Reading: 400+ Power Systems Projects – Best Electrical Project Ideas
Inst Tools > Blog > Projects > 400+ Power Systems Projects – Best Electrical Project Ideas
Explore over 400 innovative Power Systems Projects ideal for electrical engineering students and enthusiasts.
Last updated: July 12, 2024 11:09 am
Projects
37 Min Read
Explore over 400 innovative Power Systems Projects ideal for electrical engineering enthusiasts. Discover the best electrical project ideas spanning VSC-HVDC links, renewable energy integration, smart grid technology, and power quality improvement.
These electrical projects are perfect for students, researchers, and professionals seeking to enhance their knowledge and skills in the dynamic field of electrical engineering.
S.No.Projects
1Running DFT Techniques Based Reference Current Computation for Active Power Filters
2Grid Connected Variable-Speed Wind Turbine System Fuzzy Pitch Angle Control
3Regional Power Systems Load Fluctuation Modeling Using Data Analytics
4Speed Control of BLDC Motors Using Neural Adaptive Reference Models
5Fault Tolerant Operation of Bidirectional AC/DC Converters Under Unbalanced Grid Voltages Using Finite States Model Predictive Control
6AC/DC Microgrids Energy Management using Bridge Type Fault Current Limiter
7Impact of Switching Harmonics on Capacitor Cells Balancing in Cascaded H-Bridge STATCOM
8Novel Three-Phase to Five-Phase Transformation Using Special Transformer Connection
9Economic Operation of Autonomous AC, DC, and Hybrid Microgrids Decentralized Control Strategy
10Dual-Stage Isolated Multilevel Inverter for Single-Phase Solar Energy Processing
11Multitaper Detection Methodology for Periodic Forced Oscillations in Power Systems
12Smart Grids Networked Control Stability Analysis
13Four-Pole Induction Motor Drive Quad Two-Level Inverter Configuration
14Control Strategies and Integration Techniques for Grid-Connected PV Systems
15High Performance and Enhanced Reliability Concept for a Modular Fuel Cell, Modular DC–DC Converter
16Ripple Eliminators Control to Improve DC Systems Power Quality and Reduce Electrolytic Capacitors Usage
17Induction Motor Sensorless Stator Field-Oriented Direct Torque Control with SVM
18Fuzzy Logic Based MPPT for Wind Energy Conversion Systems
19Decentralized Optimal Frequency Control in Autonomous Microgrids
20Smart Grid Stability Prediction with Real-Time Sliding-Window Model Reduction
21Zero-Sequence Circulating Current Control in Parallel Converters with Space Vector Modulation
22Load Transformers Inrush Mitigation for Series Voltage Sag Compensator
23High Gain Bidirectional DC-DC Converter Implementation for Photovoltaic On-Grid Systems
24Strong/Weak Grid Scenarios Battery Connected DFIG Wind System Analysis
25Feedback Linearization for Direct Torque Control in Induction Motor Drives
26Hybrid Wind Farm Capacity Configuration and Coordinated Operation with FSIG and PMSG-Based Systems
27Voltage and Power Stability Electric Spring for Power Factor Correction
28Grid-Side Fault Protection in Grid-Connected VSIs
29New Master Controller Model Application Guidelines for STATCOM Control in Dynamic Analysis
30Solar PV Array Fed Water Pumping System with BLDC Motor Using Zeta Converter
31Nonlinear Control of Bidirectional Power Converters in DC Microgrids
32Standalone Wind-Based Energy Storage Generation Unit Modelling and Robust Control Design
33Hybrid AC/DC Microgrid Power Management with Multiple Subgrids
34Autonomous PV-Array Excited Wind-Driven Induction Generator for Off-Grid Applications in India
35Islanding Detection in Distributed Generation Using Fuzzy Rule-Based Approach
36Reliability-Centric Networking Planning for Meshed VSC-HVDC Grids
37Sensorless DC-Side Cascaded H-Bridge Multilevel Converter Based Photovoltaic System
38PV System Integration Using DC/DC Z-Source Converter
39Root-Locus Design Methodology for LCL Grid-Connected Converters in Wind Turbines
40Permanent Magnet Synchronous Generator Based Wind Turbine Control Strategies
41Induction Motors Speed Control Hybrid PID Plus Fuzzy Controller Design
42Power Quality Improvement Supported by DSTATCOM Induction Generator
43Asymmetric Fault Ride Through Capability Enhancement of DFIG Based Wind Generator
44Weak-Grid Connection Enhancement for Wind Farms Using UPQC Custom Power Device
45Hybrid Series Active Power Compensator for Power Quality Improvement in Typical Households
46Non-Sinusoidal Input Source Single-Phase Shunt Active Power Filter Implementation
47Common Mode Voltages Elimination Multilevel Inverter Modulation Schemes
48Unified Power Quality Conditioner for Single-Phase Electric Power Distribution Grids
49Constant Switching Frequency Deadbeat Predictive Control for Synchronous Permanent Magnet Motor Drives
50Grid-Connected PV-FC Hybrid System Power-Management Strategies
51VSC HVDC Hybrid Simulation Model
52Single Phase Micro-Sources Operation and Control in a Utility Connected Grid
