal†usually have power dissipation ratings of ___ |
| 2727 | What is the memory element used in clocked sequential logic circuit? |
| 2728 | How many OP-AMPS does window comparator require? |
| 2729 | When batteries have cells connected in series the effect is ___ |
| 2730 | What is residual magnetism? |
| 2731 | What type of transformer that is used to protect technicians and operators from deadly electrical shock? |
| 2732 | Find which type of network provides the greatest harmonic suppression ___ |
| 2733 | What is the range of voltage rating available in zener diodes? |
| 2734 | ___ is the dc motor control senses |
| 2735 | What is the effect in terms of bandwidth when the Q of a single-tune stage is doubled? |
| 2736 | What is the effect of light in a photodiode? |
| 2737 | Current in a chemical cell refers to the movement of ___ |
| 2738 | When you increase the resistance in a circuit, the flows of electrons will ___ |
| 2739 | Which is the majority carrier in an N-type semiconductor? |
| 2740 | A static memory generally contains ___ |
| 2741 | What special type of diode is capable of both amplification and oscillation? |
| 2742 | When an SCR is triggered or on condition, its electrical characteristics are similar to what other solid-state device (as measured between its cathode and anode)? |
| 2743 | How many turns are needed to produce a magnetizing force of 5000 A.t. for a coil of 50 amperes? |
| 2744 | When a switch is closed, it has a total resistance of ___ |
| 2745 | ___ is a type of linear regulator used in applications requiring efficient utilization of the primary power source |
| 2746 | What does SI magnetic flux refer? |
| 2747 | The purpose of cells connected in parallel is to ___ |
| 2748 | What is a pi-network? |
| 2749 | ___ is the most influential factor in the switching speed of saturated bipolar transistor |
| 2750 | Where does voltage generated in a DC generator depend? |
| 2751 | What is a group of circuits that provides timing and signals to all operation in the computer? |
| 2752 | The decibel gain of cascaded amplifiers equals the ___ |
| 2753 | Refers to the increased used of data conversion circuits as a result of increased application ___ |
| 2754 | Solve for flux density (in gauss) from a magnetic flux of 5,000 Mx through a perpendicular are of 2 cm x 5 cm ___ |
| 2755 | ___ are electrons at the outer shell |
| 2756 | An audible tone generated by combining two different frequencies in a non-linear circuit or as sound waves in air is called ___ |
| 2757 | In order to simplify a circuit, in analysis and computation the diode is normally assumed as ___ |
| 2758 | The loss of electrical energy in counter balancing the residual magnetism in each cycle is called ___ |
| 2759 | ___ is the major characteristics of an IC |
| 2760 | Which of the following statements is correct? |
| 2761 | A dc voltage supply is measured at 50 V and drops to 25 V when the load is connected ___ |
| 2762 | In shift registers made up of several flip-flops, the clock signal indicates ___ |
| 2763 | When the cells are in series, voltages add, while current capacity is ___ |
| 2764 | ___ is a device that stays on once triggered and stores one of two conditions as a digital circuit |
| 2765 | ___ is the characteristic of an oscillator that enables it to sustain oscillation after removal of the control stimulus |
| 2766 | The objective of a capacitor is to ___ |
| 2767 | A good material conductor should have valence electrons ___ |
| 2768 | A crystal with its major flat surfaces cut so that they are perpendicular to a mechanical axis of the original quartz crystal is called ___ |
| 2769 | ___ is an orderly pattern of combined silicon atoms |
| 2770 | Circuit that transforms dc from one voltage level to another or from one frequency to another ___ |
| 2771 | What is the first stage in electronic troubleshooting? |
| 2772 | Current carried by each of two long parallel conductors is doubled if their separation is also doubled, the force between them would ___ |
| 2773 | How much is the resistance of Germanium slag 10 cm long and cross sectional area of 1 squared cm? |
| 2774 | A solid-state device which only gives a “1†output if all its inputs are also “1†is called ___ |
| 2775 | What is the lagging effect between the magnetizing force applied and the flux density? |
| 2776 | Device that increases power content from an input signal ___ |
| 2777 | If a sine wave voltage varies from 0-200 V, how much is its instant voltage at 90%? |
| 2778 | What term in electronics is used to express how fast energy is consumed? |
| 2779 | What do you call the duration within it takes to read the content of a memory location after it has been addressed ___ |
| 2780 | The ___ is an analog component that has two inputs, one inverting and the other non-inverting, and a single output terminal |
| 2781 | If the gain of an amplifier without feedback is 10 and with negative feedback is 8, then the feedback fraction is ___ |
| 2782 | What is the most stable type of biasing? |
| 2783 | ___ refers to circuits with 10 to 100 integrated circuits |
| 2784 | When an atom gains an additional ___, it results to a negative ion |
| 2785 | The longer the diameter of a wire, the ___ is its resistance |
| 2786 | ___ is a low frequency oscillation which sometimes occurs under fault condition in electron tube circuits |
| 2787 | Two heaters A and B are in parallel across supply voltage V |
| 2788 | There are ___ identical cells in parallel needed to double the current reading of each cells |
| 2789 | The best way to control speed of an AC induction motor is by varying the ___ |
| 2790 | ___ is an excess property of P-type semiconductor |
| 2791 | ___ is a kind of memory where only manufacturer can store program and has a group of memory locations each permanently storing a word |
| 2792 | ___ is an output applied to Read Only Memory (ROM) |
| 2793 | Which has the largest diameter of the following dry cells? |
| 2794 | When a power supply is constructed to operate from either 240V or 120V ac lines such that it will have same secondary output, its primary when connected from 240V must be ___ |
| 2795 | The first recipient in E-mail communication ___ |
| 2796 | In a system with MOS devices, the main bus loading factor is likely to be ___ |
| 2797 | Find voltage regulation of a generator when full-load voltage is 110 V and no-load voltage is 120 ___ |
| 2798 | The typical number of bits per dynamic memory location is ___ |
| 2799 | ___ refers to BCD counter |
| 2800 | ___ is the specific gravity reading for a good lead-acid cell |
| 2801 | Solve the collector current if base current is 200 mA and the current gain is 20 ___ |
| 2802 | A ___ is a storage device used to accommodate a difference in rate of flow of data or time of occurrence of events when transmitting from one device to another |
| 2803 | What is the range of audio frequency? |
| 2804 | ___ is a segment register which normally accesses variables in the program |
| 2805 | The difference in energy between the valence and conduction bands of a semiconductor is called ___ |
| 2806 | The portion of the weld interval during which welding current is flowing ___ |
| 2807 | The base SI unit of luminous intensity is ___ |
| 2808 | The purpose of installing thyrectors across the incoming power lines to speed the control system is to ___ |
| 2809 | In order to match the load to the generator means making load resistance ___ |
| 2810 | Silicon diodes are used in a two-diode full-wave rectifier circuit to supply a load of 12 volts DC ___ |
| 2811 | What do you call the force which sets up or tends to set up magnetic flux in a magnetic circuit? |
| 2812 | ___ is a pn junction semiconductor device that emits noncoherent optical radiation when biased in the forward direction, as a result of a recombination effect |
| 2813 | If three amplifiers with a gain of 8 each are in cascade, how much is the overall gain? |
| 2814 | The ___ grid in an electron tube is where the input signal is usually applied |
| 2815 | Find the ripple factor (Kr) of a sinusoidal signal with peak ripple of 4 volts and an average of 30 ___ |
| 2816 | An LC circuit resonates at 2000 kHz and has a Q of 100 ___ |
| 2817 | What materials possess permeabilities slightly less than that of free space? |
| 2818 | ___ can erase EPROMS |
| 2819 | Materials with permeabilities slightly less than that of free space are referred to as ___ |
| 2820 | ___ is retrieving data from memory |
| 2821 | How do you measure the current in a circuit without an ammeter? |
| 2822 | An instrument used to measure one location in terms of coordinates ___ |
| 2823 | ___ is a byte of data stored in a memory location |
| 2824 | The overall gain of an amplifier in cascade is ___ |
| 2825 | What is the degree of exactness of measurement when compared to the expected value of the variable being measured? |
| 2826 | What type of materials formed when trivalent material is doped with silicon or germanium? |
| 2827 | Term used to describe sudden reverse conduction of an electronic component caused by excess reverse voltage across the device ___ |
| 2828 | In an Amplitude-Modulated (AM) radio transmitter, the modulator is ___ |
| 2829 | What level is used to represent logic-0 in a negative logic circuit? |
| 2830 | What element possesses four valence electrons? |
| 2831 | What is the unit of magnetic flux in SI system? |
| 2832 | ___ has the unit of electron volt |
| 2833 | What is the reason why robot actuators have lesser capabilities than electric or hydraulic robot actuators? |
| 2834 | What law in electronics where an induced current will be in such a direction that its own magnetic field will oppose the magnetic field that produces the same? |
| 2835 | What level is used to represent logic-1 in a negative logic circuit? |
| 2836 | A user-program that has the ability to move a robot axis to any position within its range ___ |
| 2837 | What is the smallest part of a computer language? |
| 2838 | A very high resistance connected in parallel with smoothing capacitors in a high voltage DC system is called a ___ |
| 2839 | What is the majority carrier in an N material? |
| 2840 | What composes all matter whether a liquid, solid or gas? |
| 2841 | An advantage of full-wave rectifier over half-wave rectifier ___ |
| 2842 | The reciprocal of capacitance is called ___ |
| 2843 | Find the output of four (4) lead acid cells ___ |
| 2844 | What is an electronic measuring equipment used in navigation operating in 1GHz band which provides bearing and distance indication? |
| 2845 | What instrument is used for observing voltage and current waveforms? |
| 2846 | Dynamometer type instrument can be used for ___ |
| 2847 | What force in analog instrument quickly brings the moving system to rest in its final position? |
| 2848 | In an oscilloscope, ___ adjusts the brightness of the spot by changing the voltage on the control grid |
| 2849 | In VTVMs, ___ is used to balance both halves of the difference amplifier or cathode-coupled amplifier |
| 2850 | The temperature coefficient of resistance of the shunt material is ___ |
| 2851 | A transistor amplifier has high output impedance because ___ |
| 2852 | Which coupling has the best frequency response? |
| 2853 | The size of a dc generator can be reduced by using ___ |
| 2854 | The greatest percentage of the heat loss in a dc machine is due to ___ |
| 2855 | In a dc generator armature reaction ___ pole tip |
| 2856 | The effect of armature reaction is to ___ |
| 2857 | A separately excited dc generator is not used because ___ |
| 2858 | The field winding of a dc shunt machine usually carries ___ of the rated current of the machine |
| 2859 | Difference between the speed of a rotating magnetic field and the associated rotor ___ |
| 2860 | For the same rating, a dc machine has ___ an ac machine |
| 2861 | For a given dc generator, the generated voltage depends upon ___ |
| 2862 | A triplex wave winding will have ___ parallel paths |
| 2863 | In a wave winding, the commutator pitch is approximately equal to ___ |
| 2864 | What is the approcimate efficiency of large transformer? |
| 2865 | In a lap winding, the number of the brushes required is equal to ___ |
| 2866 | High voltage dc machines use what winding ___ |
| 2867 | The voltage regulation of an alternator is larger than of a dc generator because of ___ |
| 2868 | The nature of armature winding of a dc machine is decided by ___ |
| 2869 | The terminal voltage of a ___ generator vary widely with changes in load current |
| 2870 | A dc compound generator having full load terminal voltage equal to the no load generator voltage is called ___ generator |
| 2871 | In a dc machine the number of commutator segments is equal to ___ |
| 2872 | The number of parallel paths in a simplex lap winding is equal to ___ |
| 2873 | By laminating the core of a transformer, ___ decreases |
| 2874 | In a practical transformer, copper losses account for how many percent of the total losses? |
| 2875 | In a simplex wave winding, the number of parallel paths is equal to ___ |
| 2876 | The commutator pitch for a simplex lap winding is equal to ___ |
| 2877 | The greatest eddy current loss occurs in the of a dc machine ___ |
| 2878 | The yoke of a dc machine carries ___ poke flux |
| 2879 | The armature winding of a dc machine is placed on the rotor to ___ |
| 2880 | A machine with field excitation by botrh shunt and series windings ___ |
| 2881 | The core type transformer provides ___ |
| 2882 | Which DC machines are the most common ___ |
| 2883 | The real working Part of a dc machine is the ___ |
| 2884 | The coupling field between electrical and the mechanical systems of a dc machine is ___ |
| 2885 | The winding of the transformer with greater number of turns will be ___ |
| 2886 | The voltage per turn of the primary of a transformer is ___ the voltage per turn of the secondary |
| 2887 | The armature of a dc machine is made of ___ |
| 2888 | The yoke of a dc machine is made of ___ |
| 2889 | When the load on a transformer is increased, the eddy current loss ___ |
| 2890 | Intermittent sparking at the brushes of dc motor may be caused due to ___ |
| 2891 | Hot bearings of a dc motor may be caused by ___ |
| 2892 | Excessive motor vibration is caused by ___ |
| 2893 | The stator of an alternator is identical to that of a ___ |
| 2894 | Majority of alternators in use have ___ |
| 2895 | A graphical relation between the generated emf and the field current of a machine ___ |
| 2896 | The temperature rise of a transformer is directly proportional to ___ |
| 2897 | Excessive sparking at the brushes may caused due to ___ |
| 2898 | The greatest percentage of power loss in a dc motor is due to ___ |
| 2899 | The iron losses in a dc motor depend upon ___ |
| 2900 | The effect of leakage flux in a transformer is to ___ |
| 2901 | If a transformer core has air gaps then ___ |
| 2902 | The friction and wind age losses in a dc motor depends upon ___ |
| 2903 | When load is removed, the motote that will run at the highest speed is the ___ motor |
| 2904 | Which motor is used to start heavy loads? |
| 2905 | A galvanic cell resulting from difference in potential between adjacent on the surface of a metal immersed in an electrolyte ___ |
| 2906 | What cell is used to detect infrared radiation, either its generated voltage or its change of résistance may be used as a measure of the intensity of the radiation ___ |
| 2907 | For 20% increase in current, the motor that will give the greatest increase in torque is ___ motor |
| 2908 | The demand for a large increase in torque of a dc shunt motor is met by a ___ |
| 2909 | The disadvantage of a short pitched coil is that ___ |
| 2910 | The rotor of a turbo alternator is made cylindrical in order to reduce ___ |
| 2911 | The deciding factor in the selection of a dc motor for a particular application is its ___ characteristics |
| 2912 | For the same rating ___ motor has the least starting torque |
| 2913 | When the secondary of a transformer is short circuited, the primary inductance ___ |
| 2914 | After a shunt motor is up to speed the speed may be increased considerably by ___ |
| 2915 | The distribution of load between two alternators operating in parallel can be changed by changing |
| 2916 | If the excitation of an alternator operating in parallel with pther alternators is decreased, its |
| 2917 | The running speed of a dc series motor is basically determined by ___ |
| 2918 | The speed of a ___ motor is practically constant |
| 2919 | The open circuit test on a transformer gives ___ |
| 2920 | In a very large dc motor with severe heavy duty, armature reaction effects are corrected by ___ |
| 2921 | If the lagging load power factor of an alternator is decreased, the demagnetizing effect of the armature reaction |
| 2922 | The number of cycles generated in a 6 pole alternator in one revolution is ___ |
| 2923 | In a dc motor, the brushes are shifted from the mechanical neutral palne in a direction opposite to the rotation to ___ |
| 2924 | In the short circuit test in a transformer, ___ winding is generally short circuited |
| 2925 | The open circuit test on a transformer is always made on ___ |
| 2926 | With respect to the direction of rotation, interpoles on a dc motor must have the same polarity as the main poles ___ |
| 2927 | If a power transformer is operated at very high frequencies then ___ |
| 2928 | An ideal transformer is one which ___ |
| 2929 | Armature reaction in a dc motor is increased ___ |
| 2930 | The shaft torque in a dc motor is less than total armature torque because of ___ in the motor |
| 2931 | DC machines which are subjected to abrupt changes of load are provided with ___ |
| 2932 | The main drawback of a dc shunt generator is that ___ |
| 2933 | Machine in which torque is produced by the interaction of ac current in the stator and dc currents in the rotor turning synchronism ___ |
| 2934 | AC machine in which the torque is produced by the interaction of currents in the stator and currents induced in the motor by transformer action ___ |
| 2935 | The torque developed by a dc motor is directly proportional to ___ |
| 2936 | In case if a 4 pole machine, 1 mechanical degree corresponds to ___ electrical degree |
| 2937 | The frequency of emf generated in an 8 pole alternator at 900 rpm is ___ |
| 2938 | When the speed of a dc motor increases, its armature current ___ |
| 2939 | The salient pole construction for field structure of an alternator is generally used for ___ machine |
| 2940 | The field winding of an armature is ___ excited |
| 2941 | The transformer that should never have the secondary open circuited when primary is energized is ___ |
| 2942 | The core type transformer is generally suitable for ___ |
| 2943 | The mechanical power developed in a dc motor is maximum when back emf is equal to ___ the applied voltage |
| 2944 | Back emf in a dc motor is maximum at ___ |
| 2945 | The synchronous reactance of an alternator is due to ___ |
| 2946 | The back emf or counter emf in a dc motor ___ |
| 2947 | Why are the field poles and the armature of a dc machine laminated ___ |
| 2948 | The ac armature winding of an alternator operates at ___ the field of winding |
| 2949 | The current in armature conductors of a dc machine is ___ |
| 2950 | A 4 pole dc machine has magnetic circuits ___ |
| 2951 | The synchronous reactance of an alternator as the iron is saturated ___ |
| 2952 | Why are carbon brushes preferable compared to copper brushes ___ |
| 2953 | The stator of n alternator is wound for ___ on the rotor |
| 2954 | A dc motor is still used in industrial applications because it ___ |
| 2955 | DC series motors are used in those applications where ___ required |
| 2956 | This synchronous reactance of an alternator is generally ___ armature resistance |
| 2957 | If the excitation of an alternator operating in parallel with other alternators is increased above the normal value excitation of excitation its ___ |
| 2958 | A constant voltage source has ___ |
| 2959 | When the primary of a transformer is connected to a dc supply ___ |
| 2960 | The flux in the core o a single phase transformer is ___ |
| 2961 | As the load increases a, ___ motor will speed uo |
| 2962 | The demand for a large increase in torque of a dc series motor is met by a ___ |
| 2963 | To produce an output of 7.5v, how many carbon zinc cells are connected in series ___ |
| 2964 | The armature of a dc machine is laminated in order to reduce ___ |
| 2965 | Small Dc machines generally have ___ poles |
| 2966 | The field structure of a dc machine uses ___ |
| 2967 | Which of the following is a dry storage cell ___ |
| 2968 | A storage battery in which the plates consist if lead antimony supporting grids covered with a lead oxide paste immersed in weak sulfuric acid ___ |
| 2969 | In an auto transformer, the primary and secondary are ___ coupled |
| 2970 | A transformer operates poorly at very low frequcnies because ___ |
| 2971 | Two things which are same for primary and secondary of transformer are ___ |
| 2972 | To increase current capacity, cells are connected in ___ |
| 2973 | To increase the voltage output, cells are connected in ___ |
| 2974 | An 8 pole duplex lap winding will have ___ parallel paths |
| 2975 | For given number of poles (2) and armature conductors, a lap winding will carry ___ a wave winding |
| 2976 | In an alternator, the effect of armature reaction is minimum at power factor of ___ |
| 2977 | One of the following is a false statement ___ |
| 2978 | What is the output of a lead acid cell ___ |
| 2979 | The efficiency of the turbo-alternator ___ with increase in speed |
| 2980 | When the load on an alternator is increased, the terminal voltage increases if the load power factor is ___ |
| 2981 | A series motor will over speed when ___ |
| 2982 | A motor takes a large current at starting because ___ |
| 2983 | Combination of ac motor, dc generator, and exciter to provide adjustable voltage dc power to a dc motor ___ |
| 2984 | A series motor designed to operate on dc or ac ___ |
| 2985 | What refers to a method in which the charger and the battery are always connected to each other for supplying current to the load ___ |
| 2986 | Four carbon zinc cell in series will provide about ___ |
| 2987 | A transformer is so designed that primary and secondary windings have ___ |
| 2988 | The maximum flux produced in the core of a transformer is ___ |
| 2989 | The common dry cell, which is a primary cell having a carbon positive electrode and a zinc negative electrode in an electrolyte of sal ammoniac and a depolarizer ___ |
| 2990 | A storage battery in which the electrodes are grids of lead containing lead oxides that changes in composition during charging and discharging and the electrolyte is dilute sulfuric acid ___ |
| 2991 | Connecting batteries of equal voltage in parallel ___ |
| 2992 | If it must deliver an average of 2.0a, how long will the battery lat before it needs recharging ___ |
| 2993 | The speed at which a 6 pole alternator should be drive to generate 50 cycles per second is ___ |
| 2994 | The armature winding of a dc Machine is ___ winding |
| 2995 | The efficiency of a transformer will be at maximum when ___ |
| 2996 | A transformer will have zero efficiency at ___ |
| 2997 | A stand alone solar power system ___ |
| 2998 | Which motor never use belt connected loads ___ |
| 2999 | Cumulatively compounded motors are used in applications where ___ is required |
| 3000 | The rating of an alternator is expressed in ___ |
| 3001 | The voltage of the bus bar to which several alternators are paralleled may be raised by simultaneously ___ of all alternators |
| 3002 | An example of rechargeable dc source is an/a ___ |
| 3003 | Transformers having ratings less than 5kva are generally ___ |
| 3004 | What can be found in a transformer with open-circuit test ___ |
| 3005 | Three cells connected in series from a ___ |
| 3006 | The amount of back emf of shunt motor will increase when ___ |
| 3007 | A transformer is an efficient device because it ___ |
| 3008 | The frequency of the system with which several alternators are parallel can be increased by simultaneously ___ of all generators |
| 3009 | A small 9V battery might be used to provide power to ___ |
| 3010 | Overheating of a dc motor is often due to ___ |
| 3011 | ___ the primary leakage flux links |
| 3012 | Leclanche cell is the other name of ___ |
| 3013 | Damper windings are used in alternators to ___ |
| 3014 | The alternators driven by ___ do not have a tendency to hunt |
| 3015 | The voltage output of a cell depends on ___ |
| 3016 | Which of the most suitable motor for elevator ___ |
| 3017 | A dc series motor is most suitable for ___ |
| 3018 | Nickel-iron cells is a secondary cell with a nominal open- circuit voltage output of 1.2 and is otherwise known as ___ |
| 3019 | The air gap in an alternator is ___ in an induction machine |
| 3020 | The ac armature winding of an alternator is ___ |
| 3021 | What gives the relative activity in forming ion charges for some of the chemical elements ___ |
| 3022 | The most commonly used method of speed control of a dc motor is by vbarying ___ |
| 3023 | Which is a variable speed motor? |
| 3024 | Silver cadmium is secondary cell with a nominal opne circuit voltage of ___ |
| 3025 | In a vacuum cleaner, ___ motor is generally used |
| 3026 | Which is the most suitable for punch presses ___ |
| 3027 | The voltage regulation of an alternator with a power factor of 0.8 lagging is ___ at unity power factor |
| 3028 | For the same rating ___ motor has the highest staring torque |
| 3029 | Galvanic cell is the other name of ___ |
| 3030 | DC shunt motors are used in those applications where ___ is required |
| 3031 | A commutatively compounded motor does not run at dangerous speed at light loads because of the presence of ___ |
| 3032 | A method of converting chemical energy into electric energy by dissolving two different conducting materials in an electrolyte ___ |
| 3033 | Which motor has the best speed regulation ___ |
| 3034 | Which of the following is the main function of a dc motor ___ |
| 3035 | Considered as the main types of battery ___ |
| 3036 | Carbon brushes are used in a dc machine because ___ |
| 3037 | Which of the following is not a primary cell ___ |
| 3038 | Which of the following is not a secondary cell ___ |
| 3039 | For the same rating, the size of low speed alternator is ___ that of high speed alternator |
| 3040 | The common 9v flat battery for transistor radio has ___ cells connected ins series |
| 3041 | High speed alternators are driven by ___ |
| 3042 | Low speed alternators are driven by ___ |
| 3043 | The speed of a dc motor is ___ |
| 3044 | What is the nominal output of an automotive battery having six lead acid cells in series ___ |
| 3045 | In a chemical cell current is the movement of ___ |
| 3046 | A transformer will work on ___ |
| 3047 | Volt is a unit of ___ |
| 3048 | Which of the following is the main function of a battery ___ |
| 3049 | A ___ is a group of cells that generates electric energy from their internal chemical reaction |
| 3050 | When temperature of a pure semiconductor is increased, its resistance ___ |
| 3051 | What factor is shown on a data sheet that tells how much you have to reduce the power of a device ___ |
| 3052 | A circuit whose parameters change with voltage or current ___ |
| 3053 | Another term for superconductor ___ |
| 3054 | Which of the following is neither a basic physical law nor deliverable from one ___ |
| 3055 | Under the conditions of maximum power transfer, a voltage source is delivering a power of 15 W to the load ___ |
| 3056 | Which of the following capacitors has the highest cost per µF ___ |
| 3057 | What theorem is usually used in the analysis of transistor circuit ___ |
| 3058 | Which of the following represents the energy stored in a capacitor ___ |
| 3059 | Another term of the quality factor of the resonant circuit ___ |
| 3060 | What theorem is generally used in the analysis of vacuum tubes ___ |
| 3061 | When capacitors are connected in series, the total capacitance is ___ |
| 3062 | A capacitor of 0.5 µF charged to 220 V is connected across an uncharged 0.5 µF capacitor ___ |
| 3063 | For maximum power transfer, what is the relation between load resistance ___ |
| 3064 | The maximum power transfer theorem is used in ___ |
| 3065 | Which of the following capacitors are used only in dc circuits ___ |
| 3066 | Which factor does not affect resistance ___ |
| 3067 | What is a rotating vector whose projection can represent either current or voltage in an ac circuit ___ |
| 3068 | The arc across a switch when it open an RL circuit is a result of the ___ |
| 3069 | When resistance are connected in parallel, the total resistance is ___ |
| 3070 | An inductive load always has a ___ power factor |
| 3071 | What is the total capacitance of 10 capacitors, each of 20 µF in series ___ |
| 3072 | Norton’s theorem is what form of an ac equivalent circuit ___ |
| 3073 | The charging of a capacitor through a resistance follows what law ___ |
| 3074 | What is the efficiency under the conditions of maximum power transfer ___ |
| 3075 | The ratio between the reactive power and the apparent power of an ac load is called ___ |
| 3076 | Which of the following combination of length and cross-sectional area will give a certain volume of copper the least resistance ___ |
| 3077 | Thevenin’s theorem is what form of an equivalent circuit ___ |
| 3078 | When current and voltage arte in phase in an ac circuit, the ___ is equal to zero |
| 3079 | When capacitors are connected in parallel, the total capacitance is ___ |
| 3080 | Why are inductance and capacitance not relevant in a dc circuit ___ |
| 3081 | Which of the following is the peakiest ___ |
| 3082 | Form its definition, the unit of electric field, £ is the N/C and equivalent unit of £ is the ___ |
| 3083 | The reason why electrical appliances are not connected in series ___ |
| 3084 | A trimmer is a variable capacitor in which capacitance is varied by changing the ___ |
| 3085 | When the temperature of copper wire is increased its resistance is ___ |
| 3086 | The hot resistance of an incandescent lamp is about times its cold resistance ___ |
| 3087 | If the capacitance of mica capacitor is 5 times the capacitance of air capacitor, then the relative permittivity of mica is ___ |
| 3088 | A coil of inductance L has an inductive reactance of ___ |
| 3089 | When two complex conjugates are subtracted, the result is a ___ |
| 3090 | Rationalizing the denominator of a complex number means ___ |
| 3091 | In a circuit, a passive element is one which ___ |
| 3092 | When the movable plates of a gang capacitor completely overlap the fixed plates, the capacitance of the capacitor is ___ |
| 3093 | If the inductance is decreased, the impedance of the circuit containing a resistor a capacitor and an inductor connected in series to an ac source ___ |
| 3094 | The area of capacitor plates increases two times, then its capacitance ___ |
| 3095 | In calculating maximum instantaneous power ___ voltage or current is used |
| 3096 | What fusion of elements is without chemical action between them ___ |
| 3097 | A resistor wound with a wire doubled back on itself to reduce the inductance ___ |
| 3098 | A switch designed to have low capacitance between its terminal when open ___ |
| 3099 | What dielectric is generally employed by a variable capacitor ___ |
| 3100 | A neon glow lamp used as a night light ionizes at approximately ___ |
| 3101 | ___ Of the equivalent combination of units, which one is not equal to watt? |
| 3102 | If a multiplate capacitor has 10 plates, each of ___ |
| 3103 | The capacitance of a capacitor is ___ relative permittivity |
| 3104 | The power factor of a circuit is equal to ___ |
| 3105 | In dividing or multiplying phasor quantities, ___ form is used |
| 3106 | In adding or subtracting phasor quantities, ___ form is the most convenient |
| 3107 | Which of the following dielectric materials makes the lowest-capacitance capacitor ___ |
| 3108 | In an ac circuit, the power dissipated as heat depends on ___ |
| 3109 | What is the time constant for L of 240 mH in series with R of 20 Ω ___ |
| 3110 | In a multiple capacitor, the plate area is ___ |
| 3111 | The rms value of a triangular or sawtooth waveform is ___ times its peak value |
| 3112 | What is the rms value of a square wave ___ |
| 3113 | If a coil has a Q of 10, it means that ___ |
| 3114 | An impedance given by 90²-45˚ is a/an ___ impedance |
| 3115 | A lead conductor has a resistance of 25 fi at 0 ËšC ___ |
| 3116 | For a carbon composition resistor, typical resistance values range from ___ |
| 3117 | What determines the magnitude of electric current ___ |
| 3118 | If one resistance in a series connection is open, then ___ |
| 3119 | Which of the following is a common material used in wire-wound resistors ___ |
| 3120 | Which of the following has negative temperature coefficient ___ |
| 3121 | The reciprocal of a complex number is ___ |
| 3122 | In a complex number 5 + j 10, 10 is called ___ part |
| 3123 | When two coils of identical reactance are in parallel without mutual inductance, the reactance of the combination is ___ the reactance of each coil |
