In this article, we shared the economics of power generation objective questions and answers for electrical and electronics engineers.
Economics of Power Generation
The below list provides all the multiple-choice questions (MCQ) and online test quiz related to the economics of power generation.
1. The load factor of the domestic load is usually
| A) | 60 to 70% |
| B) | 50 to 60% |
| C) | 30 to 40% |
| D) | 10 to 15% |
2. Which of the following source of power is least reliable?
| A) | Geothermal power |
| B) | Wind power |
| C) | Solar energy |
| D) | MHD |
3. Which of the following is not a method for estimating depreciation charges?
| A) | Sinking fund method |
| B) | Halsey’s 50-50 formula |
| C) | Diminishing value method |
| D) | Straight-line method |
4. For a high value of diversity factor, a power station of given installed capacity will be in a position to supply
| A) | more number of consumers |
| B) | neither less number of consumers nor more number of consumers |
| C) | either less number of consumers or more number of consumers |
| D) | less number of consumers |
5. Annual depreciation of the plant is proportional to the earning capacity of the plant vide
| A) | reducing balances depreciation |
| B) | sinking fund depreciation |
| C) | straight-line depreciation |
| D) | none of these answers |
6. The expected useful life of a hydroelectric power station is around
| A) | 60 years |
| B) | 100 years |
| C) | 15 years |
| D) | 30 years |
7. In a load curve the highest point represents
| A) | peak demand |
| B) | average demand |
| C) | none of these answers |
| D) | diversified demand |
8. ____ can generate power at unpredictable or uncontrolled times.
| A) | Wind power plant |
| B) | Any of these answers |
| C) | Solar power plant |
| D) | Tidal power plant |
9. Anything having some heating value can be used as fuel in case of
| A) | closed cycle gas turbines |
| B) | open cycle gas turbines |
| C) | diesel engines |
| D) | petrol engines |
10. Which of the following are not repayable after a stipulated period?
| A) | Shares |
| B) | Fixed deposits |
| C) | Bonds |
| D) | Cash certificates |
11. Which of the following are not repayable after a stipulated period?
| A) | Fixed deposits |
| B) | Shares |
| C) | Cash certificates |
| D) | Bonds |
12. Which of the following component, in a steam power plant needs maximum maintenance attention?
| A) | Water treatment plant |
| B) | Steam turbine |
| C) | Condenser |
| D) | Boiler |
13. Static capacitors are rated in terms of
| A) | kW |
| B) | kVAR |
| D) | kWh |
14. For a diesel generating station the useful life is expected to be around
| A) | 15 to 20 years |
| B) | 50 to 75 years |
| C) | 75 to 100 years |
| D) | 20 to 50 years |
15. Ships are generally powered by
| A) | hydraulic turbines |
| B) | none of these answers |
| D) | steam accumulators |
| E) | nuclear power plants |
16. Load shedding is possible through which of the following?
| A) | Voltage reduction |
| C) | Switching of the loads |
| D) | Frequency reduction |
17. Which of the following is not a source of power?
| A) | Thermocouple |
| B) | Solar cell |
| C) | Photovoltaic cell |
| D) | Photoelectric cell |
18. For a power plant which of the following constitutes running cost?
| A) | All of these answers |
| B) | Cost of lubricants |
| C) | Cost of wages |
| D) | Cost of fuel |
19. For a consumer the most economical power factor is generally
| A) | 0.5 leading |
| B) | 0.5 lagging |
| C) | 0.95 leading |
| D) | 0.95 lagging |
20. Annual operating expenditure of a power plant consists of
| A) | all of these answers |
| B) | semi-fixed charges |
| C) | running charges |
| D) | fixed charges |
21. A pilot exciter is provided on generators for which of the following reasons?
| A) | None of these answers |
| B) | To excite the poles of main exciter |
| C) | To provide requisite starting torque to generator |
| D) | To provide requisite starting torque to main exciter |
22. A load curve indicates
| A) | average kWh (kW) energy consumption during the period |
| B) | average power used during the period |
| D) | either average power used during the period or average kWh (kW) energy consumption during the period |
23. The primary reason for the low power factor is supply system is due to installation of
| A) | induction motors |
| B) | d.c. motors |
| C) | synchronous motors |
| D) | single phase motors |
24. A synchronous condenser is virtually which of the following?
| A) | Over excited synchronous motor |
| B) | None of these answers |
| C) | Under excited synchronous motor |
| D) | Induction motor |
| E) | D.C. generator |
25. ____ will offer the least load.