53Harmonic Elimination in Single Phase Systems via Hybrid Series Active Filter
54Random Forest Regression Based Space Vector PWM Inverter
55Online Parameter Estimation Method for Indirect Field Oriented Induction Motor Drives
56Node Voltage Level and Stability Estimation, Control, and Prediction Techniques
57High-Power Fuel Cell Converter with Direct Double-Frequency Ripple Current Control
58Dynamic and Stability Considerations in Meshed Multiterminal HVDC Networks
59Enhanced-Boost Quasi-Z-Source Inverters with Switched Impedance Networks
60Modulation and Control Strategies for Transformerless Unified Power Flow Controllers
61Switched-Doubly-Fed-Machine Propulsion Drive Bumpless Automatic Transfer
62Frequency and Voltage Control in Hybrid AC/DC Microgrids for Economic Operation
63Bidirectional DC-DC Coupled Multi-Input Transformer for PV-Wind-Battery-Based Grids
64Mechanical Resonance Damping in Wind Power Generators for Frequency Regulation
65MATLAB Simulink-Based MPPT Controllers and PV Cell Analysis
66Microgrid Voltage and Current Harmonics Compensation Using Dual-Interfacing-Converters
67Synchronous Generator Control Design in Horizontal Axis Wind Turbines
68Low-Complexity Three-Vector Based Model Predictive Direct Power Control for DFIG
69Hybrid Excited Flux Bidirectional Modulated Generator Based Wind Power Generation System
70Three-Phase High Power Shunt Active Power Filter Dynamic DC-Bus Voltage Control Strategies
71Versatile Unified Power Quality Conditioner for Three-Phase Four-Wire Distribution System
72Grid-Connected Photovoltaic Power System Design and Analysis
73Diagnosis of Single-Phase Open-Line Fault in Three-Phase PWM Rectifier with LCL Filter
74VSC-HVDC Connected Offshore Wind Farms Fault Ride Through and Grid Support Topology
75Implementation of Novel Soft-Switching Configurations
76DC-link Control Filtering Options for Torque Ripple Reduction in Wind Turbines
77Closed Loop Control of Six Pulse DC Link Three Phase Inverter without Electrolytic Capacitors
78Control Strategies for Diode-Assisted Buck-Boost Voltage Source Inverters
79Universal Filtering Capability of Single-Stage Three-Phase Grid-Tied PV Systems
80Induction Machine Model Implementation in Simulink
81Multi-Level Converter for Open-Ended Winding Motor Drives with a Floating Bridge
82Power Factor Correction and Drive Efficiency in Hybrid Resonant PWM-Fed BLDC Motors
83Modified p-q Theory Based Control of Solar PV Integrated UPQC-S
84Brushless DC Motors Current Control Scheme Driven by Four-Switch Three-Phase Inverters
85Single-Phase Grid-Connected Photovoltaic Inverter with Three-Switch Three-Port Flyback
86Advanced Current Source Inverter Designs for Multi-Level Applications
87SiC-Based Cascaded Multilevel Converter Cell Control for Solar Applications
88Advanced Control of Bidirectional DCDC Converters and ACDC Interlinking Converters
89Wide Voltage-Gain DC-DC Converter and Differential Power Processors for DC Microgrids
90DFIG-Based Wind Power Systems Frequency Control Using Switching Angle Controller
91Real-time Implementation of a Three-phase THSeAF with VSC and P+R Controller for Power Quality Improvement
92Sensorless Power Reserve Control Strategy for Two-Stage Grid-Connected PV Systems
93Grid Interfaced DFIG Based Variable Speed Wind Energy Conversion System with Power Smoothing
94Multilevel Cascaded H-Bridge Inverter Employing Dynamic Voltage Restorer
95Adaptive Harmonic Compensation in Residential Distribution via Roof-Top PV Systems
96Three-Phase Loads Power Quality Improvement of PMSG Based DG Set
97Transient Projective Integration Methodology
98Hybrid System Approach to Direct Torque Control of Induction Motors
99Middle Frequency Resonance Analysis in DFIG Systems with Phase Locked Loop Consideration
100Dynamic Voltage Restorer Real-Time Simulation Utilizing RTDS and dSPACE
101Hybrid Control Strategies for Power System Stabilization Energy Dissipation
102DSTATCOM and DG Optimal Placement Strategies
103Expanded Wind Speed Range Circuit Configuration and Control of Grid-Tie Small-Scale Wind Generation Systems
104Non-Ideal Mains Voltages New Simple Control Strategy for Shunt Active Power Filters
105Unified Inter-Phase Power Controller for Wind Farms Power Flow Control and Short Circuit Limitation
106Best Practices in Switching for Power System Reliability Improvement
107Induction Motor Drive VSI-Based Current Sensor Fault Diagnosis and Tolerant Control
108Decoupled Control Strategy for Modular Multilevel Matrix Converters in Fractional Frequency Systems
109Quasi-Z-Source Topology Based Single-Phase AC-AC Converter
110General Constant Power Generation Algorithm for Photovoltaic Systems
111Grid-Tied PVG System Efficient Single Phase Transformerless Inverter with Reactive Power Control
112Design and Implementation of Wind Turbine Variable Synthetic Inertia Controllers
113Single-Phase Grid Controlled Wound Rotor Machine with Isolated Inverter