| 3124 | For a linear circuit, ___ voltage or current is used to calculate average power |
| 3125 | A linear circuit is one whose parameters ___ |
| 3126 | What is the most convenient way of achieving large capacitance ___ |
| 3127 | In the 5-band method of capacitor color coding, the first band indicates ___ |
| 3128 | Barium-strontium titanite dielectric material is also called ___ |
| 3129 | An inductor carries 2 A dc ___ |
| 3130 | What increases the resistance of wire at high frequencies ___ |
| 3131 | Inductive reactance applies only to sine waves because it ___ |
| 3132 | For greater accuracy, the value of phase angle θ should be determined from ___ |
| 3133 | Delta to wye or wye to delta transformation technique is applied to a ___ network |
| 3134 | The wavelength of an alternating waveform depends upon the ___ of the variation |
| 3135 | The resistance of an insulator ___ when its temperature is increased |
| 3136 | Which of the following is a disadvantage of a wire-wound resistor ___ |
| 3137 | The result of rust in electrical (wire) connection is ___ |
| 3138 | The mutual inductance between two coils is ___ the reluctance of magnetic path |
| 3139 | What does a capacitor store ___ |
| 3140 | If voltage across the plates of 2 F capacitor is increased by 4 V, then charge on the plates will ___ |
| 3141 | Refers to the outward-curving distortion of the lines of force near the edges of two parallel metal plates that form a capacitor ___ |
| 3142 | The power factor of a certain circuit in which the voltage lags behind the current is 80 % ___ |
| 3143 | What is the purpose of a load in an electric circuit ___ |
| 3144 | Which of the following does not generally affect the value of a capacitor ___ |
| 3145 | How many degrees of phase represents one full cycle ___ |
| 3146 | When the power factor of a circuit is zero, ___ |
| 3147 | The ratio between the active power and the apparent power of a load in an ac circuit is called ___ |
| 3148 | The distance between the capacitor plates increases two times, then its capacitance ___ |
| 3149 | Which of the following materials has the lowest dielectric strength ___ |
| 3150 | What is expected when two 20 kΩ , 1 watt resistor in parallel are use instead of one 10 kΩ , 1 watt ___ |
| 3151 | What maximum voltage can be applied across the capacitor for very short period of time ___ |
| 3152 | If a certain circuit has a current that is lagging the voltage by 45Ëš, then it displays ___ |
| 3153 | For a series AC circuit, ___ is not used as a reference phasor |
| 3154 | For a parallel AC circuit, ___ is used as a reference phasor |
| 3155 | What can be used to estimate resonant frequency and to find reactance at any frequency for any value of capacitor or inductor ___ |
| 3156 | What is the total effective capacitance of two 0.25 µF capacitors connected in series ___ |
| 3157 | The curve between current and frequency is termed as ___ |
| 3158 | If the output resistance of a voltage source is 4 Ω , it internal resistance should be ___ |
| 3159 | What is the reciprocal of capacitance ___ |
| 3160 | A series RL circuit has R of 10 fi and XL of ___ |
| 3161 | Which of the following capacitors is suitable for dc filter circuits ___ |
| 3162 | What is the most common non-sinusoidal waveform? |
| 3163 | The capacitor opposes any change in voltage across it by ___ |
| 3164 | The temperature-resistance coefficient of pure gold is ___ |
| 3165 | When frequency of an ac wave decreases, the value of XL in a coil ___ |
| 3166 | How many coulombs are delivered by a storage battery in 25 hours if it is supplying current at the rate of 3 A ___ |
| 3167 | A capacitor consists of two ___ |
| 3168 | For multi-plate capacitor, capacitance is proportional to ___ |
| 3169 | The electric field strength between capacitor plates has a unit of ___ |
| 3170 | What is the value of a carbon composition resistor with the following color code ___ |
| 3171 | A three-by-three, series-parallel matrix of resistors, all having the same ohmic value, would have a net resistance of ___ |
| 3172 | Which of the following is a preferred resistor value ___ |
| 3173 | The second strip of an electronic resistor color-code represents ___ |
| 3174 | The usual load of a dc circuit is a/an ___ |
| 3175 | A capacitor is used to ___ |
| 3176 | Refers specifically to steady state values of quantities in ac circuits which are complex numbers ___ |
| 3177 | If two resistances of 9 Ω and 6 Ω are connected in parallel, the total resistance is ___ |
| 3178 | For a triangular and sawtooth waveform the rms voltage or current equals ___ |
| 3179 | What is the resonant frequency of a circuit when L of 3 microhenrys and C of 40 picofarads are in series ___ |
| 3180 | Capacitance increase with ___ |
| 3181 | What refers to the lowest voltage across any insulator that can cause current flow ___ |
| 3182 | The temperature coefficient of resistance of electrolytes is ___ |
| 3183 | With double the number of turns by the same length and area, the inductance is ___ |
| 3184 | A term used to express the amount of electrical energy stored in electrostatic field ___ |
| 3185 | Tungsten filament of bulbs has a hot resistance higher than its cold resistance due to its temperature coefficient which is ___ |
| 3186 | Liquids that are good conductors because of ionization are called ___ |
| 3187 | When two in-phase sine waves that have identical frequency and amplitude are added together, then the result is a sine wave with ___ the amplitude of either |
| 3188 | The factor 0.707 for converting peak to rms applies only to ___ |
| 3189 | A 5 µF capacitor charge to 5V has a stored charge equal to ___ |
| 3190 | A capacitance of 0.05 µF equals ___ |
| 3191 | What is the specific resistance of a pure silicon ___ |
| 3192 | The charging of a capacitor through a resistance obeys ___ |
| 3193 | Which of the following is a way of decreasing mutual inductance ___ |
| 3194 | When the net reactance in a series coil-capacitor circuit is zero at frequency f, the nature of its reactance of frequency 2f is ___ |
| 3195 | In a complex resistance-reactance plane ___ |
| 3196 | Metal tin becomes superconductor at approximately ___ |
| 3197 | A rheostat is a form of ___ |
| 3198 | In a parallel bank with unequal branch resistances ___ |
| 3199 | In a series circuit with unequal resistances the ___ |
| 3200 | Which waveform in which the rms value and the mean value are equal ___ |
| 3201 | For parallel capacitors, total charge is ___ |
| 3202 | High resistance values are a consequence of the ___ of the film |
| 3203 | Which of the following describes the action of a capacitor ___ |
| 3204 | What is the cross-sectional are of a conductor whose diameter is 0.001 inch ___ |
| 3205 | A real current source has ___ |
| 3206 | When two unequal values of resistors are connected in parallel across a dc source, greater current flows through the ___ |
| 3207 | The reason why alternating current can induce voltage is ___ |
| 3208 | When voltage is applied across a ceramic dielectric the electrostatic field produced is 50 times greater than air dielectric ___ |
| 3209 | Which of the following is not a factor affecting capacitance of a basic capacitor ___ |
| 3210 | It is impossible to change the voltage across a capacitor instantly, as this would produce ___ current |
| 3211 | The ratio of the flux density to the electric field intensity in the dielectric is called ___ |
| 3212 | Which of the following has a positive temperature coefficient ___ |
| 3213 | An inductive circuit of resistance 16.5 Ω and inductance of 0.14 H takes a current of 25 A. if the frequency is 50 Hz, find the supply voltage ___ |
| 3214 | The ___ of an alternating quantity is defined as the fractional part of a period or cycle through which the quantity has advanced from selected origin |
| 3215 | A series-parallel combination of identical resistors will ___ |
| 3216 | A wire of one kilometre length has a resistance of 20 Ω ___ |
| 3217 | The admittance of a parallel RLC circuit is found to be the sum of conductance and susceptances ___ |
| 3218 | Which of the following is the statement of Ohm’s law ___ |
| 3219 | What value of R is needed with a 0.05 µF C for an RC time constant of 0.02 s ___ |
| 3220 | Norton’s theorem is ___ Thevenin’s theorem |
| 3221 | An open resistor when checked with an ohmmeter reads ___ |
| 3222 | According to Gauss theorem, flux can be equated to ___ |
| 3223 | If an emf in circuit A produces a current in circuit B, then the same emf in circuit B produces the same current in circuit A. this theorem is known as ___ |
| 3224 | If two complex conjugates are added, ___ components results |
| 3225 | When two pure sine waves of the same frequency and the same amplitude which are exactly 180Ëš out-of-phase are added together, the result is ___ |
| 3226 | Parallel resonant circuit is sometimes called as ___ |
| 3227 | Series resonant circuit is sometimes known as ___ |
| 3228 | For series capacitors, total charge is ___ |
| 3229 | The ratio of maximum value to the effective value of an alternating quantity is called ___ |
| 3230 | What is the total resistance of a two equal valued resistors in series ___ |
| 3231 | A capacitor opposes change in ___ |
| 3232 | A capacitor requires 12 µC of charge to raise its potential of 3 V ___ |
| 3233 | Electric energy refers to ___ |
| 3234 | What is the conductance of a circuit having three 10 fi resistors in parallel ___ |
| 3235 | The internal resistance of an ideal voltage source is ___ |
| 3236 | What is a closed path made of several branches of the network called ___ |
| 3237 | Which statement is true about a passive circuit ___ |
| 3238 | What is the hot resistance of a 100 W, 220 V incandescent lamp ___ |
| 3239 | An electric circuit contains ___ |
| 3240 | In a circuit, an active element is one which ___ |
| 3241 | Which of the following dielectric materials makes the highest-capacitance capacitor ___ |
| 3242 | In a rectangular wave, the form factor is ___ |
| 3243 | What is the form factor of a triangular wave ___ |
| 3244 | The Q-factor of a series resonant circuit is also known as ___ |
| 3245 | The Q-factor of a parallel resonant circuit is also known as ___ |
| 3246 | The potential gradient in a cable is maximum in ___ |
| 3247 | What is the complex impedance of a circuit with an absolute resistance of 300 Ω ? |
| 3248 | Which of the following elements is active ___ |
| 3249 | Which of the statements below is not true ___ |
| 3250 | The ohmic value of a resistor with negative temperature coefficient ___ |
| 3251 | In a pure capacitance, ___ |
| 3252 | In an RL series circuit, ___ |
| 3253 | In a rectangular wave, the peak factor is ___ |
| 3254 | At parallel resonance, the currents flowing through L and C are ___ |
| 3255 | An alloy composed of 84 % copper, 12 % manganese and 4 % nickel ___ |
| 3256 | A factor that states how much the resistance changes for a change in temperature ___ |
| 3257 | What refers to such work at very low temperatures, near absolute zero ___ |
| 3258 | The superposition theorem is used when the circuit contains ___ |
| 3259 | Which of the following is not a factor affecting dielectric strength ___ |
| 3260 | What is the peak factor for alternating current or voltage varying sinusiodally ___ |
| 3261 | Which component opposes voltage change ___ |
| 3262 | The farad is not equivalent to which of the following combination of units ___ |
| 3263 | The unit of elastance is ___ |
| 3264 | Voltage resonance means ___ |
| 3265 | Leakage resistance in a capacitor results into ___ |
| 3266 | In an ac circuit with XL and R in series, the |
| 3267 | In an ac circuit with a resistive branch and an inductive branch in parallel, the ___ |
| 3268 | Two complex numbers or phasors are said to be conjugate if they ___ |
| 3269 | In an inductive coil, the rate of rise of current is maximum ___ |
| 3270 | A capacitor is basically constructed of ___ |
| 3271 | An inductance of 1 mH is ___ |
| 3272 | If three 100-pF capacitors are connected in series, then the total capacitance is ___ |
| 3273 | The internal resistance of an ideal current source is ___ |
| 3274 | “Any resistance R in a branch of a network in which a current I is flowing can be replaced by a voltage equal to IR†___ |
| 3275 | For a series circuit, the higher the quality factor ___ |
| 3276 | The reactance curve is a plot of frequency versus ___ for a series RLC circuit |
| 3277 | The charge in the capacitor is stored at the ___ |
| 3278 | The voltage cannot be exactly in phase with the current in a circuit that contains ___ |
| 3279 | A capacitance of 6 µµF means ___ |
| 3280 | And ideal current source has an internal conductance of ___ siemen(s) |
| 3281 | What is the resonant frequency of a circuit when L of 25 microhenrys and C of 10 picofarads are in parallel ___ |
| 3282 | Which of the following does not refer to electrical energy ___ |
| 3283 | Which of the following is the most popular waveform ___ |
| 3284 | The graph between an alternating quantity and time is called ___ |
| 3285 | A trigger circuit consisting of a capacitor of 0.01 µF is connected in series with a resistor ___ |
| 3286 | A 0.09 microfarad capacitor is charged to 220 volts ___ |
| 3287 | Which of the following is not considered a physical factor affecting resistance ___ |
| 3288 | Which of the following does not affect resistance ___ |
| 3289 | The reason why electrical appliances are connected in parallel ___ |
| 3290 | What determines the direction of induced emf in a conductor or coil ___ |
| 3291 | Loop currents should be assumed to flow in which direction ___ |
| 3292 | The impedance in the study of electronics is represented by resistance and ___ |
| 3293 | Permeability is otherwise known as ___ |
| 3294 | Points to be considered in choosing a capacitor ___ |
| 3295 | Effects of capacitance ___ |
| 3296 | What is the peak factor of a triangular wave ___ |
| 3297 | A series RLC circuit consists of a 10 Ω resistor in series with L = 10 µH, and C = 100 µF ___ |
| 3298 | The average value of a triangular or sawtooth wave is ___ times its peak value |
| 3299 | What capacitance exists not through design but simply because two conducting surfaces are relatively close to each other ___ |
| 3300 | What is the reading of an ohmmeter for a shorted capacitor ___ |
| 3301 | An open inductor has ___ |
| 3302 | What rating of a resistor determines its ability to absorb heat ___ |
| 3303 | Transient period is considered over after ___ |
| 3304 | Which one of the following elements serves as a protection against overload ___ |
| 3305 | What is the half-power bandwidth of a parallel resonant circuit which has a resonant frequency of 3.6 MHz and Q of 218 ___ |
| 3306 | At what frequency will the current in a series RLC circuit reach its maximum value for ___ |
| 3307 | At what frequency will the current in a series RLC circuit reach its maximum value for an applied voltage of ___ |
| 3308 | The value of temperature coefficient (a) is dependent upon ___ |
| 3309 | An intermittent and non-symmetrical alternating current like that obtained from the secondary winding of an induction coil ___ |
| 3310 | An ac series circuit is composed of a resistance of 20 Ω , inductive reactance of 40 Ω , and a capacitive reactance of 15 Ω ___ |
| 3311 | What is considered as the most important value of a sine wave ___ |
| 3312 | Which statement is true ___ |
| 3313 | If resonant frequency is 10 kHz and quality factor is 50, then ___ |
| 3314 | If a capacitor is rated for 200V dc, what is its effective ac working voltage ___ |
| 3315 | The open-circuit voltage at the terminal of load RL is 60V ___ |
| 3316 | Which is considered as the effect of a dielectric material ___ |
| 3317 | As applied to a series RLC circuit, bandwidth means ___ |
| 3318 | What is the temperature coefficient of the resistance Eureka ___ |
| 3319 | A capacitive load always has a ___ power factor |
| 3320 | A tank circuit is a ___ |
| 3321 | Kirchhoff’s laws (KCL and KVL) are applicable to ___ |
| 3322 | A series RLC circuit has a power factor at its half-power points ___ |
| 3323 | Two capacitors of capacitance 9 µF and 18 µF in series will have a total capacitance of ___ |
| 3324 | What is the specific resistance of a pure germanium ___ |
| 3325 | If three 9 mH inductors are connected in parallel without mutual inductance then the total inductance is ___ |
| 3326 | In an ac circuit with inductive reactance, the ___ |
| 3327 | The current is ___ times the maximum current at half-power points of a resonance curve |
| 3328 | In a resonant circuit, if Q ≤ 10 resonant frequency ___ bandwidth |
| 3329 | Resistor with colored bands in the body ___ |
| 3330 | In a series RLC circuit ___ |
| 3331 | What is the other name of relative permittivity ___ |
| 3332 | Property of an electric circuit that dissipates electric energy ___ |
| 3333 | At what frequency will an inductor of 5mH have the same reactance as a capacitor of 0.1 µF ___ |
| 3334 | VL = VC in a series RLC circuit when ___ |
| 3335 | In liquids and gases, ionization current results from a flow of ___ |
| 3336 | What is the reciprocal of quality factor ___ |
| 3337 | The ratio of W/VA in an ac circuit means ___ |
| 3338 | The symbol Q refers to ___ |
| 3339 | Series resonance occurs when ___ |
| 3340 | Electron flow assumes charges flow from ___ |
| 3341 | Conventional flow assumes charges flow from ___ |
| 3342 | When a current carrying conductor is placed in a magnetic field, the maximum force will act on the conductor when the conductor is at an angle of ___ to the magnetic field |
| 3343 | The direction of force o a current carrying conductor placed in a magnetic field can be found by ___ |
| 3344 | At/m is a unit of ___ |
| 3345 | The flux density in an air-cored coil is ___ |
| 3346 | When the relative permeability of a material is much greater than 1, it is called ___ material |
| 3347 | The greater percentage of materials is ___ |
| 3348 | Which of the following is a diamagnetic material ___ |
| 3349 | When the relative permeability of a material is slightly more than 1, it is called ___ material |
| 3350 | When the relative permeability of a material is slightly less than 1, it is called ___ material |
| 3351 | The permeability of a material having a flux density of ___ |
| 3352 | As the magnetic intensity decreases, the relative permeability of a magnetic material ___ |
| 3353 | A magnetic pole produces 5000 field lines ___ |
| 3354 | Which of the following has the highest permeability ___ |
| 3355 | The relative permeability of a magnetic material is ___ |
| 3356 | The force acting on a pole of 5 Wb is 25 N ___ |
| 3357 | Magnetic field intensity is a ___ quantity |
| 3358 | What is the typical saturation flux density for most magnetic materials ___ |
| 3359 | The unit of flux density is ___ |
| 3360 | One weber of flux is equal to ___ magnetic lines of force |
| 3361 | Two similar poles, each 1Wb, placed 1 m apart in air will experience a repulsive force of ___ |
| 3362 | The force between two magnetic poles is ___ the relative permeability of the medium |
| 3363 | If the distance between two magnetic poles decreases by 2 times, the force between them ___ |
| 3364 | The force between two magnetic poles is ___ their pole strengths |
| 3365 | Temporary magnets are commonly employed in ___ |
| 3366 | Permanent magnets can be found in ___ |
| 3367 | What is the main advantage of temporary magnets ___ |
| 3368 | Which of the following is used by temporary magnets as the magnetic material ___ |
| 3369 | Which of the following is used by permanent magnets as the magnetic material ___ |
| 3370 | One farad equals ___ |
| 3371 | What is used as the dielectric material in high voltage transformers ___ |
| 3372 | What is used as the insulating material or dielectric in an electric ion ___ |
| 3373 | Which of the following materials has the highest dielectric strength ___ |
| 3374 | What is the other name for dielectric strength ___ |
| 3375 | The electric potential across part AB of a circuit is 5 V; point A being at higher potential ___ |
| 3376 | The electric potential at a point in air due to a charge is 21 V ___ |
| 3377 | Electric potential is a ___ quantity |
| 3378 | The potential at a point due to a charge is 15 V ___ |
| 3379 | Three charges of +5 C, -6 C and +9 C are placed inside a sphere ___ |
| 3380 | Electric field intensity at a point is numerically equal to ___ at that point |
| 3381 | The permittivity of a material is given by one of the following formulas ___ |
| 3382 | The electric flux density is a ___ quantity |
| 3383 | The electric field intensity between the parallel plate air capacitor is 20 N/C ___ |
| 3384 | Electric field intensity at a point due to a given charge ___ if the relative permittivity of the medium decreases |
| 3385 | Electric field intensity is a ___ |
| 3386 | Electric field intensity is measured in ___ |
| 3387 | Electric lines of force leave or enter the charge surface at an angle of ___ |
| 3388 | A test charge means a charge of ___ |
| 3389 | The dielectric constant of most materials lies between ___ |
| 3390 | What is another name for relative permittivity ___ |
| 3391 | The force between two charges placed a given distance apart ___ as the relative permittivity of the medium is increased |
| 3392 | If the relative permittivity of a material is 10, then its permittivity is ___ |
| 3393 | If two similar charges 1 coulomb each are placed 1 m apart in air, then the force of repulsion is ___ |
| 3394 | What is the relative permittivity of air ___ |
| 3395 | What is the value of the absolute permittivity of air ___ |
| 3396 | This paper does not exhibit electricity because it contains the same number of ___ |
| 3397 | A negatively charge body has ___ |
| 3398 | A positively charged body has ___ |
| 3399 | Under ordinary conditions, a body is considered ___ |
| 3400 | The hot resistance of an incandescent lamp is about its cold resistance ___ |
| 3401 | A 200-watt lamp working for 24 hours will consume approximately units ___ |
| 3402 | What is the practical unit of electrical energy ___ |
| 3403 | Ohm’s law cannot be applied to which material ___ |
| 3404 | If the value of a25 a conductor is ___ |
| 3405 | If the value of a0 a conductor is ___ |
| 3406 | The temperature coefficient of resistance of eureka is ___ |
| 3407 | The temperature coefficient of resistance of insulators is ___ |
| 3408 | The temperature coefficient of resistance of a conductor ___ with an increase in temperature |
| 3409 | What determines the value of the temperature coefficient of resistance of a material ___ |
| 3410 | The temperature coefficient of resistance of semiconductors is ___ |
| 3411 | The temperature coefficient of resistance of conductors is ___ |
| 3412 | What is the SI unit of conductivity ___ |
| 3413 | If the resistance of a material 2 m long and ___ |
| 3414 | What is the SI unit of conductance ___ |
| 3415 | The resistivity of a conductor ___ with an increase in temperature |
| 3416 | A length of wire has a resistance of 10 ohms ___ |
| 3417 | If the length and area of cross-section of a wire are doubled, then its resistance ___ |
| 3418 | The resistance of a material is its area of cross-section ___ |
| 3419 | Electromotive force in a circuit ___ |
| 3420 | Electronic current in a wire is the flow of ___ electrons |
| 3421 | A one cubic cm of copper has how many free electrons at room temperature ___ |
| 3422 | One coulomb of charge consists of ___ electrons |
| 3423 | If the number of valence electrons of an atom is less than 4, then the substance is probably ___ |
| 3424 | If the number of valence electrons of an atom is exactly 4, then the substance is called ___ |
| 3425 | If the number of valence electrons of an atom is more than 4, the substance is called ___ |
| 3426 | If the number of valence electrons of an atom is less than 4, the substance is called ___ |
| 3427 | The electrons in the last orbit of an atom are called ___ electrons |
| 3428 | What is the maximum number of electrons that can be accommodated in the last orbit of an atom ___ |
| 3429 | The mass of proton is ___ the mass of an electron |
| 3430 | Hipernik is an alloy containing iron and ___ nickel |
| 3431 | ___ is a substance of whose molecules consist of the same kind of atom |
| 3432 | What is the measure of the density and sign of the electric charge at a point relative to that at some time ___ |
| 3433 | Hysteresis is a phenomenon of ___ in a magnetic circuit |
| 3434 | There are how many compounds available in nature ___ |
| 3435 | If the magnetic material is located within a coil through which alternating current (60 Hz frequency) flows, then ___ hysteresis loops will be formed every second |
| 3436 | The magnetic materials should have a large hysteresis loss for one of the following applications ___ |
| 3437 | Core materials of a good relay have ___ hysteresis loop |
| 3438 | Which of the following materials has the least hysteresis loop area ___ |
| 3439 | The core of a transformer heats up when its primary is fed from an ac source because of ___ |
| 3440 | Hysteresis loss can be reduced by one of the following ___ |
| 3441 | A magnetizing force of 1000 AT/m will produce a flux density of ___ in air |
| 3442 | What is the SI unit of reluctance ___ |
| 3443 | If a magnetic flux cuts across 200 turns at a rate of 2Wb/s, the induced voltage according to Faraday’s law is about ___ |
| 3444 | The B-H curve of is not a straight line ___ |
| 3445 | The phenomenon that when an electric current passes through an anisotropic crystal, there is an absorption or liberation of heat due to the non-uniformity in current distribution ___ |
| 3446 | The B-H curve for ___ is a straight line passing through the origin |
| 3447 | Another term for corona discharge ___ |
| 3448 | The reluctance of a magnetic circuit is not dependent on which of the following ___ |
| 3449 | The science of adapting electronics to aerospace flight ___ |
| 3450 | What is the usual value of leakage coefficient for electrical machines ___ |
| 3451 | The reluctance of a magnetic circuit varies with ___ |
| 3452 | Theory of ferromagnetic phenomena which assumes each atom is a permanent magnet which can turn freely about its center under the influence of applied field and other magnets ___ |
| 3453 | A law relating between the magnetic and electric susceptibilities and the absolute temperatures which is followed b ferromagnets, antiferromagnets, non-polar ferroelectrics, antiferroelectrics and some paramagnets ___ |
| 3454 | The reluctance of the magnetic circuit is ___ relative permeability of the material comprising the circuit |
| 3455 | A law stating that the magnetic susceptibilities of most paramagnetic substances are inversely proportional to their absolute temperatures ___ |
| 3456 | The conduction of electricity across the surface of a dielectric is called ___ |
| 3457 | A factor used to correct for the electrostatic forces of the more distant ions in an ionic solid ___ |
| 3458 | Defined as the ratio of the volume occupied by the atoms or ions in a unit cell divided by the volume of the unit cell and is used to measure the compactness of a crystal ___ |
| 3459 | Formed when there exist distant electronic interactions between (opposite) charges present in the neighboring atoms or molecules ___ |
| 3460 | Permeance of a magnetic circuit is the cross-sectional area of the circuit ___ |
| 3461 | What type of bond is formed when there exists some form of collective interactions between the (negatively charged) electrons and (positively charged) nuclei in a solid ___ |
| 3462 | Why is it that the magnitude of magnetomotive force required for air gap is much greater than that required for iron part of a magnetic circuit ___ |
| 3463 | What bond is formed when electrons in the outermost energy orbits of the atoms are shared between two or more electrons ___ |
| 3464 | In electro-mechanical conversion devices like generators and motors the reason why a small air gap is left between the rotor and stator is to ___ |
| 3465 | What bond is formed when one or more electrons in the outermost energy orbit of an atom are transferred to another ___ |
| 3466 | A principle that states that only two electrons with different spins are allowed to exist in a given orbit ___ |
| 3467 | Amorphous solid is also called ___ |
| 3468 | What solid has no defined crystal structure except perhaps in the arrangement of the nearest neighboring atoms or ions ___ |
| 3469 | Mmf in a magnetic circuit corresponds to ___ in an electric circuitmc |
| 3470 | One of the solid structures in which the position of the atoms or ions are predetermined ___ |
| 3471 | What determines the atomic number of an element ___ |
| 3472 | A 6- V battery is connected across a solenoid of 100 turns having a resistance of 2 Ω , Calculate the number of ampere turns ___ |
| 3473 | How many turns are needed to produce a magnetomotive force of 1000 A.t for a coil with 6 amperes ___ |
| 3474 | Calculate the flux density that will be produced by the field intensity of ___ |
| 3475 | Calculate the permeability (in T/A. t/m) of a magnetic material that has a relative permeability of ___ |
| 3476 | What is the reluctance of a magnetic path having a length of ___ |
| 3477 | If a 20 V potential is applied across a relay coil with 50 turns having 1 Ω of resistance, the total magnetomotive producing magnetic flux in the circuit is ___ |
| 3478 | A magnetic flux of ___ |
| 3479 | The magnetic flux through a coil changes ___ |
| 3480 | Back emf refers to the ___ |
| 3481 | The magnetic field around the conductor is determined by the ___ |
| 3482 | When the current flows, the magnetic field ___ conductor is in what direction |
| 3483 | Ohm’s law can be used only to a ___ circuit or component |
| 3484 | A magnetic field is ___ |
| 3485 | How is mutual inductance between two coils decreased ___ |
| 3486 | One of the common application of an air- cored choke ___ |
| 3487 | The magnetic energy stored in an inductor is ___ current |
| 3488 | The force between two magnetic poles is ___ their poles strength |
| 3489 | A t/m is a unit of ___ |
| 3490 | The permeability of permalloy is ___ |
| 3491 | Which of the following is a paramagnetic material ___ |
| 3492 | The core of a magnetic equipment uses a magnetic material with ___ |
| 3493 | Magnetic intensity is a ___ |
| 3494 | Residual magnetism refers to the flux density, which exists in the iron core when the magnetic field intensity is ___ |
| 3495 | How many electrons are needed in the valence orbit to give a material’s stability ___ |
| 3496 | Which of the following statements is TRUE ___ |
| 3497 | The energy stored in an electrostatic field or electromagnetic field is called ___ |
| 3498 | What principle states that each electron in an atom must have a different set of quantum numbers ___ |
| 3499 | Gases whose particles are charged are known as ___ |
| 3500 | Electron is a Greek word for ___ |
| 3501 | The evaporation of electrons from a heated surface is called ___ |
| 3502 | Cobalt is an example of a ___ material |
| 3503 | Hydrogen is an example of a ___ material |
| 3504 | Hysteresis refers to the ___ between flux density of the material and the magnetizing force applied |
| 3505 | An atom or a group of atoms that carries a net electric charge ___ |
| 3506 | A negative ion results when an atom gains an additional ___ |
| 3507 | Which element has four valence electrons ___ |
| 3508 | A good conductor has how many valence electrons ___ |
| 3509 | Which of the following has the least number of valence electrons ___ |
| 3510 | Electrons at the outer shell are called ___ |
| 3511 | The unit of electrical energy is ___ |
| 3512 | An electron- volt (eV) is a unit of ___ |
| 3513 | One oersted (Oe) is equivalent to ___ Gb/cm |
| 3514 | How much is the flux in Weber in the above problem ___ |
| 3515 | The magnetic flux of 2000 lines is how many Maxwells ___ |
| 3516 | One ampere- turn is equivalent to ___ gilberts |
| 3517 | The customary energy unit in atomic and nuclear physics is ___ |
| 3518 | Flux density is measured in ___ |
| 3519 | The unit of flux is ___ in cgs system |
| 3520 | What is the cgs unit of magnetomotive force ___ |
| 3521 | What is the unit of magnetomotive force ___ |
| 3522 | What is the SI unit of magnetic flux ___ |
| 3523 | What is the unit of reluctance ___ |
| 3524 | The quantity maxwells is equivalent to one ___ |
| 3525 | Which of the following electric quantities is vector in character ___ |
| 3526 | Which of the following is a vector quantity ___ |
| 3527 | Flux linkages equals ___ |
| 3528 | The physical motion resulting from the forces of magnetic fields is called ___ |
| 3529 | The idea of preventing one component from affecting another through their common electric and magnetic field is referred to as ___ |
| 3530 | A commercial alloy of aluminum nickel, and iron with cobalt, copper and titanium added to produce about 12 grades ___ |
| 3531 | An alloy of 40 percent iron and 60 percent nickel ___ |
| 3532 | An alloy of 22 percent iron and 78 per cent nickel ___ |
| 3533 | Bonding of atoms that is due to the force of attraction between positive ions and a group of negative ions ___ |
| 3534 | How many neutrons does a copper atom have ___ |
| 3535 | A germanium atom has an atomic weight of 72 ___ |