| A) | Hair dryer |
| B) | Television |
| C) | Electric shaver |
| D) | Vacuum cleaner |
26. Annual depreciation as per straight line method, is calculated by
| A) | the capital cost minus the salvage value, is divided by the number of years of life |
| B) | the capital cost divided by number of year of life |
| D) | increasing a uniform sum of money per annum at a stipulated rate of interest |
27. Generators for peak load plants are usually designed for maximum efficiency at
| A) | full load |
| B) | 50 to 75 percent full load |
| C) | 25 percent overload |
| D) | 25 to 50 percent full load |
28. Low power factor is usually not due to
| B) | arc lamps |
| C) | incandescent lamp |
| D) | fluorescent tubes |
29. ____ power plant cannot have a single unit of 100 MW.
| A) | Diesel |
| C) | Hydroelectric |
| D) | Nuclear |
30. Large capacity generators are invariably
| A) | forced air cooled |
| B) | hydrogen cooled |
| C) | natural air cooled |
| D) | water cooled |
31. Direct conversion of heat into electric power is possible through
| A) | thermionic converter |
| B) | batteries |
| C) | fuel cell |
| D) | all of these answers |
32. The area under the daily load curve divided by 24 hours gives
| A) | least load |
| B) | total kWh generated |
| C) | peak demand |
| D) | average load |
33. In ____ fuel transportation cost is least.
| A) | none of these answers |
| B) | steam power stations |
| C) | diesel generating plants |
| D) | nuclear power plants |
34. In India production and distribution of electrical energy is confined to
| A) | public sector |
| B) | government sectors |
| C) | joint sector |
| E) | private sector |
35. In which of the following power plants the maintenance cost is usually high?
| A) | Thermal power plants |
| B) | Nuclear power plant |
| C) | Hydro-electric power plants |
| D) | Diesel engine power plants |
36. During load shedding
| A) | system voltage is reduced |
| B) | system frequency is reduced |
| C) | some loads are switched off |
| D) | system power factor is changed |
37. Diversity factor has a direct effect on the
| A) | both fixed cost, of unit generated and running cost of unit generated |
| B) | running cost of unit generated |
| C) | neither fixed cost, of unit generated ​ nor running cost of unit generated |
| D) | fixed cost, of unit generated |
38. Which of the following is the disadvantage of static capacitors for power factor improvement?
| A) | Short service life |
| B) | All of these answers |
| C) | Cannot be repaired |
| D) | Easily damaged by high voltage |
39. In an interconnected system, the diversity factor of the whole system
| B) | decreases |
| C) | increases |
| D) | remains unchanged |
40. Which of the following is not a method for estimating depreciation charges?
| A) | Diminishing value method |
| C) | Straight line method |
| D) | Sinking fund method |
41. Load factor of a power station is defined as
| A) | maximum demand/average load |
| B) | average load/maximum demand |
| C) | average load X maximum demand |
| D) | (average load X maximum demand​)1/2​ |
42. Submarines for underwater movement, are powered by which of the following?
| A) | Air motors |
| B) | Steam accumulators |
| C) | Diesel engines |
| D) | Batteries |
43. In a distribution system, in order to improve power factor, synchronous capacitors are installed
| A) | either at the receiving end or at the sending end |
| B) | at the receiving end |
| D) | at the sending end |
44. ___ offers the highest electric load.
| A) | Washing machine |
| B) | Vacuum cleaner |
| C) | Toaster |
| D) | Television set |
45. Which of the following, in a thermal power plant, is not a fixed cost?
| A) | Insurance charges |
| B) | Interest on capital |
| C) | Fuel cost |
| D) | Depreciation |
46. ____ is the reserved generating capacity available for service under emergency conditions which is not kept in operation but in working order.