114Enhancing Frequency Regulation in Remote Power Systems via Multilevel Energy Storage
115Flexible Power Electronic Transformer Design
116Multilevel Current Source Inverter Applications for Balanced and Unbalanced PV Sources
117Direct Model Predictive Control of Bidirectional Quasi-Z-Source Inverters for PMSM Drives
118Three-Phase Four-Leg VSI Topology Dynamic Hysteresis Current Control to Minimize Switching
119Switched Inductor Multilevel Boost Converter Design
120PID Controlled Dynamic Voltage Restorer for Enhanced Power Quality
121Performance Improvement of Voltage Controlled DSTATCOM with External Inductor Design
122ESO-Based Inertia Emulation and Rotor Speed Recovery Control for DFIGs
123Three-Phase Four-Leg Active Power Filter Inverse Control
124Transformerless Medium-Voltage STATCOM Design
125Hybrid Framework for Short-Term Risk Assessment in Wind-Integrated Composite Power Systems
126Modified Weibull Distribution Models for Power System Reliability Forecasting
127Sensorless Speed Control in Brushless DC Motors
128State Space Control Enhanced AC-Current Control for Solar String Inverters
129Nonlinear Control Implementation of STATCOM
130Bridge-Type Solid-State Fault Current Limiter Based on ACDC Reactor
131Constant Power Loads Robust Stability Analysis in DC Microgrids
132Voltage Harmonic Distortions and Unbalance Impact Assessment Power-Quality Index for Three-Phase Induction Motors
133Compact Fluorescent Lamps High-Power-Factor Single-Stage Single-Switch Electronic Ballast
134Autonomous Wind-DG Microgrid Back Propagation Algorithm Based Controller
135Speed Sensorless Control of Electrical Drives Using a General PLL Type Algorithm
136UPQC-P Integrated Solar PV for Dynamic Performance in Critical Loads
137Nonlinear DC Microgrid Control for Photovoltaic Panel Integration
138Sensorless Stator Field-Oriented Direct Torque Control with SVM and Fuzzy Logic Regulation
139Power Factor Control in Open-Ended Winding Motor for High Efficiency Operation
140Load Flow Analysis in AC-DC Hybrid Distribution Systems Using a Generalized Approach
141Transformerless UPFC Modulation and Control
142Adaptive Control Scheme for Solar Photovoltaic Systems Integrated into AC Distribution Systems
143Multi-Objective Demand Side Management with Object-Oriented Usability Indices
144Direct Drive PMSG-Based Wind Energy Conversion Systems Discrete-Time Direct Torque Control
145Permanent Magnet Wind Turbine Distributed Generation System with Power Management via Solid-State Transformer
146Grid-Connected PV-Wind-Battery Multi-Input Transformer Coupled Bidirectional DC-DC Converter
147Mode Decoupling STATCOM Design for Voltage Control of Wind-Driven Induction Generator Systems
148Rapid Impedance-Based Stability Assessment MIMO-Identification Techniques for Three-Phase Systems
149Power System Stability Enhancement Using Energy Storage with Fuzzy Logic Controller
150Voltage Balancing Mechanism for Cascaded H-Bridge STATCOM
151Mid-Voltage Flexible HTS DC System in Closed-Loop Distribution Networks
152DC-DC MMC for HVDC Grid Interface in Utility-Scale Photovoltaic Systems
153Resonant vs. Conventional Controllers in Grid-Connected Photovoltaic Power Plants
154LCL Filter-Based Improved Solar Array Simulator Topology
155High Performance Fuzzy Logic Controller for Induction Motor Drive System
156Autonomous Operation Controlled Power Point Tracking for PMSG Based Wind Energy Systems
157Space Vector Modulation Based Novel Direct Torque Control with Adaptive Stator Flux Observer for Induction Motors
158DC-link Capacitor Harmonic Current Reduction in Back-to-Back Converters
159Fault Current Estimation in Multi-Terminal HVdc Grids with Modular Multilevel Converter Control
160Wind Farm Integrated Power System Load Damping Co-efficient Frequency Sensitivity Analysis
161Parallel Connected Inverters Control in Standalone AC Supply Systems
162Enhanced Frequency Response Strategy for Remote Area Power Supply Systems Using PMSG
163Railway Distribution System Fault Location Enhancement Using Superimposed Signal
164Islanded AC Microgrid Voltage Unbalance and Harmonics Compensation Enhanced Power Sharing Scheme
165Power Quality Enhancement in AC Microgrids Using Four-Leg Hybrid Electric Springs
166Switched Reluctance Motor Drives Quasi-Z-Source Integrated Multi-port Power Converter
167Integration and Stability of Solar and Wind Energy in Smart Grids
168Sliding Mode Control Design for SEPIC Converters
169Grid Interfaced Control of Wind Turbines with Induction Generators Using Power Electronics Converters
170High Voltage Grid Connected Symbiotic Operation of Wind and PV Farms
171Fuel Cells Three-Phase Interleaved DC-DC Converter with Active Clamp
172PV Cells Working Region and Stability Analysis Under Peak-Current-Mode Control
173Single Stage Three-Phase Grid Integrated Solar PV System Control Algorithm
174Improved Transformer Winding Tap Injection DSTATCOM Topology for Medium-Voltage Reactive Power Compensation
