Reading: LC Tuned circuit Working Animation
Inst Tools > Blog > Electronics Animation > LC Tuned circuit Working Animation
Last updated: September 21, 2016 12:04 pm
1 Min Read
Animated diagram showing the operation of a tuned circuit (LC circuit). This is an improvement over previous versions of this animation which uses variable frame display times to show a more realistic movement of the charge.
A tuned circuit is a very simple electronic circuit widely used in audio, radio and television equipment. It consists of an inductor L (coil of wire, left) and acapacitor C (right) connected together. Tuned circuits can store electrical energy oscillating at its resonant frequency. The capacitor stores energy in its electric field E and the inductor stores energy in its magnetic field B (green).
LC Tuned circuit
When the capacitor is charged with electricity and connected to the coil, the charge flows back and forth between the capacitor’s plates as a current i (red) through the coil as shown. This jerky animation shows “snapshots” of the circuit at progressive points in the oscillation. The oscillations are slowed down; in an actual tuned circuit the charge oscillates back and forth hundreds of thousands to billions of times per second.
Transistor as a Switch Working Principle
Optocouplers Working Principle
Forward Bias & Reverse Bias Diode Working Animation
Power Supply Circuit Working Animation
Center Tapped Full Wave Rectifier Operation
Full Wave Bridge Rectifier Operation
Ethernet Bus Animation
Token Ring and Token Bus Working Animation
Half Wave Rectifier Principle
JFET Working Animation