| 3536 | Germanium atom has ___ protons and ___ electrons |
| 3537 | The K shell or the first shell has how many permissible number of orbiting electrons ___ |
| 3538 | The uncharged particles which have no effect on its atomic charge ___ |
| 3539 | What revolves about the positive nucleus in a definite orbit ___ |
| 3540 | The simplest type of atom to exist is the ___ atom |
| 3541 | All matters (gas, liquid and solid) are composed of ___ |
| 3542 | The tiniest element of matter ___ |
| 3543 | The contribution to the ionization in an ionization chamber by electrons liberated from the walls ___ |
| 3544 | An effect which is generally used in the gausameter to measure flux density ___ |
| 3545 | The ability of a mechanically stressed ferromagnetic wire to recognize rapid switching of magnetization when subjected to a dc magnetic field ___ |
| 3546 | The emission of electrons from hot bodies is called ___ |
| 3547 | Small voltages generated by a conductor with current in an external magnetic field ___ |
| 3548 | A magnetic material losses its ferromagnetic properties at a point called ___ |
| 3549 | Is an electromagnet with its core in the form of a close magnetic ring ___ |
| 3550 | Permeability means ___ |
| 3551 | The force between two magnetic poles varies with the distance between them ___ |
| 3552 | A group of magnetically aligned atoms is called ___ |
| 3553 | Paramagnetic substance has a relative permeability of ___ |
| 3554 | Steel is hard to magnetize because of its ___ |
| 3555 | The magnetic flux through a wire loop in a magnetic field does not depend on ___ |
| 3556 | When a wire loop is rotated in a magnetic field the direction of the induced emf changes one in every revolution ___ |
| 3557 | The induced emf in a wire loop that is moved parallel to a uniform magnetic field is ___ |
| 3558 | The emf produced in a wire by its motion across a magnetic field does not depend upon the ___ |
| 3559 | A current if flowing east along a power line ___ |
| 3560 | A permanent magnet does not exert a force on ___ |
| 3561 | The magnetic field of a bar magnet most closely resembles the magnetic field of ___ |
| 3562 | When the ferromagnetic substance is inserted in a current- carrying solenoid, the magnetic field is ___ |
| 3563 | The magnetic field inside a solenoid ___ |
| 3564 | All magnetic field originates from ___ |
| 3565 | Used to maintain strength of magnetic field ___ |
| 3566 | Magnetic effects of the earth as a huge magnet with north and south poles ___ |
| 3567 | One that has magnetic poles produced by internal atomic structure with no external current necessary |
| 3568 | The air space between poles of magnets ___ |
| 3569 | Refers to the non- metallic materials that have the ferromagnetic properties of iron ___ |
| 3570 | Refers to the magnetic lines ___ |
| 3571 | The lagging effect between flux density of the material and the magnetizing force applied ___ |
| 3572 | The ratio between the intensity of magnetization produced in a substance to the magnetizing force producing it ___ |
| 3573 | The force acting on a unit n- pole placed at that point is called ___ |
| 3574 | Defined as the flux density produced in it due to its own induced magnetism ___ |
| 3575 | Defined as the number of lines per unit area through any substance in a plane at right angles to the lines of force ___ |
| 3576 | The ratio of the total flux (flux in iron path) to the useful flux (flux in air gap) ___ |
| 3577 | The amount of magnetizing force to counter balance the residual magnetism of a magnetic material is referred to as ___ |
| 3578 | The quantity of magnetism retained by a magnetic material after withdrawal of the magnetizing force is called ___ |
| 3579 | The property of magnetic materials of retaining magnetism after withdrawal of the magnetizing force is known as ___ |
| 3580 | Permeance is analogous to ___ |
| 3581 | The ratio of the permeability of material to the permiabiity of air or vacuum ___ |
| 3582 | The ability of a material to conduct magnetic flux through it ___ |
| 3583 | It is the reciprocal of reluctance and implies the case of readiness with which magnetic flux is developed ___ |
| 3584 | The property of a material which opposes the creation of magnetic flux in it ___ |
| 3585 | Referred to as the specific reluctance of a material ___ |
| 3586 | The force which set ups or tends to set up magnetic flux in a magnetic circuit ___ |
| 3587 | Defined as a closed path in which magnetic induction or flux flows ___ |
| 3588 | What is the diameter of an atom ___ |
| 3589 | The current of electric circuit is analogous to which quantity of a magnetic circuit ___ |
| 3590 | Materials that have very high permeabilities (hundreds and even thousands times of that of free space) ___ |
| 3591 | Materials whose permeabilities are slightly greater than that of free space ___ |
| 3592 | Which of the following materials has permeability slightly less than that of free space ___ |
| 3593 | Which of the following magnetic materials can be easily magnetized in both direction ___ |
| 3594 | The phenomenon by which a magnetic substance becomes a magnet when it is place near a magnet ___ |
| 3595 | The total number of magnetic lines of force in a magnetic field is called ___ |
| 3596 | The space outside the magnet where its pole have a force of attraction or repulsion on a magnetic pole is called ___ |
| 3597 | The branch of Engineering which deals with the magnetic effect of electric current is known as ___ |
| 3598 | The straight line passing through the two poles of magnet is called ___ |
| 3599 | The point in a magnet where the intensity of magnetic lines of force is maximum ___ |
| 3600 | Define as that pole which when placed in air from a similar and equal pole repels it with a force of newtons ___ |
| 3601 | Which of the following is a natural magnet ___ |
| 3602 | The phenomenon by which a subtracts pieces of iron ___ |
| 3603 | A substance that attracts pieces iron ___ |
| 3604 | The magnetic potential in a magnetic circuit can be measured in terms of ___ |
| 3605 | When a conductor is stationary and the magnetic field is moving or changing the emf induced is called ___ |
| 3606 | The emf induced in a coil due to the changing current of another neighbouring coil is called ___ |
| 3607 | The emf induced in a coil due to the change of its own flux linked with it is called ___ |
| 3608 | The process by which an emf and hence current is generated or induced in a conductor when there is a change in the magnetic flux linking the conductor is called ___ |
| 3609 | If the solenoid is gripped by the right hand with the fingers pointing the direction of current flow, the outstretched thumb will then point the north pole ___ |
| 3610 | If on looking at any one end of a solenoid; the direction of current flow is found to be clockwise then the end under observation is a south pole ___ |
| 3611 | If you hold the conductor with right hand so that the stretched thumb points in the direction of the current, then encircling fingers will give the direction of magnetic lines of force round the conductor ___ |
| 3612 | Lenz’ law states that the direction of the induced emf and hence current ___ |
| 3613 | Lenz’s law is the consequence of the law of conservation of ___ |
| 3614 | The net electrical charge in an isolated system remains constant ___ |
| 3615 | A law establishing the fact that the algebraic su of the rises and drops of the mmf around a closed loop of a magnetic circuit is equal to zero ___ |
| 3616 | States that the ratio of the thermal conductivity is proportional to the absolute temperature for all metals ___ |
| 3617 | A law that states that the polarity of the induced voltage will oppose the change in magnetic flux causing the induction ___ |
| 3618 | Whenever a conductor cuts magnetic flux, an emf is induced in it ___ |
| 3619 | The force of attraction or repulsion between two magnetic poles is inversely proportional to the square of the distance between them ___ |
| 3620 | The force of attraction or repulsion between two magnetic poles is directly proportional to their strengths ___ |
| 3621 | Whenever a flux inking a coil or current changes, an emf is induced in it ___ |
| 3622 | The magnitude of the induced emf in a coil is directly proportional to the rate of change of flux linkages ___ |
| 3623 | Who discovered superconductivity in 1911 ___ |
| 3624 | Who demonstrated that there are magnetic effects around every current-carrying conductor and that current-carrying conductors can attract and repel each other just like magnets ___ |
| 3625 | Who discovered the most important electrical effects which is the magnetic effect ___ |
| 3626 | Who discovered that a current-carrying conductor would move when placed in a magnetic field ___ |
| 3627 | Who developed the electromagnetic theory of light in 1862 ___ |
| 3628 | Who demonstrated the theory of electromagnetic induction in 1831 ___ |
| 3629 | Who discovered the relationship between magnetism and electricity that serves as the foundation for the theory of electromagnetism ___ |
| 3630 | In order to achieve accuracy, the slide wire of a potentiometer should be ___ |
| 3631 | Both X and Y plates of a CRO are excited by ac signals ___ |
| 3632 | A digital voltmeter has a 4 1/2 digit display ___ |
| 3633 | Compositional analysis of ___ is done using mass spectrometer |
| 3634 | The high voltage side of each step-down transformer has a remote-operated disconnect ___ |
| 3635 | A 480 VAC motor control center supplies a load through a breaker and a manual disconnect switch ___ |
| 3636 | The high voltage side of each step-down transformer has a remote-operated disconnect to allow transformer maintenance while keeping the other transformers in service ___ |
| 3637 | What is an advantage of using high-voltage disconnect switches instead of breakers to isolate main power transformers ___ |
| 3638 | The function of high-voltage disconnect switches is to provide ___ electrical isolation of equipment during ___ conditions |
| 3639 | Typical high-voltage transformer disconnect switches are designed to ___ |
| 3640 | High voltage electrical disconnects should not be used to ___ |
| 3641 | High-voltage disconnect switches are used to ___ |
| 3642 | Which one of the following results from a loss of control power to a breaker supplying a motor ___ |
| 3643 | Loss of breaker control power will cause ___ |
| 3644 | If a breaker is racked to the TEST position, the ___ |
| 3645 | If the alternate set of parameter values had existed just before the breaker was closed, the resulting main generator MW value would have been ___; and the resulting main generator MVAR (in) value would have been ___ |
| 3646 | The main generator output breaker was just closed to connect the main generator to the main transformer ___ |
| 3647 | If a main generator output breaker is closed when the generator output voltage is 90 degrees out of phase with the power grid voltage, the main generator will experience a ___ stress |
| 3648 | If a main generator output breaker is closed when the generator output voltage is 5 degrees out of phase with the power grid voltage, the main generator will experience a ___ stress |
| 3649 | A main generator output breaker is about to be closed to connect the main generator to the power grid via the main transformer ___ |
| 3650 | A diesel generator (DG) was initially operating at 80 percent of rated load supplying an isolated electrical bus when a malfunction caused the DG output breaker to trip ___ |
| 3651 | The following frequencies exist just prior to closing the generator output breaker ___ |
| 3652 | Generator output frequency is slightly higher than grid frequency and generator output voltage is equal to grid voltage ___ |
| 3653 | During a routine inspection of a main generator output breaker, a technician discovers severely damaged main contact surfaces ___ |
| 3654 | A main generator is about to be connected to an infinite power grid ___ |
| 3655 | Which one of the following will cause the most damage to the contact surfaces of a main generator output breaker ___ |
| 3656 | The generator breaker is closed just as the synchroscope pointer reaches the 3 o’clock position ___ |
| 3657 | A main generator is being paralleled to an infinite power grid with the following conditions ___ |
| 3658 | At which one of the following synchroscope pointer positions is the main generator output voltage the farthest out of phase with the grid voltage ___ |
| 3659 | Generator voltage is equal to grid voltage and the synchroscope is rotating slowly in the counterclockwise direction ___ |
| 3660 | Generator voltage is slightly higher than grid voltage and the synchroscope is rotating slowly in the clockwise direction ___ |
| 3661 | Which one of the following indicates that the generator and grid voltages are in phase ___ |
| 3662 | Generator voltage equals grid voltage and the synchroscope is rotating slowly in the clockwise direction ___ |
| 3663 | Two identical 1,000 MW electrical generators are being connected to the same electrical bus ___ |
| 3664 | Which one of the following conditions will cause the main generator to immediately supply reactive power (MVAR) to the grid when the generator output breaker is closed ___ |
| 3665 | A main generator is being connected to an infinite power grid that is operating at 60 Hz ___ |
| 3666 | Closing the output breaker of the generator with the frequency of the generator 0.1 Hz higher than grid frequency will result in the generator ___ |
| 3667 | If the generator breaker is closed just prior to the synchroscope pointer reaching the 12 o’clock position, which one of the following is most likely to occur ___ |
| 3668 | Which one of the following indicates that the main generator and grid voltages are in phase ___ |
| 3669 | When the generator output breaker is closed, the generator will ___ |
| 3670 | Which one of the following evolutions will draw the highest current from the main generator during operation of the output breaker ___ |
| 3671 | During paralleling operations of the main generator to an infinite power grid, closing the generator output breaker with the frequency of the generator at 61 hertz and the grid frequency at 60 hertz will ___ |
| 3672 | Generator voltage has been properly adjusted and the synchroscope is rotating slowly in the clockwise direction ___ |
| 3673 | The primary reason for isolating emergency electrical loads from their power supply bus prior to energizing the bus via the emergency diesel generator is to prevent an ___ |
| 3674 | Which one of the following generator conditions is most likely to result in equipment damage from high current flow ___ |
| 3675 | Closing the output breaker of a three-phase generator onto a deenergized bus can ___ |
| 3676 | Which one of the following will occur if the generator output breaker is closed with generator frequency 0.1 Hz lower than power grid frequency ___ |
| 3677 | Which one of the following is an unsafe practice if performed while working on or near energized electrical equipment ___ |
| 3678 | Which one of the following describes the proper operations to isolate power to the motor ___ |
| 3679 | The function of high voltage electrical disconnects is to ___ |
| 3680 | Which one of the following describes the alarm response after the control switch is released? |
| 3681 | Refer to the drawing of a valve motor control circuit for a valve that is currently fully open and has an 8-second stroke time |
| 3682 | Refer to the drawing of a valve motor control circuit (see figure below) for a valve that is currently fully open and has a 16-second stroke time ___ |
| 3683 | Two seconds later, after verifying the valve is closing, the operator releases the control switch |
| 3684 | When the valve stops moving, what will be the status of the alarm and the red (R) and green (G) indicating lights ___ |
| 3685 | Which one of the following describes the valve motor control circuit alarm response after the switch is released ___ |
| 3686 | Two seconds later, after verifying the valve is closing, the operator releases the control switch ___ |
| 3687 | Which one of the following describes the valve response when the control switch is taken to CLOSE momentarily and released ___ |
| 3688 | The operator takes the control switch to CLOSE momentarily and the valve begins to close ___ |
| 3689 | Which one of the following will actuate the alarm ___ |
| 3690 | The operator takes the control switch to CLOSE ___ |
| 3691 | The motor has been idle for several days when it is decided to start the motor ___ |
| 3692 | If the valve is currently closed, when will the alarm actuate ___ |
| 3693 | The motor has been operating for several hours when it is decided to stop the motor ___ |
| 3694 | How are the starting resistors employed before and after the motor is energized ___ |
| 3695 | The operator takes the control switch to OPEN for 5 seconds and then releases the switch ___ |
| 3696 | The motor receives overload protection from ___ overload relays; and ___ overload relay(s) must actuate to deenergize the motor |
| 3697 | What is the purpose of the Time Delay Coil (TD) in the motor controller circuit ___ |
| 3698 | The operator takes the control switch to OPEN momentarily and the valve begins to open ___ |
| 3699 | An operator takes the control switch to OPEN momentarily and the valve begins to open ___ |
| 3700 | Refer to the drawing of a valve motor control circuit for a valve that is currently fully open and has a 10-second stroke time ___ |
| 3701 | Which one of the following describes the valve response if the control switch is taken to the OPEN position for two seconds and then released ___ |
| 3702 | Which one of the following describes the valve response if the control switch is taken to the CLOSE position for two seconds and then released ___ |
| 3703 | Pushbutton PB2 has been momentarily depressed and then released, and the valve is currently at mid-stroke and moving to the open position ___ |
| 3704 | The valve is half open and moving to the open position. Which one of the following describes the current condition of the valve position indicating lights ___ |
| 3705 | Which one of the following describes the purpose of the alarm ___ |
| 3706 | Which one of the following describes the condition of the valve and its control circuit ___ |
| 3707 | Refer to the drawing of a valve motor control circuit for a valve that is currently fully closed ___ |
| 3708 | Which one of the following describes the function of the #3 contact ___ |
| 3709 | The valve is currently open with the contact configuration as ___ |
| 3710 | What is the purpose of depressing the S1 pushbutton ___ |
| 3711 | Refer to the drawing of a valve motor control circuit ___ |
| 3712 | Which one of the following will provide the first motor protection against electrical damage caused by gradual bearing degradation ___ |
| 3713 | Thermal overload devices will provide the first electrical protection for a pump motor in the event of ___ |
| 3714 | A thermal overload device for a large motor protects the motor from ___ |
| 3715 | Which one of the following describes the operation of a thermal overload device for a large motor ___ |
| 3716 | A typical 120 VAC manual circuit breaker tripped due to overload ___ |
| 3717 | While remotely investigating the condition of a normally-open 480 VAC motor control center (MCC) feeder breaker, an operator observes the following indications ___ |
| 3718 | While remotely investigating the condition of a normally-open feeder breaker to a 480 VAC motor control center (MCC), a control room operator observes the following indications ___ |
| 3719 | The following indications are observed in the control room for a normally open breaker that directly starts/stops a 480 VAC motor ___ |
| 3720 | Based on these indications, the operator should report that the feeder breaker is ___ and racked ___ |
| 3721 | While remotely investigating the condition of a typical normally-open motor control center (MCC) feeder breaker, an operator observes the following indications ___ |
| 3722 | While remotely investigating the condition of a typical normally open motor control center (MCC) feeder breaker, an operator observes the following indications ___ |
| 3723 | While remotely investigating the condition of a normally-open breaker that feeds a motor control center (MCC), an operator observes the following indications ___ |
| 3724 | The following remote indications are observed for a 480 VAC load supply breaker ___ |
| 3725 | Which one of the following will cause a loss of indication from the remote breaker position indicating lights associated with a typical 480 VAC load supply breaker ___ |
| 3726 | Given the following indications for an open 4,160 VAC breaker ___ |
| 3727 | Assuming no operator actions were taken since the breaker opened, which one of the following could have caused the breaker to open ___ |
| 3728 | Breaker local overcurrent trip flag indicators, when actuated, indicate that ___ |
| 3729 | Which one of the following describes the normal operation of a local breaker overcurrent trip flag indicator ___ |
| 3730 | Which one of the following describes the local overcurrent trip flag indicators for a breaker ___ |
| 3731 | A positive displacement pump should be started with its suction valve ___ and its discharge valve ___ |
| 3732 | A ___ pump in a liquid system should be started with its discharge valve ___ to avoid rupturing the pump casing and/or discharge piping |
| 3733 | Prior to starting a positive displacement pump, the discharge valve should be open to ___ |
| 3734 | Which one of the following describes the value of the pump head where the two curves cross ___ |
| 3735 | A positive displacement pump is initially supplying water at 40 gpm with a pump discharge pressure of 200 psia ___ |
| 3736 | A positive displacement pump is initially supplying water at 40 gpm with a pump discharge pressure of 400 psia ___ |
| 3737 | The pump must maintain a nearly constant flow rate with a minimum of discharge pressure fluctuations as system pressure varies between 200 psig and 1,900 psig ___ |
| 3738 | A pump is needed to supply fuel oil from a day tank to a diesel engine fuel injection system ___ |
| 3739 | A section of pipe is being hydrostatically tested to 1,400 psig using a positive displacement pump ___ |
| 3740 | A pump that moves liquid by means of a piston within a cylinder that displaces a given volume of fluid for each stroke is a ___ pump |
| 3741 | What is the purpose of the relief valve located between the pump outlet and the discharge isolation valve of many positive displacement pumps ___ |
| 3742 | Which one of the following describes the proper location for a relief valve that will be used to prevent exceeding the design pressure of a positive displacement pump and associated piping ___ |
| 3743 | Water enters a positive displacement pump at 50 psig and 90°F ___ |
| 3744 | Which one of the following will occur as a direct result of operating a positive displacement pump with insufficient net positive suction head ___ |
| 3745 | The available net positive suction head for a pump may be expressed as ___ |
| 3746 | Which one of the following describes the value of the head where the two curves cross ___ |
| 3747 | A rotary positive displacement pump (PDP) is being used to supply water to a piping system ___ |
| 3748 | To decrease pump flow rate to 30 gpm, pump speed must be decreased to approximately ___ |
| 3749 | An ideal (no slip) reciprocating positive displacement pump is operating in an open system to provide makeup water to a coolant system that is being maintained at 800 psig ___ |
| 3750 | Which one of the following conditions will result in the greatest increase in volumetric flow rate from a positive displacement pump operating at 300 rpm and a discharge pressure of 100 psig ___ |
| 3751 | An ideal (no slip) reciprocating positive displacement pump is operating to provide makeup water to a reactor coolant system that is being maintained at 1,000 psig ___ |
| 3752 | A variable-speed positive displacement pump is operating at 100 rpm with a flow rate of 60 gpm in an open system ___ |
| 3753 | A positive displacement pump (PDP) is operating in an open water system ___ |
| 3754 | A positive displacement pump is operating at a constant speed in an open water system with its suction and discharge valves fully open ___ |
| 3755 | A centrifugal pump is operating in parallel with a positive displacement pump in an open water system ___ |
| 3756 | The volumetric flow rate of a positive displacement pump is directly proportional to the ___ |
| 3757 | A positive displacement pump (PDP) is operating in an open system ___ |
| 3758 | Which one of the following describes the primary purpose of minimum flow piping for a centrifugal pump ___ |
| 3759 | A centrifugal pump is susceptible to overheating and possible cavitation while operating with its discharge valve closed, unless ___ |
| 3760 | If the surge tank water level increases from 8 feet to 9 feet, the pump mass flow rate will ___ |
| 3761 | If the pump flow rate increases, ___ will be affected; and if the pump inlet pressure increases, ___ will be affected |
| 3762 | How will the centrifugal pump flow rate be affected if the surge tank level decreases from 8 feet to 4 feet ___ |
| 3763 | The pump is unable to achieve its rated volumetric flow rate due to cavitation ___ |
| 3764 | Which one of the following will enable the pump to achieve a higher volumetric flow rate before cavitation occurs ___ |
| 3765 | When the pump discharge flow control valve is opened further, the pump is unable to provide the desired volumetric flow rate due to cavitation ___ |
| 3766 | Refer to the graph that represents the head-capacity characteristics for a single-speed centrifugal cooling water pump ___ |
| 3767 | A motor-driven centrifugal pump is operating in a closed-loop cooling water system and is unable to achieve its rated volumetric flow rate due to cavitation ___ |
| 3768 | At which one of the following elevations above the reservoir water level will the fire hose spray nozzle first be unable to provide flow ___ |
| 3769 | Which one of the following is at a relatively high value when a centrifugal pump is operating at shutoff head ___ |
| 3770 | A centrifugal firewater pump is operating to pressurize a fire main. The pump takes suction from a vented water storage tank ___ |
| 3771 | A fire hose connected to the fire main is being used to suppress an elevated fire ___ |
| 3772 | A centrifugal firewater pump is operating to pressurize a fire main ___ |
| 3773 | How will the pump be affected if the discharge valve is fully opened ___ |
| 3774 | A centrifugal pump is operating at maximum design flow rate, taking suction on a vented water storage tank and discharging through two parallel valves ___ |
| 3775 | A centrifugal pump is operating normally in an open system with all valves fully open ___ |
| 3776 | If the fully open discharge valve of a reciprocating positive displacement pump is closed approximately 10 percent, pump flow rate will ___; and pump head will ___ |
| 3777 | If the pump recirculation valve is opened farther, pump discharge pressure will ___; and pump flow rate will ___ |
| 3778 | A centrifugal pump is operating at rated conditions in an open system with all valves fully open ___ |
| 3779 | A single-speed centrifugal fire pump takes suction on a water storage tank and discharges through a flexible fire hose ___ |
| 3780 | The drawing shows the operating point for a single-speed centrifugal pump operating in a closed cooling water system using 6-inch diameter piping ___ |
| 3781 | Refer to the drawing showing two different operating points for the same centrifugal pump operating in the same cooling water system ___ |
| 3782 | If both pumps have the same discharge head, which pump has the lower discharge pressure, and why ___ |
| 3783 | A centrifugal water pump is operating normally with the following parameters. What is the pump discharge pressure ___ |
| 3784 | Which one of the following describes the value of head where the two curves cross ___ |
| 3785 | A centrifugal pump is located adjacent to the bottom of an open water storage tank ___ |
| 3786 | A single-stage (single impeller) centrifugal pump and a two-stage (two impellers) centrifugal pump have identical head-capacity curves ___ |
| 3787 | Centrifugal pumps A and B are identical except that pump A uses a single-suction impeller while pump B uses a double-suction impeller ___ |
| 3788 | A single-speed centrifugal pump is needed to supply river water to a storage facility ___ |
| 3789 | A centrifugal pump is needed to take suction on a water storage tank and deliver high pressure water to a water spray system ___ |
| 3790 | Pumps A and B are identical single-speed centrifugal pumps and both pumps are operating ___ |
| 3791 | Which one of the following describes a reason for designing centrifugal pumps with suction nozzles that are larger than their discharge nozzles ___ |
| 3792 | If the pump is initially operating at point B, how will the operating point change if the temperature controller setpoint is decreased by 10°F ___ |
| 3793 | If the temperature control valve is positioned more closed, the system head loss will ___; and the pump head will ___ |
| 3794 | If the pump speed is reduced by one-half, the new operating point will be located on curve ___ closer to point ___ |
| 3795 | A typical single-stage radial-flow centrifugal pump is being returned to service following maintenance on its three-phase AC induction motor ___ |
| 3796 | Which one of the following components of a centrifugal pump has the specific primary function of increasing the kinetic energy of a fluid ___ |
| 3797 | If the temperature control valve modulates further open, operating point B will be located on curve ___ closer to point ___ |
| 3798 | If the pump discharge valve is fully closed, pump discharge pressure will ___; and motor current will ___ |
| 3799 | Which one of the following actions will correct a cavitating centrifugal pump ___ |
| 3800 | Refer to the drawing of a lube oil temperature control system and the associated pump/system operating curves ___ |
| 3801 | A typical radial-flow centrifugal pump is operating at rated conditions in an open system with all valves fully open ___ |
| 3802 | A motor-driven centrifugal pump is operating in an open system with its discharge valve throttled to 50 percent ___ |
| 3803 | Pumps A and B are identical single-speed centrifugal pumps and only pump A is operating ___ |
| 3804 | Refer to the drawing of a radial-flow centrifugal pump with a recirculation line in an open system ___ |
| 3805 | A flow-limiting venturi in the discharge piping of a centrifugal pump decreases the potential for the pump to experience ___ |
| 3806 | Refer to the drawing of a cooling water system in which only centrifugal pump A is operating and the common pump discharge valve is currently 90 percent open ___ |
| 3807 | Which one of the following describes typical radial-flow centrifugal pump runout conditions ___ |
| 3808 | What adverse effect is caused by operating a motor-driven centrifugal pump under runout conditions ___ |
| 3809 | A centrifugal pump is operating at its maximum design flow rate, delivering water through two parallel valves ___ |
| 3810 | Which point represents pump operation at runout conditions ___ |
| 3811 | Operating a motor-driven centrifugal pump under “pump runout” conditions can cause ___ |
| 3812 | A centrifugal pump is operating at rated conditions in an open system ___ |
| 3813 | Which one of the following will occur if a motor-driven centrifugal pump is operated continuously at runout conditions ___ |
| 3814 | A centrifugal fire water pump takes suction from an open storage tank and discharges through a fire hose. Which one of the following will cause the pump to operate at shutoff head ___ |
| 3815 | Which one of the following will cause the pump to operate at shutoff head ___ |
| 3816 | Which one of the following describes centrifugal pump operating parameters at shutoff head ___ |
| 3817 | A variable-speed centrifugal fire water pump is taking a suction on an open storage tank and discharging through a 4-inch diameter fire hose and through a nozzle located 50 feet above the pump ___ |
| 3818 | When a centrifugal pump is operating at shutoff head, it is pumping at ___ capacity and ___ discharge head |
| 3819 | A centrifugal fire water pump takes suction from an open storage tank and discharges through a fire hose ___ |
| 3820 | Which one of the following specifies the proper pump discharge valve position and the basis for that position when starting a large motor-driven radial-flow centrifugal pump ___ |
| 3821 | Some large centrifugal pumps are interlocked so that the pump will not start unless its discharge valve is at least 90 percent closed ___ |
| 3822 | Which one of the following contains two reasons for starting a typical radial-flow centrifugal pump with the discharge piping full of water and the discharge valve closed ___ |
| 3823 | Which one of the following pumps should be started with its discharge valve throttled ___ |