175Virtual Resistor and Capacitor Droop Control in HESS for Medium Voltage DC Systems
176Low Capacitance Direct Torque and Feedback Linearization in Induction Motor Drives
177Three Port Converters in Distributed DC Grid-Connected PV Systems
178Induction Motor Protection and Fault Detection Sensors
179Direct Torque Control of T-NPC Inverters for Double-Stator-Winding PMSM Drives with SVM
180Adaptive Fuzzy Dividing Frequency-Control Method Based Development of Hybrid Active Power Filter
181Capacitor-Supported Interline DVR Fast Dynamic Control Scheme Implementation
182Wide Compensation Range Hybrid-STATCOM with Low DC-Link Voltage
183Harmonics Rejection in Stand-Alone DFIG with Nonlinear Loads
184Variable-Speed Wind Turbine Generation Active Power and Flux Control of Self-Excited Induction Generators
185Transient Stability and Power Export Enhancement using Battery Energy Storage Systems
186Stator Voltage Sensorless DFIG with Low Voltage Ride-Through Capability
187Hybrid Photovoltaic-Diesel-Fuel Cell System Micro-Grid-Connected Operation and Control
188Permanent Magnet Synchronous Motor Controller Design
189Grid-Connected VSC Modeling for Small Signal Stability Analysis in Power Systems
190Autonomous PV-Array Excited Wind-Driven Induction Generator for Off-Grid Applications in India
191New Wind Power System Maximum Power Point Tracking Strategy and Design
192Efficiency and Reliability in Zeta Converter Hybrid Models
193Matrix Converter Voltage Vector Utilization for Torque Ripple Reduction in Direct Torque Control of Induction Machines
194Comparison of Flying Capacitor Topology in Three-Phase Wind Turbine Structures
195AC/DC Grids Optimal Power Flow: From Formulation to Implementation
196Improved Energy Storage Management and PV-Active Power Control Infrastructure
197Smooth Operation Transition Scheme for Stand-alone Power Systems with Renewable Energy Generators
198Quasi-Z-Source Wind Power Generation System Ride-Through Strategy under Asymmetrical Grid Faults
199Harmonic Loss Reduction in High-Speed Motor Drive Systems Using Flying Capacitor Multilevel Inverters
200Islanding Detection Methods for Inverter-Based Distributed Generators
201Fuzzy Neural Network-Based Adaptive Global Fast Terminal Sliding Mode Control for PV Systems
202Distributed Energy Resources for Resilient Critical Load Restoration in Power Distribution Systems
203Power Quality Enhancement in Grid Connected Wind Turbine Energy Systems
204TCSC Transient Stability Control
205Adaptive Power Oscillation Damping Controller by STATCOM with Energy Storage
206Sensorless Multilevel Inverter Design with Reduced Component Count
207Three-Port Full-Bridge Soft-Switching Converter with Secondary-Side Regulation
208Contra-Rotating Power Split Transmission System with Dual MPPT Control for Wind Power Generation
209Microgrids Connected Multiphase Energy Conversion Systems with Unequal Power Sharing
210Two-Layer Control Scheme for Maintaining Optimal Frequency Voltage in Grids
21148-Pulse GTO Interline Unified Power Flow Controller Implementation
212Isolated Full-Bridge Boost Converter Effects of Switching Asymmetry
213Solar Wind Hybrid Renewable Power System Simulation and Control
214Active Power Filters Various Control Techniques
215Dynamic Interactions from Grid-Connected PMSGs Electromechanical Oscillation Modes in Power Systems
216Improved Incremental Conductance Algorithm for Solar PV Panel MPP Tracking
217Flexible Energy Control Functions in Solar PV-Powered SRM Drive for EVs
218Stator Faults Real-Time Hardware-in-the-Loop Simulation for Permanent Magnet Synchronous Motor Drives
219Active Power Filter Control Circuit with Instantaneous Reactive Power Control Algorithm Modification
220High-Order Sliding Mode Control in Magnetic Levitation Systems
221Interlinked Operation and Control of Microgrid with Hybrid Energy Storage Systems
222Study of Maximum Power Point Tracking Techniques in Solar Photovoltaic Arrays
223AC–DC Harmonic Immunity Optimization in VSC HVDC Transmission Using Modulated Techniques
224High Current Source Three-Phase Single-Stage Grid-Connected Photovoltaic Inverter
225DC Voltage Regulation Control Scheme for Stand-Alone DFIG-DC Systems
226Receding Horizon Adaptive Second-Order Sliding Mode Control for DFIG Based Wind Turbine
227DC Bus Voltage Regulation in DC Distribution Systems with Controllable Loads
228Flexible Power Electronic Transformer Design
229Supervisory Control Method for Islanded Droop in AC/DC Microgrids
230Dual Active Bridge DC-DC Converter Optimal Phase Shift Control for Reactive Power Reduction
231Dual-Mode DC/DC Buck Converter Modeling and Simulation
232Energy Storage System Filters: Optimal Frequency Guarantee vs Energy Capacity/Power Rating Trade-off
233Variable Speed Wind Turbines Nonlinear Control Via Fuzzy Techniques
234PV Grid-Connected System Isolated Buck-Boost DC/DC Converter
235Fault Prognosis in Power Electronics Systems Using Adaptive Parameter Identification.
