Reading: Power Supply Circuit Working Animation
Inst Tools > Blog > Electronics Animation > Power Supply Circuit Working Animation
Last updated: September 21, 2016 12:02 pm
1 Min Read
How to design a DC Power supply?
The first step of Power supply Design is Stepping Down the AC current into a lower voltage.
This is done by a Step Down Transformer.
Now we need to remove the Alternating Waves and make a DC Current from it.
For this purpose we will use a Bridge rectifier, in which the AC will be converted into DC.
Even if it is rectified, there will be some fluctuations in the output.
This can be removed by connecting a Capacitor Parallel, as it will not pass the DC and pass only the AC Current.
Thus the AC current will be bypassed through the Capacitor to the Ground and we will obtain a Direct Current signal at the output.
Now you can use this DC current for various applications.
In the image, the moving arrows shows that they are AC and constant arrows shows the DC.
JFET Working Animation
Forward Bias & Reverse Bias Diode Working Animation
Transistor as a Switch Working Principle
Center Tapped Full Wave Rectifier Operation
Half Wave Rectifier Principle
  • Pardeep ATTRI says:
    January 30, 2017 at 10:22 am
    Thanks Reddy sir u are giving so much knowledge .All student will always thankful to you always .Salute to you
Ethernet Bus Animation
Token Ring and Token Bus Working Animation
Optocouplers Working Principle
Full Wave Bridge Rectifier Operation
LC Tuned circuit Working Animation