| 3824 | Many large centrifugal pumps are interlocked so that the pump will not start unless its discharge valve is at least 90 percent closed ___ |
| 3825 | The pump can supply cooling water to several heat loads, all of which are in parallel alignment ___ |
| 3826 | A radial-flow centrifugal cooling water pump is driven by an AC induction motor ___ |
| 3827 | An AC motor-driven centrifugal water pump was just started ___ |
| 3828 | A centrifugal pump is circulating water at 180°F with a pump motor current of 200 amps ___ |
| 3829 | An AC motor-driven centrifugal pump was just started ___ |
| 3830 | A constant-speed centrifugal pump motor draws the most current when the pump is ___ |
| 3831 | A centrifugal pump in a cooling water system is operating with a motor current of 200 amps ___ |
| 3832 | Initially, an AC motor-driven centrifugal pump was operating in a cooling water system with cooling water temperature at 150°F ___ |
| 3833 | A reactor recirculation pump is circulating reactor coolant at 150°F ___ |
| 3834 | Which one of the following describes how and why pump motor current will change if the pump shaft shears ___ |
| 3835 | A motor-driven centrifugal pump exhibited indications of pump failure while being started ___ |
| 3836 | An AC motor-driven centrifugal pump is circulating water at 180°F with a motor current of 100 amps ___ |
| 3837 | If the temperature of the cooling water entering pump A increases to 200°F, the pump’s motor current will ___ |
| 3838 | Initially, a centrifugal pump is operating at normal discharge pressure and flow conditions with the pump discharge valve fully open ___ |
| 3839 | A constant-speed radial-flow centrifugal pump motor draws the least current when the pump is ___ |
| 3840 | In response to a loss of coolant accident, an emergency core cooling pump is taking suction from the bottom of a vented water storage tank and discharging to the downcomer region of a reactor vessel ___ |
| 3841 | The storage tank is open to the atmosphere and contains 20 feet of water at 90°F ___ |
| 3842 | If system pressure is increased by 10 psi, the available net positive suction head (NPSH) for the pump will ___; and the pump mass flow rate will ___ |
| 3843 | The pump is located at the base of the tank, takes a suction from the bottom of the tank, and discharges to a pressurized system ___ |
| 3844 | Refer to the drawing of a centrifugal pump with a water storage tank for its suction source ___ |
| 3845 | Which one of the following modifications would decrease the pumps available net positive suction head ___ |
| 3846 | The pump is located on shore, with the eye of the pump 4 feet higher than the reservoir water level ___ |
| 3847 | A centrifugal pump is taking suction from an open water storage tank ___ |
| 3848 | The pump requires a net positive suction head (NPSH) of 150 feet for pumping water at 300°F ___ |
| 3849 | What is the net positive suction head available to the condensate pump ___ |
| 3850 | An operating centrifugal pump has a net positive suction head (NPSH) requirement of 150 feet ___ |
| 3851 | A centrifugal pump is taking suction on a water storage tank and discharging through a flow control valve ___ |
| 3852 | Which one of the following will provide the greatest increase in NPSH available to the condensate pump ___ |
| 3853 | Refer to the drawing below of a centrifugal pump taking suction from the bottom of an open storage tank containing water at 75°F ___ |
| 3854 | A centrifugal pump is taking suction on a water storage tank and delivering the makeup water to a cooling water system ___ |
| 3855 | What is the minimum hotwell water level necessary to provide the required NPSH ___ |
| 3856 | Refer to the drawing of a centrifugal pump taking suction from the bottom of an open water storage tank ___ |
| 3857 | A centrifugal cooling water pump is operating in an open system with its discharge valve fully open ___ |
| 3858 | Pump and water level elevations are indicated in the figure. Assume standard atmospheric pressure ___ |
| 3859 | Refer to the drawing of an elevated centrifugal pump taking suction from the bottom of an open storage tank containing water at 66°F |
| 3860 | Refer to the drawing below of a centrifugal pump taking suction from the bottom of an open storage tank containing water at 66°F ___ |
| 3861 | A centrifugal pump is taking suction on an open storage tank that has been filled to a level of 40 feet with 10,000 gallons of 60°F water ___ |
| 3862 | Which one of the following will increase the available net positive suction head for the centrifugal pump ___ |
| 3863 | A cooling water pump is operating with pump suction parameters as follows ___ |
| 3864 | The available net positive suction head for the centrifugal pump will be decreased by ___ |
| 3865 | A variable speed motor-driven centrifugal pump is operating at 50 percent speed in an open system ___ |
| 3866 | Which one of the following will decrease available net positive suction head for the centrifugal pump ___ |
| 3867 | A motor-driven centrifugal pump is operating in an open system with its discharge valve throttled to 50 percent open ___ |
| 3868 | The available net positive suction head for the centrifugal pump will be increased by ___ |
| 3869 | When flow from a centrifugal pump is increased by opening the discharge valve further, the required net positive suction head (NPSH) ___; and the available NPSH ___ |
| 3870 | Which one of the following will decrease the available net positive suction head to the reactor recirculation pumps ___ |
| 3871 | Which one of the following conditions will result in a decrease in the available net positive suction head of a reactor recirculation pump ___ |
| 3872 | Which one of the following operations in a closed system will cause a decrease in available net positive suction head for a centrifugal pump ___ |
| 3873 | What will occur by operating a positive displacement pump with insufficient net positive suction head ___ |
| 3874 | Which one of the following will increase reactor recirculation pump available net positive suction head ___ |
| 3875 | After the pump is started, the pump suction and discharge pressures stabilize as follows ___ |
| 3876 | A motor-driven radial-flow centrifugal pump is used to provide makeup water to a vented storage tank that is 30 feet high ___ |
| 3877 | A centrifugal pump is used to provide makeup water to a vented storage tank that is 30 feet high ___ |
| 3878 | Refer to the pump and system curves for a centrifugal pump operating in a cooling water system ___ |
| 3879 | The pump discharge valve is partially throttled to produce the following initial pump operating parameters ___ |
| 3880 | Which one of the following changes to the cooling water system will result in a lower cooling water pump flow rate and a higher pump discharge head ___ |
| 3881 | A centrifugal pump is used to provide makeup water to a storage tank that is 30 feet high ___ |
| 3882 | The discharge valve for a radial-flow centrifugal cooling water pump is closed in preparation for starting the pump ___ |
| 3883 | Which one of the following changes to the cooling water system will result in a higher cooling water pump flow rate and a reduced pump discharge head ___ |
| 3884 | A variable-speed centrifugal pump is driven by an AC motor with the following initial conditions ___ |
| 3885 | Operating point A was generated from pump performance data taken six months ago ___ |
| 3886 | If the pump’s speed is increased until the pump’s flow rate equals 400 gpm, the pump’s power input will be approximately ___ |
| 3887 | A multi-speed centrifugal pump is operating at 3,600 rpm with a flow rate of 3,000 gpm ___ |
| 3888 | What will be the approximate values of pump head and motor current if pump speed is decreased to 1,200 rpm ___ |
| 3889 | A multi-speed centrifugal pump is operating with a flow rate of 3,000 gpm ___ |
| 3890 | An AC motor-driven centrifugal pump is operating with the following parameters ___ |
| 3891 | The discharge head of a variable-speed centrifugal pump will increase if the ___ |
| 3892 | A centrifugal pump is operating with the following parameters in a closed system ___ |
| 3893 | Refer to the drawing of a cooling water system and the associated pump/system operating curves ___ |
| 3894 | A variable-speed centrifugal pump is running with its drive motor at 1,800 rpm ___ |
| 3895 | A multi-speed centrifugal pump is operating at 1800 rpm, providing a flow of 400 gpm with a pump head of 20 psid ___ |
| 3896 | The discharge head of a centrifugal pump will decrease if the ___ |
| 3897 | A centrifugal pump is operating at rated speed with a pump head of 240 psid ___ |
| 3898 | Refer to the drawing of a pump with a recirculation line. Valve A will close when pump ___ |
| 3899 | Which one of the following describes the response of the pump if a complete flow blockage occurs in the discharge line just downstream of the flow transmitter ___ |
| 3900 | Refer to the drawing of a centrifugal pump with a recirculation line ___ |
| 3901 | Refer to the drawing of centrifugal pump and system operating curves ___ |
| 3902 | Refer to the drawing of a pump with a recirculation line ___ |
| 3903 | Operating a motor-driven centrifugal pump for an extended period of time under no flow conditions will cause ___ |
| 3904 | A motor-driven centrifugal pump with no recirculation flow path must be stopped when discharge pressure reaches the pump shutoff head to prevent ___ |
| 3905 | Which one of the following would result from operating a motor-driven centrifugal pump for extended periods with the discharge valve shut and no recirculation flow ___ |
| 3906 | Which one of the following describes gas binding of a centrifugal pump ___ |
| 3907 | Which one of the following is an effective method for ensuring that a centrifugal pump remains primed and does not become gas bound during pump operation and after pump shutdown ___ |
| 3908 | Gas binding in a centrifugal pump can be prevented by ___ prior to pump start |
| 3909 | Venting a centrifugal pump prior to operating it ensures that ___ |
| 3910 | Which one of the following will result in immediate cavitation of a centrifugal pump that is initially operating at normal rated flow ___ |
| 3911 | If a centrifugal pump is started with the discharge valve throttled versus fully open, the possibility of pump runout will ___; and the possibility of pump cavitation will ___ |
| 3912 | Which one of the following describes pump cavitation ___ |
| 3913 | If a centrifugal pump is started with the discharge valve fully open versus throttled, the possibility of pump runout will ___; and the possibility of pump cavitation will ___ |
| 3914 | Which one of the following changes in nuclear power plant status will bring the reactor recirculation system closer to the condition in which the recirculation pump will cavitate ___ |
| 3915 | A centrifugal pump is initially operating at maximum rated flow rate in an open system ___ |
| 3916 | What is the reactive power for this generator ___ |
| 3917 | A main generator is supplying 300 MVAR to the power grid with a 0.85 power factor ___ |
| 3918 | Refer to the drawing of an electrical system power curve ___ |
| 3919 | A nuclear power plant was initially operating at 80 percent power in the middle of a fuel cycle with the main generator connected to an infinite power grid with the following main generator output parameters ___ |
| 3920 | Refer to the drawing of an electrical system power triangle ___ |
| 3921 | A diesel generator (DG) is supplying an electrical bus that is connected to an infinite power grid ___ |
| 3922 | A 125 VDC motor is rated at 10 KW. What is the current rating for the motor ___ |
| 3923 | A 4.16 KV diesel generator (DG) is loaded to 2,850 KW with a 0.85 power factor ___ |
| 3924 | What is the power factor of the main generator ___ |
| 3925 | Which one of the following contains a combination of minor adjustments to the main generator voltage regulator and speed control setpoints such that each adjustment will cause the main generator to ___ |
| 3926 | If the main generator field current is decreased, main generator amps will initially ___; and MW will initially ___ |
| 3927 | During a surveillance test, a 4,000 KW diesel generator (DG) and a 1,000 MW main generator (MG) at a nuclear power plant are connected to a power grid ___ |
| 3928 | Which one of the following will significantly increase main generator output amperage without a significant change in main generator MW output ___ |
| 3929 | Which one of the following contains a combination of minor adjustments to the main generator voltage regulator and speed control setpoints such that each adjustment will cause the main generator to operate at a ___ |
| 3930 | During a surveillance test, a 4,000 KW diesel generator (DG) and a 1,000 MW main generator (MG) at a nuclear power plant are connected to the same power grid ___ |
| 3931 | Which one of the following pairs of main generator output parameters places the generator in the closest proximity to slipping a pole ___ |
| 3932 | Elevated main generator winding temperature requires a reduction in reactive load from 200 MVAR (out) to 150 MVAR (out) ___ |
| 3933 | A main turbine-generator is operating in parallel with an infinite power grid ___ |
| 3934 | The generator output breakers provide identical protection for the generators ___ |
| 3935 | A malfunction causes the voltage regulator setpoint for generator B to slowly and continuously increase ___ |
| 3936 | Two identical 1,000 MW generators are operating in parallel supplying the same isolated electrical bus ___ |
| 3937 | Assuming bus voltage does not change, if the DG voltage regulator setpoint is decreased slightly, DG KW will ___; and DG amps will ___ |
| 3938 | Two identical 1,000 MW generators are operating in parallel, supplying all the loads on an isolated electrical bus ___ |
| 3939 | If main generator field current is decreased, amps will initially ___; and MVAR will initially ___ |
| 3940 | A main generator is operating in parallel with an infinite power grid ___ |
| 3941 | A diesel generator (DG) is supplying both KW and KVAR to an electrical bus that is connected to an infinite power grid ___ |
| 3942 | If main generator excitation current is increased slightly, amps will initially ___; and MW will initially ___ |
| 3943 | If main generator excitation current is decreased slightly, amps will ___; and MVAR will ___ |
| 3944 | If generator field current is increased, the generator will become ___ and will attain a ___ power factor |
| 3945 | A main generator is operating in parallel with an infinite power grid with generator VARs currently at zero ___ |
| 3946 | If main generator field current is increased slightly, amps will ___; and MW will ___ |
| 3947 | A main generator that is connected to an infinite power grid has the following indications ___ |
| 3948 | A main generator is connected to an infinite power grid with VARs out (positive VARs) ___ |
| 3949 | A main generator is connected to an infinite power grid ___ |
| 3950 | A main generator that is connected to an infinite power grid has the following initial indications ___ |
| 3951 | Which one of the following describes the effects of field current changes on generator excitation and power factor with the generator connected to an infinite power grid ___ |
| 3952 | A 125 VDC battery is rated at 600 amp-hours for a continuous 50 KW load ___ |
| 3953 | A 125 VDC battery is rated at 768 amp-hours for a continuous 50 KW load ___ |
| 3954 | The term “volt” describes ___ |
| 3955 | What is the significance of a 0.8 power factor when describing the output of a generator ___ |
| 3956 | The force that causes electrons to flow in an electrical circuit is called ___ |
| 3957 | A difference in electrical potential is measured in ___ |
| 3958 | What unit of measurement is used to describe the rate of electron flow ___ |
| 3959 | A large centrifugal pump is driven by a 200 horsepower AC induction motor ___ |
| 3960 | In some instances a reversing control circuit is required to be plug-stopped in either run direction ___ |
| 3961 | On a bi-directional ___ switch, both sets of contacts are NO when the plug switch is at-rest. Both sets of contacts are in their at-rest configuration |
| 3962 | On a bi-directional ___ switch, both sets of contacts are NO when the plug switch is at-rest |
| 3963 | Pushbutton interlock normally requires two or more stacked or combination ___ and ___ PB switches |
| 3964 | ___ is the 2-wire control of a 3-phase (3-pole) electromagnetic motor-starter using momentary switches |
| 3965 | In either circuit configuration, the NO contacts of the Jog PB switch must be wired in ___ with the NC contacts of the Stop PB switch and the NO auxiliary seal-in contacts on the motor -starter, and in ___ |
| 3966 | For the jog function, the NO switch contacts of the added Jog PB switch are wired in parallel with the NO Start PB switch ___ |
| 3967 | The return to the at-rest position of both the momentary stack switches and the electromagnetic solenoid of the motor -starter also in a ___ switching configuration depends on two things: spring ___ and the pull of ___ |
| 3968 | A 3-phase AC motor ___ be started and left to run (operator not present) with a jog circuit |
| 3969 | The addition of the jog function commands the 3-wire control to function as a 2-wire control of the electric motor and driven equipment using momentary NO PB or selector switches ___ |
| 3970 | When the 3-wire control of a single 3-phase AC motor is modified for a jog function with the addition of a stacked NO / NC momentary PB switch and the Jog PB switch is pushed, the NC contacts are ___ |
| 3971 | The motor cannot be forced into a jog condition while it is running ___ |
| 3972 | When NO auxiliary contacts on the power contactor of a motor-starter are used as the hold-in contacts of a 3-wire control circuit, they must be wired in parallel with the ___ momentary PB switch |
| 3973 | Most of the electric-motor driven equipment in a manufacturing plant is either directly involved, or supportive of one or more manufacturing processes ___ |
| 3974 | In comparison of 2- and 3-wire control, a jogging circuit is more apt to be found in the ___ control of a 3-phase AC motor |
| 3975 | In series with both the seal-in and start circuits (in series with the NC Stop PB switch either ___ or ___ the start/seal-in wired ___ |
| 3976 | The jog circuit has to do two things (sometimes simultaneously): ___ |
| 3977 | When the 3-wire control of a single 3-phase AC motor is modified for a jog function with the addition of a stacked NO / NC momentary PB switch, the NC contacts on the Jog PB switch must be wired in ___ |
| 3978 | The addition of the jog function commands the 2-wire control to function as a 3-wire control of the electric motor and driven equipment using momentary NO PB or selector switches ___ |
| 3979 | Other than by a manual motor -starter, the control of a 3-phase AC motor is normally by means of either ___ or ___ wire control of an electromagnetic control relay, power contactor, or motor -starter |
| 3980 | When the Jog PB switch is pushed, the NC contacts are forced open before the NO contacts are allowed to close ___ |
| 3981 | In series with just the motor-starter ___ contacts in the seal-in circuit |
| 3982 | The electromagnetic solenoid of the motor -starter has a second propagation delay in opening not common to the PB switch, and that is the ___ or ___ of the electromagnetic field of the solenoid coil |
| 3983 | The jog function for 3-wire control can be implemented with a ___ |
| 3984 | ___, or ___ as it is sometimes called, is the 2-wire control of a 3-phase electromagnetic motor -starter using momentary switches |
| 3985 | The use of ___ -type selector or pushbutton switches in a control ladder diagram limits the control function to jog control |
| 3986 | When a 3-wire control consists of two PB switches wired in series, the ___ momentary PB switch is used as the interrupt or stop switch. The ___ momentary PB switch |
| 3987 | The jog function for 3-wire control can be implemented with a 2-position ___ switch, a ___PB switch, or a control ___ |
| 3988 | The jog circuit has to ___ |
| 3989 | In the symbols for the TODE or TOR timing-relay contacts, the ___ of the arrow indicates time delay on coming out (after de-energization of the timing-relay solenoid coil) |
| 3990 | In most control-circuit operations, the timing function is commanded to start by a (an) ___ |
| 3991 | If a mercury-filled bulb is mechanically linked to the clock spring, then a change in temperature will cause a ___ of the bulb: the switch is either open or closed when a change in temperature is sensed |
| 3992 | If drawn ___, a prescribed amount of time will elapse after the coil is energized before the contacts actually close |
| 3993 | Change of pressure in a closed vessel is normally caused by the equipment being controlled: either ___ or ___ |
| 3994 | On an 8-pin TODE plug-in relay, The common terminal #1 is NCTC to terminal # ___ and NOTO to terminal # ___ |
| 3995 | On an 11-pin TOE plug-in relay, The common terminal #6 is NCTO to terminal # ___ and NOTC to terminal # ___ |
| 3996 | The acronym NOTC stands for ___ and ___ |
| 3997 | When two or more electric motors are required for a common process, the motors are normally ___ such that should one motor fail, all the motors are stopped simultaneously |
| 3998 | The acronym ____ indicates Normally-Closed, Time-Opened, ___ contacts |
| 3999 | ___, where the timing function occurs after the input signal is de-activated or de-energized |
| 4000 | The thermostats on an electric, storage-type water heater use a ___ that will snap or pop out and away from the water-heated metal tank surface when the preset temperature is reached |
| 4001 | When used to control process or environmental cooling, the higher limit in the differential of a temperature switch is the ___ temperature setting. The lower limit is the ___ temperature setting |
| 4002 | On an 8-pin TOE plug-in relay, The coil leads are wire terminal #s ___ and ___ |
| 4003 | The coil voltage and switch contact ratings of a control relay are normally listed on some form of ___ either gum labeled, stamped, or etched on the mounting base |
| 4004 | On an 8-pin TODE plug-in relay, The coil leads are wire terminal #s ___ and ___ |
| 4005 | Stacked limit switches can be configured at the point of manufacture as a combination NO — NC stacked maintain-position limit switch where the operator ___ to one position when acted upon |
| 4006 | On an 11-pin TODE plug-in relay, If the 120-volt control-supply is mistakenly applied to either control-contact switch terminal #5 or #6 on either the 8-pin or 11-pin TODE relay, the timing relay will normally be ___ |
| 4007 | On an 11-pin TOE plug-in relay, The common terminal #1 is NCTO to terminal # ___ and NOTC to terminal # ___ |
| 4008 | The acronym TOO stands for ___ |
| 4009 | A___ electric storage-type water heater uses two thermostats and two resistive-type-heating elements to heat the water |
| 4010 | When the many different symbols of switches and pilot devices are drawn into a ladder diagram to indicate the control sequence or relay-logic scheme, the switch is drawn ___ |
| 4011 | Float or liquid-level switches, like most pilot devices, normally contain both a set of ___ and a set of ___ contacts |
| 4012 | The acronym ___ stands for time on operate |
| 4013 | Normally, temperature switches or thermostats offer only On/Off control of the heating or cooling means ___ |
| 4014 | The acronym NCTC stands for ___ and ___ |
| 4015 | The relay, with the time-delay feature, offers a timing function only after the relay coil has been either ___ or ___ |
| 4016 | The ___ time-delay relay contacts can be further described as instantly-closed on de-energization of the timing-relay solenoid coil |
| 4017 | The travel between the two liquid levels (upper level and lower level), which can be adjusted, is referred to as the ___ or ___ of the float switch |
| 4018 | The acronym NCTO standards for ___ and ___ |
| 4019 | On an 11-pin TOE plug-in relay, The common terminal #11 is NCTO to terminal # ___ and NOTC to terminal # ___ |
| 4020 | In the symbols for the TOE or TOO timing-relay contacts, the ___ of the arrow indicates time-delay on going in (on energization of the timing-relay solenoid coil) |
| 4021 | The ___ of an arrow in the NO or NC contacts symbol for a timing relay indicates time delay on coming out (after de-energization of the coil) |
| 4022 | On an 8-pin TODE plug-in relay, To energize the TODE plug-in timing relay, a NO switch, a set of NO control-relay contacts, a set of NO auxiliary contacts on a motor-starter, or a ___ |
| 4023 | The control-circuits of most process or other utilization equipment depend on four factors or mediums that either control the equipment or the equipment controls them. These factors or mediums include ___ |
| 4024 | Equipment can be controlled by a ___ (___) where it is either turned on at a particular time of day or turned off at a particular time of day |
| 4025 | Instead of terminal numbers, the three screw terminals on a typical SPDT-type limit switch are identified as ___, ___, and ___ |
| 4026 | The acronym ___ stands for time on de-energization |
| 4027 | The acronym ___ indicates Normally-Closed, Time-Opened, ___ contacts |
| 4028 | To supply fifty gallons of hot water from a forty-gallon storage tank electric water heater, both the cold-water inlet and the hot-water outlet are located in the top of the storage tank ___ |
| 4029 | The acronym TOE stands for ___ |
| 4030 | As used with non-timing relays, the NC control-relay contacts ___ on energization of the relay solenoid coil, and ___ on de-energization of the relay solenoid coil |
| 4031 | Equipment can be controlled by a ___, which is a device that is designed to switch normally-closed contacts open or to switch normally-open contacts closed |
| 4032 | The ___ time-delay relay contacts can be further described as instantly-opened on de-energization of the timing-relay solenoid coil |
| 4033 | An ___ -delay or delay on ___ timer is a device that has a preset time period that must pass after the timer has been energized before any action occurs on the timer contacts |
| 4034 | The acronym NOTO stands for ___ and ___ |
| 4035 | If drawn ___, the same time will elapse before the contacts actually open |
| 4036 | On an 8-pin TODE plug-in relay, ___ between the ungrounded and grounded control buses, must be applied to the coil terminals on the timing-relay solenoid |
| 4037 | On an 8-pin TOE plug-in relay, The common terminal #1 is NCTO to terminal # ___ and NOTC to terminal # ___ |
| 4038 | ___, where the timing function occurs after the input signal is activated or energized |
| 4039 | The acronym TODE stands for ___ |
| 4040 | A ___ timer is a timer that opens and closes the control line (or rung in the ladder diagram) circuit depending on the position of the hands of a clock |
| 4041 | On an 11-pin TODE plug-in relay, The coil leads are wire terminal #s ___ and ___ |
| 4042 | When used to control process or environmental cooling, the higher limit in the differential of a temperature switch is the ___ temperature setting. The lower limit is the ___ |
| 4043 | Similar to a double-circuit, momentary PB, control-circuit switch, the switch block of an industrial-type limit switch has four wire terminals ___ |
| 4044 | The control-circuits of most process or other utilization equipment depend on four factors or mediums that either control the equipment or the equipment controls them ___ |
| 4045 | The ___ of an arrow indicates time-delay on going in (energization of the solenoid) |
| 4046 | On de-energization of the timing-relay solenoid coil, a prescribed amount of time will elapse after the coil is de-energized before the Held-Open ___ contacts re-close |
| 4047 | When two or more electric motors are required for a common process, and each individual motor is provided with its own overload protection by placing the NC control contacts of the overload relay ___ |
| 4048 | The ___ switch is technically not a pilot device, but rather just a remote switching means |
| 4049 | When the controlled process involves the selection of many different piping lines, storage bins, and so on, for material conveying, a timer motor may be used to drive a cam bank of switches ___ |
| 4050 | When used to control process or environmental heating, the higher limit in the differential of a temperature switch is the ___ temperature setting |
| 4051 | On de-energization of the timing-relay solenoid coil, a prescribed amount of time will elapse after the coil is de-energized before the Held-Closed ___ contacts actually re-open |
| 4052 | If drawn ___, the contacts will instantly close on energization of the timing-relay solenoid coil |
| 4053 | The acronym TOR stands for ___ |
| 4054 | A difference of pressure is normally sensed by the deflection of metal. In high-pressure applications, a ___ in a cylinder is used to monitor the change in pressure |
| 4055 | The capillary-type temperature switch is actually a pressure switch. The change in pressure of the confined fluid is indicative of the change in temperature ___ |
| 4056 | The acronym ___ stands for time on energization |
| 4057 | On an 11-pin TODE plug-in relay, ___, between the ungrounded and grounded control buses, must be applied to the coil terminals on the timing-relay solenoid |
| 4058 | The ___ or ___ switch is employed to monitor the position of the liquid according to the depth of the containing vessel |
| 4059 | On an 11-pin TODE plug-in relay, The common terminal #11 is NCTC to terminal # ___ and NOTO to terminal # ___ |
| 4060 | The ___ of an arrow in the NO or NC contacts symbol for a timing relay indicates time-delay on going in (energization of the solenoid) |
| 4061 | On an 11-pin TODE plug-in relay, To energize the TODE plug-in timing relay, a NO switch, a set of NO control-relay contacts, a set of NO auxiliary contacts on a motor-starter, or a NO pilot-device switch separate ___ |
| 4062 | When used to control process or environmental cooling, the higher limit in the differential of a temperature switch is the ___ temperature setting |
| 4063 | In medium-pressure applications, a ___ is used to monitor the change in pressure |
| 4064 | An ___ -delay or delay on ___ timer is a device that does not start its timing function until the power is removed from the timer |
| 4065 | ___ switches are solid-state devices that can use induction, capacitance, or magnetism to sense the presence of a material, either its position or fluid level |
| 4066 | When a pear-shaped buoy float switch is used as the sensing means, ___ (what type of material) is used to establish contact between the long and short electrodes in the glass envelope |
| 4067 | Some timers can be started with an electrical signal and time out, ___ the controlled equipment either energized or de-energized until some other signal ___ the timer |
| 4068 | As with water, the gravitational pull on any liquid will cause the surface to seek its on ___ |
| 4069 | The travel between the two liquid levels (upper level and lower level), which can be adjusted, is referred to as the ___ of the float switch |
| 4070 | The acronym ___ indicates Normally-Open, Time-Closed, ___ contacts |
| 4071 | Positive overload protection differs from auxiliary (seal-in circuit) interlock in that all the motors do not have to enter the run condition, either simultaneously or in a staggered (ramp-up) ___ |
| 4072 | When a real clock timer controls equipment, the timing mechanism is normally a ___ clock motor |
| 4073 | ___ switches sense the flow of a fluid in a pipe or conduit or an open channel |
| 4074 | A difference of pressure is normally sensed by the deflection of metal ___ |
| 4075 | When equipment is timed off using a time-delay relay, there is an intentional delay between when the switch is opened and when the power is actually removed from a motor or other piece of equipment ___ |
| 4076 | On an 11-pin TODE plug-in relay, The common terminal #1 is NCTC to terminal # ___ and NOTO to terminal # ___ |
| 4077 | The devices used to sense the mediums position, pressure, temperature, and time are normally 2-wire switching devices, which are further described as ___ devices |
| 4078 | In high-pressure applications, a ___ in a cylinder is used to monitor the change in pressure |
| 4079 | Stacked limit switches can be configured at the point of manufacture as momentary 3-position limit switches where both sets of contacts are held open in the ___ or ___ position |
| 4080 | If the pressure in a closed vessel is greater than the atmospheric pressure (the outside air), then a ___ switch is used to monitor the exact pressure inside the vessel (normally a tank) |
| 4081 | When equipment is timed on using a time-delay relay, there is an intentional time delay between when a switch is closed and when a motor or other piece of equipment actually starts up ___ |
| 4082 | As used with non-timing relays, the NO control-relay contacts __________ on energization of the relay solenoid coil, and ___ on de-energization of the relay solenoid coil |