236High-Gain DC-DC Converter for Photovoltaic Systems and Current Injection in Nanogrids
237Continuous Time Model Predictive Control for Offset Free Direct Power Control of DFIG
238Multicell Interleaved Flyback Converter Design for High Voltage Applications
239Circulating-Current Power Phasor Model-Based Accurate Power-Sharing Control in VSI Parallel-Operation Systems
240Torque Ripple Minimization and Fast Response Strategy for Predictive Torque Control of Induction Motors
241Grid-Connected Photovoltaic System Analysis Using PSIM
242MMC Modeling Techniques Comparison in VSC HVDC Schemes
243Energy Storage Sharing in Transmission and Distribution Networks
244Renewable Energy Applications New Hybrid Boosting Converter
245Four-Switch Three-Phase Inverter-Fed Induction Motor Drives Performance Investigation at Low Speeds
246Voltage Regulation in Low-Voltage Distribution Grids for Power Quality Improvement
247Complex-Connected DFIG Wind Turbine Dynamic State Estimation Based Control Strategy
248Harmonic Reduced Three-Phase Thyristor Controlled Reactor for Static VAR Compensators
249Performance Improvement of Large Wind Farms Using Reactive Power Compensators
250Hybrid Connection Modeling and Experimental Study of Wind Turbine System with Compressed Air Energy Storage
251Analysis and Active Damping of High-Frequency Resonances in DFIG Systems
252Islanded DC Microgrid Load Sharing through Distributed Coordination of Multiple PMSGs
253Harmonic Voltage Resonance Suppression in Distribution Systems Using Active Power Filters
254Boost Converter Based Maximum Power Point Tracker for Solar Cells
255Loss Power Minimization in Distribution Systems Using Particle Swarm Optimization
256Off-Grid Application in India Autonomous PV-Array Excited Wind-Driven Induction Generator
257Reactive Power Optimization in Power Systems Using Hybrid Differential Evolution Particle Swarm Optimization Algorithm
258UPS Applications Neural Network Controller
259Low-Power Energy Conversion Systems with Two-Phase PM Machine and Reduced Controlled Switches Rectifier
260Voltage Source Inductive Filtering Converter Application Feasibility in HVDC-Light Systems
261Active Suspension Systems: Analytical and Experimental Approaches for Light Passenger Vehicles
262Optimal Dispatch in Integrated Electricity and Thermal Systems with Energy Self-Storage
263Distributed Optimal Tie-Line Power Flow Control in Multiple Interconnected AC Microgrids
264Autonomous Islanded Microgrids Coordination of Multiple PV/Battery Hybrid Units
265Zero-Current-Switching and Switching Loss-Free H6 Inverter for Single-Phase Transformerless PV Systems
266Micro Grids Integration for Power Quality Improvement Using Hybrid Energy Storage and Advanced Control
267Sensor-Free Five-Level Packed U-Cell Inverter for Autonomous Systems
268Open-End Multilevel Six-Phase Machine Drive System Using Five Three-Leg Converters
269Zero-Sequence Voltage and Negative-Sequence Current Control Scheme for Cascaded H-Bridge STATCOM
270Droop Controlled Islanded DC Microgrids: Stability and Modeling Insights
271Power System Dynamic Stability Impacts from Utility-Scale PV Energy Systems
272Fuzzy Speed Controller Based Vector Controlled Permanent Magnet Synchronous Motor Drive
273High-Efficiency Voltage Regulator Design for Rural Networks
274Synchronous Reference Frame Based Controllers for Three-Phase Four-Wire Shunt Active Power Filters
275Shared Energy Storage Systems in Transmission and Distribution Networks
276Decentralized Voltage Regulation in PV Generation Plants Using Real-Time Pricing
277High Power Efficiency and High Power Density Embedded DC-DC Buck Converter Using Switched-Capacitor
278Fast Distributed Reactive Power Control for Voltage Regulation in Distribution Networks
279Harmonics Consideration in Average-Value Modeling of Diode Rectifiers Using Multiple Reference Frame Theory.
