Reading: Comparison of HVDC transmission and HVAC transmission
Inst Tools > Blog > Transmission & Distribution > Comparison of HVDC transmission and HVAC transmission
Last updated: September 19, 2016 2:28 am
1 Min Read
DC transmission has some advantages over AC transmission, but it cannot completely replace ac transmission system due to some limitations
High Cost:
  1. The converters required at both the ends of the line are much more expensive than conventional equipment.
  2. The converters produce lot of harmonics both on dc and ac sides which may cause interference with the audio frequency communication lines. Filtering and smoothing equipments are provided at the converter station in order to remove ripples from the dc output. It is also possible to provide filters at the ac side to absorb the harmonic current. These considerably increases the cost of converter substation
  3. HVDC converters need complex cooling system
  4. Cost of HVDC circuit breaker is higher compared to ac breakers
  5. Converters have very little over load capacity and absorb considerable amount of reactive power.
Maintenance of insulators in HVDC transmission line is more Circuit breaking in multi-terminal dc systems is difficult and costlier
Therefore because of the cost factors HVDC transmission is economical if bulk amount of power (1500-6000MW) transmitting over large distance (beyond 500kms) compared to HVAC transmission
Difference between Solid Conductor and Stranded Conductor
Electrical Power Transmission And Distribution
Advantages of Suspension Insulators and Pin type Insulators
Charging Currents in Transmission Lines
Surge Impedance Loading of Transmission Line
Insulating Material for Cable Requirements
Current Limiting Reactors in Power System
Classification of Transmission Lines
Single Phase Earth Return System Advantages & Disadvantages
Advantages of Bundled Conductors in Transmission Lines
Electrical Power Distribution
Advantages & Disadvantages of AC and DC Power Transmission
Conductor Size Selection in Distribution Power System
Advantages of HVDC transmission
overview-of-communication-protocols
Industrial Automation Communication Protocols
Paddle Wheel Flow Meter
Paddle Wheel Flow Meters – Principle, Advantages, Limitations
Digital Electronics Objective Questions – Set 6
Displacement Sensing Accelerometer
Seismic Displacement Sensing Accelerometer
Ohms Law Equation
Ohms Law Calculator
Tunnel Diode
Tunnel Diode Working Principle
AC Voltage Controllers Multiple Choice Questions
Double Block and Bleed Valves Opening or Closing Sequence
