Reading: Standard Test Signals Objective Questions
Inst Tools > Blog > Multiple Choice Questions > Standard Test Signals Objective Questions
Last updated: November 27, 2021 5:41 pm
1. A feedback control systems has the inherent capability that its parameter can be adjusted to alter both its transient and steady state responses.
a) True
b) False
Answer: a
Explanation: Feedback’s inherent capability is that its parameter can be adjusted to alter both transient and steady state responses as together they are referred to as time responses.
2. Transient response analysis is done for_________ systems.
a) Unstable
b) Stable
c) Conditionally stable
d) Marginally stable
Answer: b
Explanation: In case the system happens to be unstable, we need not proceed with its transient response analysis.
3. The input signals to control systems are not known fully ahead of time, the characteristics of control system which suddenly strain a control system are:
a) Sudden shock
b) Sudden change
c) Constant velocity and acceleration
d) All of the mentioned
Answer: d
Explanation: System dynamic behavior for analysis and design is therefore judged and compared under standard test signals.
4. Standard test signals in control system are:
a) Impulse signal
b) Ramp signal
c) Unit step signal
Answer: d
Explanation: Standard test signals are impulse, ramp and unit step all of the above to test the dynamic behavior of the control system.
5. The nature of transient response is revealed by ______________
a) Sine wave
b) Cos wave
c) Tan wave
d) Test signals
Answer: d.
Explanation: The nature is dependent on system poles not on the dynamic inputs.
6. It is generally used to analyze the transient response to one of the standard test signals.
a) True
b) False
Answer: a
Explanation: For analyzing transient response mainly step is used and also other signals mainly ramp and parabolic are not used for this analysis but they are used for steady state analysis.
7. Step signal is the signal whose values is :
a) 1 for all values greater than zero
b) Indeterminate at zero
c) It is zero for time less than zero
Answer: d
Explanation: Step signal is the signal whose value varies from zero to level in zero time.
8. Ramp input :
a) Denotes constant velocity
b) Value increases linearly with time
c) It denotes constant velocity and varies linearly with time
d) It varies exponentially with time
Answer: c
Explanation: Ramp signal denotes constant velocity and also basic definition states that its value increases linearly with time.
9. A perfect impulse has one value at zero time instant but otherwise zero elsewhere.
a) True
b) False
Answer: b
Explanation: A perfect impulse signal has infinite value at zero but mathematically only a small pulse is taken with finite limits.
10. To find system’s response by means of convolution integral ____________ of the system is used.
a) Sum
b) Difference
c) Exponential
d) Weighing
Answer: d.
Explanation: Impulse response of a system is the inverse Laplace transfer function of its Laplace function.
Pneumatic Control Mechanisms Objective Questions
State Variable Analysis – Part I
Measurement and Instrumentation Objective Questions – Part 1
Liquid Chromatograph- Mass Spectrometer
Effect of Adding a Zero to a System – II
pH Meters Questions & Answers
Robotic Control System – Part I
Time Response of First Order Systems Objective Questions
Combination Electrode Questions & Answers
Mass Spectrometer Questions & Answers
Stability Analysis
Feedback Compensation
Construction of Phase -Trajectories
Control Systems Multiple Choice Questions
Advances in Control System
Fuzzy Logic Control
Fundamentals of Radiochemical Methods Questions
Control Valves Multiple Choice Questions
Hydrocarbons Questions & Answers
Root Locus in Control Systems
Quadrupole Mass Spectrometer
Biosensors Questions & Answers
Nonlinear Control Systems
Introduction to Protective Systems
pH Analyzer Do’s and Don’ts
Database for each safety module
Global Acknowledgment Instruction in Safety PLC
Pirani Gauge Working Principle
Smart DP transmitter Formula
DP Transmitter Error Calculations
Intrinsic Safety of Instruments
Intrinsic semiconductors
Introduction to Semiconductor Electronics – Types, Materials
0-10 VDC to 0-20 mA Conversion
How to Convert Voltage to Current using Resistor ?