280Series Voltage Sag Compensator Load Transformers Inrush Mitigation Technique
281Echo-State Network Control Implementation for Power Quality Improvement
282High Efficiency DC Power Electronic Transformer with Full-Bridge Converters
283Wind Turbine Control Strategy Based on PMSG and Energy Storage for Stand-Alone Systems
284Fuzzy Logic Control Parameter Optimization for Permanent Magnet Brushless Motors
285Pumped-Storage Machines Loss-of-Excitation Analysis and Protection during Starting
286Time-Delay Power Systems Primary Frequency Control Using HVDC Distributed Links
287Hybrid Multilevel Converter Implementation with Floating DC-Links for Current Waveform Improvement
288Multidimensional Droop Control for Wind Resources in DC Microgrids
289Current Compensation in Three-Phase Four-Wire Distribution System Using Reduced Rating VSC with a Zig-Zag Transformer
290Investigating Dynamic Voltage Restorer Applications with Enhanced Control Techniques
291Sliding-Mode-Controlled Cascaded Multilevel Inverter Multiband Hysteresis Modulation and Switching Characterization
292Power Quality Enhancement in Distribution System Using Combined LMS-LMF Based Control Algorithm of DSTATCOM
293Three-Phase Converter Design for Unbalanced AC Sources Using MATLAB
294Hybrid AC/DC Microgrid Autonomous Operation with Multiple Interlinking Converters
295Optimal Energy Management Strategy for Standalone DC Microgrids
296Renewable Energy Transmission in Large Power Systems Using Shunt FACTS Optimal Location and Control
297PMSM Speed Sensorless Direct Torque Control Based on Extended Kalman Filter
298Power Quality Improvement with Flyback Photovoltaic Micro Inverters
299Power Quality Improvement Novel Single-Phase Shunt Hybrid Power Filter Configuration
300New Simulation Modeling for Nonlinear Current Control in Single Phase PV Systems
301Comparative Analysis of Three-Phase Structures in Wind Turbines with Ancillary Services
302Hybrid Resonance PWM-Fed BLDC Drive with Power Factor Correction
303Wide Operational Speed Range Switched Reluctance Generator Approach in Wind Systems
304Distributed Stochastic Reserve Scheduling in AC Power Systems with Uncertain Generation
305Damped-SOGI Based Control Algorithm for Solar PV Power Generating Systems
306Adaptive Droop Control in VSC-MTDC Systems for Frequency Support
307SFCL Impact on HVDC Circuit Breakers by Simulation
308Standalone Solar Photovoltaic Hybrid System Control and Implementation
309AC Motor Vector Control System Design for Hybrid Electric Vehicles
310Programmable Testing Equipment for Battery Modeling and Simulation
311H5 Topology Development for Low Common-Mode Currents
312Adaptive Sliding Mode Control for Standalone Single-Phase Microgrids
313Data-Based Distributed Energy Resources Coordination for Active Power Provision
314PV-Battery-Based Hybrid Microgrids Unified Control and Power Management Scheme
315Innovative Charging Alternatives for Electric Vehicles
316Three-Phase AC-DC 48V Power Supply Multi-Level Configurations.
317Quad-Input-Dual-Output Buck Converter for Photovoltaic Systems Single Inductor Design
318Buck Converter Controller Design
319Single-Phase Hybrid Active Power Filter Utilizing Single Switch Parallel Active Filter and Simple Passive Filter
320DC-Link Capacitor Voltage Control for Single Phase Shunt Active Power Filter with Self-Charging Algorithm
321Convex Relaxations for Probabilistic Optimal Power Flow in Interconnected AC and HVDC Grids
322Power Systems Analytic Model for Fault Diagnosis Considering Malfunctions of Protective Devices
323Real-Time Smart Grid Stability Prediction with Sliding Window Model Reduction
324Type-4 Wind Turbines Phase Angle Calculation Dynamics during Severe Voltage Dips
325AC Microgrids Power Control and Storage Optimization with Hybrid Electric Springs
326Harmonic Consideration in Optimal Capacitor Placement and Sizing for Unbalanced Distribution Systems Using Particle Swarm Optimization
327Two-Phase PM Machine Low-Power Generation Systems with Controlled Switches
328Single-Stage DC-AC Converter for Photovoltaic Systems
329Flexible Droop Characteristics Synchronous Power Controller for Renewable Power Generation Systems
330Fuzzy Logic Control Mathematical Modeling of a Brushless DC Motor in Automobile and Industrial Applications
331Evolutionary Fuzzy Control for Optimal Energy Management of Residential PV IHESS
332VSC-HVDC Transmission Link Control with Input-Output Linearization and Robust Sliding-Mode Controller
333Asymmetric Wind Power PMSG Impedance Unbalance Compensation with External Circuits
334Three-Level Rectifiers in Wind Turbine Systems Open-Circuit Fault-Tolerant Control
335PLL-Based VSC Synchronization Instability Solutions for Weak AC Grids
336Standalone Wind Energy Conversion System Experimental Implementation with DFIG
337Nonisolated High Step-Up Boost Converter Integrated with Sepic Converter
338Open-Loop Stepper Motor Modeling and Control in Matlab/Simulink
339Flexible Energy Control Functions in Solar PV-Powered SRM Drive for EVs
340Bulk Power Systems Reliability Evaluation Incorporating UPFC
341Current Sensing Tertiary Winding Micro Inverter Development
342Enhanced DFIG Wind Turbine Performance during Three Phase Faults with Parallel Interleaved Converters