| 4083 | The proximity switch has the advantage over the mechanical limit or liquid-level switch because ___ of the medium being sensed is not required |
| 4084 | On an 8-pin TOE plug-in relay, The common terminal #8 is NCTO to terminal # ___ and NOTC to terminal # ___ |
| 4085 | The acronym ___ stands for time on release |
| 4086 | The acronym ___ indicates Normally-Closed, Time-Closed, ___ contacts |
| 4087 | On an 11-pin TOE plug-in relay, The coil leads are wire terminal #s ___ and ___ |
| 4088 | If drawn ___ the contacts will instantly open on energization |
| 4089 | The auxiliary interlock used in the supervised start of a ramp-down circuit for the three motor conveyor system is referred to as ___ because the stoppage of the three electric motors follows a specific pattern |
| 4090 | When a relay-logic Wired-Exclusive-NOR gate, formed with the combination NC — NO contacts of two relays and the inverting logic (NC contacts) of a third relay, is employed in a motor control circuit ___ |
| 4091 | Instead of a logic gate, the logic inverter or NOT Gate is technically a ___ |
| 4092 | When a PB-switch-logic Wired-NOR gate is employed in a motor control circuit, The PB-switch-logic output, taken on the load side of the last set of series-connected NC switch contacts, is ___ |
| 4093 | When a relay-logic Wired-OR gate is employed in a motor control circuit, the relay-logic output is zero volts only when all of the parallel switching or relay contacts are held ___ |
| 4094 | Relay-contact NAND gates can be formed using either two control relays or three control relays ___ |
| 4095 | When a binary-logic ___ gate is employed in a circuit, the logic output is LO when any logic input is HI |
| 4096 | When a relay-logic Wired-NOR gate utilizing only two relays is employed in a motor control circuit ___ |
| 4097 | When two (or more) ___ PB switches are wired in parallel in separate rungs of a ladder diagram that converge or connect to a common rung on their load side, a Wired-OR gate is formed |
| 4098 | All control circuits are basic logic functions or combinations of logic functions. __________ logic occurs in a given control line of a ladder diagram when only a single NC PB switch or pilot device is connected in ___ |
| 4099 | When a binary-logic Exclusive-NOR gate is employed in a circuit ___ |
| 4100 | When a relay-logic Wired-NAND gate utilizing only two relays is employed in a motor control circuit ___ |
| 4101 | When a relay-logic Wired-NAND gate is employed in a motor control circuit, the ___ |
| 4102 | When a relay-logic Wired-NOR gate that utilizes three relays is employed in a motor control circuit ___ |
| 4103 | The ___ or in logic jargon, a ___ on the nose of the triangle, which is the logic-symbol for an operational amplifier, is the symbol for the digital or binary inverter or NOT Gate |
| 4104 | When a binary-logic NOT gate (inverter gate) is employed in a circuit, The logic output is ___ when the logic input is HI |
| 4105 | When two (or more) ___ PB switches are wired in series in separate rungs of a ladder diagram that converge or connect to a common rung on their load side, a Wired-Bubbled AND gate, which is equal to a ___ gate, is formed |
| 4106 | When a relay-logic Wired-AND gate is employed in a motor control circuit, the relay-logic output is 120 volts only when all of the series switching or relay contacts are held ___ |
| 4107 | When a relay-logic Wired-AND gate is employed in a motor control circuit, The relay-logic output, taken on the load side of the last set of series-connected NO relay contacts ___ |
| 4108 | Exclusive-NOR gates are also hybrid gates that are used to check for ___ of the inputs |
| 4109 | When a binary-logic Exclusive-OR gate is employed in a circuit ___ |
| 4110 | When a binary-logic ___ gate is employed in a circuit, the logic output is HI when any logic input is HI |
| 4111 | When two (or more) ___ PB switches are wired in series in the same rung (control line) of a ladder diagram, a Wired-AND gate is formed |
| 4112 | When a binary-logic ___ gate is employed in a circuit, the logic output is LO only when all the logic inputs are HI |
| 4113 | When a PB-switch-logic Wired-NOT gate (wired-inverter gate) is employed in a circuit ___ |
| 4114 | When two PB switches are stack with a set of NC and a set of NO switch contacts, and the NC switch contacts on one PB switch are wired in series with the NO switch contacts on the other PB switch in the ___ |
| 4115 | When a relay-logic Wired-NOR gate is employed in a motor control circuit, the relay-logic output, taken on the load side of the NC inverting-relay contacts, is zero volts when any of the parallel switching ___ |
| 4116 | More than one pushbutton station (operator’s control station) can be installed for a given control line in a control circuit (line or ladder diagram) ___ |
| 4117 | NE Code will allow the ungrounded control-circuit conductors to be any color except ___ |
| 4118 | When the stop switch in a 3-wire control circuit is momentarily opened and re-closed, the motor does not automatically restart as it does in a 2-wire control circuit that suffers a momentary power loss ___ |
| 4119 | A 3-phase ___ motor-starter uses just a mechanical linkage connected to a pushbutton switch assembly to close all three power contacts simultaneously |
| 4120 | The NE Code will allow the ungrounded control-circuit conductors to be any color except ___ |
| 4121 | The simplest form of manual motor control, using an electromagnetic motor -starter, is ___ control |
| 4122 | Three-wire control of a 3-phase AC motor by means of a 3-pole electromagnetic motor-starter uses ___ switches with either pushbutton- or selector-type operators |
| 4123 | The simplest form of manual motor control, using an electromagnetic motor-starter, is ___ control |
| 4124 | The NE Code restricts the color of insulated equipment-grounding conductors to ___ |
| 4125 | In terms of control, all the supply conductors to a 3-phase AC motor have to be interrupted ___ to stop the rotor |
| 4126 | In the power circuit, ___ conductors of the motor -starters are identified with the capital letter L and the representative phase conductor number (phases 1, 2, or 3) to which they are connected |
| 4127 | In the drawing of the schematic and in the actual wiring of the 2-wire remote control of a single 3-phase AC motor, the ungrounded, fused control-power conductor supplies the ___ of the selector switch |
| 4128 | The two side rails of the ladder diagram are referred to as the control-power busses ___ |
| 4129 | In the drawing of the ladder diagram, a ___ line must be used to interconnect the multiple sets of switch contacts that are installed on a common 2-position selector switch |
| 4130 | The NE Code restricts the color of insulated grounded circuit conductors (neutral conductors) to either ___ or ___ |
| 4131 | The 3-pole across-the-line electromagnetic motor-starter consists of a power ___ and an ___ relay |
| 4132 | In terms of control, only one of the two supply conductors to a single-phase AC motor has to be interrupted to stop the rotor ___ |
| 4133 | The use of maintain-type selector or pushbutton switches in a ladder diagram is normally limited to ___ control |
| 4134 | The overload-relay sensing elements for a 3-pole electromagnetic motor-starter must be installed in series, one each, with the three load terminals of the motor-starter ___ |
| 4135 | When identifying the load side of the first switching component in the next consecutive control line of a ladder diagram, the last wire number used must be increased by 1 ___ |
| 4136 | The ___ auxiliary contacts can also be used to ___ the 3-pole electromagnetic motor-starter of a second motor when two motors cannot be operated simultaneously |
| 4137 | The overload-relay sensing elements for an across-the-line motor-starter must be installed in series, one each, with the three load terminals of the motor-starter ___ |
| 4138 | The use of NO ___ -type selector or pushbutton switches in a control ladder diagram limits the control function to jog control |
| 4139 | ___ -rated integral-horsepower 3-pole electromagnetic motor-starters may have individual overload relays installed in each motor supply conductor |
| 4140 | When wire numbering a ladder diagram, the wire number is increased by ___ (how many) each time a switching component or device is crossed from line side to load side |
| 4141 | Either a 3-pole ___ motor-starter or a 3-pole ___ across-the-line motor-starter is commonly used to control a 3-phase AC motor |
| 4142 | When wire numbering a ladder diagram, sometimes two switching components — wired in series — will be paralleled with a single switching component, wire number across the devices wired in series first ___ |
| 4143 | An ___, electromagnetic motor-starter is commonly referred to as a full-voltage motor-starter because line voltage is applied to the motor terminals when the power contactor is closed |
| 4144 | Low- or no-voltage ___ is characteristic of 2-wire control |
| 4145 | NE Code regulations do not allow a switch or switching contacts to be installed in series with a grounded-circuit conductor ___ |
| 4146 | The _______________________ motor -starter is normally supplied (purchased) with a minimum of one set of NO auxiliary contacts (control contacts) that are activated with the power contacts ___ |
| 4147 | If the NC Stop PB switch is held open (depressed), activating (closing) the NO Start PB switch will not initiate the control function: the circuit is disabled ___ |
| 4148 | Low- or no-voltage protection is characteristic of ___ control |
| 4149 | Regarding grounded or ungrounded circuit conductors, individual wires in a control circuit must color-coded ___ |
| 4150 | Because the selector switch is normally located ___ from the motor-starter location, the 2-wire control circuit gets its name from the number of control-circuit |
| 4151 | Low- or no-voltage protection is characteristic of ___control |
| 4152 | In the basic 3-wire control circuit of a 3-phase AC motor using a 3-pole electromagnetic motor -starter, two individual PB switches are required; The two individual PB switches must be wired in ___ |
| 4153 | The power contactors of some 3-pole electromagnetic motor-starters are fitted with both a set of NO and a set of NC ___ contacts, which are both activated (___(___ and ___, ___, respectively) when the power contacts are closed |
| 4154 | A 3-pole across-the-line electromagnetic motor-starter is commonly referred to as a ___ starter because line voltage is applied to the motor terminals when the power contactor is closed |
| 4155 | When two or more sets of contacts are controlled (opened or closed) simultaneously by a 2-position, maintain-type selector switch, the switch is further described as a ___ switch |
| 4156 | When two motors are controlled with a 3-position selector switch, the control or run status of the two 3-phase AC motors are interlocked with the single switch ___ |
| 4157 | If both 3-phase AC motors are to be ON in the center position of the switch, then both sets of contacts should be at-rest in their ___ configuration |
| 4158 | When wire numbering a ladder diagram, sometimes two switching components wired in series will be paralleled with a single switching component: you should wire number across the components wired in series first ___ |
| 4159 | When NO auxiliary contacts on the power contactor of a motor-starter are used as the hold-in contacts of a control circuit, they must be wired in parallel with the ___ momentary PB switch |
| 4160 | ___ control of a 3-phase AC induction motor, by means of an electromagnetic motor-starter, uses momentary switches with either pushbutton- or selector-type operators |
| 4161 | The operation of a 3-phase AC motor normally involves separate overload protection (separate overload relay) with NC ___ control contacts located in the motor’s control circuit |
| 4162 | In troubleshooting a motor control circuit, ___ measurements, with the power on, are normally the preferred method |
| 4163 | Low- or no-voltage release is characteristic of ___ control |
| 4164 | The wires or conductors, in the control-circuit ladder diagram and the power or load wiring diagram of a motor circuit, are normally both color-coded and wire-numbered for proper ___ |
| 4165 | The mechanical closing of the power contacts in a 3-pole across-the-line electromagnetic motor-starter is accomplished by mechanical linkage and a concentrated ___ field |
| 4166 | Three-wire control gets its name from the number of control circuit conductors that must be extended to the switching location from the motor-starter location ___ |
| 4167 | In the basic 3-wire control circuit of a 3-phase AC induction motor that uses a full-voltage motor -starter, two individual PB switches are required ___ |
| 4168 | The use of ___ control in a ladder diagram requires a seal-in circuit |
| 4169 | In the basic 3-wire control circuit of a 3-phase AC motor using a 3-pole electromagnetic motor -starter, two individual PB switches are required ___ |
| 4170 | ___ control of a 3-phase AC induction motor, by means of an electromagnetic motor -starter, uses momentary switches with either pushbutton- or selector-type operators |
| 4171 | When two motors are controlled with a 3-position selector switch, the control or run status of the two motors are interlocked with the single switch ___ |
| 4172 | Although the ungrounded control-circuit conductors are normally black, red, or blue, the NE Code will allow these insulated conductors to be any color except ___, ___, or ___ |
| 4173 | NE Code regulations will not allow a switch or switching contacts to be installed in series with a grounded-circuit conductor ___ |
| 4174 | In troubleshooting a motor control circuit: To take an accurate ___ measurement, the component in question, such as the solenoid coil of one of the motor -starters |
| 4175 | When wire numbering a ladder diagram, the wire number is increased by 1 each time a switching component is crossed from line side to load side ___ |
| 4176 | The NE Code restricts the color of insulated grounded circuit conductors (neutral conductors) to ___ |
| 4177 | In troubleshooting a motor control circuit and taking resistance measurements of a motor-starter solenoid coil ___ |
| 4178 | The wires or conductors, in both the control-circuit ladder diagram and the power or load wiring diagram, are normally both color-coded and wire-numbered for proper ___ |
| 4179 | A single 3-position switch operator can control two or more motors if separate contact blocks are stack-mounted on the backside of the operator ___ |
| 4180 | The 3-pole ___ motor-starter is operated by hand at its point of location |
| 4181 | In terms of control, all the supply conductors to a 3-phase AC induction motor have to be interrupted ___ to stop the rotor |
| 4182 | The mechanical closing of the power contacts in a 3-phase full-voltage motor-starter is accomplished by mechanical linkage and a concentrated electromagnetic field ___ |
| 4183 | As a rule, 3-phase AC motors are not controlled (ON/OFF) solely with a ganged knife switch because of the need for separate ___ protection of the electric motor |
| 4184 | When the FHP motor starter is located remote from the motor location, the overload protection must be temperature compensated for the difference in ambient temperatures ____ |
| 4185 | The acronym ___ describes a fractional horsepower manual motor starter |
| 4186 | A pilot device is technically a 2-position switch whose ON/OFF status is controlled by a sensed medium ___ |
| 4187 | When HOA control of a single-phase AC induction motor is provided by means of a 3-position selector switch and a pilot device, In the ___ position, power is supplied to the motor through a pilot device |
| 4188 | Control of a motor operation is normally in the form of a ___ that either applies or removes electrical power from the motor supply circuit |
| 4189 | Before beginning a motor-circuit wiring exercise, you should familiarize yourself with the switches or other device components you are wiring to ensure the circuit conductors ___ |
| 4190 | When the integral-horsepower manual motor starter is installed in an enclosure to protect personnel from exposed live wire terminals within the motor circuit, pushbutton linkages are mounted in the ___ |
| 4191 | A motor starter is an assembly of switching contacts and a means of ___ overcurrent protection for the motor |
| 4192 | When a single-phase AC induction motor operates at the lower phase-to-ground voltage of 115 volts and the motor field leads are number-identified, the ___ |
| 4193 | Ungrounded-circuit conductors in a motor-supply circuit must be color-identified to distinguish them from grounded-circuit conductors ___ |
| 4194 | Any single-phase AC 230-volt induction motor will operate satisfactorily on any single-phase (2-wire) system voltage within a range of ___ to ___ volts |
| 4195 | The control of a FHP single-phase AC induction motor using a FHP motor-starter switch is the same in principle as the control of overhead lighting circuits using a ___ toggle switch |
| 4196 | In the drawing of the load circuit of a 3-phase AC (3-pole) integral-horsepower manual motor starter, The three line terminals are identified as ___, ___, and ___ |
| 4197 | Before power can be applied to the connected motor, the overload heater (element) must be installed in the FHP motor starter because ___ |
| 4198 | When the knife disconnecting means in the motor-controls wiring laboratory at a given lab station is closed, the lower phase-to-neutral supply voltage can be measured to any grounded metal enclosure ___ |
| 4199 | In some applications, such as hood exhaust fans over dwelling cooking equipment, the assembly, which is normally a fan and light combination, is ___ to the branch circuit, with the light |
| 4200 | Incorporating the solenoid contactor into the FHP motor starter circuit creates an additional control circuit ___ |
| 4201 | For a disconnecting means to be within line-of-sight, the NE Code requires the switch to be located no more than ___ from, and within an unobstructed view from the motor or the equipment it serves |
| 4202 | Because the thermal protector is wired in series with the ___ supply terminal of the motor [again any type of switching device cannot be installed in series with an intentionally ___ circuit or component conductor] |
| 4203 | The NE Code requires a disconnecting means to be readily accessible and within line-of-sight of the motor ___ |
| 4204 | If the single-phase AC induction motor is a part of either ___ or ___ load equipment, it may be supplied through a flexible cord and plug from a receptacle outlet |
| 4205 | In other applications, such as a portable saw or drill, the motor may be flexible-cord-supplied from a receptacle outlet and the toggle or other selector switch mounted in the ___ of the motor-driven equipment |
| 4206 | Any single-phase AC 115-volt induction motor will operate satisfactorily on any system voltage within a range of ___ to ___ volts |
| 4207 | When HOA control of a single-phase AC induction motor is provided by means of a 3-position selector switch and a pilot device, In the ___ position |
| 4208 | A 3-phase AC induction motor is rated for operation at either 115 or 230 volts. If the respective phase windings are wired in parallel, the motor operates at ___ volts |
| 4209 | When the knife disconnecting means ___ |
| 4210 | A 3-phase AC induction motor is rated for operation at either 230 or 460 volts: If the respective phase windings are wired in ___, the motor should operate at 460 volts |
| 4211 | Resetting a tripped integral-horsepower manual motor starter requires pressing the Start/Stop pushbutton switch hard into the ___ position |
| 4212 | The integral-horsepower manual motor-starter is required to be ___ |
| 4213 | A 3-phase AC induction motor is rated for operation at either 230 or 460 volts. If the respective phase windings are wired in parallel, the motor operates at ___ volts |
| 4214 | A single-phase AC induction motor controlled with a toggle or selector switch can be internally ___ against sustained mechanical overload |
| 4215 | An integral-horsepower 3-phase AC induction motor must be provided with full overcurrent protection ___ |
| 4216 | When a single-phase AC induction motor operates at the lower phase-to-ground voltage of 115 volts and the motor field leads are color-identified, the intended ___ field lead will be black |
| 4217 | If a sustained motor-overload should occur, the higher-value motor overload current will cause the ___ to melt or the ___ to bend to trip the latch and release the switch contacts |
| 4218 | A 3-phase AC induction motor is rated for operation at either 115 or 230 volts ___ |
| 4219 | Resetting of a tripped 3-phase AC integral-horsepower manual motor starter due to motor mechanical overload, requires the ___ |
| 4220 | When a single-phase AC induction motor operates at the lower phase-to-ground voltage of 115 volts and the motor field leads are number-identified, the ___ circuit conductor should be connected to motor terminal T1 |
| 4221 | A 3-phase manual motor starter uses a(n) ___ linkage to close all three power (load) contacts simultaneously |
| 4222 | The control of the motor is normally used to control the ___ of the connected (driven) equipment |
| 4223 | Most selector-switch contact blocks provide two sets of switching contacts ___ |
| 4224 | When pilot devices are required in automated motor-circuit control circuits, ___ are normally used to sense or regulate the passage of time or for time-delay of sequential events |
| 4225 | When a single-phase AC induction motor operates at the lower phase-to-ground voltage of 115 volts and the motor field leads are color-identified, the ___ |
| 4226 | Incorporating the solenoid contactor into the FHP motor-starter circuit creates an additional circuit ___ |
| 4227 | As used with selector switches, the term ___ indicates that the load current is interrupted at two contact points within the switch instead of one |
| 4228 | AC induction motors are available in either single-phase or polyphase manufacture and wiring configurations ___ |
| 4229 | When the integral-horsepower manual motor starter is installed in an enclosure to protect personnel from exposed live wire terminals within the motor circuit, pushbutton linkages are mounted in the enclosure ___ |
| 4230 | For troubleshooting, the ___ position can be used as a pilot device manual override |
| 4231 | In response to electric motor overload, the overload protection device either opens the switching contacts directly, which would be a ___ motor starter |
| 4232 | A 3-phase AC induction motor is rated for operation at either 230 or 460 volts ___ |
| 4233 | A ___ is an assembly of switching contacts and a means of overload-overcurrent protection for the motor |
| 4234 | When HOA control of a single-phase AC induction motor is provided by means of a 3-position selector switch and a pilot device, the center position of the switch is normally used as the ___ position |
| 4235 | Single-phase AC induction motors rated at 200 volts are often used on 208-volt distribution systems to compensate these lower-voltage systems for ___ |
| 4236 | In the drawing of the load circuit of a 3-phase AC integral-horsepower manual motor starter, the ___ |
| 4237 | When HOA control of a single-phase AC induction motor is provided by means of a 3-position selector switch and a pilot device; In the ___ position, power is applied directly to the motor |
| 4238 | When a FHP motor operates at 120 volts, the toggle switch must be located in (wired in series with) the ___ supply conductor to the motor |
| 4239 | With 3-phase AC manual motor starter, when power is applied to the motor supply / control circuit by the closing of the knife switch disconnect in the motor-controls wiring laboratory, ___ VAC |
| 4240 | As a last check, when the wiring of the motor circuit is complete, you should make sure that white wires are interconnected to only white wires before energizing the circuit ___ |
| 4241 | When pilot devices are required in automated motor control circuits, ___ switches are normally used to sense or regulate temperature |
| 4242 | Any 3-phase AC 115-volt induction motor will operate satisfactorily on any 3-phase electrical-power distribution system voltage operating within a range of ___ to ___ volts |
| 4243 | Before starting any actual wiring of a motor circuit, you should verify the absence of voltage (no voltage) on the ___ side of the disconnecting means to ensure you are working on a wiring lab that is not energized |
| 4244 | As used with selector switches, the term ___ indicates that the load current is interrupted at a single contact point within the switch |
| 4245 | To interrupt the load current conveyed to a single-phase AC, 2-wire induction motor, either or both supply conductors can be opened ___ |
| 4246 | If the overload relay is ___, the toggle switch latches in when the switch is flipped or snapped ON |
| 4247 | When pilot devices are required in automated motor-circuit control circuits, ___ switches are normally used to sense or regulate pressure or vacuum |
| 4248 | When used in conjunction with a FHP motor starter for direct control of a single-phase AC induction motor, the selector switch or pilot device voltage rating must at least equal the motor’s voltage rating ___ |
| 4249 | When the FHP motor-starter is located remote from the motor location, the overload protection must be temperature ___ for the difference in ambient temperatures |
| 4250 | In the drawing of the load circuit of a 3-phase AC (3-pole) integral-horsepower manual motor starter ___ |
| 4251 | When HOA control of a single-phase AC induction motor is provided by means of a 3-position selector switch and a pilot device. For troubleshooting, the manual position can be used as manual ___ of the pilot device |
| 4252 | In terms of switching, a 3-phase AC integral-horsepower manual motor starter is required to be ___, which means that when switched ON into a sustained overload condition |
| 4253 | In a wiring diagram, a ___ is the standard symbol for a motor |
| 4254 | The single-phase AC induction motor may be ___; which means it is permanently wired from or connected to the branch-circuit supply at the toggle switch |
| 4255 | To protect the operator or other persons from exposure to live wire terminals when operating the switch of a manual motor starter, the motor starter must be installed in a ___ enclosure |
| 4256 | When used to control the ON/OFF status of a fan or other motor application of a fractional-horsepower AC induction motor, the set of contacts which are ___ when the selector switch |
| 4257 | To protect the operator or other persons from exposure to ___ wire terminals when operating the switch of a motor-starter, the motor starter must be installed in a deadfront enclosure |
| 4258 | When HOA control of a single-phase AC induction motor is provided by means of a 3-position selector switch and a pilot device ___ |
| 4259 | Both the supply and return circuit conductors of an AC circuit must be contained / installed in the same pipe or other raceway or pass through a common hole in a metal enclosure to avoid the heating effect of ___ |
| 4260 | When pilot devices are required in automated motor-circuit control circuits, ___ switches are normally used to sense or regulate position or motion |
| 4261 | If the control circuit is not referenced to ___, then measuring from the control transformer common return terminal is the only means available for taking these voltage readings |
| 4262 | Before taking actual voltage readings within the load or control circuit, ___ law should be used to determine if when the voltage is measured, it is the voltage expected in the circuit at the point of measure |
| 4263 | If supply voltage is not available on initial voltage checks, then checking ________________ of both power-circuit and control-circuit fuses of a motor circuit is a good place to start in effective troubleshooting ___ |
| 4264 | Operating temperature of process equipment or the ambient air in a room or other enclosed area can be sensed by the use of ___ switches |
| 4265 | There are three principal types of fuses: Current-limiting, instant, and time-delay ___ |
| 4266 | In multioutlet branch circuit; Both loads, because they are connected in parallel and in series with the limit and load control of the circuit current (the OCPD and the control switch), operate at the same AC source ___ |
| 4267 | For the testing of control fuses, the control-circuit voltage can be measured by either the ___ -to- ___ or ___ -to- ___ method |
| 4268 | In manufacturing or other types of process control ___ |
| 4269 | If the manual switch is the only means of directional or ON/OFF control, this is normally described as ___, since the motor load current flows through the switch |
| 4270 | A phenomenon referred to as “___†occurs when reading the pointer against the selected scale on an analog meter: |
| 4271 | If the overhead lighting is controlled from a single location, the SPST toggle switch must be wired in ___, ahead of the ___ lighting load, in the ___ supply of the branch circuit |
| 4272 | Analog scales may be ___ or ___ |
| 4273 | A ___ is a meter that can measure two or more electrical properties and displays the measured properties as numerical values |
| 4274 | Where the total of the single-phase lighting and receptacle loads is equal to or greater than the total air-conditioning and other motor load, the service is normally rated as ___ volt, 3-phase AC, and 4-wire |
| 4275 | Too often just any available fuse is used to replace a blown fuse ___ |
| 4276 | When the fuse, circuit breaker, or control switch is ___, the load voltage and the power supply voltage are one and the same |
| 4277 | The secondary control circuit of the separately derived system cannot be referenced to the equipment-grounding system, unless the electrical-power distribution system within the building ___ |
| 4278 | The supply voltage will divide in a series circuit as voltage drops across the individual resistive loads directly-proportional to the individual resistance values ___ |
| 4279 | The third step of divide and conquer in effective troubleshooting requires ___, ___, or ___ the various parts or sections of a very complicated control circuit and breaking them down into simpler sections of control |
| 4280 | In an overhead or general-lighting circuit of a building or other structure, the ___ is the continuous branch-circuit power supply from the panel or other load center |
| 4281 | The more common way of checking for an open fuse in an electrical power distribution system is with a ___ |
| 4282 | Circuit breakers normally trip open eventually under either continual or extended ___ overcurrent, or instantly when a ___ overcurrent condition occurs in the protected circuit |
| 4283 | The four principalprinciple quantities of measure in an electrical circuit are ___, ___, ___, and ___ |
| 4284 | When the connected load is shorted, the only resistance left in the circuit is the super-low ___ |
| 4285 | Most control voltages, especially those rated at 120 volts, are derived as a separate electrical-power control system from the higher-voltage plant electrical-power distribution system through a control ___ |
| 4286 | A feeder circuit, which interconnects two load centers, has overcurrent protection installed at both ends ___ |
| 4287 | Switches or other contact devices, which do not consume power but rather direct the flow of electrical current to the power consuming devices, are always placed in ___ with the lights or solenoids they control |
| 4288 | If the CB responded to clear ___ overcurrent in the circuit, the high-magnitude overcurrent probably caused internal damage or at least caused an error in the calibration of the CB |
| 4289 | Effective ___ starts with an analysis of the problem |
| 4290 | On a 3-phase AC, 4-wire, 208Y/120-volt building or other-structure electrical-power distribution system, any electrical utilization equipment supplied by any two ungrounded busses ___ |
| 4291 | For control circuits, taking current readings is the number one method for determining the operating status of the circuit or component ___ |
| 4292 | In some instances the control power may not be derived from a transformer in the motor control center (cabinet) ___ |
| 4293 | For any parallel circuit: Although some of the circuit current must take every available parallel path presented, the majority of circuit current will always take the path of ___ resistance |
| 4294 | Because the measured value is displayed as a numerical (digital) value on digital multimeters, errors can occur when reading a digital display if the displayed ___, ___, and/or ___ are not properly applied |
| 4295 | For any series circuit, The total circuit wattage is equal to the ___ of all the individual series load-resistance wattages |
| 4296 | Instead of a voltage range switch, most DMMs are ___, which means that once a measuring function is selected, the meter automatically selects the best meter range for taking the measurement |
| 4297 | Circuit breakers normally trip open under either continual or extended ____________ -overcurrent or instantly when a ___ overcurrent condition occurs in the protected circuit |