| A) | Hot reserve |
| B) | Cold reserve |
| C) | Firm power |
| D) | Spinning reserve |
47. Power generation cost reduces as
| A) | diversity factor decreases and load factor increases |
| B) | diversity factor increases and load factor decreases |
| C) | both diversity factor as well as load factor decrease |
| D) | both diversity factor as well as load factor increase |
48. Submarines for underwater movement, are powered by which of the following?
| A) | Diesel engines |
| B) | Air motors |
| C) | Steam accumulators |
| D) | Batteries |
49. Load curve is useful in deciding the
| A) | the total installed capacity of the plant |
| B) | all of these answers |
| C) | operating schedule of generating units |
| D) | sizes of generating units |
50. Load curve of a power plant has always
| A) | zero slope |
| B) | positive slope |
| C) | negative slope |
| D) | any combination of zero slope, positive slope and negative slope |
51. The increased load during the summer months is due to
| A) | increased business activity |
| B) | increased use of fans and air conditioners |
| C) | increased water supply |
52. Annual depreciation cost is calculated by
| A) | sinking fund method |
| B) | both sinking fund method and straight line method |
| D) | straight line method |
53. With reference to a power station which of the following is not a fixed cost?
| A) | Depreciation |
| B) | Fuel cost |
| C) | Interest on capital |
| D) | Insurance charges |
54. A company can raise funds through
| A) | fixed deposits |
| B) | shares |
| C) | bonds |
| D) | any of these answers |
55. Which plant can never have 100 percent load factor?
| A) | Hydro electric plant |
| B) | Peak load plant |
| C) | Nuclear power plant |
| D) | Base load plant |
56. The efficiency of a plant is of least concern when it is selected as
| A) | peak load plant |
| B) | either peak load plant or casual run plant |
| C) | casual run plant |
| D) | base load plant |
57. In a power plant if the maximum demand on the plant is equal to the plant capacity, then
| A) | load factor will be unity |
| B) | plant reserve capacity will be zero |
| C) | load factor will be nearly 60% |
| D) | diversity factor will be unity |
58. Maximum demand on a power plant is
| A) | both the greatest of all “short time interval averaged” demand during a period or instantaneous maximum value of kVA supplied during a period |
| B) | instantaneous maximum value of kVA supplied during a period |
| C) | the greatest of all “short time interval averaged” demand during a period |
59. ____ is invariably used as base load plant.
| A) | Gas turbine plant |
| C) | Diesel engine plant |
| D) | Pumped storage plant |
60. For any type of consumer the ideal tariff is
| A) | block rate tariff |
| B) | three part tariff |
| C) | two part tariff |
61. ____ power plant is expected to have the longest life.
| A) | Hydroelectric |
| B) | Steam |
| C) | Any of these answers |
| D) | Diesel |
62. Which of the following is the essential requirement of a peak load plant?
| A) | It should produce high voltage |
| B) | It should be small in size |
| C) | It should be capable of starting quickly |
| D) | It should run at high speed |
63. Direct conversion of heat into electrical energy is possible through
| A) | fuel cells |
| B) | MHD generators |
| D) | solar cells |
64. Maximum demand tariff is generally not applied to domestic consumers because
| A) | they consume less power |
| B) | their maximum demand is low |
| D) | their load factor is low |
65. ___ industry has the least power consumption per tonne of product.
| A) | Soap |
| B) | Sugar |
| C) | Vegetable oil |
| D) | Caustic soda |
66. Which of the following plants is almost inevitably used as base-load plant?
| A) | Pumped storage plant |
| C) | Gas turbine plant |
| D) | Diesel engine plant |
67. Salvage value of the plant is always
| A) | positive |
| B) | negative |
| C) | any of these answers |
| D) | zero |
68. For which of the following power plants highly skilled engineers are required for running the plants?
| A) | Solar power plants |
| B) | Gas turbine power plants |
| C) | Nuclear power plants |
| D) | Hydro-electric power plants |
69. ___ is invariably used for peak load
| C) | Pumped storage plant |
| D) | Steam turbine plant |
70. Which of the following place is not associated with nuclear power plants in India?
| A) | Kota |
| B) | Narora |
| C) | Banglore |
| D) | Tarapur |
71. When the demand of consumers is not met by a power plant, it will resort to which of the following?
| A) | Efficient plant operation |
| B) | Penalizing high load consumers by increasing the charges for electricity |
