Reading: Harmonics Disadvantages in Power System
Inst Tools > Blog > Power Systems > Harmonics Disadvantages in Power System
Last updated: September 21, 2016 10:35 am
Power Systems
1 Min Read
Sources of Harmonics:
Several sources of harmonic currents that may be found on electrical power distribution networks are listed below:
  • Variable speed motor drives
  • Rectifiers
  • Arc furnaces
  • Wielding equipment
  • Uninterrupted power supplies
  • Switching mode power supplies
  • Compact fluorescent lamps
  • Electronic ballasts
Disadvantages of Harmonics:
Harmonics degrades the performance of power system. Some of the disadvantages of harmonics in the power distributed network are listed below:
  • The harmonics flowing in the distribution network downgrade the quality of the electrical power supply. There can have several negative effects on the operation of the power system
  • Increased losses on the distribution system due to increase in the effective rms current
  • Over-load in neutral conductors due to cumulative increase in the third harmonics created by the single phase loads
  • Overloads, vibration and premature ageing of the generators, transformers and motors as well as increase in the noise level
  • Overloads and premature ageing of the power factor correction capacitors
  • Distortion of the supply voltage that can disturb the operation of the sensitive loads
  • Disturbances in the communication networks and telephone lines
  • Resonance between the supply inductance and capacitance of the power factor correction capacitors
Generating Station Grounding Principles
Underground Cable Fault Identification Methods
Why Symmetrical Components Used for Unbalanced faults in Power System
Silicon Carbide Lightning Arresters Working Principle
Harmonics effect on Transformer
Ungrounded or Isolated Neutral System Disadvantages
Electrical Power System Protection Quiz
Advantages & Disadvantages of AC power and DC power
Shunt Vs Series Capacitors Advantages
Why Reactive Power is Generated at Load
Auto Recloser Circuit Breaker in Power System
Rotor Angle Stability of Synchronous Generators in Power System
Current Limiting Reactors and Short Circuit Currents
Advantages and Disadvantages of Per Unit System
shunt-capacitor-advantages-in-power-system
Shunt Capacitor Advantages in Power System
Transformer Tap changer
harmonics-effect-on-induction-motor
Harmonics effect on Induction Motor
neutral-grounding-practice-in-power-system
Neutral Grounding Practice in Power System
Reactive Power Sources and Sinks in Power System
Electromagnetic Subject Quiz
ON OFF Valve Parts
ON OFF Valve Preventive Maintenance and Testing Procedure
Magnetic Flow Meter Liner Damaged
Magnetic Flow Meter Liner Damaged and Winding Burnt
Two Electrode Conductivity Probes
Two Electrode Conductivity Probes Principle
Interview on Flow Measurement
Interview Questions on Flow Measurement
4-Bit Parallel Adder and Subtractor Objective Questions
Modern Instrumentation & IoT: Key Innovations & Trends
PLC Ladder Logic Door Open and Closing System
Which Language is Best for PLC Programming?