| 4298 | For single-pole circuit breakers, line voltage should be read to any other breaker terminal that is not on the ___ in the load center |
| 4299 | With voltage available in the panel, on a 2-pole or a 3-pole CB, voltage measured with a meter between any two terminals on the load side of the CB should read ___ voltage |
| 4300 | A ___ movement / meter or ___ is a meter movement, consisting of a permanent magnet, a coil of wire, and a free-moving rotary dial |
| 4301 | The supply side (line side) of a CB, which is normally clip-mounted on its underside to one or more stabs on the panel ungrounded power bus, is normally ___ for voltage measurements |
| 4302 | The use or sensing of time is very diversified: Equipment can also be controlled by a real ___ where it is turned on at a particular time of day or turned off at a particular time of day |
| 4303 | The scales on an analog multimeter are normally divided using ___ divisions, ___ divisions, and ___ |
| 4304 | Circuit breakers can be considered as ___ overcurrent protection devices |
| 4305 | Most problems found in the circuit must be determined with the ___ on |
| 4306 | Because of the main bonding jumper connection between the grounded, common-return, neutral conductor and the grounding-electrode/equipment-grounding system of a 3-phase AC, 4-wire, 208Y/120-volt building ___ |
| 4307 | The acronym VOM stands for ___ |
| 4308 | ___ volts should be measured with the other test lead to the line side of the secondary control fuse |
| 4309 | The main advantages of a digital multimeter over an analog multimeter is the ability of a digital meter to ___ measurements, the ease in ___ the displayed values, and built-in ___ |
| 4310 | For any parallel circuit: The circuit current divides ___ -proportional to the value resistances found in the individual parallel branches |
| 4311 | In manufacturing or other types of process control; The vertical buses of the control or signal circuit supplying several rungs used to create the ladder diagram creates a multioutlet branch circuit ___ |
| 4312 | To check the continuity of a fuse with the power on, two methods are available for taking voltage readings; Which of the following is (are) true ___ |
| 4313 | For any series circuit, According to Kirchhoff’s Voltage Law, the ___ of the individual-load voltage drops will always equal the supply voltage |
| 4314 | If a 10- , a 20- , and a 30- resistor are wired in parallel across a 120-volt AC source, the total circuit resistance should equal ___ |
| 4315 | When electrical-power distribution and process control circuits operate in reference to earth ground, the supply is the ___ circuit conductor and the return is the ___ circuit conductor |
| 4316 | Kirchhoff’s voltage and current laws also come into play in effective troubleshooting ___ |
| 4317 | The use or sensing of time is very diversified; equipment can also be controlled by a ___ where it is turned on at a particular time of day or turned off at a particular time of day |
| 4318 | The waveforms associated with voltages are normally sinusoidal. Most voltmeters, whether analog or digital, can only display ___ AC voltage values |
| 4319 | An analog multimeter is normally stored with the function/range switch set to the ___ position |
| 4320 | For any series circuit; A voltmeter offers high ___ to the flow of current; however, a minute amount of current ― enough to drive the meter, but not enough to energize the connected load does flow |
| 4321 | The total circuit current depends on the resistance of both loads ___ |
| 4322 | The two principle applications of series-parallel combination circuits are the electrical-power ___ of a building or other structure, and manufacturing or other types of ___ |
| 4323 | All electrical circuits can be reduced to a simple series circuit in terms of calculation ___ |
| 4324 | To check the continuity of a fuse with the power on, two methods are available for taking voltage readings. Which of the following applies ___ |
| 4325 | Most process or other utilization equipment depends on other factors that either controls the equipment or the equipment controls them ___ |
| 4326 | The use or sensing of time is very diversified: Equipment can be ___, meaning there is an intended time delay between when a switch is closed and when a motor or other piece of equipment actually starts |
| 4327 | If zero volts is measured on both the line and load sides of the control fuse, the fuse, as before with the power-fuse voltage measurements, is not necessarily open ___ |
| 4328 | In multioutlet branch circuit; The entire load current will pass through the OCPD and switch and divide at the ___ or ___ where the loads are connected in parallel |
| 4329 | For control circuits, taking ___ readings is the number one method for determining the operating status of the circuit or component |
| 4330 | When switches or auxiliary contacts are wired in ___ each other in adjacent rungs of the ladder diagram that are made common to a single rung, an OR function (gate) is formed |
| 4331 | Operating temperature of process equipment or the ambient air in a room or other enclosed area can be sensed by the use of ___ or ___ switches |
| 4332 | The electrical-power distribution system within a building or other structure has three major circuit classifications are ___ |
| 4333 | The standard single-phase AC service is normally rated 120/240-volt, 3-wire; The two ungrounded service conductors ___ be fused |
| 4334 | The basic steps in the effective design and troubleshooting of either a load or a control circuit include ___ |
| 4335 | When 2-position, ___ switches are used; they must be wired in series with only the pair of traveler conductors, which interconnect the two ___ switches |
| 4336 | Within the electrical-power distribution system of a building or other structure, the AC source and the fused knife switch or circuit breaker would be located in the ___ equipment load center |
| 4337 | There are three principal types of fuses ___ |
| 4338 | In the control section ladder diagram, all the parallel rungs ___ |
| 4339 | For any series circuit: The, the circuit voltage can always be measured at the power source (point of power supply); assuming power is available to the power supply ___ |
| 4340 | The overcurrent protection for both the incoming service and any feeder distribution circuits is split with short-circuit ground-fault protection at their ___ end, and overload-overcurrent protection at their ___ end |
| 4341 | The total circuit current depends on the resistance of both loads. In parallel; Operating at the same voltage the load with the least resistance will draw the ___ of the circuit current |
| 4342 | In combination circuits, voltage, resistance, and current rules are obeyed according to the type of circuit seen; In a ___ circuit |
| 4343 | Electrical test instruments may be either ___ or ___ |
| 4344 | According to the electrical needs of the occupant of a building or other structure, the incoming service may be rated as either single-phase or 3-phase AC ___ |
| 4345 | Except in fundamental circuits, where the behavior of voltage, current, resistance, and wattage is investigated, series circuits which contain more than one utilization-equipment load are not common ___ |
| 4346 | In the 480Y/277-volt, 3-phase AC, 4-wire building or other-structure electrical-power distribution systems, the 3-phase line voltage is ___ volts; the lower single-phase neutral voltage is ___ volts |
| 4347 | There are three principal types of fuses: ___ fuses have a rejection feature on one blade or on one end cap of a barrel-type (ferrule-type) fuse which fits a rejection type fuseholder |
| 4348 | In this case, if there is no voltage present before the fuse, the circuit breaker (CB) in the panel may be turned off or tripped (out or open) ___ |
| 4349 | As the name implies, in a parallel circuit all the utilization-equipment loads are connected in ___ with each other, and then the ___ -array is connected across a ___ power supply |
| 4350 | The majority of the time, a(n) ___ in one part of the load or control circuit creates a(n) ____________ in another part of the circuit ― normally the control fuse and the failure appears to be a(n) ____________ circuit |
| 4351 | For any series circuit, Circuit voltage ___ as “voltage drops†according to the individual resistances |
| 4352 | ___ switches are pilot devices that are often used to sense a change in pressure |
| 4353 | For any series circuit, The total circuit resistance is equal to the ________________ of all the individual resistance loads connected in series |
| 4354 | A series circuit forms a single ___ path between the supply and return terminals of a given power supply |
| 4355 | If the fuse in question is contained in a fuseholder that is remote from the disconnecting means, the disconnect must still be ___, and one end of the fuse should be ___ of the fuseholder for the continuity reading |
| 4356 | For any series circuit; If there is a break in the circuit, the voltage can still be measured at the point of ___, but the connected-load voltage reading will move from the ___ to the point of ___ or the ___ in the circuit |
| 4357 | Voltage measured from the load side or load terminal of two single-pole CBs located side-by-side in a single column should read ___ voltage |
| 4358 | Each rung in the ladder is in ___ with every other rung in the same ladder. In other words, all the control lines are in ___ from (across) a common control-voltage source |
| 4359 | The overcurrent protection device(s) mustprotect the circuit conductors, the electrical-power distribution equipment, and the connected electrical utilization equipment loads they all supply at the correct ___ |
| 4360 | Since the resistance of dirt, oxidation, or other contaminates at the contact points of the two test probes of the ohmmeter is also being measured in this test; the actual ohmic reading does not have any ___ value |
| 4361 | Within the electrical-power distribution system of a building or other structure, multioutlet branch circuits are normally used to supply mutiple ___ or ___ receptacle outlets in a given room or manufacturing area |
| 4362 | In manufacturing or other types of process control, the AC source and the fused knife switch or circuit breaker would be located in the ___ center |
| 4363 | ___ or ___ switches are pilot devices that are often used to sense a change in pressure |
| 4364 | The two common failures of motor control and motor load circuits are ___ and ___, and of the two: the ___ is the more common |
| 4365 | When the load of a parallel circuit consists of two or more individual loads, the supply circuit conductor forms a common bus to which one side (supply side) of all the parallel loads is connected ___ |
| 4366 | For any series circuit: Circuit ___ is held constant according to the values of total resistance and the magnitude of the supply voltage |
| 4367 | The use or sensing of time is very diversified: A ___ is a device that is designed to switch closed contacts open or to switch open contacts closed |
| 4368 | With one test lead of the voltmeter referenced to the metal enclosure of the disconnecting means and the other test lead referenced to the line side of either the line 1, line 2, or line 3 fuse, a measure of ___ volts |
| 4369 | There are three principal types of fuses: current-limiting, instant (non-time delay), and time-delay ___ |
| 4370 | Each type of fuse has different voltage and current ratings ___ |
| 4371 | Because high-bay lighting normally operates at the higher single-phase AC voltage of 277 volts, a 3-phase AC, 480-volt D-primary, 208Y/120-volt secondary power transformer is used to ___ |
| 4372 | To check the continuity of a fuse by an ohmic reading, the disconnecting means on the line side (ahead-of) of the fuse must be opened to ensure the circuit is ___, and to open any ___ paths to the fuse that may be present |
| 4373 | The display on most DMMs displays the information or measured values in a ___ a solid silver rectangular plane |
| 4374 | As in single-phase panels: To, to balance the load current of the 120-volt, 2-wire neutral loads between the three ungrounded busses in a 3-phase AC, 4-wire, 208Y/120-volt building ___ |
| 4375 | For current to flow in any electrical circuit there has to be a ___ from the power supply to the connected load, and back to the power supply |
| 4376 | The grounded-return circuit conductor is a current-carrying conductor in an electrical circuit referenced to earth ground ___ |
| 4377 | ___ or ___ overcurrent protection (short-circuit, ground-fault, and overload protection) is provided for the branch circuits with overcurrent protection located only at its supply end |
| 4378 | The use or sensing of time is very diversified ___ |
| 4379 | The location of the short normally has to be located by ___ the affected circuit in parts and taking ___ checks of different parts of the circuit |
| 4380 | Short circuits occur when the load has been ___, ___, or ___ with or by a conductive material of low resistance value |
| 4381 | If the letters OL appear on the digital display when a measure is being attempted, this indicates the measure is of higher value than the digital multimeter can read the meter is ___ |
| 4382 | When the load of a parallel circuit consists of two or more individual loads, the supply circuit conductor forms a ___ to which one side (supply side) of all the parallel loads is connected |
| 4383 | ___ and ___ mentally breakdown the control circuit into sections or parts |
| 4384 | ___ occur in an electrical circuit when the load has been shunted, paralleled, or bypassed with or by a conductive material of low resistance value |
| 4385 | If the building electrical-power distribution system operates in reference to ground ___ |
| 4386 | Single-pole circuit breakers will not be found in 3-wire, delta-supplied power panels that are not referenced to ground ___ |
| 4387 | For any series circuit; The circuit voltage can always be measured at the power source (point of power supply); assuming power is available to the power supply ___ |
| 4388 | When two or more utilization equipment loads are supplied from a common circuit, they are wired in ___ |
| 4389 | For any parallel circuit: The ___ of the individual-branch load currents must equal the total circuit current |
| 4390 | Instead of an arrowhead, the wiper is drawn pointing into and touching the arc in the ___ symbol in line or ladder diagrams |
| 4391 | When a selector switch is used as a momentary switch, it is normally noted on the ladder diagram as ___ |
| 4392 | The acronym used to identify the type of voltage solenoid or meter is normally written within the circle between the wire terminals: mA in the circle indicates a(n) ___ |
| 4393 | If the switch is drawn in ___ configuration, one end of the moveable linkage or bar of the switch is hinged to one of the two wire terminals |
| 4394 | You should take the ___ home |
| 4395 | A short straight line drawn over two small open circles indicates some type of ___ |
| 4396 | The ___ for the motor symbol is used in both the control or signal section of a schematic (ladder diagram) and the power or load section of the same schematic |
| 4397 | When drawing a 2-position selector switch, the arrowhead should point to the ___ selected position |
| 4398 | Both a zigzag line and double shepherd hooks series-wired on the load side of the latch-type switch symbol (an arc drawn between two straight lines) indicate a ___ |
| 4399 | The chassis common, which uses a ___ symbol, is not necessarily ___ |
| 4400 | A lazy Z drawn across the parallel lines indicates a ___ iron-core reactor |
| 4401 | A ___ switch is a switch in which one or more metal blades pivoted at one end, serves as the moving parts for the opening or closing of the circuit by the moving blade(s) either disengaging or engaging contact clips |
| 4402 | A ___ switch, commonly referred to as a wall switch, is a two-position snap switch normally used to control overhead lighting or fractional horsepower motors |
| 4403 | A ___ diagram is a drawing similar to a pictorial drawing, except the components of the circuit are represented by rectangles or circles |
| 4404 | With the exception of ___ coils, the symbol of a reactor coil consists of a number of ___ or ___ drawn in a straight line |
| 4405 | Addressed by the acronym SPST, a ___ , ___ switch can be of either single-break or double-break configuration |
| 4406 | Instead of just a button, the head of the mushroom-head or palm-head operator Is flared open or out similar to a mushroom (or open umbrella), so the button can be accessed and actuated from about ___ |
| 4407 | A good point to remember is that any switch/relay-logic symbol is created with the thought of conveying as much information as possible about the device or circuit component it represents ___ |
| 4408 | A single ___ drawn as perched over two open circles, one at either end of the arch, normally indicates some type of circuit interrupters, such as a motor-circuit interrupter or a circuit breaker |
| 4409 | The two side rails of the ladder are referred to as the control-power ___ |
| 4410 | In line or ladder diagrams, straight lines are used to indicate circuit conductors ___ |
| 4411 | Meter shunts, used to pass the majority of load current in parallel to the meter movement, are also represented by the resistance ___ |
| 4412 | The same bolt of lightning symbol used to symbolize the current-actuated coil, also is used as the sensing element in the symbol of an ___ circuit breaker and as the magnetic sensor in a motor-starter ___ |
| 4413 | Boxes, some square and others rectangular, normally symbolize some type of ___ control, whether limiting the current as in a power fuse or a resistor, or increasing the ___ as in some type of amplifier |
| 4414 | An arc drawn between the two straight lines symbolizes a ___, which contains a latch-type switch but no means of sensing or responding to an overcurrent condition in the motor circuit |
| 4415 | In the elementary diagram, ___, instead of a picture or likeness, is used for the circuit components |
| 4416 | The interconnecting broken line in the symbol of a rotary switch, which represents a mechanical linkage, is a type of switch ___ where one set of contacts is opened the second set is closed |
| 4417 | A ___ disconnect is normally connected in the power circuit just ahead of the electric motor at the motor location to provide a safety disconnect when the motor, needing service |
| 4418 | The acronym used to identify the type of voltage solenoid or meter is normally written within the circle between the wire terminals: VAR in the circle indicates a(n) ___ |
| 4419 | Control circuits are normally referenced to the distribution equipment-grounding system ___ |
| 4420 | When used to adjust the supply voltage, the variable resistor is referred to as a ___ characteristically a 3-terminal device |
| 4421 | Normally, the actuator of a pushbutton (PB) switch, whether momentary- or maintained-type, is a vertical line without the ___ |
| 4422 | ___ are like a second language in the electrical field. The way the symbols is drawn is intended to relay its function |
| 4423 | In the control section of the ladder diagram; The grounded circuit conductor is identified as wire # ___ |
| 4424 | ___ are technically electromechanical linear-motion actuators |
| 4425 | In addition to color-coding, the line conductors in the power or load circuit are identified with the capital letter ___ and the representative phase conductor to which they are connected |
| 4426 | When addressing the switching contacts of a relay, contactor, or motor-starter, the parallel lines drawn perpendicular to the wire terminal lines symbolize a set of ___ contacts: |
| 4427 | Because most switches can be maintained opened or closed, the “___†concept was developed |
| 4428 | A PB stack switch, which may contain several sets of switching contacts that can all be either NO or NC, or a combination to where some are NO and others are NC, is normally used in pushbutton ___ |
| 4429 | In line or ladder diagrams, ___ are used to indicate circuit conductors |
| 4430 | The prints or drawings of electrical-power distribution circuits within a building or other structure, which are drawn over the basic outline of the architectural floor plan ___ |
| 4431 | When two paralleled lines are drawn parallel to the arches in the winding(s) symbol, this indicates an ___ core in the autotransformer, DC motor field, reactor, or transformer |
| 4432 | ___ mccontacts, whether open or closed can be contained in a control relay, an industrial relay, a power contactor, or a motor starter |
| 4433 | ___ lines are used to indicate the circuit conductors which interconnect the control devices in switch/relay-logic |
| 4434 | Two reactor coil winding symbols, drawn in parallel without any electrical or mechanical connection, represent an ___ or ___ transformer |
| 4435 | The winding symbol of a reactor is also used to represent transformers. The single winding drawn with one or more taps is the symbol for a(n) ___ |
| 4436 | The acronym used to identify the type of voltage solenoid or meter is normally written within the circle between the wire terminals: WH in the circle indicates a(n) ___ |
| 4437 | ___ are like a second language in the electrical field |
| 4438 | If the switch is drawn in ___ configuration, the line and load wire terminals of the switch assembly are connected one each to stationary contact pads within the switch |
| 4439 | What is drawn on top of the square box is used to symbolize the type of annunciator. A horn, siren, or speaker is symbolized by the ___ |
| 4440 | As used with the acronym DPST, ___-___, ___-___ indicates two single-pole single-throw switches are ganged on a common switch operator |
| 4441 | The basic ___ circuit can be represented with a box drawing of a power source, connecting lines as wires, and another box drawing of a connected load |
| 4442 | Intended to provide a fast and easy understanding of the connections and use of the components, ___ diagrams show the logic of an electrical circuit or system using standard symbols |
| 4443 | The ladder diagram is actually an elementary diagram that can be drawn as two principal sections ___ |
| 4444 | What is drawn on top of the square box is used to symbolize the type of annunciator. A ___ symbolizes a buzzer or some type of clapper |
| 4445 | With the exception of the vertical busses wire #1 and #2, you should increase the wire number by ___ each time a switching component is crossed from line side to load side when wire-numbering a ladder diagram |
| 4446 | The typical ___ line, which is the resistance symbol in electronic drawings, normally is not used in control drawings |
| 4447 | A(n) ___ circle is representative of some type of screw or lug terminal |
| 4448 | A circle represents a ___ coil with wire-terminal circles or short wire leads extended on either side along the horizontal centerline of the circle |
| 4449 | Electrical drawings have two main divisions: ___ and ___ |
| 4450 | The power supply to the stator assembly of the AC motor is symbolized by supply lines drawn on the ___ of the circle symbol |
| 4451 | ___ resistors are shown in line or ladder diagrams as a rectangular box |
| 4452 | The rheostat is used to limit current in a circuit ___ |
| 4453 | The schematic, also referred to as a ___ or ___ diagram, outlines the circuit components in their electrical sequence without regard or reference as to their physical location |
| 4454 | The indicating-light circle, which is normally drawn to a smaller scale compared to a ___ symbol in a ladder diagram, is further identified with four short ___ drawn at a diagonal of outside the circle |
| 4455 | When the fused vertical bus contains control contacts, as is typical in a control circuit which contains a safety circuit, you should add ___ to the wire number of the last control line number |
| 4456 | In the AC motor, the rotating member is referred to as the ___ |
| 4457 | All circuit breakers, whether magnetic, thermal or thermal/magnetic, are required by the NE Code to be ___ indicating that if the circuit breaker is switched on and into a fault overcurrent circuit condition |
| 4458 | In the rotary switch symbol, a break-before-make configuration is noted (with the ___ operator) as ___ or ___ contacts |
| 4459 | ___ switches are normally drawn as one set of NO switching contacts |
| 4460 | In an elementary diagram of switched lighting in the electrical-power distribution system of a building, which is normally referenced to earth ground ___ |
| 4461 | Three supply lines identify a ___ -phase AC, 3-wire induction motor |
| 4462 | Drawn open or apart, the parallel lines in the symbol for instant-operating contacts indicates a set of ___ contacts |
| 4463 | When used as the supply-protection of a solid-state drive the more common application in electric-motor supply circuits, the instantaneous-trip circuit breaker is normally referred to as an MCP a ___ |
| 4464 | Addressed by the acronym SPDT, a ___, ___ switch can also be either single-break or double-break in configuration |
| 4465 | The fused side of the ungrounded circuit conductor, extended from the load side of the control fuse, is identified as wire # ___ |
| 4466 | The acronym ___ indicates the normally-closed at-rest status of the control contacts |
| 4467 | ___ switches may be drawn as one set of switching contacts that are either NO or NC |
| 4468 | A letter inside the indicating-light circle in a ladder diagram is used to indicate the color of the switch: the capital letter ___ represents amber (yellow), ___ represents green, ___ represents red, and ___ represents blue |
| 4469 | When the typical pushbutton switch, mounted through the front cover of the control panel with the exposed energized contact block terminals contained inside the control panel ___ |
| 4470 | The color-coding of the circuit conductors is normally not enough to identify the conductors that must be extended to a given switch or control component ladder diagram ___ |
| 4471 | On the electrical plans, a given circuit is represented as a ___ drawing to reduce the clutter of too many lines or symbols on a given electrical print |
| 4472 | A single tap, which is connected to the reactor coil winding symbol with an arrowhead, represents a ___ -___ autotransformer |
| 4473 | Control-circuit switches are of two principal types: Either ___ or ___ |
| 4474 | The complexity of electrical distribution and control circuits requires the engineer, electrician, or technician to learn a second language: the shorthand language of same term throughout ___ |
| 4475 | The ___ offers an inversed-timed response to motor starting and running overload overcurrents |
| 4476 | Normally, selector switches are used with a ___ -type control rung (ladder-diagram control line), and pushbutton switches are normally used with a ___ -type control rung |
| 4477 | Normally, a single-gang knife switch or other single-gang disconnecting means indicates a single-phase AC motor supply, although either a single or 3-phase, AC supply is ___ |
| 4478 | The midpoint of the two series-connected sets of control contacts in the first control line should be labeled with the next ___ consecutive number (___ to ___) |
| 4479 | On the electrical plans instead of color coding, the number of supply and return circuit conductors between the switch and the light, and between the switch and the AC source, the type of ___ |
| 4480 | The term ___ indicates a state of being whole, unbroken or interrupted as ___ through part of a circuit, or ___ through a device winding |
| 4481 | ___ circuits are electrical circuits within an automated system used to stop, start, and/or regulate flow of gas, liquid, and/or electricity in a specified manner or logical sequence |
| 4482 | When a solenoid piping valve is noted with a number-dash-letter, the number indicates the number of valve ___ |
| 4483 | To facilitate the quick change of the electric motors, the supply conductors will often be cord and receptacle connected ___ |
| 4484 | Two basic uses of precision ceramic core wire-wound variable resistors as adjustable autotransformers are ___ divide and ___ control |
| 4485 | The winding symbol of a reactor is also used to represent transformers ___ |
| 4486 | The broken line interconnecting the three poles of the disconnect operator (handle), normally indicates a ___ all switches |
| 4487 | Drawn with railroad tracks, the symbol of a tap-connected reactor coil represents an ___-___ autotransformer |
| 4488 | The acronym used to identify the type of voltage solenoid or meter is normally written within the circle between the wire terminals: AH in the circle indicates a(n) ___ |
| 4489 | A ___ switch is a type of lighting toggle switch designed for either recessed installation in a box or for surface mounting |
| 4490 | Two or more ___ drawn in series normally indicates some type of inductive coil or winding |
| 4491 | A ___ contains the switch but no means of sensing or responding to an overcurrent condition in the motor circuit — it is not an overcurrent protection device, but rather just a ___-___ circuit switch |
| 4492 | Also referred to as a coil and plunger, a ___ is an electromagnet consisting of a hollow coil or spool, which contains a movable iron core (armature) that is held partially out of the coil by spring tension |
| 4493 | The mushroom-head or palm-head pushbutton operator is extended past the end of the locking collar, such that the closing of the mushroom head is ___ by the collar |
| 4494 | As used in control circuits: a ___ switch is a maintain-type control switch with contacts so arranged as to permit a conductor in a circuit to be connected to a common terminal |
| 4495 | When a control switch contains one set of NO contacts and one set of NC contacts, and the NC contacts are opened before the NO contacts are closed, a ___ switching configuration is created |
| 4496 | The ___ interconnecting the three poles (switches) of a 3-pole disconnecting means operator (handle), normally indicates a mechanical linkage all switches |
| 4497 | With the exception of the vertical busess wire #1 andwire #2, you should increase the wire number by ___ each time a switching component is crossed from line side to load side |
| 4498 | In a ladder diagram, the “S†symbol drawn in the left vertical line and represents a ___ |
| 4499 | There are two standard fuse symbols ___ |
| 4500 | If a control switch is drawn with one end of the moveable linkage, or the bar of the switch is hinged to one of the ___ |
| 4501 | Addressed by the acronym ___, a single-pole, double-throw switch can also be either single-break or double-break in configuration |
| 4502 | ___ circuit conductors in any electrical circuit must be fused at their point of supply. These conductors must be insulated and color-coded to any color other than white, gray, or green |
| 4503 | ___ circuit conductors in any electrical circuit must be fused at their point of supply |
| 4504 | A pair of series-connected control contacts will be paralleled with another pair of series-connected control contacts ___ |
| 4505 | The short line with an arrowhead extended from the switch is another form of shorthand used to reduce clutter on the electrical plan ___ |
| 4506 | A lighted pushbutton can be indicated in more than one way on a ladder diagram or other drawing ___ |
| 4507 | The acronym used to identify the type of voltage solenoid or meter is normally written within the circle between the wire terminals: A or AM in the circle indicates a(n) ___ |
| 4508 | To aid in the quicker response in an emergency shutdown (safety) situation, the ___ that keeps the operator extended and the switching contacts closed, is less for the mushroom-head operator |
| 4509 | Both potentiometers and rheostats can be classified as linear or taper. When classified as ___, the percentage of output voltage varies directly with the percentage of tap |
| 4510 | Because the ___ cannot momentarily pass current in excess of its rating, it must be set to trip at a value higher than the locked-rotor current rating of the electric motor when magnetic circuit breaker installed |
| 4511 | Because the magnetic circuit breaker cannot momentarily pass current in excess of its rating, it must be set to trip at a value higher than the ___-___ current rating of the electric motor |
| 4512 | At the top of the right vertical line in a ladder diagram, the ___ symbol (___) is shown connected common to the other side of the control transformer and to the return-circuit conductor of the ladder diagram |
| 4513 | The thermal/magnetic circuit breaker is also referred to as an ___-___ circuit breaker: |
| 4514 | The schematic diagram should not be confused with a ___ diagram, which does represent the physical location of the contained circuit components |
| 4515 | With the exception of solenoid coils, the symbol of a reactor coil consists of a number of arches or humps drawn in a straight line ___ |
