Reading: Current Limiting Reactors and Short Circuit Currents
Inst Tools > Blog > Power Systems > Current Limiting Reactors and Short Circuit Currents
Last updated: September 20, 2016 2:15 pm
Power Systems
3 Min Read
A current limiting reactors is also called as series reactors. It is an inductive coil having large inductive reactance compared to the resistance and is used to limit the short circuit current during fault conditions. These reactors are connected in feeders and ties, in generator leads and between the bus sections to reduce the magnitude of the short circuit current. The reactor allow free interchange of power under normal condition. however during fault condition the disturbance is confined to only faulty location.As the resistance of the reactors are small compared to reactance the efficiency of the system is not affected much
Short circuit current is reduced by an increase in the reactance of the system. Short circuit current depends on the generating capacity, voltage at the fault point and the total reactance between the generating point and the fault location. Breaking capacity of the circuit breaker depends on the magnitude of the fault current. If the fault current is beyond the designed limit of the breaking capacity of the breaker, the fault cannot be extinguish. Therefore in large interconnected power system large number of generators and motors feed the fault on occurrence of the fault. Therefore at times the magnitude of the short circuit current exceeds the breaking capacity of the breaker. Therefore it is necessary to limit the fault current by some means. By including a reactor or few reactors at some strategic locations, short circuit currents at different points can be reduced.
Advantages:
  • Protective reactors are used to reduce the flow of short circuit current at the fault point so as to protect the apparatus from excessive mechanical stresses and from over heating and thus protect the system as a whole
  • Protective systems are used to reduce the voltage disturbances caused by the short circuits
  • They also localize the fault by limiting the current that flow in to the fault from other healthy feeders or parts of the system thereby avoiding the fault by spreading
  • It helps to reduce the duty imposed on the switching equipment during fault conditions
Disadvantages:
  • Total percentage reactance of the system increases thereby causing increase in reactive voltage drop and decrease in power factor due to increased angle of lag. Thus regulation of the system becomes poor.
Why Symmetrical Components Used for Unbalanced faults in Power System
Neutral Grounding Practice in Power System
Voltage Variations Effects on Power Plant Equipment
Harmonics effect on Transformer
Ungrounded or Isolated Neutral System Disadvantages
Rotor Angle Stability of Synchronous Generators in Power System
Electrical Power System Protection Quiz
Silicon Carbide Lightning Arresters Working Principle
Why Reactive Power is Generated at Load
Shunt Capacitor Advantages in Power System
Harmonics effect on Induction Motor
Underground Cable Fault Identification Methods
Reactive Power Sources and Sinks in Power System
harmonics-disadvantages-in-power-system
Harmonics Disadvantages in Power System
Advantages & Disadvantages of AC power and DC power
Auto Recloser Circuit Breaker in Power System
Corona-Ring-on-Surge-Arresters
Advantages and Disadvantages of Per Unit System
Shunt Vs Series Capacitors Advantages
Transformer Tap changer
Hydrazine analyzer Working Principle
Hydrazine Analyzer Working Principle
Types of Industrial Storage Batteries
liquid flow control system
Practical Process Control System Questions & Answers – 7
Industrial Star Delta Starter for 3-Phase Induction Motor
Star Delta Starter – Working, Circuit, Advantages, Disadvantages
open vs closed loop
Open Loop and Closed Loop Animation
Controller Output Current Loop
DCS Controllers to Output Current Loops
foundation-fieldbus-vs-profibus
Comparison between Foundation Fieldbus and Profibus
PLC Tag Naming Conventions