| C) | Load shedding |
| D) | Power factor improvement at the generators |
72. Which of the following may not be the effect of the low plant operating power factor?
| A) | Reduced voltage level |
| B) | Overloaded transformers |
| C) | Improved illumination from the lighting |
| D) | Overloaded cables |
73. Generating capacity connected to the bus bars and ready to take load when switched on is known as ____
| A) | firm power |
| B) | hot reserve |
| C) | spinning reserve |
| D) | cold reserve |
74. When a plant resorts to load shedding it can be concluded that
| A) | peak demand is more than the installed capacity |
| B) | the diversity factor is zero |
| C) | daily load factor is unity |
| D) | the plant is under repairs |
75. An induction motor has a relatively high power factor at
| A) | near full load |
| C) | no load |
| D) | rated r.p.m. |
| E) | 20 percent load |
76. Air will not be the working substance in which of the following?
| A) | Petrol engine |
| B) | Closed cycle gas turbine |
| C) | Open cycle gas turbine |
| D) | Diesel engine |
77. Annual depreciation cost is calculated by
| B) | both sinking fund method and straight-line method |
78. For the same maximum demand, if the load factor is decreased, the cost of generation will
| B) | decrease |
| C) | remain unchanged |
| D) | increase |
79. Which of the following is an advantage of static capacitors for power factor improvement?
| A) | Little maintenance cost |
| C) | Low losses |
| D) | Ease in installation |
80. Which of the following devices may be used to provide protection against lightning overvoltages?
| B) | Rod gaps |
| C) | Horn gaps |
| D) | Surge absorbers |
81. ____ public sector undertaking is associated with erection and sometimes running of thermal power plants
| A) | SAIL |
| B) | BHEL |
| C) | BEL |
| D) | NTPC |
82. In two part tariff, variation in load factor will affect
| A) | either fixed charges or operating or running charges |
| B) | fixed charges |
| C) | operating or running charges |
| D) | both fixed charges and operating or running charges |
83. The knowledge of diversity factor helps in determining
| A) | kWh generated |
| C) | average load |
| D) | peak load |
| E) | plant capacity |
84. Base load plants usually have ____ capital cost,____ operating cost and ____ load factor.
| A) | low, high, low |
| B) | high, high, high |
| C) | high, low, high |
| D) | low, low, low |
85. The area under a load curve gives
| A) | maximum demand |
| B) | energy consumed |
| C) | average demand |
86. Which of the following equipment provides fluctuating load?
| A) | Lathe machine |
| C) | Welding transformer |
| D) | Exhaust fan |
87. For cooling of large size generators hydrogen is used because
| B) | it offers reduced fire risk |
| C) | it is light |
| D) | it has high thermal conductivity |
88. An alternator coupled to a ____ runs at slow speed, as compared to others
| A) | gas turbine |
| B) | hydraulic turbine |
| C) | steam turbine |
| D) | diesel engine |
89. If the tariff for electrical energy charges provides incentive by way of reduced charges for higher consumption, then it can be concluded that
| A) | power is generated through a hydroelectric plant |
| B) | load factor is unity |
| C) | plant has sufficient reserve capacity |
| D) | station has more than two generators |
90. ____ will be least affected due to charge in supply voltage frequency.
| A) | Room heater |
| B) | Mixer grinder |
| C) | Electric clock |
| D) | Ceiling fan |
91. A low utilization factor for a plant indicates that
| A) | plant is used for stand by purpose only |
| B) | plant is under maintenance |
| C) | plant is used for base load only |
| D) | plant is used for peak load as well as base load |
92. In Hopknison demand rate or two part tariff the demand rate or fixed charges are
| A) | dependent upon the energy consumed |
| B) | dependent upon the maximum demand of the consumer |
| C) | both dependent upon the energy consumed and dependent upon the maximum demand of the consumer |
| D) | neither dependent upon the energy consumed nor dependent upon the maximum demand of the consumer |