| 4516 | The acronym used to identify the type of voltage solenoid or meter is normally written within the circle between the wire terminals: V or VM in the circle indicates a(n) ___ |
| 4517 | Numbered in this manner, the next ___ consecutive number will identify the ___ side conductor of both parallel sets of contacts |
| 4518 | Addressed by the acronym DPDT, ___- ___, ___-___ indicates two single-pole double-throw switches are ganged on a common switch operator |
| 4519 | If the line is not touching either circle, this indicates a normally ___ break switch |
| 4520 | The ___ represents a magnetic sensing element, which is normally a current solenoid (heavy coil of wire) wired in series with the latch switch |
| 4521 | A ___ or ___ diagram is normally a skeletal, geometrical drawing |
| 4522 | In the power or load circuit, line conductors are identified with the capital letter L and the representative phase conductor to which they are connected ___ |
| 4523 | The electrical plan, or ___ as it is normally called, is drawn over the basic outline of the architectural floor plan of the building (or other structure) |
| 4524 | The 3-phase AC, 3-wire, wire-wound rotor induction motor is symbolized with two ___ circles |
| 4525 | When drawing a 3-position selector switch, the arrowhead should point to the ___ position |
| 4526 | Older schematics may show one line drawn with a hump over the other to indicate no ___ and use either the straight-line intersection or perpendicular line termination as ___ |
| 4527 | Because the single-line drawings of the electrical layout are drawn over the floor plan of the building or floor level (multistory) being represented, electrical circuits are normally drawn as ___ lines |
| 4528 | To communicate between control and sensing equipment located on a rotating platform and stationary control and sensing equipment, a brush and slip ring assembly is required ___ |
| 4529 | The double shepherd hooks on the load side of the latch-type switch symbol (an arc drawn between two straight lines) indicates a ___ |
| 4530 | When a control switch contains one set of NO contacts and one set of NC contacts, and the NC contacts are opened before the NO contacts are closed, this is referred to as a ___ switching configuration |
| 4531 | If the short straight line is drawn over one of the open circles at a slight angle so that it is touching the side of the other open circle, this indicates a normally ___ break switch |
| 4532 | A bolt of lightning (zigzag line) laid on its side represents a ______coil |
| 4533 | On the electrical plan of a building or other structure, the capital ___ symbol for a toggle switch in a given circuit indicates a single-pole light switch |
| 4534 | As compared to the ___, which directs only the starting or stopping of an electric motor, the ___ supplies the 3-phase power to the line-side of the 3-phase manual or electromechanical motor starter |
| 4535 | A(n)___ circle connecting two or more straight lines indicates a splice or other interconnection of two or more wires |
| 4536 | A circle is normally used to indicate a wire connection: A(n) ___ is normally used to indicate a splice with some type of wire fastener |
| 4537 | The acronym used to identify the type of voltage solenoid or meter is normally written within the circle between the wire terminals: VA in the circle indicates a(n) ___ |
| 4538 | A ___ /___circuit breaker is a hybrid circuit breaker that contains a magnetic sensing element (___ symbol) and a thermal sensing element (___ shepherd hooks) wired in series |
| 4539 | The ___ diagram represents the physical location of the contained circuit components |
| 4540 | The ___ at the angled-end of the selector-switch actuator symbol normally denotes a knob-type selector switch that is either turned left or right |
| 4541 | When used to control the available connected-load current, the variable resistor is referred to as a ___ characteristically a 2-terminal device |
| 4542 | As used with the acronym ___, double-pole, single-throw indicates two single-pole single-throw switches are ganged on a common switch operator |
| 4543 | The midpoint of the two series-connected sets of control contacts in the second parallel control line should be labeled with the next ___ consecutive number (___-to-___) |
| 4544 | As compared to the control circuit which only directs the starting or stopping of an electric motor, the ___ or ___ circuit supplies the 3-phase AC power from the load side |
| 4545 | ___ of electrical equipment aid in familiarization of the different components within the electrical system, but they have limited use in conveying control information about the electrical circuit |
| 4546 | The three position, center-return, mushroom-head, push/pull operator is stacked with one set of NO contacts and a set of NC contacts ___ |
| 4547 | To link the two together, mentally, they are identified in the same manner ___ |
| 4548 | The zigzag line on the load side of the latch-type switch symbol (an arc drawn between the two straight lines) indicates a ___ |
| 4549 | The prints or drawings of electrical-power distribution circuits within a building or other structure are normally referred to as ___ |
| 4550 | When identifying the load-side of the first switching component in the next consecutive control line, you should add ___ to the last wire number used |
| 4551 | The ___ Push/Pull pushbutton switch is a special type of switch often used in safety circuits where immediate shutdown of the machine or process is required with easy access to the switch |
| 4552 | The symbol of a ___ (acronym) NO single-break toggle switch is representative of two of the SPST NO single-break toggle switches internally mechanically connected to a single switch operator in a common enclosure |
| 4553 | In the rotary switch symbol, a make-before-break configuration is noted (with an ___ at the end of the selector-actuator symbol) denotes ___ contacts |
| 4554 | A selector switch with more than three positions is normally re-classified as a ___ switch |
| 4555 | The switch symbols are categorized according to ___ (what the switch does): |
| 4556 | Autotransformers are often used because of their lower ___ |
| 4557 | Any symbol is created with the thought of conveying as much information as possible about the device or circuit component it represents ___ |
| 4558 | The acronym used to identify the type of voltage solenoid or meter is normally written within the circle between the wire terminals: VARH in the circle indicates a(n) ___ |
| 4559 | Because most momentary PB switches are limited to two positions (either at-rest or activated) in either a NO or an NC switch configuration and cannot be left in a third state somewhere in between these two states ___ |
| 4560 | The three-position, centre-return, mushroom-head, push/pull operator is stacked with one set of NO contacts and a set of NC contacts ___ |
| 4561 | Many times the drawn lines in line or ladder diagrams must cross without connection to the lines they cross ___ |
| 4562 | The ___ interconnecting the three poles (switches) of a 3-pole disconnecting means operator (handle), normally indicates a mechanical linkage — all switches or switching contacts shown interconnected with the broken line |
| 4563 | To reduce clutter and create parallel connections, ___ are used on schematics, especially in vertical bus connections, to indicate screw terminal splice on a control device |
| 4564 | In a separately-derived control circuit, these white- or gray-colored ___ circuit conductors are referred to as just the “common†|
| 4565 | A small ___ is a wire-terminal connection, but a medium to large circle is used with switch and relay-logic symbols to identify the solenoid or light as the load in a given line (or rung) in the control circuit |
| 4566 | The ___ head or ___ head momentary pushbutton switch is a special type of NC PB switch often used in safety circuits where immediate shutdown of the machine or process is required with easy access to the switch |
| 4567 | The acronym ___ indicates the normally-closed held-open at-rest status of the control contacts |
| 4568 | As used in the electrical-power distribution wiring of a building or other structure, a ___ is that part of a branch circuit extended from the panel or other load center housing the branch circuit fuse |
| 4569 | The ___ symbol in a ladder diagram indicates some type of annunciator |
| 4570 | The same size ___, which is used for relay or motor-starter voltage solenoids in a ladder diagram, is used to symbolize panel meters |
| 4571 | In a 2-wire branch-circuit, which operates at the lower phase-to-neutral voltage, ___ circuit conductors are referred to as the “grounded common return†|
| 4572 | A single circuit conductor is typically connected to several devices in a common ladder diagram that operates in parallel ___ |
| 4573 | The ___ for the motor symbol is used in both the control or signal section (ladder diagram-the voltage solenoid) of a schematic and the power or load section of the same schematic |
| 4574 | In a ladder diagram, the “S†symbol drawn in the left vertical line and represents ___ |
| 4575 | Because alternators, generators, electric motors, solenoids, and transformers are all constructed with one or more coils of wire, ___ are represented by a variety of symbols |
| 4576 | The acronym ___ indicates the normally-open at-rest status of the control contacts |
| 4577 | Addressed by the acronym ___, a single-pole, single-throw switch can be either a single-break or double-break configuration |
| 4578 | Both potentiometers and rheostats can be classified as linear or taper ___ |
| 4579 | A special type of palm-head momentary pushbutton is a 3-position momentary switch that is at-rest in a 3rd ___ position |
| 4580 | The symbol of a winding(s), which consists of a number of arches or humps drawn in a straight line, represents a(n) ___ |
| 4581 | If interrupted at only one break point (single-break), the temperature could be high enough to melt the respective pad surfaces and cause ___ holes, where the metal at the entry/exit point melted |
| 4582 | The stator winding leads of a 3-phase AC synchronous motor are identified the same as the 3-phase AC induction motors: ___, ___, and ___ |
| 4583 | Double-break configuration increases the ___ of the switch by interrupting load (or control) current at two points |
| 4584 | Understanding electrical-power distribution and electrical-control circuits require a vast transfer of knowledge ___ |
| 4585 | Two supply lines identify a ___ -phase AC, 2-wire induction motor |
| 4586 | When a control switch contains one set of NO contacts and one set of NC contacts, and the NO contacts are closed before the NC contacts are opened, a ___ switching configuration is created |
| 4587 | A ___ is a drawing that shows the length, height, and depth of a selected object in one view |
| 4588 | The acronym ___ indicates the normally-open held-closed at-rest status of the control contacts |
| 4589 | Pilot or indicating lights are also symbolized with a circle, which is normally drawn to a smaller scale compared to a voltage-solenoid symbol in the ladder diagram ___ |
| 4590 | Two standard fuse symbols are used in electrical control print ___ |
| 4591 | A ___ is a drawing of electrical components and their connections done in an agreed-to symbolic form and used as a convenient way of representing electrical circuits |
| 4592 | The thermal circuit breaker is also referred to as an ___ circuit breaker |
| 4593 | Normally the actuator of a pushbutton switch, whether momentary (standard pushbuttons) or maintained (selector pushbutton), is a vertical line ___ the arrowhead |
| 4594 | The circuit conductors are wire-numbered to identify their ___ in the control sequence |
| 4595 | The circle in the control section, which actually identifies the voltage solenoid of the motor-starter, contactor, or relay controlling the power applied to the motor, is normally ___ |
| 4596 | A ___ -actuated solenoid coil is symbolized with a circle with short wire leads extended on either side along the horizontal centerline of the circle, whereas a ___ -actuated solenoid coil is symbolized with a zigzag line |
| 4597 | What is drawn on top of the square box is used to symbolize the type of annunciator ___ |
| 4598 | As used with the electrical plan of a building or other structure, the term ___ indicates a single ON/OFF snap switch |
| 4599 | Rheostats and potentiometers are both ___ resistors |
| 4600 | Most symbols use a combination of straight lines and circles, straight lines and boxes, and/or straight lines and arches ___ |
| 4601 | As used with 3-phase AC wire-wound rotor induction motors, a ___ bank is a form of reduced-torque starting in which two or more resistors are wired in series with the rotor circuit of the motor upon initial starting |
| 4602 | The majority of the relay-logic symbols represent some type of ___ |
| 4603 | A special type of palm-head momentary pushbutton is a 3-position momentary switch that is at-rest in a third neutral position ___ |
| 4604 | When a pushbutton switch is configured as a ___ -type switch, the switch symbol in the schematic or wiring diagram relates two separate PB switches |
| 4605 | Switches in most power or load circuits are drawn ___ |
| 4606 | A ___ diagram is a detailed diagram showing a complicated circuit in a logical sequence |
| 4607 | The extension of the vertical control busses can be visualized as the ___ of a ladder |
| 4608 | A ___ is a nonconductive device or assembly designed with fuse clips to hold a cartridge fuse |
| 4609 | The acronym used to identify the type of voltage solenoid or meter is normally written within the circle between the wire terminals ___ |
| 4610 | In a switch or relay logic ladder diagram: The acronym ___ indicates the normally-open at-rest status of the control contacts |
| 4611 | ___ is the storage of an electrical charge between two conductive surfaces in the form of an electrostatic field across an insulating surface in a ___ |
| 4612 | Which of the following safety rules are not true ___ |
| 4613 | Which of the following safety rules is not true ___ |
| 4614 | When you become part of the electrical circuit, the severity of the electrical shock is determined by which of the following ___ |
| 4615 | The severity of the electrical shock is determined by which of the following ___ |
| 4616 | The ___ or ___ of current allowed to flow through the body is the most important factor that will differentiate between a light electrical shock, a severe electrical shock, and death by electrocution |
| 4617 | As used with cabinets, disconnects, controllers, and other enclosures: the electrical power distribution system of a building or other structure, the term “___ enclosure†indicates without live parts |
| 4618 | You are part of the ground return path in the equipment-grounding system because the floor you are normally standing on or the metal enclosure you may be touching is part of the ___ |
| 4619 | When the outer layer of skin is ___, it has a high-value of resistance |
| 4620 | For all practical purposes, the human body can be considered a ___ conductor of low ___ |
| 4621 | Although the circuit conductors do offer a minute resistance to the flow of electrical current, the ___ is the main opposition to current flow |
| 4622 | You should ___ all equipment enclosures including plug-in type test equipment, especially when ___ are present |
| 4623 | In order for you to suffer ___, you must become part of the circuit |
| 4624 | Hands are not the only body surface that may be accidentally placed in the path of electrical current ___ |
| 4625 | Most electrical-power distribution systems within a building or other structure operate with one circuit conductor, normally the ___ conductor |
| 4626 | Both ___ voltages and ___ body resistances will reduce the degree of electrical shock or damage to the human body |
| 4627 | In addition to providing a single path for current flow along the length of the circuit conductors, the ___ on the circuit conductors of the electrical power distribution |
| 4628 | A(n) ___ is a conducting object through which a direct connection to earth is established |
| 4629 | Electricity must either be controlled or commanded to do ___ or as is the case with static electricity |
| 4630 | A ___ electrical-power distribution system is a premises wiring system (building or other structure) whose power is derived from a source of electric energy or equipment other than a service |
| 4631 | Electrical ___ is the connection of two or more metal parts to establish electrical continuity and conductivity |
| 4632 | Other than protection from structural fire or the dispersion of molten metal, a fuse or circuit breaker technically is not people protection at all ___ |
| 4633 | The duration of contact (amount of time) in an electrical shock is closely related to skin resistance ___ |
| 4634 | Electrical shock to the heart muscles or to the nerves directing the heart in the human body can disrupt the brain’s electric impulses and cause the heart to lose its rhythmic coordinated ___ |
| 4635 | Electricity can be described as a potential that ___ a flow or movement of free electrons along the length of a conductor |
| 4636 | The length of the conductor, which is normally copper or aluminium wire, any type of metal, including the steel or ___ |
| 4637 | The best prevention of shock or electrocution available to all is safety first ___ |
| 4638 | It is possible for an electrician to work a full career in the electrical field without any serious accident or injury ___ |
| 4639 | You are advised not to grab an individual who is in contact with a live wire (being shocked) ___ |
| 4640 | You are advised not to grab an individual who is in contact with a live wire ___ |
| 4641 | In order to avoid the harmful effects of possible electrical shock or electrocution, you should always consider ___ |
| 4642 | Other factors that may affect the severity of the electrical shock include the phase of the heart cycle at the initial moment of the electrical shock; the frequency of the ___ |
| 4643 | You should not place both hands on an energized circuit at the same time ___ |
| 4644 | The ground-fault return path of the electrical-power distribution system is referred to as the ___ system |
| 4645 | In addition to providing a single path for current flow along the length of the circuit conductors, the ___ on the circuit conductors of the electrical-power distribution |
| 4646 | Electricity must either be controlled or commanded to do useful work, or as is the case with ___ electricity, it must be discharged |
| 4647 | The ___ or ___ within an electrical circuit is commonly referred to as the circuit voltage |
| 4648 | Before using a tool, you should know its ___ and how it ___ |
| 4649 | Static electricity is a form of ___ generated by friction, where a static charge is maintained between two conductive surfaces separated by an insulator |
| 4650 | You should always turn off or remove all power ___ making alterations to an electric circuit |
| 4651 | The NE Code requires bonding of all the non-current-carrying metal parts of the electrical-power ___ |
| 4652 | You should always use the ___ tool for the job |
| 4653 | Because current will take every available path back to its source, the circuit conductors must be ___ |
| 4654 | Because current will take every ___ back to its source, the circuit conductors must be ___ to form a single path for current flow |
| 4655 | The path of current is the most ___ one from one point of contact (entry) to the other point of contact in the human body |
| 4656 | Electrical ___ is connection to ground or to a conductive body extends the ground connection |
| 4657 | Grounding the service neutral conductor limits the magnitude of the voltage that can occur on the non-current-carrying ___ |
| 4658 | The NE Code requires bonding of all the non-current-carrying metal parts of the ___ |
| 4659 | The ground-fault return path of the electrical-power distribution system is referred to as the ___ system a conductive path installed to connect normally non-current-carrying metal parts of equipment together |
| 4660 | The operating voltage of the equipment you are working with determines the ___ voltage |
| 4661 | Accidents are sometimes the result of ___ by the individual, but so often accidents happen because we are ___ of the dangers |
| 4662 | Grounding the service neutral conductor limits the magnitude of the voltage that can occur on the non-current-carrying metal parts within the ___ |
| 4663 | The magnitude or amount of current allowed to flow through the body is the most important factor that ___ |
| 4664 | Whether in the wiring laboratories or on the job, electrical safety depends on the use of safe procedures in ___ |
| 4665 | ___ resistance is an important factor in controlling the harmful effect of a electric current |
| 4666 | During a severe electrical shock, ___ burns are the result of an electrical-equipment failure in the form of short circuit |
| 4667 | Voltage, along with the current, your individual body resistance, the duration of electrical contact, and the path of ___ |
| 4668 | Before using a tool, you should know its function and how it ___ |
| 4669 | You should always think ___ either in the wiring laboratories you are about to begin or on the job |
| 4670 | ___ should be a number one priority in all walks of life and in all phases of life |
| 4671 | During a severe electrical shock, ___ burns are normally caused by contact with the superheated air |
| 4672 | To ___ the magnitude of current that flows in an electrical shock situation we must ___ a person’s resistance |
| 4673 | ___, along with ___, your individual body ___, the ___ of electrical contact, and the ___ of current flow through your body all combine to determine the extent of harm to you |
| 4674 | A ___ is a conducting object through which a direct connection to earth is established |
| 4675 | The best or safest form of electrical ___ |
| 4676 | The non-current-carrying metal or other conductive parts of the building or other ___ |
| 4677 | Grounded or grounding is ___ to ground or to a conductive body that extends the ground connection |
| 4678 | Besides a ground-fault return path, bonding within the equipment-grounding system provides a means to dissipate ___ |
| 4679 | Bonded or bonding is the connection of two or more metal parts to establish ___ |
| 4680 | To reduce your risk of personal injury due ___ |
| 4681 | The more common electrically shock-related injury is ___ |
| 4682 | Which of the following safety rules are not ___ |
| 4683 | As used with cabinets, disconnects, controllers, and other enclosures: the electrical power ___ |
| 4684 | The duration of contact (amount of time) in an electrical shock is closely related to ___ |
| 4685 | ___ burns occur when current flows along the skin or within the body (most dangerous) |
| 4686 | ___ burns are normally caused by contact with the superheated air |
| 4687 | You should always wear safety glasses because the majority of your wiring-laboratory exercises or work on the ___ |
| 4688 | Whether in the wiring laboratories or on the job, electrical safety depends on the use of ___ |
| 4689 | Other factors that may affect the severity of the electrical shock include the ____ of the heart cycle at the initial moment of the electrical shock |
| 4690 | During a severe electrical shock, ___ burns occur when current flows along the skin |
| 4691 | Because of this constant contact, you are on one side of the circuit at all ___ |
| 4692 | The equipment-grounding system is designed to ground-fault any of the ungrounded circuit conductors in the ___ |
| 4693 | In order for you to suffer electrical ___ you must become part of the circuit |
| 4694 | Two important concepts must be understood and honoured when wiring or ___ |
| 4695 | Installing the electrical-power distribution system in raceways and other enclosures, the insulated circuit conductors are protected from ___ |
| 4696 | Horseplay or just kidding around is OK in the wiring- laboratory exercises or on the ___ |
| 4697 | Besides a ground-fault return path, bonding within the equipment-grounding system, as well as the ___ |
| 4698 | ___ is the main safety factor when using hand tools |
| 4699 | To reduce your risk of personal injury due to electrical shock, you should apply the safety rules presented to you in the ___ |
| 4700 | Once inside your body, resistance to the flow of ___ |
| 4701 | Once inside your body, resistance to the flow of current is ___ |
| 4702 | ___ should be a number one priority in all walks of life and in all phases of life especially in the workplace |
| 4703 | A ___ conductor is a conductor used to connect the system grounded conductor or the electrical distribution or utilization equipment to a grounding electrode |
| 4704 | The two best safety precautions an electrician can use is ___ |
| 4705 | ___ burns are the result of an electrical-equipment failure in the form of either a short circuit or ground fault |
| 4706 | The generation of electricity, which is technically the ___ flow of electrons along the length of a material or the ___ transfer of electrons from one material to another |
| 4707 | Electricity must either be controlled or commanded to do useful work, or as is the case with ___ |
| 4708 | You should remove all jewellery when working with ___ |
| 4709 | A _____________ is the rate of change of the varying magnitude of a substance |
| 4710 | ________ should be a number one priority in all walks of life and in all phases of life |
| 4711 | You should not use a lead pencil or a metal shank tool, such as a screwdriver, to poke at an ___ |
| 4712 | The voltage range for either process equipment or for electrical-power distribution within a building is ___ |
| 4713 | To minimize the magnitude of current that flows in an electrical shock situation, we must ___ |
| 4714 | The forced flow or movement of the electrons is described as ___ |
| 4715 | The __________ within an electrical circuit is commonly referred to as the circuit |
| 4716 | Skin resistance is an important factor in controlling the harmful effect of an ___ |
| 4717 | To reduce your risk of personal injury due to ___ |
| 4718 | The length of the conductor is normally copper or aluminium wire, although just about any type of ___ |
| 4719 | Whether in the wiring laboratories or on the job, electrical safety depends on the use of safe procedures in the ___ |
| 4720 | The ___ system is designed to ground-fault any of the ungrounded circuit conductors in the electrical-power distribution system should one come in contact with any of the noncurrent-carrying bonded surfaces |
| 4721 | Damage to the lungs is normally due to electrical ___ that scar or otherwise damage (destroys the ___ of) lung tissue |
| 4722 | When you become part of the electrical circuit, the severity of the electrical shock is ___ |
| 4723 | Electrical shock occurs when you complete a path by touching a ___ |
| 4724 | Because abnormal conditions such as short-circuit or ground-fault overcurrents can occur and effectively ___ |
| 4725 | ___ are sometimes the result of carelessness by the individual, but so often accidents happen because we are unware of the dangers that are present in what we are attempting to do |
| 4726 | Your individual body resistance, the duration of electrical contact, and the path of current flow (along with voltage) through your ___ |
| 4727 | A separately derived electrical-power distribution system is a premises wiring system whose power is ___ |
| 4728 | ___ is a general term, including fittings, devices, appliances, luminaires, apparatuses, machinery and the like used as a part of, or in connection with, an electrical installation |
| 4729 | The forced flow or movement of the electrons is as the ___ |
| 4730 | The path of the current is the most direct one from one point of contact (entry) to the other point of ___ |
| 4731 | Other than protection from structural fire or the dispersion of molten metal, a fuse or circuit breaker technically is ___ |
| 4732 | Because abnormal conditions such as short-circuit or ground-fault overcurrents can occur and effectively bypass the ___ |
| 4733 | Insulated circuit conductors are protected from physical damage by ___ |
| 4734 | A ___ system consists of all grounding electrodes that are present at each building or structure served bonded together to form the grounding electrode system |
| 4735 | Damp shoes will not contribute to a possible electrical shock ___ |
| 4736 | Because the electrical circuit or circuits you are working on are normally voltage-referenced to the ___ |
| 4737 | ___ can be described as a potential that forces a flow or movement of free electrons along the length of a conductor |
| 4738 | The synchronous rotor speed of a ___ 3-phase AC alternator is 1800 rpms for an output frequency of 60 Hz |
| 4739 | Because supply line L2 might be a grounded circuit conductor in the electrical power distribution system of ___ |
| 4740 | The rotating speed of a 3-phase AC alternator is determined by ___ |
| 4741 | When the primary and secondary leads of three single-phase AC transformers are interconnected (respectively) in either a delta or ___ |
| 4742 | When a transformer is used for ___, the primary and secondary voltage ratings are equal |
| 4743 | Electric motors, whether AC or DC, use either the ___ or ___ or to a certain extent both ___ of two magnetic |
| 4744 | Due to the line losses along the extreme length of the circuit conductors, ___ are required to increase the voltage of the generated AC power for transmission |
| 4745 | The locked-rotor current and the start-up current of a motor under full-load conditions are ___ |
| 4746 | For ___ wiring configurations, the transformer has a secondary load voltage lower than the primary supply voltage |
| 4747 | The output voltage of a 3-phase AC alternator is determined by ___ |
| 4748 | The average AC induction motor will draw up to ___ % of its nameplate full-load current rating under locked-rotor conditions |
| 4749 | In terms of their operating characteristics, single-phase AC induction motors are commonly referred as ___ |
| 4750 | If an AC induction motor has a successful start and near running speed is attained, the motor appears to be a ___ |
| 4751 | At the load end of the utility-owned transmission/distribution system, more 3-phase or single-phase AC ___ |
| 4752 | The ___ value of impedance reflected into the primary circuit of a transformer will occur when the secondary circuit is open |
| 4753 | In the electrical power distribution system of a building or other structure, the wye and delta wiring configurations are ___ |
| 4754 | Within a building or other structure, the X2 common-node connection of the wye-connected secondary of a 3-phase transformer is ___ |
| 4755 | Due to the sometimes vast lengths of wire (circuit conductors) required to transmit the electrical energy from the ___ |
| 4756 | In the standard delta or wye configuration, individual single-phase AC transformers cannot be haphazardly wired together to form a ___ |
| 4757 | The average electric motor will draw up to ___ % of its nameplate full-load current rating under locked-rotor conditions |
| 4758 | The revolving- ___ type rotates the three single-phase windings, located 120 mechanical degrees apart on the rotor assembly around the inside of a fixed or stationary electromagnetic field |
| 4759 | The external motor overload-protection device can have a rating or setting between ___% and ___% with ___% being the normal setting |
| 4760 | In a split-phase AC induction motor, to attain the phase shift from the single-phase AC source, the start winding would have to be ___ |
| 4761 | Because the start winding is purposely made more resistive than inductive, and because the starting winding current is out of phase with both the ___ |
| 4762 | In the electrical-power distribution system of a building or other structure, the wye and delta wiring configurations are normally mixed between the ___ |
| 4763 | In an isolation ___ transformer: The secondary winding is physically and electrically isolated from the primary winding |
| 4764 | For power transformers, the excitation current is of such low value when compared to the secondary full-load ___ |
| 4765 | The stationary assembly of a 3-phase AC alternator is referred to as ___ |
| 4766 | The delta-to-delta transformation of a 3-phase AC electrical-power distribution system was the preferred electrical-power distribution in a ___ |
| 4767 | When the respective circuit windings of three single-phase AC transformers are mounted on a common ___ |
| 4768 | Transformer or motor action depends on the ___ of two opposing electromagnetic fields |
| 4769 | The turning rotor of an AC induction motor can never attain the synchronous speed of the ___ |
| 4770 | The external overload protection can be a ___ mounted in the bell housing on the non-drive end of the motor |
| 4771 | The effect of eddy currents is reduced to a bare-bones minimum by constructing the iron core of several ___ |
| 4772 | The impedance of a second isolation transformer located in the immediate vicinity of the switchgear, which includes ___ |
