Reading: Differences between Watts and Volt Amps
Inst Tools > Blog > Electrical Basics > Differences between Watts and Volt Amps
Last updated: September 19, 2016 1:30 am
Electrical Basics
As you would know, electrical products generally indicate both to show how much energy and current they draw.
So herewith a quick summary of the differences with some interesting alternative calculations to work out total VA (I am waiting for the deluge of critiques from my electrical brotherhood).
Real Power – Watts
Real power is measured in watts (or W). One watt is the consumption or generation of energy at the rate of one joule per second. This is what you as a consumer generally pay your electrical utility in kilowatt-hours (a 60W light bulb left on for 10 hours consumes 0.6 kWh).
We have a surprisingly wide range of charges throughout the world for kilowatt-hour charges. For example (for 2011 in US cents), in India it is 8c/kWh against Denmark where it is 41c/kWh (perhaps – and I am speculating here – they are paying for the enormous investment in wind energy). Other interesting ones are Australia (29c/kWh), UK (20c/kWh)  and South Africa and Canada (10c/kWh). People building aluminium smelters would consider these numbers as they would make a big difference to a business case.
Watts are calculated by W = volts (rms) x amps (rms) x cos (phi) where phi is the angle between the current and voltage for ac circuits (cos (phi) is often referred to as the power factor).  Rms volts refers to root mean square voltage (which is peak volts divided by square root of 2).
For dc circuits, this simply becomes W = V (dc) x I (dc) .
When calculating the real power for multiple devices; you simply add the watts for each appliance.
The measurement of watts does require specialized equipment where both voltage and current needs to be measured over a specific time. A standard multimeter is not much help here.
Apparent Power – Volt-Amperes (VA)
VA = volts (rms) x amps (rms)
or for dc  VA = V (dc) x I (dc)
Volt amps are very important for calculating current draw (and is essential to know in sizing cables). So to work out the current draw of a device; you simply take the VA and divide by rms voltage.
For example, you have a device which is rated at 500VA (maximum VA the device will draw). If it is supplied by a 230Vrms ac line; you would calculate maximum current as 500 VA/230Vrm = 2.2amps (rms). You must ensure your wires and associated circuits can cope with 2.2amps (rms).
Adding VA
Unfortunately (apart from direct current circuits); you can’t simply add the VA rating of devices to come up with the total VA rating. This is because the currents for each device are not necessarily in phase with each other.
But – importantly – you can add up the individual VA ratings to get a conservative figure since the actual total (calculated correctly) will always be less than or equal to this value.
Power Factor
Power factor is always between zero and 1 because watts (real power) is always less than or equal to volt amperes. As you electrical types know, it is possible to have a voltage across a device (e.g. capacitor) and to draw a significant current (and thus need to rate the cables correctly for this current) but to consume no energy (zero watts).
As far as kWh are concerned, Earl Wilson remarked: Benjamin Franklin may have discovered electricity, but it was the man who invented the meter who made the money.
Volts vs Watts
What is a Relay? Types of Industrial Relays
Difference between AC and DC
Difference between Stepper Motor and Servo Motor
Transformers Coolers Weld Joints Oil Oozes Were Eye Sores
Difference Between Core and Shell Transformers
What is a Current Transformer?
Acceptable Earth Resistance Values
Motor Protection Circuits
Types of Relays used in an Air Circuit Breaker (ACB)
Difference Between Alternator and Generator?
Circuit Breaker Working Principle Animation
Difference Between Wattmeter and Energy Meter
Difference Between Trunking and Conduit
Electrical Voltage and current Signals
Difference between RCCB and RCBO
Advantages of Star and Delta Systems
Instrument Cable
Difference Between Power Cable and Instrument Cable
Star and Delta Wiring Animation
Electrical Drives Animation
Auto Changeover Switch
What is an Auto Changeover Switch?
What's the problem with shock and vibration
What’s the problem with shock and vibration ?
Chlorine dioxide measurement principle
Chlorine dioxide Analyzer Principle
Measurement of Xd and Xq – Synchronous Machine
Infrared Flue Gas Analyser
What is Infrared Flue Gas Analyzer? – Working Principle
Simatic Hardware Configuration
Configuration of Profibus Network in Siemens PLC
SC connector
Top Electrical Engineering Interview Questions for Freshers
gate-valve-principle-animation
Basics of Gate Valves
