Reading: Corona Ring on Surge Arresters and other EHV equipment
Inst Tools > Blog > Power Systems > Corona Ring on Surge Arresters and other EHV equipment
Last updated: September 19, 2016 4:48 am
Power Systems
1 Min Read
Have you ever seen a ring around the SurgeĀ ArresterĀ or other EHV equipment? What is the purpose of the Ring around the Extra High Voltage (EHV) equipment? What is the use of big rings at EHV testing centers?
Corona Ring:
This Metal Ring what we see in the substations and other transmission line network is “Corona Ring”. At higher voltages such as in EHV transmission networks corona discharge effect is prominent. Corona Ring distributes the electrical potential gradient evenly and maintains the maximum value below the threshold limits of the corona effect. Corona Rings are employed at high altitude electrical equipment where density of the air is less.
Corona-Ring-on-Surge-Arresters
Generating Station Grounding Principles
Auto Recloser Circuit Breaker in Power System
Why Reactive Power is Generated at Load
Harmonics Disadvantages in Power System
Rotor Angle Stability of Synchronous Generators in Power System
Why Symmetrical Components Used for Unbalanced faults in Power System
Electrical Power System Protection Quiz
Shunt Capacitor Advantages in Power System
Ungrounded or Isolated Neutral System Disadvantages
Shunt Vs Series Capacitors Advantages
Harmonics effect on Induction Motor
Underground Cable Fault Identification Methods
harmonics-effect-on-transformer
Harmonics effect on Transformer
Advantages and Disadvantages of Per Unit System
Silicon Carbide Lightning Arresters Working Principle
current-limiting-reactors-and-short-circuit-currents
Current Limiting Reactors and Short Circuit Currents
neutral-grounding-practice-in-power-system
Neutral Grounding Practice in Power System
Advantages & Disadvantages of AC power and DC power
Voltage Variations Effects on Power Plant Equipment
Percentage-to-Current-Conversion
Formula to Calculate 4-20ma from Percentage
Safety Instrumented System (SIS) Worksheets
Safety Instrumented System (SIS) Worksheets and Documents
Troubleshooting Ultrasonic Flow Meter Common Problems
Totally Enclosed Fan Cooled (TEFC) Motor
Totally Enclosed Fan Cooled (TEFC) Motors Rampant Winding Burnouts
Tunnel Diode
Tunnel Diode Working Principle
Asymmetric capillary for Level Measurement
Effects of Symmetric and Asymmetric Capillary Tube Pressure Measurement
PLC Program for Valves
PLC Pump Permissive Interlocks
Tips for Reducing the Noise Signals