| 4773 | At the branch-circuit level, the overload-overcurrent protection is normally ___ |
| 4774 | The magnitude of the output voltage of a 3-phase AC alternator is normally set at the desired value by ___ |
| 4775 | The electrical characteristics ____ of the start and run windings in the stator assembly |
| 4776 | A motor-circuit switch used as the disconnecting means for an electric motor circuit must be ___ |
| 4777 | The number of cycles the three single-phase AC sinusoidal waveforms complete in one second in a ___ |
| 4778 | In addition to power transmission and distribution, transformers ___ |
| 4779 | In a given single-phase AC transformer, the voltage and turns ratios are ___ proportional to each other |
| 4780 | The output frequency of a 3-phase AC alternator is determined by ___ |
| 4781 | The power supplied to almost all 3-phase AC motor applications is controlled through a system of electromechanical control ___ |
| 4782 | An electromagnetic field is produced by passing electrical ___ through the windings of a generator, a motor, a reactor, a solenoid, or a transformer |
| 4783 | When the voltage ratio of a power transformer is 1-to-1 (same voltage ratings), the transformer is ___ |
| 4784 | The expended electrical energy in a transformer, which is normally ___ |
| 4785 | Electric motors use either the repulsion or attraction (interaction) of two ___ or ___ fields to cause the rotating member of the motor (the rotor) to turn |
| 4786 | In the high-voltage configuration of 9-lead, dual voltage (230/460), 3-phase AC induction motors ___ |
| 4787 | The main restriction of primary-circuit current is ___ from the secondary circuit of the transformer |
| 4788 | In terms of their operating characteristics, single-phase AC induction motors are commonly referred to as ___ |
| 4789 | The output voltage of a 3-phase AC alternator is ___ |
| 4790 | In comparison to the delta wiring configuration, the wye configuration is the more common ___ |
| 4791 | If the motor branch-circuit will be protected against high-level short-circuit/ground-fault overcurrent ___ |
| 4792 | At the branch-circuit level, the ___ -overcurrent protection of an AC induction motor is normally thermal |
| 4793 | The secondary of the electrical-utility distribution system load-end transformer supplies the service conductors for ___ |
| 4794 | For a single electric motor supplied by an individual branch circuit, the rated-load ampacity of the ___ |
| 4795 | If the branch-circuit breaker or fuses are the combined overcurrent protection, their rating should fall within ___ |
| 4796 | According to the size of the motor and the type of manufacture, the electric motor may be ___ |
| 4797 | The electric motor is used to convert electrical energy into ___ |
| 4798 | The main restriction of primary-circuit current is reflected ___ from the secondary circuit of the transformer |
| 4799 | All transformers are initially rated as ___ with minimum construction of one primary 2-wire winding (connected to the AC ___) |
| 4800 | For ___ wiring configurations, the transformer has a secondary load voltage higher than the primary supply voltage |
| 4801 | The continual de-magnetization and re-magnetization of the iron core due to electromagnetic field reversal make the ___ |
| 4802 | Technically, a true single-phase AC induction motor, which would have a single pair of electromagnetic poles about its ___ |
| 4803 | Once a three-phase AC motor is wired in either a wye or delta configuration at the correct operating ___ |
| 4804 | An electromagnetic field is produced by passing electrical ___ through the windings of a generator a motor, a reactor, a solenoid, or a transformer |
| 4805 | The electric ___ is used to convert electrical energy into mechanical energy in the form of rotary motion |
| 4806 | Both the time-delay fuses and the inverse-time circuit breaker have inverse-time characteristics in response to ___ |
| 4807 | The open-secondary primary-circuit current, which supports the continual reversal of the |
| 4808 | Not all split-phase AC induction motors employ a centrifugal switch to disconnect the ___ |
| 4809 | The principal type(s) of single-phase AC induction motors ___ |
| 4810 | The interaction of the primary and secondary electromagnetic fields is at its maximum, which causes the ___ |
| 4811 | ___ is defined as the average field intensity of a magnet multiplied by its area |
| 4812 | For signaling, remote control, or other low-power, low-voltage control or sensing ___ |
| 4813 | Normally, separate overload protection devices for AC induction motors are not designed to respond to ___ |
| 4814 | The operating full-load current of an AC induction motor, as specified on the motor nameplate, is initially ___ |
| 4815 | ___ lines are imaginary lines that indicate the strength and direction of a given magnetic field |
| 4816 | The revolving ___ alternator rotates the three single-phase windings located 120 mechanical degrees apart on the rotor assembly, around the inside of a fixed or stationary electromagnetic field |
| 4817 | In the wiring diagram of a 9-lead, 230/460-volt, ___ -three-phase AC, squirrel-cage induction motor for 460-volt operation, six connections are required |
| 4818 | The output frequency of a 3-phase AC alternator is ___ |
| 4819 | With the coils of the start and run windings placed at ___ mechanical degrees apart around the inner surface of the stator structure at the point of manufacture of the single-phase AC induction motor |
| 4820 | If the motor branch-circuit will be protected against high-level short-circuit/ground-fault overcurrent with instant-acting ___ |
| 4821 | The two ___ in the indicated circuit conductors in the standard symbol of a transformer represent either wire terminals on some sort of terminal block, or short sections of wire |
| 4822 | The wye and delta wiring configurations are normally mixed between the primary and secondary load circuits of the ___ |
| 4823 | Only the branch-circuit fuse or circuit breaker can provide the necessary _______ overcurrent protection |
| 4824 | If the motor branch-circuit will be protected against high-level short-circuit/ground-fault overcurrent with ___ |
| 4825 | The relative motion of the sinusoidal electromagnetic field will cause stray currents to flow at ___ |
| 4826 | The turning rotor of an AC induction motor can never attain the synchronous speed of the stator circuits rotating electromagnetic field ___ |
| 4827 | In the ___ or ___ circuit, three separate sets of normally-open contacts on the power contactor are closed simultaneously by the energization of a solenoid coil |
| 4828 | In a given single-phase AC transformer, the ratios of both current and voltage are dependent on the ___ |
| 4829 | Many AC induction motors are designed to operate in an overload condition which will draw overcurrent in excess of ___ |
| 4830 | The impedance of a second isolation transformer located in the immediate vicinity of the switchgear of ___ |
| 4831 | The turning of the electromagnetic field of the rotor in a 3-phase alternator induces three single-phase ___ |
| 4832 | ___ overloads are a common occurrence with driven machinery |
| 4833 | It is a temporary magnet whose magnetic properties are produced from the application of ___ |
| 4834 | The expended electrical energy of the excitation current is referred to as ____ losses |
| 4835 | For power transformers, the excitation current is of such low value when compared to the ___ |
| 4836 | Reset of an ___________ overload relay is normally accomplished by turning the control power off |
| 4837 | For lightning suppression and electrical safety in terms of proper electrical-power control, distribution, and ___ |
| 4838 | The load of the secondary (rotor) circuit of the motor is reflected into the primary for ___ |
| 4839 | Electrical power applied to the solenoid coil is controlled by an array of normally-open or normally-closed ___ |
| 4840 | The normal dual voltage rating of 3-phase AC induction motors is ___ volts |
| 4841 | Most AC motors listed as “induction” will be the squirrel-cage type, which describes the type of ___ |
| 4842 | In the wiring diagram of a 9-lead, 230/460-volt, ___ -configured, 3-phase AC, squirrel-cage induction motor for 230-volt operation, four connections are required |
| 4843 | The transformation of voltage, current, or circuit impedance is by mutual ___ |
| 4844 | Normally, separate overload protection devices are not designed to respond to ___ |
| 4845 | The two parallel bars (lines) between the two winding symbols in the standard symbol of ___ |
| 4846 | The motor lead identification of single-phase AC induction motors is not as standard as the ___ |
| 4847 | The ever-changing and periodically-reversing alternating ____ of the primary and secondary circuits of the transformer |
| 4848 | The ____ rating of the transformer indicates the maximum amount of power that can be drawn by the load |
| 4849 | When the transformer circuit is put in a fault (shorted) condition, the flow of high-magnitude overcurrent generates ___ |
| 4850 | The single-phase AC resistance-start/induction-run motor can develop a rotating electromagnetic field due to the higher ___ of the start winding as compared to the run winding |
| 4851 | The process of induction, which is required for the magnetic operation of a transformer, depends on a length of conductor and a concentrated magnetic or electromagnetic field with relative motion between the two ___ |
| 4852 | As within a transformer, the primary (stator) winding of the electric motor offers only a ___ |
| 4853 | The increased current flow in the primary or stator circuit during start-up or ___ |
| 4854 | There are three principal types of single-phase AC induction motors ___ |
| 4855 | External overload protection can be provided at the branch-circuit level as ___ overcurrent protection or it can be provided within the control circuit by separate ___ relays |
| 4856 | In the high-voltage configuration of 9-lead, dual voltage, 3-phase AC induction motors, the winding leads are wired in ___ |
| 4857 | The generated electromagnetic field causes an alternating voltage to be induced in the ___ |
| 4858 | Ignoring transformer core losses, the power rating of a transformer is equal to ___ |
| 4859 | When an AC induction motor operates in an ___ condition other words, the torque required by the connected (driven) load exceeds the torque available from the motor according to its horsepower rating |
| 4860 | The ___ value of impedance reflected into the primary circuit of a transformer will occur when circuit open |
| 4861 | The fact that the transformer has only one power rating for both the primary and secondary circuits sets the ___ |
| 4862 | The increased current flow in the primary or stator circuit of an AC induction motor during start-up or under locked-rotor conditions will ___ |
| 4863 | The turning rotor of an AC induction motor can never attain the synchronous speed of the stator circuits rotating electromagnetic field: The induction motor has to have a small percentage of ___ to supply the heat |
| 4864 | When an AC induction motor enters an overload condition, the motor must be taken off the line before the heat buildup, due to the slowing of the turning rotor, has reached insulation-failure level ___ |
| 4865 | When combined as a single unit, the power contactor and thermal overload relay are ___ |
| 4866 | ___ motors are easily recognized by the two slip rings on the rotor shaft |
| 4867 | The rotor will continue to turn with the start winding disconnected from the motor supply circuit once the single-phase AC induction motor is ___ |
| 4868 | The magnitude of currents flowing in the respective circuits of a transformer is governed by the ___ |
| 4869 | Because the motor supply circuit may be configured as a three-phase AC, 3-wire corner-ground delta electrical-power distribution ___ |
| 4870 | Regardless of the type of motor or its application, all-electric motors have several things in ___ |
| 4871 | The magnitude of the output voltage of a 3-phase AC alternator is normally set at ___ |
| 4872 | When overrating the branch-circuit fuses or circuit breaker for the NE Code-maximum rating of the ___ |
| 4873 | If the branch-circuit fuse(s) or circuit breaker is the only overcurrent protection provided for the ___ |
| 4874 | In addition to power transmission and distribution ___ |
| 4875 | The amount of fault overcurrent available at the load terminals of switchgear either short-circuit or ___ |
| 4876 | If the rotor of an electrical induction motor is turning near the cyclic speed of the induced rotating electromagnetic field in ___ |
| 4877 | The expended electrical energy in a transformer, which is normally dissipated as ___ |
| 4878 | The operating full-load current of an AC induction motor as specified on the motor nameplate is initially established by its design ___ |
| 4879 | In a single-voltage, ___ -connected, 3-phase AC induction motor, the three single-phase windings are wired end-to-end to form three nodes and a completely closed loop circuit |
| 4880 | Once the squirrel-cage rotor has accelerated to a point that it is operating at about ________ % of the synchronous speed |
| 4881 | Mutual ___ is defined as the production of varying or alternating EMF in one circuit by movement of field lines rising from another nearby circuit with varying current across its conductors |
| 4882 | In a given single-phase AC transformer, the voltage and turns ratios are ___ |
| 4883 | The capital letter X is used to identify the in and out terminals of the ___ -voltage winding |
| 4884 | The last step-down transformer in the electrical-utility distribution system is normally used as the ___ |
| 4885 | If the motor branch-circuit will be protected against high-level short-circuit/ground-fault overcurrent with an inverse-time circuit breaker, the standard overrate is ___ % |
| 4886 | When overrating the branch-circuit fuses or circuit breaker for the standard rating of the electric motor branch-circuit ___ |
| 4887 | Because the phase rotation of the three-phase AC supply controls the direction of rotation for the ___ |
| 4888 | Electrically, whether single-phase, 2-phase, or 3-phase, the common AC ___ motor appears as a transformer to the applied electrical power |
| 4889 | The ___ value of impedance reflected into the primary circuit of a transformer will occur when the secondary circuit is shorted |
| 4890 | Transformer or motor action depends on the interaction of two opposing electromagnetic fields ___ |
| 4891 | The amount of fault overcurrent available at the load terminals of switchgear— either short-circuit or ___ |
| 4892 | Electrically, whether single-phase, 2-phase, or three-phase, the common AC ___ motor appears as a transformer to the applied electrical power |
| 4893 | A standard squirrel-cage, AC induction motor will be provided with across-the-line starting and separate ___ |
| 4894 | Technically, a true single-phase AC induction motor, which would have a single pair of electromagnetic poles about ___ |
| 4895 | As the name implies, the start winding is only necessary for the starting of the single-phase AC motor ___ |
| 4896 | If the rotor is not turning (during start-up or under locked-rotor conditions), the motor’s stator and rotor circuits now function as a transformer ___ |
| 4897 | The ___ rating of the transformer indicates the maximum amount of power that can be drawn by the load without seriously overheating the transformer |
| 4898 | The revolving- ___ -type rotates the three single-phase windings, located 120 mechanical degrees apart on the rotor assembly, around the inside of a fixed or stationary electromagnetic field |
| 4899 | The current drawn in the primary (stator) windings, because of the value of the reflected impedance, is also of ___ value |
| 4900 | In comparison to the wye wiring configuration, the delta configuration is ___ |
| 4901 | Internal thermal overload protection normally consists of a solid-state device that has a ___ |
| 4902 | The rotor assembly now turns at synchronous speed at ___ slip |
| 4903 | Through brushes riding on the three slip rings on the rotor shaft, the magnitude of the rotor current in ___ |
| 4904 | The capital letter X is used to identify the in and out terminals of the __________ -voltage winding |
| 4905 | The last step-down transformer in the electrical-utility distribution system is normally used as the service ___ |
| 4906 | In the wiring diagram of a 9-lead, 230/460-volt, __________ |
| 4907 | At the load end of the utility-owned transmission/distribution system, more 3-phase or single-phase AC transformers are ___ |
| 4908 | The number of cycles the three single-phase AC sinusoidal waveforms complete in a 3-phase AC alternator in ___ |
| 4909 | The motor lead identification of single-phase AC induction motors is not as standard as ___ |
| 4910 | In the wiring diagram of a 9-lead, 230/460-volt, ___-configured, 3-phase AC, squirrel-cage induction motor for 460-volt operation, six connections are required |
| 4911 | In a rotating-field 3-phase AC alternator each of the three single-phase windings consists of a ___ |
| 4912 | A ___ is comprised of lines of force concentrated in the region surrounding a magnet |
| 4913 | The more common type of control transformer contains two ___ volt primary windings |
| 4914 | As with any AC induction motor, the speed of the rotating magnetic field of a single-phase AC induction motor is ___ |
| 4915 | The lower the magnitude of overcurrent the ___ the time interval before the circuit is opened |
| 4916 | Three-phase AC motors can be divided into three general types ___ |
| 4917 | The electric-utility’s power grid is considered to be an ___ |
| 4918 | The electric-utility’s power grid is considered to be an ___ in terms of the magnitude |
| 4919 | Three-phase AC power can be transformed either by three individual single-phase AC transformers or ___ |
| 4920 | “Two-pole†means there are two poles or one ___ for each single-phase AC source |
| 4921 | The main restriction of primary-circuit current is reflected ___ |
| 4922 | To prevent ___ buildup, especially in the rotating member, fins are normally mounted on the ends of the rotor |
| 4923 | On the standard symbol for a transformer, the in and out winding numbers ___ |
| 4924 | The outs of the same windings are identified with _________ numbers |
| 4925 | The revolving ___ alternator is constructed by placing the three sets of single-phase windings |
| 4926 | External overload protection can be sensed by ___ |
| 4927 | External overload protection can be sensed by either ___ or ___ means |
| 4928 | The windings of an AC induction motor appear as an almost short-circuit to the incoming power on ___ |
| 4929 | The insulated conductors must be identified to a colour other than ___ |
| 4930 | The switch used to control the operation of the connected load in an electrical circuit may function ___ |
| 4931 | Identification of the circuit conductors, either by ___ -coding, or by an effective ___ system |
| 4932 | In a DC circuit or in a single-phase resistive AC circuit, the product of the line ___ times the line |
| 4933 | Going into a 3-phase motor or transformer, the 3-phase ___ wiring configuration is referred to as a voltage divider |
| 4934 | The conductive material employed (steel, copper, or aluminium) and the cross-sectional of the circuit conductors are the ___ |
| 4935 | To protect the conductor insulation by preventing the conductors, normally in the form of round wires, from ___ |
| 4936 | This conductor can be left bare, or when insulated, it must be colour-identified ___ |
| 4937 | The power factor (pf) will always be ___ |
| 4938 | A switch to provide ___ control; and an overcurrent protection device to provide ___ control |
| 4939 | A(n) ___ is labelled or referred to as a voltage device because it stores electrical energy |
| 4940 | In terms of power calculations of a single-phase AC circuit, the apparent power available from ___ |
| 4941 | The power factor (pf) of an AC circuit will always be a value ___ |
| 4942 | The rating of the _________ determines how much electrical current the load will receive |
| 4943 | Circuit conductors with inadequate wire size present a higher value of resistance to the flow of ___ |
| 4944 | For small-scale electrical-power generation, the generation of AC power is ___ |
| 4945 | Power lost as wattage along the length of the circuit conductors is dissipated as ___ |
| 4946 | When a change in the magnitude of the circuit current occurs, is described as the ___ power |
| 4947 | The power factor of an AC circuit is the ratio of the ___ power to (divided by) ___ power |
| 4948 | The power factor of an AC circuit is the ratio of the ___ power to ___ power of the circuit |
| 4949 | In terms of power calculations of a 3-phase AC circuit, the apparent power available from a feeder is ___ |
| 4950 | ___ overcurrent normally involves an accidental cross-connection of at least two circuit conductors |
| 4951 | Without some form of overcurrent protection device installed in series with the ___ |
| 4952 | An inductor is ___ |
| 4953 | A(n) ___ consists of two or more conductive plates with an insulating, non-conducting plate dielectric |
| 4954 | A(n) _______________ consists of two or more conductive plates with an insulating, non-conducting plate |
| 4955 | The ____________ required by a connected load will dictate the size of wires installed |
| 4956 | The most economical way to mass-produce AC power is by steam turbines that drive large ___ AC generators |
| 4957 | The three major categories or divisions (types) of overcurrent are ___, ___, and ___ |
| 4958 | Three-phase AC power is the more common form of ___ |
| 4959 | At the standard 60-Hz electrical-power distribution frequency, the ____________ of the circuit |
| 4960 | ___ overcurrent is a short-circuit between one of the ungrounded circuit conductors and the metal enclosure |
| 4961 | A(n) _______________ is manufactured as a wound or spiral-wrapped coil of continuous wire |
| 4962 | The acronym AC stands for ____________ current |
| 4963 | The stored power, which is returned to the circuit either by the capacitor, when a change in the magnitude of the circuit ___ |
| 4964 | The means of ___ control in an electrical circuit is normally in the form of a switch |
| 4965 | ___ electricity is a convenient means of generating large amounts of power at one location |
| 4966 | ___ overcurrent, which is a very low resistance connection between one of the ungrounded circuit conductors |
| 4967 | The circuit conductors within an electrical circuit must be ___ |
| 4968 | One of the circuit conductors in other-structure electrical-power distribution system is ___ |
| 4969 | The magnitudes of the 3-phase AC line current are 173% greater than ___ |
| 4970 | ___ current(s) that can destroy circuit conductors or wiring equipment |
| 4971 | The 3-phase AC line ___ and the individual single-phase winding ___, measured |
| 4972 | Together, the two ___ electrical-degree alternations in AC power generation equals one cycle |
| 4973 | The means of ___ control in an electrical circuit is normally an overcurrent protection device |
| 4974 | In a 3-phase resistive AC circuit, the product of the ___ times the line ___ times |
| 4975 | A 3-phase AC line conductors appear to be in parallel; the transformer is connected in a 3-phase ___ |
| 4976 | All AC circuits other than purely resistive AC circuits have another element that offers ___ |
| 4977 | A(n) _______________ is labelled or referred to as a current device |
| 4978 | The basic electrical circuit for generated electricity, ___ consists of a power supply |
| 4979 | For a small-scale electrical-power generation, the generation of AC power is ___ |
| 4980 | Lightning and friction are sources of ___ electricity that must be controlled normally |
| 4981 | Coming out of transformer, the 3-phase ___ wiring configuration is referred to as a current multiplier |
| 4982 | A switch to provide ___ and an overcurrent protection device to provide ___ control |
| 4983 | The rated-load current of the electrical utilization equipment, such as luminaires is described as a(n) ___ |
| 4984 | The distinctive ___ colour of insulation along its length identifies this specific conductor |
| 4985 | The ___ power, represented by the acronym of VA or kVA |
| 4986 | In the United States, the utility electrical power transmission frequency is held at ___ Hz |
| 4987 | In terms of thousands (k) of circular mils (c mil) area in a range of ___kcmil to ___kcmil |
| 4988 | When a switch is placed in series with the supply power, ___ control has been added |
| 4989 | Generators or alternators, motors, transformers, solenoids for valves are all ___ loads |
| 4990 | In terms of insulated circuit conductors, the National Electrical Code lists wire sizes in ___ |
| 4991 | An inductor __________ |
| 4992 | The ___ power, represented by the acronym of VA or kVA, is the power supply circuit |
| 4993 | The flow of ___ in an electrical circuit is actually the forced movement of electrons |
| 4994 | The basic electrical circuit generated electricity or static electricity, consists ___ |
| 4995 | When electricity is generated by friction, the transfer of free electrons from ___ |
| 4996 | The 3-phase AC line ___, measured between any two of the three supply lines |
| 4997 | The ___ mechanical-degree displacement within the alternator generates an electrical displacement |
| 4998 | The components required for electrical induction to take place in a generator include ___ |
| 4999 | In ___ current circuits, the current flow in the electrical circuit alternates directional flow |
| 5000 | The rated ampacity of given wire size is normally defined as the magnitude of ___ |
| 5001 | The resistance is used to determine the wire’s rated ___ according to wire |
| 5002 | __________ overcurrent is self-defining |
| 5003 | The circuit conductors within an electrical circuit must be ___ to ensure that current is directed |
| 5004 | The power factor of an AC circuit is the ratio of the ___ power to the ___ power of the circuit |
| 5005 | The length of the electrical circuit must be ___ to provide a single path for the current to flow |
| 5006 | The 3-phase AC line conductors, the alternator, motor, or transformer is connected in a 3-phase ___ configuration |
| 5007 | The rms values of voltage or current normally are referred to as the ___values of power |
| 5008 | The excessive voltage drop will cause excessive ___ buildup |
| 5009 | The forced flow of free electrons in an electrical circuit, whether AC or DC, is always from ___ |
| 5010 | The flow of voltage in an electrical circuit is actually the forced movement of ___ |
| 5011 | The overcurrent protection device supplying an electrical circuit is ____ |
| 5012 | In a 3-phase __________ wiring configuration: The 3-phase AC line voltage, measured |
| 5013 | A(n) ________ condition is a controlled overcurrent situation, normally of low magnitude |
| 5014 | The forced flow of free electrons in an electrical circuit, whether AC or DC, is always ___ |
| 5015 | For data processing and other types of electronic (solid-state) equipment where the energy ___ |
| 5016 | The capacitor ______ |
| 5017 | For data processing and other types of electronic (solid-state) equipment where ___ |
| 5018 | Wattage, which is representative of the work being done, whether it is heat, light, or ___ |
| 5019 | The magnitude of the _______ required by a connected load will dictate the size of wires |
| 5020 | ________ overcurrent normally involves an accidental cross-connection |
| 5021 | __________ overcurrent is self-defining: |
| 5022 | The rated ______ of given wire size is normally defined as the magnitude of load current |
| 5023 | The ______ mechanical-degree displacement within the alternator generates an electrical displacement |
| 5024 | Together, the two _______ electrical-degree alternations in AC power generation equals |
| 5025 | The magnitudes of the 3-phase AC line ___ and the single-phase AC winding ___ are equal |
| 5026 | The status of the ______ determines when load will receive electrical current |
| 5027 | The rated ampacity of the circuit conductors, the full-load current rating of the ___ |
| 5028 | In general, circuit conductors must be provided with a means of ___ |
| 5029 | The resistance is used to determine the wire’s rated ___ according to wire size |
| 5030 | The power factor of an AC circuit is the ratio of the ___ power to ___ power |
| 5031 | As shown in the AC power triangle: Wattage, which is representative of the work being done ___ |
| 5032 | When the respective ends of the individual single-phase windings in a 3-phase alternator ___ |
| 5033 | In terms of power calculations of a 3-phase AC circuit, the apparent power available ___ |
| 5034 | As shown in the AC power triangle: The ______ power of the AC circuit is the hypotenuse |
| 5035 | A capacitor __________ |
| 5036 | The generation of electrical power within the alternator of a single-phase ___` |
| 5037 | ______ current(s) (is) are high-magnitude fault overcurrent(s) that can destroy circuit conductors |
| 5038 | When the respective ends of the individual single-phase windings in a 3-phase alternator, motor, or transformer are ___ |
| 5039 | For the majority of the generated ____________ to be applied to the connected load |
| 5040 | Any value or magnitude of current that is greater than (in excess of) the rated-ampacity of ___ |
| 5041 | The required rated-load ampacity of the circuit conductors determines the required wire ____ |
| 5042 | The switch used to control the operation of the connected load in an electrical circuit may function ____ |
| 5043 | When the three principal components of an electrical circuit are series-connected ___ |
| 5044 | A non-circuit conductor that has been intentionally grounded and must be installed or ___ |
| 5045 | For electrical induction to take place in ___ |
| 5046 | The acronym DC stands for __________ |
| 5047 | The rated ampacity of the circuit conductors, the full-load current rating ___ |
| 5048 | Generators or alternators, motors, transformers, solenoids for valves and for relays ______ |
| 5049 | To protect against the flow of high-magnitude fault overcurrent, the wires ___ |
| 5050 | For the electrical energy or power to be effectively transmitted or transferred from ___ |
| 5051 | The connected loads can be supplied as a 2-wire branch circuit at either __________ volts |
| 5052 | There are other sources of ___ electricity, such as lightning or friction |
| 5053 | In terms of power calculations of a 3-phase AC circuit, the apparent power ___ |
| 5054 | There are two types of electrical-circuit current: ___ |
| 5055 | The generation of electrical power within the alternator of a single-phase or 3-phase AC electrical-power distribution system creates a ______ |
| 5056 | The most economical way to mass-produce AC power is by steam turbines that drive large __________ AC generators |
| 5057 | The electrical energy stored in a reactive load is released back into the circuit when circuit conditions ___ |
| 5058 | The overcurrent protection device in an electrical circuit is designed or rated to protect ___ |
| 5059 | The magnitudes of the 3-phase AC line ___ are 173% greater than (times 1.732) the single-phase AC winding ___ |
| 5060 | In terms of power calculations of a single-phase AC circuit, the apparent power available from a feeder or branch circuit is simply the product of line ____ times line _____ |
| 5061 | When an overcurrent protection device is placed in series with and ahead of the control switch, then _______ control has been added |
| 5062 | In a 3-phase _______wiring configuration: The 3-phase AC line voltage, measured between any two of the three supply lines in the 3-phase alternator, motor or transformer, is |
| 5063 | The _______ power of an AC circuit is the hypotenuse of the power triangle |
| 5064 | The rms values of voltage or current, normally referred to as the _____ values of power |
| 5065 | In general, circuit conductors must be provided with a means of overcurrent protection _______ |
| 5066 | ______ overcurrent can occur only if the electrical power distribution system is referenced to earth ground |
| 5067 | Reactance does not effectively dissipate electrical resistance as ______ |
| 5068 | All AC circuits (other than purely resistive AC circuits) have another element that offers a type of resistance to the flow of electrical current______ |
| 5069 | The magnitude of short-circuit overcurrent is normally less than the magnitude of ground-fault overcurrent available from the same transformer |
| 5070 | A compressor seal is required to prevent ___ |
| 5071 | The purpose of a condenser in a refrigeration system is ___ |
| 5072 | The refrigeration compressor’s operating control that uses a bimetal element is a ___ |
| 5073 | The expansion valve in a refrigeration system |
| 5074 | The oil-pressure failure switches of a mechanical refrigeration system |
| 5075 | The safety control that uses a current transformer with a resistor in the motor circuit is known as ___ |
| 5076 | About the Electrical MCQ category |