343Multiconverter Unified Power-Quality Conditioning System: MC-UPQC
344Autonomous Wind-DG Microgrid Back Propagation Algorithm Based Controller
345Induction Motor Drive Indirect Vector Control with Intelligent Fuzzy Logic Controller
346Polynomial Fuzzy Model-Based Maximum Power Point Tracking Control of Photovoltaic Systems
347Reduced Cost of Reactive Power in DFIG Wind Turbine System with Optimized Grid Filter
348Intelligent Controller-Based Maximum Power Point Tracking in Grid-Connected Wind Plants
349Rapid Voltage Regulation Flexible IQÐV Scheme for DFIG in Wind Power Plants
350Interleaved Buck Converter Modeling and Simulation Study
351Residential Solar Photovoltaic Systems Control and Grid Integration with Artificial Neural Networks
352Modified p-q Theory Based Control in Solar PV Integrated UPQC-S
353Quasi Single Stage High Reliability and Efficiency Buck Boot Inverter
354Single-Phase Multilevel Six-Leg Converter with Reduced Controlled Switches for AC-DC-AC Conversion
355Current Harmonic Detection and Photovoltaic Inverter Design with Ancillary Services
356Power Factor Correction Focused Instantaneous Power Control of D-STATCOM
357Design of a Novel Multilevel Inverter
358Transformerless Multilevel Inverter for PV Systems with Ground Connection
359Low Capacitance Multi-Level Cascaded H-Bridge StatCom
360Distributed Maximum Power Point Tracking Using Model Predictive Control in Photovoltaic Systems
361Single Phase Cascaded H5 Inverter with Leakage Current Elimination for Transformerless Photovoltaic System
362Modular Multilevel Converter-Based HVDC System Control and Characteristic Investigation
363Shunt Active Filter Implementation Using Empirical Mode Decomposition
364Predictability and Optimal Placement Strategies for Enhanced Multi-Objective Performance
365Bridgeless Converter-Based Power Quality Improved Computer Power Supply
366Three-Level Static Synchronous Compensator Research
367Solar PV Array Fed Water Pumping System with Zeta Converter for BLDC Motor Drives
36824-Pulse AC-DC Converter Employing Pulse Doubling Technique for Vector-Controlled Induction Motor Drives
369Grid-Connected PV-Wind-Battery Multi-Input Transformer Coupled Bidirectional DC-DC Converter
370Wind Power and Wave Power Generation Systems Integration Using a DC Microgrid
371Solar Wind Hybrid Renewable Power System Simulation and Control
372Dynamic Voltage Restorer (DVR) Overview for Power Quality Enhancement
373Three-Phase Active Power Filters Control Method Study
374Microgrid Steady-State Voltage Stability Analysis and Improvement
375Non-linear PWM Control and Design for Single-phase Boost Mode Photovoltaic Inverter with Grid Connection
376Smart Grids Integration for Enhanced Power Quality
377Control Algorithm for Solar PV Power Generating System with Damped-SOGI
378Current-Source Converter Design and Implementation for D-STATCOM Industry Applications
379Genetic Algorithm Based Optimal Hybrid System Sizing for Standalone Applications
380Stability-Enhanced Adaptive Droop for AC-MTDC Grid Power Sharing
381Unbalanced Microgrids DFIG Wind Power Generators Control Based on Instantaneous Power Theory
382Fixed-Speed Dish-Stirling Solar-Thermal Power Plant Primary Frequency Control Scheme
383Decoupled Adaptive Noise Detection Based Control for Grid Supportive Solar PV Systems
384Investigation into Transient Performance of VSI-Fed Induction Motor Drives
385Stability Analysis for DC Microgrid Clusters with Primary and Secondary Controllers
386Hybrid AC-DC Microgrids Unified Control for DC-AC Interlinking Converters
387Dynamic Active and Reactive Power Tuning in Interconnected AC Microgrids
388Coordinated Distributed MPC for Power System Load Frequency Control with Wind Farms
389Single-Phase Boost Rectifiers with Sinusoidal Input Current
390Simplified Series Active Power Filters Design
391Induction Motors Online Simplified Rotor Resistance Estimator
392AC–DC Converters Harmonic Mitigation for Vector Controlled Induction Motor Drives
393Advanced Multilevel Inverter Topology for Maximum Voltage and Minimum DC Sources
394Series Voltage Regulator for Distribution Transformers to Compensate Voltage Sag/Swell
395Photovoltaic Grid-Connected Resonant Inverter Simulation for Parallel Loads
396Stability Analysis of Hybrid Multi Infeed HVDC System Connected between Offshore Wind Farms and Power Grids
397Finite-Time Consensus Algorithm for DC Microgrid Cluster Coordination
398Demand Response Predictive Control in Active Distribution Networks
399Modular Tri-port High-Power Converter for SRM-Based Plug-in Hybrid Electrical Trucks
400Advanced Voltage Support and Active Power Flow Control in Unbalanced Grid-Connected Converters
401Optimal Current Control Technique for Dual Stator Winding Induction Generators
402Novel DVR Based on Diode-Clamped Modular Multilevel Converters
403Autonomous Wind-DG Microgrid Back Propagation Algorithm Based Controller
404Decentralized Control Architecture for DC Nanogrid Clusters
405DFIG Based Wind Turbine System Fault Estimation using Adaptive Observer
406Standalone Solar Photo-Voltaic Hybrid System Control and Implementation
407SVC Switching ANN-Based Distribution Level for Minimal-Injected Harmonics.
