Reading: Single Phase Earth Return System Advantages & Disadvantages
Inst Tools > Blog > Transmission & Distribution > Single Phase Earth Return System Advantages & Disadvantages
Last updated: September 19, 2016 2:53 am
2 Min Read
Generally in secondary distribution system, single phase two wire distribution system is generally followed. But for remote distribution systems in rural areas single phase ground return system has found economical. In this system earth is used as return conductor and only one phase wire or conductor is used. This system requires grounding rods deep into the soil at each consumer’s site in order to establish a sufficiently low impedance to the ground. This single phase earth return system has certain limitations like increase in earth potential and interference with telecommunication lines. Some of the advantages and disadvantages of single phase earth return systems are:
Advantages:
  • Single Phase earth return system is economical to the extent of 30-40 percent conventional three phase system under favorable conditions. The galvanized steel line conductor system affords further economy
  • Better voltage regulation which is the main problem in long conventional feeders
  • Improved power factor as compared to the conventional system, nearly about 0.95 whereas conventional system usually have power factor between 0.7 to 0.8
  • The outage on the single wire earth return system are comparatively lesser than on the conventional system due to the less number of components per span
Disadvantages:
  •  Maximum ground return current permitted is 7 to 8 amps. This limitation is to avoid communication interference and safety hazards due to voltage gradient. A 1:1 isolation transformer is used to minimize the possibility of telephone interference
  • Maximum power limit of distribution of single wire earth return system is limited up to 3 to 3.5kVA/km of the line
  • Particular configuration and the maintenance of the earth electrode is an important point while adopting this system
  • Single phase earth return system without the isolation transformer may create extraordinary interference with the telecommunication circuits
Classification of Transmission Lines
Difference between Solid Conductor and Stranded Conductor
Surge Impedance Loading of Transmission Line
Conductor Size Selection in Distribution Power System
Electrical Power Transmission And Distribution
Comparison of HVDC transmission and HVAC transmission
Current Limiting Reactors in Power System
Insulating Material for Cable Requirements
Advantages of HVDC transmission
Charging Currents in Transmission Lines
Electrical Power Distribution
Advantages of Bundled Conductors in Transmission Lines
Advantages & Disadvantages of AC and DC Power Transmission
advantages-of-suspension-insulators-and-pin-type-insulators
Advantages of Suspension Insulators and Pin type Insulators
Why is IEC 60269 Important
Why is IEC 60269 Important? – Electrical Applications
Industrial Drives Multiple Choice Questions and Answers
Immersion Electrical Heaters
Single and Three Phase Immersion Electrical Heaters Wiring Circuits
Instrument Calibration Lab Exercise
Programmable Logic Array Objective Questions
Two-Liquid Manometer Principle
Actuators Questions and Answers
RTD lead resistances Wiring
Resistance Temperature Detectors Working Principle
