Reading: Voltage Control Methods at Distribution System
Inst Tools > Blog > Transmission & Distribution > Voltage Control Methods at Distribution System
Last updated: September 19, 2016 2:54 am
2 Min Read
All the equipments connected to the power utility system is designed to be used within the voltage range. Voltage drop exist in each part of the system. Consumers who are electrically connected on the primary distribution feeder near to the substation will have maximum voltage levels compared to consumers who are located at the tail end or far end of the distribution (higher voltage drops attributes to the poor voltage levels).
But for satisfactory operation of the electrical equipment voltage levels to these equipment’s should be within the operational range. Therefore in order to provide supply voltage within prescribed limits some voltage correction or voltage control measures should be taken.
Some of the methods available to achieve voltage control at the distribution end of the power system are explained below:
Voltage Control Methods:
  • By operating grid or main sub-distribution on load/off load tap changing arrangement of the transformer.
  • By addition of extra feeders. This reduces the load carrying of the feeder and hence results in reduced voltage drop and improve regulation
  • By increasing the conductor sizes of the existing conductors. This reduces the losses in thee conductor resulting in improvement in the voltage profile
  • By rearrange the system and transfer loads
  • By balance load between different phases
  • Converting thee single phase system or single wire earth return system to three phase system
  • By adding distribution transformer capacity
  • By altering tap settings on the distribution transformers
  • Providing line drop compensator such as shunt capacitors for improving the power factor and series capacitors for improving the voltage profiles and stability of the system. Switching on and off theses devices whenever they are necessary
  • By installing voltage regulators at the distribution side
  • Increase distribution voltage levels.
Advantages of Suspension Insulators and Pin type Insulators
Advantages & Disadvantages of AC and DC Power Transmission
Current Limiting Reactors in Power System
Electrical Power Transmission And Distribution
Advantages of HVDC transmission
Comparison of HVDC transmission and HVAC transmission
Charging Currents in Transmission Lines
Classification of Transmission Lines
Single Phase Earth Return System Advantages & Disadvantages
Surge Impedance Loading of Transmission Line
Insulating Material for Cable Requirements
Conductor Size Selection in Distribution Power System
Advantages of Bundled Conductors in Transmission Lines
Electrical Power Distribution
Electrical Contactor, Switch, Circuit Breaker
Difference between Solid Conductor and Stranded Conductor
pressure switch ladder-logic diagram
Draw the appropriate Pressure Switch Symbol ?
Transmission and Distribution Objective Questions and Answers
175+ Transmission and Distribution Objective Questions and Answers
Microwave Barrier Level Switch Working Principle
Partial Stroke Testing Device (PSD) in SIS Final Control Element
Purpose of Stop in a Pressure Measuring Instrument
Yokogawa DCS CPU
System Cabinet Health Checks – PLC and DCS Industrial Automation
What is a Spare Part
What is a Spare Part? Classification, Cost, Critical Inventory
