Reading: Harmonics effect on Transformer
Inst Tools > Blog > Power Systems > Harmonics effect on Transformer
Last updated: September 19, 2016 5:00 am
Power Systems
1 Min Read
Harmonics distortion effect on Power System and their impact on Induction Motors are already discussed.
Some of the disadvantages of harmonics and their impact on the transformers are:
  • RMS current increase
  • Eddy Current loss increases
  • DC offset current saturation
RMS current Increase:
Harmonics currents in the system will increase the RMS current in the transformers. This increase in the RMS current will increase the losses (copper losses) in the transformer which results in the reduction of the overall efficiency of the transformer
Eddy Current Loss Increase:
Eddy currents loss is proportional to the square of the applied frequency. As the harmonic components will have the frequencies of the order of multiples of the fundamental frequency eddy current losses will increase with the presence of the harmonic components in the current and voltage waveforms. Therefore because of the increase in the eddy current loss overall efficiency of the transformer comes down. Harmonic component also increase the temperature of the windings.
DC offset current saturation:
Due to the presence of dc component in the harmonics tend to saturate the core of the transformer.
Current Limiting Reactors and Short Circuit Currents
Advantages & Disadvantages of AC power and DC power
Voltage Variations Effects on Power Plant Equipment
Auto Recloser Circuit Breaker in Power System
Harmonics effect on Induction Motor
Advantages and Disadvantages of Per Unit System
Rotor Angle Stability of Synchronous Generators in Power System
Harmonics Disadvantages in Power System
Reactive Power Sources and Sinks in Power System
Electrical Power System Protection Quiz
Silicon Carbide Lightning Arresters Working Principle
shunt-capacitor-advantages-in-power-system
Shunt Capacitor Advantages in Power System
neutral-grounding-practice-in-power-system
Neutral Grounding Practice in Power System
Corona-Ring-on-Surge-Arresters
why-reactive-power-is-generated-at-load
Why Reactive Power is Generated at Load
Shunt Vs Series Capacitors Advantages
why-symmetrical-components-used
Why Symmetrical Components Used for Unbalanced faults in Power System
Why Grounding
Generating Station Grounding Principles
Underground Cable Fault Identification Methods
Radiometric level Principle
Radiometric level measurement Working Principle
Siemens PLC Write Protection
How to Protect Siemens PLC using Password?
Siemens Profibus Interface DP
How to Create New Project Using Simatic Manager
Metal Foil Strain Gauge Principle
Pulse Generation using Timer in Siemens PLC
Stability in Frequency Domain
Preliminary Considerations of Classical Design
Identification of Equipment Standards