93. Which lightning stroke is most dangerous?
| A) | Direct stroke on tower top |
| B) | Direct stroke on ground wire |
| C) | Indirect stroke on conductor |
| D) | Direct stroke on line conductor |
94. Demand factor is defined as
| A) | maximum demand/connected load |
| B) | connected load/maximum demand |
| C) | average load/maximum load |
| D) | average load X maximum load |
95. Which of the following is the disadvantage due to low power factor ?
| A) | Poor voltage regulation |
| C) | High cost of equipment for a given load |
| D) | Increased transmission losses |
96. Approximate estimation of power demand can be made by
| A) | economic parameters |
| B) | load survey method |
| C) | statistical methods |
| D) | mathematical method |
| E) | all of these answers |
97. The least share of power is provided in India, by which of the following power plants?
| B) | Diesel power plants |
| D) | Nuclear power plants |
98. Which of the following generating station has minimum running cost ?
| A) | Diesel |
| B) | Thermal |
| C) | Nuclear |
| D) | Hydro |
99. A 130 MW generator is usually ____ cooled
| A) | oxygen |
| B) | air |
| C) | hydrogen |
| D) | nitrogen |
100. Efficiency is the secondary consideration in which of the following plants?
| B) | Base load plants |
| C) | Peak load plants |
| D) | Both Base load plants and Peak load plants |
101. The connected load of a domestic consumer is around
| A) | 40 kW |
| B) | 5 kW |
| C) | 80 kW |
| D) | 120 kW |
102. Load shedding is done to
| A) | reduce peak demand |
| B) | repair the machine |
| C) | improve power factor |
| D) | run the equipment efficiently |
103. Following power plant has instant starting
| B) | diesel power plant |
| C) | hydropower plant |
| D) | both hydro power plant and diesel power plant |
| E) | nuclear power plant |
104. Depreciation charges are high in case of
| A) | diesel plant |
| C) | hydroelectric plant |
| D) | thermal plant |
105. The depreciation charges in diminishing value method are
| A) | same in all years |
| B) | heavy in later years |
| C) | light in early years |
| D) | heavy in early years |
106. Which of the following is not an operating cost?
| A) | Salaries of operating staff |
| B) | Fuel cost |
| C) | Maintenance cost |
| D) | Salaries of high officials |
107. Which of the following is not necessarily an advantage of interconnecting various power stations ?
| A) | Economy in operation of plants |
| B) | Improved frequency of power supplied |
| C) | Increased reliability |
| D) | Reduction in total installed capacity |
108. A nuclear power plant is invariably used as a
| A) | base load plant |
| B) | peak load plant |
| C) | stand-by plant |
| E) | spinning reserve plant |
109. Which of the following is the disadvantage of a synchronous condenser ?
| A) | Continuous losses in motor |
| B) | High maintenance cost |
| C) | All of these answers |
| D) | Noise |
110. For the same cylinder dimensions and speed, which of the following engine will produce least power ?
| A) | Diesel engine |
| C) | Supercharged engine |
| D) | Petrol engine |
111. A power transformer is usually rated in
| A) | kWh |
| B) | kVA |
| C) | kVAR |
| D) | kW |
112. Major share of power produced in India is through
| A) | hydroelectric power plants |
| B) | nuclear power plants |
| C) | diesel power plants |
| D) | thermal power plants |
113. Maximum demand tariff is generally not applied to domestic consumers because
| A) | their load factor is low |
| C) | they consume less power |
| D) | their maximum demand is low |
114. Most efficient plants are normally used as
| B) | base load plants |
| C) | either peak load plants or base load plants |
| D) | peak load plants |
115. In case of ____ fuel transportation is the major problem.
| A) | diesel power plants |
| B) | hydro-electric power plants |
| C) | thermal power plants |
116. Diversity factor is always
| A) | more than fifty |
| B) | less than unity |
| C) | more than unity |
| D) | equal to unity |
117. By the use of which of the following power factor can be improved?
| A) | Synchronous compensators |
| B) | Static capacitors |
| C) | Phase advancers |
| D) | Any of these answers |
118. The effect of electric shock on human body depends on which of the following
| A) | duration of contact |
| B) | current |
| C) | voltage |
119. Which of the following power plants need the least period for installation ?
| A) | Diesel power plant |
| B) | Hydro-electric power plant |
| C) | Thermal power plant |
| D) | Nuclear power plant |
120. An over excited synchronous motor on no-load is known as
| A) | alternator |
| B) | synchronous condenser |
| C) | induction motor |
| D) | generator |
Click Here for Answers