408Large PV Power Plants Power Ramp Limitation Capabilities with Active Power Reserves
409State of Charge Hybrid Estimation for LFP Batteries
410Extremum Seeking Control for Global MPP Tracking under Partial Shading in PV Arrays
411Harmonic Current Compensation Limits of Three-Phase Multifunctional Photovoltaic Converters
412Special Applications 84-Pulse VSC Configuration Using Multi-Level DC Voltage Reinjection
413Enhanced Virtual Synchronous Generator Control for Microgrid Parallel Inverters
414Quasi-Z-Source Topology Based Single-Phase AC–AC Converter
415Three-Phase DSTATCOM Fast-Acting DC-Link Voltage Controller to Compensate AC and DC Loads
416Doubly-Fed Wind Power Generation Systems Synchronous Flux Weakening Control
417VSC-Based HVDC Transmission Systems Subsynchronous Resonance Investigation
418D-STATCOM Enhancement of Power Quality in Distribution System
419Unified Power Quality Conditioner Model Predictive Control with Control Saturation
420Single-Stage Three-Phase Grid-Tied PV System with Universal Filtering Capability
421Boost-Buck Converter Based High-Efficiency Robust PV Inverter Derivation
422Dual Stator-Winding Induction Generator Asymmetrical Operation Analysis with Unbalanced Loads
423Multilevel Inverter for Power Conditioning in Four-Wire Distribution Systems Using Solar Photovoltaic Array
424Power Controlling and Management in Grid-Connected Systems
425Buck Converter Fuzzy Logic Control for Photovoltaic Emulator
426DSTATCOM Application for Voltage Sag Mitigation in Isolated Distribution Systems with Motor Loads
427UPQC Signal Detection Algorithm Based on PSO-Fuzzy Logic
428Power Quality Improvement Using Shunt Active Filter
429Dual Buck Inverter with Series Connected Diodes and Single Inductor
430Control Methodology for a Photovoltaic System Interfaced with a Distribution Network
431High Gain Bidirectional DC-DC Converter Operation for Photovoltaic On-grid Systems
432Unified Control and Power Management for Hybrid Microgrids
433Boost Converter Based Single-Phase PFC Topologies Review
434Doubly Fed Induction Generators Performance Analysis in Weak Power Systems
435Single-Phase Voltage-Controlled Grid-Connected Photovoltaic System with Power Quality Conditioner Functionality
436Torque Ripple Control in Non-Ideal Permanent Magnet Brushless Motors
437Dynamic Modelling and Control of Single Side Short Stator Linear Induction Motors
438Optimal Distributed Energy Storage System Operation in Distribution Networks
  • Latest Electrical Projects Ideas
  • Agriculture Engineering Projects List​
  • LED Projects for Electronics Students
  • Automobile Engineering Projects
  • Renewable Energy Projects for Students
Top 100 Industrial Internet of Things Projects (IIoT)
Top 300 Arduino Projects for Engineering Students
200 Raspberry Pi Projects
Top 100 Biomedical Instrumentation Engineering Projects for Students
ECE Projects – IEEE and IoT Projects List
100 VHDL Projects for Engineering Students
Top 100 Power Systems Projects – Electrical Engineering
100 Instrumentation Projects for Final Year Engineering Students
Top 100 DTMF Based Projects, Topics and Ideas
170+ Agriculture Engineering Projects List​
300+ Free Electronics Projects & Ideas
Top 100 LabVIEW Projects for Engineering Students
600+ Digital Image Processing Projects – DIP Project Ideas
ESP8266 WiFi Module Projects for Engineering Students
Analytical Instrumentation Engineering Projects
Top 100 Analytical Instrumentation Engineering Projects
GSM Based Projects
GSM Based Projects – Ideas and Topics
LED Projects for Engineering Students
Home Automation Project Ideas
Pneumatic and Hydraulic Projects
200 Pneumatic and Hydraulic Projects List
Top 100 Proteus Design Suite Projects for Engineering Students
VLSI Projects for Engineering Students
700+ VLSI Projects for Engineering Students
Ohm Meter Circuit
Ohm Meter
Emergency Block Valve
SIS Emergency Block Valves (EBV)
Pressure Gauge Installation
Pressure Gauge Installation at Pump Discharge
2-wire loop-powered transmitter
Loop Controller HART Signal Noise
HART Communication Problems
Hydrogen Sulfide Accident
The Aghorn Hydrogen Sulfide Accident – H2S Gas
Pressure Temperature Compensation Flow Measurement
Protection Relays Interview Questions & Answers
